Date/Time: Fri, 06 Nov 2026 12:55:12 +0000
Data Not Working
View Count: 263
[2026-06-13 14:15:39]
User727014 - Posts: 1
I renewed my services on the 10th, and it has not connected since. It constantly says Connecting and Reconnecting Wait, but it never turn on
[2026-06-13 22:45:58]
Sierra_Chart Engineering - Posts: 25390
Connect to the data feed:
Select "File >> Disconnect"
Select "File >> Connect to Data Feed"
To access historical and streaming market data independent from your Trading service. Follow these instructions.
Set "Global Settings >> Data/Trade Service Settings >> Current Selected Service" to "SC Data-All Services".
Press "OK"
And then translate the symbols in your Chartbooks in Sierra Chart using this "Edit' menu command:
Edit Menu: Edit >> Translate Symbols To Current Service (Translate Symbols to Current Service)
You can then use the data provided by Sierra Chart independent of your trading service.
