Date/Time: Fri, 06 Nov 2026 12:53:05 +0000
Sierra Chart Connection issues
View Count: 376
[2026-06-12 19:17:39]
User584849 - Posts: 3
Dear SC Techinical Team,
My Sierra Chart is not connecting even though the services are active as seen in the control panel. Could you please indicate what the issue is and how to resolve it? Please see the attached Sierra chart log and the Control Panel status.
Regards,
Fernando da Silva
imageActivated Service_12062026.jpg / V - Attached On 2026-06-12 19:15:08 UTC - Size: 206.88 KB - 92 views
imageSierra Chart Log_12062026_connection issue.jpg / V - Attached On 2026-06-12 19:15:18 UTC - Size: 269.4 KB - 100 views
[2026-06-12 19:30:11]
We need to see your log by following these instructions:
Reconnect to the data feed:
[2026-06-13 21:45:02]
The problem is solved.
Thanks for the support.
