Date/Time: Tue, 17 Nov 2026 18:09:00 +0000
historical intraday data download failed(Unsupported protocol version)
View Count: 368
| [2026-05-06 16:48:10] |
| User828097 - Posts: 5 |
my seirra charting platforms can not load any data or chart for usage. when i add a symbol, after a while it says(HISTORICAL INTRADAY DATA DOWNLOADING FAILED, ERROR DOWNLOADING HISTORICAL INDRADAY DATA FOR XAUUSD. HISTORICAL DATA LOGON ERROR. UNSUPPORTED PROTOCOL VERSION)
| [2026-05-06 17:21:12] |
| John - SC Support - Posts: 48555 |
If you are not on the current version of software, then please update to the current release by following these instructions: Software Download: Fast Update Let us know if you continue to have an issue with the latest release. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-05-06 19:17:48] |
I am on the current version. This was my first step of troubleshooting the issue. Thank you
| [2026-05-06 19:38:48] |
Please do the following for us: - Select "Window >> Message Log" - On the Message Log window, select "Edit >> Clear Log" - Open a new chart for XAUUSD When you get the error you have stated, then get us the Message Log by following these instructions: Support Board Posting Information: How to Post Your Message Log (Required In Some Cases) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-05-06 20:30:53] |
Still not working. On the console log i saw (An Established connection was aborted by the software in your host machine)
| [2026-05-06 20:35:35] |
Please follow the instructions we gave in post #4 and get us the Message Log so we can see what it states.
| [2026-05-06 20:45:11] |
2026-05-06 20:37:29.904 | Software version: 2899 64-bit 2026-05-06 20:37:29.904 | Primary Thread ID: 268 2026-05-06 20:37:29.904 | Usage end date: 2026-05-26 2026-05-06 20:37:29.904 | Enabled for: Advanced Features 2. 2026-05-06 20:37:29.904 | Enabled for: Sierra Chart Historical Data Service. 2026-05-06 20:37:29.904 | Enabled for: Delayed Denali Exchange Data Feed. 2026-05-06 20:37:29.904 | Allow Support for Sierra Chart Data Feeds is enabled. 2026-05-06 20:37:29.904 | Current selected Data/Trading service: SC Data 2026-05-06 20:37:29.904 | Custom symbol settings values: enabled 2026-05-06 20:37:29.904 | Chart Update Interval: 400 2026-05-06 20:37:29.904 | Intraday Data Storage Time Unit: 1 2026-05-06 20:37:29.904 | Time Zone: +00:00:00 (UTC+00) 2026-05-06 20:37:29.904 | 2026-05-06 20:37:29 Local computer time in UTC 2026-05-06 20:37:29.904 | 2026-05-06 20:37:29 Local computer time in SC Time Zone 2026-05-06 20:37:29.904 | 2026-05-06 20:34:45 Server time in UTC 2026-05-06 20:37:29.904 | Local computer UTC time and Server UTC time difference: 5 seconds. 2026-05-06 20:37:29.904 | Notice: Your computer's clock is off by 5 seconds. Set the 'Global Settings >> NTP Settings >> NTP Client Enable' to 'Yes'. 2026-05-06 20:37:29.904 | Program path: C:\SierraChart\ 2026-05-06 20:37:29.904 | Data Files path: C:\SierraChart\Data\ 2026-05-06 20:37:29.905 | OS Version Number: 10.0 2026-05-06 20:37:29.905 | Locale Setting: C 2026-05-06 20:37:29.905 | Crash reporter started: true 2026-05-06 20:37:29.905 | 2026-05-06 20:37:31.527 | DTC Client socket (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. * 2026-05-06 20:37:31.528 | DTC Client socket (1) | Socket gracefully closed by remote side. 2026-05-06 20:37:31.528 | DTC Client socket (1) | Closed. 2026-05-06 20:37:36.505 | SC Data with Depth | Did not receive Encoding Response from server. Disconnecting. * 2026-05-06 20:37:36.505 | SC Data with Depth | Waiting for socket receive thread to end 2026-05-06 20:37:36.505 | DTC Client socket (6) | CloseSocket call. 2026-05-06 20:37:36.506 | DTC Client socket (6) | Shutdown started. Waiting for graceful close. 2026-05-06 20:37:36.506 | SC Data with Depth | Disconnected from the server. 2026-05-06 20:37:36.506 | SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. 2026-05-06 20:37:37.378 | XAUUSD 1 Min #4 | Reloading chart. 2026-05-06 20:37:37.401 | XAUUSD 1 Min #4 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\XAUUSD.scid 2026-05-06 20:37:37.405 | XAUUSD 1 Min #4 | Chart data loading complete. 2026-05-06 20:37:38.508 | SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 10048 2026-05-06 20:37:38.509 | DTC Client socket (1) | Creating socket. 2026-05-06 20:37:38.509 | DTC Client socket (1) | New receive buffer size: 0 2026-05-06 20:37:38.510 | DTC Client socket (1) | Connecting to IP: 69.39.70.241. 2026-05-06 20:37:42.387 | SC Data with Depth | Network connection to server complete. 2026-05-06 20:37:42.387 | SC Data with Depth | Starting socket receive thread. 2026-05-06 20:37:42.387 | SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard 2026-05-06 20:38:02.397 | SC Data with Depth | Did not receive Encoding Response from server. Disconnecting. * 2026-05-06 20:38:02.397 | SC Data with Depth | Waiting for socket receive thread to end 2026-05-06 20:38:02.398 | DTC Client socket (1) | CloseSocket call. 2026-05-06 20:38:02.398 | SC Data with Depth | Disconnected from the server. 2026-05-06 20:38:02.398 | SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. 2026-05-06 20:38:02.398 | DTC Client socket (1) | Shutdown started. Waiting for graceful close. 2026-05-06 20:38:02.552 | DTC Client socket (3) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. * 2026-05-06 20:38:02.552 | DTC Client socket (3) | Socket gracefully closed by remote side. 2026-05-06 20:38:02.552 | DTC Client socket (3) | Closed. 2026-05-06 20:38:04.403 | SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 10048 2026-05-06 20:38:04.404 | DTC Client socket (3) | Creating socket. 2026-05-06 20:38:04.404 | DTC Client socket (3) | New receive buffer size: 0 2026-05-06 20:38:04.404 | DTC Client socket (3) | Connecting to IP: 64.152.155.113. 2026-05-06 20:38:04.808 | SC Data with Depth | Network connection to server complete. 2026-05-06 20:38:04.808 | SC Data with Depth | Starting socket receive thread. 2026-05-06 20:38:04.808 | SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard 2026-05-06 20:38:24.655 | DTC Client socket (2) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. * 2026-05-06 20:38:24.655 | DTC Client socket (2) | Socket gracefully closed by remote side. 2026-05-06 20:38:24.655 | DTC Client socket (2) | Closed. 2026-05-06 20:38:24.817 | SC Data with Depth | Did not receive Encoding Response from server. Disconnecting. * 2026-05-06 20:38:24.817 | SC Data with Depth | Waiting for socket receive thread to end 2026-05-06 20:38:24.817 | DTC Client socket (3) | CloseSocket call. 2026-05-06 20:38:24.817 | DTC Client socket (3) | Shutdown started. Waiting for graceful close. 2026-05-06 20:38:24.818 | SC Data with Depth | Disconnected from the server. 2026-05-06 20:38:24.818 | SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. 2026-05-06 20:38:26.832 | SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 443 2026-05-06 20:38:26.833 | DTC Client socket (2) | Creating socket. 2026-05-06 20:38:26.833 | DTC Client socket (2) | New receive buffer size: 0 2026-05-06 20:38:26.833 | DTC Client socket (2) | Connecting to IP: 69.39.70.241. 2026-05-06 20:38:27.130 | SC Data with Depth | Network connection to server complete. 2026-05-06 20:38:27.130 | SC Data with Depth | Starting socket receive thread. 2026-05-06 20:38:27.130 | SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard 2026-05-06 20:38:37.143 | Starting downloads for all open Historical Daily data charts. 2026-05-06 20:38:37.143 | Added historical Daily data request for XAUUSD to the queue. 2026-05-06 20:38:37.143 | Triggering next historical data download in queue. 2026-05-06 20:38:37.144 | HD Request # 3 | Downloading Historical Daily chart data for XAUUSD. Starting date: 1976-05-18. Service: fxcm 2026-05-06 20:38:37.144 | HD Request # 3 | Using server: ds12.sierracharts.com port 10149 2026-05-06 20:38:37.144 | Socket (7) | Creating socket. 2026-05-06 20:38:37.145 | Socket (7) | New receive buffer size: 0 2026-05-06 20:38:37.145 | Socket (7) | Connecting to IP: 69.39.70.241. 2026-05-06 20:38:47.137 | SC Data with Depth | Did not receive Encoding Response from server. Disconnecting. * 2026-05-06 20:38:47.137 | SC Data with Depth | Waiting for socket receive thread to end 2026-05-06 20:38:47.137 | DTC Client socket (2) | CloseSocket call. 2026-05-06 20:38:47.137 | SC Data with Depth | Disconnected from the server. 2026-05-06 20:38:47.137 | SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. 2026-05-06 20:38:47.138 | DTC Client socket (2) | Shutdown started. Waiting for graceful close. 2026-05-06 20:38:47.485 | HD Request # 3 | Sending historical data logon request message. 2026-05-06 20:38:49.142 | SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 10048 2026-05-06 20:38:49.144 | DTC Client socket (8) | Creating socket. 2026-05-06 20:38:49.144 | DTC Client socket (8) | New receive buffer size: 0 2026-05-06 20:38:49.144 | DTC Client socket (8) | Connecting to IP: 64.152.155.113. 2026-05-06 20:38:49.659 | SC Data with Depth | Network connection to server complete. 2026-05-06 20:38:49.659 | SC Data with Depth | Starting socket receive thread. 2026-05-06 20:38:49.660 | SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard 2026-05-06 20:38:51.079 | DTC Client socket (4) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. * 2026-05-06 20:38:51.079 | DTC Client socket (4) | Socket gracefully closed by remote side. 2026-05-06 20:38:51.079 | DTC Client socket (4) | Closed. 2026-05-06 20:38:54.061 | HD Request # 3 | Setting DTC encoding to Binary VLS 2026-05-06 20:38:54.061 | HD Request # 3 | Sending historical data logon request message. 2026-05-06 20:38:54.061 | Socket (7) | CloseSocket call. 2026-05-06 20:38:54.061 | HD Request # 3 | Error downloading historical Daily data for XAUUSD. Historical data logon error: Unsupported protocol version 2026-05-06 20:38:54.061 | Socket (7) | Write in progress. Shutdown being delayed. PendingSize=0 2026-05-06 20:38:54.061 | Historical data download thread signaled to stop. 2026-05-06 20:38:54.061 | HD Request # 3 | Received 0 Daily data records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for XAUUSD 2026-05-06 20:38:54.061 | HD Request # 3 | Completion time: 17s. 2026-05-06 20:38:54.061 | HD Request # 3 | Daily data download complete for XAUUSD. Unique request ID: 3 2026-05-06 20:38:54.061 | Removing historical data download ID 3. 2026-05-06 20:38:54.061 | 2026-05-06 20:38:54.061 | No download requests in the queue to start downloads for. 2026-05-06 20:38:54.189 | XAUUSD[M] Daily #3 | Reloading chart. 2026-05-06 20:38:54.198 | XAUUSD[M] Daily #3 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\XAUUSD.dly 2026-05-06 20:38:54.199 | XAUUSD[M] Daily #3 | Chart data loading complete. 2026-05-06 20:38:54.371 | Socket (7) | Socket gracefully closed by remote side. 2026-05-06 20:38:54.377 | Socket (7) | Write has completed. Shutdown being performed. 2026-05-06 20:38:54.377 | Socket (7) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2026-05-06 20:38:54.377 | Socket (7) | Closed. 2026-05-06 20:39:09.674 | SC Data with Depth | Did not receive Encoding Response from server. Disconnecting. * 2026-05-06 20:39:09.674 | SC Data with Depth | Waiting for socket receive thread to end 2026-05-06 20:39:09.674 | DTC Client socket (8) | CloseSocket call. 2026-05-06 20:39:09.674 | SC Data with Depth | Disconnected from the server. 2026-05-06 20:39:09.674 | SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. 2026-05-06 20:39:09.674 | DTC Client socket (8) | Shutdown started. Waiting for graceful close. 2026-05-06 20:39:11.678 | SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 443 2026-05-06 20:39:11.679 | DTC Client socket (4) | Creating socket. 2026-05-06 20:39:11.679 | DTC Client socket (4) | New receive buffer size: 0 2026-05-06 20:39:11.679 | DTC Client socket (4) | Connecting to IP: 69.39.70.241. 2026-05-06 20:39:11.982 | SC Data with Depth | Network connection to server complete. 2026-05-06 20:39:11.982 | SC Data with Depth | Starting socket receive thread. 2026-05-06 20:39:11.982 | SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard 2026-05-06 20:39:14.602 | DTC Client socket (5) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. * 2026-05-06 20:39:14.603 | DTC Client socket (5) | Socket gracefully closed by remote side. 2026-05-06 20:39:14.603 | DTC Client socket (5) | Closed. 2026-05-06 20:39:31.990 | SC Data with Depth | Did not receive Encoding Response from server. Disconnecting. * 2026-05-06 20:39:31.990 | SC Data with Depth | Waiting for socket receive thread to end 2026-05-06 20:39:31.990 | DTC Client socket (4) | CloseSocket call. 2026-05-06 20:39:31.990 | DTC Client socket (4) | Shutdown started. Waiting for graceful close. 2026-05-06 20:39:31.990 | SC Data with Depth | Disconnected from the server. 2026-05-06 20:39:31.990 | SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. 2026-05-06 20:39:33.995 | SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 443 2026-05-06 20:39:33.997 | DTC Client socket (5) | Creating socket. 2026-05-06 20:39:33.997 | DTC Client socket (5) | New receive buffer size: 0 2026-05-06 20:39:33.997 | DTC Client socket (5) | Connecting to IP: 64.152.155.113. 2026-05-06 20:39:34.509 | SC Data with Depth | Network connection to server complete. 2026-05-06 20:39:34.509 | SC Data with Depth | Starting socket receive thread. 2026-05-06 20:39:34.509 | SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard 2026-05-06 20:39:36.869 | DTC Client socket (6) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. * 2026-05-06 20:39:36.869 | DTC Client socket (6) | Socket gracefully closed by remote side. 2026-05-06 20:39:36.869 | DTC Client socket (6) | Closed. 2026-05-06 20:39:40.858 | SC Data with Depth | Setting DTC encoding to Binary VLS 2026-05-06 20:39:40.858 | SC Data with Depth | Sending logon request message. 2026-05-06 20:39:40.858 | SC Data with Depth | Server has requested a logoff. Reason: No Logon message received. 2026-05-06 20:39:40.858 | SC Data with Depth | Failed connections: 3 2026-05-06 20:39:40.858 | SC Data with Depth | Waiting for socket receive thread to end 2026-05-06 20:39:40.858 | DTC Client socket (5) | CloseSocket call. 2026-05-06 20:39:40.858 | DTC Client socket (5) | Write in progress. Shutdown being delayed. PendingSize=0 2026-05-06 20:39:40.858 | SC Data with Depth | Disconnected from the server. 2026-05-06 20:39:40.858 | SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. 2026-05-06 20:39:41.267 | DTC Client socket (5) | Socket gracefully closed by remote side. 2026-05-06 20:39:41.267 | DTC Client socket (5) | Write has completed. Shutdown being performed. 2026-05-06 20:39:41.267 | DTC Client socket (5) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2026-05-06 20:39:41.267 | DTC Client socket (5) | Closed. 2026-05-06 20:39:42.868 | SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 443 2026-05-06 20:39:42.870 | DTC Client socket (5) | Creating socket. 2026-05-06 20:39:42.870 | DTC Client socket (5) | New receive buffer size: 0 2026-05-06 20:39:42.870 | DTC Client socket (5) | Connecting to IP: 69.39.70.241. 2026-05-06 20:39:43.213 | SC Data with Depth | Network connection to server complete. 2026-05-06 20:39:43.213 | SC Data with Depth | Starting socket receive thread. 2026-05-06 20:39:43.214 | SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard 2026-05-06 20:40:02.776 | DTC Client socket (1) | Socket gracefully closed by remote side. 2026-05-06 20:40:02.776 | DTC Client socket (1) | Closed. 2026-05-06 20:40:03.230 | SC Data with Depth | Did not receive Encoding Response from server. Disconnecting. * 2026-05-06 20:40:03.230 | SC Data with Depth | Waiting for socket receive thread to end 2026-05-06 20:40:03.231 | DTC Client socket (5) | CloseSocket call. 2026-05-06 20:40:03.231 | DTC Client socket (5) | Shutdown started. Waiting for graceful close. 2026-05-06 20:40:03.231 | SC Data with Depth | Disconnected from the server. 2026-05-06 20:40:03.231 | SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. 2026-05-06 20:40:05.235 | SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 10048 2026-05-06 20:40:05.236 | DTC Client socket (1) | Creating socket. 2026-05-06 20:40:05.237 | DTC Client socket (1) | New receive buffer size: 0 2026-05-06 20:40:05.237 | DTC Client socket (1) | Connecting to IP: 64.152.155.113. 2026-05-06 20:40:05.639 | SC Data with Depth | Network connection to server complete. 2026-05-06 20:40:05.639 | SC Data with Depth | Starting socket receive thread. 2026-05-06 20:40:05.639 | SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard 2026-05-06 20:40:25.227 | DTC Client socket (3) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. * 2026-05-06 20:40:25.227 | DTC Client socket (3) | Socket gracefully closed by remote side. 2026-05-06 20:40:25.227 | DTC Client socket (3) | Closed. 2026-05-06 20:40:25.661 | SC Data with Depth | Did not receive Encoding Response from server. Disconnecting. * 2026-05-06 20:40:25.661 | SC Data with Depth | Waiting for socket receive thread to end 2026-05-06 20:40:25.662 | DTC Client socket (1) | CloseSocket call. 2026-05-06 20:40:25.662 | SC Data with Depth | Disconnected from the server. 2026-05-06 20:40:25.662 | SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. 2026-05-06 20:40:25.662 | DTC Client socket (1) | Shutdown started. Waiting for graceful close. 2026-05-06 20:40:27.673 | SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 10048 2026-05-06 20:40:27.673 | DTC Client socket (3) | Creating socket. 2026-05-06 20:40:27.674 | DTC Client socket (3) | New receive buffer size: 0 2026-05-06 20:40:27.674 | DTC Client socket (3) | Connecting to IP: 69.39.70.241. 2026-05-06 20:40:27.967 | SC Data with Depth | Network connection to server complete. 2026-05-06 20:40:27.967 | SC Data with Depth | Starting socket receive thread. 2026-05-06 20:40:27.967 | SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard 2026-05-06 20:40:47.493 | DTC Client socket (2) | Socket gracefully closed by remote side. 2026-05-06 20:40:47.493 | DTC Client socket (2) | Closed. 2026-05-06 20:40:47.980 | SC Data with Depth | Did not receive Encoding Response from server. Disconnecting. * 2026-05-06 20:40:47.980 | SC Data with Depth | Waiting for socket receive thread to end 2026-05-06 20:40:47.980 | DTC Client socket (3) | CloseSocket call. 2026-05-06 20:40:47.980 | SC Data with Depth | Disconnected from the server. 2026-05-06 20:40:47.980 | SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. 2026-05-06 20:40:47.980 | DTC Client socket (3) | Shutdown started. Waiting for graceful close. 2026-05-06 20:40:49.995 | SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 10048 2026-05-06 20:40:49.997 | DTC Client socket (2) | Creating socket. 2026-05-06 20:40:49.997 | DTC Client socket (2) | New receive buffer size: 0 2026-05-06 20:40:49.997 | DTC Client socket (2) | Connecting to IP: 64.152.155.113. 2026-05-06 20:40:50.491 | SC Data with Depth | Network connection to server complete. 2026-05-06 20:40:50.491 | SC Data with Depth | Starting socket receive thread. 2026-05-06 20:40:50.491 | SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard 2026-05-06 20:41:10.140 | DTC Client socket (8) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. * 2026-05-06 20:41:10.140 | DTC Client socket (8) | Socket gracefully closed by remote side. 2026-05-06 20:41:10.140 | DTC Client socket (8) | Closed. 2026-05-06 20:41:10.500 | SC Data with Depth | Did not receive Encoding Response from server. Disconnecting. * 2026-05-06 20:41:10.500 | SC Data with Depth | Waiting for socket receive thread to end 2026-05-06 20:41:10.500 | DTC Client socket (2) | CloseSocket call. 2026-05-06 20:41:10.500 | SC Data with Depth | Disconnected from the server. 2026-05-06 20:41:10.500 | SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. 2026-05-06 20:41:10.500 | DTC Client socket (2) | Shutdown started. Waiting for graceful close. 2026-05-06 20:41:12.516 | SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 10048 2026-05-06 20:41:12.519 | DTC Client socket (6) | Creating socket. 2026-05-06 20:41:12.519 | DTC Client socket (6) | New receive buffer size: 0 2026-05-06 20:41:12.519 | DTC Client socket (6) | Connecting to IP: 69.39.70.241. 2026-05-06 20:41:12.813 | SC Data with Depth | Network connection to server complete. 2026-05-06 20:41:12.813 | SC Data with Depth | Starting socket receive thread. 2026-05-06 20:41:12.813 | SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard 2026-05-06 20:41:19.734 | SC Data with Depth | Setting DTC encoding to Binary VLS 2026-05-06 20:41:19.734 | SC Data with Depth | Sending logon request message. 2026-05-06 20:41:19.734 | SC Data with Depth | Server has requested a logoff. Reason: No Logon message received. 2026-05-06 20:41:19.734 | SC Data with Depth | Failed connections: 4 2026-05-06 20:41:19.734 | SC Data with Depth | Waiting for socket receive thread to end 2026-05-06 20:41:19.734 | DTC Client socket (6) | CloseSocket call. 2026-05-06 20:41:19.734 | DTC Client socket (6) | Write in progress. Shutdown being delayed. PendingSize=0 2026-05-06 20:41:19.734 | SC Data with Depth | Disconnected from the server. 2026-05-06 20:41:19.734 | SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. 2026-05-06 20:41:20.040 | DTC Client socket (6) | Socket gracefully closed by remote side. 2026-05-06 20:41:20.040 | DTC Client socket (6) | Write has completed. Shutdown being performed. 2026-05-06 20:41:20.040 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2026-05-06 20:41:20.040 | DTC Client socket (6) | Closed. 2026-05-06 20:41:21.760 | SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 443 2026-05-06 20:41:21.765 | DTC Client socket (6) | Creating socket. 2026-05-06 20:41:21.765 | DTC Client socket (6) | New receive buffer size: 0 2026-05-06 20:41:21.765 | DTC Client socket (6) | Connecting to IP: 64.152.155.113. 2026-05-06 20:41:22.520 | SC Data with Depth | Network connection to server complete. 2026-05-06 20:41:22.520 | SC Data with Depth | Starting socket receive thread. 2026-05-06 20:41:22.521 | SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard 2026-05-06 20:41:32.266 | DTC Client socket (4) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. * 2026-05-06 20:41:32.266 | DTC Client socket (4) | Socket gracefully closed by remote side. 2026-05-06 20:41:32.267 | DTC Client socket (4) | Closed. 2026-05-06 20:41:42.525 | SC Data with Depth | Did not receive Encoding Response from server. Disconnecting. * 2026-05-06 20:41:42.525 | SC Data with Depth | Waiting for socket receive thread to end 2026-05-06 20:41:42.526 | DTC Client socket (6) | CloseSocket call. 2026-05-06 20:41:42.526 | SC Data with Depth | Disconnected from the server. 2026-05-06 20:41:42.526 | SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. 2026-05-06 20:41:42.526 | DTC Client socket (6) | Shutdown started. Waiting for graceful close. 2026-05-06 20:41:44.533 | SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 10048 2026-05-06 20:41:44.535 | DTC Client socket (4) | Creating socket. 2026-05-06 20:41:44.535 | DTC Client socket (4) | New receive buffer size: 0 2026-05-06 20:41:44.535 | DTC Client socket (4) | Connecting to IP: 69.39.70.241. 2026-05-06 20:41:44.762 | SC Data with Depth | Network connection to server complete. 2026-05-06 20:41:44.762 | SC Data with Depth | Starting socket receive thread. 2026-05-06 20:41:44.763 | SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard 2026-05-06 20:42:03.498 | DTC Client socket (5) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. * 2026-05-06 20:42:03.498 | DTC Client socket (5) | Socket gracefully closed by remote side. 2026-05-06 20:42:03.498 | DTC Client socket (5) | Closed. 2026-05-06 20:42:04.773 | SC Data with Depth | Did not receive Encoding Response from server. Disconnecting. * 2026-05-06 20:42:04.773 | SC Data with Depth | Waiting for socket receive thread to end 2026-05-06 20:42:04.774 | DTC Client socket (4) | CloseSocket call. 2026-05-06 20:42:04.774 | SC Data with Depth | Disconnected from the server. 2026-05-06 20:42:04.774 | SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. 2026-05-06 20:42:04.774 | DTC Client socket (4) | Shutdown started. Waiting for graceful close. 2026-05-06 20:42:06.786 | SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 10048 2026-05-06 20:42:06.788 | DTC Client socket (5) | Creating socket. 2026-05-06 20:42:06.788 | DTC Client socket (5) | New receive buffer size: 0 2026-05-06 20:42:06.788 | DTC Client socket (5) | Connecting to IP: 64.152.155.113. 2026-05-06 20:42:07.290 | SC Data with Depth | Network connection to server complete. 2026-05-06 20:42:07.290 | SC Data with Depth | Starting socket receive thread. 2026-05-06 20:42:07.290 | SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard 2026-05-06 20:42:25.968 | DTC Client socket (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. * 2026-05-06 20:42:25.968 | DTC Client socket (1) | Socket gracefully closed by remote side. 2026-05-06 20:42:25.968 | DTC Client socket (1) | Closed. 2026-05-06 20:42:27.295 | SC Data with Depth | Did not receive Encoding Response from server. Disconnecting. * 2026-05-06 20:42:27.295 | SC Data with Depth | Waiting for socket receive thread to end 2026-05-06 20:42:27.295 | DTC Client socket (5) | CloseSocket call. 2026-05-06 20:42:27.295 | SC Data with Depth | Disconnected from the server. 2026-05-06 20:42:27.295 | SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. 2026-05-06 20:42:27.295 | DTC Client socket (5) | Shutdown started. Waiting for graceful close. 2026-05-06 20:42:29.298 | SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 10048 2026-05-06 20:42:29.303 | DTC Client socket (1) | Creating socket. 2026-05-06 20:42:29.303 | DTC Client socket (1) | New receive buffer size: 0 2026-05-06 20:42:29.303 | DTC Client socket (1) | Connecting to IP: 69.39.70.241. 2026-05-06 20:42:29.537 | SC Data with Depth | Network connection to server complete. 2026-05-06 20:42:29.537 | SC Data with Depth | Starting socket receive thread. 2026-05-06 20:42:29.537 | SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard 2026-05-06 20:42:39.368 | SC Data with Depth | Setting DTC encoding to Binary VLS 2026-05-06 20:42:39.368 | SC Data with Depth | Sending logon request message. 2026-05-06 20:42:39.369 | SC Data with Depth | Server has requested a logoff. Reason: No Logon message received. 2026-05-06 20:42:39.369 | SC Data with Depth | Failed connections: 5 2026-05-06 20:42:39.369 | SC Data with Depth | Waiting for socket receive thread to end 2026-05-06 20:42:39.370 | DTC Client socket (1) | CloseSocket call. 2026-05-06 20:42:39.370 | DTC Client socket (1) | Write in progress. Shutdown being delayed. PendingSize=0 2026-05-06 20:42:39.370 | SC Data with Depth | Disconnected from the server. 2026-05-06 20:42:39.370 | SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. 2026-05-06 20:42:39.617 | DTC Client socket (1) | Socket gracefully closed by remote side. 2026-05-06 20:42:39.648 | DTC Client socket (1) | Write has completed. Shutdown being performed. 2026-05-06 20:42:39.649 | DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2026-05-06 20:42:39.649 | DTC Client socket (1) | Closed. 2026-05-06 20:42:41.386 | SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 443 2026-05-06 20:42:41.387 | DTC Client socket (1) | Creating socket. 2026-05-06 20:42:41.387 | DTC Client socket (1) | New receive buffer size: 0 2026-05-06 20:42:41.387 | DTC Client socket (1) | Connecting to IP: 64.152.155.113. 2026-05-06 20:42:41.804 | SC Data with Depth | Network connection to server complete. 2026-05-06 20:42:41.804 | SC Data with Depth | Starting socket receive thread. 2026-05-06 20:42:41.804 | SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard 2026-05-06 20:42:48.249 | DTC Client socket (3) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. * 2026-05-06 20:42:48.249 | DTC Client socket (3) | Socket gracefully closed by remote side. 2026-05-06 20:42:48.249 | DTC Client socket (3) | Closed. 2026-05-06 20:43:01.811 | SC Data with Depth | Did not receive Encoding Response from server. Disconnecting. * 2026-05-06 20:43:01.811 | SC Data with Depth | Waiting for socket receive thread to end 2026-05-06 20:43:01.812 | DTC Client socket (1) | CloseSocket call. 2026-05-06 20:43:01.812 | SC Data with Depth | Disconnected from the server. 2026-05-06 20:43:01.812 | SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. 2026-05-06 20:43:01.812 | DTC Client socket (1) | Shutdown started. Waiting for graceful close. 2026-05-06 20:43:03.819 | SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 10048 2026-05-06 20:43:03.820 | DTC Client socket (3) | Creating socket. 2026-05-06 20:43:03.821 | DTC Client socket (3) | New receive buffer size: 0 2026-05-06 20:43:03.821 | DTC Client socket (3) | Connecting to IP: 69.39.70.241. 2026-05-06 20:43:04.065 | SC Data with Depth | Network connection to server complete. 2026-05-06 20:43:04.065 | SC Data with Depth | Starting socket receive thread. 2026-05-06 20:43:04.065 | SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard 2026-05-06 20:43:10.969 | DTC Client socket (2) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. * 2026-05-06 20:43:10.969 | DTC Client socket (2) | Socket gracefully closed by remote side. 2026-05-06 20:43:10.969 | DTC Client socket (2) | Closed. 2026-05-06 20:43:24.084 | SC Data with Depth | Did not receive Encoding Response from server. Disconnecting. * 2026-05-06 20:43:24.084 | SC Data with Depth | Waiting for socket receive thread to end 2026-05-06 20:43:24.085 | DTC Client socket (3) | CloseSocket call. 2026-05-06 20:43:24.085 | SC Data with Depth | Disconnected from the server. 2026-05-06 20:43:24.085 | SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. 2026-05-06 20:43:24.085 | DTC Client socket (3) | Shutdown started. Waiting for graceful close. 2026-05-06 20:43:26.092 | SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 443 2026-05-06 20:43:26.093 | DTC Client socket (2) | Creating socket. 2026-05-06 20:43:26.094 | DTC Client socket (2) | New receive buffer size: 0 2026-05-06 20:43:26.094 | DTC Client socket (2) | Connecting to IP: 64.152.155.113. 2026-05-06 20:43:26.443 | SC Data with Depth | Network connection to server complete. 2026-05-06 20:43:26.443 | SC Data with Depth | Starting socket receive thread. 2026-05-06 20:43:26.444 | SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard 2026-05-06 20:43:43.025 | DTC Client socket (6) | Socket gracefully closed by remote side. 2026-05-06 20:43:43.026 | DTC Client socket (6) | Closed. 2026-05-06 20:43:46.452 | SC Data with Depth | Did not receive Encoding Response from server. Disconnecting. * 2026-05-06 20:43:46.452 | SC Data with Depth | Waiting for socket receive thread to end 2026-05-06 20:43:46.453 | DTC Client socket (2) | CloseSocket call. 2026-05-06 20:43:46.453 | SC Data with Depth | Disconnected from the server. 2026-05-06 20:43:46.453 | SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. 2026-05-06 20:43:46.453 | DTC Client socket (2) | Shutdown started. Waiting for graceful close. 2026-05-06 20:43:48.455 | SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 443 2026-05-06 20:43:48.458 | DTC Client socket (6) | Creating socket. 2026-05-06 20:43:48.458 | DTC Client socket (6) | New receive buffer size: 0 2026-05-06 20:43:48.458 | DTC Client socket (6) | Connecting to IP: 69.39.70.241. 2026-05-06 20:43:48.785 | SC Data with Depth | Network connection to server complete. 2026-05-06 20:43:48.785 | SC Data with Depth | Starting socket receive thread. 2026-05-06 20:43:48.785 | SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard 2026-05-06 20:44:05.039 | DTC Client socket (4) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. * 2026-05-06 20:44:05.040 | DTC Client socket (4) | Socket gracefully closed by remote side. 2026-05-06 20:44:05.040 | DTC Client socket (4) | Closed. 2026-05-06 20:44:08.794 | SC Data with Depth | Did not receive Encoding Response from server. Disconnecting. * 2026-05-06 20:44:08.794 | SC Data with Depth | Waiting for socket receive thread to end 2026-05-06 20:44:08.795 | DTC Client socket (6) | CloseSocket call. 2026-05-06 20:44:08.795 | SC Data with Depth | Disconnected from the server. 2026-05-06 20:44:08.795 | SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. 2026-05-06 20:44:08.795 | DTC Client socket (6) | Shutdown started. Waiting for graceful close. 2026-05-06 20:44:10.819 | SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 10048 2026-05-06 20:44:10.821 | DTC Client socket (4) | Creating socket. 2026-05-06 20:44:10.821 | DTC Client socket (4) | New receive buffer size: 0 2026-05-06 20:44:10.821 | DTC Client socket (4) | Connecting to IP: 64.152.155.113. 2026-05-06 20:44:11.193 | SC Data with Depth | Network connection to server complete. 2026-05-06 20:44:11.193 | SC Data with Depth | Starting socket receive thread. 2026-05-06 20:44:11.193 | SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard |
| [2026-05-06 20:51:22] |
You are having a connectivity issue. You are not able to connect to our data servers to get the data. Refer to the following: Data/Trading Service Connection and Symbol Issues: 1.2. Network Communication or Server Problem For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
