Date/Time: Tue, 10 Nov 2026 17:33:07 +0000
Native NYMEX calendar spread position/PnL display with Teton/Sierra Chart simulator
View Count: 429
[2026-04-28 16:23:00]
User445870 - Posts: 5
Hello Sierra Chart Support,
I am evaluating Sierra Chart with Teton order routing through EdgeClear for trading native exchange-listed NYMEX energy calendar spreads.
My main concern is position reporting and floating PnL display for native calendar spreads.
I previously tested native crude oil calendar spreads in another platform/environment, and the active position appeared to be counted both as the native spread and as individual outright legs. This caused the floating PnL/risk display to look duplicated or overstated while the spread was open, even though the closed trade later appeared as a spread trade.
I want to avoid that behavior.
Could you please clarify the following for Sierra Chart + Teton:
1. For native exchange-listed NYMEX calendar spreads such as CLV26-CLX26, CLQ26-CLU26, NG calendar spreads, RB calendar spreads, and HO calendar spreads, does Sierra Chart display the active position as one native spread position, or does it also display the outright legs separately?
2. In the Trade Positions window and Trade Activity Log, will the floating PnL be based on the native spread position only, or can it show both the spread and the individual legs at the same time?
3. Does Sierra Chart’s internal trade simulator correctly simulate native exchange-listed calendar spread order entry, position display, and floating PnL when live market data is enabled?
4. What is the correct Sierra Chart symbol format for standard NYMEX crude oil calendar spreads, for example CLV26-CLX26? Also, what is the correct format for NG, RB, and HO calendar spreads?
5. Are there any Sierra Chart settings needed to ensure native exchange-listed spreads are displayed and simulated correctly?
6. If the broker uses Teton, does the broker need to enable each calendar spread symbol individually, or can all NYMEX energy calendar spreads be enabled through a broader account/template setting?
My goal is to trade the native exchange calendar spread itself, not synthetic outright legs, and to ensure that position display and floating PnL do not double-count the spread and legs.
Thank you.
[2026-04-29 14:40:48]
Sierra_Chart Engineering - Posts: 25407
All of your questions are answered in this section here:
Trade Account and Risk Management: Trading Spreads and Position Reporting for Spreads
Let us know if you have any other questions.
You can do testing using the Trading Evaluator-Delayed service:
Simulated Futures Trading Service
This is not a problem:
Date Time Of Last Edit: 2026-04-29 14:46:43
[2026-05-06 03:47:03]
Thank you. In the trading evaluator, I was able to use the Find Symbol then search (it was not listed) to find native spread like CLZ26-CLF27.FUT_SPREAD.NYMEX. Could you tell me how to search for a native butterfly?
[2026-05-06 13:20:42]
John - SC Support - Posts: 48483
You use the same process to do a search for spreads. The butterflys should be showing in the list of results.
[2026-05-06 20:20:33]
Sierra (DTC) returns a minimal SecurityDefinitionResponse for
CLM26-2*CLN26+CLQ26.FUT_SPREAD.NYMEX,
but it lacks MinPriceIncrement, CurrencyValuePerIncrement, SecurityExpirationDate, and Description.
Fake spread strings return no definition.
Trading Evaluator rejects the CL butterfly with “Symbol is unknown for trading.”
Is this native 1x2x1 CL butterfly intended to be tradable through Sierra/Teton, or is it only partially parsed but not supported for order routing/account simulation?
[2026-05-06 20:34:39]
We are not understanding where you are getting the symbol that you list.
The only butterfly that we can find in the list of symbols for those contracts is the following:
CL:BF M26-N26-Q26.FUT_SPREAD.NYMEX
We do not see a 1x2x1 native spread listed in what we retrieve for the list of spreads.
[2026-05-06 21:15:25]
Hello John,
Thank you for the earlier guidance.
I can now load and trade native NYMEX CL calendar spread symbols in Trading Evaluator - Delayed, for example:
`CLZ26-CLF27.FUT_SPREAD.NYMEX`
For those calendar spreads, DTC order entry works, account margin/P&L updates in the Trading Evaluator account, and the DOM/chart works.
However, for native CL butterfly-style symbols such as:
`CL:BF M26-N26-Q26.FUT_SPREAD.NYMEX`
or similar CL butterfly expressions, Sierra allows the symbol to be selected/typed, but the chart/DOM cannot load and I see messages such as:
`Symbol settings not found for current service`
and
`Service client does not support market data subscriptions`
Also, DTC security definition responses for these butterfly expressions are minimal and do not include fields such as MinPriceIncrement, CurrencyValuePerIncrement, Description, or SecurityExpirationDate.
Could you please clarify:
1. Are CL butterflies unavailable in Trading Evaluator - Delayed but available through a live Teton/Denali broker connection?
2. If native CL butterflies cannot be charted, can they still be traded through DTC/Teton, or should they be considered unsupported?
3. For automation, should I restrict Sierra/DTC trading to native calendar spreads only unless a butterfly symbol returns full symbol settings and full security definition fields?
[2026-05-07 21:48:38]
Give us a chance to follow-up.
[2026-05-12 02:35:29]
There is no support, for trading these types of spreads either live or using the Trading Evaluator.
It is a fair amount of work for us to determine what the issue is with this.
Will not be tradable with either.
They need to be considered unsupported.
Yes calendar spreads only.
Date Time Of Last Edit: 2026-05-12 02:36:46
