Date/Time: Thu, 22 Oct 2026 17:10:12 +0000
Trial User needs Service Package to create DOMs, Footprints and Market Profiles?
View Count: 14
| [2026-10-22 15:38:21] |
| User510765 - Posts: 3 |
As a Trial User, I have a few setup questions... 1) As a Trial User, can I create chartbooks for the E-Mini S&P 500 Futures? Chartbooks such as: DOM Footprint Market Profile Even in a delayed time format? Or do I need to get myself registered for one of the Service Packages such as I believe Service Package #10? Which will allow me to have access to the Denali Data Feed & Teton Futures Order Routing? If the answer to this is YES, then I would have to set up an account with GFF Brokers (A division of Stage 5), deposit a minimum, select Teton Routing in my Service Package #10...and then have access to create DOMs Footprints Market Profiles I'd just like to know if I can create with the Trial or do I need to activate a Service Package, then create a GFF account for access to Denali which will then give me the feeds I need to start using Sierra Chart properly? Thanks very much! Marc |
| [2026-10-22 16:39:12] |
| John - SC Support - Posts: 48299 |
While on a Trial, you have limited data. The E-Mini S&P 500 from the CME Group (ES) is not available during the Trial. Refer to the following: Sierra Chart Trial Account If you really need the data for ES, then you would have to change to a paid package. With any paid package, you have access to the historical data for all symbols that Sierra Chart supports (including ES) as well as our Delayed Streaming Data. For the CME Group, the data is delayed by 10 minutes and 10 seconds, but otherwise acts like real-time data. You can also use our Delayed Streaming data with our Simulated Futures Trading Service. If the Delayed Streaming data will suffice for you for now, then you would also want to be on one of the "Base" packages. Specifically, since you state you want Market Profiles, you would need to be on the "Base Advanced" package. Refer to the information at the following link: Description of Service Packages and Pricing The only reason you would need to be on one of the "Integrated" packages and open a brokerage account is if you want the real-time data for the CME Group at the non-professional rates. Refer to the following: Denali Exchange Data Feed: Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
