Date/Time: Mon, 19 Oct 2026 13:36:10 +0000
Problem of CQG WebAPI connection
View Count: 2141
[2014-11-05 06:42:40]
Thib - Posts: 54
Hello SC,
I can't connecto to CQG WebAPI with 1209 Prerelaese. I only can connect to CQG FIX trading (but without real time data feed of course).
Connection timed out. Will disconnect and retry. | 2014-11-05 07:33:00 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-11-05 07:33:00
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-11-05 07:33:00
Socket (928) | SSL shutdown indicates not able to send 'close notify'. | 2014-11-05 07:33:00
Socket (928) | SSL has been shut down. | 2014-11-05 07:33:00
Socket (928) | SSL object has been freed. SSL state is now disconnected. | 2014-11-05 07:33:00
Socket (928) | Shutdown and closed. | 2014-11-05 07:33:00
CQG WebAPI | Websocket closed. | 2014-11-05 07:33:00
CQG WebAPI | Disconnected. | 2014-11-05 07:33:00
Will reconnect to the server in 5.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-11-05 07:33:00
CQG WebAPI | Connecting to CQG web API. | 2014-11-05 07:33:05
Connecting to websocket server. | 2014-11-05 07:33:05
Socket (0) | Resolved address api.geo.cqg.com to IP 208.48.16.34 | 2014-11-05 07:33:05
Socket (772) | Connected. | 2014-11-05 07:33:05
Socket (772) | Starting SSL connection. | 2014-11-05 07:33:05
Socket (772) | SSL connection established. | 2014-11-05 07:33:06
Opening websocket. | 2014-11-05 07:33:06
Sending websocket handshake. | 2014-11-05 07:33:06
Received websocket handshake acknowledgment. | 2014-11-05 07:33:06
TRANSPORT OPEN | 2014-11-05 07:33:06
CQG WebAPI | Websocket connected. | 2014-11-05 07:33:06
CQG WebAPI | Sending market data logon message. | 2014-11-05 07:33:06
Problem parsing protocol buffer. | 2014-11-05 07:33:06 *
[2014-11-05 11:00:43]
We do not see this problem when connecting to CQG. So we will need to look further into this.
For now go back to the current release of Sierra Chart. Update with Help >> Download Current Version.
[2014-11-06 07:26:41]
User33803 - Posts: 40
I have exactly the same issue
[2014-11-06 08:42:58]
We apologize for this. The CQG live server does not support the the protocol definition file that CQG sent us and it will not for about a month. We had not known that.
This whole thing is hard to believe.
Go back to the current version of Sierra Chart. Perform the download with Help >> Download Current Version.
[2014-11-11 17:22:40]
I have tested Release 1210 with CQG Web API and it worked fine for around 4 hours but lately I am having problems with sent orders (they appear, disappear, appear again, I am not able to cancel them, then I am able...)
On the other hand, I am investigating if using CQG Web API has a higher cost per contract traded and a lower fixed monthly cost. In this case, I would prefer using the old CQG trading scheme. Now, in Release 1210, if you choose CQG FIX trading you have no Market Data. Is it possible to have the option of choosing between the CQG Web API and the "old" CQG trading in coming releases? Now I have to get back to Release 1205.
Date Time Of Last Edit: 2014-11-11 17:24:18
[2014-11-11 18:34:11]
In order for us to solve this problem, we need to see the order lines in the Trade Activity Log for one of the orders that is doing this. Provide them by following these instructions:
Trade Activity Log: Providing Trade Activity Log Data Lines to Support
We will look into this.
Date Time Of Last Edit: 2014-11-11 18:34:53
[2014-11-11 18:48:50]
The issue is that when the order disappear or reappear it seems that it does not leave any trace in the TAL. The orders are maintained in the TOP windows but they disappear from the chart. If you close SC and open it again than the order reappear in the Chart but after some minutes they suddenly disappear (but they are still showing in the TOP window). Sometimes I can cancel them from the TOP window, sometimes not. It is a really strange behaviour.
I had to install Release 1205 in order to cancel and close some orders/positions with the old "CQG Trading". That is why you could see some "mess" in the TAL lines I am including.
You'll see XXXXXXX in the place of the "Trade Account" when I used CQG WebAPI and YYYYYYY when I used "CQG Trading" or "CQG FIX". I am supplying a lot of lines because I use to understand every line of the TAL and its meaning but in this case I haven't been able, sorry.
ActivityType  DateTime  Symbol  Quantity  FillPrice  PositionQuantity  BuySell  FilledQuantity  OrderStatus  Price  OrderType  InternalOrderID  ServiceOrderID  OrderActionSource  Price2  TradeAccount  OpenClose  ParentInternalOrderID  FillExecutionServiceID
Order  2014-11-11 17:15:01.000  F.US.CLEZ14        Sell    Pending Child  78.25  Limit  99214     : F.US.CLEZ14 15 Min #2| |BuyEntry | Last: 77.029999. Attached Order    XXXXXXXXXXXXXX  Close  99213
Order  2014-11-11 17:15:01.001  F.US.CLEZ14        Sell    Pending Child  77.65  Stop  99215     : F.US.CLEZ14 15 Min #2| |BuyEntry | Last: 77.029999. Attached Order    XXXXXXXXXXXXXX  Close  99213
Order  2014-11-11 17:15:01.002  F.US.CLEZ14  2      Buy    Order Sent  77.90  Stop  99213     : F.US.CLEZ14 15 Min #2| |BuyEntry | Last: 77.029999    XXXXXXXXXXXXXX  Open
Order  2014-11-11 17:15:01.003  F.US.CLEZ14        Buy    Pending Child  76.31  Limit  99217     : F.US.CLEZ14 15 Min #2| |SellEntry | Last: 77.029999. Attached Order    XXXXXXXXXXXXXX  Close  99216
Order  2014-11-11 17:15:01.004  F.US.CLEZ14        Buy    Pending Child  76.90  Stop  99218     : F.US.CLEZ14 15 Min #2| |SellEntry | Last: 77.029999. Attached Order    XXXXXXXXXXXXXX  Close  99216
Order  2014-11-11 17:15:01.005  F.US.CLEZ14  2      Sell    Order Sent  76.65  Stop  99216     : F.US.CLEZ14 15 Min #2| |SellEntry | Last: 77.029999    XXXXXXXXXXXXXX  Open
Order  2014-11-11 17:15:01.006  F.US.EPZ14      -2  Sell    Pending Child  2049.50  Limit  99220     : F.US.EPZ14 15 Min #4| |BuyEntry | Last: 2037.25. Attached Order    XXXXXXXXXXXXXX  Open  99219
Order  2014-11-11 17:15:01.007  F.US.EPZ14      -2  Sell    Pending Child  2036.50  Stop  99221     : F.US.EPZ14 15 Min #4| |BuyEntry | Last: 2037.25. Attached Order    XXXXXXXXXXXXXX  Open  99219
Order  2014-11-11 17:15:01.008  F.US.EPZ14  2    -2  Buy    Order Sent  2042.25  Stop  99219     : F.US.EPZ14 15 Min #4| |BuyEntry | Last: 2037.25    XXXXXXXXXXXXXX  Close
Order  2014-11-11 17:15:01.009  F.US.EPZ14      -2  Buy    Pending Child  2022.75  Limit  99223     : F.US.EPZ14 15 Min #4| |SellEntry | Last: 2037.25. Attached Order    XXXXXXXXXXXXXX  Close  99222
Order  2014-11-11 17:15:01.010  F.US.EPZ14      -2  Buy    Pending Child  2035.75  Stop  99224     : F.US.EPZ14 15 Min #4| |SellEntry | Last: 2037.25. Attached Order    XXXXXXXXXXXXXX  Close  99222
Order  2014-11-11 17:15:01.011  F.US.EPZ14  2    -2  Sell    Order Sent  2030.00  Stop  99222     : F.US.EPZ14 15 Min #4| |SellEntry | Last: 2037.25    XXXXXXXXXXXXXX  Open
Order  2014-11-11 17:15:01.012  F.US.CLEZ14  2      Buy    Pending Open  77.90  Stop  99213  482896915  CQG order update (In Transit)    XXXXXXXXXXXXXX  Open
Order  2014-11-11 17:15:01.013  F.US.CLEZ14  2      Buy    Open  77.90  Stop  99213  482896915  CQG order update (Ack Place)    XXXXXXXXXXXXXX  Open
Order  2014-11-11 17:15:01.014  F.US.CLEZ14  2      Sell    Pending Open  76.65  Stop  99216  483011048  CQG order update (In Transit)    XXXXXXXXXXXXXX  Open
Order  2014-11-11 17:15:01.015  F.US.CLEZ14  2      Sell    Open  76.65  Stop  99216  483011048  CQG order update (Ack Place)    XXXXXXXXXXXXXX  Open
Order  2014-11-11 17:15:01.016  F.US.EPZ14  2    -2  Buy    Pending Open  2042.25  Stop  99219  482907011  CQG order update (In Transit)    XXXXXXXXXXXXXX  Close
Order  2014-11-11 17:15:01.017  F.US.EPZ14  2    -2  Buy    Open  2042.25  Stop  99219  482907011  CQG order update (Ack Place)    XXXXXXXXXXXXXX  Close
Order  2014-11-11 17:15:01.018  F.US.EPZ14  2    -2  Sell    Pending Open  2030.00  Stop  99222  482911854  CQG order update (In Transit)    XXXXXXXXXXXXXX  Open
Order  2014-11-11 17:15:01.019  F.US.EPZ14  2    -2  Sell    Open  2030.00  Stop  99222  482911854  CQG order update (Ack Place)    XXXXXXXXXXXXXX  Open
Order  2014-11-11 17:15:01.020  F.US.JY6Z14        Sell    Pending Child  0.008682  Limit  99226     : F.US.JY6Z14 15 Min #5| |BuyEntry | Last: 0.0086420001. Attached Order    XXXXXXXXXXXXXX  Close  99225
Order  2014-11-11 17:15:01.021  F.US.JY6Z14        Sell    Pending Child  0.008648  Stop  99227     : F.US.JY6Z14 15 Min #5| |BuyEntry | Last: 0.0086420001. Attached Order    XXXXXXXXXXXXXX  Close  99225
Order  2014-11-11 17:15:01.022  F.US.JY6Z14  2      Buy    Order Sent  0.008665  Stop  99225     : F.US.JY6Z14 15 Min #5| |BuyEntry | Last: 0.0086420001    XXXXXXXXXXXXXX  Open
Order  2014-11-11 17:15:01.023  F.US.JY6Z14        Buy    Pending Child  0.008592  Limit  99229     : F.US.JY6Z14 15 Min #5| |SellEntry | Last: 0.0086420001. Attached Order    XXXXXXXXXXXXXX  Close  99228
Order  2014-11-11 17:15:01.024  F.US.JY6Z14        Buy    Pending Child  0.008626  Stop  99230     : F.US.JY6Z14 15 Min #5| |SellEntry | Last: 0.0086420001. Attached Order    XXXXXXXXXXXXXX  Close  99228
Order  2014-11-11 17:15:01.025  F.US.JY6Z14  2      Sell    Order Sent  0.008609  Stop  99228     : F.US.JY6Z14 15 Min #5| |SellEntry | Last: 0.0086420001    XXXXXXXXXXXXXX  Open
Order  2014-11-11 17:15:01.026  F.US.JY6Z14  2      Buy    Pending Open  0.008665  Stop  99225  482956477  CQG order update (In Transit)    XXXXXXXXXXXXXX  Open
Order  2014-11-11 17:15:01.027  F.US.JY6Z14  2      Buy    Open  0.008665  Stop  99225  482956477  CQG order update (Ack Place)    XXXXXXXXXXXXXX  Open
Order  2014-11-11 17:15:01.028  F.US.JY6Z14  2      Sell    Pending Open  0.008609  Stop  99228  482882803  CQG order update (In Transit)    XXXXXXXXXXXXXX  Open
Order  2014-11-11 17:15:01.029  F.US.JY6Z14  2      Sell    Open  0.008609  Stop  99228  482882803  CQG order update (Ack Place)    XXXXXXXXXXXXXX  Open
Order  2014-11-11 17:15:01.230  F.US.CLEZ14  2      Buy    Open  77.90  Stop  99306  482896915  CQG order update (Ack Place)    XXXXXXXXXXXXXX
Order  2014-11-11 17:15:01.257  F.US.CLEZ14  2      Sell    Open  76.65  Stop  99349  483011048  CQG order update (Ack Place)    XXXXXXXXXXXXXX
Order  2014-11-11 17:15:01.340  F.US.EPZ14  2    -2  Buy    Open  2042.25  Stop  99343  482907011  CQG order update (Ack Place)    XXXXXXXXXXXXXX
Order  2014-11-11 17:15:01.393  F.US.EPZ14  2    -2  Sell    Open  2030.00  Stop  99355  482911854  CQG order update (Ack Place)    XXXXXXXXXXXXXX
Order  2014-11-11 17:15:01.630  F.US.JY6Z14  2      Buy    Open  0.008665  Stop  99264  482956477  CQG order update (Ack Place)    XXXXXXXXXXXXXX
Order  2014-11-11 17:15:01.720  F.US.JY6Z14  2      Sell    Open  0.008609  Stop  99292  482882803  CQG order update (Ack Place)    XXXXXXXXXXXXXX
Order  2014-11-11 17:15:02.000  F.US.USAZ14        Buy    Pending Child  140 22/32  Limit  99232     : F.US.USAZ14 15 Min #3| |SellEntry | Last: 140.78125. Attached Order    XXXXXXXXXXXXXX  Close  99231
Order  2014-11-11 17:15:02.001  F.US.USAZ14        Buy    Pending Child  141 11/32  Stop  99233     : F.US.USAZ14 15 Min #3| |SellEntry | Last: 140.78125. Attached Order    XXXXXXXXXXXXXX  Close  99231
Order  2014-11-11 17:15:02.002  F.US.USAZ14  2      Sell    Order Sent  141 2/32  Limit  99231     : F.US.USAZ14 15 Min #3| |SellEntry | Last: 140.78125    XXXXXXXXXXXXXX  Open
Order  2014-11-11 17:15:02.003  F.US.USAZ14        Sell    Pending Child  141 0/32  Limit  99235     : F.US.USAZ14 15 Min #3| |BuyEntry | Last: 140.78125. Attached Order    XXXXXXXXXXXXXX  Close  99234
Order  2014-11-11 17:15:02.004  F.US.USAZ14        Sell    Pending Child  140 11/32  Stop  99236     : F.US.USAZ14 15 Min #3| |BuyEntry | Last: 140.78125. Attached Order    XXXXXXXXXXXXXX  Close  99234
Order  2014-11-11 17:15:02.005  F.US.USAZ14  2      Buy    Order Sent  140 20/32  Limit  99234     : F.US.USAZ14 15 Min #3| |BuyEntry | Last: 140.78125    XXXXXXXXXXXXXX  Open
Order  2014-11-11 17:15:02.006  F.US.USAZ14  2      Sell    Pending Open  141 2/32  Limit  99231  482911855  CQG order update (In Transit)    XXXXXXXXXXXXXX  Open
Order  2014-11-11 17:15:02.007  F.US.USAZ14  2      Sell    Open  141 2/32  Limit  99231  482911855  CQG order update (Ack Place)    XXXXXXXXXXXXXX  Open
Order  2014-11-11 17:15:02.008  F.US.USAZ14  2      Buy    Pending Open  140 20/32  Limit  99234  482946452  CQG order update (In Transit)    XXXXXXXXXXXXXX  Open
Order  2014-11-11 17:15:02.009  F.US.USAZ14  2      Buy    Open  140 20/32  Limit  99234  482946452  CQG order update (Ack Place)    XXXXXXXXXXXXXX  Open
Order  2014-11-11 17:15:02.317  F.US.USAZ14  2      Sell    Open  141 2/32  Limit  99356  482911855  CQG order update (Ack Place)    XXXXXXXXXXXXXX
Order  2014-11-11 17:15:02.390  F.US.USAZ14  2      Buy    Open  140 20/32  Limit  99275  482946452  CQG order update (Ack Place)    XXXXXXXXXXXXXX
Order  2014-11-11 17:15:09.000  F.US.GCEZ14        Sell    Pending Child  1161.5  Limit  99238     : F.US.GCEZ14 15 Min #1| |BuyEntry | Last: 1155. Attached Order    XXXXXXXXXXXXXX  Close  99237
Order  2014-11-11 17:15:09.001  F.US.GCEZ14        Sell    Pending Child  1154.5  Stop  99239     : F.US.GCEZ14 15 Min #1| |BuyEntry | Last: 1155. Attached Order    XXXXXXXXXXXXXX  Close  99237
Order  2014-11-11 17:15:09.002  F.US.GCEZ14  1      Buy    Order Sent  1158.0  Stop  99237     : F.US.GCEZ14 15 Min #1| |BuyEntry | Last: 1155    XXXXXXXXXXXXXX  Open
Order  2014-11-11 17:15:09.003  F.US.GCEZ14        Buy    Pending Child  1148.2  Limit  99241     : F.US.GCEZ14 15 Min #1| |SellEntry | Last: 1155. Attached Order    XXXXXXXXXXXXXX  Close  99240
Order  2014-11-11 17:15:09.004  F.US.GCEZ14        Buy    Pending Child  1155.2  Stop  99242     : F.US.GCEZ14 15 Min #1| |SellEntry | Last: 1155. Attached Order    XXXXXXXXXXXXXX  Close  99240
Order  2014-11-11 17:15:09.005  F.US.GCEZ14  1      Sell    Order Sent  1151.7  Stop  99240     : F.US.GCEZ14 15 Min #1| |SellEntry | Last: 1155    XXXXXXXXXXXXXX  Open
Order  2014-11-11 17:15:09.006  F.US.GCEZ14  1      Buy    Pending Open  1157.9  Stop  99237  483011051  CQG order update (In Transit)    XXXXXXXXXXXXXX  Open
Order  2014-11-11 17:15:09.007  F.US.GCEZ14  1      Buy    Open  1157.9  Stop  99237  483011051  CQG order update (Ack Place)    XXXXXXXXXXXXXX  Open
Order  2014-11-11 17:15:09.008  F.US.GCEZ14  1      Sell    Pending Open  1151.6  Stop  99240  482887483  CQG order update (In Transit)    XXXXXXXXXXXXXX  Open
Order  2014-11-11 17:15:09.009  F.US.GCEZ14  1      Sell    Open  1151.6  Stop  99240  482887483  CQG order update (Ack Place)    XXXXXXXXXXXXXX  Open
Order  2014-11-11 17:15:09.387  F.US.GCEZ14  1    1  Sell    Open  1151.6  Stop  99322  482887483  CQG order update (Ack Place)    XXXXXXXXXXXXXX
Fill  2014-11-11 17:25:59.000  F.US.GCEZ14  1  1158.4    Buy    Filled      99237  99237.1.483011051  CQG fills data (Restored). Exchange Order ID: 483011051    YYYYYYYYYYYYYYY      483011051
Order  2014-11-11 17:25:59.000  F.US.GCEZ14  1  1158.4    Buy  1  Filled  1157.9  Stop  99237  483011051  CQG order update (Fill)    XXXXXXXXXXXXXX  Open
Fill  2014-11-11 17:25:59.001  F.US.GCEZ14  1  1158.4  1  Buy  1  Filled  1157.9  Stop  99237  483011051  CQG order update (Fill)    XXXXXXXXXXXXXX  Open    21789080017
Order  2014-11-11 17:25:59.002  F.US.GCEZ14      1  Sell    Pending Modify  1161.5  Limit  99238    Modifying Attached Order from parent modification/fill. Ref price: 1158.4. New Price: 1161.9. Requested Price: 1161.9. Requested Quantity: 0    XXXXXXXXXXXXXX  Close  99237
Order  2014-11-11 17:25:59.003  F.US.GCEZ14      1  Sell    Pending Child  1161.9  Limit  99238    Order modified internally    XXXXXXXXXXXXXX  Close  99237
Order  2014-11-11 17:25:59.004  F.US.GCEZ14      1  Sell    Pending Modify  1154.5  Stop  99239    Modifying Attached Order from parent modification/fill. Ref price: 1158.4. New Price: 1154.9. Requested Price: 1154.9. Requested Quantity: 0    XXXXXXXXXXXXXX  Close  99237
Order  2014-11-11 17:25:59.005  F.US.GCEZ14      1  Sell    Pending Child  1154.9  Stop  99239    Order modified internally    XXXXXXXXXXXXXX  Close  99237
Order  2014-11-11 17:25:59.006  F.US.GCEZ14  1    1  Sell    Order Sent  1161.9  Limit  99238    Auto-sent child from parent fill    XXXXXXXXXXXXXX  Close  99237
Order  2014-11-11 17:25:59.007  F.US.GCEZ14  1    1  Sell    Order Sent  1154.9  Stop  99239    Auto-sent child from parent fill    XXXXXXXXXXXXXX  Close  99237
Order  2014-11-11 17:25:59.008  F.US.GCEZ14  1    1  Sell    Pending Open  1161.8  Limit  99238  482917281  CQG order update (In Transit)    XXXXXXXXXXXXXX  Close  99237
Order  2014-11-11 17:25:59.009  F.US.GCEZ14  1    1  Sell    Pending Open  1154.8  Stop  99239  482917282  CQG order update (In Transit)    XXXXXXXXXXXXXX  Close  99237
Order  2014-11-11 17:25:59.010  F.US.GCEZ14  1    1  Sell    Open  1161.8  Limit  99238  482917281  CQG order update (Ack Place)    XXXXXXXXXXXXXX  Close  99237
Order  2014-11-11 17:25:59.011  F.US.GCEZ14  1    1  Sell    Open  1154.8  Stop  99239  482917282  CQG order update (Ack Place)    XXXXXXXXXXXXXX  Close  99237
Order  2014-11-11 17:25:59.740  F.US.GCEZ14  1    1  Sell    Open  1161.8  Limit  99250  482917281  CQG order update (Ack Place)    XXXXXXXXXXXXXX
Order  2014-11-11 17:25:59.743  F.US.GCEZ14  1    1  Sell    Open  1154.8  Stop  99251  482917282  CQG order update (Ack Place)    XXXXXXXXXXXXXX
Order  2014-11-11 17:27:41.000  F.US.EPZ14  2    -2  Buy    Pending Cancel  2026.00  Limit  99052  482890384  Canceling due to no order update from server    XXXXXXXXXXXXXX  Open  99051
Order  2014-11-11 17:27:41.001  F.US.EPZ14  2    -2  Buy    Canceled  2026.00  Limit  99052  482890384  Canceling due to no order update from server    XXXXXXXXXXXXXX  Open  99051
Order  2014-11-11 17:27:41.002  F.US.EPZ14  2    -2  Buy    Pending Cancel  2039.00  Stop  99053  482205224  Canceling due to no order update from server    XXXXXXXXXXXXXX  Open  99051
Order  2014-11-11 17:27:41.003  F.US.EPZ14  2    -2  Buy    Canceled  2039.00  Stop  99053  482205224  Canceling due to no order update from server    XXXXXXXXXXXXXX  Open  99051
Order  2014-11-11 17:27:41.004  F.US.CLEZ14  2      Buy    Pending Cancel  77.90  Stop  99213  482896915  Canceling due to no order update from server    XXXXXXXXXXXXXX  Open
Order  2014-11-11 17:27:41.005  F.US.CLEZ14  2      Buy    Canceled  77.90  Stop  99213  482896915  Canceling due to no order update from server    XXXXXXXXXXXXXX  Open
Order  2014-11-11 17:27:41.006  F.US.CLEZ14        Sell    Pending Cancel  78.25  Limit  99214    Canceling child orders of internal order ID 99213    XXXXXXXXXXXXXX  Close  99213
Order  2014-11-11 17:27:41.007  F.US.CLEZ14        Sell    Canceled  78.25  Limit  99214    Canceling child orders of internal order ID 99213    XXXXXXXXXXXXXX  Close  99213
Order  2014-11-11 17:27:41.008  F.US.CLEZ14        Sell    Pending Cancel  77.65  Stop  99215    Canceling child orders of internal order ID 99213    XXXXXXXXXXXXXX  Close  99213
Order  2014-11-11 17:27:41.009  F.US.CLEZ14        Sell    Canceled  77.65  Stop  99215    Canceling child orders of internal order ID 99213    XXXXXXXXXXXXXX  Close  99213
Order  2014-11-11 17:27:41.010  F.US.CLEZ14  2      Sell    Pending Cancel  76.65  Stop  99216  483011048  Canceling due to no order update from server    XXXXXXXXXXXXXX  Open
Order  2014-11-11 17:27:41.011  F.US.CLEZ14  2      Sell    Canceled  76.65  Stop  99216  483011048  Canceling due to no order update from server    XXXXXXXXXXXXXX  Open
Order  2014-11-11 17:27:41.012  F.US.CLEZ14        Buy    Pending Cancel  76.31  Limit  99217    Canceling child orders of internal order ID 99216    XXXXXXXXXXXXXX  Close  99216
Order  2014-11-11 17:27:41.013  F.US.CLEZ14        Buy    Canceled  76.31  Limit  99217    Canceling child orders of internal order ID 99216    XXXXXXXXXXXXXX  Close  99216
Order  2014-11-11 17:27:41.014  F.US.CLEZ14        Buy    Pending Cancel  76.90  Stop  99218    Canceling child orders of internal order ID 99216    XXXXXXXXXXXXXX  Close  99216
Order  2014-11-11 17:27:41.015  F.US.CLEZ14        Buy    Canceled  76.90  Stop  99218    Canceling child orders of internal order ID 99216    XXXXXXXXXXXXXX  Close  99216
Order  2014-11-11 17:27:41.016  F.US.EPZ14  2    -2  Buy    Pending Cancel  2042.25  Stop  99219  482907011  Canceling due to no order update from server    XXXXXXXXXXXXXX  Close
Order  2014-11-11 17:27:41.017  F.US.EPZ14  2    -2  Buy    Canceled  2042.25  Stop  99219  482907011  Canceling due to no order update from server    XXXXXXXXXXXXXX  Close
Order  2014-11-11 17:27:41.018  F.US.EPZ14      -2  Sell    Pending Cancel  2049.50  Limit  99220    Canceling child orders of internal order ID 99219    XXXXXXXXXXXXXX  Open  99219
Order  2014-11-11 17:27:41.019  F.US.EPZ14      -2  Sell    Canceled  2049.50  Limit  99220    Canceling child orders of internal order ID 99219    XXXXXXXXXXXXXX  Open  99219
Order  2014-11-11 17:27:41.020  F.US.EPZ14      -2  Sell    Pending Cancel  2036.50  Stop  99221    Canceling child orders of internal order ID 99219    XXXXXXXXXXXXXX  Open  99219
Order  2014-11-11 17:27:41.021  F.US.EPZ14      -2  Sell    Canceled  2036.50  Stop  99221    Canceling child orders of internal order ID 99219    XXXXXXXXXXXXXX  Open  99219
Order  2014-11-11 17:27:41.022  F.US.EPZ14  2    -2  Sell    Pending Cancel  2030.00  Stop  99222  482911854  Canceling due to no order update from server    XXXXXXXXXXXXXX  Open
Order  2014-11-11 17:27:41.023  F.US.EPZ14  2    -2  Sell    Canceled  2030.00  Stop  99222  482911854  Canceling due to no order update from server    XXXXXXXXXXXXXX  Open
Order  2014-11-11 17:27:41.024  F.US.EPZ14      -2  Buy    Pending Cancel  2022.75  Limit  99223    Canceling child orders of internal order ID 99222    XXXXXXXXXXXXXX  Close  99222
Order  2014-11-11 17:27:41.025  F.US.EPZ14      -2  Buy    Canceled  2022.75  Limit  99223    Canceling child orders of internal order ID 99222    XXXXXXXXXXXXXX  Close  99222
Order  2014-11-11 17:27:41.026  F.US.EPZ14      -2  Buy    Pending Cancel  2035.75  Stop  99224    Canceling child orders of internal order ID 99222    XXXXXXXXXXXXXX  Close  99222
Order  2014-11-11 17:27:41.027  F.US.EPZ14      -2  Buy    Canceled  2035.75  Stop  99224    Canceling child orders of internal order ID 99222    XXXXXXXXXXXXXX  Close  99222
Order  2014-11-11 17:27:41.028  F.US.JY6Z14  2      Buy    Pending Cancel  0.008665  Stop  99225  482956477  Canceling due to no order update from server    XXXXXXXXXXXXXX  Open
Order  2014-11-11 17:27:41.029  F.US.JY6Z14  2      Buy    Canceled  0.008665  Stop  99225  482956477  Canceling due to no order update from server    XXXXXXXXXXXXXX  Open
Order  2014-11-11 17:27:41.030  F.US.JY6Z14        Sell    Pending Cancel  0.008682  Limit  99226    Canceling child orders of internal order ID 99225    XXXXXXXXXXXXXX  Close  99225
Order  2014-11-11 17:27:41.031  F.US.JY6Z14        Sell    Canceled  0.008682  Limit  99226    Canceling child orders of internal order ID 99225    XXXXXXXXXXXXXX  Close  99225
Order  2014-11-11 17:27:41.032  F.US.JY6Z14        Sell    Pending Cancel  0.008648  Stop  99227    Canceling child orders of internal order ID 99225    XXXXXXXXXXXXXX  Close  99225
Order  2014-11-11 17:27:41.033  F.US.JY6Z14        Sell    Canceled  0.008648  Stop  99227    Canceling child orders of internal order ID 99225    XXXXXXXXXXXXXX  Close  99225
Order  2014-11-11 17:27:41.034  F.US.JY6Z14  2      Sell    Pending Cancel  0.008609  Stop  99228  482882803  Canceling due to no order update from server    XXXXXXXXXXXXXX  Open
Order  2014-11-11 17:27:41.035  F.US.JY6Z14  2      Sell    Canceled  0.008609  Stop  99228  482882803  Canceling due to no order update from server    XXXXXXXXXXXXXX  Open
Order  2014-11-11 17:27:41.036  F.US.JY6Z14        Buy    Pending Cancel  0.008592  Limit  99229    Canceling child orders of internal order ID 99228    XXXXXXXXXXXXXX  Close  99228
Order  2014-11-11 17:27:41.037  F.US.JY6Z14        Buy    Canceled  0.008592  Limit  99229    Canceling child orders of internal order ID 99228    XXXXXXXXXXXXXX  Close  99228
Order  2014-11-11 17:27:41.038  F.US.JY6Z14        Buy    Pending Cancel  0.008626  Stop  99230    Canceling child orders of internal order ID 99228    XXXXXXXXXXXXXX  Close  99228
Order  2014-11-11 17:27:41.039  F.US.JY6Z14        Buy    Canceled  0.008626  Stop  99230    Canceling child orders of internal order ID 99228    XXXXXXXXXXXXXX  Close  99228
Order  2014-11-11 17:27:41.040  F.US.USAZ14  2      Sell    Pending Cancel  141 2/32  Limit  99231  482911855  Canceling due to no order update from server    XXXXXXXXXXXXXX  Open
Order  2014-11-11 17:27:41.041  F.US.USAZ14  2      Sell    Canceled  141 2/32  Limit  99231  482911855  Canceling due to no order update from server    XXXXXXXXXXXXXX  Open
Order  2014-11-11 17:27:41.042  F.US.USAZ14        Buy    Pending Cancel  140 22/32  Limit  99232    Canceling child orders of internal order ID 99231    XXXXXXXXXXXXXX  Close  99231
Order  2014-11-11 17:27:41.043  F.US.USAZ14        Buy    Canceled  140 22/32  Limit  99232    Canceling child orders of internal order ID 99231    XXXXXXXXXXXXXX  Close  99231
Order  2014-11-11 17:27:41.044  F.US.USAZ14        Buy    Pending Cancel  141 11/32  Stop  99233    Canceling child orders of internal order ID 99231    XXXXXXXXXXXXXX  Close  99231
Order  2014-11-11 17:27:41.045  F.US.USAZ14        Buy    Canceled  141 11/32  Stop  99233    Canceling child orders of internal order ID 99231    XXXXXXXXXXXXXX  Close  99231
Order  2014-11-11 17:27:41.046  F.US.USAZ14  2      Buy    Pending Cancel  140 20/32  Limit  99234  482946452  Canceling due to no order update from server    XXXXXXXXXXXXXX  Open
Order  2014-11-11 17:27:41.047  F.US.USAZ14  2      Buy    Canceled  140 20/32  Limit  99234  482946452  Canceling due to no order update from server    XXXXXXXXXXXXXX  Open
Order  2014-11-11 17:27:41.048  F.US.USAZ14        Sell    Pending Cancel  141 0/32  Limit  99235    Canceling child orders of internal order ID 99234    XXXXXXXXXXXXXX  Close  99234
Order  2014-11-11 17:27:41.049  F.US.USAZ14        Sell    Canceled  141 0/32  Limit  99235    Canceling child orders of internal order ID 99234    XXXXXXXXXXXXXX  Close  99234
Order  2014-11-11 17:27:41.050  F.US.USAZ14        Sell    Pending Cancel  140 11/32  Stop  99236    Canceling child orders of internal order ID 99234    XXXXXXXXXXXXXX  Close  99234
Order  2014-11-11 17:27:41.051  F.US.USAZ14        Sell    Canceled  140 11/32  Stop  99236    Canceling child orders of internal order ID 99234    XXXXXXXXXXXXXX  Close  99234
Order  2014-11-11 17:27:41.052  F.US.GCEZ14  1    1  Sell    Pending Cancel  1151.6  Stop  99240  482887483  Canceling due to no order update from server    XXXXXXXXXXXXXX  Open
Order  2014-11-11 17:27:41.053  F.US.GCEZ14  1    1  Sell    Canceled  1151.6  Stop  99240  482887483  Canceling due to no order update from server    XXXXXXXXXXXXXX  Open
Order  2014-11-11 17:27:41.054  F.US.GCEZ14      1  Buy    Pending Cancel  1148.2  Limit  99241    Canceling child orders of internal order ID 99240    XXXXXXXXXXXXXX  Close  99240
Order  2014-11-11 17:27:41.055  F.US.GCEZ14      1  Buy    Canceled  1148.2  Limit  99241    Canceling child orders of internal order ID 99240    XXXXXXXXXXXXXX  Close  99240
Order  2014-11-11 17:27:41.056  F.US.GCEZ14      1  Buy    Pending Cancel  1155.2  Stop  99242    Canceling child orders of internal order ID 99240    XXXXXXXXXXXXXX  Close  99240
Order  2014-11-11 17:27:41.057  F.US.GCEZ14      1  Buy    Canceled  1155.2  Stop  99242    Canceling child orders of internal order ID 99240    XXXXXXXXXXXXXX  Close  99240
Order  2014-11-11 17:27:41.058  F.US.GCEZ14  1    1  Sell    Pending Cancel  1161.8  Limit  99238  482917281  Canceling due to no order update from server    XXXXXXXXXXXXXX  Close  99237
Order  2014-11-11 17:27:41.059  F.US.GCEZ14  1    1  Sell    Canceled  1161.8  Limit  99238  482917281  Canceling due to no order update from server    XXXXXXXXXXXXXX  Close  99237
Order  2014-11-11 17:27:41.060  F.US.GCEZ14  1    1  Sell    Pending Cancel  1154.8  Stop  99239  482917282  Canceling due to no order update from server    XXXXXXXXXXXXXX  Close  99237
Order  2014-11-11 17:27:41.061  F.US.GCEZ14  1    1  Sell    Canceled  1154.8  Stop  99239  482917282  Canceling due to no order update from server    XXXXXXXXXXXXXX  Close  99237
Order  2014-11-11 17:30:31.000              Unspecified          Connected to server    None
Order  2014-11-11 17:30:43.000  F.US.EPZ14            Unspecified          Synchronized Internal Position to current Service Position. Current Position quantity: 0    XXXXXXXXXXXXXX
Order  2014-11-11 17:30:43.001  F.US.GCEZ14            Unspecified          Synchronized Internal Position to current Service Position. Current Position quantity: 0    XXXXXXXXXXXXXX
Order  2014-11-11 17:30:43.002  F.US.EPZ14            Unspecified          Synchronized Internal Position to current Service Position. Current Position quantity: -2    XXXXXXXXXXXXXX
Order  2014-11-11 17:30:43.003  F.US.GCEZ14            Unspecified          Synchronized Internal Position to current Service Position. Current Position quantity: 1    XXXXXXXXXXXXXX
Order  2014-11-11 17:31:07.000  F.US.GCEZ14  1    1  Sell    Pending Cancel  1151.6  Stop  99322  482887483  F.US.GCEZ14 15 Min #1 | User order cancel    XXXXXXXXXXXXXX
Order  2014-11-11 17:31:27.000  F.US.CLEZ14  2      Buy    Pending Cancel  77.90  Stop  99306  482896915  F.US.CLEZ14 15 Min #2 | User order cancel    XXXXXXXXXXXXXX
Order  2014-11-11 17:31:33.000  F.US.CLEZ14  2      Sell    Pending Cancel  76.65  Stop  99349  483011048  F.US.CLEZ14 15 Min #2 | User order cancel    XXXXXXXXXXXXXX
Fill  2014-11-11 17:32:48.000  F.US.GCEZ14  1  1161.8    Sell    Filled      99238  99238.1.482917281  CQG fills data (Restored). Exchange Order ID: 482917281    YYYYYYYYYYYYYYY      482917281
Fill  2014-11-11 17:32:48.077  F.US.GCEZ14  1  1161.8    Sell    Filled        482917281  CQG fills data (Restored). Exchange Order ID: 482917281    XXXXXXXXXXXXXX      21789102174
Order  2014-11-11 17:33:33.000              Unspecified          Connected to server    None
Order  2014-11-11 17:33:39.000  F.US.EPZ14            Unspecified          Synchronized Internal Position to current Service Position. Current Position quantity: 0    XXXXXXXXXXXXXX
Order  2014-11-11 17:33:39.001  F.US.GCEZ14            Unspecified          Synchronized Internal Position to current Service Position. Current Position quantity: 0    XXXXXXXXXXXXXX
Order  2014-11-11 17:33:40.000  F.US.CLEZ14  2      Buy    Open  77.90  Stop  99306  482896915  CQG order update (Status). Exchange ID: 807054207439    XXXXXXXXXXXXXX
Order  2014-11-11 17:33:40.001  F.US.CLEZ14  2      Sell    Open  76.65  Stop  99349  483011048  CQG order update (Status). Exchange ID: 807054207441    XXXXXXXXXXXXXX
Order  2014-11-11 17:33:40.002  F.US.GCEZ14  1      Sell    Open  1151.6  Stop  99322  482887483  CQG order update (Status). Exchange ID: 761549917870    XXXXXXXXXXXXXX
Order  2014-11-11 17:33:40.003  F.US.GCEZ14  1  1161.8    Sell  1  Filled  1161.8  Limit  99250  482917281  CQG order update (Status). Exchange ID: 761549945323    XXXXXXXXXXXXXX
Order  2014-11-11 17:33:40.004  F.US.EPZ14            Unspecified          Synchronized Internal Position to current Service Position. Current Position quantity: -2    YYYYYYYYYYYYYYY
Order  2014-11-11 17:34:02.000  F.US.CLEZ14  2      Buy    Pending Cancel  77.90  Stop  99306  482896915  Canceling selected orders    XXXXXXXXXXXXXX
Order  2014-11-11 17:34:22.000  F.US.CLEZ14  2      Buy    Open  77.90  Stop  99306  482896915  CQG order update (Status). Exchange ID: 807054207439    XXXXXXXXXXXXXX
Order  2014-11-11 17:34:31.000  F.US.CLEZ14  2      Sell    Pending Cancel  76.65  Stop  99349  483011048  Canceling selected orders    XXXXXXXXXXXXXX
Order  2014-11-11 17:34:41.000  F.US.CLEZ14  2      Sell    Open  76.65  Stop  99349  483011048  CQG order update (Status). Exchange ID: 807054207441    XXXXXXXXXXXXXX
Fill  2014-11-11 17:36:01.000  F.US.CLEZ14  1  76.65  -1  Sell  1  Open  76.65  Stop  99349  483011048  CQG order update (Partial Fill). Exchange ID: 807054207441    XXXXXXXXXXXXXX  Open    483011048
Order  2014-11-11 17:36:01.001  F.US.CLEZ14  2  76.65  -1  Sell  2  Filled  76.65  Stop  99349  483011048  CQG order update (Fill). Exchange ID: 807054207441    XXXXXXXXXXXXXX
Fill  2014-11-11 17:36:01.002  F.US.CLEZ14  1  76.65  -2  Sell  2  Filled  76.65  Stop  99349  483011048  CQG order update (Fill). Exchange ID: 807054207441    XXXXXXXXXXXXXX  Open    483011048
Fill  2014-11-11 17:36:01.213  F.US.CLEZ14  1  76.65    Sell    Filled        483011048  CQG fills data (Restored). Exchange Order ID: 483011048    XXXXXXXXXXXXXX      21789113820
Fill  2014-11-11 17:36:01.217  F.US.CLEZ14  1  76.65    Sell    Filled        483011048  CQG fills data (Restored). Exchange Order ID: 483011048    XXXXXXXXXXXXXX      21789113824
Order  2014-11-11 17:36:09.000  F.US.CLEZ14            Unspecified          Synchronized Internal Position to current Service Position. Current Position quantity: -2    YYYYYYYYYYYYYYY
Order  2014-11-11 17:36:09.001  F.US.CLEZ14            Unspecified          Synchronized Internal Position to current Service Position. Current Position quantity: 0    XXXXXXXXXXXXXX
Order  2014-11-11 17:38:31.000              Unspecified          Connected to server    None
Order  2014-11-11 17:38:41.000  F.US.CLEZ14            Unspecified          Synchronized Internal Position to current Service Position. Current Position quantity: 0    YYYYYYYYYYYYYYY
Order  2014-11-11 17:38:41.001  F.US.EPZ14            Unspecified          Synchronized Internal Position to current Service Position. Current Position quantity: 0    YYYYYYYYYYYYYYY
Order  2014-11-11 17:38:41.002  F.US.CLEZ14            Unspecified          Synchronized Internal Position to current Service Position. Current Position quantity: -2    XXXXXXXXXXXXXX
Order  2014-11-11 17:38:41.003  F.US.EPZ14            Unspecified          Synchronized Internal Position to current Service Position. Current Position quantity: -2    XXXXXXXXXXXXXX
Order  2014-11-11 17:38:46.000  F.US.CLEZ14  2    -2  Buy    Pending Cancel  77.90  Stop  99306  482896915  F.US.CLEZ14 15 Min #2 | User order cancel    XXXXXXXXXXXXXX
Order  2014-11-11 17:38:46.001  F.US.CLEZ14  2    -2  Buy    Canceled  77.90  Stop  99306  482896915  CQG order update (Canceled)    XXXXXXXXXXXXXX
Order  2014-11-11 17:38:54.000  F.US.GCEZ14  1      Sell    Pending Cancel  1151.6  Stop  99322  482887483  F.US.GCEZ14 15 Min #1 | User order cancel    XXXXXXXXXXXXXX
Order  2014-11-11 17:38:54.001  F.US.GCEZ14  1      Sell    Canceled  1151.6  Stop  99322  482887483  CQG order update (Canceled)    XXXXXXXXXXXXXX
Order  2014-11-11 17:38:57.000  F.US.GCEZ14  1      Sell    Pending Cancel  1154.8  Stop  99251  482917282  F.US.GCEZ14 15 Min #1 | User order cancel    XXXXXXXXXXXXXX
Order  2014-11-11 17:38:58.000  F.US.GCEZ14  1      Sell    Canceled  1154.8  Stop  99251  482917282  CQG order update (Canceled)    XXXXXXXXXXXXXX
Order  2014-11-11 17:39:05.000  F.US.USAZ14  2      Buy    Pending Cancel  140 20/32  Limit  99275  482946452  F.US.USAZ14 15 Min #3 | User order cancel    XXXXXXXXXXXXXX
Order  2014-11-11 17:39:06.000  F.US.USAZ14  2      Buy    Canceled  140 20/32  Limit  99275  482946452  CQG order update (Canceled)    XXXXXXXXXXXXXX
Order  2014-11-11 17:39:07.000  F.US.USAZ14  2      Sell    Pending Cancel  141 2/32  Limit  99356  482911855  F.US.USAZ14 15 Min #3 | User order cancel    XXXXXXXXXXXXXX
Order  2014-11-11 17:39:07.001  F.US.USAZ14  2      Sell    Canceled  141 2/32  Limit  99356  482911855  CQG order update (Canceled)    XXXXXXXXXXXXXX
Order  2014-11-11 17:39:11.000  F.US.EPZ14  2    -2  Buy    Pending Cancel  2042.25  Stop  99343  482907011  F.US.EPZ14 15 Min #4 | User order cancel    XXXXXXXXXXXXXX
Order  2014-11-11 17:39:11.001  F.US.EPZ14  2    -2  Buy    Canceled  2042.25  Stop  99343  482907011  CQG order update (Canceled)    XXXXXXXXXXXXXX
Order  2014-11-11 17:39:14.000  F.US.EPZ14  2    -2  Buy    Pending Cancel  2026.00  Limit  99326  482890384  F.US.EPZ14 15 Min #4 | User order cancel    XXXXXXXXXXXXXX
Order  2014-11-11 17:39:15.000  F.US.EPZ14  2    -2  Buy    Canceled  2026.00  Limit  99326  482890384  CQG order update (Canceled)    XXXXXXXXXXXXXX
Order  2014-11-11 17:39:18.000  F.US.EPZ14  2    -2  Sell    Pending Cancel  2030.00  Stop  99355  482911854  F.US.EPZ14 15 Min #4 | User order cancel    XXXXXXXXXXXXXX
Order  2014-11-11 17:39:18.001  F.US.EPZ14  2    -2  Sell    Canceled  2030.00  Stop  99355  482911854  CQG order update (Canceled)    XXXXXXXXXXXXXX
Order  2014-11-11 17:39:31.000  F.US.JY6Z14  2      Buy    Pending Cancel  0.008665  Stop  99264  482956477  F.US.JY6Z14 15 Min #5 | User order cancel    XXXXXXXXXXXXXX
Order  2014-11-11 17:39:31.001  F.US.JY6Z14  2      Buy    Canceled  0.008665  Stop  99264  482956477  CQG order update (Canceled)    XXXXXXXXXXXXXX
Order  2014-11-11 17:39:33.000  F.US.JY6Z14  2      Sell    Pending Cancel  0.008609  Stop  99292  482882803  F.US.JY6Z14 15 Min #5 | User order cancel    XXXXXXXXXXXXXX
Order  2014-11-11 17:39:33.001  F.US.JY6Z14  2      Sell    Canceled  0.008609  Stop  99292  482882803  CQG order update (Canceled)    XXXXXXXXXXXXXX
Order  2014-11-11 17:39:52.000  F.US.CLEZ14      -2  Sell    Pending Child  76.84  Limit  99580    F.US.CLEZ14 15 Min #2 | User order entry | Last: 76.629997. Attached Order    XXXXXXXXXXXXXX  Open  99579
Order  2014-11-11 17:39:52.001  F.US.CLEZ14      -2  Sell    Pending Child  76.25  Stop  99581    F.US.CLEZ14 15 Min #2 | User order entry | Last: 76.629997. Attached Order    XXXXXXXXXXXXXX  Open  99579
Order  2014-11-11 17:39:52.002  F.US.CLEZ14  2    -2  Buy    Order Sent  76.50  Limit  99579    F.US.CLEZ14 15 Min #2 | User order entry | Last: 76.629997    XXXXXXXXXXXXXX  Close
Order  2014-11-11 17:39:52.003  F.US.CLEZ14  2    -2  Buy    Pending Open  76.50  Limit  99579  483031529  CQG order update (In Transit)    XXXXXXXXXXXXXX  Close
Order  2014-11-11 17:39:52.004  F.US.CLEZ14  2    -2  Buy    Open  76.50  Limit  99579  483031529  CQG order update (Ack Place)    XXXXXXXXXXXXXX  Close
Order  2014-11-11 17:39:59.000  F.US.CLEZ14      -2  Sell    Pending Cancel  76.84  Limit  99580    F.US.CLEZ14 15 Min #2 | User order cancel    XXXXXXXXXXXXXX  Open  99579
Order  2014-11-11 17:39:59.001  F.US.CLEZ14      -2  Sell    Canceled  76.84  Limit  99580    F.US.CLEZ14 15 Min #2 | User order cancel    XXXXXXXXXXXXXX  Open  99579
Order  2014-11-11 17:40:00.000  F.US.CLEZ14      -2  Sell    Pending Cancel  76.25  Stop  99581    F.US.CLEZ14 15 Min #2 | User order cancel    XXXXXXXXXXXXXX  Open  99579
Order  2014-11-11 17:40:00.001  F.US.CLEZ14      -2  Sell    Canceled  76.25  Stop  99581    F.US.CLEZ14 15 Min #2 | User order cancel    XXXXXXXXXXXXXX  Open  99579
Order  2014-11-11 17:40:08.000  F.US.CLEZ14      -2  Buy    Pending Child  76.56  Limit  99583    F.US.CLEZ14 15 Min #2 | User order entry | Last: 76.669998. Attached Order    XXXXXXXXXXXXXX  Close  99582
Order  2014-11-11 17:40:08.001  F.US.CLEZ14      -2  Buy    Pending Child  77.15  Stop  99584    F.US.CLEZ14 15 Min #2 | User order entry | Last: 76.669998. Attached Order    XXXXXXXXXXXXXX  Close  99582
Order  2014-11-11 17:40:08.002  F.US.CLEZ14  2    -2  Sell    Order Sent  76.90  Limit  99582    F.US.CLEZ14 15 Min #2 | User order entry | Last: 76.669998    XXXXXXXXXXXXXX  Open
Order  2014-11-11 17:40:09.000  F.US.CLEZ14  2    -2  Sell    Pending Open  76.90  Limit  99582  482878868  CQG order update (In Transit)    XXXXXXXXXXXXXX  Open
Order  2014-11-11 17:40:09.001  F.US.CLEZ14  2    -2  Sell    Open  76.90  Limit  99582  482878868  CQG order update (Ack Place)    XXXXXXXXXXXXXX  Open
Order  2014-11-11 17:40:10.000  F.US.CLEZ14      -2  Buy    Pending Cancel  77.15  Stop  99584    F.US.CLEZ14 15 Min #2 | User order cancel    XXXXXXXXXXXXXX  Close  99582
Order  2014-11-11 17:40:10.001  F.US.CLEZ14      -2  Buy    Canceled  77.15  Stop  99584    F.US.CLEZ14 15 Min #2 | User order cancel    XXXXXXXXXXXXXX  Close  99582
Order  2014-11-11 17:40:12.000  F.US.CLEZ14      -2  Buy    Pending Cancel  76.56  Limit  99583    F.US.CLEZ14 15 Min #2 | User order cancel    XXXXXXXXXXXXXX  Close  99582
Order  2014-11-11 17:40:12.001  F.US.CLEZ14      -2  Buy    Canceled  76.56  Limit  99583    F.US.CLEZ14 15 Min #2 | User order cancel    XXXXXXXXXXXXXX  Close  99582
Order  2014-11-11 17:40:17.000  F.US.CLEZ14  2    -2  Buy    Pending Modify  76.50  Limit  99579  483031529  F.US.CLEZ14 15 Min #2 | User order modification. Requested Price: 76.359998. Requested Quantity: 2    XXXXXXXXXXXXXX  Close
Order  2014-11-11 17:40:17.001  F.US.CLEZ14  2    -2  Buy    Open  76.36  Limit  99579  482902632  CQG order update (Modified)    XXXXXXXXXXXXXX  Close
Order  2014-11-11 17:41:07.000  F.US.CLEZ14  2    -2  Sell    Pending Modify  76.90  Limit  99582  482878868  F.US.CLEZ14 15 Min #2 | User order modification. Requested Price: 76.639998. Requested Quantity: 2    XXXXXXXXXXXXXX  Open
Order  2014-11-11 17:41:08.000  F.US.CLEZ14  2    -2  Sell    Open  76.64  Limit  99582  482883482  CQG order update (Modified)    XXXXXXXXXXXXXX  Open
Order  2014-11-11 17:41:19.000  F.US.CLEZ14  2    -2  Buy    Pending Modify  76.36  Limit  99579  482902632  F.US.CLEZ14 15 Min #2 | User order modification. Requested Price: 76.509998. Requested Quantity: 2    XXXXXXXXXXXXXX  Close
Order  2014-11-11 17:41:19.001  F.US.CLEZ14  2    -2  Buy    Open  76.51  Limit  99579  482952182  CQG order update (Modified)    XXXXXXXXXXXXXX  Close
Order  2014-11-11 17:41:26.000  F.US.CLEZ14  2    -2  Buy    Pending Modify  76.51  Limit  99579  482952182  F.US.CLEZ14 15 Min #2 | User order modification. Requested Price: 76.289998. Requested Quantity: 2    XXXXXXXXXXXXXX  Close
Order  2014-11-11 17:41:26.001  F.US.CLEZ14  2    -2  Buy    Open  76.29  Limit  99579  482878927  CQG order update (Modified)    XXXXXXXXXXXXXX  Close
Order  2014-11-11 17:41:54.000  F.US.CLEZ14  2      Buy    Open  76.29  Limit  99579  482878927  User order modification ignored. New price is the same    XXXXXXXXXXXXXX  Close
Order  2014-11-11 17:42:01.000  F.US.EPZ14  2    -2  Buy    Pending Cancel  2039.00  Stop  99319  482205224  Canceling due to no order update from server    XXXXXXXXXXXXXX
Order  2014-11-11 17:42:01.001  F.US.EPZ14  2    -2  Buy    Canceled  2039.00  Stop  99319  482205224  Canceling due to no order update from server    XXXXXXXXXXXXXX
Order  2014-11-11 17:42:03.000  F.US.CLEZ14  2    -2  Buy    Pending Modify  76.29  Limit  99579  482878927  F.US.CLEZ14 #6 | User order modification. Requested Price: 76.499998. Requested Quantity: 2    XXXXXXXXXXXXXX  Close
Order  2014-11-11 17:42:03.001  F.US.CLEZ14  2    -2  Buy    Open  76.50  Limit  99579  482897633  CQG order update (Modified)    XXXXXXXXXXXXXX  Close
Order  2014-11-11 17:42:03.002  F.US.CLEZ14  2      Buy    Open  76.50  Limit  99579  482897633  User order modification ignored. New price is the same    XXXXXXXXXXXXXX  Close
Fill  2014-11-11 17:42:12.000  F.US.CLEZ14  1  76.50    Buy    Filled      99579  99579.5.482897633  CQG fills data (Restored). Exchange Order ID: 482897633    YYYYYYYYYYYYYYY      482897633
Fill  2014-11-11 17:42:12.000  F.US.CLEZ14  1  76.50  -1  Buy  1  Open  76.50  Limit  99579  482897633  CQG order update (Fill)    XXXXXXXXXXXXXX  Close    21789135694
Order  2014-11-11 17:42:12.001  F.US.CLEZ14  2  76.50  -1  Buy  2  Filled  76.50  Limit  99579  482897633  CQG order update (Fill)    XXXXXXXXXXXXXX  Close
Fill  2014-11-11 17:42:12.002  F.US.CLEZ14  1  76.50    Buy  2  Filled  76.50  Limit  99579  482897633  CQG order update (Fill)    XXXXXXXXXXXXXX  Close    21789135705
Order  2014-11-11 17:42:20.000  F.US.CLEZ14            Unspecified          Removing Position with quantity of 0    XXXXXXXXXXXXXX
Order  2014-11-11 17:42:41.000  F.US.CLEZ14  2      Sell    Pending Cancel  76.64  Limit  99582  482883482  F.US.CLEZ14 #6 | User order cancel    XXXXXXXXXXXXXX  Open
Order  2014-11-11 17:42:42.000  F.US.CLEZ14  2      Sell    Canceled  76.64  Limit  99582  482883482  CQG order update (Canceled)    XXXXXXXXXXXXXX  Open
Order  2014-11-11 17:43:40.000  F.US.EPZ14      -2  Sell    Pending Child  2048.00  Limit  99586    F.US.EPZ14 15 Min #4 | User order entry | Last: 2034.75. Attached Order    XXXXXXXXXXXXXX  Open  99585
Order  2014-11-11 17:43:40.001  F.US.EPZ14      -2  Sell    Pending Child  2035.00  Stop  99587    F.US.EPZ14 15 Min #4 | User order entry | Last: 2034.75. Attached Order    XXXXXXXXXXXXXX  Open  99585
Order  2014-11-11 17:43:40.002  F.US.EPZ14  2    -2  Buy    Order Sent  2040.75  Stop Limit  99585    F.US.EPZ14 15 Min #4 | User order entry | Last: 2034.75  2041.75  XXXXXXXXXXXXXX  Close
Order  2014-11-11 17:43:40.003  F.US.EPZ14  2    -2  Buy    Pending Open  2040.75  Stop Limit  99585  482902719  CQG order update (In Transit)  2041.75  XXXXXXXXXXXXXX  Close
Order  2014-11-11 17:43:40.004  F.US.EPZ14  2    -2  Buy    Open  2040.75  Stop Limit  99585  482902719  CQG order update (Ack Place)  2041.75  XXXXXXXXXXXXXX  Close
Order  2014-11-11 17:43:46.000  F.US.EPZ14  2      Buy    Open  2040.75  Stop Limit  99585  482902719  User order modification ignored. New price is the same  2041.75  XXXXXXXXXXXXXX  Close
Order  2014-11-11 17:44:02.000  F.US.EPZ14  2      Buy    Open  2040.75  Stop Limit  99585  482902719  Order modification not confirmed by user  2041.75  XXXXXXXXXXXXXX  Close
Order  2014-11-11 17:44:10.000  F.US.EPZ14      -2  Sell    Pending Cancel  2035.00  Stop  99587    Canceling selected orders    XXXXXXXXXXXXXX  Open  99585
Order  2014-11-11 17:44:10.001  F.US.EPZ14      -2  Sell    Canceled  2035.00  Stop  99587    Canceling selected orders    XXXXXXXXXXXXXX  Open  99585
Order  2014-11-11 17:44:10.002  F.US.EPZ14  2    -2  Buy    Pending Cancel  2040.75  Stop Limit  99585  482902719  Canceling selected orders  2041.75  XXXXXXXXXXXXXX  Close
Order  2014-11-11 17:44:10.003  F.US.EPZ14      -2  Sell    Pending Cancel  2048.00  Limit  99586    Canceling selected orders    XXXXXXXXXXXXXX  Open  99585
Order  2014-11-11 17:44:10.004  F.US.EPZ14      -2  Sell    Canceled  2048.00  Limit  99586    Canceling selected orders    XXXXXXXXXXXXXX  Open  99585
Order  2014-11-11 17:44:10.005  F.US.EPZ14  2    -2  Buy    Canceled  2040.75  Stop Limit  99585  482902719  CQG order update (Canceled)  2041.75  XXXXXXXXXXXXXX  Close
Order  2014-11-11 17:48:47.000  F.US.EPZ14  2    -2  Buy    Order Sent  2026.00  Limit  99588    F.US.EPZ14 15 Min #4 | User order entry | Last: 2034.75    XXXXXXXXXXXXXX  Close
Order  2014-11-11 17:48:47.001  F.US.EPZ14  2    -2  Buy    Order Sent  2039.00  Stop  99589    F.US.EPZ14 15 Min #4 | User order entry | Last: 2034.75    XXXXXXXXXXXXXX  Close
Order  2014-11-11 17:48:47.002  F.US.EPZ14  2    -2  Buy    Pending Open  2026.00  Limit  99588  482952283  CQG order update (In Transit)    XXXXXXXXXXXXXX  Close
Order  2014-11-11 17:48:47.003  F.US.EPZ14  2    -2  Buy    Open  2026.00  Limit  99588  482952283  CQG order update (Ack Place)    XXXXXXXXXXXXXX  Close
Order  2014-11-11 17:48:47.004  F.US.EPZ14  2    -2  Buy    Pending Open  2039.00  Stop  99589  482879052  CQG order update (In Transit)    XXXXXXXXXXXXXX  Close
Order  2014-11-11 17:48:47.005  F.US.EPZ14  2    -2  Buy    Open  2039.00  Stop  99589  482879052  CQG order update (Ack Place)    XXXXXXXXXXXXXX  Close
Order  2014-11-11 17:48:47.707  F.US.EPZ4  2    -2  Buy    Open    Limit  99765  482952283  CQG order update (Ack Place)    XXXXXXXXXXXXXX
Order  2014-11-11 17:48:47.753  F.US.EPZ4  2    -2  Buy    Open    Stop  99713  482879052  CQG order update (Ack Place)    XXXXXXXXXXXXXX
Order  2014-11-11 17:50:55.000  F.US.EPZ14  2    -2  Buy    Pending Cancel  2026.00  Limit  99588  482952283  Canceling due to no order update from server    XXXXXXXXXXXXXX  Close
Order  2014-11-11 17:50:55.001  F.US.EPZ14  2    -2  Buy    Canceled  2026.00  Limit  99588  482952283  Canceling due to no order update from server    XXXXXXXXXXXXXX  Close
Order  2014-11-11 17:50:56.000  F.US.EPZ14  2    -2  Buy    Pending Cancel  2039.00  Stop  99589  482879052  Canceling due to no order update from server    XXXXXXXXXXXXXX  Close
Order  2014-11-11 17:50:56.001  F.US.EPZ14  2    -2  Buy    Canceled  2039.00  Stop  99589  482879052  Canceling due to no order update from server    XXXXXXXXXXXXXX  Close
Order  2014-11-11 17:56:04.000              Unspecified          Connected to server    None
Order  2014-11-11 17:56:09.000  F.US.EPZ14            Unspecified          Synchronized Internal Position to current Service Position. Current Position quantity: 0    XXXXXXXXXXXXXX
Order  2014-11-11 17:56:10.000  F.US.EPZ14  2      Buy    Open  2039.00  Stop  99319  482205224  CQG order update (Status). Exchange ID: 642766670473    XXXXXXXXXXXXXX
Order  2014-11-11 17:56:10.001  F.US.EPZ14  2      Buy    Open  2039.00  Stop  99589  482879052  CQG order update (Status). Exchange ID: 642767097579    XXXXXXXXXXXXXX  Close
Order  2014-11-11 17:56:10.002  F.US.EPZ14  2      Buy    Open  2026.00  Limit  99588  482952283  CQG order update (Status). Exchange ID: 642767097578    XXXXXXXXXXXXXX  Close
Order  2014-11-11 17:56:10.003  F.US.CLEZ14            Unspecified          Removing Position with quantity of 0    YYYYYYYYYYYYYYY
Order  2014-11-11 17:56:10.004  F.US.EPZ14            Unspecified          Synchronized Internal Position to current Service Position. Current Position quantity: -2    YYYYYYYYYYYYYYY
Order  2014-11-11 17:56:10.005  F.US.GCEZ14            Unspecified          Removing Position with quantity of 0    YYYYYYYYYYYYYYY
Order  2014-11-11 17:56:10.006  F.US.JY6Z14            Unspecified          Removing Position with quantity of 0    YYYYYYYYYYYYYYY
Order  2014-11-11 17:56:33.000              Unspecified          Connected to server    None
Order  2014-11-11 17:56:44.000  F.US.EPZ14            Unspecified          Synchronized Internal Position to current Service Position. Current Position quantity: 0    YYYYYYYYYYYYYYY
Order  2014-11-11 17:56:44.001  F.US.EPZ14            Unspecified          Synchronized Internal Position to current Service Position. Current Position quantity: -2    XXXXXXXXXXXXXX
Order  2014-11-11 17:57:13.000  F.US.EPZ14  2    -2  Buy    Pending Cancel  2039.00  Stop  99319  482205224  Canceling selected orders    XXXXXXXXXXXXXX
Order  2014-11-11 17:57:13.001  F.US.EPZ14  2    -2  Buy    Canceled  2039.00  Stop  99319  482205224  CQG order update (Canceled)    XXXXXXXXXXXXXX
Order  2014-11-11 17:58:33.000  F.US.EPZ14  2    -2  Buy    Pending Cancel  2026.00  Limit  99588  482952283  Canceling due to no order update from server    XXXXXXXXXXXXXX  Close
Order  2014-11-11 17:58:33.001  F.US.EPZ14  2    -2  Buy    Canceled  2026.00  Limit  99588  482952283  Canceling due to no order update from server    XXXXXXXXXXXXXX  Close
Order  2014-11-11 17:58:33.002  F.US.EPZ14  2    -2  Buy    Pending Cancel  2039.00  Stop  99589  482879052  Canceling due to no order update from server    XXXXXXXXXXXXXX  Close
Order  2014-11-11 17:58:33.003  F.US.EPZ14  2    -2  Buy    Canceled  2039.00  Stop  99589  482879052  Canceling due to no order update from server    XXXXXXXXXXXXXX  Close
Order  2014-11-11 18:01:05.000              Unspecified          Connected to server    None
Order  2014-11-11 18:01:10.000  F.US.EPZ14            Unspecified          Synchronized Internal Position to current Service Position. Current Position quantity: 0    XXXXXXXXXXXXXX
Order  2014-11-11 18:01:11.000  F.US.EPZ14  2      Buy    Open  2039.00  Stop  99589  482879052  CQG order update (Status). Exchange ID: 642767097579    XXXXXXXXXXXXXX  Close
Order  2014-11-11 18:01:11.001  F.US.EPZ14  2      Buy    Open  2026.00  Limit  99588  482952283  CQG order update (Status). Exchange ID: 642767097578    XXXXXXXXXXXXXX  Close
Order  2014-11-11 18:01:11.002  F.US.CLEZ14            Unspecified          Removing Position with quantity of 0    YYYYYYYYYYYYYYY
Order  2014-11-11 18:01:11.003  F.US.EPZ14            Unspecified          Synchronized Internal Position to current Service Position. Current Position quantity: -2    YYYYYYYYYYYYYYY
Order  2014-11-11 18:01:11.004  F.US.GCEZ14            Unspecified          Removing Position with quantity of 0    YYYYYYYYYYYYYYY
Order  2014-11-11 18:01:11.005  F.US.JY6Z14            Unspecified          Removing Position with quantity of 0    YYYYYYYYYYYYYYY
Order  2014-11-11 18:01:46.000              Unspecified          Connected to server    None
Order  2014-11-11 18:01:58.000  F.US.EPZ14            Unspecified          Synchronized Internal Position to current Service Position. Current Position quantity: 0    YYYYYYYYYYYYYYY
Order  2014-11-11 18:01:58.001  F.US.EPZ14            Unspecified          Synchronized Internal Position to current Service Position. Current Position quantity: -2    XXXXXXXXXXXXXX
Order  2014-11-11 18:25:14.000              Unspecified          Connected to server    None
Order  2014-11-11 18:25:25.000  F.US.EPZ14            Unspecified          Synchronized Internal Position to current Service Position. Current Position quantity: 0    XXXXXXXXXXXXXX
Order  2014-11-11 18:25:25.001  F.US.EPZ4            Unspecified          Synchronized Internal Position to current Service Position. Current Position quantity: -2    XXXXXXXXXXXXXX
Order  2014-11-11 18:29:09.000  F.US.EPZ14  2      Buy    Pending Cancel    Limit  99588  482952283  Canceling due to no order update from server    XXXXXXXXXXXXXX  Close
Order  2014-11-11 18:29:09.001  F.US.EPZ14  2      Buy    Canceled    Limit  99588  482952283  Canceling due to no order update from server    XXXXXXXXXXXXXX  Close
Order  2014-11-11 18:29:09.002  F.US.EPZ14  2      Buy    Pending Cancel    Stop  99589  482879052  Canceling due to no order update from server    XXXXXXXXXXXXXX  Close
Order  2014-11-11 18:29:09.003  F.US.EPZ14  2      Buy    Canceled    Stop  99589  482879052  Canceling due to no order update from server    XXXXXXXXXXXXXX  Close
Order  2014-11-11 18:30:13.000              Unspecified          Connected to server    None
Order  2014-11-11 18:30:24.000  F.US.EPZ4            Unspecified          Synchronized Internal Position to current Service Position. Current Position quantity: 0    XXXXXXXXXXXXXX
Order  2014-11-11 18:30:24.001  F.US.EPZ4            Unspecified          Synchronized Internal Position to current Service Position. Current Position quantity: -2    XXXXXXXXXXXXXX
Order  2014-11-11 18:31:15.000              Unspecified          Connected to server    None
Order  2014-11-11 18:31:21.000  F.US.EPZ4            Unspecified          Synchronized Internal Position to current Service Position. Current Position quantity: 0    XXXXXXXXXXXXXX
Order  2014-11-11 18:31:22.000  F.US.CLEZ14            Unspecified          Removing Position with quantity of 0    YYYYYYYYYYYYYYY
Order  2014-11-11 18:31:22.001  F.US.EPZ14            Unspecified          Synchronized Internal Position to current Service Position. Current Position quantity: -2    YYYYYYYYYYYYYYY
Order  2014-11-11 18:31:22.002  F.US.GCEZ14            Unspecified          Removing Position with quantity of 0    YYYYYYYYYYYYYYY
Order  2014-11-11 18:31:22.003  F.US.JY6Z14            Unspecified          Removing Position with quantity of 0    YYYYYYYYYYYYYYY
Order  2014-11-11 18:31:58.000              Unspecified          Connected to server    None
Order  2014-11-11 18:32:09.000  F.US.EPZ14            Unspecified          Synchronized Internal Position to current Service Position. Current Position quantity: 0    YYYYYYYYYYYYYYY
Order  2014-11-11 18:32:10.000  F.US.EPZ14            Unspecified          Synchronized Internal Position to current Service Position. Current Position quantity: -2    XXXXXXXXXXXXXX
Order  2014-11-11 18:35:30.000              Unspecified          Connected to server    None
Order  2014-11-11 18:35:36.000  F.US.EPZ14            Unspecified          Synchronized Internal Position to current Service Position. Current Position quantity: 0    XXXXXXXXXXXXXX
Order  2014-11-11 18:35:37.000  F.US.EPZ14            Unspecified          Synchronized Internal Position to current Service Position. Current Position quantity: -2    YYYYYYYYYYYYYYY
Order  2014-11-11 18:36:49.000  F.US.EPZ14  2    -2  Buy    Order Sent  2044.75  Stop  99961    F.US.EPZ14 15 Min #4 | User order entry | Last: 2034.25    YYYYYYYYYYYYYYY  Close
Order  2014-11-11 18:36:49.001  F.US.EPZ14  2    -2  Sell    Order Sent  2052.00  Limit  99962    F.US.EPZ14 15 Min #4 | User order entry | Last: 2034.25. Attached Order    YYYYYYYYYYYYYYY  Open  99961
Order  2014-11-11 18:36:49.002  F.US.EPZ14  2    -2  Sell    Order Sent  2039.00  Stop  99963    F.US.EPZ14 15 Min #4 | User order entry | Last: 2034.25. Attached Order    YYYYYYYYYYYYYYY  Open  99961
Order  2014-11-11 18:36:49.003  F.US.EPZ14  2    -2  Buy    Pending Open  2044.75  Stop  99961  482927758  CQG order update (New)    YYYYYYYYYYYYYYY  Close
Order  2014-11-11 18:36:49.004  F.US.EPZ14  2    -2  Sell    Open  2052.00  Limit  99962  482927759  CQG order update (Suspended)    YYYYYYYYYYYYYYY  Open  99961
Order  2014-11-11 18:36:49.005  F.US.EPZ14  2    -2  Sell    Open  2039.00  Stop  99963  482927760  CQG order update (Suspended)    YYYYYYYYYYYYYYY  Open  99961
Order  2014-11-11 18:36:49.006  F.US.EPZ14  2    -2  Buy    Open  2044.75  Stop  99961  482927758  CQG order update (New). Exchange ID: 642767161916    YYYYYYYYYYYYYYY  Close
Order  2014-11-11 18:36:51.000  F.US.EPZ14  2    -2  Buy    Pending Cancel  2044.75  Stop  99961  482927758  F.US.EPZ14 15 Min #4 | User order cancel    YYYYYYYYYYYYYYY  Close
Order  2014-11-11 18:36:51.001  F.US.EPZ14  2    -2  Buy    Canceled  2044.75  Stop  99961  482927758  CQG order update (Cancel). Exchange ID: 642767161916    YYYYYYYYYYYYYYY  Close
Order  2014-11-11 18:36:51.002  F.US.EPZ14  2    -2  Sell    Canceled  2052.00  Limit  99962  482927759  CQG order update (Cancel)    YYYYYYYYYYYYYYY  Open  99961
Order  2014-11-11 18:36:51.003  F.US.EPZ14  2    -2  Sell    Canceled  2039.00  Stop  99963  482927760  CQG order update (Cancel)    YYYYYYYYYYYYYYY  Open  99961
Order  2014-11-11 18:47:03.000  F.US.EPZ4  2      Buy    Pending Cancel  2039.00000  Stop  99713  482879052  Canceling selected orders    XXXXXXXXXXXXXX
Order  2014-11-11 18:47:18.000  F.US.EPZ4  2      Buy    Pending Cancel  2026.00000  Limit  99765  482952283  Canceling selected orders    XXXXXXXXXXXXXX
Order  2014-11-11 18:48:15.000  F.US.EPZ4  2      Buy    Open  2039.00000  Stop  99713  482879052  CQG order update (Status). Exchange ID: 642767097579    XXXXXXXXXXXXXX
Order  2014-11-11 18:48:15.001  F.US.EPZ4  2      Buy    Open  2026.00000  Limit  99765  482952283  CQG order update (Status). Exchange ID: 642767097578    XXXXXXXXXXXXXX
Order  2014-11-11 18:50:53.000              Unspecified          Connected to server    None
Order  2014-11-11 18:51:04.000  F.US.EPZ14            Unspecified          Synchronized Internal Position to current Service Position. Current Position quantity: 0    YYYYYYYYYYYYYYY
Order  2014-11-11 18:51:04.001  F.US.EPZ14            Unspecified          Synchronized Internal Position to current Service Position. Current Position quantity: -2    XXXXXXXXXXXXXX
Order  2014-11-11 18:51:19.000  F.US.EPZ4  2      Buy    Pending Cancel  2026.00000  Limit  99765  482952283  Canceling selected orders    XXXXXXXXXXXXXX
Order  2014-11-11 18:51:19.001  F.US.EPZ4  2      Buy    Canceled  2026.00000  Limit  99765  482952283  CQG order update (Canceled)    XXXXXXXXXXXXXX
Order  2014-11-11 18:51:25.000  F.US.EPZ4  2      Buy    Pending Cancel  2039.00000  Stop  99713  482879052  Canceling selected orders    XXXXXXXXXXXXXX
Order  2014-11-11 18:51:25.001  F.US.EPZ4  2      Buy    Canceled  2039.00000  Stop  99713  482879052  CQG order update (Canceled)    XXXXXXXXXXXXXX
Order  2014-11-11 18:52:54.000              Unspecified          Connected to server    None
Order  2014-11-11 18:53:00.000  F.US.EPZ14            Unspecified          Synchronized Internal Position to current Service Position. Current Position quantity: 0    XXXXXXXXXXXXXX
Order  2014-11-11 18:53:02.000  F.US.EPZ14            Unspecified          Synchronized Internal Position to current Service Position. Current Position quantity: -2    YYYYYYYYYYYYYYY
Order  2014-11-11 18:53:48.000  F.US.EPZ14  2    -2  Buy    Order Sent  2026.00  Limit  100218    F.US.EPZ14 15 Min #4 | User order entry | Last: 2034    YYYYYYYYYYYYYYY  Close
Order  2014-11-11 18:53:48.001  F.US.EPZ14  2    -2  Buy    Order Sent  2039.00  Stop  100219    F.US.EPZ14 15 Min #4 | User order entry | Last: 2034    YYYYYYYYYYYYYYY  Close
Order  2014-11-11 18:53:49.000  F.US.EPZ14  2    -2  Buy    Pending Open  2026.00  Limit  100218  482884052  CQG order update (New)    YYYYYYYYYYYYYYY  Close
Order  2014-11-11 18:53:49.001  F.US.EPZ14  2    -2  Buy    Pending Open  2039.00  Stop  100219  482884053  CQG order update (New)    YYYYYYYYYYYYYYY  Close
Order  2014-11-11 18:53:49.002  F.US.EPZ14  2    -2  Buy    Open  2026.00  Limit  100218  482884052  CQG order update (New). Exchange ID: 642767180858    YYYYYYYYYYYYYYY  Close
Order  2014-11-11 18:53:49.003  F.US.EPZ14  2    -2  Buy    Open  2039.00  Stop  100219  482884053  CQG order update (New). Exchange ID: 642767180859    YYYYYYYYYYYYYYY  Close
Date Time Of Last Edit: 2014-11-11 19:04:11
[2014-11-11 21:00:00]
This log is helpful. And we discovered one of the main problems why an order could disappear from a chart and go into a "Canceled" state when using CQG. This has now been fixed and we are putting out version 1211 now.
[2014-11-11 21:42:37]
I am happy that the log is so useful.
I understand that Release 1211 will not allow both services yet: CQG WebAPI and "old" CQG Trading.
[2014-11-11 23:41:24]
In 1211 you will find the following services:
CQG Web API(Supports trading and market data through the web socket interface)
CQG FIX Trading (supports FIX trading and market data. This is proven and well tested.)
Date Time Of Last Edit: 2014-11-11 23:41:36
