Date/Time: Fri, 06 Nov 2026 12:59:29 +0000
Hisorical Data
View Count: 254
[2026-06-05 11:25:17]
User165981 - Posts: 66
Im trying to download 1200 days of NQ daily candles. Attached are my settings. Im only getting from March of this year (current contract).
What am I doing incorrectly?
imageScreenshot from 2026-06-05 07-23-09.png / V - Attached On 2026-06-05 11:25:07 UTC - Size: 85.88 KB - 142 views
[2026-06-05 12:47:15]
User135243 - Posts: 330
you've to use the continous contract
[2026-06-05 14:24:48]
I know this sound dumb, but how do I do that? I only have these options
imageScreenshot from 2026-06-05 10-24-15.png / V - Attached On 2026-06-05 14:24:40 UTC - Size: 43.02 KB - 128 views
[2026-06-05 14:37:08]
Refer to the following:
Continuous Futures Contract Charts
[2026-06-05 15:06:07]
Ok I got it to download and I used auto rollover to yes and continuious contract-- volume based no back adjust. I'm not seeing the gaps. I have the show rollover checked on chart setting.
[2026-06-05 16:01:35]
Are you just making a statement, or are you asking why you are not seeing gaps at the rollover times?
[2026-06-05 16:48:23]
Asking why, sorry.
[2026-06-05 17:08:21]
Please tell us exactly the option you have selected for the "Chart >> Chart Settings >> Symbol >> Continuous Contract".
And please get us an image showing the data at the transition between two contracts with the option for "Chart >> Show Rollover Dates" enabled, so we can see where the rollover is set for your chart. Follow these instructions to get us an image:
[2026-06-05 17:20:08]
https://www.sierrachart.com/image.php?Image=1780679913464.png
Here you go
imageScreenshot from 2026-06-05 13-19-06.png / V - Attached On 2026-06-05 17:19:56 UTC - Size: 93.83 KB - 122 views
[2026-06-05 17:46:17]
It is not as obvious in a Daily chart, but it is there. You also have to take into consideration that the daily data uses a Settlement Price for the daily data.
For instance, at the transistion from the H to the M contract, the H contract shows the following:
Daily data for March 13, 2026 (H contract) Last Price: 24394.25
Intraday data for March 13, 2026 (H contract) Last Pricee: 24335.25
