Date/Time: Tue, 20 Oct 2026 19:06:13 +0000
RTH Troubleshooting
View Count: 352
[2026-07-21 15:52:32]
User940141 - Posts: 5
I'm moving from NT8 to Sierra and i can't put my sierra chart on (RTH) as
shown in the picture.and under is Sierra that's not doing it[image:
Screenshot 2026-07-20 163628.png]
[image: Screenshot 2026-07-20 163710.png]
imagetmp_1784584502_Screenshot 2026-07-20 163710.png / V - Attached On 2026-07-21 15:52:24 UTC - Size: 17.63 KB - 94 views
imagetmp_1784584502_Screenshot 2026-07-20 163628.png / V - Attached On 2026-07-21 15:52:27 UTC - Size: 42.35 KB - 97 views
[2026-07-21 15:52:36]
John - SC Support - Posts: 48276
We can not tell anything from the images, as they are not showing the time scale, so we do not know what is being shown.
If you want a chart that covers just the RTH session, then you need to set your Session Times to cover that time period and not use an Evening Session. Refer to the following:
Chart Session Times
[2026-07-21 16:28:38]
The one From NT8 opens at the NYSE to EOD…..the Sierra chart one doesn’t allow me to do so as example displayed on NT8
[2026-07-21 18:22:30]
You can set a Sierra Chart chart to cover any times you want. You do this through the Session Times. What exactly is not working for you?
The link to the documentation for the Session Times is here:
Chart Session Times
[2026-07-21 18:48:55]
It doesn’t set it up how I want I’ve tried it several times. Do you guys have phone support because I don’t want to go back and forth typing delaying the process.
[2026-07-21 19:19:26]
We do not have phone support. It is one of the ways we keep our costs down.
If you want to talk to someone, then we recommend one of the people at the following link:
Sierra Chart Personal Assistance
What exactly do you want to see in your chart?
Date Time Of Last Edit: 2026-07-21 19:20:17
[2026-07-22 16:54:49]
User708541 - Posts: 208
This should help you.
This is a screenshot showing how to set the Session Times. I'm in Pacific Time so adjust the times for your local time. Sierra also allows you to set the charts up for exchange time. So if setting this to your local time doesn't give you the results you want, then check if your charts are configured for exchange time.
imageHow to Set RTH.jpg / V - Attached On 2026-07-22 16:54:34 UTC - Size: 310.24 KB - 91 views
[2026-07-23 03:42:10]
Yes! Thank you got it
