Date/Time: Fri, 09 Oct 2026 14:33:04 +0000
Disconnect from remote side
View Count: 1031
| [2026-05-28 15:48:38] |
| User98657 - Posts: 420 |
Today, 5/28/26, at approximately 10:13:41 there was a rush of data on a piece of Iran news. It wasn't an enormous rush, but it was a flush of data. One of my charts froze. I don't normally have this issue. Also, my other charts seemed fine. I'm not running a lot of load-consuming studies, and my machine is more than adequate. The market I was watching was the NQ, and it is set to trade the MNQ. I have two separate instances of SC running. One of those utilizes a sub instance. That instance kept running fine. My other instance, the instance that froze, only has two charts. So I pulled the message log up and scrolled back to that time frame and what I see is that at 10:13:41.550 is "Socket gracefully closed by remote side". There's a string of these "close" messages during the timeframe my chart was locked, along with "Denali Data Feed | Disconnected from Server". Can you tell me why this might have happened? |
| [2026-05-28 16:38:38] |
| John - SC Support - Posts: 48165 |
We would really need to see your entire Message Log so we can see what it states. Please get us the log by following these instructions: Support Board Posting Information: How to Post Your Message Log (Required In Some Cases) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-05-28 17:27:53] |
John, I've sent the log via the "Send For Analysis" |
| [2026-05-28 17:52:42] |
The first items of note in your log are issues with the "Domain Name Resolution" (DNS), as your computer could not find the correct servers. This is shown in lines like the following: 2026-05-27 03:56:45.642 | Error getting address info for futurestrading16.sierracharts.com. Windows error code 11001: No such host is known.
Refer to the following regarding this: https://www.sierrachart.com/index.php?page=doc/helpdetails1.php#DomainNameServiceIssues The next item we see related to the time of 10:13:41 is the following: 2026-05-28 10:13:41.761 | Denali Data Feed | Disconnected from the server.
So there was a disconnection at that time, but there is no specific reason given. The system then reconnected 3 seconds later and everything is fine. Most likely this was caused by a general Internet "Hiccough", where you lost connection to our server, and then when it reconnected everything was fine. But we really do not know for sure what occurred. We do not see any issues with our servers at that time. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-05-28 18:44:54] |
Thanks for taking a look. I'll just assume the second item was a one-off.
| [2026-05-28 18:50:05] |
We did get one other report of an error at the exact same time (assuming you are both referring to the same time zone). So there may have been an issue. We brought this up with Engineering, and they state that there was something that occurred with the CME around that time. We do not have any additional information. And, as we stated, the system automatically reconnected and backfilled the data, so at worst you had a 3 second stoppage.
| [2026-06-09 17:12:43] |
So today the same thing happened on obviously abnormal range and volatility, but this time I lost connection on both instances of SC. I believe they were connected to two separate servers, but I cannot confirm that. I'm guessing I'm not alone and that you'll likely get a fair amount of alerts. I didn't see that the previous episode was fleshed out in terms of what happened with the server(s), but today's was pretty obvious and I'd really like to know where the SC Servers ran into difficulty, if it is being addressed (though I assume it is), and of course, if there's anything I can do to avoid it. |
| [2026-06-09 17:36:12] |
| frozentundra - Posts: 102 |
I also observed this today on Teton data, same as described above.
| [2026-06-09 18:49:21] |
| Jimmyy - Posts: 341 |
i too had disconnects today, although idk if it was my internet or what. is it better to just have windows firewall and other protections in windows security turned off ? Date Time Of Last Edit: 2026-06-09 18:51:05
| [2026-06-09 20:19:01] |
Refer to the following regarding the interuption around 12:38 today: 2026-6-9: Teton Order Routing Connectivity Issue and CME Market Data Interruption 12:38 PM For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-06-10 01:13:17] |
Thank you John. I appreciate the reply from engineering, and want to be clear that although I was very interested in knowing what happened, today's issue did not affect me monetarily. And I personally would categorize the events as one of those life events that can happen in trading. Just a few points I'd add: I do think an answer from the ISP is in order. While it does appear SC may have implemented one slight change to prevent some minor packet loss, it seems to me your redundancies and failovers did what they are designed to do. And perhaps the ISP issue, if the engineers are correct, was a one-off issue we're not likely to see again, but it would be nice to know. Also, I'm sure the engineers didn't intend to minimize any issues end users may have experienced during this, but saying "Only about half of the users receiving CME data." and that " not " all users.... doesn't make me feel great when I'm one of the half that was affected. Thanks again John, and thanks to the engineers for investigating and letting us know. |
