Date/Time: Tue, 24 Nov 2026 18:17:07 +0000
Rithmic Data Freezes Chart
View Count: 437
[2026-08-19 17:18:18]
User341268 - Posts: 3
Hello
Whenever I connect through rithmic on sierra chart the chart completely freezes. I have tried connecting from two different instances, the problem is the same. The other data feed through my live broker is working just fine. This has happened on two different prop firms. What should I do to fix this? Thank you!
[2026-08-19 18:24:26]
John - SC Support - Posts: 48643
Are you getting an error when you connect to Rithmic? In particular, are you getting an "Permission Denied" error? If so, then refer to the following:
Rithmic Trading Platform Service: Permission Denied Resolution Procedure
As noted in the above, you are setup to get data from our Denali Exchnage Data Feed, so you should have the "Market Data" and "Historical Data" Username/Password fields blank in the "Data/Trade Service Settings". This is the most common reason for the Permission Denied error, but there are others as noted in that link.
[2026-08-19 20:53:19]
There are no visible errors in the message log, I have ran it through with AI.
[2026-08-19 21:21:09]
Please get us your Message Log by following these instructions:
Close all of the Chartbooks with "File >> Close All Chartbooks".
Open a single chart for the symbol you have an issue with through "File >> Find Symbol". Tell us that symbol of the chart. Tell us about *one* symbol only.
[2026-08-20 10:06:10]
This is very strange. On a naked chart it works, but on my configured charts it does not. I think it has something to do with historical data download skipped. When I follow these steps that you mentioned, I get live data. This is the message log. However, when I open my own charts, on both ES and NQ, the data is frozen.
2026-08-20 06:01:09.099 | Trade activity files set size: 432
2026-08-20 06:01:09.103 | Rithmic Direct - DTC | Processed connection points. Count: 496
2026-08-20 06:01:09.106 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (4) | Creating socket. Using TLS 1.2.
2026-08-20 06:01:09.107 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (4) | New receive buffer size: 0
2026-08-20 06:01:09.107 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (4) | Connecting to IP: 216.66.0.130.
2026-08-20 06:01:09.136 | Created the DTC Protocol server.
2026-08-20 06:01:09.136 | DTC Protocol Server listening on port 11099. Address: 0.0.0.0
2026-08-20 06:01:09.136 | Reading Internal Order ID file.
2026-08-20 06:01:09.137 | Reading Trade Orders file.
2026-08-20 06:01:09.137 | Reading Trade Positions file.
2026-08-20 06:01:09.137 | Reading Trade Account Data files.
2026-08-20 06:01:09.139 | Software version: 2899 64-bit
2026-08-20 06:01:09.139 | Primary Thread ID: 31656
2026-08-20 06:01:09.139 | Usage end date: 2026-09-03
2026-08-20 06:01:09.139 | Enabled for: Advanced Features 2.
2026-08-20 06:01:09.139 | Enabled for: Sierra Chart Historical Data Service.
2026-08-20 06:01:09.139 | Enabled for: Denali Real-Time Exchange Data Feed.
2026-08-20 06:01:09.139 | Enabled for: Delayed Denali Exchange Data Feed.
2026-08-20 06:01:09.139 | Enabled for exchange2: CME
2026-08-20 06:01:09.139 | Allow Support for Sierra Chart Data Feeds is enabled.
2026-08-20 06:01:09.139 | Current selected Data/Trading service: Rithmic Direct - DTC
2026-08-20 06:01:09.139 | Custom symbol settings values: enabled
2026-08-20 06:01:09.139 | Chart Update Interval: 400
2026-08-20 06:01:09.139 | Intraday Data Storage Time Unit: 0
2026-08-20 06:01:09.139 | Time Zone: -04:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00)
2026-08-20 06:01:09.139 | 2026-08-20 10:01:09 Local computer time in UTC
2026-08-20 06:01:09.139 | 2026-08-20 06:01:09 Local computer time in SC Time Zone
2026-08-20 06:01:09.139 | 2026-08-20 10:01:07 Server time in UTC
2026-08-20 06:01:09.139 | Local computer UTC time and Server UTC time difference: 1 seconds.
2026-08-20 06:01:09.139 | Program path: C:\SierraChart\
2026-08-20 06:01:09.139 | Data Files path: C:\SierraChart\Data\
2026-08-20 06:01:09.139 | OS Version Number: 10.0
2026-08-20 06:01:09.139 | Locale Setting: C
2026-08-20 06:01:09.139 | Crash reporter started: true
2026-08-20 06:01:09.157 | Created the DTC Protocol historical data server.
2026-08-20 06:01:09.157 | HD Server Manager | Listening on port 11098.
2026-08-20 06:01:09.158 | Checking for new symbol settings. Requested symbol settings MD5 for service code rithmic_v2.trading. Request ID: 1.
2026-08-20 06:01:09.172 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close.
2026-08-20 06:01:09.302 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side.
2026-08-20 06:01:09.302 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed.
2026-08-20 06:01:09.551 | Received 5 login tokens.
2026-08-20 06:01:09.756 | Symbol settings MD5 received. Request ID: 1.
2026-08-20 06:01:09.756 | Symbol settings are up-to-date for rithmic_v2.trading.
2026-08-20 06:01:10.274 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\RithmicConnections.json. Size: 115672
2026-08-20 06:01:10.275 | Rithmic Direct - DTC | Processed connection points. Count: 496
2026-08-20 06:01:10.527 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (4) | CloseSocket call.
2026-08-20 06:01:10.527 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (4) | Shutdown started. Waiting for graceful close.
2026-08-20 06:01:10.633 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (4) | Socket gracefully closed by remote side.
2026-08-20 06:01:10.633 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (4) | Closed.
2026-08-20 06:01:11.680 | Requested user files to download.
2026-08-20 06:01:12.327 | File to download: OrderflowTriggers2_64.dll. Action: 1
2026-08-20 06:01:12.329 | File to download: VolumeTriggers_64.dll. Action: 1
2026-08-20 06:01:12.332 | File to download: DeltaWickABS_64.dll. Action: 1
2026-08-20 06:01:12.335 | File to download: DeltaSlingshotFADE_64.dll. Action: 1
2026-08-20 06:01:12.337 | File to download: BreakScanner_64.dll. Action: 1
2026-08-20 06:01:12.339 | File to download: ABSindi_64.dll. Action: 1
2026-08-20 06:01:12.342 | User files to download complete
2026-08-20 06:01:13.695 |
2026-08-20 06:01:13.695 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2026-08-20 06:01:13.695 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2026-08-20 06:01:13.695 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500
2026-08-20 06:01:13.696 | DTC Client socket (1) | Creating socket. Using TLS 1.2.
2026-08-20 06:01:13.696 | DTC Client socket (1) | New receive buffer size: 0
2026-08-20 06:01:13.696 | DTC Client socket (1) | Connecting to IP: 184.105.22.231.
2026-08-20 06:01:13.821 | Rithmic Direct - DTC | Network connection to server complete.
2026-08-20 06:01:13.821 | Rithmic Direct - DTC | Starting socket receive thread.
2026-08-20 06:01:13.821 | Rithmic Direct - DTC | Using fixed encoding of Binary
2026-08-20 06:01:13.821 | Rithmic Direct - DTC | Sending logon request message.
2026-08-20 06:01:14.203 | Rithmic Direct - DTC | Received logon response.
2026-08-20 06:01:14.203 | Rithmic Direct - DTC | Server Name: .
2026-08-20 06:01:14.203 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8
2026-08-20 06:01:14.203 | Rithmic Direct - DTC | Successfully connected.
2026-08-20 06:01:14.203 | Rithmic Direct - DTC | Trading is supported.
2026-08-20 06:01:14.203 | Rithmic Direct - DTC | Order cancel and replace is supported.
2026-08-20 06:01:14.203 | Rithmic Direct - DTC | OCO Orders supported.
2026-08-20 06:01:14.203 | Rithmic Direct - DTC | Symbol and Exchange Delimiter: .
2026-08-20 06:01:14.203 | Rithmic Direct - DTC | MarketDepthIsSupported: 0
2026-08-20 06:01:14.203 | Rithmic Direct - DTC | Connection to server complete.
2026-08-20 06:01:14.204 | No download requests in the queue to start downloads for. | Number times message added: 3
2026-08-20 06:01:16.930 | Files to Open on Startup | Opening file: JTmarket-internals-NYSE.Cht
2026-08-20 06:01:16.942 | TICK-NYSE 1 Min #2 | Reloading chart.
2026-08-20 06:01:16.955 | TICK-NASDAQ 1 Min #3 | Reloading chart.
2026-08-20 06:01:16.968 | UDVR-NQ 1 Min #1 | Reloading chart.
2026-08-20 06:01:16.982 | Files to Open on Startup | Opening file: SierraEdge PRO ES.Cht
2026-08-20 06:01:17.010 | ESU26_FUT_CME [CBV] #2 | Reloading chart.
2026-08-20 06:01:17.010 | ESU26_FUT_CME [CBV] #2 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart.
2026-08-20 06:01:17.010 | ESU26_FUT_CME [CBV] #2 | There are no continuous futures contract symbols. Loading data normally.
2026-08-20 06:01:17.044 | ESU26_FUT_CME [CBV] #31 | Reloading chart.
2026-08-20 06:01:17.044 | ESU26_FUT_CME [CBV] #31 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart.
2026-08-20 06:01:17.044 | ESU26_FUT_CME [CBV] #31 | There are no continuous futures contract symbols. Loading data normally.
2026-08-20 06:01:17.080 | ESU26_FUT_CME [CBV] #11 | Reloading chart.
2026-08-20 06:01:17.080 | ESU26_FUT_CME [CBV] #11 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart.
2026-08-20 06:01:17.080 | ESU26_FUT_CME [CBV] #11 | There are no continuous futures contract symbols. Loading data normally.
2026-08-20 06:01:17.092 | ESU26_FUT_CME [CBV] Daily #4 | Reloading chart.
2026-08-20 06:01:17.092 | ESU26_FUT_CME [CBV] Daily #4 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart.
2026-08-20 06:01:17.092 | ESU26_FUT_CME [CBV] Daily #4 | There are no continuous futures contract symbols. Loading data normally.
2026-08-20 06:01:17.143 | ESU26_FUT_CME [CBV] 60 Min #34 | Reloading chart.
2026-08-20 06:01:17.143 | ESU26_FUT_CME [CBV] 60 Min #34 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart.
2026-08-20 06:01:17.143 | ESU26_FUT_CME [CBV] 60 Min #34 | There are no continuous futures contract symbols. Loading data normally.
2026-08-20 06:01:17.170 | Loading DLL: C:\SierraChart\Data\UserContributedStudies.dll (UserContributedStudies_64.dll). Handle: 7ffc3a500000
2026-08-20 06:01:17.189 | ESU26_FUT_CME [CBV] Daily #14 | Reloading chart.
2026-08-20 06:01:17.190 | ESU26_FUT_CME [CBV] Daily #14 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart.
2026-08-20 06:01:17.190 | ESU26_FUT_CME [CBV] Daily #14 | There are no continuous futures contract symbols. Loading data normally.
2026-08-20 06:01:17.235 | ESU26_FUT_CME [CBV] 480 Min #15 | Reloading chart.
2026-08-20 06:01:17.235 | ESU26_FUT_CME [CBV] 480 Min #15 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart.
2026-08-20 06:01:17.235 | ESU26_FUT_CME [CBV] 480 Min #15 | There are no continuous futures contract symbols. Loading data normally.
2026-08-20 06:01:17.352 | ESU26_FUT_CME [CBV] 120 Min #16 | Reloading chart.
2026-08-20 06:01:17.352 | ESU26_FUT_CME [CBV] 120 Min #16 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart.
2026-08-20 06:01:17.352 | ESU26_FUT_CME [CBV] 120 Min #16 | There are no continuous futures contract symbols. Loading data normally.
2026-08-20 06:01:17.482 | ESU26_FUT_CME [CBV] 30 Min #17 | Reloading chart.
2026-08-20 06:01:17.482 | ESU26_FUT_CME [CBV] 30 Min #17 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart.
2026-08-20 06:01:17.482 | ESU26_FUT_CME [CBV] 30 Min #17 | There are no continuous futures contract symbols. Loading data normally.
2026-08-20 06:01:17.681 | ESU26_FUT_CME [CBV] 30 Min #23 | Reloading chart.
2026-08-20 06:01:17.681 | ESU26_FUT_CME [CBV] 30 Min #23 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart.
2026-08-20 06:01:17.681 | ESU26_FUT_CME [CBV] 30 Min #23 | There are no continuous futures contract symbols. Loading data normally.
2026-08-20 06:01:17.919 | ESU26_FUT_CME [CBV] 30 Min #24 | Reloading chart.
2026-08-20 06:01:17.919 | ESU26_FUT_CME [CBV] 30 Min #24 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart.
2026-08-20 06:01:17.919 | ESU26_FUT_CME [CBV] 30 Min #24 | There are no continuous futures contract symbols. Loading data normally.
2026-08-20 06:01:18.073 | NQU26_FUT_CME 5 Min #53 | Reloading chart.
2026-08-20 06:01:18.435 | RTYU26_FUT_CME 5 Min #54 | Reloading chart.
2026-08-20 06:01:18.475 | + Loading additional symbol data. | Number times message added: 1
2026-08-20 06:01:18.674 | USDX 5 Min #55 | Reloading chart.
2026-08-20 06:01:19.305 | + Loading additional symbol data.
2026-08-20 06:01:19.612 | ESU26_FUT_CME #1 | Reloading chart.
2026-08-20 06:01:19.815 | + Loading additional symbol data.
2026-08-20 06:01:20.497 | ESU26_FUT_CME [CB] 30 Min #10 | Reloading chart.
2026-08-20 06:01:20.497 | ESU26_FUT_CME [CB] 30 Min #10 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart.
2026-08-20 06:01:20.497 | ESU26_FUT_CME [CB] 30 Min #10 | There are no continuous futures contract symbols. Loading data normally.
2026-08-20 06:01:20.727 | Files to Open on Startup | Opening file: SierraEdge NQ PMP.Cht
2026-08-20 06:01:21.497 | NQU26_FUT_CME [CBV] 30 Min #10 | Reloading chart.
2026-08-20 06:01:21.497 | NQU26_FUT_CME [CBV] 30 Min #10 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart.
2026-08-20 06:01:21.497 | NQU26_FUT_CME [CBV] 30 Min #10 | There are no continuous futures contract symbols. Loading data normally.
2026-08-20 06:01:25.346 | NQU26_FUT_CME [CBV] #6 | Reloading chart.
2026-08-20 06:01:25.346 | NQU26_FUT_CME [CBV] #6 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart.
2026-08-20 06:01:25.346 | NQU26_FUT_CME [CBV] #6 | There are no continuous futures contract symbols. Loading data normally.
2026-08-20 06:01:28.064 | NQU26_FUT_CME [CBV] 60 Min #14 | Reloading chart.
2026-08-20 06:01:28.064 | NQU26_FUT_CME [CBV] 60 Min #14 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart.
2026-08-20 06:01:28.064 | NQU26_FUT_CME [CBV] 60 Min #14 | There are no continuous futures contract symbols. Loading data normally.
2026-08-20 06:01:28.385 | NQU26_FUT_CME [CBV] #1 | Reloading chart.
2026-08-20 06:01:28.385 | NQU26_FUT_CME [CBV] #1 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart.
2026-08-20 06:01:28.385 | NQU26_FUT_CME [CBV] #1 | There are no continuous futures contract symbols. Loading data normally.
2026-08-20 06:01:29.525 | NQU26_FUT_CME [CBV] #12 | Reloading chart.
2026-08-20 06:01:29.525 | NQU26_FUT_CME [CBV] #12 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart.
2026-08-20 06:01:29.525 | NQU26_FUT_CME [CBV] #12 | There are no continuous futures contract symbols. Loading data normally.
2026-08-20 06:01:29.870 | NQU26_FUT_CME [CBV] 60 Min #2 | Reloading chart.
2026-08-20 06:01:29.870 | NQU26_FUT_CME [CBV] 60 Min #2 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart.
2026-08-20 06:01:29.870 | NQU26_FUT_CME [CBV] 60 Min #2 | There are no continuous futures contract symbols. Loading data normally.
2026-08-20 06:01:29.977 | NQU26_FUT_CME [CBV] Daily #3 | Reloading chart.
2026-08-20 06:01:29.977 | NQU26_FUT_CME [CBV] Daily #3 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart.
2026-08-20 06:01:29.977 | NQU26_FUT_CME [CBV] Daily #3 | There are no continuous futures contract symbols. Loading data normally.
2026-08-20 06:01:31.016 | NQU26_FUT_CME [CBV] #4 | Reloading chart.
2026-08-20 06:01:31.016 | NQU26_FUT_CME [CBV] #4 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart.
2026-08-20 06:01:31.016 | NQU26_FUT_CME [CBV] #4 | There are no continuous futures contract symbols. Loading data normally.
2026-08-20 06:01:31.886 | NQU26_FUT_CME [CB] 30 Min #5 | Reloading chart.
2026-08-20 06:01:31.886 | NQU26_FUT_CME [CB] 30 Min #5 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart.
2026-08-20 06:01:31.886 | NQU26_FUT_CME [CB] 30 Min #5 | There are no continuous futures contract symbols. Loading data normally.
2026-08-20 06:01:32.830 | NQU26_FUT_CME [CBV] Daily #7 | Reloading chart.
2026-08-20 06:01:32.830 | NQU26_FUT_CME [CBV] Daily #7 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart.
2026-08-20 06:01:32.830 | NQU26_FUT_CME [CBV] Daily #7 | There are no continuous futures contract symbols. Loading data normally.
2026-08-20 06:01:33.379 | NQU26_FUT_CME [CBV] 480 Min #8 | Reloading chart.
2026-08-20 06:01:33.379 | NQU26_FUT_CME [CBV] 480 Min #8 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart.
2026-08-20 06:01:33.379 | NQU26_FUT_CME [CBV] 480 Min #8 | There are no continuous futures contract symbols. Loading data normally.
2026-08-20 06:01:34.359 | NQU26_FUT_CME [CBV] 120 Min #9 | Reloading chart.
2026-08-20 06:01:34.359 | NQU26_FUT_CME [CBV] 120 Min #9 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart.
2026-08-20 06:01:34.359 | NQU26_FUT_CME [CBV] 120 Min #9 | There are no continuous futures contract symbols. Loading data normally.
2026-08-20 06:01:34.511 | NQU26_FUT_CME #11 | Reloading chart.
2026-08-20 06:01:35.692 | NQU26_FUT_CME [CV] 5 Min #13 | Reloading chart.
2026-08-20 06:01:35.692 | NQU26_FUT_CME [CV] 5 Min #13 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart.
2026-08-20 06:01:35.692 | NQU26_FUT_CME [CV] 5 Min #13 | There are no continuous futures contract symbols. Loading data normally.
2026-08-20 06:01:35.928 | Files to Open on Startup | Opening file: SierraEdge PRO NQ.Cht
2026-08-20 06:01:37.700 | Loading DLL: C:\SierraChart\Data\TTMSqueeze.dll (TTMSqueeze_64.dll). Handle: 66000000
2026-08-20 06:01:38.300 | NQU26_FUT_CME [CBV] 1 Min #6 | Reloading chart.
2026-08-20 06:01:38.300 | NQU26_FUT_CME [CBV] 1 Min #6 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart.
2026-08-20 06:01:38.300 | NQU26_FUT_CME [CBV] 1 Min #6 | There are no continuous futures contract symbols. Loading data normally.
2026-08-20 06:01:38.624 | NQU26_FUT_CME [CBV] Renko 22t #9 | Reloading chart.
2026-08-20 06:01:38.624 | NQU26_FUT_CME [CBV] Renko 22t #9 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart.
2026-08-20 06:01:38.624 | NQU26_FUT_CME [CBV] Renko 22t #9 | There are no continuous futures contract symbols. Loading data normally.
2026-08-20 06:01:38.765 | Loading DLL: C:\SierraChart\Data\GoogleSheetsImporter.dll (GoogleSheetsImporter_64.dll). Handle: fc50000
2026-08-20 06:01:38.922 | Loading DLL: C:\SierraChart\Data\OffenseDefense.dll (OffenseDefense_64.dll). Handle: 10a40000
2026-08-20 06:01:39.003 | Loading DLL: C:\SierraChart\Data\jtMTFMomentum.dll (jtMTFMomentum_64.dll). Handle: 7ffc98270000
2026-08-20 06:01:39.079 | Loading DLL: C:\SierraChart\Data\MomentumCalculations_64 (1).dll (MomentumCalculations_64 (1).dll). Handle: 7ffc920f0000
2026-08-20 06:01:39.535 | NQU26_FUT_CME [CBV] 5 Min #33 | Reloading chart.
2026-08-20 06:01:39.535 | NQU26_FUT_CME [CBV] 5 Min #33 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart.
2026-08-20 06:01:39.535 | NQU26_FUT_CME [CBV] 5 Min #33 | There are no continuous futures contract symbols. Loading data normally.
2026-08-20 06:01:39.793 | Loading DLL: C:\SierraChart\Data\MenthorQLevelsV3.dll (MenthorQLevelsV3.dll). Handle: 7ffc92030000
2026-08-20 06:01:40.064 | Loading DLL: C:\SierraChart\Data\BreakScanner.dll (BreakScanner_64.dll). Handle: 13470000
2026-08-20 06:01:40.223 | Loading DLL: C:\SierraChart\Data\OrderflowTriggers2.dll (OrderflowTriggers2_64.dll). Handle: 16330000
2026-08-20 06:01:40.433 | Loading DLL: C:\SierraChart\Data\DeltaSlingshotFADE.dll (DeltaSlingshotFADE_64.dll). Handle: 7ffc39f90000
2026-08-20 06:01:40.435 | The custom study DeltaSlingshotFADE.dll requires version 2911 or higher of Sierra Chart. Current version: 2899. Select 'Help >> Download Current Version'. *
2026-08-20 06:01:41.223 | NQU26_FUT_CME/MNQU26_FUT_CME [CBV] 1 Min #21 | Reloading chart.
2026-08-20 06:01:41.223 | NQU26_FUT_CME/MNQU26_FUT_CME [CBV] 1 Min #21 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart.
2026-08-20 06:01:41.223 | NQU26_FUT_CME/MNQU26_FUT_CME [CBV] 1 Min #21 | There are no continuous futures contract symbols. Loading data normally.
2026-08-20 06:01:43.046 | Loading market depth data.
2026-08-20 06:01:44.354 | Loaded depth data records for NQU26_FUT_CME 2026-08-09 from 00:00:00.000000 to 00:00:00.000000.
2026-08-20 06:01:44.428 | NQU26_FUT_CME [CBV] Flex Renko 40-20-16 #8 | Reloading chart.
2026-08-20 06:01:44.428 | NQU26_FUT_CME [CBV] Flex Renko 40-20-16 #8 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart.
2026-08-20 06:01:44.428 | NQU26_FUT_CME [CBV] Flex Renko 40-20-16 #8 | There are no continuous futures contract symbols. Loading data normally.
2026-08-20 06:01:44.511 | Loading DLL: C:\SierraChart\Data\CheckAccountName-razvanmindruta.dll (CheckAccountName-razvanmindruta_64.dll). Handle: 9d70000
2026-08-20 06:01:44.557 | Loading DLL: C:\SierraChart\Data\ABSindi.dll (ABSindi_64.dll). Handle: aa00000
2026-08-20 06:01:44.612 | Loading DLL: C:\SierraChart\Data\TradesVizAutoSyncTradesProduction_0.016.dll (TradesVizAutoSyncTradesProduction_0.016.dll). Handle: b180000
2026-08-20 06:01:44.669 | NQU26_FUT_CME 15.00 Range #3 | Reloading chart.
2026-08-20 06:01:44.867 | NQU26_FUT_CME 15.00 Range #1 | Reloading chart.
2026-08-20 06:01:45.141 | NQU26_FUT_CME [CV] 20.00 Range #4 | Reloading chart.
2026-08-20 06:01:45.141 | NQU26_FUT_CME [CV] 20.00 Range #4 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart.
2026-08-20 06:01:45.141 | NQU26_FUT_CME [CV] 20.00 Range #4 | There are no continuous futures contract symbols. Loading data normally.
2026-08-20 06:01:45.499 | NVOL-NYSE 1000 Trades #2 | Reloading chart.
2026-08-20 06:01:45.683 | NISS-NYSE 1000 Trades #5 | Reloading chart.
2026-08-20 06:01:46.114 | VOLX 1000 Trades #7 | Reloading chart.
2026-08-20 06:01:46.291 | TICK-NYSE 1000 Trades #10 | Reloading chart.
2026-08-20 06:01:46.300 | NQU26_FUT_CME 1 Min #11 | Reloading chart.
2026-08-20 06:01:46.347 | NQU26_FUT_CME 5 Min #12 | Reloading chart.
2026-08-20 06:01:46.501 | NQU26_FUT_CME 15 Min #13 | Reloading chart.
2026-08-20 06:01:46.546 | NQU26_FUT_CME 60 Min #14 | Reloading chart.
2026-08-20 06:01:46.562 | + Loading additional symbol data.
2026-08-20 06:01:46.674 | NQU26_FUT_CME 240 Min #15 | Reloading chart.
2026-08-20 06:01:46.778 | NQU26_FUT_CME Daily #16 | Reloading chart.
2026-08-20 06:01:47.026 | Loaded depth data records for NQU26_FUT_CME 2026-08-10 from 2026-08-10 09:30:00.000000 to 2026-08-10 15:59:59.999000.
2026-08-20 06:01:47.576 | + Loading additional symbol data.
2026-08-20 06:01:49.109 | NVOL-NYSE 500 Volume #17 | Reloading chart.
2026-08-20 06:01:49.132 | NISS-NYSE 500 Volume #18 | Reloading chart.
2026-08-20 06:01:49.148 | VOLX 500 Volume #19 | Reloading chart.
2026-08-20 06:01:49.252 | TICK-NYSE 500 Volume #20 | Reloading chart.
2026-08-20 06:01:49.300 | NQU26_FUT_CME 1 Min #22 | Reloading chart.
2026-08-20 06:01:49.322 | NQU26_FUT_CME 5 Min #23 | Reloading chart.
2026-08-20 06:01:49.341 | + Loading additional symbol data.
2026-08-20 06:01:49.362 | NQU26_FUT_CME 15 Min #24 | Reloading chart.
2026-08-20 06:01:49.471 | NQU26_FUT_CME 60 Min #25 | Reloading chart.
2026-08-20 06:01:49.572 | Loaded depth data records for NQU26_FUT_CME 2026-08-11 from 2026-08-11 09:30:00.000000 to 2026-08-11 12:10:16.913000.
2026-08-20 06:01:49.621 | + Loading additional symbol data.
2026-08-20 06:01:49.645 | NQU26_FUT_CME 240 Min #26 | Reloading chart.
2026-08-20 06:01:49.693 | NQU26_FUT_CME Daily #27 | Reloading chart.
2026-08-20 06:01:50.181 | Files to Open on Startup | Opening file: SierraEdge GC PMP.Cht
2026-08-20 06:01:50.481 | Loaded depth data records for NQU26_FUT_CME 2026-08-14 from 2026-08-14 11:14:15.983000 to 2026-08-14 15:59:59.999000.
2026-08-20 06:01:50.562 | Loading market depth data.
2026-08-20 06:01:51.302 | + Loading additional symbol data.
2026-08-20 06:01:51.447 | GCM26_FUT_CME [CBV] #1 | Reloading chart.
2026-08-20 06:01:51.447 | GCM26_FUT_CME [CBV] #1 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart.
2026-08-20 06:01:51.447 | GCM26_FUT_CME [CBV] #1 | There are no continuous futures contract symbols. Loading data normally.
2026-08-20 06:01:51.664 | Loaded depth data records for NQU26_FUT_CME 2026-08-16 from 00:00:00.000000 to 00:00:00.000000.
2026-08-20 06:01:51.699 | GCM26_FUT_CME [CBV] #11 | Reloading chart.
2026-08-20 06:01:51.699 | GCM26_FUT_CME [CBV] #11 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart.
2026-08-20 06:01:51.699 | GCM26_FUT_CME [CBV] #11 | There are no continuous futures contract symbols. Loading data normally.
2026-08-20 06:01:51.743 | GCM26_FUT_CME [CBV] 60 Min #2 | Reloading chart.
2026-08-20 06:01:51.743 | GCM26_FUT_CME [CBV] 60 Min #2 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart.
2026-08-20 06:01:51.743 | GCM26_FUT_CME [CBV] 60 Min #2 | There are no continuous futures contract symbols. Loading data normally.
2026-08-20 06:01:51.771 | Loaded depth data records for NQU26_FUT_CME 2026-08-09 from 2026-08-09 18:00:00.000000 to 2026-08-09 19:59:59.456000.
2026-08-20 06:01:51.831 | GCM26_FUT_CME [CBV] #3 | Reloading chart.
2026-08-20 06:01:51.831 | GCM26_FUT_CME [CBV] #3 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart.
2026-08-20 06:01:51.831 | GCM26_FUT_CME [CBV] #3 | There are no continuous futures contract symbols. Loading data normally.
2026-08-20 06:01:52.067 | GCM26_FUT_CME [CBV] Daily #4 | Reloading chart.
2026-08-20 06:01:52.067 | GCM26_FUT_CME [CBV] Daily #4 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart.
2026-08-20 06:01:52.067 | GCM26_FUT_CME [CBV] Daily #4 | There are no continuous futures contract symbols. Loading data normally.
2026-08-20 06:01:52.156 | GCM26_FUT_CME [CBV] Daily #5 | Reloading chart.
2026-08-20 06:01:52.156 | GCM26_FUT_CME [CBV] Daily #5 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart.
2026-08-20 06:01:52.156 | GCM26_FUT_CME [CBV] Daily #5 | There are no continuous futures contract symbols. Loading data normally.
2026-08-20 06:01:52.198 | + Loading additional symbol data.
2026-08-20 06:01:52.212 | GCM26_FUT_CME [CBV] 120 Min #7 | Reloading chart.
2026-08-20 06:01:52.212 | GCM26_FUT_CME [CBV] 120 Min #7 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart.
2026-08-20 06:01:52.212 | GCM26_FUT_CME [CBV] 120 Min #7 | There are no continuous futures contract symbols. Loading data normally.
2026-08-20 06:01:52.259 | GCM26_FUT_CME [CBV] 30 Min #8 | Reloading chart.
2026-08-20 06:01:52.259 | GCM26_FUT_CME [CBV] 30 Min #8 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart.
2026-08-20 06:01:52.259 | GCM26_FUT_CME [CBV] 30 Min #8 | There are no continuous futures contract symbols. Loading data normally.
2026-08-20 06:01:52.281 | GCZ26_FUT_CME [CB] 30 Min #9 | Reloading chart.
2026-08-20 06:01:52.281 | GCZ26_FUT_CME [CB] 30 Min #9 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart.
2026-08-20 06:01:52.281 | GCZ26_FUT_CME [CB] 30 Min #9 | There are no continuous futures contract symbols. Loading data normally.
2026-08-20 06:01:52.360 | GCZ26_FUT_CME [CBV] 30 Min #10 | Reloading chart.
2026-08-20 06:01:52.360 | GCZ26_FUT_CME [CBV] 30 Min #10 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart.
2026-08-20 06:01:52.360 | GCZ26_FUT_CME [CBV] 30 Min #10 | There are no continuous futures contract symbols. Loading data normally.
2026-08-20 06:01:52.426 | GCM26_FUT_CME [CBV] 480 Min #6 | Reloading chart.
2026-08-20 06:01:52.426 | GCM26_FUT_CME [CBV] 480 Min #6 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart.
2026-08-20 06:01:52.426 | GCM26_FUT_CME [CBV] 480 Min #6 | There are no continuous futures contract symbols. Loading data normally.
2026-08-20 06:01:52.655 | USDX [CBV] 3 Min #12 | Reloading chart.
2026-08-20 06:01:52.655 | USDX [CBV] 3 Min #12 | No contract months found for symbol. Unable to build continuous futures contract chart.
2026-08-20 06:01:52.655 | USDX [CBV] 3 Min #12 | There are no continuous futures contract symbols. Loading data normally.
2026-08-20 06:01:52.790 | GCZ26_FUT_CME #13 | Reloading chart.
2026-08-20 06:01:52.984 | GCM26_FUT_CME [CBV] 5 Min #14 | Reloading chart.
2026-08-20 06:01:52.984 | GCM26_FUT_CME [CBV] 5 Min #14 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart.
2026-08-20 06:01:52.984 | GCM26_FUT_CME [CBV] 5 Min #14 | There are no continuous futures contract symbols. Loading data normally.
2026-08-20 06:01:53.307 | Files to Open on Startup | Opening file: SierraEdge PRO GC.Cht
2026-08-20 06:01:53.727 | Loading DLL: C:\SierraChart\Data\VolumeTriggers.dll (VolumeTriggers_64.dll). Handle: 90d0000
2026-08-20 06:01:53.749 | GCM26_FUT_CME [CBV] 3.0 Range #5 | Reloading chart.
2026-08-20 06:01:53.749 | GCM26_FUT_CME [CBV] 3.0 Range #5 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart.
2026-08-20 06:01:53.749 | GCM26_FUT_CME [CBV] 3.0 Range #5 | There are no continuous futures contract symbols. Loading data normally.
2026-08-20 06:01:53.760 | Loading DLL: C:\SierraChart\Data\DeltaWickABS.dll (DeltaWickABS_64.dll). Handle: 7ffc737d0000
2026-08-20 06:01:53.762 | The custom study DeltaWickABS.dll requires version 2911 or higher of Sierra Chart. Current version: 2899. Select 'Help >> Download Current Version'. *
2026-08-20 06:01:53.780 | GCM26_FUT_CME/MGCM26_FUT_CME [CBV] 30 Sec #6 | Reloading chart.
2026-08-20 06:01:53.780 | GCM26_FUT_CME/MGCM26_FUT_CME [CBV] 30 Sec #6 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart.
2026-08-20 06:01:53.780 | GCM26_FUT_CME/MGCM26_FUT_CME [CBV] 30 Sec #6 | There are no continuous futures contract symbols. Loading data normally.
2026-08-20 06:01:54.419 | GCZ26_FUT_CME/MGCZ26_FUT_CME 0.8 Range #7 | Reloading chart.
2026-08-20 06:01:54.494 | GCM26_FUT_CME/MGCM26_FUT_CME [CBV] 200 Trades #12 | Reloading chart.
2026-08-20 06:01:54.494 | GCM26_FUT_CME/MGCM26_FUT_CME [CBV] 200 Trades #12 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart.
2026-08-20 06:01:54.494 | GCM26_FUT_CME/MGCM26_FUT_CME [CBV] 200 Trades #12 | There are no continuous futures contract symbols. Loading data normally.
2026-08-20 06:01:54.500 | Loading market depth data.
2026-08-20 06:01:54.588 | + Loading additional symbol data.
2026-08-20 06:01:54.847 | GCZ26_FUT_CME [CBV] Renko 22t #2 | Reloading chart.
2026-08-20 06:01:54.847 | GCZ26_FUT_CME [CBV] Renko 22t #2 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart.
2026-08-20 06:01:54.847 | GCZ26_FUT_CME [CBV] Renko 22t #2 | There are no continuous futures contract symbols. Loading data normally.
2026-08-20 06:01:54.860 | Loaded depth data records for GCM26_FUT_CME 2026-06-19 from 2026-06-19 08:20:00.027000 to 2026-06-19 13:00:00.000000.
2026-08-20 06:01:54.860 | Loaded depth data records for GCM26_FUT_CME 2026-06-20 from 2026-06-20 08:39:42.941897 to 2026-06-20 08:39:42.941897.
2026-08-20 06:01:54.866 | GCZ26_FUT_CME 2.0 Range #3 | Reloading chart.
2026-08-20 06:01:54.882 | Files to Open on Startup | Opening file: Sierra Edge ES execution.Cht
2026-08-20 06:01:54.964 | Loaded depth data records for GCM26_FUT_CME 2026-06-21 from 00:00:00.000000 to 00:00:00.000000.
2026-08-20 06:01:55.311 | Loading DLL: C:\SierraChart\Data\CumulativeDeltaDivDetector.dll (CumulativeDeltaDivDetector_64.dll). Handle: 1fd50000
2026-08-20 06:01:55.349 | ESU26_FUT_CME [CBV] 3000 Volume #1 | Reloading chart.
2026-08-20 06:01:55.349 | ESU26_FUT_CME [CBV] 3000 Volume #1 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart.
2026-08-20 06:01:55.349 | ESU26_FUT_CME [CBV] 3000 Volume #1 | There are no continuous futures contract symbols. Loading data normally.
2026-08-20 06:01:55.629 | ESU26_FUT_CME [CBV] 30 Sec #4 | Reloading chart.
2026-08-20 06:01:55.629 | ESU26_FUT_CME [CBV] 30 Sec #4 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart.
2026-08-20 06:01:55.629 | ESU26_FUT_CME [CBV] 30 Sec #4 | There are no continuous futures contract symbols. Loading data normally.
2026-08-20 06:01:55.689 | Loading DLL: C:\SierraChart\Data\gexbot_sierra_plugin_v3.2026.03.16.dll (gexbot_sierra_plugin_v3.2026.03.16.dll). Handle: 7ffc39e90000
2026-08-20 06:01:55.721 | Loading market depth data.
2026-08-20 06:01:55.737 | ESU26_FUT_CME/MESU26_FUT_CME [CBV] 512 Trades #6 | Reloading chart.
2026-08-20 06:01:55.737 | ESU26_FUT_CME/MESU26_FUT_CME [CBV] 512 Trades #6 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart.
2026-08-20 06:01:55.737 | ESU26_FUT_CME/MESU26_FUT_CME [CBV] 512 Trades #6 | There are no continuous futures contract symbols. Loading data normally.
2026-08-20 06:01:55.923 | Loaded depth data records for GCZ26_FUT_CME 2026-08-09 from 2026-08-09 18:00:00.000000 to 2026-08-09 19:59:59.997000.
2026-08-20 06:01:55.932 | ESU26_FUT_CME/MESU26_FUT_CME [CBV] Flex Renko 6-4-1 #8 | Reloading chart.
2026-08-20 06:01:55.932 | ESU26_FUT_CME/MESU26_FUT_CME [CBV] Flex Renko 6-4-1 #8 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart.
2026-08-20 06:01:55.932 | ESU26_FUT_CME/MESU26_FUT_CME [CBV] Flex Renko 6-4-1 #8 | There are no continuous futures contract symbols. Loading data normally.
2026-08-20 06:01:56.903 | Loading market depth data.
2026-08-20 06:01:57.241 | Loaded depth data records for GCM26_FUT_CME 2026-06-22 from 2026-06-22 08:20:00.002000 to 2026-06-22 16:00:00.859000.
2026-08-20 06:01:57.564 | ESU26_FUT_CME 2.50 Range #9 | Reloading chart.
2026-08-20 06:01:57.633 | ESU26_FUT_CME [CBV] 40 Trades #12 | Reloading chart.
2026-08-20 06:01:57.633 | ESU26_FUT_CME [CBV] 40 Trades #12 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart.
2026-08-20 06:01:57.633 | ESU26_FUT_CME [CBV] 40 Trades #12 | There are no continuous futures contract symbols. Loading data normally.
2026-08-20 06:01:57.748 | ESU26_FUT_CME [CBV] 5 Min #5 | Reloading chart.
2026-08-20 06:01:57.748 | ESU26_FUT_CME [CBV] 5 Min #5 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart.
2026-08-20 06:01:57.748 | ESU26_FUT_CME [CBV] 5 Min #5 | There are no continuous futures contract symbols. Loading data normally.
2026-08-20 06:01:57.917 | ESU26_FUT_CME [CBV] 3000 Volume #11 | Reloading chart.
2026-08-20 06:01:57.917 | ESU26_FUT_CME [CBV] 3000 Volume #11 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart.
2026-08-20 06:01:57.917 | ESU26_FUT_CME [CBV] 3000 Volume #11 | There are no continuous futures contract symbols. Loading data normally.
2026-08-20 06:01:57.996 | Loaded depth data records for NQU26_FUT_CME 2026-08-17 from 2026-08-17 09:30:00.000000 to 2026-08-17 15:59:59.999000.
2026-08-20 06:01:58.186 | ESU26_FUT_CME 4.00 Range #3 | Reloading chart.
2026-08-20 06:01:58.412 | Loading market depth data.
2026-08-20 06:01:58.728 | Loaded depth data records for ESU26_FUT_CME 2026-08-17 from 2026-08-17 18:00:00.000000 to 2026-08-17 19:59:59.924000.
2026-08-20 06:01:59.102 | + Loading additional symbol data.
2026-08-20 06:01:59.137 | ESU26_FUT_CME 7.00 Range #7 | Reloading chart.
2026-08-20 06:01:59.451 | Files to Open on Startup | Opening file: SierraEdge ES PMP.Cht
2026-08-20 06:01:59.498 | The Chartbook file is not compatible. Contact Sierra Chart support for help with converting it. File: C:\SierraChart\Data\SierraEdge ES PMP.Cht *
2026-08-20 06:01:59.617 | + Loading additional symbol data. | Number times message added: 1
2026-08-20 06:02:00.253 | ESU26_FUT_CME [CBV-D] Daily #4 | Chart data loading complete.
2026-08-20 06:02:00.474 | Loaded depth data records for ESU26_FUT_CME 2026-08-14 from 2026-08-14 11:15:37.958000 to 2026-08-14 15:59:59.999000.
2026-08-20 06:02:00.478 | ESU26_FUT_CME [CBV-D] Daily #14 | Chart data loading complete.
2026-08-20 06:02:00.490 | Loaded depth data records for ESU26_FUT_CME 2026-08-16 from 00:00:00.000000 to 00:00:00.000000.
2026-08-20 06:02:00.904 | + Loading additional symbol data. | Number times message added: 1
2026-08-20 06:02:01.017 | Using symbol data fast lookup vector
2026-08-20 06:02:01.021 | SC Data with Depth | Starting real-time market data updates for: NVOL-NYSE. ID: 1 Service code: statscalc
2026-08-20 06:02:01.041 | SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 10048
2026-08-20 06:02:01.043 | DTC Client socket (3) | Creating socket.
2026-08-20 06:02:01.043 | DTC Client socket (3) | New receive buffer size: 0
2026-08-20 06:02:01.043 | DTC Client socket (3) | Connecting to IP: 69.39.70.241.
2026-08-20 06:02:01.043 | SC Data with Depth | Requesting security definition data for: NVOL-NYSE. ID: 1
2026-08-20 06:02:01.043 | Starting DelayedDownloadMonitoringTimer
2026-08-20 06:02:01.043 | Starting HDTimeoutTimer
2026-08-20 06:02:01.043 | Added historical Intraday data request for NVOL-NYSE to the queue.
2026-08-20 06:02:01.043 | Intraday data recording state for symbol NVOL-NYSE is set to download 'Pending'.
2026-08-20 06:02:01.044 | Triggering next historical data download in queue.
2026-08-20 06:02:01.044 | TICK-NYSE 1 Min #2 | Started historical data download for additional symbol NVOL-NYSE. Download ID: 1
2026-08-20 06:02:01.044 | Loaded depth data records for GCZ26_FUT_CME 2026-08-10 from 2026-08-09 20:00:00.000000 to 2026-08-10 19:59:59.911000.
2026-08-20 06:02:01.045 | SC Data with Depth | Starting real-time market data updates for: NISS-NYSE. ID: 2 Service code: statscalc
2026-08-20 06:02:01.045 | SC Data with Depth | Requesting security definition data for: NISS-NYSE. ID: 2
2026-08-20 06:02:01.045 | Added historical Intraday data request for NISS-NYSE to the queue.
2026-08-20 06:02:01.045 | Intraday data recording state for symbol NISS-NYSE is set to download 'Pending'.
2026-08-20 06:02:01.045 | TICK-NYSE 1 Min #2 | Started historical data download for additional symbol NISS-NYSE. Download ID: 2
2026-08-20 06:02:01.045 | TICK-NYSE 1 Min #2 | Chart data loading complete.
2026-08-20 06:02:01.092 | + Loading additional symbol data.
2026-08-20 06:02:01.111 | ESU26_FUT_CME #1 | StartDateTimeForLoadingOrderFills: 2025-08-12 00:00:00
2026-08-20 06:02:01.113 | ESU26_FUT_CME #1 | Chart data loading complete.
2026-08-20 06:02:01.129 | USDX 5 Min #55 | StartDateTimeForLoadingOrderFills: 2025-08-13 00:00:00
2026-08-20 06:02:01.129 | USDX 5 Min #55 | Chart data loading complete.
2026-08-20 06:02:01.213 | ESU26_FUT_CME [CBV-D] #31 | Chart data loading complete.
2026-08-20 06:02:01.247 | ESU26_FUT_CME [CBV-D] 30 Min #17 | Chart data loading complete.
2026-08-20 06:02:01.270 | ESU26_FUT_CME [CBV-D] 30 Min #23 | Chart data loading complete.
2026-08-20 06:02:01.290 | ESU26_FUT_CME [CBV-D] 30 Min #24 | Chart data loading complete.
2026-08-20 06:02:01.430 | ESU26_FUT_CME [CBV-D] #2 | Chart data loading complete.
2026-08-20 06:02:01.739 | SC Data with Depth | Starting real-time market data updates for: NISS-NASDAQ. ID: 3 Service code: statscalc
2026-08-20 06:02:01.739 | SC Data with Depth | Requesting security definition data for: NISS-NASDAQ. ID: 3
2026-08-20 06:02:01.740 | Added historical Intraday data request for NISS-NASDAQ to the queue.
2026-08-20 06:02:01.740 | Intraday data recording state for symbol NISS-NASDAQ is set to download 'Pending'.
2026-08-20 06:02:01.740 | TICK-NASDAQ 1 Min #3 | Started historical data download for additional symbol NISS-NASDAQ. Download ID: 3
2026-08-20 06:02:01.740 | SC Data with Depth | Starting real-time market data updates for: NVOL-NASDAQ. ID: 4 Service code: statscalc
2026-08-20 06:02:01.740 | SC Data with Depth | Requesting security definition data for: NVOL-NASDAQ. ID: 4
2026-08-20 06:02:01.740 | Added historical Intraday data request for NVOL-NASDAQ to the queue.
2026-08-20 06:02:01.740 | Intraday data recording state for symbol NVOL-NASDAQ is set to download 'Pending'.
2026-08-20 06:02:01.740 | TICK-NASDAQ 1 Min #3 | Started historical data download for additional symbol NVOL-NASDAQ. Download ID: 4
2026-08-20 06:02:01.741 | TICK-NASDAQ 1 Min #3 | Chart data loading complete.
2026-08-20 06:02:01.771 | RTYU26_FUT_CME 5 Min #54 | StartDateTimeForLoadingOrderFills: 2025-08-12 00:00:00
2026-08-20 06:02:01.771 | RTYU26_FUT_CME 5 Min #54 | Chart data loading complete.
2026-08-20 06:02:01.813 | NQU26_FUT_CME [CBV-D] Daily #3 | Chart data loading complete.
2026-08-20 06:02:01.915 | UDVR-NQ 1 Min #1 | Chart data loading complete.
2026-08-20 06:02:02.015 | ESU26_FUT_CME [CBV-D] #11 | Chart data loading complete.
2026-08-20 06:02:02.058 | NQU26_FUT_CME [CBV-D] Daily #7 | Chart data loading complete.
2026-08-20 06:02:02.108 | NQU26_FUT_CME [CBV-D] #12 | Chart data loading complete.
2026-08-20 06:02:02.141 | NQU26_FUT_CME [CBV-D] 30 Min #10 | Chart data loading complete.
2026-08-20 06:02:02.160 | ESU26_FUT_CME [CBV-D] 120 Min #16 | Chart data loading complete.
2026-08-20 06:02:02.175 | ESU26_FUT_CME [CBV-D] 480 Min #15 | Chart data loading complete.
2026-08-20 06:02:02.185 | NQU26_FUT_CME 5 Min #53 | StartDateTimeForLoadingOrderFills: 2025-08-12 00:00:00
2026-08-20 06:02:02.186 | NQU26_FUT_CME 5 Min #53 | Chart data loading complete.
2026-08-20 06:02:02.263 | Loaded depth data records for GCM26_FUT_CME 2026-06-23 from 2026-06-23 08:20:00.000000 to 2026-06-23 16:00:00.990000.
2026-08-20 06:02:02.268 | ESU26_FUT_CME [CBV-D] 60 Min #34 | Chart data loading complete.
2026-08-20 06:02:02.368 | NQU26_FUT_CME [CV-D] 5 Min #13 | Chart data loading complete.
2026-08-20 06:02:02.514 | NQU26_FUT_CME [CBV-D] #1 | Chart data loading complete.
2026-08-20 06:02:02.614 | ESU26_FUT_CME [CB-D] 30 Min #10 | Chart data loading complete.
2026-08-20 06:02:02.748 | NQU26_FUT_CME [CBV-D] #6 | Chart data loading complete.
2026-08-20 06:02:02.886 | NQU26_FUT_CME [CBV-D] #4 | Chart data loading complete.
2026-08-20 06:02:02.964 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (4) | Creating socket. Using TLS 1.2.
2026-08-20 06:02:02.964 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (4) | New receive buffer size: 0
2026-08-20 06:02:02.964 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (4) | Connecting to IP: 38.79.0.89.
2026-08-20 06:02:03.321 | NQU26_FUT_CME [CBV-D] 60 Min #14 | Chart data loading complete.
2026-08-20 06:02:03.364 | NQU26_FUT_CME [CBV-D] 60 Min #2 | Chart data loading complete.
2026-08-20 06:02:03.520 | NQU26_FUT_CME [CB-D] 30 Min #5 | Chart data loading complete.
2026-08-20 06:02:04.100 | NQU26_FUT_CME [CBV-D] Renko 22t #9 | Chart data loading complete.
2026-08-20 06:02:04.132 | NQU26_FUT_CME [CBV-D] 120 Min #9 | Chart data loading complete.
2026-08-20 06:02:04.164 | NQU26_FUT_CME [CBV-D] 480 Min #8 | Chart data loading complete.
2026-08-20 06:02:04.439 | NQU26_FUT_CME #11 | Chart data loading complete.
2026-08-20 06:02:04.451 | NQU26_FUT_CME [CBV-D] 1 Min #6 | StartDateTimeForLoadingOrderFills: 2025-08-12 00:00:00
2026-08-20 06:02:05.165 | NQU26_FUT_CME [CBV-D] 1 Min #6 | Chart data loading complete.
2026-08-20 06:02:05.174 | NISS-NYSE 1000 Trades #5 | Chart data loading complete.
2026-08-20 06:02:05.194 | NQU26_FUT_CME [CBV-D] 5 Min #33 | Study: Google Sheets Importer | Making HTTP request.
2026-08-20 06:02:05.304 | Loaded depth data records for GCZ26_FUT_CME 2026-08-11 from 2026-08-10 20:00:00.000000 to 2026-08-11 12:00:06.809000.
2026-08-20 06:02:05.386 | NQU26_FUT_CME [CBV-D] 5 Min #33 | Chart data loading complete.
2026-08-20 06:02:05.408 | Chart #16 has tagged chart #33 for full recalculation. Chartbook: SierraEdge PRO NQ.Cht
2026-08-20 06:02:05.408 | NQU26_FUT_CME Daily #16 | Chart data loading complete.
2026-08-20 06:02:05.444 | NQU26_FUT_CME [CV-D] 20.00 Range #4 | StartDateTimeForLoadingOrderFills: 2025-08-12 00:00:00
2026-08-20 06:02:05.470 | NQU26_FUT_CME [CV-D] 20.00 Range #4 | Chart data loading complete.
2026-08-20 06:02:05.498 | VOLX 1000 Trades #7 | Chart data loading complete.
2026-08-20 06:02:05.525 | Chart #11 has tagged chart #33 for full recalculation. Chartbook: SierraEdge PRO NQ.Cht
2026-08-20 06:02:05.525 | NQU26_FUT_CME 1 Min #11 | Chart data loading complete.
2026-08-20 06:02:05.527 | Chart #12 has tagged chart #33 for full recalculation. Chartbook: SierraEdge PRO NQ.Cht
2026-08-20 06:02:05.527 | NQU26_FUT_CME 5 Min #12 | Chart data loading complete.
2026-08-20 06:02:05.529 | Chart #15 has tagged chart #33 for full recalculation. Chartbook: SierraEdge PRO NQ.Cht
2026-08-20 06:02:05.529 | NQU26_FUT_CME 240 Min #15 | Chart data loading complete.
2026-08-20 06:02:05.535 | Chart #13 has tagged chart #33 for full recalculation. Chartbook: SierraEdge PRO NQ.Cht
2026-08-20 06:02:05.535 | NQU26_FUT_CME 15 Min #13 | Chart data loading complete.
2026-08-20 06:02:05.536 | Chart #14 has tagged chart #33 for full recalculation. Chartbook: SierraEdge PRO NQ.Cht
2026-08-20 06:02:05.536 | NQU26_FUT_CME 60 Min #14 | Chart data loading complete.
2026-08-20 06:02:05.539 | Chart #19 has tagged chart #33 for full recalculation. Chartbook: SierraEdge PRO NQ.Cht
2026-08-20 06:02:05.539 | VOLX 500 Volume #19 | Chart data loading complete.
2026-08-20 06:02:05.559 | Chart #18 has tagged chart #33 for full recalculation. Chartbook: SierraEdge PRO NQ.Cht
2026-08-20 06:02:05.559 | NISS-NYSE 500 Volume #18 | Chart data loading complete.
2026-08-20 06:02:05.565 | NQU26_FUT_CME Daily #27 | Chart data loading complete.
2026-08-20 06:02:05.600 | NVOL-NYSE 1000 Trades #2 | Chart data loading complete.
2026-08-20 06:02:05.606 | Chart #17 has tagged chart #33 for full recalculation. Chartbook: SierraEdge PRO NQ.Cht
2026-08-20 06:02:05.606 | NVOL-NYSE 500 Volume #17 | Chart data loading complete.
2026-08-20 06:02:05.626 | Chart #22 has tagged chart #33 for full recalculation. Chartbook: SierraEdge PRO NQ.Cht
2026-08-20 06:02:05.626 | NQU26_FUT_CME 1 Min #22 | Chart data loading complete.
2026-08-20 06:02:05.632 | GCM26_FUT_CME [CBV-D] #1 | Chart data loading complete.
2026-08-20 06:02:05.637 | GCM26_FUT_CME [CBV-D] #11 | Chart data loading complete.
2026-08-20 06:02:05.638 | NQU26_FUT_CME 15 Min #24 | Chart data loading complete.
2026-08-20 06:02:05.644 | NQU26_FUT_CME 240 Min #26 | Chart data loading complete.
2026-08-20 06:02:05.646 | Chart #23 has tagged chart #33 for full recalculation. Chartbook: SierraEdge PRO NQ.Cht
2026-08-20 06:02:05.646 | NQU26_FUT_CME 5 Min #23 | Chart data loading complete.
2026-08-20 06:02:05.650 | NQU26_FUT_CME 60 Min #25 | Chart data loading complete.
2026-08-20 06:02:05.672 | GCM26_FUT_CME [CBV-D] Daily #4 | Chart data loading complete.
2026-08-20 06:02:05.674 | TICK-NYSE 1000 Trades #10 | Chart data loading complete.
2026-08-20 06:02:05.676 | Chart #20 has tagged chart #33 for full recalculation. Chartbook: SierraEdge PRO NQ.Cht
2026-08-20 06:02:05.676 | TICK-NYSE 500 Volume #20 | Chart data loading complete.
2026-08-20 06:02:05.708 | NQU26_FUT_CME 15.00 Range #3 | StartDateTimeForLoadingOrderFills: 2025-08-12 00:00:00
2026-08-20 06:02:05.725 | SC Data with Depth | Starting real-time market data updates for: TICK-NYSE. ID: 5 Service code: statscalc
2026-08-20 06:02:05.725 | SC Data with Depth | Requesting security definition data for: TICK-NYSE. ID: 5
2026-08-20 06:02:05.725 | Added historical Intraday data request for TICK-NYSE to the queue.
2026-08-20 06:02:05.725 | Intraday data recording state for symbol TICK-NYSE is set to download 'Pending'.
2026-08-20 06:02:05.725 | NQU26_FUT_CME 15.00 Range #3 | Started historical data download for additional symbol TICK-NYSE. Download ID: 5
2026-08-20 06:02:05.985 | Chart #3 has tagged chart #6 for full recalculation. Chartbook: SierraEdge PRO NQ.Cht
2026-08-20 06:02:05.985 | NQU26_FUT_CME 15.00 Range #3 | Chart data loading complete.
2026-08-20 06:02:06.004 | GCM26_FUT_CME [CBV-D] Daily #5 | Chart data loading complete.
2026-08-20 06:02:06.021 | GCM26_FUT_CME [CBV-D] 30 Min #8 | Chart data loading complete.
2026-08-20 06:02:06.049 | GCZ26_FUT_CME [CBV-D] 30 Min #10 | Chart data loading complete.
2026-08-20 06:02:06.335 | NQU26_FUT_CME [CBV-D] Flex Renko 40-20-16 #8 | StartDateTimeForLoadingOrderFills: 2025-08-12 00:00:00
2026-08-20 06:02:06.336 | SC Data with Depth | Starting real-time market data updates for: UDVR-NQ. ID: 6 Service code: statscalc
2026-08-20 06:02:06.336 | SC Data with Depth | Requesting security definition data for: UDVR-NQ. ID: 6
2026-08-20 06:02:06.336 | Added historical Intraday data request for UDVR-NQ to the queue.
2026-08-20 06:02:06.336 | Intraday data recording state for symbol UDVR-NQ is set to download 'Pending'.
2026-08-20 06:02:06.336 | NQU26_FUT_CME [CBV-D] Flex Renko 40-20-16 #8 | Started historical data download for additional symbol UDVR-NQ. Download ID: 6
2026-08-20 06:02:06.347 | SC Data with Depth | Starting real-time market data updates for: ADR-NYSE. ID: 7 Service code: statscalc
2026-08-20 06:02:06.347 | SC Data with Depth | Requesting security definition data for: ADR-NYSE. ID: 7
2026-08-20 06:02:06.347 | Added historical Intraday data request for ADR-NYSE to the queue.
2026-08-20 06:02:06.347 | Intraday data recording state for symbol ADR-NYSE is set to download 'Pending'.
2026-08-20 06:02:06.347 | NQU26_FUT_CME [CBV-D] Flex Renko 40-20-16 #8 | Started historical data download for additional symbol ADR-NYSE. Download ID: 7
2026-08-20 06:02:06.347 | SC Data with Depth | Starting real-time market data updates for: UDVR-NYSE. ID: 8 Service code: statscalc
2026-08-20 06:02:06.347 | SC Data with Depth | Requesting security definition data for: UDVR-NYSE. ID: 8
2026-08-20 06:02:06.347 | Added historical Intraday data request for UDVR-NYSE to the queue.
2026-08-20 06:02:06.347 | Intraday data recording state for symbol UDVR-NYSE is set to download 'Pending'.
2026-08-20 06:02:06.347 | NQU26_FUT_CME [CBV-D] Flex Renko 40-20-16 #8 | Started historical data download for additional symbol UDVR-NYSE. Download ID: 8
2026-08-20 06:02:06.348 | SC Data with Depth | Starting real-time market data updates for: ADR-NASDAQ. ID: 9 Service code: statscalc
2026-08-20 06:02:06.348 | SC Data with Depth | Requesting security definition data for: ADR-NASDAQ. ID: 9
2026-08-20 06:02:06.348 | Added historical Intraday data request for ADR-NASDAQ to the queue.
2026-08-20 06:02:06.348 | Intraday data recording state for symbol ADR-NASDAQ is set to download 'Pending'.
2026-08-20 06:02:06.348 | NQU26_FUT_CME [CBV-D] Flex Renko 40-20-16 #8 | Started historical data download for additional symbol ADR-NASDAQ. Download ID: 9
2026-08-20 06:02:06.348 | SC Data with Depth | Starting real-time market data updates for: TICK-NASDAQ. ID: 10 Service code: statscalc
2026-08-20 06:02:06.348 | SC Data with Depth | Requesting security definition data for: TICK-NASDAQ. ID: 10
2026-08-20 06:02:06.348 | Added historical Intraday data request for TICK-NASDAQ to the queue.
2026-08-20 06:02:06.348 | Intraday data recording state for symbol TICK-NASDAQ is set to download 'Pending'.
2026-08-20 06:02:06.348 | NQU26_FUT_CME [CBV-D] Flex Renko 40-20-16 #8 | Started historical data download for additional symbol TICK-NASDAQ. Download ID: 10
2026-08-20 06:02:06.470 | NQU26_FUT_CME [CBV-D] Flex Renko 40-20-16 #8 | Chart data loading complete.
2026-08-20 06:02:06.501 | DTC Client socket (3) | Socket gracefully closed by remote side.
2026-08-20 06:02:06.507 | Loaded depth data records for GCZ26_FUT_CME 2026-08-14 from 2026-08-14 11:04:06.564000 to 2026-08-14 16:59:59.995000.
2026-08-20 06:02:06.512 | GCZ26_FUT_CME [CB-D] 30 Min #9 | Chart data loading complete.
2026-08-20 06:02:06.531 | GCM26_FUT_CME [CBV-D] 120 Min #7 | Chart data loading complete.
2026-08-20 06:02:06.534 | GCM26_FUT_CME [CBV-D] 5 Min #14 | Study: Google Sheets Importer | Making HTTP request.
2026-08-20 06:02:06.563 | GCM26_FUT_CME [CBV-D] 5 Min #14 | Chart data loading complete.
2026-08-20 06:02:06.607 | GCZ26_FUT_CME #13 | Chart data loading complete.
2026-08-20 06:02:06.611 | HTTPS connection ID:3 to downloads.rithmic.com:443 for request ID:3 (7) | Creating socket. Using TLS 1.2.
2026-08-20 06:02:06.611 | HTTPS connection ID:3 to downloads.rithmic.com:443 for request ID:3 (7) | New receive buffer size: 0
2026-08-20 06:02:06.611 | HTTPS connection ID:3 to downloads.rithmic.com:443 for request ID:3 (7) | Connecting to IP: 38.79.0.89.
2026-08-20 06:02:06.647 | GCM26_FUT_CME [CBV-D] #3 | Chart data loading complete.
2026-08-20 06:02:06.662 | GCM26_FUT_CME/MGCM26_FUT_CME [CBV-D] 30 Sec #6 | StartDateTimeForLoadingOrderFills: -00:05:00
2026-08-20 06:02:06.664 | GCM26_FUT_CME/MGCM26_FUT_CME [CBV-D] 30 Sec #6 | Chart data loading complete.
2026-08-20 06:02:06.694 | USDX [CBV-D] 3 Min #12 | Chart data loading complete.
2026-08-20 06:02:06.713 | GCM26_FUT_CME [CBV-D] 480 Min #6 | Chart data loading complete.
2026-08-20 06:02:06.724 | GCM26_FUT_CME [CBV-D] 60 Min #2 | Study: Google Sheets Importer | Making HTTP request.
2026-08-20 06:02:06.729 | GCM26_FUT_CME [CBV-D] 60 Min #2 | Chart data loading complete.
2026-08-20 06:02:06.748 | GCZ26_FUT_CME/MGCZ26_FUT_CME 0.8 Range #7 | StartDateTimeForLoadingOrderFills: -00:05:00
2026-08-20 06:02:06.787 | Loaded depth data records for GCZ26_FUT_CME 2026-08-16 from 2026-08-16 08:00:07.501000 to 2026-08-16 19:59:57.067000.
2026-08-20 06:02:06.909 | Loaded depth data records for NQU26_FUT_CME 2026-08-10 from 2026-08-09 20:00:00.003000 to 2026-08-10 19:59:59.969000.
2026-08-20 06:02:07.000 | GCZ26_FUT_CME/MGCZ26_FUT_CME 0.8 Range #7 | Chart data loading complete.
2026-08-20 06:02:07.116 | GCZ26_FUT_CME [CBV-D] Renko 22t #2 | Chart data loading complete.
2026-08-20 06:02:07.121 | GCM26_FUT_CME [CBV-D] 3.0 Range #5 | StartDateTimeForLoadingOrderFills: -00:05:00
2026-08-20 06:02:08.171 | GCM26_FUT_CME [CBV-D] 3.0 Range #5 | Chart data loading complete.
2026-08-20 06:02:08.389 | ESU26_FUT_CME [CBV-D] 30 Sec #4 | Chart data loading complete.
2026-08-20 06:02:08.517 | ESU26_FUT_CME 2.50 Range #9 | StartDateTimeForLoadingOrderFills: 2025-08-12 00:00:00
2026-08-20 06:02:08.711 | ESU26_FUT_CME 2.50 Range #9 | Chart data loading complete.
2026-08-20 06:02:08.733 | Delaying start of download for NVOL-NYSE.
2026-08-20 06:02:08.902 | Loaded depth data records for ESU26_FUT_CME 2026-08-17 from 2026-08-17 09:30:00.000000 to 2026-08-17 15:59:59.999000.
2026-08-20 06:02:09.522 | Loaded depth data records for GCM26_FUT_CME 2026-06-24 from 2026-06-24 08:20:00.001000 to 2026-06-24 16:00:00.967000.
2026-08-20 06:02:09.593 | Loaded depth data records for ESU26_FUT_CME 2026-08-18 from 2026-08-17 20:00:00.000000 to 2026-08-18 19:59:59.883000.
2026-08-20 06:02:09.659 | Chart #3 has tagged chart #6 for full recalculation. Chartbook: SierraEdge PRO NQ.Cht
2026-08-20 06:02:11.264 | SC Data with Depth | Network connection to server complete.
2026-08-20 06:02:11.264 | SC Data with Depth | Starting socket receive thread.
2026-08-20 06:02:11.264 | SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard
2026-08-20 06:02:11.266 | DTC Client socket (3) | Socket gracefully closed by remote side.
2026-08-20 06:02:11.288 | ESU26_FUT_CME 4.00 Range #3 | StartDateTimeForLoadingOrderFills: 2025-08-12 00:00:00
2026-08-20 06:02:11.355 | Chart #3 has tagged chart #4 for full recalculation. Chartbook: Sierra Edge ES execution.Cht
2026-08-20 06:02:11.397 | ESU26_FUT_CME 4.00 Range #3 | Chart data loading complete.
2026-08-20 06:02:11.419 | ESU26_FUT_CME 7.00 Range #7 | StartDateTimeForLoadingOrderFills: 2025-08-12 00:00:00
2026-08-20 06:02:11.487 | ESU26_FUT_CME 7.00 Range #7 | Chart data loading complete.
2026-08-20 06:02:11.625 | ESU26_FUT_CME/MESU26_FUT_CME [CBV-D] Flex Renko 6-4-1 #8 | StartDateTimeForLoadingOrderFills: 2025-08-12 00:00:00
2026-08-20 06:02:11.804 | ESU26_FUT_CME/MESU26_FUT_CME [CBV-D] Flex Renko 6-4-1 #8 | Chart data loading complete.
2026-08-20 06:02:11.885 | DTC Client socket (3) | Socket gracefully closed by remote side.
2026-08-20 06:02:11.888 | DTC Client socket (3) | CloseSocket call.
2026-08-20 06:02:11.888 | DTC Client socket (3) | Signaling for receive thread to end. Bytes in receive buffer: 0
2026-08-20 06:02:11.888 | DTC Client socket (3) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2026-08-20 06:02:11.888 | DTC Client socket (3) | Closed.
2026-08-20 06:02:12.058 | ESU26_FUT_CME [CBV-D] 3000 Volume #11 | Chart data loading complete.
2026-08-20 06:02:12.097 | ESU26_FUT_CME [CBV-D] 5 Min #5 | Study: Google Sheets Importer | Making HTTP request.
2026-08-20 06:02:12.220 | ESU26_FUT_CME [CBV-D] 5 Min #5 | Chart data loading complete.
2026-08-20 06:02:12.627 | ESU26_FUT_CME [CBV-D] 3000 Volume #1 | StartDateTimeForLoadingOrderFills: 2025-08-12 00:00:00
2026-08-20 06:02:12.889 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (4) | Socket gracefully closed by remote side.
2026-08-20 06:02:12.912 | ESU26_FUT_CME [CBV-D] 3000 Volume #1 | Chart data loading complete.
2026-08-20 06:02:12.919 | SC Data with Depth | Failed connections: 1
2026-08-20 06:02:12.919 | DTC Client socket (0) | CloseSocket call.
2026-08-20 06:02:12.920 | SC Data with Depth | Disconnected from the server.
2026-08-20 06:02:12.920 | SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds.
2026-08-20 06:02:12.964 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (4) | Socket gracefully closed by remote side.
2026-08-20 06:02:13.114 | HTTPS connection ID:3 to downloads.rithmic.com:443 for request ID:3 (7) | Socket gracefully closed by remote side. | Number times message added: 1
2026-08-20 06:02:13.267 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\RithmicConnections.json. Size: 115672
2026-08-20 06:02:13.269 | Rithmic Direct - DTC | Processed connection points. Count: 496
2026-08-20 06:02:13.271 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (4) | CloseSocket call.
2026-08-20 06:02:13.272 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2026-08-20 06:02:13.272 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (4) | Closed.
2026-08-20 06:02:13.274 | HTTPS connection ID:3 to downloads.rithmic.com:443 for request ID:3 (7) | CloseSocket call.
2026-08-20 06:02:13.275 | HTTPS connection ID:3 to downloads.rithmic.com:443 for request ID:3 (7) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2026-08-20 06:02:13.275 | HTTPS connection ID:3 to downloads.rithmic.com:443 for request ID:3 (7) | Closed.
2026-08-20 06:02:13.755 | Rithmic Direct - DTC | Starting real-time market data updates for: ESU26_FUT_CME. ID: 11
2026-08-20 06:02:13.755 | Rithmic Direct - DTC | Requesting security definition data for: ESU26_FUT_CME. ID: 11
2026-08-20 06:02:13.755 | Rithmic Direct - DTC | Using primary service for historical data for ESU26_FUT_CME
2026-08-20 06:02:13.755 | Starting DelayedDownloadMonitoringTimer
2026-08-20 06:02:13.755 | Starting HDTimeoutTimer
2026-08-20 06:02:13.755 | Historical data service client indicated that downloads are not enabled. Symbol: ESU26_FUT_CME. Data Type: Intraday data.
2026-08-20 06:02:13.755 | Historical data download ID 11 not found when removing ID from outstanding request set.
2026-08-20 06:02:13.755 | Real-time Intraday chart data file updates started for ESU26_FUT_CME
2026-08-20 06:02:13.756 | Intraday chart data file opened for ESU26_FUT_CME
2026-08-20 06:02:14.099 | Rithmic Direct - DTC | Starting real-time market data updates for: NQU26_FUT_CME. ID: 12
2026-08-20 06:02:14.099 | Rithmic Direct - DTC | Requesting security definition data for: NQU26_FUT_CME. ID: 12
2026-08-20 06:02:14.099 | Rithmic Direct - DTC | Using primary service for historical data for NQU26_FUT_CME
2026-08-20 06:02:14.099 | Historical data service client indicated that downloads are not enabled. Symbol: NQU26_FUT_CME. Data Type: Intraday data.
2026-08-20 06:02:14.099 | Historical data download ID 12 not found when removing ID from outstanding request set.
2026-08-20 06:02:14.099 | Real-time Intraday chart data file updates started for NQU26_FUT_CME
2026-08-20 06:02:14.099 | Intraday chart data file opened for NQU26_FUT_CME
2026-08-20 06:02:14.099 | Rithmic Direct - DTC | Starting real-time market data updates for: RTYU26_FUT_CME. ID: 13
2026-08-20 06:02:14.099 | Rithmic Direct - DTC | Requesting security definition data for: RTYU26_FUT_CME. ID: 13
2026-08-20 06:02:14.099 | Rithmic Direct - DTC | Using primary service for historical data for RTYU26_FUT_CME
2026-08-20 06:02:14.099 | Historical data service client indicated that downloads are not enabled. Symbol: RTYU26_FUT_CME. Data Type: Intraday data.
2026-08-20 06:02:14.099 | Historical data download ID 13 not found when removing ID from outstanding request set.
2026-08-20 06:02:14.099 | Real-time Intraday chart data file updates started for RTYU26_FUT_CME
2026-08-20 06:02:14.099 | Intraday chart data file opened for RTYU26_FUT_CME
2026-08-20 06:02:14.099 | SC Data with Depth | Starting real-time market data updates for: USDX. ID: 14 Service code: fxstatscalc
2026-08-20 06:02:14.099 | SC Data with Depth | Requesting security definition data for: USDX. ID: 14
2026-08-20 06:02:14.099 | Added historical Intraday data request for USDX to the queue.
2026-08-20 06:02:14.099 | Intraday data recording state for symbol USDX is set to download 'Pending'.
2026-08-20 06:02:14.099 | Triggering next historical data download in queue.
2026-08-20 06:02:14.234 | Requesting market depth updates for: NQU26_FUT_CME if supported. NumLevels=1400
2026-08-20 06:02:14.234 | Separate subscription for market depth updates not supported. NQU26_FUT_CME
2026-08-20 06:02:14.234 | Rithmic Direct - DTC | Starting real-time market data updates for: MNQU26_FUT_CME. ID: 15
2026-08-20 06:02:14.234 | Rithmic Direct - DTC | Requesting security definition data for: MNQU26_FUT_CME. ID: 15
2026-08-20 06:02:14.298 | NQU26_FUT_CME 15.00 Range #3 | Reloading chart.
2026-08-20 06:02:14.300 | Using Bid/Ask average for last trade price for VOLX
2026-08-20 06:02:14.301 | SC Data with Depth | Starting real-time market data updates for: VOLX. ID: 16 Service code: fxcm
2026-08-20 06:02:14.301 | SC Data with Depth | Requesting security definition data for: VOLX. ID: 16
2026-08-20 06:02:14.301 | Added historical Intraday data request for VOLX to the queue.
2026-08-20 06:02:14.301 | Intraday data recording state for symbol VOLX is set to download 'Pending'.
2026-08-20 06:02:14.301 | Triggering next historical data download in queue.
2026-08-20 06:02:14.302 | Rithmic Direct - DTC | Starting real-time market data updates for: GCM26_FUT_CME. ID: 17
2026-08-20 06:02:14.302 | Rithmic Direct - DTC | Requesting security definition data for: GCM26_FUT_CME. ID: 17
2026-08-20 06:02:14.302 | Rithmic Direct - DTC | Using primary service for historical data for GCM26_FUT_CME
2026-08-20 06:02:14.302 | Historical data service client indicated that downloads are not enabled. Symbol: GCM26_FUT_CME. Data Type: Intraday data.
2026-08-20 06:02:14.302 | Historical data download ID 16 not found when removing ID from outstanding request set.
2026-08-20 06:02:14.302 | Real-time Intraday chart data file updates started for GCM26_FUT_CME
2026-08-20 06:02:14.302 | Intraday chart data file opened for GCM26_FUT_CME
2026-08-20 06:02:14.312 | Rithmic Direct - DTC | Starting real-time market data updates for: GCZ26_FUT_CME. ID: 18
2026-08-20 06:02:14.312 | Rithmic Direct - DTC | Requesting security definition data for: GCZ26_FUT_CME. ID: 18
2026-08-20 06:02:14.312 | Rithmic Direct - DTC | Using primary service for historical data for GCZ26_FUT_CME
2026-08-20 06:02:14.312 | Historical data service client indicated that downloads are not enabled. Symbol: GCZ26_FUT_CME. Data Type: Intraday data.
2026-08-20 06:02:14.312 | Historical data download ID 17 not found when removing ID from outstanding request set.
2026-08-20 06:02:14.312 | Real-time Intraday chart data file updates started for GCZ26_FUT_CME
2026-08-20 06:02:14.312 | Intraday chart data file opened for GCZ26_FUT_CME
2026-08-20 06:02:14.355 | Rithmic Direct - DTC | Starting real-time market data updates for: MGCM26_FUT_CME. ID: 19
2026-08-20 06:02:14.355 | Rithmic Direct - DTC | Requesting security definition data for: MGCM26_FUT_CME. ID: 19
2026-08-20 06:02:14.363 | GCZ26_FUT_CME/MGCZ26_FUT_CME 0.8 Range #7 | Reloading chart.
2026-08-20 06:02:14.364 | Requesting market depth updates for: GCM26_FUT_CME if supported. NumLevels=1400
2026-08-20 06:02:14.364 | Separate subscription for market depth updates not supported. GCM26_FUT_CME
2026-08-20 06:02:14.404 | Requesting market depth updates for: GCZ26_FUT_CME if supported. NumLevels=1400
2026-08-20 06:02:14.404 | Separate subscription for market depth updates not supported. GCZ26_FUT_CME
2026-08-20 06:02:14.505 | + Loading additional symbol data.
2026-08-20 06:02:14.603 | Loaded depth data records for GCZ26_FUT_CME 2026-08-17 from 2026-08-16 20:00:00.000000 to 2026-08-17 19:59:59.208000.
2026-08-20 06:02:14.612 | Requesting market depth updates for: ESU26_FUT_CME if supported. NumLevels=1400
2026-08-20 06:02:14.612 | Separate subscription for market depth updates not supported. ESU26_FUT_CME
2026-08-20 06:02:14.612 | Rithmic Direct - DTC | Starting real-time market data updates for: MESU26_FUT_CME. ID: 20
2026-08-20 06:02:14.612 | Rithmic Direct - DTC | Requesting security definition data for: MESU26_FUT_CME. ID: 20
2026-08-20 06:02:14.834 | GCZ26_FUT_CME/MGCZ26_FUT_CME 0.8 Range #7 | StartDateTimeForLoadingOrderFills: -00:05:00
2026-08-20 06:02:15.067 | GCZ26_FUT_CME/MGCZ26_FUT_CME 0.8 Range #7 | Chart data loading complete.
2026-08-20 06:02:15.306 | SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 443
2026-08-20 06:02:15.315 | DTC Client socket (2) | Creating socket.
2026-08-20 06:02:15.315 | DTC Client socket (2) | New receive buffer size: 0
2026-08-20 06:02:15.315 | DTC Client socket (2) | Connecting to IP: 64.152.155.113.
2026-08-20 06:02:15.337 | ESU26_FUT_CME 2.50 Range #9 | Reloading chart.
2026-08-20 06:02:15.429 | Loaded depth data records for GCM26_FUT_CME 2026-06-25 from 2026-06-25 08:20:00.002000 to 2026-06-25 09:33:55.814000.
2026-08-20 06:02:15.613 | GCM26_FUT_CME/MGCM26_FUT_CME [CBV-D] 200 Trades #12 | StartDateTimeForLoadingOrderFills: -00:05:00
2026-08-20 06:02:15.616 | GCM26_FUT_CME/MGCM26_FUT_CME [CBV-D] 200 Trades #12 | Chart data loading complete.
2026-08-20 06:02:15.616 | SC Data with Depth | Network connection to server complete.
2026-08-20 06:02:15.616 | SC Data with Depth | Starting socket receive thread.
2026-08-20 06:02:15.616 | SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard
2026-08-20 06:02:15.636 | ESU26_FUT_CME 4.00 Range #3 | Reloading chart.
2026-08-20 06:02:15.652 | ESU26_FUT_CME 7.00 Range #7 | Reloading chart.
2026-08-20 06:02:15.856 | SC Data with Depth | Setting DTC encoding to Binary VLS
2026-08-20 06:02:15.856 | SC Data with Depth | Sending logon request message.
2026-08-20 06:02:16.058 | Rithmic Direct - DTC | Starting real-time market data updates for: MGCZ26_FUT_CME. ID: 21
2026-08-20 06:02:16.058 | Rithmic Direct - DTC | Requesting security definition data for: MGCZ26_FUT_CME. ID: 21
2026-08-20 06:02:16.192 | SC Data with Depth | Received logon response.
2026-08-20 06:02:16.192 | SC Data with Depth | Server Name: SC Realtime Server.
2026-08-20 06:02:16.192 | SC Data with Depth | Server protocol version: 8. Client protocol version: 8
2026-08-20 06:02:16.192 | SC Data with Depth | Successfully connected.
2026-08-20 06:02:16.192 | SC Data with Depth | Trading is not supported.
2026-08-20 06:02:16.192 | SC Data with Depth | MarketDepthIsSupported: 1
2026-08-20 06:02:16.203 | SC Data with Depth | Restarting real-time data updates for symbol: ADR-NASDAQ
2026-08-20 06:02:16.203 | SC Data with Depth | Restarting real-time data updates for symbol: ADR-NYSE
2026-08-20 06:02:16.203 | SC Data with Depth | Restarting real-time data updates for symbol: NISS-NASDAQ
2026-08-20 06:02:16.203 | SC Data with Depth | Restarting real-time data updates for symbol: NISS-NYSE
2026-08-20 06:02:16.203 | SC Data with Depth | Restarting real-time data updates for symbol: NVOL-NASDAQ
2026-08-20 06:02:16.203 | SC Data with Depth | Restarting real-time data updates for symbol: NVOL-NYSE
2026-08-20 06:02:16.203 | SC Data with Depth | Restarting real-time data updates for symbol: TICK-NASDAQ
2026-08-20 06:02:16.203 | SC Data with Depth | Restarting real-time data updates for symbol: TICK-NYSE
2026-08-20 06:02:16.203 | SC Data with Depth | Restarting real-time data updates for symbol: UDVR-NQ
2026-08-20 06:02:16.203 | SC Data with Depth | Restarting real-time data updates for symbol: UDVR-NYSE
2026-08-20 06:02:16.203 | SC Data with Depth | Restarting real-time data updates for symbol: USDX
2026-08-20 06:02:16.203 | SC Data with Depth | Restarting real-time data updates for symbol: VOLX
2026-08-20 06:02:16.577 | + Loading additional symbol data.
2026-08-20 06:02:16.587 | SC Data with Depth | Setting external service identifier for symbol ADR-NASDAQ to 111
2026-08-20 06:02:16.587 | SC Data with Depth | Received security definition for symbol ADR-NASDAQ
2026-08-20 06:02:16.587 | SC Data with Depth | Setting external service identifier for symbol ADR-NYSE to 107
2026-08-20 06:02:16.587 | SC Data with Depth | Received security definition for symbol ADR-NYSE
2026-08-20 06:02:16.587 | SC Data with Depth | Setting external service identifier for symbol NISS-NASDAQ to 43
2026-08-20 06:02:16.587 | SC Data with Depth | Received security definition for symbol NISS-NASDAQ
2026-08-20 06:02:16.587 | SC Data with Depth | Setting external service identifier for symbol NISS-NYSE to 9
2026-08-20 06:02:16.587 | SC Data with Depth | Received security definition for symbol NISS-NYSE
2026-08-20 06:02:16.587 | SC Data with Depth | Setting external service identifier for symbol NVOL-NASDAQ to 51
2026-08-20 06:02:16.587 | SC Data with Depth | Received security definition for symbol NVOL-NASDAQ
2026-08-20 06:02:16.587 | SC Data with Depth | Setting external service identifier for symbol NVOL-NYSE to 17
2026-08-20 06:02:16.587 | SC Data with Depth | Received security definition for symbol NVOL-NYSE
2026-08-20 06:02:16.587 | SC Data with Depth | Setting external service identifier for symbol TICK-NASDAQ to 37
2026-08-20 06:02:16.587 | SC Data with Depth | Received security definition for symbol TICK-NASDAQ
2026-08-20 06:02:16.587 | SC Data with Depth | Setting external service identifier for symbol TICK-NYSE to 1
2026-08-20 06:02:16.587 | SC Data with Depth | Received security definition for symbol TICK-NYSE
2026-08-20 06:02:16.587 | SC Data with Depth | Setting external service identifier for symbol UDVR-NQ to 114
2026-08-20 06:02:16.587 | SC Data with Depth | Received security definition for symbol UDVR-NQ
2026-08-20 06:02:16.587 | SC Data with Depth | Setting external service identifier for symbol UDVR-NYSE to 108
2026-08-20 06:02:16.587 | SC Data with Depth | Received security definition for symbol UDVR-NYSE
2026-08-20 06:02:16.587 | SC Data with Depth | Setting external service identifier for symbol USDX to 1
2026-08-20 06:02:16.587 | SC Data with Depth | Received security definition for symbol USDX
2026-08-20 06:02:16.587 | SC Data with Depth | Setting external service identifier for symbol VOLX to 67
2026-08-20 06:02:16.587 | SC Data with Depth | Received security definition for symbol VOLX
2026-08-20 06:02:16.890 | + Loading additional symbol data. | Number times message added: 1
2026-08-20 06:02:17.057 | ESU26_FUT_CME 2.50 Range #9 | StartDateTimeForLoadingOrderFills: 2025-08-12 00:00:00
2026-08-20 06:02:17.208 | Chart #9 has tagged chart #1 for full recalculation. Chartbook: Sierra Edge ES execution.Cht
2026-08-20 06:02:17.252 | ESU26_FUT_CME 2.50 Range #9 | Chart data loading complete.
2026-08-20 06:02:17.447 | ESU26_FUT_CME 4.00 Range #3 | StartDateTimeForLoadingOrderFills: 2025-08-12 00:00:00
2026-08-20 06:02:17.535 | ESU26_FUT_CME 4.00 Range #3 | Chart data loading complete.
2026-08-20 06:02:17.538 | ESU26_FUT_CME 7.00 Range #7 | StartDateTimeForLoadingOrderFills: 2025-08-12 00:00:00
2026-08-20 06:02:17.598 | ESU26_FUT_CME 7.00 Range #7 | Chart data loading complete.
2026-08-20 06:02:18.725 | + Loading additional symbol data.
2026-08-20 06:02:19.208 | NQU26_FUT_CME 15.00 Range #3 | StartDateTimeForLoadingOrderFills: 2025-08-12 00:00:00
2026-08-20 06:02:19.441 | NQU26_FUT_CME 15.00 Range #3 | Chart data loading complete.
2026-08-20 06:02:21.234 | HD Request # 1 | Downloading Intraday chart data for NVOL-NYSE to the file NVOL-NYSE.scid. Service: statscalc
2026-08-20 06:02:21.235 | HD Request # 1 | Download start date-time: 2026-08-19 16:30:00.000000. File last date-time: 2026-08-19 16:30:00.963001
2026-08-20 06:02:21.235 | HD Request # 1 | Using server: ds12.sierracharts.com port 10149
2026-08-20 06:02:21.236 | Socket (3) | Creating socket.
2026-08-20 06:02:21.236 | Socket (3) | New receive buffer size: 0
2026-08-20 06:02:21.236 | Socket (3) | Connecting to IP: 69.39.70.241.
2026-08-20 06:02:21.495 | HD Request # 1 | Setting DTC encoding to Binary VLS
2026-08-20 06:02:21.495 | HD Request # 1 | Sending historical data logon request message.
2026-08-20 06:02:21.542 | Loaded depth data records for ESU26_FUT_CME 2026-08-19 from 2026-08-18 20:00:00.000000 to 2026-08-19 16:45:16.913000.
2026-08-20 06:02:21.636 | ESU26_FUT_CME [CBV-D] 40 Trades #12 | Chart data loading complete.
2026-08-20 06:02:21.642 | HD Request # 1 | Requesting Intraday data. Start date-time: 2026-08-19 16:30:00. Record interval: 0. Symbol: NVOL-NYSE
2026-08-20 06:02:21.770 | HD Request # 1 | Decompressing data.
2026-08-20 06:02:21.890 | Loaded depth data records for GCZ26_FUT_CME 2026-08-18 from 2026-08-17 20:00:00.000000 to 2026-08-18 19:59:59.750000.
2026-08-20 06:02:21.898 | HD Request # 1 | Receiving Intraday data for NVOL-NYSE starting at 2026-08-19 16:30:00.000000
2026-08-20 06:02:21.898 | Socket (3) | CloseSocket call.
2026-08-20 06:02:21.898 | Socket (3) | Shutdown started. Waiting for graceful close.
2026-08-20 06:02:21.899 | Historical data download thread signaled to stop.
2026-08-20 06:02:21.899 | HD Request # 1 | Received 1 Intraday data record from 2026-08-19 16:30:00.000000 to 2026-08-19 16:30:00.000000 (0.0 seconds. Delay: 13.5 hours) and wrote 0 records for NVOL-NYSE
2026-08-20 06:02:21.899 | HD Request # 1 | Add time&sales data | Remembered last file record date-time: 2026-08-19 20:30:00.963001
2026-08-20 06:02:21.899 | HD Request # 1 | Completion time: 0s.
2026-08-20 06:02:21.899 | HD Request # 1 | Intraday data download complete for NVOL-NYSE. Unique request ID: 1
2026-08-20 06:02:21.899 | Removing historical data download ID 1.
2026-08-20 06:02:21.899 | Real-time Intraday chart data file updates started for NVOL-NYSE
2026-08-20 06:02:21.899 | Intraday chart data file opened for NVOL-NYSE
2026-08-20 06:02:21.899 | HD Request # 1 | Enabling Intraday chart updating for symbol.
2026-08-20 06:02:21.899 | TICK-NYSE[M] 1 Min #2 | Historical data download for additional symbol NVOL-NYSE with ID 1 has completed.
2026-08-20 06:02:21.899 | Triggering next historical data download in queue.
2026-08-20 06:02:21.900 | HD Request # 2 | Downloading Intraday chart data for NISS-NYSE to the file NISS-NYSE.scid. Service: statscalc
2026-08-20 06:02:21.900 | HD Request # 2 | Download start date-time: 2026-08-20 06:00:57.000000. File last date-time: 2026-08-20 06:00:57.212000
2026-08-20 06:02:21.900 | HD Request # 2 | Using server: ds4.sierracharts.com port 10150
2026-08-20 06:02:21.900 | Socket (4) | Creating socket.
2026-08-20 06:02:21.900 | Socket (4) | New receive buffer size: 0
2026-08-20 06:02:21.900 | Socket (4) | Connecting to IP: 64.152.155.113.
2026-08-20 06:02:22.026 | Socket (3) | Socket gracefully closed by remote side.
2026-08-20 06:02:22.026 | Socket (3) | Closed.
2026-08-20 06:02:22.158 | HD Request # 2 | Setting DTC encoding to Binary VLS
2026-08-20 06:02:22.158 | HD Request # 2 | Sending historical data logon request message.
2026-08-20 06:02:22.183 | Loaded depth data records for ESU26_FUT_CME 2026-08-18 from 2026-08-18 09:30:00.000000 to 2026-08-18 15:59:59.999000.
2026-08-20 06:02:22.304 | HD Request # 2 | Requesting Intraday data. Start date-time: 2026-08-20 06:00:57. Record interval: 0. Symbol: NISS-NYSE
2026-08-20 06:02:22.432 | HD Request # 2 | Decompressing data.
2026-08-20 06:02:22.559 | HD Request # 2 | Receiving Intraday data for NISS-NYSE starting at 2026-08-20 06:00:57.000000
2026-08-20 06:02:22.560 | Socket (4) | CloseSocket call.
2026-08-20 06:02:22.560 | Socket (4) | Shutdown started. Waiting for graceful close.
2026-08-20 06:02:22.560 | Historical data download thread signaled to stop.
2026-08-20 06:02:22.560 | HD Request # 2 | Timestamp of first Intraday data file record written: 2026-08-20 06:00:58.000000.
2026-08-20 06:02:22.560 | HD Request # 2 | Received 85 Intraday data records from 2026-08-20 06:00:57.000000 to 2026-08-20 06:02:21.000000 (84.0 seconds. Delay: 1.6 seconds) and wrote 84 records for NISS-NYSE
2026-08-20 06:02:22.561 | HD Request # 2 | Add time&sales data | Remembered last file record date-time: 2026-08-20 10:02:21.000000
2026-08-20 06:02:22.561 | Added 5 Time and Sales records to Intraday data file for NISS-NYSE after download.
2026-08-20 06:02:22.561 | HD Request # 2 | Completion time: 1s.
2026-08-20 06:02:22.561 | HD Request # 2 | Intraday data download complete for NISS-NYSE. Unique request ID: 2
2026-08-20 06:02:22.561 | Removing historical data download ID 2.
2026-08-20 06:02:22.561 | Real-time Intraday chart data file updates started for NISS-NYSE
2026-08-20 06:02:22.561 | Intraday chart data file opened for NISS-NYSE
2026-08-20 06:02:22.561 | HD Request # 2 | Enabling Intraday chart updating for symbol.
2026-08-20 06:02:22.561 | TICK-NYSE[M] 1 Min #2 | Historical data download for additional symbol NISS-NYSE with ID 2 has completed.
2026-08-20 06:02:22.561 | Triggering next historical data download in queue.
2026-08-20 06:02:22.561 | HD Request # 3 | Downloading Intraday chart data for NISS-NASDAQ to the file NISS-NASDAQ.scid. Service: statscalc
2026-08-20 06:02:22.562 | HD Request # 3 | Download start date-time: 2026-08-20 06:00:57.000000. File last date-time: 2026-08-20 06:00:57.212000
2026-08-20 06:02:22.562 | HD Request # 3 | Using server: ds12.sierracharts.com port 10149
2026-08-20 06:02:22.562 | Socket (3) | Creating socket.
2026-08-20 06:02:22.562 | Socket (3) | New receive buffer size: 0
2026-08-20 06:02:22.562 | Socket (3) | Connecting to IP: 69.39.70.241.
2026-08-20 06:02:22.687 | Socket (4) | Socket gracefully closed by remote side.
2026-08-20 06:02:22.687 | Socket (4) | Closed.
2026-08-20 06:02:22.831 | HD Request # 3 | Setting DTC encoding to Binary VLS
2026-08-20 06:02:22.831 | HD Request # 3 | Sending historical data logon request message.
2026-08-20 06:02:22.965 | HD Request # 3 | Requesting Intraday data. Start date-time: 2026-08-20 06:00:57. Record interval: 0. Symbol: NISS-NASDAQ
2026-08-20 06:02:23.098 | HD Request # 3 | Decompressing data.
2026-08-20 06:02:23.231 | HD Request # 3 | Receiving Intraday data for NISS-NASDAQ starting at 2026-08-20 06:00:57.000000
2026-08-20 06:02:23.231 | Socket (3) | CloseSocket call.
2026-08-20 06:02:23.231 | Socket (3) | Shutdown started. Waiting for graceful close.
2026-08-20 06:02:23.231 | Historical data download thread signaled to stop.
2026-08-20 06:02:23.231 | HD Request # 3 | Timestamp of first Intraday data file record written: 2026-08-20 06:00:58.000000.
2026-08-20 06:02:23.231 | HD Request # 3 | Received 84 Intraday data records from 2026-08-20 06:00:57.000000 to 2026-08-20 06:02:20.000000 (83.0 seconds. Delay: 3.2 seconds) and wrote 83 records for NISS-NASDAQ
2026-08-20 06:02:23.232 | HD Request # 3 | Add time&sales data | Remembered last file record date-time: 2026-08-20 10:02:20.000000
2026-08-20 06:02:23.232 | Added 12 Time and Sales records to Intraday data file for NISS-NASDAQ after download.
2026-08-20 06:02:23.232 | HD Request # 3 | Completion time: 1s.
2026-08-20 06:02:23.232 | HD Request # 3 | Intraday data download complete for NISS-NASDAQ. Unique request ID: 3
2026-08-20 06:02:23.232 | Removing historical data download ID 3.
2026-08-20 06:02:23.232 | Real-time Intraday chart data file updates started for NISS-NASDAQ
2026-08-20 06:02:23.232 | Intraday chart data file opened for NISS-NASDAQ
2026-08-20 06:02:23.232 | HD Request # 3 | Enabling Intraday chart updating for symbol.
2026-08-20 06:02:23.232 | TICK-NASDAQ[M] 1 Min #3 | Historical data download for additional symbol NISS-NASDAQ with ID 3 has completed.
2026-08-20 06:02:23.233 | Triggering next historical data download in queue.
2026-08-20 06:02:23.233 | HD Request # 4 | Downloading Intraday chart data for NVOL-NASDAQ to the file NVOL-NASDAQ.scid. Service: statscalc
2026-08-20 06:02:23.233 | HD Request # 4 | Download start date-time: 2026-08-19 16:30:00.000000. File last date-time: 2026-08-19 16:30:00.963001
2026-08-20 06:02:23.234 | HD Request # 4 | Using server: ds4.sierracharts.com port 10150
2026-08-20 06:02:23.234 | Socket (4) | Creating socket.
2026-08-20 06:02:23.234 | Socket (4) | New receive buffer size: 0
2026-08-20 06:02:23.234 | Socket (4) | Connecting to IP: 64.152.155.113.
2026-08-20 06:02:23.364 | Socket (3) | Socket gracefully closed by remote side.
2026-08-20 06:02:23.364 | Socket (3) | Closed.
2026-08-20 06:02:23.487 | HD Request # 4 | Setting DTC encoding to Binary VLS
2026-08-20 06:02:23.487 | HD Request # 4 | Sending historical data logon request message.
2026-08-20 06:02:23.612 | HD Request # 4 | Requesting Intraday data. Start date-time: 2026-08-19 16:30:00. Record interval: 0. Symbol: NVOL-NASDAQ
2026-08-20 06:02:23.737 | HD Request # 4 | Decompressing data.
2026-08-20 06:02:23.861 | HD Request # 4 | Receiving Intraday data for NVOL-NASDAQ starting at 2026-08-19 16:30:00.000000
2026-08-20 06:02:23.861 | Socket (4) | CloseSocket call.
2026-08-20 06:02:23.861 | Socket (4) | Shutdown started. Waiting for graceful close.
2026-08-20 06:02:23.862 | Historical data download thread signaled to stop.
2026-08-20 06:02:23.862 | HD Request # 4 | Received 1 Intraday data record from 2026-08-19 16:30:00.000000 to 2026-08-19 16:30:00.000000 (0.0 seconds. Delay: 13.5 hours) and wrote 0 records for NVOL-NASDAQ
2026-08-20 06:02:23.862 | HD Request # 4 | Add time&sales data | Remembered last file record date-time: 2026-08-19 20:30:00.963001
2026-08-20 06:02:23.862 | HD Request # 4 | Completion time: 0s.
2026-08-20 06:02:23.862 | HD Request # 4 | Intraday data download complete for NVOL-NASDAQ. Unique request ID: 4
2026-08-20 06:02:23.862 | Removing historical data download ID 4.
2026-08-20 06:02:23.862 | Real-time Intraday chart data file updates started for NVOL-NASDAQ
2026-08-20 06:02:23.862 | Intraday chart data file opened for NVOL-NASDAQ
2026-08-20 06:02:23.862 | HD Request # 4 | Enabling Intraday chart updating for symbol.
2026-08-20 06:02:23.862 | TICK-NASDAQ[M] 1 Min #3 | Historical data download for additional symbol NVOL-NASDAQ with ID 4 has completed.
2026-08-20 06:02:23.862 | Triggering next historical data download in queue.
2026-08-20 06:02:23.862 | HD Request # 5 | Downloading Intraday chart data for TICK-NYSE to the file TICK-NYSE.scid. Service: statscalc
2026-08-20 06:02:23.862 | HD Request # 5 | Download start date-time: 2026-08-20 06:00:57.000000. File last date-time: 2026-08-20 06:00:57.212000
2026-08-20 06:02:23.862 | HD Request # 5 | Using server: ds12.sierracharts.com port 10149
2026-08-20 06:02:23.862 | Socket (3) | Creating socket.
2026-08-20 06:02:23.862 | Socket (3) | New receive buffer size: 0
2026-08-20 06:02:23.862 | Socket (3) | Connecting to IP: 69.39.70.241.
2026-08-20 06:02:23.981 | Loaded depth data records for NQU26_FUT_CME 2026-08-11 from 2026-08-10 20:00:00.002000 to 2026-08-11 12:10:16.913000.
2026-08-20 06:02:23.985 | Socket (4) | Socket gracefully closed by remote side.
2026-08-20 06:02:23.985 | Socket (4) | Closed.
2026-08-20 06:02:24.121 | HD Request # 5 | Setting DTC encoding to Binary VLS
2026-08-20 06:02:24.121 | HD Request # 5 | Sending historical data logon request message.
2026-08-20 06:02:24.249 | HD Request # 5 | Requesting Intraday data. Start date-time: 2026-08-20 06:00:57. Record interval: 0. Symbol: TICK-NYSE
2026-08-20 06:02:24.377 | HD Request # 5 | Decompressing data.
2026-08-20 06:02:24.505 | HD Request # 5 | Receiving Intraday data for TICK-NYSE starting at 2026-08-20 06:00:57.000000
2026-08-20 06:02:24.505 | Socket (3) | CloseSocket call.
2026-08-20 06:02:24.505 | Socket (3) | Shutdown started. Waiting for graceful close.
2026-08-20 06:02:24.506 | Historical data download thread signaled to stop.
2026-08-20 06:02:24.506 | HD Request # 5 | Timestamp of first Intraday data file record written: 2026-08-20 06:00:58.000000.
2026-08-20 06:02:24.506 | HD Request # 5 | Received 84 Intraday data records from 2026-08-20 06:00:57.000000 to 2026-08-20 06:02:20.000000 (83.0 seconds. Delay: 4.5 seconds) and wrote 83 records for TICK-NYSE
2026-08-20 06:02:24.506 | HD Request # 5 | Add time&sales data | Remembered last file record date-time: 2026-08-20 10:02:20.000000
2026-08-20 06:02:24.506 | Added 17 Time and Sales records to Intraday data file for TICK-NYSE after download.
2026-08-20 06:02:24.506 | HD Request # 5 | Completion time: 1s.
2026-08-20 06:02:24.506 | HD Request # 5 | Intraday data download complete for TICK-NYSE. Unique request ID: 5
2026-08-20 06:02:24.506 | Removing historical data download ID 5.
2026-08-20 06:02:24.506 | Real-time Intraday chart data file updates started for TICK-NYSE
2026-08-20 06:02:24.506 | Intraday chart data file opened for TICK-NYSE
2026-08-20 06:02:24.506 | HD Request # 5 | Enabling Intraday chart updating for symbol.
2026-08-20 06:02:24.506 | NQU26_FUT_CME 15.00 Range #3 | Historical data download for additional symbol TICK-NYSE with ID 5 has completed.
2026-08-20 06:02:24.506 | Triggering next historical data download in queue.
2026-08-20 06:02:24.507 | HD Request # 6 | Downloading Intraday chart data for UDVR-NQ to the file UDVR-NQ.scid. Service: statscalc
2026-08-20 06:02:24.507 | HD Request # 6 | Download start date-time: 2026-08-20 06:00:57.000000. File last date-time: 2026-08-20 06:00:57.212000
2026-08-20 06:02:24.507 | HD Request # 6 | Using server: ds4.sierracharts.com port 10150
2026-08-20 06:02:24.507 | Socket (4) | Creating socket.
2026-08-20 06:02:24.507 | Socket (4) | New receive buffer size: 0
2026-08-20 06:02:24.507 | Socket (4) | Connecting to IP: 64.152.155.113.
2026-08-20 06:02:24.634 | Socket (3) | Socket gracefully closed by remote side.
2026-08-20 06:02:24.634 | Socket (3) | Closed.
2026-08-20 06:02:24.763 | HD Request # 6 | Setting DTC encoding to Binary VLS
2026-08-20 06:02:24.763 | HD Request # 6 | Sending historical data logon request message.
2026-08-20 06:02:24.888 | HD Request # 6 | Requesting Intraday data. Start date-time: 2026-08-20 06:00:57. Record interval: 0. Symbol: UDVR-NQ
2026-08-20 06:02:25.014 | HD Request # 6 | Decompressing data.
2026-08-20 06:02:25.139 | HD Request # 6 | Receiving Intraday data for UDVR-NQ starting at 2026-08-20 06:00:57.000000
2026-08-20 06:02:25.139 | Socket (4) | CloseSocket call.
2026-08-20 06:02:25.139 | Socket (4) | Shutdown started. Waiting for graceful close.
2026-08-20 06:02:25.166 | Historical data download thread signaled to stop.
2026-08-20 06:02:25.166 | HD Request # 6 | Timestamp of first Intraday data file record written: 2026-08-20 06:00:58.000000.
2026-08-20 06:02:25.167 | HD Request # 6 | Received 87 Intraday data records from 2026-08-20 06:00:57.000000 to 2026-08-20 06:02:23.000000 (86.0 seconds. Delay: 2.2 seconds) and wrote 86 records for UDVR-NQ
2026-08-20 06:02:25.167 | HD Request # 6 | Add time&sales data | Remembered last file record date-time: 2026-08-20 10:02:23.000000
2026-08-20 06:02:25.167 | Added 7 Time and Sales records to Intraday data file for UDVR-NQ after download.
2026-08-20 06:02:25.167 | HD Request # 6 | Completion time: 1s.
2026-08-20 06:02:25.167 | HD Request # 6 | Intraday data download complete for UDVR-NQ. Unique request ID: 6
2026-08-20 06:02:25.167 | Removing historical data download ID 6.
2026-08-20 06:02:25.167 | Real-time Intraday chart data file updates started for UDVR-NQ
2026-08-20 06:02:25.167 | Intraday chart data file opened for UDVR-NQ
2026-08-20 06:02:25.167 | HD Request # 6 | Enabling Intraday chart updating for symbol.
2026-08-20 06:02:25.167 | NQU26_FUT_CME [CBV-D] Flex Renko 40-20-16 #8 | Historical data download for additional symbol UDVR-NQ with ID 6 has completed.
2026-08-20 06:02:25.167 | Triggering next historical data download in queue.
2026-08-20 06:02:25.167 | HD Request # 7 | Downloading Intraday chart data for ADR-NYSE to the file ADR-NYSE.scid. Service: statscalc
2026-08-20 06:02:25.167 | HD Request # 7 | Download start date-time: 2026-08-20 06:00:57.000000. File last date-time: 2026-08-20 06:00:57.212000
2026-08-20 06:02:25.168 | HD Request # 7 | Using server: ds12.sierracharts.com port 10149
2026-08-20 06:02:25.168 | Socket (3) | Creating socket.
2026-08-20 06:02:25.168 | Socket (3) | New receive buffer size: 0
2026-08-20 06:02:25.168 | Socket (3) | Connecting to IP: 69.39.70.241.
2026-08-20 06:02:25.265 | Socket (4) | Socket gracefully closed by remote side.
2026-08-20 06:02:25.265 | Socket (4) | Closed.
2026-08-20 06:02:25.423 | HD Request # 7 | Setting DTC encoding to Binary VLS
2026-08-20 06:02:25.423 | HD Request # 7 | Sending historical data logon request message.
2026-08-20 06:02:25.549 | HD Request # 7 | Requesting Intraday data. Start date-time: 2026-08-20 06:00:57. Record interval: 0. Symbol: ADR-NYSE
2026-08-20 06:02:25.676 | HD Request # 7 | Decompressing data.
2026-08-20 06:02:25.802 | HD Request # 7 | Receiving Intraday data for ADR-NYSE starting at 2026-08-20 06:00:57.000000
2026-08-20 06:02:25.802 | Socket (3) | CloseSocket call.
2026-08-20 06:02:25.803 | Socket (3) | Shutdown started. Waiting for graceful close.
2026-08-20 06:02:25.869 | Historical data download thread signaled to stop.
2026-08-20 06:02:25.869 | HD Request # 7 | Timestamp of first Intraday data file record written: 2026-08-20 06:00:58.000000.
2026-08-20 06:02:25.870 | HD Request # 7 | Received 88 Intraday data records from 2026-08-20 06:00:57.000000 to 2026-08-20 06:02:24.000000 (87.0 seconds. Delay: 1.9 seconds) and wrote 87 records for ADR-NYSE
2026-08-20 06:02:25.870 | HD Request # 7 | Add time&sales data | Remembered last file record date-time: 2026-08-20 10:02:24.000000
2026-08-20 06:02:25.870 | Added 6 Time and Sales records to Intraday data file for ADR-NYSE after download.
2026-08-20 06:02:25.870 | HD Request # 7 | Completion time: 0s.
2026-08-20 06:02:25.870 | HD Request # 7 | Intraday data download complete for ADR-NYSE. Unique request ID: 7
2026-08-20 06:02:25.870 | Removing historical data download ID 7.
2026-08-20 06:02:25.870 | Real-time Intraday chart data file updates started for ADR-NYSE
2026-08-20 06:02:25.870 | Intraday chart data file opened for ADR-NYSE
2026-08-20 06:02:25.870 | HD Request # 7 | Enabling Intraday chart updating for symbol.
2026-08-20 06:02:25.870 | NQU26_FUT_CME [CBV-D] Flex Renko 40-20-16 #8 | Historical data download for additional symbol ADR-NYSE with ID 7 has completed.
2026-08-20 06:02:25.870 | Triggering next historical data download in queue.
2026-08-20 06:02:25.871 | HD Request # 8 | Downloading Intraday chart data for UDVR-NYSE to the file UDVR-NYSE.scid. Service: statscalc
2026-08-20 06:02:25.872 | HD Request # 8 | Download start date-time: 2026-08-20 06:00:57.000000. File last date-time: 2026-08-20 06:00:57.212001
2026-08-20 06:02:25.872 | HD Request # 8 | Using server: ds4.sierracharts.com port 10150
2026-08-20 06:02:25.872 | Socket (4) | Creating socket.
2026-08-20 06:02:25.872 | Socket (4) | New receive buffer size: 0
2026-08-20 06:02:25.872 | Socket (4) | Connecting to IP: 64.152.155.113.
2026-08-20 06:02:25.899 | Opened cached Intraday file: C:\SierraChart\Data\NISS-NYSE.scid. Thread ID: 35040
2026-08-20 06:02:25.899 | Opened cached Intraday file: C:\SierraChart\Data\NISS-NASDAQ.scid. Thread ID: 35040
2026-08-20 06:02:25.900 | Opened cached Intraday file: C:\SierraChart\Data\TICK-NYSE.scid. Thread ID: 35040
2026-08-20 06:02:25.901 | Opened cached Intraday file: C:\SierraChart\Data\UDVR-NQ.scid. Thread ID: 35040
2026-08-20 06:02:25.928 | Socket (3) | Socket gracefully closed by remote side.
2026-08-20 06:02:25.928 | Socket (3) | Closed.
2026-08-20 06:02:26.129 | HD Request # 8 | Setting DTC encoding to Binary VLS
2026-08-20 06:02:26.129 | HD Request # 8 | Sending historical data logon request message.
2026-08-20 06:02:26.196 | Loaded depth data records for NQU26_FUT_CME 2026-08-18 from 2026-08-18 09:30:00.000000 to 2026-08-18 15:59:59.999000.
2026-08-20 06:02:26.256 | HD Request # 8 | Requesting Intraday data. Start date-time: 2026-08-20 06:00:57. Record interval: 0. Symbol: UDVR-NYSE
2026-08-20 06:02:26.384 | HD Request # 8 | Decompressing data.
2026-08-20 06:02:26.511 | HD Request # 8 | Receiving Intraday data for UDVR-NYSE starting at 2026-08-20 06:00:57.000000
2026-08-20 06:02:26.511 | Socket (4) | CloseSocket call.
2026-08-20 06:02:26.511 | Socket (4) | Shutdown started. Waiting for graceful close.
2026-08-20 06:02:26.580 | Historical data download thread signaled to stop.
2026-08-20 06:02:26.580 | HD Request # 8 | Timestamp of first Intraday data file record written: 2026-08-20 06:00:58.000000.
2026-08-20 06:02:26.580 | HD Request # 8 | Received 89 Intraday data records from 2026-08-20 06:00:57.000000 to 2026-08-20 06:02:25.000000 (88.0 seconds. Delay: 1.6 seconds) and wrote 88 records for UDVR-NYSE
2026-08-20 06:02:26.581 | HD Request # 8 | Add time&sales data | Remembered last file record date-time: 2026-08-20 10:02:25.000000
2026-08-20 06:02:26.581 | Added 6 Time and Sales records to Intraday data file for UDVR-NYSE after download.
2026-08-20 06:02:26.581 | HD Request # 8 | Completion time: 1s.
2026-08-20 06:02:26.581 | HD Request # 8 | Intraday data download complete for UDVR-NYSE. Unique request ID: 8
2026-08-20 06:02:26.581 | Removing historical data download ID 8.
2026-08-20 06:02:26.581 | Real-time Intraday chart data file updates started for UDVR-NYSE
2026-08-20 06:02:26.581 | Intraday chart data file opened for UDVR-NYSE
2026-08-20 06:02:26.581 | HD Request # 8 | Enabling Intraday chart updating for symbol.
2026-08-20 06:02:26.581 | NQU26_FUT_CME [CBV-D] Flex Renko 40-20-16 #8 | Historical data download for additional symbol UDVR-NYSE with ID 8 has completed.
2026-08-20 06:02:26.581 | Triggering next historical data download in queue.
2026-08-20 06:02:26.581 | HD Request # 9 | Downloading Intraday chart data for ADR-NASDAQ to the file ADR-NASDAQ.scid. Service: statscalc
2026-08-20 06:02:26.582 | HD Request # 9 | Download start date-time: 2026-08-20 06:00:57.000000. File last date-time: 2026-08-20 06:00:57.212000
2026-08-20 06:02:26.582 | HD Request # 9 | Using server: ds12.sierracharts.com port 10149
2026-08-20 06:02:26.582 | Socket (3) | Creating socket.
2026-08-20 06:02:26.582 | Socket (3) | New receive buffer size: 0
2026-08-20 06:02:26.582 | Socket (3) | Connecting to IP: 69.39.70.241.
2026-08-20 06:02:26.639 | Socket (4) | Socket gracefully closed by remote side.
2026-08-20 06:02:26.639 | Socket (4) | Closed.
2026-08-20 06:02:26.852 | HD Request # 9 | Setting DTC encoding to Binary VLS
2026-08-20 06:02:26.852 | HD Request # 9 | Sending historical data logon request message.
2026-08-20 06:02:26.985 | HD Request # 9 | Requesting Intraday data. Start date-time: 2026-08-20 06:00:57. Record interval: 0. Symbol: ADR-NASDAQ
2026-08-20 06:02:27.117 | HD Request # 9 | Decompressing data.
2026-08-20 06:02:27.250 | HD Request # 9 | Receiving Intraday data for ADR-NASDAQ starting at 2026-08-20 06:00:57.000000
2026-08-20 06:02:27.250 | Socket (3) | CloseSocket call.
2026-08-20 06:02:27.250 | Socket (3) | Shutdown started. Waiting for graceful close.
2026-08-20 06:02:27.250 | Historical data download thread signaled to stop.
2026-08-20 06:02:27.250 | HD Request # 9 | Timestamp of first Intraday data file record written: 2026-08-20 06:00:58.000000.
2026-08-20 06:02:27.250 | HD Request # 9 | Received 88 Intraday data records from 2026-08-20 06:00:57.000000 to 2026-08-20 06:02:24.000000 (87.0 seconds. Delay: 3.3 seconds) and wrote 87 records for ADR-NASDAQ
2026-08-20 06:02:27.251 | HD Request # 9 | Add time&sales data | Remembered last file record date-time: 2026-08-20 10:02:24.000000
2026-08-20 06:02:27.251 | Added 11 Time and Sales records to Intraday data file for ADR-NASDAQ after download.
2026-08-20 06:02:27.251 | HD Request # 9 | Completion time: 1s.
2026-08-20 06:02:27.251 | HD Request # 9 | Intraday data download complete for ADR-NASDAQ. Unique request ID: 9
2026-08-20 06:02:27.251 | Removing historical data download ID 9.
2026-08-20 06:02:27.251 | Real-time Intraday chart data file updates started for ADR-NASDAQ
2026-08-20 06:02:27.251 | Intraday chart data file opened for ADR-NASDAQ
2026-08-20 06:02:27.251 | HD Request # 9 | Enabling Intraday chart updating for symbol.
2026-08-20 06:02:27.251 | NQU26_FUT_CME [CBV-D] Flex Renko 40-20-16 #8 | Historical data download for additional symbol ADR-NASDAQ with ID 9 has completed.
2026-08-20 06:02:27.251 | Triggering next historical data download in queue.
2026-08-20 06:02:27.251 | HD Request # 10 | Downloading Intraday chart data for TICK-NASDAQ to the file TICK-NASDAQ.scid. Service: statscalc
2026-08-20 06:02:27.251 | HD Request # 10 | Download start date-time: 2026-08-20 06:00:57.000000. File last date-time: 2026-08-20 06:00:57.212001
2026-08-20 06:02:27.251 | HD Request # 10 | Using server: ds4.sierracharts.com port 10150
2026-08-20 06:02:27.251 | Socket (4) | Creating socket.
2026-08-20 06:02:27.252 | Socket (4) | New receive buffer size: 0
2026-08-20 06:02:27.252 | Socket (4) | Connecting to IP: 64.152.155.113.
2026-08-20 06:02:27.382 | Socket (3) | Socket gracefully closed by remote side.
2026-08-20 06:02:27.382 | Socket (3) | Closed.
2026-08-20 06:02:27.507 | HD Request # 10 | Setting DTC encoding to Binary VLS
2026-08-20 06:02:27.507 | HD Request # 10 | Sending historical data logon request message.
2026-08-20 06:02:27.635 | HD Request # 10 | Requesting Intraday data. Start date-time: 2026-08-20 06:00:57. Record interval: 0. Symbol: TICK-NASDAQ
2026-08-20 06:02:27.762 | HD Request # 10 | Decompressing data.
2026-08-20 06:02:27.889 | HD Request # 10 | Receiving Intraday data for TICK-NASDAQ starting at 2026-08-20 06:00:57.000000
2026-08-20 06:02:27.889 | Socket (4) | CloseSocket call.
2026-08-20 06:02:27.890 | Socket (4) | Shutdown started. Waiting for graceful close.
2026-08-20 06:02:27.915 | Historical data download thread signaled to stop.
2026-08-20 06:02:27.915 | HD Request # 10 | Timestamp of first Intraday data file record written: 2026-08-20 06:00:58.000000.
2026-08-20 06:02:27.915 | HD Request # 10 | Received 91 Intraday data records from 2026-08-20 06:00:57.000000 to 2026-08-20 06:02:27.000000 (90.0 seconds. Delay: 0.9 seconds) and wrote 90 records for TICK-NASDAQ
2026-08-20 06:02:27.916 | HD Request # 10 | Add time&sales data | Remembered last file record date-time: 2026-08-20 10:02:27.000000
2026-08-20 06:02:27.916 | Added 4 Time and Sales records to Intraday data file for TICK-NASDAQ after download.
2026-08-20 06:02:27.916 | HD Request # 10 | Completion time: 0s.
2026-08-20 06:02:27.916 | HD Request # 10 | Intraday data download complete for TICK-NASDAQ. Unique request ID: 10
2026-08-20 06:02:27.916 | Removing historical data download ID 10.
2026-08-20 06:02:27.916 | Real-time Intraday chart data file updates started for TICK-NASDAQ
2026-08-20 06:02:27.916 | Intraday chart data file opened for TICK-NASDAQ
2026-08-20 06:02:27.916 | HD Request # 10 | Enabling Intraday chart updating for symbol.
2026-08-20 06:02:27.916 | NQU26_FUT_CME [CBV-D] Flex Renko 40-20-16 #8 | Historical data download for additional symbol TICK-NASDAQ with ID 10 has completed.
2026-08-20 06:02:27.916 | Triggering next historical data download in queue.
2026-08-20 06:02:27.916 | HD Request # 11 | Downloading Intraday chart data for USDX to the file USDX.scid. Service: fxstatscalc
2026-08-20 06:02:27.916 | HD Request # 11 | Download start date-time: 2026-08-20 06:00:57.000000. File last date-time: 2026-08-20 06:00:57.000000
2026-08-20 06:02:27.917 | HD Request # 11 | Using server: ds12.sierracharts.com port 10149
2026-08-20 06:02:27.917 | Socket (3) | Creating socket.
2026-08-20 06:02:27.917 | Socket (3) | New receive buffer size: 0
2026-08-20 06:02:27.917 | Socket (3) | Connecting to IP: 69.39.70.241.
2026-08-20 06:02:28.016 | Socket (4) | Socket gracefully closed by remote side.
2026-08-20 06:02:28.016 | Socket (4) | Closed.
2026-08-20 06:02:28.172 | HD Request # 11 | Setting DTC encoding to Binary VLS
2026-08-20 06:02:28.172 | HD Request # 11 | Sending historical data logon request message.
2026-08-20 06:02:28.298 | HD Request # 11 | Requesting Intraday data. Start date-time: 2026-08-20 06:00:57. Record interval: 0. Symbol: USDX
2026-08-20 06:02:28.424 | HD Request # 11 | Decompressing data.
2026-08-20 06:02:28.551 | HD Request # 11 | Receiving Intraday data for USDX starting at 2026-08-20 06:00:57.000000
2026-08-20 06:02:28.551 | Socket (3) | CloseSocket call.
2026-08-20 06:02:28.552 | Socket (3) | Shutdown started. Waiting for graceful close.
2026-08-20 06:02:28.552 | Historical data download thread signaled to stop.
2026-08-20 06:02:28.552 | HD Request # 11 | Timestamp of first Intraday data file record written: 2026-08-20 06:00:58.000000.
2026-08-20 06:02:28.552 | HD Request # 11 | Received 90 Intraday data records from 2026-08-20 06:00:57.000000 to 2026-08-20 06:02:27.000000 (90.0 seconds. Delay: 1.6 seconds) and wrote 89 records for USDX
2026-08-20 06:02:28.553 | HD Request # 11 | Add time&sales data | Remembered last file record date-time: 2026-08-20 10:02:27.000000
2026-08-20 06:02:28.553 | Added 2 Time and Sales records to Intraday data file for USDX after download.
2026-08-20 06:02:28.553 | HD Request # 11 | Completion time: 1s.
2026-08-20 06:02:28.553 | HD Request # 11 | Intraday data download complete for USDX. Unique request ID: 14
2026-08-20 06:02:28.553 | Removing historical data download ID 14.
2026-08-20 06:02:28.553 | Real-time Intraday chart data file updates started for USDX
2026-08-20 06:02:28.553 | Intraday chart data file opened for USDX
2026-08-20 06:02:28.553 | HD Request # 11 | Enabling Intraday chart updating for symbol.
2026-08-20 06:02:28.553 | Triggering next historical data download in queue.
2026-08-20 06:02:28.553 | HD Request # 12 | Downloading Intraday chart data for VOLX to the file VOLX.scid. Service: fxcm
2026-08-20 06:02:28.553 | HD Request # 12 | Download start date-time: 2026-08-20 06:00:15.000000. File last date-time: 2026-08-20 06:00:15.988000
2026-08-20 06:02:28.553 | HD Request # 12 | Using server: ds4.sierracharts.com port 10150
2026-08-20 06:02:28.553 | Socket (4) | Creating socket.
2026-08-20 06:02:28.553 | Socket (4) | New receive buffer size: 0
2026-08-20 06:02:28.553 | Socket (4) | Connecting to IP: 64.152.155.113.
2026-08-20 06:02:28.677 | Socket (3) | Socket gracefully closed by remote side.
2026-08-20 06:02:28.677 | Socket (3) | Closed.
2026-08-20 06:02:28.809 | HD Request # 12 | Setting DTC encoding to Binary VLS
2026-08-20 06:02:28.809 | HD Request # 12 | Sending historical data logon request message.
2026-08-20 06:02:28.936 | HD Request # 12 | Requesting Intraday data. Start date-time: 2026-08-20 06:00:15. Record interval: 0. Symbol: VOLX
2026-08-20 06:02:29.064 | HD Request # 12 | Decompressing data.
2026-08-20 06:02:29.096 | Loaded depth data records for GCZ26_FUT_CME 2026-08-19 from 2026-08-18 20:00:00.000000 to 2026-08-19 16:35:12.485000.
2026-08-20 06:02:29.098 | GCZ26_FUT_CME 2.0 Range #3 | StartDateTimeForLoadingOrderFills: 2026-08-18 18:00:00
2026-08-20 06:02:29.110 | Chart #3 has tagged chart #6 for full recalculation. Chartbook: SierraEdge PRO GC.Cht
2026-08-20 06:02:29.110 | GCZ26_FUT_CME 2.0 Range #3 | Chart data loading complete.
2026-08-20 06:02:29.168 | GCM26_FUT_CME/MGCM26_FUT_CME [CBV-D] 30 Sec #6 | Performing a full recalculation because it has been tagged. Chartbook: SierraEdge PRO GC.Cht
2026-08-20 06:02:29.190 | HD Request # 12 | Receiving Intraday data for VOLX starting at 2026-08-20 06:00:15.922000
2026-08-20 06:02:29.191 | Socket (4) | CloseSocket call.
2026-08-20 06:02:29.191 | Socket (4) | Shutdown started. Waiting for graceful close.
2026-08-20 06:02:29.191 | Historical data download thread signaled to stop.
2026-08-20 06:02:29.191 | HD Request # 12 | Timestamp of first Intraday data file record written: 2026-08-20 06:01:14.488000.
2026-08-20 06:02:29.191 | HD Request # 12 | Received 7 Intraday data records from 2026-08-20 06:00:15.922000 to 2026-08-20 06:02:11.169000 (115.2 seconds. Delay: 18.0 seconds) and wrote 5 records for VOLX
2026-08-20 06:02:29.192 | HD Request # 12 | Add time&sales data | Remembered last file record date-time: 2026-08-20 10:02:11.169000
2026-08-20 06:02:29.192 | HD Request # 12 | Completion time: 1s.
2026-08-20 06:02:29.192 | HD Request # 12 | Intraday data download complete for VOLX. Unique request ID: 15
2026-08-20 06:02:29.192 | Removing historical data download ID 15.
2026-08-20 06:02:29.192 | Real-time Intraday chart data file updates started for VOLX
2026-08-20 06:02:29.192 | Intraday chart data file opened for VOLX
2026-08-20 06:02:29.192 | HD Request # 12 | Enabling Intraday chart updating for symbol.
2026-08-20 06:02:29.192 | No download requests in the queue to start downloads for.
2026-08-20 06:02:29.318 | Socket (4) | Socket gracefully closed by remote side.
2026-08-20 06:02:29.318 | Socket (4) | Closed.
2026-08-20 06:02:29.323 | Loaded depth data records for NQU26_FUT_CME 2026-08-14 from 2026-08-14 11:14:15.983000 to 2026-08-14 16:59:59.992000.
2026-08-20 06:02:29.484 | Loaded depth data records for NQU26_FUT_CME 2026-08-16 from 2026-08-16 18:00:00.000000 to 2026-08-16 19:59:59.965000.
2026-08-20 06:02:30.408 | Loaded depth data records for ESU26_FUT_CME 2026-08-19 from 2026-08-19 09:30:00.000000 to 2026-08-19 15:59:59.999000.
2026-08-20 06:02:30.410 | ESU26_FUT_CME/MESU26_FUT_CME [CBV-D] 512 Trades #6 | StartDateTimeForLoadingOrderFills: 2025-08-12 00:00:00
2026-08-20 06:02:30.549 | ESU26_FUT_CME/MESU26_FUT_CME [CBV-D] 512 Trades #6 | Chart data loading complete.
2026-08-20 06:02:30.702 | ESU26_FUT_CME [CBV-D] 30 Sec #4 | Performing a full recalculation because it has been tagged. Chartbook: Sierra Edge ES execution.Cht
2026-08-20 06:02:30.869 | ESU26_FUT_CME [CBV-D] 3000 Volume #1 | Performing a full recalculation because it has been tagged. Chartbook: Sierra Edge ES execution.Cht
2026-08-20 06:02:30.912 | Opened cached Intraday file: C:\SierraChart\Data\ADR-NYSE.scid. Thread ID: 35040
2026-08-20 06:02:30.913 | Opened cached Intraday file: C:\SierraChart\Data\UDVR-NYSE.scid. Thread ID: 35040
2026-08-20 06:02:30.913 | Opened cached Intraday file: C:\SierraChart\Data\ADR-NASDAQ.scid. Thread ID: 35040
2026-08-20 06:02:30.913 | Opened cached Intraday file: C:\SierraChart\Data\TICK-NASDAQ.scid. Thread ID: 35040
2026-08-20 06:02:30.914 | Opened cached Intraday file: C:\SierraChart\Data\USDX.scid. Thread ID: 35040
2026-08-20 06:02:34.220 | Loaded depth data records for NQU26_FUT_CME 2026-08-17 from 2026-08-16 20:00:00.003000 to 2026-08-17 19:59:59.975000.
2026-08-20 06:02:35.058 | Loaded depth data records for NQU26_FUT_CME 2026-08-19 from 2026-08-19 09:30:00.000000 to 2026-08-19 15:59:59.999000.
2026-08-20 06:02:35.059 | NQU26_FUT_CME/MNQU26_FUT_CME [CBV-D] 1 Min #21 | StartDateTimeForLoadingOrderFills: 2025-08-12 00:00:00
2026-08-20 06:02:35.797 | NQU26_FUT_CME/MNQU26_FUT_CME [CBV-D] 1 Min #21 | Chart data loading complete.
2026-08-20 06:02:37.491 | Loaded depth data records for NQU26_FUT_CME 2026-08-18 from 2026-08-17 20:00:00.001000 to 2026-08-18 19:59:59.901000.
2026-08-20 06:02:40.625 | Loaded depth data records for NQU26_FUT_CME 2026-08-19 from 2026-08-18 20:00:00.001000 to 2026-08-19 16:45:22.244000.
2026-08-20 06:02:40.692 | NQU26_FUT_CME 15.00 Range #1 | StartDateTimeForLoadingOrderFills: 2026-08-18 18:00:00
2026-08-20 06:02:40.705 | NQU26_FUT_CME 15.00 Range #1 | Chart data loading complete.
2026-08-20 06:02:41.308 | NQU26_FUT_CME [CBV-D] 1 Min #6 | Performing a full recalculation because it has been tagged. Chartbook: SierraEdge PRO NQ.Cht
2026-08-20 06:02:42.084 | NQU26_FUT_CME [CBV-D] 5 Min #33 | Performing a full recalculation because it has been tagged. Chartbook: SierraEdge PRO NQ.Cht
2026-08-20 06:02:42.085 | NQU26_FUT_CME [CBV-D] 5 Min #33 | Study: Google Sheets Importer | Making HTTP request.
2026-08-20 06:03:01.753 | Chartbook C:\SierraChart\Data\SierraEdge PRO NQ.Cht already closed. ACSIL function requested to close chart #11.
2026-08-20 06:03:01.753 | Chartbook C:\SierraChart\Data\SierraEdge PRO NQ.Cht already closed. ACSIL function requested to close chart #12.
2026-08-20 06:03:01.753 | Chartbook C:\SierraChart\Data\SierraEdge PRO NQ.Cht already closed. ACSIL function requested to close chart #13.
2026-08-20 06:03:01.753 | Chartbook C:\SierraChart\Data\SierraEdge PRO NQ.Cht already closed. ACSIL function requested to close chart #14.
2026-08-20 06:03:01.753 | Chartbook C:\SierraChart\Data\SierraEdge PRO NQ.Cht already closed. ACSIL function requested to close chart #15.
2026-08-20 06:03:01.753 | Chartbook C:\SierraChart\Data\SierraEdge PRO NQ.Cht already closed. ACSIL function requested to close chart #16.
2026-08-20 06:03:10.047 | NQU6.CME 1 Min #1 | Reloading chart.
2026-08-20 06:03:10.451 | Mapping NQU6.CME to NQU26. Service code: cme
2026-08-20 06:03:10.452 | Denali Data Feed | Starting real-time market data updates for: NQU6.CME (NQU26). ID: 22 Service code: cme
2026-08-20 06:03:10.452 | Denali Data Feed | Connecting to the server ds25-2.sierracharts.com. Port 10048
2026-08-20 06:03:10.452 | Denali Data Feed | Requesting security definition data for: NQU6.CME (NQU26). ID: 22
2026-08-20 06:03:10.452 | Added historical Intraday data request for NQU6.CME to the queue.
2026-08-20 06:03:10.452 | Intraday data recording state for symbol NQU6.CME is set to download 'Pending'.
2026-08-20 06:03:10.452 | Triggering next historical data download in queue.
2026-08-20 06:03:10.452 | Delaying start of download for NQU6.CME.
2026-08-20 06:03:10.489 | DTC Client socket (3) | Creating socket.
2026-08-20 06:03:10.489 | DTC Client socket (3) | New receive buffer size: 0
2026-08-20 06:03:10.489 | DTC Client socket (3) | Connecting to IP: 64.152.155.21.
2026-08-20 06:03:10.615 | Denali Data Feed | Network connection to server complete.
2026-08-20 06:03:10.615 | Denali Data Feed | Starting socket receive thread.
2026-08-20 06:03:10.615 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard
2026-08-20 06:03:10.746 | Denali Data Feed | Setting DTC encoding to Binary VLS
2026-08-20 06:03:10.746 | Denali Data Feed | Sending logon request message.
2026-08-20 06:03:11.340 | Denali Data Feed | Received logon response.
2026-08-20 06:03:11.340 | Denali Data Feed | Server Name: SC Realtime Server.
2026-08-20 06:03:11.340 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8
2026-08-20 06:03:11.340 | Denali Data Feed | Successfully connected.
2026-08-20 06:03:11.340 | Denali Data Feed | Trading is not supported.
2026-08-20 06:03:11.340 | Denali Data Feed | MarketDepthIsSupported: 1
2026-08-20 06:03:11.340 | Denali Data Feed | Restarting real-time data updates for symbol: NQU6.CME -> NQU26
2026-08-20 06:03:11.558 | Denali Data Feed | Setting external service identifier for symbol NQU6.CME to 42004177
2026-08-20 06:03:11.558 | Denali Data Feed | Received security definition for symbol NQU6.CME
2026-08-20 06:03:12.111 | NQU6.CME[M] 1 Min #1 | Chart data loading complete.
2026-08-20 06:03:16.640 | HD Request # 13 | Downloading Intraday chart data for NQU6.CME to the file NQU6.CME.scid. Service: cme
2026-08-20 06:03:16.640 | HD Request # 13 | Download start date-time: 2026-08-20 06:00:57.000000. File last date-time: 2026-08-20 06:00:57.156000
2026-08-20 06:03:16.641 | HD Request # 13 | Using server: ds32.sierracharts.com port 10149
2026-08-20 06:03:16.641 | Socket (4) | Creating socket.
2026-08-20 06:03:16.641 | Socket (4) | New receive buffer size: 0
2026-08-20 06:03:16.641 | Socket (4) | Connecting to IP: 69.39.70.248.
2026-08-20 06:03:16.900 | HD Request # 13 | Setting DTC encoding to Binary VLS
2026-08-20 06:03:16.900 | HD Request # 13 | Sending historical data logon request message.
2026-08-20 06:03:17.060 | HD Request # 13 | Requesting Intraday data. Start date-time: 2026-08-20 06:00:57. Record interval: 0. Symbol: NQU26
2026-08-20 06:03:17.188 | HD Request # 13 | Decompressing data.
2026-08-20 06:03:17.316 | HD Request # 13 | Receiving Intraday data for NQU6.CME starting at 2026-08-20 06:00:57.156000
2026-08-20 06:03:17.316 | Socket (4) | CloseSocket call.
2026-08-20 06:03:17.317 | Socket (4) | Shutdown started. Waiting for graceful close.
2026-08-20 06:03:17.317 | Historical data download thread signaled to stop.
2026-08-20 06:03:17.317 | HD Request # 13 | Timestamp of first Intraday data file record written: 2026-08-20 06:00:57.519000.
2026-08-20 06:03:17.317 | HD Request # 13 | Received 173 Intraday data records from 2026-08-20 06:00:57.156000 to 2026-08-20 06:03:15.923000 (2.3 minutes. Delay: 1.4 seconds) and wrote 172 records for NQU6.CME
2026-08-20 06:03:17.318 | HD Request # 13 | Add time&sales data | Remembered last file record date-time: 2026-08-20 10:03:15.923000
2026-08-20 06:03:17.318 | HD Request # 13 | Completion time: 1s.
2026-08-20 06:03:17.318 | HD Request # 13 | Intraday data download complete for NQU6.CME. Unique request ID: 18
2026-08-20 06:03:17.318 | Removing historical data download ID 18.
2026-08-20 06:03:17.318 | Real-time Intraday chart data file updates started for NQU6.CME
2026-08-20 06:03:17.318 | Intraday chart data file opened for NQU6.CME
2026-08-20 06:03:17.318 | HD Request # 13 | Enabling Intraday chart updating for symbol.
2026-08-20 06:03:17.318 | No download requests in the queue to start downloads for.
2026-08-20 06:03:17.444 | Socket (4) | Socket gracefully closed by remote side.
2026-08-20 06:03:17.444 | Socket (4) | Closed.
2026-08-20 06:03:20.998 | Opened cached Intraday file: C:\SierraChart\Data\NQU6.CME.scid. Thread ID: 35040
2026-08-20 06:03:37.389 | File >> Disconnect selected.
2026-08-20 06:03:37.389 | Rithmic Direct - DTC | Waiting for socket receive thread to end
2026-08-20 06:03:37.389 | DTC Client socket (1) | CloseSocket call.
2026-08-20 06:03:37.389 | DTC Client socket (1) | Shutdown started. Waiting for graceful close.
2026-08-20 06:03:37.391 | Denali Data Feed | Waiting for socket receive thread to end
2026-08-20 06:03:37.392 | DTC Client socket (3) | CloseSocket call.
2026-08-20 06:03:37.392 | Denali Data Feed | Disconnected from the server.
2026-08-20 06:03:37.392 | SC Data with Depth | Waiting for socket receive thread to end
2026-08-20 06:03:37.392 | DTC Client socket (3) | Shutdown started. Waiting for graceful close.
2026-08-20 06:03:37.392 | DTC Client socket (2) | CloseSocket call.
2026-08-20 06:03:37.392 | SC Data with Depth | Disconnected from the server.
2026-08-20 06:03:37.392 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2026-08-20 06:03:37.392 | Rithmic Direct - DTC | Disconnected.
2026-08-20 06:03:37.514 | DTC Client socket (1) | Socket gracefully closed by remote side.
2026-08-20 06:03:37.514 | DTC Client socket (1) | Closed.
2026-08-20 06:03:37.569 | DTC Client socket (2) | Socket gracefully closed by remote side.
2026-08-20 06:03:37.569 | DTC Client socket (2) | Closed.
2026-08-20 06:03:37.643 | DTC Client socket (3) | Socket gracefully closed by remote side.
2026-08-20 06:03:37.643 | DTC Client socket (3) | Closed.
2026-08-20 06:03:46.249 |
2026-08-20 06:03:46.249 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2026-08-20 06:03:46.249 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2026-08-20 06:03:46.249 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500
2026-08-20 06:03:46.406 | DTC Client socket (1) | Creating socket. Using TLS 1.2.
2026-08-20 06:03:46.406 | DTC Client socket (1) | New receive buffer size: 0
2026-08-20 06:03:46.406 | DTC Client socket (1) | Connecting to IP: 184.105.22.231.
2026-08-20 06:03:46.536 | Rithmic Direct - DTC | Network connection to server complete.
2026-08-20 06:03:46.536 | Rithmic Direct - DTC | Starting socket receive thread.
2026-08-20 06:03:46.536 | Rithmic Direct - DTC | Using fixed encoding of Binary
2026-08-20 06:03:46.536 | Rithmic Direct - DTC | Sending logon request message.
2026-08-20 06:03:46.933 | Rithmic Direct - DTC | Received logon response.
2026-08-20 06:03:46.933 | Rithmic Direct - DTC | Server Name: .
2026-08-20 06:03:46.933 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8
2026-08-20 06:03:46.933 | Rithmic Direct - DTC | Successfully connected.
2026-08-20 06:03:46.933 | Rithmic Direct - DTC | Trading is supported.
2026-08-20 06:03:46.933 | Rithmic Direct - DTC | Order cancel and replace is supported.
2026-08-20 06:03:46.933 | Rithmic Direct - DTC | OCO Orders supported.
2026-08-20 06:03:46.933 | Rithmic Direct - DTC | Symbol and Exchange Delimiter: .
2026-08-20 06:03:46.933 | Rithmic Direct - DTC | MarketDepthIsSupported: 0
2026-08-20 06:03:46.933 | Rithmic Direct - DTC | Connection to server complete.
2026-08-20 06:03:46.934 | No download requests in the queue to start downloads for. | Number times message added: 3
2026-08-20 06:03:47.090 | Mapping NQU6.CME to NQU26. Service code: cme
2026-08-20 06:03:47.090 | Using symbol data fast lookup vector
2026-08-20 06:03:47.090 | Denali Data Feed | Starting real-time market data updates for: NQU6.CME (NQU26). ID: 1 Service code: cme
2026-08-20 06:03:47.090 | Denali Data Feed | Connecting to the server ds32-2.sierracharts.com. Port 10048
2026-08-20 06:03:47.090 | Denali Data Feed | Requesting security definition data for: NQU6.CME (NQU26). ID: 1
2026-08-20 06:03:47.090 | Added historical Intraday data request for NQU6.CME to the queue.
2026-08-20 06:03:47.090 | Intraday data recording state for symbol NQU6.CME is set to download 'Pending'.
2026-08-20 06:03:47.090 | Triggering next historical data download in queue.
2026-08-20 06:03:47.094 | DTC Client socket (2) | Creating socket.
2026-08-20 06:03:47.095 | Delaying start of download for NQU6.CME.
2026-08-20 06:03:47.095 | DTC Client socket (2) | New receive buffer size: 0
2026-08-20 06:03:47.095 | DTC Client socket (2) | Connecting to IP: 69.39.70.249.
2026-08-20 06:03:47.223 | Denali Data Feed | Network connection to server complete.
2026-08-20 06:03:47.223 | Denali Data Feed | Starting socket receive thread.
2026-08-20 06:03:47.223 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard
2026-08-20 06:03:47.362 | Denali Data Feed | Setting DTC encoding to Binary VLS
2026-08-20 06:03:47.362 | Denali Data Feed | Sending logon request message.
2026-08-20 06:03:47.925 | Denali Data Feed | Received logon response.
2026-08-20 06:03:47.925 | Denali Data Feed | Server Name: SC Realtime Server.
2026-08-20 06:03:47.925 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8
2026-08-20 06:03:47.925 | Denali Data Feed | Successfully connected.
2026-08-20 06:03:47.925 | Denali Data Feed | Trading is not supported.
2026-08-20 06:03:47.925 | Denali Data Feed | MarketDepthIsSupported: 1
2026-08-20 06:03:47.925 | Denali Data Feed | Restarting real-time data updates for symbol: NQU6.CME -> NQU26
2026-08-20 06:03:48.144 | Denali Data Feed | Setting external service identifier for symbol NQU6.CME to 42004177
2026-08-20 06:03:48.144 | Denali Data Feed | Received security definition for symbol NQU6.CME
2026-08-20 06:03:54.001 | HD Request # 14 | Downloading Intraday chart data for NQU6.CME to the file NQU6.CME.scid. Service: cme
2026-08-20 06:03:54.001 | HD Request # 14 | Download start date-time: 2026-08-20 06:03:36.000000. File last date-time: 2026-08-20 06:03:36.227000
2026-08-20 06:03:54.001 | HD Request # 14 | Using server: ds37.sierracharts.com port 10150
2026-08-20 06:03:54.008 | Socket (3) | Creating socket.
2026-08-20 06:03:54.008 | Socket (3) | New receive buffer size: 0
2026-08-20 06:03:54.008 | Socket (3) | Connecting to IP: 4.8.175.92.
2026-08-20 06:03:54.275 | HD Request # 14 | Setting DTC encoding to Binary VLS
2026-08-20 06:03:54.275 | HD Request # 14 | Sending historical data logon request message.
2026-08-20 06:03:54.471 | HD Request # 14 | Requesting Intraday data. Start date-time: 2026-08-20 06:03:36. Record interval: 0. Symbol: NQU26
2026-08-20 06:03:54.604 | HD Request # 14 | Decompressing data.
2026-08-20 06:03:54.736 | HD Request # 14 | Receiving Intraday data for NQU6.CME starting at 2026-08-20 06:03:36.165000
2026-08-20 06:03:54.737 | Socket (3) | CloseSocket call.
2026-08-20 06:03:54.737 | Socket (3) | Shutdown started. Waiting for graceful close.
2026-08-20 06:03:54.737 | Historical data download thread signaled to stop.
2026-08-20 06:03:54.738 | HD Request # 14 | Timestamp of first Intraday data file record written: 2026-08-20 06:03:38.057000.
2026-08-20 06:03:54.738 | HD Request # 14 | Received 26 Intraday data records from 2026-08-20 06:03:36.165000 to 2026-08-20 06:03:52.803000 (16.6 seconds. Delay: 1.9 seconds) and wrote 23 records for NQU6.CME
2026-08-20 06:03:54.738 | HD Request # 14 | Add time&sales data | Remembered last file record date-time: 2026-08-20 10:03:52.803000
2026-08-20 06:03:54.738 | HD Request # 14 | Completion time: 0s.
2026-08-20 06:03:54.738 | HD Request # 14 | Intraday data download complete for NQU6.CME. Unique request ID: 19
2026-08-20 06:03:54.738 | Removing historical data download ID 19.
2026-08-20 06:03:54.738 | Real-time Intraday chart data file updates started for NQU6.CME
2026-08-20 06:03:54.738 | Intraday chart data file opened for NQU6.CME
2026-08-20 06:03:54.738 | HD Request # 14 | Enabling Intraday chart updating for symbol.
2026-08-20 06:03:54.738 | No download requests in the queue to start downloads for.
2026-08-20 06:03:54.869 | Socket (3) | Socket gracefully closed by remote side.
2026-08-20 06:03:54.869 | Socket (3) | Closed.
2026-08-20 06:04:01.063 | Opened cached Intraday file: C:\SierraChart\Data\NQU6.CME.scid. Thread ID: 35040
2026-08-20 06:04:06.262 | HTTPS connection ID:4 to downloads.rithmic.com:443 for request ID:4 (3) | Creating socket. Using TLS 1.2.
2026-08-20 06:04:06.263 | HTTPS connection ID:4 to downloads.rithmic.com:443 for request ID:4 (3) | New receive buffer size: 0
2026-08-20 06:04:06.263 | HTTPS connection ID:4 to downloads.rithmic.com:443 for request ID:4 (3) | Connecting to IP: 38.79.0.89.
2026-08-20 06:04:07.419 | HTTPS connection ID:4 to downloads.rithmic.com:443 for request ID:4 (3) | Socket gracefully closed by remote side. | Number times message added: 1
2026-08-20 06:04:07.419 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\RithmicConnections.json. Size: 115672
2026-08-20 06:04:07.420 | Rithmic Direct - DTC | Processed connection points. Count: 496
2026-08-20 06:04:07.420 | HTTPS connection ID:4 to downloads.rithmic.com:443 for request ID:4 (3) | CloseSocket call.
2026-08-20 06:04:07.421 | HTTPS connection ID:4 to downloads.rithmic.com:443 for request ID:4 (3) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2026-08-20 06:04:07.421 | HTTPS connection ID:4 to downloads.rithmic.com:443 for request ID:4 (3) | Closed.
[2026-08-20 15:48:48]
John - SC Support - Posts: 48643
The one issue we see is that you have the wrong symbols for your charts. They are setup to use the Teton CME Routing symbols and not Rithmic.
With your chartbooks open, select "Edit >> Translate Symbols to Current Service" to update the symbols to what is needed for Rithmic.
