Date/Time: Thu, 22 Oct 2026 02:23:18 +0000
SC Data is not working
View Count: 45
[2026-10-21 20:43:27]
nottjaay - Posts: 2
Hello, my Sierra Chart trial is active until November 11, 2026, and my email is verified. However, the Data/Trade Service Settings dropdown still shows “SC Data (Not enabled on package).” My charts are blank and the Message Log shows “Symbol not allowed: FreeTrialSymbols.” Could you please check my trial data access and explain how I can load a supported MES symbol using the trial? Thank you.
[2026-10-21 21:53:15]
John - SC Support - Posts: 48289
Please use the "Forced Login" option and see if this resolves the issue for you:
Sierra Chart - Software Login Instructions: Forced Login
