Date/Time: Wed, 11 Nov 2026 18:03:41 +0000
how do I could customise my candlestick charts?
View Count: 556
| [2026-08-06 16:53:39] |
| b1u3lee - Posts: 43 |
Could you point me to how I could customise my candlestick charts? I would like it to start from GLOBEX OPEN 0600 EST to 0459 the next session? |
| [2026-08-06 16:54:38] |
| John - SC Support - Posts: 48497 |
The Session Times control the hours of the data in the chart. Refer to the following: Chart Session Times For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-08-10 13:11:30] |
Thanks. Im able to customise the chart session time Is there a link showing how to use the fibonacci tool and also displaying candle values? the fibonacci tool comes out as a wave instead. Also I'm having difficulty displaying the candle values on my hourly chart |
| [2026-08-11 01:26:22] |
| Sierra_Chart Engineering - Posts: 25412 |
Maybe you want to use the Price Retracement tool: Chart Drawing Tools: Price Retracement (2 point) | Price Expansion (2 point) | Price Projection (3 point) Tools And here are the instructions to see Chart Values: Chart Drawing Tools: Viewing Tool and Chart Data When Using Tools Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2026-08-11 01:26:52
| [2026-08-13 15:58:44] |
Hi Engineering Team I noticed a lag while scrunging my hourly charts with daily volume profile. Is this because my laptop can't handle so much data on a single chart? |
| [2026-08-13 20:10:15] |
You need to increase this Input to a higher value: Volume By Price Study: Ticks Per Volume Bar We would recommend increasing it, by 5 to 10 times higher. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-08-14 04:42:44] |
I see. Is this also what is commonly known as tick compression?
| [2026-08-14 06:56:28] |
Yes, you could say that.
| [2026-08-15 14:28:23] |
another question, so there are 2 options for ticks per volume bar I.e intraday & historical what count as historical chart? or can I safely assume my tick & hourly charts are both considered intraday charts? |
| [2026-08-17 09:05:50] |
or can I safely assume my tick & hourly charts are both considered intraday charts? Yes.
| [2026-08-17 14:17:31] |
so whats considered a historical chart?
| [2026-08-17 14:22:23] |
Charts that have daily bar time frames and higher. This includes daily, weekly, monthly, quarterly, yearly.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2026-08-17 14:22:46
