Date/Time: Tue, 24 Nov 2026 18:17:05 +0000
Regression in ACSIL DLL Execution and OpenGL Rendering in Version 2904
View Count: 482
[2026-05-17 17:19:46]
User732871 - Posts: 7
Date Time Of Last Edit: 2026-05-17 17:24:47
[2026-05-17 17:24:08]
Hello Sierra Chart Support,
I need assistance with a reproducible issue in the latest Sierra Chart version (2904) where ACSIL custom studies (DLL‑based) load successfully but do not execute or plot anything on the chart.
Critical detail
These exact same DLLs, chartbooks, and symbols work perfectly in Sierra Chart version 2878 on the same machine.
No changes to Windows, hardware, antivirus, or configuration — only the Sierra Chart version is different.
This strongly indicates a regression or compatibility change inside Sierra Chart, not an external or Windows‑related issue.
1. ACSIL DLL Studies Not Plotting in 2904
DLLs load successfully (confirmed in Message Log).
Studies appear in the “Add Custom Study” window.
Study settings open normally.
But nothing plots on the chart.
No errors or warnings appear.
Example from the log:
Code
Loading DLL: dynsupplyanddemandzones_64.dll
Loading DLL: OrderFlowLabs.com.free_64.dll
Loading DLL: VolumeTriggersPRO_64.dll
Important detail
Within the same DLL bundle, some studies do plot while others do not.
For example, in the ZYP Free study bundle, certain studies work normally, while others fail silently.
This confirms:
The DLLs load correctly
The ACSIL interface is partially functional
The issue is internal to Sierra Chart’s handling of specific ACSIL study functions in newer builds
2. OpenGL Rendering Issues (Regression)
When OpenGL is enabled in version 2904:
A. Chartbooks open with missing title bars
Charts open without title bars, even though “Show Title Bar” is enabled.
The title bar is pre‑selected but not visible until manually dragged.
B. Mouse cursor is not aligned with the crosshair
The cursor and crosshair become desynchronized, making chart interaction inaccurate.
C. When OpenGL is disabled, Sierra Chart becomes extremely slow
Non‑OpenGL mode is significantly slower than in version 2878.
These behaviors:
Did not occur in version 2878
Are not caused by Windows
Are reproducible across clean installations
Indicate an internal rendering pipeline issue
3. Environment
Clean installation in a new folder
Default settings
Default chartbooks
No imported configurations
Tested with SC Data and Denali
Tested on multiple symbols (NQM26, MESM26, EURUSD, etc.)
Same behavior across all tests
4. Clarification
The message:
Code
Historical data for NQM26-CME is delayed because connection to main data feed is not present.
is expected when the market is closed and is not related to the custom study issue.
Request
Please investigate why:
ACSIL DLL studies that work correctly in version 2878 fail to execute or draw anything in version 2904, despite loading successfully and showing no errors.
OpenGL mode causes missing title bars and mouse‑crosshair desynchronization, and
Non‑OpenGL mode is significantly slower than in older versions.
These issues appear to be regressions introduced in recent builds.
I can provide full logs, chartbooks, or DLLs if needed.
Thank you,
George
[2026-05-17 21:25:07]
Sierra_Chart Engineering - Posts: 25476
Regarding this:
Refer to the what is new notes here:
https://www.sierrachart.com/index.php?page=doc/Whats_New.php#SCVer2903
Rebuild your custom studies due to some changes with datatypes from int/float to double.
Regarding these first thing we want to do is to run Sierra Chart in Safe Mode:
Sierra Chart - Software Login Instructions: Using Safe Mode
This could not be true:
It makes no sense. There are no changes related to this. We do not observe any such problem. There is some other explanation in your particular case.
We will check on the issues you have with OpenGL but that does not make sense. We do not have any other reports of these.
Also refer to:
High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often: 30.44 - Performance Differences Between Versions of Sierra Chart
[2026-05-19 13:49:35]
We did do testing related to OpenGL and could not reproduce any of the problems:
We did:
1. Build Release for 2908 and run in empty folder with default settings
2. Open NQM26 Historical. Chart was maximized. I restored the chart to see title bar. It is visible and looks good.
3. Save chartbook (chart is restored), restart SC and open chartbook. Title is visible and looks good
4. Crosshair: Mouse cursor jumps on X axis to the nearest candle. And it moves smoothly on Y axis. (GDI works the same)
5. Added 3 charts to chartbook, did steps 2 and 3.
First I tested on Nvida graphics card on one monitor. The second test was with AMD graphics on the second monitor. All works good.
