Date/Time: Thu, 26 Nov 2026 04:45:50 +0000
Modify Value Lables color and Font. Image attached.
View Count: 244
| [2026-05-19 15:44:43] |
| User838995 - Posts: 22 |
Hi Ican change the width of Horizontal Line Non extended tool but the price label font is so small that Icant even read. How to make it large and bold? In Zig zag study: Display Value Lables for Extention Line. How to make it small and change the color of numbers and background ...atleast the numbers color. Image attached.Both of these areas are marked with White Elips. Please give me simple step wise instructions. Image attached. Thank you.K https://www.sierrachart.com/image.php?Image=1779183564575.png |
| [2026-05-19 15:49:59] |
If there are no font controls for a specific drawing tool, then that font is controlled through the "Global Chart Drawing Font". Refer to the following: Chart Drawing Tools: Global Chart Drawing Font (Global Settings >> Tool Settings >> General >> Drawing Font) For the Zig Zag study, the Extension Line Labels use the "Chart Text" font. So the only way to change this is to change the size of the text for the entire chart. Refer to the following: Graphics Settings: Chart Text For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
