Date/Time: Thu, 26 Nov 2026 04:57:41 +0000
Price level maximum ASK/minimum BID
View Count: 245
[2026-06-04 13:43:25]
User290911 - Posts: 1
Is there a way to highlight for each bar the price level where the maximum ASK/minimum BID of the entire bar occurred?
[2026-06-04 15:51:25]
If you are using the Numbers Bars study, then you can do this with the study itself. Refer to the following:
Numbers Bars: Highlight Minimum Value In
Numbers Bars: Highlight Maximum Value In
Numbers Bars: Highlight Maximum/Minimum Value Based On
If you want to get the information from the Numbers Bars study and display it on a bar chart, then you can get those values from the "Price at Minimum Highlight" and "Price at Maximum Highlight" subgraphs and use the "Study/Price Overlay" to get those to another chart, and you can then use the "Study/Subgraph Reference" to display the values as you want in that chart. Refer to the following:
Study/Price Overlay Study
Study Subgraph Reference
