Date/Time: Sat, 28 Nov 2026 03:04:42 +0000
Question for John in support
View Count: 308
[2026-10-08 16:30:52]
User922418 - Posts: 42
John
Two questions:
1) how do I add a horizontal line to this chart (See attached picture)?
2) how do I get rid of the volume valley's near the high and low of the chart but keep the volume valley lines in the middle of the chart?
Private File
[2026-10-08 16:39:21]
1) There are multiple methods to add a horiztonal line. Refer to the following two options specifically:
Chart Drawing Tools: Horizontal Line | Horizontal Ray | Horizonal Line Non-Extended | Vertical Line
Horizontal Lines
2) There is the following option to control Peaks and Valleys at the extremes:
Volume By Price Study: Include High/Low in Peaks and Valleys
But that is the only option. There is no method to control within a certain range from High or Low.
[2026-10-08 17:37:26]
John
I appreciate you so much.
This is the second picture I wanted to upload, but for whatever reason, it didn't load in my first post
Private File
[2026-10-08 18:06:56]
The only option available to control where the Peaks and Valleys show is the following:
