Date/Time: Thu, 26 Nov 2026 04:33:42 +0000
large volume trade indicator issue
View Count: 537
| [2026-05-14 17:52:00] |
| User300837 - Posts: 7 |
everytime i hit apply the bubbles change dimension, using the same settings. aso, i cant find any way to have the bubbles transparent while having volume text inside them. thanks for the help!
| [2026-05-14 18:23:41] |
Set the Input for "Automatic Combining of Price Levels for Markers" to "No". Refer to the information for that Input in the following section: Large Volume Trade Indicator: Inputs aso, i cant find any way to have the bubbles transparent while having volume text inside them.
This is not supported. When you display the numbers, the markers no longer support transparency. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-05-14 18:31:02] |
is there any way to patch this keeping the setting on “yes”?
| [2026-05-14 19:35:22] |
It should default to "No". One of the following must be occurring: - You have saved defaults for that study that has that item set to "Yes". Refer to the following: Chart Studies: Using Custom Default Study Settings - You are using a Study Collection that uses that study and in that Study Collection that Input is set to "Yes". Refer to the following: Study Collections For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
