Date/Time: Sat, 18 May 2024 20:37:21 +0000
Switched from AMP account to Direct payment with Interactive Brokers feed
View Count: 1199
[2014-11-06 23:42:57] |
User976523 - Posts: 1 |
Hello, I used to use Sierra Chart with an AMP Futures account, but I stopped using it several months ago. Now I want to use it with my Interactive Brokers feed, or another feed, and I can't figure out how to set SC to the different user account. It wants to automatically log in to the unfunded/unsupported AMP account even though I have purchased credit for SC directly with another username/account. It doesn't matter if I switch brokers in the broker/data feeds drop down menu. How do I reset this in Sierra? Thanks - Japhy |
[2014-11-07 01:55:08] |
See: Sierra Chart - Software Login Instructions: Login with a Different Sierra Chart Account Name Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
