Date/Time: Mon, 09 Nov 2026 14:54:29 +0000
Misalignement
View Count: 302
| [2026-06-18 08:14:08] |
| User444704 - Posts: 1 |
Hello, I am experiencing a misalignment issue between candlesticks and the FP Candlestick study on my chart. Setup details: - Symbol: MNQU26_FUT_CME - Bar Period Type: Range Per Bar - Standard (in ticks), value 19 - Graph Draw Type: Candlestick Bars - Chart number: #13 FP Candlestick study settings: - Overlay from Same Chart as Study: Yes - Chart Number to Overlay: #13 - Multiplier: 1 - Chart Region: 1 The issue: the footprint (Bid/Ask cells) does not align with the candlesticks. They appear in separate areas of the chart despite being in the same Chart Region 1. Additionally, the chart title bar still shows [CV][M] even though Chart Settings shows Range Per Bar with Candlestick Bars — no Candlevolume setting is active as far as I can tell. Could you help me understand what is causing this misalignment and how to fix it? Thank you. |
| [2026-06-18 16:17:51] |
| John - SC Support - Posts: 48464 |
When you have a Numbers Bars study on a chart, and then overlay the bars from that chart back to itself in order to show on the Numbers Bars, those bars are going to be centered in the area for a bar as defined by the Numbers Bars. So if you have 1 column displayed, the candles will be in the middle of that column. If you have two columns, it will be between the two columns. If you have 3 columns, it will be in the middle of the second column. If the above is not what you are seeing, then we would need to see an image of what you are seeing to understand what exactly is occurring. Follow these instructions to get us an image: Support Board Posting Information: Attaching or Posting a Screenshot/Image (Optional) The notation of "[CV]" is for a Continuous Futures Contract chart. Refer to the following: Continuous Futures Contract Charts: Text Indicator Description Table The "[M]" means that you are getting the data from our Denali Exchange Data Feed. Refer to the following: Chart Data and Chart Data Files: The Meaning of the [M] Designation after a Symbol The Numbers Bars study will not change the Bar Period of your chart. If it is setup as a Range chart, then it will stay as a Range chart. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
