Date/Time: Sat, 14 Nov 2026 02:43:04 +0000
Funded at AMP and want to use Tenton/Denali
View Count: 303
| [2026-07-01 16:50:34] |
| User469312 - Posts: 107 |
Hello. I have a funded account at AMP and use SC as my trading platform. I currently use CQG but I also pay for Denali data - AMP told me I am set up both for AMP and to use Denali (or what ever SC uses most likely Tenton) AMP clears of course. I am set for futures and options and would like to transition to Tenton. What must be done on my end? Thanking you in advance |
| [2026-07-01 19:28:24] |
| John - SC Support - Posts: 48527 |
The first thing we want to point out is that if you are wanting to trade Options, then you can not use the Teton Order Routing service for this, as Teton does not have support for trading Options. You could have two different accounts with AMP, one for Teton and trading the regular futures contracts, the other for CQG to trade Options. Or you can continue to use CQG instead for both and just have the one account with AMP. Let us know what you decide and we can then point you to the necessary instructions. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-07-01 19:41:17] |
Thank you for the clarification. it was one of the reasons why I was looking to shift to Tenton so any help I would be so grateful. I cannot get the options to work on SC using CQG - it always comes up invalid security. I have followed all the instructions to a tee and still cannot get it to work. I am set up at AMP for options and AMP will not help me with regard to options and always tell me to reach out to SC. I'm not dumb and don't want to waste your time just need guidance here - I trade both but like to fire off options to capture the larger trend moves. Any guidance will be helpful |
| [2026-07-01 19:58:27] |
Did you follow the instructions at the following link: Denali Exchange Data Feed: Denali Futures Options Data with Other Trading Services As noted in there, you will need to enter a "Trade and Current Quote Symbol" for the actual options symbol that CQG requires for the chosen option. We are unable to help with the particular CQG symbol that is required for options, as we simply do not know. You can try the following website and see if it will give you what you need for the CQG symbology: https://www.cqg.com/partners/exchanges/tradable-symbols For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-07-01 20:05:10] |
Yes but That might be the problem, the symbol - I will work on this and see what transpire- Thank you so much for your help here. I will follow up either way! I am very grateful for the help
