Date/Time: Thu, 26 Nov 2026 23:36:33 +0000
no Stock data today ???? 20260826
View Count: 385
| [2026-08-26 15:02:00] |
| User882361 - Posts: 8 |
hi there, I am facing some questions here.... today for some reason no Stock data came in, restof dataFeeds were fine... are there some "issues" .... I have the latest vesr, and yes all payments are fine too. so ie [ ORCL/VIXY/TLT/INTC/MU/GOOGL/META/SPY/MSFT/AAPL/ASML/AMD/XLK/TSM/QQQ/SMH... ] best regards Robert |
| [2026-08-26 15:33:57] |
The only "issue" with data today is if you are using the NASDAQ TotalView data, then you need to be on the current release (v 2945). Refer to the last post in this thread: Important Notice: Market Data feed Changes, Required Update in December 2026 We are not sure how you have that spreadsheet setup, so there is nothing we can tell from that in particular. We need to see a basic bar chart for one symbol that shows the Date-time along the bottom and the current price and the most recent bar displayed in the chart. Please let us know the time zone of the chart. Follow these instructions to get us an image: Support Board Posting Information: Attaching or Posting a Screenshot/Image (Optional) Also, please get us your Message Log by following these instructions for the same symbol that you get us the image for: Follow the instructions here to clear the Message Log:
Message Log: Clearing the Message Log Close all of the Chartbooks with "File >> Close All Chartbooks". Open a single chart for the symbol you have an issue with through "File >> Find Symbol". Tell us that symbol of the chart. Tell us about *one* symbol only. Disconnect from the data feed with "File >> Disconnect". Connect to the data feed with "File >> Connect to Data Feed". After the connection and after about 10 seconds, provide a copy of the Message Log following these instructions: Support Board Posting Information: How to Post Your Message Log (Required In Some Cases) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-08-26 17:09:26] |
thanx for your time/patience !!!! the v2945 solved the issue !... thank U again >>> best regards Robert >>>>> pls close this ticket<<<<< |
| [2026-08-27 19:22:25] |
| Sierra_Chart Engineering - Posts: 25499 |
We apologize that there was an issue with NASDAQ Totalview yesterday when running an older version. That issue was resolved yesterday evening. But there was no issue for the the general US equities feeds and level 1 data. If you are running a new version and having no issue that is fine but an older version at this time will work as well. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
