Date/Time: Tue, 27 Oct 2026 17:54:03 +0000
Market Data
View Count: 505
| [2026-04-16 12:26:59] |
| User317915 - Posts: 6 |
Please kindly tell me if I have market data. I have set up with AMP but I cannot get market data.
| [2026-04-16 12:57:21] |
| Sierra_Chart Engineering - Posts: 25297 |
Your Sierra Chart account is set up, to receive real-time market data for the full CME Group. Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Close all of the Chartbooks with "File >> Close All Chartbooks". Open a single chart for the symbol you have an issue with through "File >> Find Symbol". Tell us that symbol of the chart. Tell us about *one* symbol only. Disconnect from the data feed with "File >> Disconnect". Connect to the data feed with "File >> Connect to Data Feed". After the connection and after about 10 seconds, provide a copy of the Message Log following these instructions: Support Board Posting Information: How to Post Your Message Log (Required In Some Cases) We will then determine what the problem is. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-04-21 14:00:58] |
2026-04-15 03:34:12.282 | Trade activity files set size: 266 2026-04-15 03:34:12.459 | Reading Internal Order ID file. 2026-04-15 03:34:12.480 | Reading Trade Orders file. 2026-04-15 03:34:12.491 | Reading Trade Positions file. 2026-04-15 03:34:12.500 | Reading Trade Account Data files. 2026-04-15 03:34:12.503 | Software version: 2761 64-bit 2026-04-15 03:34:12.503 | Primary Thread ID: 11208 2026-04-15 03:34:12.503 | Usage end date: 2026-05-05 2026-04-15 03:34:12.503 | Enabled for: Advanced Features 2. 2026-04-15 03:34:12.503 | Enabled for: Sierra Chart Historical Data Service. 2026-04-15 03:34:12.503 | Enabled for: Denali Real-Time Exchange Data Feed. 2026-04-15 03:34:12.503 | Enabled for: Delayed Denali Exchange Data Feed. 2026-04-15 03:34:12.503 | Enabled for exchange2: CME (Trading Account Required) 2026-04-15 03:34:12.503 | Enabled for exchange2: CBOT (Trading Account Required) 2026-04-15 03:34:12.503 | Enabled for exchange2: COMEX (Trading Account Required) 2026-04-15 03:34:12.503 | Enabled for exchange2: NYMEX (Trading Account Required) 2026-04-15 03:34:12.503 | Allow Support for Sierra Chart Data Feeds is enabled. 2026-04-15 03:34:12.503 | Current selected Data/Trading service: CQG WebAPI 2026-04-15 03:34:12.503 | Custom symbol settings values: enabled 2026-04-15 03:34:12.503 | Chart Update Interval: 400 2026-04-15 03:34:12.503 | Intraday Data Storage Time Unit: 0 2026-04-15 03:34:12.503 | Time Zone: -04:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) 2026-04-15 03:34:12.503 | 2026-04-15 07:34:12 Local computer time in UTC 2026-04-15 03:34:12.503 | 2026-04-15 03:34:12 Local computer time in SC Time Zone 2026-04-15 03:34:12.503 | 2026-04-15 07:34:15 Server time in UTC 2026-04-15 03:34:12.503 | Local computer UTC time and Server UTC time difference: 7 seconds. 2026-04-15 03:34:12.503 | Notice: Your computer's clock is off by 7 seconds. Set the 'Global Settings >> NTP Settings >> NTP Client Enable' to 'Yes'. 2026-04-15 03:34:12.503 | Program path: C:\SierraChart\ 2026-04-15 03:34:12.503 | Data Files path: C:\SierraChart\Data\ 2026-04-15 03:34:12.503 | OS Version Number: 10.0 2026-04-15 03:34:12.503 | Locale Setting: C 2026-04-15 03:34:12.509 | DLLs: UserContributedStudies_64.dll 2026-04-15 03:34:12.509 | Allowed protected custom studies: 2026-04-15 03:34:12.509 | Crash reporter started: true 2026-04-15 03:34:12.509 | 2026-04-15 03:34:12.539 | Checking for new symbol settings. Requested symbol settings MD5 for service code cqg. Request ID: 1. 2026-04-15 03:34:12.580 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. 2026-04-15 03:34:12.668 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. 2026-04-15 03:34:12.668 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed. 2026-04-15 03:34:12.820 | Received 5 login tokens. 2026-04-15 03:34:13.006 | Symbol settings MD5 received. Request ID: 1. 2026-04-15 03:34:13.006 | Requested symbol settings for service code cqg. Request ID: 2. 2026-04-15 03:34:13.713 | Symbol settings received. Request ID: 2. 2026-04-15 03:34:15.040 | Requested user files to download. 2026-04-15 03:34:17.043 | 2026-04-15 03:34:17.046 | CQG WebAPI | Connecting to server api.cqg.com 2026-04-15 03:34:17.046 | CQG WebSocket | Connecting to WebSocket server api.cqg.com:443 2026-04-15 03:34:17.261 | CQG WebSocket socket (1) | Creating socket. Using TLS 1.2. 2026-04-15 03:34:17.262 | CQG WebSocket socket (1) | New receive buffer size: 0 2026-04-15 03:34:17.262 | CQG WebSocket socket (1) | Connecting to IP: 195.166.124.175. 2026-04-15 03:34:17.283 | CQG WebSocket | Opening WebSocket. 2026-04-15 03:34:17.283 | CQG WebSocket | Sending WebSocket handshake. 2026-04-15 03:34:17.349 | CQG WebSocket | Server header | HTTP/1.1 101 Switching Protocols 2026-04-15 03:34:17.349 | CQG WebSocket | Server header | Connection: Upgrade 2026-04-15 03:34:17.349 | CQG WebSocket | Server header | Sec-WebSocket-Accept: JGSIK8BiEJw0hfMIfW9qN6c+4Y8= 2026-04-15 03:34:17.349 | CQG WebSocket | Server header | Server: WebSocket++/0.8.2 2026-04-15 03:34:17.349 | CQG WebSocket | Server header | Upgrade: websocket 2026-04-15 03:34:17.349 | CQG WebSocket | Server header | 2026-04-15 03:34:17.349 | CQG WebSocket | Web socket state is now open. 2026-04-15 03:34:17.350 | CQG WebAPI | WebSocket connected. 2026-04-15 03:34:17.350 | CQG WebAPI | Sending market data logon message. 2026-04-15 03:34:17.589 | CQG WebAPI | Base Time: 2026-03-28T06:33:36. 2026-03-28 06:33:36 2026-04-15 03:34:17.589 | CQG WebAPI | Logon successful. Session Token = op7cY7fLooRHCRkoat/VL1LD+QoOrEsDFV58LllocF4zFAIxunPligR37bVlyTlATpB4eX2dLtk 2026-04-15 03:34:17.589 | CQG WebAPI | Connection to server complete. 2026-04-15 03:34:17.591 | No download requests in the queue to start downloads for. | Number times message added: 3 2026-04-15 03:34:17.594 | Updated verified funded futures trading account ending date to: 2026-05-15 07:34:17 2026-04-15 03:34:17.594 | CQG WebAPI | Sending Trade Accounts request message. 2026-04-15 03:34:17.734 | CQG WebAPI | Brokerage name: AMP. Account Name: 220033 2026-04-15 03:34:17.734 | Updated verified funded futures trading account ending date to: 2026-05-15 07:34:17 2026-04-15 03:34:17.734 | CQG WebAPI | Sending collateral subscribe request. 2026-04-15 03:34:17.841 | CQG WebAPI | Sending positions subscribe request. RequestID: 431146 2026-04-15 03:34:17.842 | CQG WebAPI | Sending orders subscribe request. RequestID: 431147 2026-04-15 03:34:20.280 | Files to Open on Startup | Opening file: ExampleChartbook.cht 2026-04-15 03:34:37.740 | ExtendTheFundedTradingAccountStatusExpirationDate: Sending request. 2026-04-15 03:34:38.167 | ExtendTheFundedTradingAccountStatusExpirationDate | Result: {"Result":"The Funded Trading Account Status Expiration Date is more than 25 days into the future. The Date is currently: 2026-05-13"}. Success=true 2026-04-15 04:00:36.355 | 6BU25-CME [CBV] #2 | Reloading chart. 2026-04-15 04:00:36.355 | 6BU25-CME [CBV] #2 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. 2026-04-15 04:00:36.355 | 6BU25-CME [CBV] #2 | There are no continuous futures contract symbols. Loading data normally. 2026-04-15 04:00:36.423 | ESU25-CME [CBV] 7500 Volume #3 | Reloading chart. 2026-04-15 04:00:36.423 | ESU25-CME [CBV] 7500 Volume #3 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. 2026-04-15 04:00:36.423 | ESU25-CME [CBV] 7500 Volume #3 | There are no continuous futures contract symbols. Loading data normally. 2026-04-15 04:00:36.493 | ESU25-CME [CBV] #10 | Reloading chart. 2026-04-15 04:00:36.493 | ESU25-CME [CBV] #10 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. 2026-04-15 04:00:36.493 | ESU25-CME [CBV] #10 | There are no continuous futures contract symbols. Loading data normally. 2026-04-15 04:00:36.568 | CLV25-NYMEX [CBV] #11 | Reloading chart. 2026-04-15 04:00:36.568 | CLV25-NYMEX [CBV] #11 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. 2026-04-15 04:00:36.568 | CLV25-NYMEX [CBV] #11 | There are no continuous futures contract symbols. Loading data normally. 2026-04-15 04:00:36.640 | ESU25-CME [CBV] #1 | Reloading chart. 2026-04-15 04:00:36.640 | ESU25-CME [CBV] #1 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. 2026-04-15 04:00:36.640 | ESU25-CME [CBV] #1 | There are no continuous futures contract symbols. Loading data normally. 2026-04-15 04:00:36.706 | CLV25-NYMEX [CBV] 2000 Volume #4 | Reloading chart. 2026-04-15 04:00:36.706 | CLV25-NYMEX [CBV] 2000 Volume #4 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. 2026-04-15 04:00:36.706 | CLV25-NYMEX [CBV] 2000 Volume #4 | There are no continuous futures contract symbols. Loading data normally. 2026-04-15 04:00:36.789 | ESU25-CME [CBV] 5000 Volume #7 | Reloading chart. 2026-04-15 04:00:36.789 | ESU25-CME [CBV] 5000 Volume #7 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. 2026-04-15 04:00:36.789 | ESU25-CME [CBV] 5000 Volume #7 | There are no continuous futures contract symbols. Loading data normally. 2026-04-15 04:00:36.858 | 6BU25-CME [CBV] 2000 Volume #5 | Reloading chart. 2026-04-15 04:00:36.858 | 6BU25-CME [CBV] 2000 Volume #5 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. 2026-04-15 04:00:36.858 | 6BU25-CME [CBV] 2000 Volume #5 | There are no continuous futures contract symbols. Loading data normally. 2026-04-15 04:00:37.140 | ESU25-CME #8 | Reloading chart. 2026-04-15 04:00:37.156 | ESU25-CME #8 | StartDateTimeForLoadingOrderFills: 00:00:00 2026-04-15 04:00:37.182 | ESU25-CME #8 | Chart data loading complete. 2026-04-15 04:00:37.378 | CLV25-NYMEX #15 | Reloading chart. 2026-04-15 04:00:37.378 | CLV25-NYMEX #15 | StartDateTimeForLoadingOrderFills: 00:00:00 2026-04-15 04:00:37.379 | CLV25-NYMEX #15 | Chart data loading complete. 2026-04-15 04:00:37.407 | Using symbol data fast lookup vector 2026-04-15 04:00:37.409 | CQG WebAPI | Starting real-time market data updates for: ESH23-CME. ID: 1 2026-04-15 04:00:37.410 | CQG WebAPI | Sending symbol resolution request for ESH23-CME. ID: 431148 2026-04-15 04:00:37.410 | CQG WebAPI | Requesting security definition data for: ESH23-CME. ID: 1 2026-04-15 04:00:37.411 | CQG WebAPI | Starting real-time market data updates for: ESM23-CME. ID: 2 2026-04-15 04:00:37.412 | CQG WebAPI | Sending symbol resolution request for ESM23-CME. ID: 431149 2026-04-15 04:00:37.412 | CQG WebAPI | Requesting security definition data for: ESM23-CME. ID: 2 2026-04-15 04:00:37.412 | CQG WebAPI | Starting real-time market data updates for: ESU23-CME. ID: 3 2026-04-15 04:00:37.412 | CQG WebAPI | Sending symbol resolution request for ESU23-CME. ID: 431150 2026-04-15 04:00:37.412 | CQG WebAPI | Requesting security definition data for: ESU23-CME. ID: 3 2026-04-15 04:00:37.412 | CQG WebAPI | Starting real-time market data updates for: ESZ23-CME. ID: 4 2026-04-15 04:00:37.412 | CQG WebAPI | Sending symbol resolution request for ESZ23-CME. ID: 431151 2026-04-15 04:00:37.412 | CQG WebAPI | Requesting security definition data for: ESZ23-CME. ID: 4 2026-04-15 04:00:37.412 | CQG WebAPI | Starting real-time market data updates for: ESH24-CME. ID: 5 2026-04-15 04:00:37.412 | CQG WebAPI | Sending symbol resolution request for ESH24-CME. ID: 431152 2026-04-15 04:00:37.412 | CQG WebAPI | Requesting security definition data for: ESH24-CME. ID: 5 2026-04-15 04:00:37.412 | CQG WebAPI | Starting real-time market data updates for: CLF23-NYMEX. ID: 6 2026-04-15 04:00:37.412 | CQG WebAPI | Sending symbol resolution request for CLF23-NYMEX. ID: 431153 2026-04-15 04:00:37.412 | CQG WebAPI | Requesting security definition data for: CLF23-NYMEX. ID: 6 2026-04-15 04:00:37.413 | CQG WebAPI | Starting real-time market data updates for: CLG23-NYMEX. ID: 7 2026-04-15 04:00:37.413 | CQG WebAPI | Sending symbol resolution request for CLG23-NYMEX. ID: 431154 2026-04-15 04:00:37.413 | CQG WebAPI | Requesting security definition data for: CLG23-NYMEX. ID: 7 2026-04-15 04:00:37.413 | CQG WebAPI | Starting real-time market data updates for: CLH23-NYMEX. ID: 8 2026-04-15 04:00:37.413 | CQG WebAPI | Sending symbol resolution request for CLH23-NYMEX. ID: 431155 2026-04-15 04:00:37.413 | CQG WebAPI | Requesting security definition data for: CLH23-NYMEX. ID: 8 2026-04-15 04:00:37.414 | CQG WebAPI | Starting real-time market data updates for: CLJ23-NYMEX. ID: 9 2026-04-15 04:00:37.414 | CQG WebAPI | Sending symbol resolution request for CLJ23-NYMEX. ID: 431156 2026-04-15 04:00:37.414 | CQG WebAPI | Requesting security definition data for: CLJ23-NYMEX. ID: 9 2026-04-15 04:00:37.414 | CQG WebAPI | Starting real-time market data updates for: CLK23-NYMEX. ID: 10 2026-04-15 04:00:37.414 | CQG WebAPI | Sending symbol resolution request for CLK23-NYMEX. ID: 431157 2026-04-15 04:00:37.414 | CQG WebAPI | Requesting security definition data for: CLK23-NYMEX. ID: 10 2026-04-15 04:00:37.414 | CQG WebAPI | Starting real-time market data updates for: CLM23-NYMEX. ID: 11 2026-04-15 04:00:37.414 | CQG WebAPI | Sending symbol resolution request for CLM23-NYMEX. ID: 431158 2026-04-15 04:00:37.414 | CQG WebAPI | Requesting security definition data for: CLM23-NYMEX. ID: 11 2026-04-15 04:00:37.414 | CQG WebAPI | Starting real-time market data updates for: CLN23-NYMEX. ID: 12 2026-04-15 04:00:37.414 | CQG WebAPI | Sending symbol resolution request for CLN23-NYMEX. ID: 431159 2026-04-15 04:00:37.414 | CQG WebAPI | Requesting security definition data for: CLN23-NYMEX. ID: 12 2026-04-15 04:00:37.415 | CQG WebAPI | Starting real-time market data updates for: CLQ23-NYMEX. ID: 13 2026-04-15 04:00:37.415 | CQG WebAPI | Sending symbol resolution request for CLQ23-NYMEX. ID: 431160 2026-04-15 04:00:37.415 | CQG WebAPI | Requesting security definition data for: CLQ23-NYMEX. ID: 13 2026-04-15 04:00:37.415 | CQG WebAPI | Starting real-time market data updates for: CLU23-NYMEX. ID: 14 2026-04-15 04:00:37.415 | CQG WebAPI | Sending symbol resolution request for CLU23-NYMEX. ID: 431161 2026-04-15 04:00:37.415 | CQG WebAPI | Requesting security definition data for: CLU23-NYMEX. ID: 14 2026-04-15 04:00:37.415 | CQG WebAPI | Starting real-time market data updates for: CLV23-NYMEX. ID: 15 2026-04-15 04:00:37.415 | CQG WebAPI | Sending symbol resolution request for CLV23-NYMEX. ID: 431162 2026-04-15 04:00:37.415 | CQG WebAPI | Requesting security definition data for: CLV23-NYMEX. ID: 15 2026-04-15 04:00:37.415 | CQG WebAPI | Starting real-time market data updates for: CLX23-NYMEX. ID: 16 2026-04-15 04:00:37.415 | CQG WebAPI | Sending symbol resolution request for CLX23-NYMEX. ID: 431163 2026-04-15 04:00:37.415 | CQG WebAPI | Requesting security definition data for: CLX23-NYMEX. ID: 16 2026-04-15 04:00:37.415 | CQG WebAPI | Starting real-time market data updates for: CLZ23-NYMEX. ID: 17 2026-04-15 04:00:37.415 | CQG WebAPI | Sending symbol resolution request for CLZ23-NYMEX. ID: 431164 2026-04-15 04:00:37.415 | CQG WebAPI | Requesting security definition data for: CLZ23-NYMEX. ID: 17 2026-04-15 04:00:37.416 | CQG WebAPI | Starting real-time market data updates for: CLF24-NYMEX. ID: 18 2026-04-15 04:00:37.416 | CQG WebAPI | Sending symbol resolution request for CLF24-NYMEX. ID: 431165 2026-04-15 04:00:37.416 | CQG WebAPI | Requesting security definition data for: CLF24-NYMEX. ID: 18 2026-04-15 04:00:37.416 | CQG WebAPI | Starting real-time market data updates for: CLG24-NYMEX. ID: 19 2026-04-15 04:00:37.416 | CQG WebAPI | Sending symbol resolution request for CLG24-NYMEX. ID: 431166 2026-04-15 04:00:37.416 | CQG WebAPI | Requesting security definition data for: CLG24-NYMEX. ID: 19 2026-04-15 04:00:37.442 | 6BU25-CME [CBV-D] #2 | StartDateTimeForLoadingOrderFills: 00:00:00 2026-04-15 04:00:37.470 | 6BU25-CME [CBV-D] #2 | Chart data loading complete. 2026-04-15 04:00:37.498 | CLV25-NYMEX [CBV-D] 2000 Volume #4 | Chart data loading complete. 2026-04-15 04:00:37.520 | CLV25-NYMEX [CBV-D] #11 | Chart data loading complete. 2026-04-15 04:00:37.571 | CQG WebAPI | Received message: Requested symbol was not found. 2026-04-15 04:00:37.571 | Symbol Error | ESH23-CME is unknown, unavailable, or improperly formatted. Requested symbol was not found. 2026-04-15 04:00:37.572 | CQG WebAPI | Received message: Requested symbol was not found. 2026-04-15 04:00:37.572 | Symbol Error | ESM23-CME is unknown, unavailable, or improperly formatted. Requested symbol was not found. 2026-04-15 04:00:37.572 | CQG WebAPI | Received message: Requested symbol was not found. 2026-04-15 04:00:37.572 | Symbol Error | ESU23-CME is unknown, unavailable, or improperly formatted. Requested symbol was not found. 2026-04-15 04:00:37.572 | CQG WebAPI | Received message: Requested symbol was not found. 2026-04-15 04:00:37.572 | Symbol Error | ESH24-CME is unknown, unavailable, or improperly formatted. Requested symbol was not found. 2026-04-15 04:00:37.572 | CQG WebAPI | Received message: Requested symbol was not found. 2026-04-15 04:00:37.572 | Symbol Error | CLF23-NYMEX is unknown, unavailable, or improperly formatted. Requested symbol was not found. 2026-04-15 04:00:37.572 | CQG WebAPI | Received message: Requested symbol was not found. 2026-04-15 04:00:37.572 | Symbol Error | ESZ23-CME is unknown, unavailable, or improperly formatted. Requested symbol was not found. 2026-04-15 04:00:37.585 | CQG WebAPI | Starting real-time market data updates for: 6BU25-CME. ID: 20 2026-04-15 04:00:37.585 | CQG WebAPI | Sending symbol resolution request for 6BU25-CME. ID: 431167 2026-04-15 04:00:37.585 | CQG WebAPI | Requesting security definition data for: 6BU25-CME. ID: 20 2026-04-15 04:00:37.586 | CQG WebAPI | Using primary service for historical data for 6BU25-CME 2026-04-15 04:00:37.586 | Starting DelayedDownloadMonitoringTimer 2026-04-15 04:00:37.586 | Starting HDTimeoutTimer 2026-04-15 04:00:37.587 | Added historical Intraday data request for 6BU25-CME to the queue. 2026-04-15 04:00:37.587 | Intraday data recording state for symbol 6BU25-CME is set to download 'Pending'. 2026-04-15 04:00:37.590 | Triggering next historical data download in queue. 2026-04-15 04:00:37.605 | Delaying start of download for 6BU25-CME. 2026-04-15 04:00:37.608 | 6BU25-CME [CBV-D] 2000 Volume #5 | StartDateTimeForLoadingOrderFills: 00:00:00 2026-04-15 04:00:37.657 | 6BU25-CME [CBV-D] 2000 Volume #5 | Chart data loading complete. 2026-04-15 04:00:37.669 | CQG WebAPI | Received message: Requested symbol was not found. 2026-04-15 04:00:37.669 | Symbol Error | CLG23-NYMEX is unknown, unavailable, or improperly formatted. Requested symbol was not found. 2026-04-15 04:00:37.669 | CQG WebAPI | Received message: Requested symbol was not found. 2026-04-15 04:00:37.669 | Symbol Error | CLH23-NYMEX is unknown, unavailable, or improperly formatted. Requested symbol was not found. 2026-04-15 04:00:37.669 | CQG WebAPI | Received message: Requested symbol was not found. 2026-04-15 04:00:37.669 | Symbol Error | CLJ23-NYMEX is unknown, unavailable, or improperly formatted. Requested symbol was not found. 2026-04-15 04:00:37.669 | CQG WebAPI | Received message: Requested symbol was not found. 2026-04-15 04:00:37.669 | Symbol Error | CLK23-NYMEX is unknown, unavailable, or improperly formatted. Requested symbol was not found. 2026-04-15 04:00:37.669 | CQG WebAPI | Received message: Requested symbol was not found. 2026-04-15 04:00:37.669 | Symbol Error | CLM23-NYMEX is unknown, unavailable, or improperly formatted. Requested symbol was not found. 2026-04-15 04:00:37.669 | CQG WebAPI | Received message: Requested symbol was not found. 2026-04-15 04:00:37.669 | Symbol Error | CLQ23-NYMEX is unknown, unavailable, or improperly formatted. Requested symbol was not found. 2026-04-15 04:00:37.669 | CQG WebAPI | Received message: Requested symbol was not found. 2026-04-15 04:00:37.669 | Symbol Error | CLN23-NYMEX is unknown, unavailable, or improperly formatted. Requested symbol was not found. 2026-04-15 04:00:37.669 | CQG WebAPI | Received message: Requested symbol was not found. 2026-04-15 04:00:37.669 | Symbol Error | CLV23-NYMEX is unknown, unavailable, or improperly formatted. Requested symbol was not found. 2026-04-15 04:00:37.669 | CQG WebAPI | Received message: Requested symbol was not found. 2026-04-15 04:00:37.669 | Symbol Error | CLX23-NYMEX is unknown, unavailable, or improperly formatted. Requested symbol was not found. 2026-04-15 04:00:37.669 | CQG WebAPI | Received message: Requested symbol was not found. 2026-04-15 04:00:37.669 | Symbol Error | CLU23-NYMEX is unknown, unavailable, or improperly formatted. Requested symbol was not found. 2026-04-15 04:00:37.669 | CQG WebAPI | Received message: Requested symbol was not found. 2026-04-15 04:00:37.669 | Symbol Error | CLZ23-NYMEX is unknown, unavailable, or improperly formatted. Requested symbol was not found. 2026-04-15 04:00:37.669 | CQG WebAPI | Received message: Requested symbol was not found. 2026-04-15 04:00:37.669 | Symbol Error | CLF24-NYMEX is unknown, unavailable, or improperly formatted. Requested symbol was not found. 2026-04-15 04:00:37.669 | CQG WebAPI | Received message: Requested symbol was not found. 2026-04-15 04:00:37.669 | Symbol Error | CLG24-NYMEX is unknown, unavailable, or improperly formatted. Requested symbol was not found. 2026-04-15 04:00:37.675 | CQG WebAPI | Starting real-time market data updates for: ESU25-CME. ID: 21 2026-04-15 04:00:37.675 | CQG WebAPI | Sending symbol resolution request for ESU25-CME. ID: 431168 2026-04-15 04:00:37.675 | CQG WebAPI | Requesting security definition data for: ESU25-CME. ID: 21 2026-04-15 04:00:37.675 | CQG WebAPI | Using primary service for historical data for ESU25-CME 2026-04-15 04:00:37.675 | Added historical Intraday data request for ESU25-CME to the queue. 2026-04-15 04:00:37.675 | Intraday data recording state for symbol ESU25-CME is set to download 'Pending'. 2026-04-15 04:00:37.675 | Triggering next historical data download in queue. 2026-04-15 04:00:37.685 | CQG WebAPI | Starting real-time market data updates for: CLV25-NYMEX. ID: 22 2026-04-15 04:00:37.685 | CQG WebAPI | Sending symbol resolution request for CLV25-NYMEX. ID: 431169 2026-04-15 04:00:37.685 | CQG WebAPI | Requesting security definition data for: CLV25-NYMEX. ID: 22 2026-04-15 04:00:37.685 | CQG WebAPI | Using primary service for historical data for CLV25-NYMEX 2026-04-15 04:00:37.685 | Added historical Intraday data request for CLV25-NYMEX to the queue. 2026-04-15 04:00:37.685 | Intraday data recording state for symbol CLV25-NYMEX is set to download 'Pending'. 2026-04-15 04:00:37.685 | Triggering next historical data download in queue. 2026-04-15 04:00:37.722 | CQG WebAPI | Received message: Requested symbol was not found. 2026-04-15 04:00:37.722 | Symbol Error | 6BU25-CME is unknown, unavailable, or improperly formatted. Requested symbol was not found. 2026-04-15 04:00:37.804 | CQG WebAPI | Received message: Requested symbol was not found. 2026-04-15 04:00:37.804 | Symbol Error | ESU25-CME is unknown, unavailable, or improperly formatted. Requested symbol was not found. 2026-04-15 04:00:37.804 | CQG WebAPI | Received message: Requested symbol was not found. 2026-04-15 04:00:37.804 | Symbol Error | CLV25-NYMEX is unknown, unavailable, or improperly formatted. Requested symbol was not found. 2026-04-15 04:00:38.577 | HD Request # 1 | Downloading Intraday chart data for 6BU25-CME to the file 6BU25-CME.scid. Service: cqg 2026-04-15 04:00:38.578 | HD Request # 1 | Download start date-time: 2025-10-11 04:00:38.000000. File last date-time: 2025-09-15 10:02:50.367000 2026-04-15 04:00:38.578 | HD Request # 1 | Error downloading historical Intraday data for 6BU25-CME. The symbol is unknown to the server. 2026-04-15 04:00:38.579 | HD Request # 1 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for 6BU25-CME 2026-04-15 04:00:38.579 | HD Request # 1 | Add time&sales data | Remembered last file record date-time: 2025-09-15 14:02:50.367000 2026-04-15 04:00:38.580 | HD Request # 1 | Completion time: 0s. 2026-04-15 04:00:38.580 | HD Request # 1 | Intraday data download complete for 6BU25-CME. Unique request ID: 1 2026-04-15 04:00:38.580 | Removing historical data download ID 1. 2026-04-15 04:00:38.580 | Real-time Intraday chart data file updates started for 6BU25-CME 2026-04-15 04:00:38.580 | Intraday chart data file opened for 6BU25-CME 2026-04-15 04:00:38.580 | HD Request # 1 | Enabling Intraday chart updating for symbol. 2026-04-15 04:00:38.581 | 2026-04-15 04:00:38.581 | Triggering next historical data download in queue. 2026-04-15 04:00:38.581 | HD Request # 2 | Downloading Intraday chart data for ESU25-CME to the file ESU25-CME.scid. Service: cqg 2026-04-15 04:00:38.601 | HD Request # 2 | Download start date-time: 2025-10-11 04:00:38.000000. File last date-time: 2025-09-19 09:29:58.698000 2026-04-15 04:00:38.601 | HD Request # 2 | Error downloading historical Intraday data for ESU25-CME. The symbol is unknown to the server. 2026-04-15 04:00:38.601 | HD Request # 2 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESU25-CME 2026-04-15 04:00:38.601 | HD Request # 2 | Add time&sales data | Remembered last file record date-time: 2025-09-19 13:29:58.698000 2026-04-15 04:00:38.601 | HD Request # 2 | Completion time: 0s. 2026-04-15 04:00:38.601 | HD Request # 2 | Intraday data download complete for ESU25-CME. Unique request ID: 2 2026-04-15 04:00:38.601 | Removing historical data download ID 2. 2026-04-15 04:00:38.601 | Real-time Intraday chart data file updates started for ESU25-CME 2026-04-15 04:00:38.601 | Intraday chart data file opened for ESU25-CME 2026-04-15 04:00:38.601 | HD Request # 2 | Enabling Intraday chart updating for symbol. 2026-04-15 04:00:38.601 | 2026-04-15 04:00:38.601 | Triggering next historical data download in queue. 2026-04-15 04:00:38.601 | HD Request # 3 | Downloading Intraday chart data for CLV25-NYMEX to the file CLV25-NYMEX.scid. Service: cqg 2026-04-15 04:00:38.602 | HD Request # 3 | Download start date-time: 2025-10-11 04:00:38.000000. File last date-time: 2025-09-22 14:29:55.618000 2026-04-15 04:00:38.602 | HD Request # 3 | Error downloading historical Intraday data for CLV25-NYMEX. The symbol is unknown to the server. 2026-04-15 04:00:38.602 | HD Request # 3 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for CLV25-NYMEX 2026-04-15 04:00:38.602 | HD Request # 3 | Add time&sales data | Remembered last file record date-time: 2025-09-22 18:29:55.618000 2026-04-15 04:00:38.602 | HD Request # 3 | Completion time: 0s. 2026-04-15 04:00:38.602 | HD Request # 3 | Intraday data download complete for CLV25-NYMEX. Unique request ID: 3 2026-04-15 04:00:38.602 | Removing historical data download ID 3. 2026-04-15 04:00:38.602 | Real-time Intraday chart data file updates started for CLV25-NYMEX 2026-04-15 04:00:38.602 | Intraday chart data file opened for CLV25-NYMEX 2026-04-15 04:00:38.602 | HD Request # 3 | Enabling Intraday chart updating for symbol. 2026-04-15 04:00:38.602 | 2026-04-15 04:00:38.602 | No download requests in the queue to start downloads for. 2026-04-15 04:00:42.604 | Requesting market depth updates for: CLV25-NYMEX if supported. NumLevels=1400 2026-04-15 04:00:42.604 | Symbol Error | CLV25-NYMEX is unknown, unavailable, or improperly formatted. Symbol is invalid during SubscribeToSymbolDOM 2026-04-15 04:00:42.605 | Requesting market depth updates for: ESU25-CME if supported. NumLevels=1400 2026-04-15 04:00:42.605 | Symbol Error | ESU25-CME is unknown, unavailable, or improperly formatted. Symbol is invalid during SubscribeToSymbolDOM 2026-04-15 04:00:45.528 | ESU25-CME [CBV-D] 7500 Volume #3 | Chart data loading complete. 2026-04-15 04:00:46.087 | ESU25-CME [CBV-D] #1 | Chart data loading complete. 2026-04-15 04:00:47.687 | ESU25-CME [CBV] 5000 Volume #7 | Chart Data Loading Thread: Load canceled. 2026-04-15 04:00:48.887 | ESU25-CME [CBV-D] #10 | Chart data loading complete. 2026-04-15 04:01:02.632 | Unsubscribed from market depth data for ESU25-CME 2026-04-15 04:01:06.998 | CQG WebAPI | Sending Web API Logoff message. 2026-04-15 04:01:06.998 | CQG WebSocket socket (1) | CloseSocket call. 2026-04-15 04:01:06.998 | CQG WebSocket socket (1) | Max send buffers used during socket life: 3 2026-04-15 04:01:06.998 | CQG WebSocket socket (1) | Max send buffer size during socket life: 561 2026-04-15 04:01:06.998 | CQG WebSocket | WebSocket closed. 2026-04-15 04:01:06.998 | CQG WebAPI | WebSocket closed. 2026-04-15 04:01:06.998 | CQG WebSocket socket (1) | Write in progress. Shutdown being delayed. PendingSize=0 2026-04-15 04:01:07.000 | CQG WebAPI | Disconnected. 2026-04-15 04:01:07.002 | CQG WebSocket socket (1) | Write has completed. Shutdown being performed. 2026-04-15 04:01:07.002 | CQG WebSocket socket (1) | Shutdown started. Waiting for graceful close. 2026-04-15 04:01:07.005 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-04-15 04:01:07.007 | CQG WebSocket socket (1) | Socket gracefully closed by remote side. 2026-04-15 04:01:07.007 | CQG WebSocket socket (1) | Closed. 2026-04-15 04:01:07.040 | F.US.CLEV25 #15 | Reloading chart. 2026-04-15 04:01:07.041 | F.US.CLEV25 #15 | StartDateTimeForLoadingOrderFills: 00:00:00 2026-04-15 04:01:07.041 | F.US.CLEV25 #15 | Chart data loading complete. 2026-04-15 04:01:07.042 | F.US.CLEV25 [CBV-D] #11 | Reloading chart. 2026-04-15 04:01:07.345 | Starting DelayedDownloadMonitoringTimer 2026-04-15 04:01:07.345 | Starting HDTimeoutTimer 2026-04-15 04:01:07.345 | Added historical Intraday data request for F.US.CLEV25 to the queue. 2026-04-15 04:01:07.347 | Triggering next historical data download in queue. 2026-04-15 04:01:07.367 | F.US.CLEV25 [CBV-D] #11 | Performing continuous chart historical Daily data download for symbol F.US.CLEV25 starting at last date in file. 2026-04-15 04:01:07.367 | Starting DelayedDownloadMonitoringTimer 2026-04-15 04:01:07.367 | Starting HDTimeoutTimer 2026-04-15 04:01:07.367 | Added historical Daily data request for F.US.CLEV25 to the queue. 2026-04-15 04:01:07.368 | Triggering next historical data download in queue. 2026-04-15 04:01:07.433 | F.US.CLEV25 [CBV-D] #11 | Waiting for historical downloads to complete with the IDs: 4, 5, 2026-04-15 04:01:07.438 | Mapping F.US.CLEV25 to CLV25. Service code: nymex 2026-04-15 04:01:07.438 | HD Request # 4 | Downloading Intraday chart data for F.US.CLEV25 to the file F.US.CLEV25.scid. Service: nymex 2026-04-15 04:01:07.439 | HD Request # 4 | Download start date-time: 2025-09-22 14:29:55.000000. File last date-time: 2025-09-22 14:29:55.618000 2026-04-15 04:01:07.441 | HD Request # 4 | Using server: ds28.sierracharts.com port 10150 2026-04-15 04:01:07.442 | HD Request # 5 | Downloading Historical Daily chart data for F.US.CLEV25. Starting date: 2025-09-18. Service: cqg 2026-04-15 04:01:07.445 | Mapping F.US.EPH23 to ESH23. Service code: cme 2026-04-15 04:01:07.445 | Mapping F.US.EPM23 to ESM23. Service code: cme 2026-04-15 04:01:07.445 | Mapping F.US.EPU23 to ESU23. Service code: cme 2026-04-15 04:01:07.446 | Mapping F.US.EPZ23 to ESZ23. Service code: cme 2026-04-15 04:01:07.446 | Mapping F.US.EPH24 to ESH24. Service code: cme 2026-04-15 04:01:07.446 | Mapping F.US.CLEF23 to CLF23. Service code: nymex 2026-04-15 04:01:07.446 | Mapping F.US.CLEG23 to CLG23. Service code: nymex 2026-04-15 04:01:07.446 | Mapping F.US.CLEH23 to CLH23. Service code: nymex 2026-04-15 04:01:07.446 | Mapping F.US.CLEJ23 to CLJ23. Service code: nymex 2026-04-15 04:01:07.446 | Mapping F.US.CLEK23 to CLK23. Service code: nymex 2026-04-15 04:01:07.446 | Mapping F.US.CLEM23 to CLM23. Service code: nymex 2026-04-15 04:01:07.447 | Mapping F.US.CLEN23 to CLN23. Service code: nymex 2026-04-15 04:01:07.447 | Mapping F.US.CLEQ23 to CLQ23. Service code: nymex 2026-04-15 04:01:07.447 | Mapping F.US.CLEU23 to CLU23. Service code: nymex 2026-04-15 04:01:07.448 | Mapping F.US.CLEV23 to CLV23. Service code: nymex 2026-04-15 04:01:07.448 | Mapping F.US.CLEX23 to CLX23. Service code: nymex 2026-04-15 04:01:07.448 | Mapping F.US.CLEZ23 to CLZ23. Service code: nymex 2026-04-15 04:01:07.448 | Mapping F.US.CLEF24 to CLF24. Service code: nymex 2026-04-15 04:01:07.448 | Mapping F.US.CLEG24 to CLG24. Service code: nymex 2026-04-15 04:01:07.451 | F.US.CLEV25 [CBV-D] 2000 Volume #4 | Reloading chart. 2026-04-15 04:01:07.549 | F.US.CLEV25 [CBV-D] 2000 Volume #4 | Waiting for historical downloads to complete with the IDs: 4, 5, 2026-04-15 04:01:07.558 | Enabling compression for file: C:\SierraChart\Data\F.US.BP6U25.scid 2026-04-15 04:01:07.559 | F.US.BP6U25 [CBV-D] #2 | Reloading chart. 2026-04-15 04:01:07.560 | Added historical Intraday data request for F.US.BP6U25 to the queue. 2026-04-15 04:01:07.560 | Triggering next historical data download in queue. 2026-04-15 04:01:07.567 | Socket (1) | Creating socket. 2026-04-15 04:01:07.567 | Socket (1) | New receive buffer size: 0 2026-04-15 04:01:07.567 | Socket (1) | Connecting to IP: 67.214.125.5. 2026-04-15 04:01:07.571 | F.US.BP6U25 [CBV-D] #2 | Performing continuous chart historical Daily data download for symbol F.US.BP6U25 starting at last date in file. 2026-04-15 04:01:07.571 | Added historical Daily data request for F.US.BP6U25 to the queue. 2026-04-15 04:01:07.571 | Triggering next historical data download in queue. 2026-04-15 04:01:07.571 | F.US.BP6U25 [CBV-D] #2 | Waiting for historical downloads to complete with the IDs: 6, 7, 2026-04-15 04:01:07.597 | F.US.EPU25 [CBV-D] 7500 Volume #3 | Reloading chart. 2026-04-15 04:01:07.752 | Added historical Intraday data request for F.US.EPU25 to the queue. 2026-04-15 04:01:07.752 | Triggering next historical data download in queue. 2026-04-15 04:01:07.754 | HD Request # 4 | Setting DTC encoding to Binary VLS 2026-04-15 04:01:07.754 | HD Request # 4 | Sending historical data logon request message. 2026-04-15 04:01:07.764 | F.US.EPU25 [CBV-D] 7500 Volume #3 | Performing continuous chart historical Daily data download for symbol F.US.EPU25 starting at last date in file. 2026-04-15 04:01:07.764 | Added historical Daily data request for F.US.EPU25 to the queue. 2026-04-15 04:01:07.764 | Triggering next historical data download in queue. 2026-04-15 04:01:07.837 | F.US.EPU25 [CBV-D] 7500 Volume #3 | Waiting for historical downloads to complete with the IDs: 8, 9, 2026-04-15 04:01:07.842 | F.US.BP6U25 [CBV-D] 2000 Volume #5 | Reloading chart. 2026-04-15 04:01:07.844 | F.US.BP6U25 [CBV-D] 2000 Volume #5 | Waiting for historical downloads to complete with the IDs: 6, 7, 2026-04-15 04:01:07.848 | F.US.EPU25 [CBV-D] #10 | Reloading chart. 2026-04-15 04:01:07.893 | HD Request # 4 | Requesting Intraday data. Start date-time: 2025-09-22 14:29:55. Record interval: 0. Symbol: CLV25 2026-04-15 04:01:07.943 | F.US.EPU25 [CBV-D] #10 | Waiting for historical downloads to complete with the IDs: 8, 9, 2026-04-15 04:01:07.985 | HD Request # 4 | Decompressing data. 2026-04-15 04:01:08.077 | HD Request # 4 | Receiving Intraday data for F.US.CLEV25 starting at 2025-09-22 14:29:55.086000 2026-04-15 04:01:08.077 | Socket (1) | CloseSocket call. 2026-04-15 04:01:08.078 | Socket (1) | Shutdown started. Waiting for graceful close. 2026-04-15 04:01:08.081 | Historical data download thread signaled to stop. 2026-04-15 04:01:08.081 | HD Request # 4 | Received 2 Intraday data records from 2025-09-22 14:29:55.086000 to 2025-09-22 14:29:55.618000 (0.5 seconds. Delay: 204.6 days) and wrote 0 records for F.US.CLEV25 2026-04-15 04:01:08.081 | HD Request # 4 | Completion time: 1s. 2026-04-15 04:01:08.081 | HD Request # 4 | Intraday data download complete for F.US.CLEV25. Unique request ID: 4 2026-04-15 04:01:08.081 | Removing historical data download ID 4. 2026-04-15 04:01:08.081 | Real-time Intraday chart data file updates started for F.US.CLEV25 2026-04-15 04:01:08.081 | Intraday chart data file opened for F.US.CLEV25 2026-04-15 04:01:08.081 | HD Request # 4 | Enabling Intraday chart updating for symbol. 2026-04-15 04:01:08.081 | 2026-04-15 04:01:08.081 | Triggering next historical data download in queue. 2026-04-15 04:01:08.081 | Historical data for F.US.CLEV25 is delayed because connection to main data feed is not present. Current data will be received upon connection. 2026-04-15 04:01:08.081 | Mapping F.US.BP6U25 to 6BU25. Service code: cme 2026-04-15 04:01:08.081 | HD Request # 6 | Downloading Intraday chart data for F.US.BP6U25 to the file F.US.BP6U25.scid. Service: cme 2026-04-15 04:01:08.082 | HD Request # 6 | Download start date-time: 2025-05-28 20:00:00.000000. File last date-time: 00:00:00.000000 2026-04-15 04:01:08.083 | HD Request # 6 | Using server: ds32.sierracharts.com port 10149 2026-04-15 04:01:08.093 | Socket (3) | Creating socket. 2026-04-15 04:01:08.093 | Socket (3) | New receive buffer size: 0 2026-04-15 04:01:08.093 | Socket (3) | Connecting to IP: 69.39.70.248. 2026-04-15 04:01:08.169 | Socket (1) | Socket gracefully closed by remote side. 2026-04-15 04:01:08.169 | Socket (1) | Closed. 2026-04-15 04:01:08.182 | HD Request # 5 | Requesting historical Daily data for CLV25 starting at 2025-09-17. SC External HD service. 2026-04-15 04:01:08.279 | HD Request # 6 | Setting DTC encoding to Binary VLS 2026-04-15 04:01:08.279 | HD Request # 6 | Sending historical data logon request message. 2026-04-15 04:01:08.404 | HD Request # 6 | Requesting Intraday data. Start date-time: 2025-05-28 20:00:00. Record interval: 0. Symbol: 6BU25 2026-04-15 04:01:08.497 | HD Request # 5 | Receiving historical Daily data for F.US.CLEV25 starting at 2025-09-18. 2026-04-15 04:01:08.498 | HD Request # 5 | Writing historical Daily data to the file F.US.CLEV25.dly. 2026-04-15 04:01:08.499 | HD Request # 6 | Decompressing data. 2026-04-15 04:01:08.510 | HD Request # 5 | Bytes received: 211 2026-04-15 04:01:08.510 | HD Request # 5 | Received 4 Daily data records from 2025-09-18 00:00:00 to 2025-09-22 00:00:00 (5.0 days) and wrote 3 records for F.US.CLEV25 2026-04-15 04:01:08.510 | HD Request # 5 | Completion time: 1s. 2026-04-15 04:01:08.510 | HD Request # 5 | Daily data download complete for F.US.CLEV25. Unique request ID: 5 2026-04-15 04:01:08.510 | Removing historical data download ID 5. 2026-04-15 04:01:08.510 | 2026-04-15 04:01:08.510 | Triggering next historical data download in queue. 2026-04-15 04:01:08.511 | HD Request # 7 | Downloading Historical Daily chart data for F.US.BP6U25. Starting date: 1925-10-25. Service: cqg 2026-04-15 04:01:08.681 | F.US.CLEV25 [CBV] #11 | Download is complete for all contract months in chart. Proceeding with data load. 2026-04-15 04:01:08.682 | F.US.CLEV25 [CBV] #11 | Reloading chart. 2026-04-15 04:01:08.706 | HD Request # 6 | Receiving Intraday data for F.US.BP6U25 starting at 2025-05-28 20:02:42.262000 2026-04-15 04:01:08.987 | HD Request # 6 | Timestamp of first Intraday data file record written: 2025-05-28 20:02:42.262000. 2026-04-15 04:01:09.552 | HD Request # 7 | Requesting historical Daily data for B6U25 starting at 1925-10-24. SC External HD service. 2026-04-15 04:01:09.553 | 2026-04-15 04:01:09.553 | CQG WebAPI | Connecting to server api.cqg.com 2026-04-15 04:01:09.553 | CQG WebSocket | Connecting to WebSocket server api.cqg.com:443 2026-04-15 04:01:09.561 | F.US.CLEV25 [CBV] 2000 Volume #4 | Download is complete for all contract months in chart. Proceeding with data load. 2026-04-15 04:01:09.562 | F.US.CLEV25 [CBV] 2000 Volume #4 | Reloading chart. 2026-04-15 04:01:09.676 | CQG WebSocket socket (6) | Creating socket. Using TLS 1.2. 2026-04-15 04:01:09.676 | CQG WebSocket socket (6) | New receive buffer size: 0 2026-04-15 04:01:09.676 | CQG WebSocket socket (6) | Connecting to IP: 195.166.124.175. 2026-04-15 04:01:10.716 | CQG WebSocket | Opening WebSocket. 2026-04-15 04:01:10.716 | CQG WebSocket | Sending WebSocket handshake. 2026-04-15 04:01:10.720 | F.US.CLEV25 [CBV] #11 | Reloading chart. 2026-04-15 04:01:12.304 | CQG WebSocket | Server header | HTTP/1.1 101 Switching Protocols 2026-04-15 04:01:12.304 | CQG WebSocket | Server header | Connection: Upgrade 2026-04-15 04:01:12.304 | CQG WebSocket | Server header | Sec-WebSocket-Accept: QgY+VALOR4KIlCMWGftVKNFKZLI= 2026-04-15 04:01:12.304 | CQG WebSocket | Server header | Server: WebSocket++/0.8.2 2026-04-15 04:01:12.304 | CQG WebSocket | Server header | Upgrade: websocket 2026-04-15 04:01:12.304 | CQG WebSocket | Server header | 2026-04-15 04:01:12.304 | CQG WebSocket | Web socket state is now open. 2026-04-15 04:01:12.304 | CQG WebAPI | WebSocket connected. 2026-04-15 04:01:12.305 | CQG WebAPI | Sending market data logon message. 2026-04-15 04:01:12.306 | HD Request # 7 | Receiving historical Daily data for F.US.BP6U25 starting at 2020-09-01. 2026-04-15 04:01:12.306 | HD Request # 7 | Writing historical Daily data to the file F.US.BP6U25.dly. 2026-04-15 04:01:12.317 | HD Request # 7 | Bytes received: 62629 2026-04-15 04:01:12.317 | HD Request # 7 | Received 1267 Daily data records from 2020-09-01 00:00:00 to 2025-09-15 00:00:00 (5.0 years) and wrote 1267 records for F.US.BP6U25 2026-04-15 04:01:12.317 | HD Request # 7 | Completion time: 4s. 2026-04-15 04:01:12.317 | HD Request # 7 | Daily data download complete for F.US.BP6U25. Unique request ID: 7 2026-04-15 04:01:12.317 | Removing historical data download ID 7. 2026-04-15 04:01:12.317 | 2026-04-15 04:01:12.317 | Triggering next historical data download in queue. 2026-04-15 04:01:12.319 | Mapping F.US.EPU25 to ESU25. Service code: cme 2026-04-15 04:01:12.321 | HD Request # 8 | Downloading Historical Daily chart data for F.US.EPU25. Starting date: 2025-09-17. Service: cqg 2026-04-15 04:01:12.323 | F.US.CLEV25 [CBV] 2000 Volume #4 | Reloading chart. 2026-04-15 04:01:13.914 | CQG WebAPI | Base Time: 2026-03-28T06:33:36. 2026-03-28 06:33:36 2026-04-15 04:01:13.914 | CQG WebAPI | Logon successful. Session Token = UfJgQK4NVa+Ju5CjP280chUAYscSXiQGPhsgLwNIwwMdJDMUjOkT3uN6YOLayZEEZRJxdx0W8Yw 2026-04-15 04:01:13.914 | CQG WebAPI | Connection to server complete. 2026-04-15 04:01:13.919 | No download requests in the queue to start downloads for. 2026-04-15 04:01:13.919 | Triggering next historical data download in queue. 2026-04-15 04:01:13.919 | No download requests in the queue to start downloads for. | Number times message added: 1 2026-04-15 04:01:13.919 | Updated verified funded futures trading account ending date to: 2026-05-15 08:01:13 2026-04-15 04:01:13.920 | CQG WebAPI | Sending Trade Accounts request message. 2026-04-15 04:01:13.920 | Mapping F.US.EPH23 to ESH23. Service code: cme 2026-04-15 04:01:13.920 | Using symbol data fast lookup vector 2026-04-15 04:01:13.920 | Denali Data Feed | Starting real-time market data updates for: F.US.EPH23 (ESH23). ID: 1 Service code: cme 2026-04-15 04:01:13.923 | Denali Data Feed | Connecting to the server ds32.sierracharts.com. Port 443 2026-04-15 04:01:13.923 | CQG WebAPI | Sending symbol resolution request for F.US.EPH23. ID: 431171 2026-04-15 04:01:13.923 | Denali Data Feed | Requesting security definition data for: F.US.EPH23 (ESH23). ID: 1 2026-04-15 04:01:13.923 | Mapping F.US.EPM23 to ESM23. Service code: cme 2026-04-15 04:01:13.924 | Denali Data Feed | Starting real-time market data updates for: F.US.EPM23 (ESM23). ID: 2 Service code: cme 2026-04-15 04:01:13.924 | CQG WebAPI | Sending symbol resolution request for F.US.EPM23. ID: 431172 2026-04-15 04:01:13.924 | Denali Data Feed | Requesting security definition data for: F.US.EPM23 (ESM23). ID: 2 2026-04-15 04:01:13.924 | Mapping F.US.EPU23 to ESU23. Service code: cme 2026-04-15 04:01:13.924 | Denali Data Feed | Starting real-time market data updates for: F.US.EPU23 (ESU23). ID: 3 Service code: cme 2026-04-15 04:01:13.924 | CQG WebAPI | Sending symbol resolution request for F.US.EPU23. ID: 431173 2026-04-15 04:01:13.924 | Denali Data Feed | Requesting security definition data for: F.US.EPU23 (ESU23). ID: 3 2026-04-15 04:01:13.924 | Mapping F.US.EPZ23 to ESZ23. Service code: cme 2026-04-15 04:01:13.924 | Denali Data Feed | Starting real-time market data updates for: F.US.EPZ23 (ESZ23). ID: 4 Service code: cme 2026-04-15 04:01:13.924 | CQG WebAPI | Sending symbol resolution request for F.US.EPZ23. ID: 431174 2026-04-15 04:01:13.924 | Denali Data Feed | Requesting security definition data for: F.US.EPZ23 (ESZ23). ID: 4 2026-04-15 04:01:13.924 | DTC Client socket (2) | Creating socket. 2026-04-15 04:01:13.924 | Mapping F.US.EPH24 to ESH24. Service code: cme 2026-04-15 04:01:13.924 | DTC Client socket (2) | New receive buffer size: 0 2026-04-15 04:01:13.924 | DTC Client socket (2) | Connecting to IP: 69.39.70.248. 2026-04-15 04:01:13.924 | Denali Data Feed | Starting real-time market data updates for: F.US.EPH24 (ESH24). ID: 5 Service code: cme 2026-04-15 04:01:13.924 | CQG WebAPI | Sending symbol resolution request for F.US.EPH24. ID: 431175 2026-04-15 04:01:13.924 | Denali Data Feed | Requesting security definition data for: F.US.EPH24 (ESH24). ID: 5 2026-04-15 04:01:13.924 | Mapping F.US.CLEF23 to CLF23. Service code: nymex 2026-04-15 04:01:13.925 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEF23 (CLF23). ID: 6 Service code: nymex 2026-04-15 04:01:13.925 | CQG WebAPI | Sending symbol resolution request for F.US.CLEF23. ID: 431176 2026-04-15 04:01:13.925 | Denali Data Feed | Requesting security definition data for: F.US.CLEF23 (CLF23). ID: 6 2026-04-15 04:01:13.925 | Mapping F.US.CLEG23 to CLG23. Service code: nymex 2026-04-15 04:01:13.925 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEG23 (CLG23). ID: 7 Service code: nymex 2026-04-15 04:01:13.925 | CQG WebAPI | Sending symbol resolution request for F.US.CLEG23. ID: 431177 2026-04-15 04:01:13.925 | Denali Data Feed | Requesting security definition data for: F.US.CLEG23 (CLG23). ID: 7 2026-04-15 04:01:13.925 | Mapping F.US.CLEH23 to CLH23. Service code: nymex 2026-04-15 04:01:13.925 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEH23 (CLH23). ID: 8 Service code: nymex 2026-04-15 04:01:13.925 | CQG WebAPI | Sending symbol resolution request for F.US.CLEH23. ID: 431178 2026-04-15 04:01:13.925 | Denali Data Feed | Requesting security definition data for: F.US.CLEH23 (CLH23). ID: 8 2026-04-15 04:01:13.925 | Mapping F.US.CLEJ23 to CLJ23. Service code: nymex 2026-04-15 04:01:13.925 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEJ23 (CLJ23). ID: 9 Service code: nymex 2026-04-15 04:01:13.925 | CQG WebAPI | Sending symbol resolution request for F.US.CLEJ23. ID: 431179 2026-04-15 04:01:13.925 | Denali Data Feed | Requesting security definition data for: F.US.CLEJ23 (CLJ23). ID: 9 2026-04-15 04:01:13.925 | Mapping F.US.CLEK23 to CLK23. Service code: nymex 2026-04-15 04:01:13.926 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEK23 (CLK23). ID: 10 Service code: nymex 2026-04-15 04:01:13.926 | CQG WebAPI | Sending symbol resolution request for F.US.CLEK23. ID: 431180 2026-04-15 04:01:13.926 | Denali Data Feed | Requesting security definition data for: F.US.CLEK23 (CLK23). ID: 10 2026-04-15 04:01:13.926 | Mapping F.US.CLEM23 to CLM23. Service code: nymex 2026-04-15 04:01:13.926 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEM23 (CLM23). ID: 11 Service code: nymex 2026-04-15 04:01:13.926 | CQG WebAPI | Sending symbol resolution request for F.US.CLEM23. ID: 431181 2026-04-15 04:01:13.926 | Denali Data Feed | Requesting security definition data for: F.US.CLEM23 (CLM23). ID: 11 2026-04-15 04:01:13.926 | Mapping F.US.CLEN23 to CLN23. Service code: nymex 2026-04-15 04:01:13.926 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEN23 (CLN23). ID: 12 Service code: nymex 2026-04-15 04:01:13.926 | CQG WebAPI | Sending symbol resolution request for F.US.CLEN23. ID: 431182 2026-04-15 04:01:13.926 | Denali Data Feed | Requesting security definition data for: F.US.CLEN23 (CLN23). ID: 12 2026-04-15 04:01:13.926 | Mapping F.US.CLEQ23 to CLQ23. Service code: nymex 2026-04-15 04:01:13.926 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEQ23 (CLQ23). ID: 13 Service code: nymex 2026-04-15 04:01:13.926 | CQG WebAPI | Sending symbol resolution request for F.US.CLEQ23. ID: 431183 2026-04-15 04:01:13.926 | Denali Data Feed | Requesting security definition data for: F.US.CLEQ23 (CLQ23). ID: 13 2026-04-15 04:01:13.926 | Mapping F.US.CLEU23 to CLU23. Service code: nymex 2026-04-15 04:01:13.927 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEU23 (CLU23). ID: 14 Service code: nymex 2026-04-15 04:01:13.927 | CQG WebAPI | Sending symbol resolution request for F.US.CLEU23. ID: 431184 2026-04-15 04:01:13.927 | Denali Data Feed | Requesting security definition data for: F.US.CLEU23 (CLU23). ID: 14 2026-04-15 04:01:13.927 | Mapping F.US.CLEV23 to CLV23. Service code: nymex 2026-04-15 04:01:13.927 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEV23 (CLV23). ID: 15 Service code: nymex 2026-04-15 04:01:13.927 | CQG WebAPI | Sending symbol resolution request for F.US.CLEV23. ID: 431185 2026-04-15 04:01:13.927 | Denali Data Feed | Requesting security definition data for: F.US.CLEV23 (CLV23). ID: 15 2026-04-15 04:01:13.927 | Mapping F.US.CLEX23 to CLX23. Service code: nymex 2026-04-15 04:01:13.927 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEX23 (CLX23). ID: 16 Service code: nymex 2026-04-15 04:01:13.927 | CQG WebAPI | Sending symbol resolution request for F.US.CLEX23. ID: 431186 2026-04-15 04:01:13.927 | Denali Data Feed | Requesting security definition data for: F.US.CLEX23 (CLX23). ID: 16 2026-04-15 04:01:13.927 | Mapping F.US.CLEZ23 to CLZ23. Service code: nymex 2026-04-15 04:01:13.927 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEZ23 (CLZ23). ID: 17 Service code: nymex 2026-04-15 04:01:13.927 | CQG WebAPI | Sending symbol resolution request for F.US.CLEZ23. ID: 431187 2026-04-15 04:01:13.927 | Denali Data Feed | Requesting security definition data for: F.US.CLEZ23 (CLZ23). ID: 17 2026-04-15 04:01:13.927 | Mapping F.US.CLEF24 to CLF24. Service code: nymex 2026-04-15 04:01:13.927 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEF24 (CLF24). ID: 18 Service code: nymex 2026-04-15 04:01:13.928 | CQG WebAPI | Sending symbol resolution request for F.US.CLEF24. ID: 431188 2026-04-15 04:01:13.928 | Denali Data Feed | Requesting security definition data for: F.US.CLEF24 (CLF24). ID: 18 2026-04-15 04:01:13.928 | Mapping F.US.CLEG24 to CLG24. Service code: nymex 2026-04-15 04:01:13.928 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEG24 (CLG24). ID: 19 Service code: nymex 2026-04-15 04:01:13.928 | CQG WebAPI | Sending symbol resolution request for F.US.CLEG24. ID: 431189 2026-04-15 04:01:13.928 | Denali Data Feed | Requesting security definition data for: F.US.CLEG24 (CLG24). ID: 19 2026-04-15 04:01:13.942 | Mapping F.US.CLEV25 to CLV25. Service code: nymex 2026-04-15 04:01:13.942 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEV25 (CLV25). ID: 20 Service code: nymex 2026-04-15 04:01:13.942 | CQG WebAPI | Sending symbol resolution request for F.US.CLEV25. ID: 431190 2026-04-15 04:01:13.942 | Denali Data Feed | Requesting security definition data for: F.US.CLEV25 (CLV25). ID: 20 2026-04-15 04:01:13.942 | Added historical Intraday data request for F.US.CLEV25 to the queue. 2026-04-15 04:01:13.942 | Intraday data recording state for symbol F.US.CLEV25 is set to download 'Pending'. 2026-04-15 04:01:13.942 | Triggering next historical data download in queue. 2026-04-15 04:01:13.975 | CQG WebAPI | Brokerage name: AMP. Account Name: 220033 2026-04-15 04:01:13.975 | Updated verified funded futures trading account ending date to: 2026-05-15 08:01:13 2026-04-15 04:01:13.975 | CQG WebAPI | Sending collateral subscribe request. 2026-04-15 04:01:14.016 | Denali Data Feed | Network connection to server complete. 2026-04-15 04:01:14.016 | Denali Data Feed | Starting socket receive thread. 2026-04-15 04:01:14.016 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard 2026-04-15 04:01:14.125 | Denali Data Feed | Setting DTC encoding to Binary VLS 2026-04-15 04:01:14.125 | Denali Data Feed | Sending logon request message. 2026-04-15 04:01:14.177 | CQG WebAPI | Sending positions subscribe request. RequestID: 431192 2026-04-15 04:01:14.177 | CQG WebAPI | Sending orders subscribe request. RequestID: 431193 2026-04-15 04:01:14.252 | HD Request # 8 | Requesting historical Daily data for ESU25 starting at 2025-09-16. SC External HD service. 2026-04-15 04:01:14.323 | CQG WebAPI | Received symbol resolution report for symbol F.US.EPH23. Search Symbol: F.US.EPH23. Request ID: 431171. Contract ID: 1. 2026-04-15 04:01:14.323 | CQG WebAPI | Received symbol resolution report for symbol F.US.EPM23. Search Symbol: F.US.EPM23. Request ID: 431172. Contract ID: 2. 2026-04-15 04:01:14.323 | CQG WebAPI | Received symbol resolution report for symbol F.US.EPU23. Search Symbol: F.US.EPU23. Request ID: 431173. Contract ID: 3. 2026-04-15 04:01:14.323 | CQG WebAPI | Received symbol resolution report for symbol F.US.EPZ23. Search Symbol: F.US.EPZ23. Request ID: 431174. Contract ID: 4. 2026-04-15 04:01:14.326 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEF23. Search Symbol: F.US.CLEF23. Request ID: 431176. Contract ID: 5. 2026-04-15 04:01:14.326 | CQG WebAPI | Received symbol resolution report for symbol F.US.EPH24. Search Symbol: F.US.EPH24. Request ID: 431175. Contract ID: 6. 2026-04-15 04:01:14.326 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEJ23. Search Symbol: F.US.CLEJ23. Request ID: 431179. Contract ID: 7. 2026-04-15 04:01:14.326 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEH23. Search Symbol: F.US.CLEH23. Request ID: 431178. Contract ID: 8. 2026-04-15 04:01:14.326 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEK23. Search Symbol: F.US.CLEK23. Request ID: 431180. Contract ID: 9. 2026-04-15 04:01:14.326 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEG23. Search Symbol: F.US.CLEG23. Request ID: 431177. Contract ID: 10. 2026-04-15 04:01:14.326 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEM23. Search Symbol: F.US.CLEM23. Request ID: 431181. Contract ID: 11. 2026-04-15 04:01:14.326 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEN23. Search Symbol: F.US.CLEN23. Request ID: 431182. Contract ID: 12. 2026-04-15 04:01:14.326 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEQ23. Search Symbol: F.US.CLEQ23. Request ID: 431183. Contract ID: 13. 2026-04-15 04:01:14.326 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEU23. Search Symbol: F.US.CLEU23. Request ID: 431184. Contract ID: 14. 2026-04-15 04:01:14.326 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEV23. Search Symbol: F.US.CLEV23. Request ID: 431185. Contract ID: 15. 2026-04-15 04:01:14.326 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEZ23. Search Symbol: F.US.CLEZ23. Request ID: 431187. Contract ID: 16. 2026-04-15 04:01:14.326 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEF24. Search Symbol: F.US.CLEF24. Request ID: 431188. Contract ID: 17. 2026-04-15 04:01:14.326 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEX23. Search Symbol: F.US.CLEX23. Request ID: 431186. Contract ID: 18. 2026-04-15 04:01:14.326 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEV25. Search Symbol: F.US.CLEV25. Request ID: 431190. Contract ID: 19. 2026-04-15 04:01:14.326 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEG24. Search Symbol: F.US.CLEG24. Request ID: 431189. Contract ID: 20. 2026-04-15 04:01:14.360 | HD Request # 8 | Receiving historical Daily data for F.US.EPU25 starting at 2025-09-17. 2026-04-15 04:01:14.361 | HD Request # 8 | Writing historical Daily data to the file F.US.EPU25.dly. 2026-04-15 04:01:14.367 | HD Request # 8 | Bytes received: 221 2026-04-15 04:01:14.367 | HD Request # 8 | Received 4 Daily data records from 2025-09-17 00:00:00 to 2025-09-19 00:00:00 (3.0 days) and wrote 3 records for F.US.EPU25 2026-04-15 04:01:14.367 | HD Request # 8 | Completion time: 2s. 2026-04-15 04:01:14.367 | HD Request # 8 | Daily data download complete for F.US.EPU25. Unique request ID: 9 2026-04-15 04:01:14.367 | Removing historical data download ID 9. 2026-04-15 04:01:14.367 | 2026-04-15 04:01:14.367 | No download requests in the queue to start downloads for. 2026-04-15 04:01:14.658 | Denali Data Feed | Received logon response. 2026-04-15 04:01:14.658 | Denali Data Feed | Server Name: SC Realtime Server. 2026-04-15 04:01:14.658 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8 2026-04-15 04:01:14.658 | Denali Data Feed | Successfully connected. 2026-04-15 04:01:14.658 | Denali Data Feed | Trading is not supported. 2026-04-15 04:01:14.658 | Denali Data Feed | MarketDepthIsSupported: 1 2026-04-15 04:01:14.659 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEF23 -> CLF23 2026-04-15 04:01:14.659 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEF24 -> CLF24 2026-04-15 04:01:14.659 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEG23 -> CLG23 2026-04-15 04:01:14.659 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEG24 -> CLG24 2026-04-15 04:01:14.659 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEH23 -> CLH23 2026-04-15 04:01:14.659 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEJ23 -> CLJ23 2026-04-15 04:01:14.659 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEK23 -> CLK23 2026-04-15 04:01:14.659 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEM23 -> CLM23 2026-04-15 04:01:14.659 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEN23 -> CLN23 2026-04-15 04:01:14.659 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEQ23 -> CLQ23 2026-04-15 04:01:14.659 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEU23 -> CLU23 2026-04-15 04:01:14.659 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEV23 -> CLV23 2026-04-15 04:01:14.659 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEV25 -> CLV25 2026-04-15 04:01:14.659 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEX23 -> CLX23 2026-04-15 04:01:14.659 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEZ23 -> CLZ23 2026-04-15 04:01:14.659 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.EPH23 -> ESH23 2026-04-15 04:01:14.659 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.EPH24 -> ESH24 2026-04-15 04:01:14.659 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.EPM23 -> ESM23 2026-04-15 04:01:14.659 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.EPU23 -> ESU23 2026-04-15 04:01:14.659 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.EPZ23 -> ESZ23 2026-04-15 04:01:14.845 | Denali Data Feed | Real-time data for symbol F.US.CLEF23 is currently unavailable. 2026-04-15 04:01:14.845 | Denali Data Feed | Received security definition for symbol F.US.CLEF23 2026-04-15 04:01:14.845 | Denali Data Feed | Real-time data for symbol F.US.CLEF24 is currently unavailable. 2026-04-15 04:01:14.845 | Denali Data Feed | Received security definition for symbol F.US.CLEF24 2026-04-15 04:01:14.845 | Denali Data Feed | Real-time data for symbol F.US.CLEG23 is currently unavailable. 2026-04-15 04:01:14.845 | Denali Data Feed | Received security definition for symbol F.US.CLEG23 2026-04-15 04:01:14.845 | Denali Data Feed | Real-time data for symbol F.US.CLEG24 is currently unavailable. 2026-04-15 04:01:14.845 | Denali Data Feed | Received security definition for symbol F.US.CLEG24 2026-04-15 04:01:14.845 | Denali Data Feed | Real-time data for symbol F.US.CLEH23 is currently unavailable. 2026-04-15 04:01:14.845 | Denali Data Feed | Received security definition for symbol F.US.CLEH23 2026-04-15 04:01:14.845 | Denali Data Feed | Real-time data for symbol F.US.CLEJ23 is currently unavailable. 2026-04-15 04:01:14.845 | Denali Data Feed | Received security definition for symbol F.US.CLEJ23 2026-04-15 04:01:14.845 | Denali Data Feed | Real-time data for symbol F.US.CLEK23 is currently unavailable. 2026-04-15 04:01:14.845 | Denali Data Feed | Received security definition for symbol F.US.CLEK23 2026-04-15 04:01:14.845 | Denali Data Feed | Real-time data for symbol F.US.CLEM23 is currently unavailable. 2026-04-15 04:01:14.845 | Denali Data Feed | Received security definition for symbol F.US.CLEM23 2026-04-15 04:01:14.845 | Denali Data Feed | Real-time data for symbol F.US.CLEN23 is currently unavailable. 2026-04-15 04:01:14.845 | Denali Data Feed | Received security definition for symbol F.US.CLEN23 2026-04-15 04:01:14.845 | Denali Data Feed | Real-time data for symbol F.US.CLEQ23 is currently unavailable. 2026-04-15 04:01:14.845 | Denali Data Feed | Received security definition for symbol F.US.CLEQ23 2026-04-15 04:01:14.845 | Denali Data Feed | Real-time data for symbol F.US.CLEU23 is currently unavailable. 2026-04-15 04:01:14.845 | Denali Data Feed | Received security definition for symbol F.US.CLEU23 2026-04-15 04:01:14.845 | Denali Data Feed | Real-time data for symbol F.US.CLEV23 is currently unavailable. 2026-04-15 04:01:14.845 | Denali Data Feed | Received security definition for symbol F.US.CLEV23 2026-04-15 04:01:14.845 | Denali Data Feed | Real-time data for symbol F.US.CLEV25 is currently unavailable. 2026-04-15 04:01:14.845 | Denali Data Feed | Received security definition for symbol F.US.CLEV25 2026-04-15 04:01:14.845 | Denali Data Feed | Real-time data for symbol F.US.CLEX23 is currently unavailable. 2026-04-15 04:01:14.845 | Denali Data Feed | Received security definition for symbol F.US.CLEX23 2026-04-15 04:01:14.845 | Denali Data Feed | Real-time data for symbol F.US.CLEZ23 is currently unavailable. 2026-04-15 04:01:14.845 | Denali Data Feed | Received security definition for symbol F.US.CLEZ23 2026-04-15 04:01:14.845 | Denali Data Feed | Real-time data for symbol F.US.EPH23 is currently unavailable. 2026-04-15 04:01:14.845 | Denali Data Feed | Received security definition for symbol F.US.EPH23 2026-04-15 04:01:14.845 | Denali Data Feed | Real-time data for symbol F.US.EPH24 is currently unavailable. 2026-04-15 04:01:14.845 | Denali Data Feed | Received security definition for symbol F.US.EPH24 2026-04-15 04:01:14.845 | Denali Data Feed | Real-time data for symbol F.US.EPM23 is currently unavailable. 2026-04-15 04:01:14.845 | Denali Data Feed | Received security definition for symbol F.US.EPM23 2026-04-15 04:01:14.845 | Denali Data Feed | Real-time data for symbol F.US.EPU23 is currently unavailable. 2026-04-15 04:01:14.845 | Denali Data Feed | Received security definition for symbol F.US.EPU23 2026-04-15 04:01:14.845 | Denali Data Feed | Real-time data for symbol F.US.EPZ23 is currently unavailable. 2026-04-15 04:01:14.845 | Denali Data Feed | Received security definition for symbol F.US.EPZ23 2026-04-15 04:01:16.926 | F.US.CLEV25 [CBV][M] 2000 Volume #4 | Chart data loading complete. 2026-04-15 04:01:17.891 | F.US.CLEV25 [CBV][M] #11 | Chart data loading complete. 2026-04-15 04:01:18.901 | Socket (3) | CloseSocket call. 2026-04-15 04:01:18.901 | Socket (3) | Shutdown started. Waiting for graceful close. 2026-04-15 04:01:18.901 | Historical data download thread signaled to stop. 2026-04-15 04:01:18.902 | HD Request # 6 | Received 1866254 Intraday data records from 2025-05-28 20:02:42.262000 to 2025-09-15 10:02:50.367000 (109.6 days. Delay: 211.7 days) and wrote 1866254 records for F.US.BP6U25 2026-04-15 04:01:18.912 | HD Request # 6 | Add time&sales data | Remembered last file record date-time: 2025-09-15 14:02:50.367000 2026-04-15 04:01:18.912 | HD Request # 6 | Completion time: 10s. 2026-04-15 04:01:18.912 | HD Request # 6 | Intraday data download complete for F.US.BP6U25. Unique request ID: 6 2026-04-15 04:01:18.912 | Removing historical data download ID 6. 2026-04-15 04:01:18.912 | HD Request # 6 | Enabling Intraday chart updating for symbol. 2026-04-15 04:01:18.912 | 2026-04-15 04:01:18.912 | Triggering next historical data download in queue. 2026-04-15 04:01:18.912 | Historical data for F.US.BP6U25 is delayed because connection to main data feed is not present. Current data will be received upon connection. 2026-04-15 04:01:18.912 | Mapping F.US.EPU25 to ESU25. Service code: cme 2026-04-15 04:01:18.912 | HD Request # 9 | Downloading Intraday chart data for F.US.EPU25 to the file F.US.EPU25.scid. Service: cme 2026-04-15 04:01:18.912 | HD Request # 9 | Download start date-time: 2025-09-19 09:29:58.000000. File last date-time: 2025-09-19 09:29:58.698000 2026-04-15 04:01:18.912 | HD Request # 9 | Using server: ds26.sierracharts.com port 10150 2026-04-15 04:01:18.920 | Requesting market depth updates for: F.US.CLEV25 if supported. NumLevels=100 2026-04-15 04:01:18.922 | Socket (1) | Creating socket. 2026-04-15 04:01:18.922 | Socket (1) | New receive buffer size: 0 2026-04-15 04:01:18.922 | Socket (1) | Connecting to IP: 64.152.155.17. 2026-04-15 04:01:18.935 | F.US.BP6U25 [CBV] #2 | Download is complete for all contract months in chart. Proceeding with data load. 2026-04-15 04:01:18.936 | F.US.BP6U25 [CBV] #2 | Reloading chart. 2026-04-15 04:01:18.992 | Socket (3) | Socket gracefully closed by remote side. 2026-04-15 04:01:18.993 | Socket (3) | Closed. 2026-04-15 04:01:19.072 | F.US.BP6U25 [CBV] #2 | StartDateTimeForLoadingOrderFills: 00:00:00 2026-04-15 04:01:19.083 | F.US.BP6U25 [CBV] #2 | Chart data loading complete. 2026-04-15 04:01:19.095 | Denali Data Feed | Clearing market depth for F.US.CLEV25 2026-04-15 04:01:19.101 | HD Request # 9 | Setting DTC encoding to Binary VLS 2026-04-15 04:01:19.101 | HD Request # 9 | Sending historical data logon request message. 2026-04-15 04:01:19.220 | F.US.BP6U25 [CBV] 2000 Volume #5 | Download is complete for all contract months in chart. Proceeding with data load. 2026-04-15 04:01:19.220 | F.US.BP6U25 [CBV] 2000 Volume #5 | Reloading chart. 2026-04-15 04:01:19.220 | HD Request # 9 | Requesting Intraday data. Start date-time: 2025-09-19 09:29:58. Record interval: 0. Symbol: ESU25 2026-04-15 04:01:19.309 | HD Request # 9 | Decompressing data. 2026-04-15 04:01:19.340 | F.US.BP6U25 [CBV] #2 | Reloading chart. 2026-04-15 04:01:19.342 | Enabling compression for file: C:\SierraChart\Data\F.US.BP6U25.dly 2026-04-15 04:01:19.397 | HD Request # 9 | Receiving Intraday data for F.US.EPU25 starting at 2025-09-19 09:29:58.697000 2026-04-15 04:01:19.397 | Socket (1) | CloseSocket call. 2026-04-15 04:01:19.397 | Socket (1) | Shutdown started. Waiting for graceful close. 2026-04-15 04:01:19.399 | Historical data download thread signaled to stop. 2026-04-15 04:01:19.399 | HD Request # 9 | Received 5 Intraday data records from 2025-09-19 09:29:58.697000 to 2025-09-19 09:29:58.698000 (0.0 seconds. Delay: 207.8 days) and wrote 0 records for F.US.EPU25 2026-04-15 04:01:19.400 | HD Request # 9 | Add time&sales data | Remembered last file record date-time: 2025-09-19 13:29:58.698000 2026-04-15 04:01:19.400 | HD Request # 9 | Completion time: 1s. 2026-04-15 04:01:19.400 | HD Request # 9 | Intraday data download complete for F.US.EPU25. Unique request ID: 8 2026-04-15 04:01:19.400 | Removing historical data download ID 8. 2026-04-15 04:01:19.400 | Real-time Intraday chart data file updates started for F.US.EPU25 2026-04-15 04:01:19.400 | Intraday chart data file opened for F.US.EPU25 2026-04-15 04:01:19.400 | HD Request # 9 | Enabling Intraday chart updating for symbol. 2026-04-15 04:01:19.400 | 2026-04-15 04:01:19.400 | Triggering next historical data download in queue. 2026-04-15 04:01:19.400 | HD Request # 10 | Downloading Intraday chart data for F.US.CLEV25 to the file F.US.CLEV25.scid. Service: nymex 2026-04-15 04:01:19.400 | HD Request # 10 | Download start date-time: 2025-09-22 14:29:55.000000. File last date-time: 2025-09-22 14:29:55.618000 2026-04-15 04:01:19.400 | HD Request # 10 | Using server: ds28.sierracharts.com port 10149 2026-04-15 04:01:19.401 | Socket (3) | Creating socket. 2026-04-15 04:01:19.401 | Socket (3) | New receive buffer size: 0 2026-04-15 04:01:19.401 | Socket (3) | Connecting to IP: 67.214.125.5. 2026-04-15 04:01:19.485 | Socket (1) | Socket gracefully closed by remote side. 2026-04-15 04:01:19.485 | Socket (1) | Closed. 2026-04-15 04:01:19.505 | F.US.BP6U25 [CBV] #2 | StartDateTimeForLoadingOrderFills: 00:00:00 2026-04-15 04:01:19.517 | F.US.BP6U25 [CBV] #2 | Chart data loading complete. 2026-04-15 04:01:19.564 | F.US.BP6U25 [CBV] 2000 Volume #5 | StartDateTimeForLoadingOrderFills: 00:00:00 2026-04-15 04:01:19.581 | F.US.BP6U25 [CBV] 2000 Volume #5 | Chart data loading complete. 2026-04-15 04:01:19.587 | HD Request # 10 | Setting DTC encoding to Binary VLS 2026-04-15 04:01:19.587 | HD Request # 10 | Sending historical data logon request message. 2026-04-15 04:01:19.622 | F.US.BP6U25 [CBV] 2000 Volume #5 | Reloading chart. 2026-04-15 04:01:19.648 | F.US.EPU25 [CBV] #10 | Download is complete for all contract months in chart. Proceeding with data load. 2026-04-15 04:01:19.649 | F.US.EPU25 [CBV] #10 | Reloading chart. 2026-04-15 04:01:19.712 | HD Request # 10 | Requesting Intraday data. Start date-time: 2025-09-22 14:29:55. Record interval: 0. Symbol: CLV25 2026-04-15 04:01:19.747 | Mapping F.US.BP6U25 to 6BU25. Service code: cme 2026-04-15 04:01:19.747 | Denali Data Feed | Starting real-time market data updates for: F.US.BP6U25 (6BU25). ID: 22 Service code: cme 2026-04-15 04:01:19.747 | CQG WebAPI | Sending symbol resolution request for F.US.BP6U25. ID: 431194 2026-04-15 04:01:19.747 | Denali Data Feed | Requesting security definition data for: F.US.BP6U25 (6BU25). ID: 22 2026-04-15 04:01:19.747 | Added historical Intraday data request for F.US.BP6U25 to the queue. 2026-04-15 04:01:19.747 | Intraday data recording state for symbol F.US.BP6U25 is set to download 'Pending'. 2026-04-15 04:01:19.747 | Triggering next historical data download in queue. 2026-04-15 04:01:19.778 | F.US.EPU25 [CBV] 7500 Volume #3 | Download is complete for all contract months in chart. Proceeding with data load. 2026-04-15 04:01:19.778 | F.US.EPU25 [CBV] 7500 Volume #3 | Reloading chart. 2026-04-15 04:01:19.880 | CQG WebAPI | Received symbol resolution report for symbol F.US.BP6U25. Search Symbol: F.US.BP6U25. Request ID: 431194. Contract ID: 21. 2026-04-15 04:01:19.939 | Denali Data Feed | Real-time data for symbol F.US.BP6U25 is currently unavailable. 2026-04-15 04:01:19.939 | Denali Data Feed | Received security definition for symbol F.US.BP6U25 2026-04-15 04:01:20.008 | F.US.BP6U25 [CBV] 2000 Volume #5 | StartDateTimeForLoadingOrderFills: 00:00:00 2026-04-15 04:01:20.034 | F.US.BP6U25 [CBV] 2000 Volume #5 | Chart data loading complete. 2026-04-15 04:01:20.056 | F.US.EPU25 [CBV] #10 | Reloading chart. 2026-04-15 04:01:20.116 | HD Request # 10 | Decompressing data. 2026-04-15 04:01:20.210 | HD Request # 10 | Receiving Intraday data for F.US.CLEV25 starting at 2025-09-22 14:29:55.086000 2026-04-15 04:01:20.210 | Socket (3) | CloseSocket call. 2026-04-15 04:01:20.210 | Socket (3) | Shutdown started. Waiting for graceful close. 2026-04-15 04:01:20.302 | Socket (3) | Socket gracefully closed by remote side. 2026-04-15 04:01:20.302 | Socket (3) | Closed. 2026-04-15 04:01:20.378 | Historical data download thread signaled to stop. 2026-04-15 04:01:20.378 | HD Request # 10 | Received 2 Intraday data records from 2025-09-22 14:29:55.086000 to 2025-09-22 14:29:55.618000 (0.5 seconds. Delay: 204.6 days) and wrote 0 records for F.US.CLEV25 2026-04-15 04:01:20.379 | HD Request # 10 | Add time&sales data | Remembered last file record date-time: 2025-09-22 18:29:55.618000 2026-04-15 04:01:20.379 | HD Request # 10 | Completion time: 1s. 2026-04-15 04:01:20.379 | HD Request # 10 | Intraday data download complete for F.US.CLEV25. Unique request ID: 10 2026-04-15 04:01:20.379 | Removing historical data download ID 10. 2026-04-15 04:01:20.379 | Real-time Intraday chart data file updates started for F.US.CLEV25 2026-04-15 04:01:20.379 | Intraday chart data file opened for F.US.CLEV25 2026-04-15 04:01:20.379 | HD Request # 10 | Enabling Intraday chart updating for symbol. 2026-04-15 04:01:20.379 | 2026-04-15 04:01:20.379 | Triggering next historical data download in queue. 2026-04-15 04:01:20.405 | Delaying start of download for F.US.BP6U25. 2026-04-15 04:01:20.421 | F.US.EPU25 [CBV] 7500 Volume #3 | Reloading chart. 2026-04-15 04:01:20.704 | Denali Data Feed | Starting real-time market data updates for: F.US.EPU25 (ESU25). ID: 21 Service code: cme 2026-04-15 04:01:20.704 | CQG WebAPI | Sending symbol resolution request for F.US.EPU25. ID: 431195 2026-04-15 04:01:20.704 | Denali Data Feed | Requesting security definition data for: F.US.EPU25 (ESU25). ID: 21 2026-04-15 04:01:20.796 | CQG WebAPI | Received symbol resolution report for symbol F.US.EPU25. Search Symbol: F.US.EPU25. Request ID: 431195. Contract ID: 22. 2026-04-15 04:01:20.876 | Denali Data Feed | Real-time data for symbol F.US.EPU25 is currently unavailable. 2026-04-15 04:01:20.876 | Denali Data Feed | Received security definition for symbol F.US.EPU25 2026-04-15 04:01:24.350 | HD Request # 11 | Downloading Intraday chart data for F.US.BP6U25 to the file F.US.BP6U25.scid. Service: cme 2026-04-15 04:01:24.351 | HD Request # 11 | Download start date-time: 2025-09-15 10:02:50.000000. File last date-time: 2025-09-15 10:02:50.367000 2026-04-15 04:01:24.351 | HD Request # 11 | Using server: ds32.sierracharts.com port 10150 2026-04-15 04:01:24.351 | Socket (1) | Creating socket. 2026-04-15 04:01:24.351 | Socket (1) | New receive buffer size: 0 2026-04-15 04:01:24.351 | Socket (1) | Connecting to IP: 69.39.70.248. 2026-04-15 04:01:24.538 | HD Request # 11 | Setting DTC encoding to Binary VLS 2026-04-15 04:01:24.538 | HD Request # 11 | Sending historical data logon request message. 2026-04-15 04:01:24.661 | HD Request # 11 | Requesting Intraday data. Start date-time: 2025-09-15 10:02:50. Record interval: 0. Symbol: 6BU25 2026-04-15 04:01:24.754 | HD Request # 11 | Decompressing data. 2026-04-15 04:01:24.846 | HD Request # 11 | Receiving Intraday data for F.US.BP6U25 starting at 2025-09-15 10:02:50.367000 2026-04-15 04:01:24.846 | Socket (1) | CloseSocket call. 2026-04-15 04:01:24.846 | Socket (1) | Shutdown started. Waiting for graceful close. 2026-04-15 04:01:24.846 | Historical data download thread signaled to stop. 2026-04-15 04:01:24.846 | HD Request # 11 | Received 1 Intraday data record from 2025-09-15 10:02:50.367000 to 2025-09-15 10:02:50.367000 (0.0 seconds. Delay: 211.7 days) and wrote 0 records for F.US.BP6U25 2026-04-15 04:01:24.847 | HD Request # 11 | Add time&sales data | Remembered last file record date-time: 2025-09-15 14:02:50.367000 2026-04-15 04:01:24.847 | HD Request # 11 | Completion time: 0s. 2026-04-15 04:01:24.847 | HD Request # 11 | Intraday data download complete for F.US.BP6U25. Unique request ID: 11 2026-04-15 04:01:24.847 | Removing historical data download ID 11. 2026-04-15 04:01:24.847 | Real-time Intraday chart data file updates started for F.US.BP6U25 2026-04-15 04:01:24.847 | Intraday chart data file opened for F.US.BP6U25 2026-04-15 04:01:24.847 | HD Request # 11 | Enabling Intraday chart updating for symbol. 2026-04-15 04:01:24.847 | 2026-04-15 04:01:24.847 | No download requests in the queue to start downloads for. 2026-04-15 04:01:24.938 | Socket (1) | Socket gracefully closed by remote side. 2026-04-15 04:01:24.938 | Socket (1) | Closed. 2026-04-15 04:02:01.909 | F.US.EPU25 [CBV][M] 7500 Volume #3 | Chart data loading complete. 2026-04-15 04:02:20.498 | F.US.EPU25 [CBV][M] #10 | Chart data loading complete. 2026-04-15 11:36:57.215 | The data feed was lost. There was no activity for at least 60.0 seconds. 2026-04-15 11:36:57.216 | Connection to the external service has been lost. 2026-04-15 11:36:57.626 | CQG WebSocket | Timeout waiting for pong message from server. 2026-04-15 11:36:57.630 | CQG WebAPI | WebSocket closed. 2026-04-15 11:36:57.631 | Denali Data Feed | There has been no activity on the network socket for 2h 57m 49s. Will reconnect. 2026-04-15 11:36:57.632 | Denali Data Feed | Waiting for socket receive thread to end 2026-04-15 11:36:57.639 | DTC Client socket (2) | CloseSocket call. 2026-04-15 11:36:57.639 | DTC Client socket (2) | Max send buffers used during socket life: 3 2026-04-15 11:36:57.639 | DTC Client socket (2) | Max send buffer size during socket life: 1420 2026-04-15 11:36:57.639 | DTC Client socket (2) | Write in progress. Shutdown being delayed. PendingSize=0 2026-04-15 11:36:57.641 | Denali Data Feed | Disconnected from the server. 2026-04-15 11:36:57.641 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds. 2026-04-15 11:36:57.644 | CQG WebAPI | Sending Web API Logoff message. 2026-04-15 11:36:57.644 | CQG WebSocket socket (6) | CloseSocket call. 2026-04-15 11:36:57.644 | CQG WebSocket socket (6) | Max send buffers used during socket life: 3 2026-04-15 11:36:57.644 | CQG WebSocket socket (6) | Max send buffer size during socket life: 541 2026-04-15 11:36:57.644 | CQG WebSocket | WebSocket closed. 2026-04-15 11:36:57.644 | CQG WebAPI | WebSocket closed. 2026-04-15 11:36:57.644 | CQG WebSocket socket (6) | Write in progress. Shutdown being delayed. PendingSize=8 2026-04-15 11:36:57.652 | CQG WebAPI | Disconnected. 2026-04-15 11:36:57.652 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-04-15 11:36:57.687 | DTC Client socket (2) | Write has completed. Shutdown being performed. 2026-04-15 11:36:57.687 | DTC Client socket (2) | Shutdown started. Waiting for graceful close. 2026-04-15 11:36:57.688 | DTC Client socket (2) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. * 2026-04-15 11:36:57.688 | DTC Client socket (2) | Socket gracefully closed by remote side. 2026-04-15 11:36:57.688 | DTC Client socket (2) | Closed. 2026-04-15 11:36:59.657 | 2026-04-15 11:36:59.659 | CQG WebAPI | Connecting to server api.cqg.com 2026-04-15 11:36:59.659 | CQG WebSocket | Connecting to WebSocket server api.cqg.com:443 2026-04-15 11:37:00.033 | CQG WebSocket socket (1) | Creating socket. Using TLS 1.2. 2026-04-15 11:37:00.033 | CQG WebSocket socket (1) | New receive buffer size: 0 2026-04-15 11:37:00.033 | CQG WebSocket socket (1) | Connecting to IP: 195.166.124.175. 2026-04-15 11:37:00.045 | CQG WebSocket | Opening WebSocket. 2026-04-15 11:37:00.045 | CQG WebSocket | Sending WebSocket handshake. 2026-04-15 11:37:00.077 | CQG WebSocket | Server header | HTTP/1.1 101 Switching Protocols 2026-04-15 11:37:00.077 | CQG WebSocket | Server header | Connection: Upgrade 2026-04-15 11:37:00.077 | CQG WebSocket | Server header | Sec-WebSocket-Accept: u9oKiD8DdpL6a3SmvRVT8X+Dcr8= 2026-04-15 11:37:00.077 | CQG WebSocket | Server header | Server: WebSocket++/0.8.2 2026-04-15 11:37:00.077 | CQG WebSocket | Server header | Upgrade: websocket 2026-04-15 11:37:00.077 | CQG WebSocket | Server header | 2026-04-15 11:37:00.077 | CQG WebSocket | Web socket state is now open. 2026-04-15 11:37:00.077 | CQG WebAPI | WebSocket connected. 2026-04-15 11:37:00.078 | CQG WebAPI | Sending market data logon message. 2026-04-15 11:37:00.367 | CQG WebAPI | Base Time: 2026-03-28T06:49:02. 2026-03-28 06:49:02 2026-04-15 11:37:00.367 | CQG WebAPI | Logon successful. Session Token = vt/w5uuH3Wc2iMJVebqLjP1pF4/QKrdrZUvjq6KCWJgTdBXl8p2t8Zm7OvMU9pjrj65GvIg9dDt 2026-04-15 11:37:00.367 | CQG WebAPI | Connection to server complete. 2026-04-15 11:37:00.368 | DTC Client socket (0) | CloseSocket call. 2026-04-15 11:37:00.368 | Denali Data Feed | Disconnected from the server. 2026-04-15 11:37:00.385 | No download requests in the queue to start downloads for. | Number times message added: 3 2026-04-15 11:37:00.386 | Updated verified funded futures trading account ending date to: 2026-05-15 15:37:00 2026-04-15 11:37:00.411 | CQG WebAPI | Sending Trade Accounts request message. 2026-04-15 11:37:00.413 | Mapping F.US.EPU25 to ESU25. Service code: cme 2026-04-15 11:37:00.413 | Using symbol data fast lookup vector 2026-04-15 11:37:00.415 | Denali Data Feed | Starting real-time market data updates for: F.US.EPU25 (ESU25). ID: 1 Service code: cme 2026-04-15 11:37:00.416 | Denali Data Feed | Connecting to the server ds28.sierracharts.com. Port 443 2026-04-15 11:37:00.417 | CQG WebAPI | Sending symbol resolution request for F.US.EPU25. ID: 431197 2026-04-15 11:37:00.417 | Denali Data Feed | Requesting security definition data for: F.US.EPU25 (ESU25). ID: 1 2026-04-15 11:37:00.418 | Added historical Intraday data request for F.US.EPU25 to the queue. 2026-04-15 11:37:00.418 | Intraday data recording state for symbol F.US.EPU25 is set to download 'Pending'. 2026-04-15 11:37:00.418 | Triggering next historical data download in queue. 2026-04-15 11:37:00.426 | DTC Client socket (2) | Creating socket. 2026-04-15 11:37:00.426 | DTC Client socket (2) | New receive buffer size: 0 2026-04-15 11:37:00.426 | DTC Client socket (2) | Connecting to IP: 67.214.125.5. 2026-04-15 11:37:00.435 | Delaying start of download for F.US.EPU25. 2026-04-15 11:37:00.437 | Mapping F.US.CLEV25 to CLV25. Service code: nymex 2026-04-15 11:37:00.438 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEV25 (CLV25). ID: 2 Service code: nymex 2026-04-15 11:37:00.438 | CQG WebAPI | Sending symbol resolution request for F.US.CLEV25. ID: 431198 2026-04-15 11:37:00.438 | Denali Data Feed | Requesting security definition data for: F.US.CLEV25 (CLV25). ID: 2 2026-04-15 11:37:00.438 | Added historical Intraday data request for F.US.CLEV25 to the queue. 2026-04-15 11:37:00.438 | Intraday data recording state for symbol F.US.CLEV25 is set to download 'Pending'. 2026-04-15 11:37:00.438 | Triggering next historical data download in queue. 2026-04-15 11:37:00.448 | Mapping F.US.BP6U25 to 6BU25. Service code: cme 2026-04-15 11:37:00.449 | Denali Data Feed | Starting real-time market data updates for: F.US.BP6U25 (6BU25). ID: 3 Service code: cme 2026-04-15 11:37:00.449 | CQG WebAPI | Sending symbol resolution request for F.US.BP6U25. ID: 431199 2026-04-15 11:37:00.449 | Denali Data Feed | Requesting security definition data for: F.US.BP6U25 (6BU25). ID: 3 2026-04-15 11:37:00.449 | Added historical Intraday data request for F.US.BP6U25 to the queue. 2026-04-15 11:37:00.449 | Intraday data recording state for symbol F.US.BP6U25 is set to download 'Pending'. 2026-04-15 11:37:00.449 | Triggering next historical data download in queue. 2026-04-15 11:37:00.468 | Mapping F.US.EPH23 to ESH23. Service code: cme 2026-04-15 11:37:00.468 | Denali Data Feed | Starting real-time market data updates for: F.US.EPH23 (ESH23). ID: 4 Service code: cme 2026-04-15 11:37:00.468 | CQG WebAPI | Sending symbol resolution request for F.US.EPH23. ID: 431200 2026-04-15 11:37:00.468 | Denali Data Feed | Requesting security definition data for: F.US.EPH23 (ESH23). ID: 4 2026-04-15 11:37:00.469 | Mapping F.US.EPM23 to ESM23. Service code: cme 2026-04-15 11:37:00.469 | Denali Data Feed | Starting real-time market data updates for: F.US.EPM23 (ESM23). ID: 5 Service code: cme 2026-04-15 11:37:00.469 | CQG WebAPI | Sending symbol resolution request for F.US.EPM23. ID: 431201 2026-04-15 11:37:00.469 | Denali Data Feed | Requesting security definition data for: F.US.EPM23 (ESM23). ID: 5 2026-04-15 11:37:00.469 | Mapping F.US.EPU23 to ESU23. Service code: cme 2026-04-15 11:37:00.470 | Denali Data Feed | Starting real-time market data updates for: F.US.EPU23 (ESU23). ID: 6 Service code: cme 2026-04-15 11:37:00.470 | CQG WebAPI | Sending symbol resolution request for F.US.EPU23. ID: 431202 2026-04-15 11:37:00.470 | Denali Data Feed | Requesting security definition data for: F.US.EPU23 (ESU23). ID: 6 2026-04-15 11:37:00.470 | Mapping F.US.EPZ23 to ESZ23. Service code: cme 2026-04-15 11:37:00.470 | Denali Data Feed | Starting real-time market data updates for: F.US.EPZ23 (ESZ23). ID: 7 Service code: cme 2026-04-15 11:37:00.470 | CQG WebAPI | Sending symbol resolution request for F.US.EPZ23. ID: 431203 2026-04-15 11:37:00.470 | Denali Data Feed | Requesting security definition data for: F.US.EPZ23 (ESZ23). ID: 7 2026-04-15 11:37:00.470 | Mapping F.US.EPH24 to ESH24. Service code: cme 2026-04-15 11:37:00.470 | Denali Data Feed | Starting real-time market data updates for: F.US.EPH24 (ESH24). ID: 8 Service code: cme 2026-04-15 11:37:00.470 | CQG WebAPI | Sending symbol resolution request for F.US.EPH24. ID: 431204 2026-04-15 11:37:00.470 | Denali Data Feed | Requesting security definition data for: F.US.EPH24 (ESH24). ID: 8 2026-04-15 11:37:00.471 | Mapping F.US.CLEF23 to CLF23. Service code: nymex 2026-04-15 11:37:00.471 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEF23 (CLF23). ID: 9 Service code: nymex 2026-04-15 11:37:00.471 | CQG WebAPI | Sending symbol resolution request for F.US.CLEF23. ID: 431205 2026-04-15 11:37:00.471 | Denali Data Feed | Requesting security definition data for: F.US.CLEF23 (CLF23). ID: 9 2026-04-15 11:37:00.471 | Mapping F.US.CLEG23 to CLG23. Service code: nymex 2026-04-15 11:37:00.472 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEG23 (CLG23). ID: 10 Service code: nymex 2026-04-15 11:37:00.472 | CQG WebAPI | Sending symbol resolution request for F.US.CLEG23. ID: 431206 2026-04-15 11:37:00.472 | Denali Data Feed | Requesting security definition data for: F.US.CLEG23 (CLG23). ID: 10 2026-04-15 11:37:00.472 | Mapping F.US.CLEH23 to CLH23. Service code: nymex 2026-04-15 11:37:00.472 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEH23 (CLH23). ID: 11 Service code: nymex 2026-04-15 11:37:00.472 | CQG WebAPI | Sending symbol resolution request for F.US.CLEH23. ID: 431207 2026-04-15 11:37:00.472 | Denali Data Feed | Requesting security definition data for: F.US.CLEH23 (CLH23). ID: 11 2026-04-15 11:37:00.472 | Mapping F.US.CLEJ23 to CLJ23. Service code: nymex 2026-04-15 11:37:00.472 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEJ23 (CLJ23). ID: 12 Service code: nymex 2026-04-15 11:37:00.472 | CQG WebAPI | Sending symbol resolution request for F.US.CLEJ23. ID: 431208 2026-04-15 11:37:00.472 | Denali Data Feed | Requesting security definition data for: F.US.CLEJ23 (CLJ23). ID: 12 2026-04-15 11:37:00.473 | Mapping F.US.CLEK23 to CLK23. Service code: nymex 2026-04-15 11:37:00.473 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEK23 (CLK23). ID: 13 Service code: nymex 2026-04-15 11:37:00.473 | CQG WebAPI | Sending symbol resolution request for F.US.CLEK23. ID: 431209 2026-04-15 11:37:00.473 | Denali Data Feed | Requesting security definition data for: F.US.CLEK23 (CLK23). ID: 13 2026-04-15 11:37:00.473 | Mapping F.US.CLEM23 to CLM23. Service code: nymex 2026-04-15 11:37:00.474 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEM23 (CLM23). ID: 14 Service code: nymex 2026-04-15 11:37:00.474 | CQG WebAPI | Sending symbol resolution request for F.US.CLEM23. ID: 431210 2026-04-15 11:37:00.474 | Denali Data Feed | Requesting security definition data for: F.US.CLEM23 (CLM23). ID: 14 2026-04-15 11:37:00.474 | Mapping F.US.CLEN23 to CLN23. Service code: nymex 2026-04-15 11:37:00.475 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEN23 (CLN23). ID: 15 Service code: nymex 2026-04-15 11:37:00.475 | CQG WebAPI | Sending symbol resolution request for F.US.CLEN23. ID: 431211 2026-04-15 11:37:00.475 | Denali Data Feed | Requesting security definition data for: F.US.CLEN23 (CLN23). ID: 15 2026-04-15 11:37:00.475 | Mapping F.US.CLEQ23 to CLQ23. Service code: nymex 2026-04-15 11:37:00.475 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEQ23 (CLQ23). ID: 16 Service code: nymex 2026-04-15 11:37:00.475 | CQG WebAPI | Sending symbol resolution request for F.US.CLEQ23. ID: 431212 2026-04-15 11:37:00.475 | Denali Data Feed | Requesting security definition data for: F.US.CLEQ23 (CLQ23). ID: 16 2026-04-15 11:37:00.476 | Mapping F.US.CLEU23 to CLU23. Service code: nymex 2026-04-15 11:37:00.476 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEU23 (CLU23). ID: 17 Service code: nymex 2026-04-15 11:37:00.476 | CQG WebAPI | Sending symbol resolution request for F.US.CLEU23. ID: 431213 2026-04-15 11:37:00.476 | Denali Data Feed | Requesting security definition data for: F.US.CLEU23 (CLU23). ID: 17 2026-04-15 11:37:00.476 | Mapping F.US.CLEV23 to CLV23. Service code: nymex 2026-04-15 11:37:00.476 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEV23 (CLV23). ID: 18 Service code: nymex 2026-04-15 11:37:00.476 | CQG WebAPI | Sending symbol resolution request for F.US.CLEV23. ID: 431214 2026-04-15 11:37:00.476 | Denali Data Feed | Requesting security definition data for: F.US.CLEV23 (CLV23). ID: 18 2026-04-15 11:37:00.477 | Mapping F.US.CLEX23 to CLX23. Service code: nymex 2026-04-15 11:37:00.477 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEX23 (CLX23). ID: 19 Service code: nymex 2026-04-15 11:37:00.477 | CQG WebAPI | Sending symbol resolution request for F.US.CLEX23. ID: 431215 2026-04-15 11:37:00.477 | Denali Data Feed | Requesting security definition data for: F.US.CLEX23 (CLX23). ID: 19 2026-04-15 11:37:00.477 | Mapping F.US.CLEZ23 to CLZ23. Service code: nymex 2026-04-15 11:37:00.477 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEZ23 (CLZ23). ID: 20 Service code: nymex 2026-04-15 11:37:00.477 | CQG WebAPI | Sending symbol resolution request for F.US.CLEZ23. ID: 431216 2026-04-15 11:37:00.477 | Denali Data Feed | Requesting security definition data for: F.US.CLEZ23 (CLZ23). ID: 20 2026-04-15 11:37:00.477 | Mapping F.US.CLEF24 to CLF24. Service code: nymex 2026-04-15 11:37:00.477 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEF24 (CLF24). ID: 21 Service code: nymex 2026-04-15 11:37:00.477 | CQG WebAPI | Sending symbol resolution request for F.US.CLEF24. ID: 431217 2026-04-15 11:37:00.477 | Denali Data Feed | Requesting security definition data for: F.US.CLEF24 (CLF24). ID: 21 2026-04-15 11:37:00.477 | Mapping F.US.CLEG24 to CLG24. Service code: nymex 2026-04-15 11:37:00.478 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEG24 (CLG24). ID: 22 Service code: nymex 2026-04-15 11:37:00.478 | CQG WebAPI | Sending symbol resolution request for F.US.CLEG24. ID: 431218 2026-04-15 11:37:00.478 | Denali Data Feed | Requesting security definition data for: F.US.CLEG24 (CLG24). ID: 22 2026-04-15 11:37:00.480 | CQG WebAPI | Received symbol resolution report for symbol F.US.EPH23. Search Symbol: F.US.EPH23. Request ID: 431200. Contract ID: 1. 2026-04-15 11:37:00.481 | CQG WebAPI | Brokerage name: AMP. Account Name: 220033 2026-04-15 11:37:00.481 | Updated verified funded futures trading account ending date to: 2026-05-15 15:37:00 2026-04-15 11:37:00.481 | CQG WebAPI | Sending collateral subscribe request. 2026-04-15 11:37:00.482 | CQG WebAPI | Received symbol resolution report for symbol F.US.EPM23. Search Symbol: F.US.EPM23. Request ID: 431201. Contract ID: 2. 2026-04-15 11:37:00.482 | CQG WebAPI | Received symbol resolution report for symbol F.US.EPU23. Search Symbol: F.US.EPU23. Request ID: 431202. Contract ID: 3. 2026-04-15 11:37:00.482 | CQG WebAPI | Received symbol resolution report for symbol F.US.EPZ23. Search Symbol: F.US.EPZ23. Request ID: 431203. Contract ID: 4. 2026-04-15 11:37:00.482 | CQG WebAPI | Received symbol resolution report for symbol F.US.EPH24. Search Symbol: F.US.EPH24. Request ID: 431204. Contract ID: 5. 2026-04-15 11:37:00.482 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEN23. Search Symbol: F.US.CLEN23. Request ID: 431211. Contract ID: 6. 2026-04-15 11:37:00.546 | CQG WebAPI | Received symbol resolution report for symbol F.US.EPU25. Search Symbol: F.US.EPU25. Request ID: 431197. Contract ID: 7. 2026-04-15 11:37:00.546 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEV25. Search Symbol: F.US.CLEV25. Request ID: 431198. Contract ID: 8. 2026-04-15 11:37:00.546 | CQG WebAPI | Received symbol resolution report for symbol F.US.BP6U25. Search Symbol: F.US.BP6U25. Request ID: 431199. Contract ID: 9. 2026-04-15 11:37:00.547 | Denali Data Feed | Network connection to server complete. 2026-04-15 11:37:00.547 | Denali Data Feed | Starting socket receive thread. 2026-04-15 11:37:00.547 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard 2026-04-15 11:37:00.569 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEF23. Search Symbol: F.US.CLEF23. Request ID: 431205. Contract ID: 10. 2026-04-15 11:37:00.569 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEG23. Search Symbol: F.US.CLEG23. Request ID: 431206. Contract ID: 11. 2026-04-15 11:37:00.569 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEJ23. Search Symbol: F.US.CLEJ23. Request ID: 431208. Contract ID: 12. 2026-04-15 11:37:00.569 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEK23. Search Symbol: F.US.CLEK23. Request ID: 431209. Contract ID: 13. 2026-04-15 11:37:00.569 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEH23. Search Symbol: F.US.CLEH23. Request ID: 431207. Contract ID: 14. 2026-04-15 11:37:00.569 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEM23. Search Symbol: F.US.CLEM23. Request ID: 431210. Contract ID: 15. 2026-04-15 11:37:00.569 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEU23. Search Symbol: F.US.CLEU23. Request ID: 431213. Contract ID: 16. 2026-04-15 11:37:00.569 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEV23. Search Symbol: F.US.CLEV23. Request ID: 431214. Contract ID: 17. 2026-04-15 11:37:00.569 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEQ23. Search Symbol: F.US.CLEQ23. Request ID: 431212. Contract ID: 18. 2026-04-15 11:37:00.596 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEX23. Search Symbol: F.US.CLEX23. Request ID: 431215. Contract ID: 19. 2026-04-15 11:37:00.596 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEZ23. Search Symbol: F.US.CLEZ23. Request ID: 431216. Contract ID: 20. 2026-04-15 11:37:00.596 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEF24. Search Symbol: F.US.CLEF24. Request ID: 431217. Contract ID: 21. 2026-04-15 11:37:00.596 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEG24. Search Symbol: F.US.CLEG24. Request ID: 431218. Contract ID: 22. 2026-04-15 11:37:00.646 | CQG WebAPI | Sending positions subscribe request. RequestID: 431220 2026-04-15 11:37:00.646 | CQG WebAPI | Sending orders subscribe request. RequestID: 431221 2026-04-15 11:37:00.649 | Denali Data Feed | Setting DTC encoding to Binary VLS 2026-04-15 11:37:00.649 | Denali Data Feed | Sending logon request message. 2026-04-15 11:37:01.181 | Denali Data Feed | Received logon response. 2026-04-15 11:37:01.181 | Denali Data Feed | Server Name: SC Realtime Server. 2026-04-15 11:37:01.181 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8 2026-04-15 11:37:01.181 | Denali Data Feed | Successfully connected. 2026-04-15 11:37:01.181 | Denali Data Feed | Trading is not supported. 2026-04-15 11:37:01.181 | Denali Data Feed | MarketDepthIsSupported: 1 2026-04-15 11:37:01.182 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.BP6U25 -> 6BU25 2026-04-15 11:37:01.182 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEF23 -> CLF23 2026-04-15 11:37:01.182 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEF24 -> CLF24 2026-04-15 11:37:01.182 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEG23 -> CLG23 2026-04-15 11:37:01.182 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEG24 -> CLG24 2026-04-15 11:37:01.182 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEH23 -> CLH23 2026-04-15 11:37:01.182 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEJ23 -> CLJ23 2026-04-15 11:37:01.182 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEK23 -> CLK23 2026-04-15 11:37:01.182 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEM23 -> CLM23 2026-04-15 11:37:01.182 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEN23 -> CLN23 2026-04-15 11:37:01.182 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEQ23 -> CLQ23 2026-04-15 11:37:01.182 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEU23 -> CLU23 2026-04-15 11:37:01.182 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEV23 -> CLV23 2026-04-15 11:37:01.182 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEV25 -> CLV25 2026-04-15 11:37:01.182 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEX23 -> CLX23 2026-04-15 11:37:01.182 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEZ23 -> CLZ23 2026-04-15 11:37:01.182 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.EPH23 -> ESH23 2026-04-15 11:37:01.182 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.EPH24 -> ESH24 2026-04-15 11:37:01.182 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.EPM23 -> ESM23 2026-04-15 11:37:01.182 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.EPU23 -> ESU23 2026-04-15 11:37:01.182 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.EPU25 -> ESU25 2026-04-15 11:37:01.182 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.EPZ23 -> ESZ23 2026-04-15 11:37:01.367 | Denali Data Feed | Real-time data for symbol F.US.BP6U25 is currently unavailable. 2026-04-15 11:37:01.367 | Denali Data Feed | Received security definition for symbol F.US.BP6U25 2026-04-15 11:37:01.367 | Denali Data Feed | Real-time data for symbol F.US.CLEF23 is currently unavailable. 2026-04-15 11:37:01.367 | Denali Data Feed | Received security definition for symbol F.US.CLEF23 2026-04-15 11:37:01.367 | Denali Data Feed | Real-time data for symbol F.US.CLEF24 is currently unavailable. 2026-04-15 11:37:01.367 | Denali Data Feed | Received security definition for symbol F.US.CLEF24 2026-04-15 11:37:01.367 | Denali Data Feed | Real-time data for symbol F.US.CLEG23 is currently unavailable. 2026-04-15 11:37:01.367 | Denali Data Feed | Received security definition for symbol F.US.CLEG23 2026-04-15 11:37:01.367 | Denali Data Feed | Real-time data for symbol F.US.CLEG24 is currently unavailable. 2026-04-15 11:37:01.367 | Denali Data Feed | Received security definition for symbol F.US.CLEG24 2026-04-15 11:37:01.367 | Denali Data Feed | Real-time data for symbol F.US.CLEH23 is currently unavailable. 2026-04-15 11:37:01.367 | Denali Data Feed | Received security definition for symbol F.US.CLEH23 2026-04-15 11:37:01.367 | Denali Data Feed | Real-time data for symbol F.US.CLEJ23 is currently unavailable. 2026-04-15 11:37:01.367 | Denali Data Feed | Received security definition for symbol F.US.CLEJ23 2026-04-15 11:37:01.367 | Denali Data Feed | Real-time data for symbol F.US.CLEK23 is currently unavailable. 2026-04-15 11:37:01.367 | Denali Data Feed | Received security definition for symbol F.US.CLEK23 2026-04-15 11:37:01.367 | Denali Data Feed | Real-time data for symbol F.US.CLEM23 is currently unavailable. 2026-04-15 11:37:01.367 | Denali Data Feed | Received security definition for symbol F.US.CLEM23 2026-04-15 11:37:01.367 | Denali Data Feed | Real-time data for symbol F.US.CLEN23 is currently unavailable. 2026-04-15 11:37:01.367 | Denali Data Feed | Received security definition for symbol F.US.CLEN23 2026-04-15 11:37:01.367 | Denali Data Feed | Real-time data for symbol F.US.CLEQ23 is currently unavailable. 2026-04-15 11:37:01.367 | Denali Data Feed | Received security definition for symbol F.US.CLEQ23 2026-04-15 11:37:01.367 | Denali Data Feed | Real-time data for symbol F.US.CLEU23 is currently unavailable. 2026-04-15 11:37:01.367 | Denali Data Feed | Received security definition for symbol F.US.CLEU23 2026-04-15 11:37:01.367 | Denali Data Feed | Real-time data for symbol F.US.CLEV23 is currently unavailable. 2026-04-15 11:37:01.367 | Denali Data Feed | Received security definition for symbol F.US.CLEV23 2026-04-15 11:37:01.367 | Denali Data Feed | Real-time data for symbol F.US.CLEV25 is currently unavailable. 2026-04-15 11:37:01.367 | Denali Data Feed | Received security definition for symbol F.US.CLEV25 2026-04-15 11:37:01.367 | Denali Data Feed | Real-time data for symbol F.US.CLEX23 is currently unavailable. 2026-04-15 11:37:01.367 | Denali Data Feed | Received security definition for symbol F.US.CLEX23 2026-04-15 11:37:01.367 | Denali Data Feed | Real-time data for symbol F.US.CLEZ23 is currently unavailable. 2026-04-15 11:37:01.367 | Denali Data Feed | Received security definition for symbol F.US.CLEZ23 2026-04-15 11:37:01.367 | Denali Data Feed | Real-time data for symbol F.US.EPH23 is currently unavailable. 2026-04-15 11:37:01.367 | Denali Data Feed | Received security definition for symbol F.US.EPH23 2026-04-15 11:37:01.367 | Denali Data Feed | Real-time data for symbol F.US.EPH24 is currently unavailable. 2026-04-15 11:37:01.367 | Denali Data Feed | Received security definition for symbol F.US.EPH24 2026-04-15 11:37:01.367 | Denali Data Feed | Real-time data for symbol F.US.EPM23 is currently unavailable. 2026-04-15 11:37:01.367 | Denali Data Feed | Received security definition for symbol F.US.EPM23 2026-04-15 11:37:01.367 | Denali Data Feed | Real-time data for symbol F.US.EPU23 is currently unavailable. 2026-04-15 11:37:01.367 | Denali Data Feed | Received security definition for symbol F.US.EPU23 2026-04-15 11:37:01.367 | Denali Data Feed | Real-time data for symbol F.US.EPU25 is currently unavailable. 2026-04-15 11:37:01.367 | Denali Data Feed | Received security definition for symbol F.US.EPU25 2026-04-15 11:37:01.367 | Denali Data Feed | Real-time data for symbol F.US.EPZ23 is currently unavailable. 2026-04-15 11:37:01.367 | Denali Data Feed | Received security definition for symbol F.US.EPZ23 2026-04-15 11:37:05.371 | Requesting market depth updates for: F.US.CLEV25 if supported. NumLevels=100 2026-04-15 11:37:05.554 | Denali Data Feed | Clearing market depth for F.US.CLEV25 2026-04-15 11:37:06.225 | HD Request # 12 | Downloading Intraday chart data for F.US.EPU25 to the file F.US.EPU25.scid. Service: cme 2026-04-15 11:37:06.242 | HD Request # 12 | Download start date-time: 2025-09-19 09:29:58.000000. File last date-time: 2025-09-19 09:29:58.698000 2026-04-15 11:37:06.244 | HD Request # 12 | Using server: ds26.sierracharts.com port 10149 2026-04-15 11:37:06.256 | Socket (3) | Creating socket. 2026-04-15 11:37:06.257 | Socket (3) | New receive buffer size: 0 2026-04-15 11:37:06.260 | Socket (3) | Connecting to IP: 64.152.155.17. 2026-04-15 11:37:06.445 | HD Request # 12 | Setting DTC encoding to Binary VLS 2026-04-15 11:37:06.445 | HD Request # 12 | Sending historical data logon request message. 2026-04-15 11:37:06.594 | HD Request # 12 | Requesting Intraday data. Start date-time: 2025-09-19 09:29:58. Record interval: 0. Symbol: ESU25 2026-04-15 11:37:06.739 | HD Request # 12 | Decompressing data. 2026-04-15 11:37:06.830 | HD Request # 12 | Receiving Intraday data for F.US.EPU25 starting at 2025-09-19 09:29:58.697000 2026-04-15 11:37:06.830 | Socket (3) | CloseSocket call. 2026-04-15 11:37:06.830 | Socket (3) | Shutdown started. Waiting for graceful close. 2026-04-15 11:37:06.831 | Historical data download thread signaled to stop. 2026-04-15 11:37:06.831 | HD Request # 12 | Received 5 Intraday data records from 2025-09-19 09:29:58.697000 to 2025-09-19 09:29:58.698000 (0.0 seconds. Delay: 208.1 days) and wrote 0 records for F.US.EPU25 2026-04-15 11:37:06.831 | HD Request # 12 | Add time&sales data | Remembered last file record date-time: 2025-09-19 13:29:58.698000 2026-04-15 11:37:06.831 | HD Request # 12 | Completion time: 0s. 2026-04-15 11:37:06.831 | HD Request # 12 | Intraday data download complete for F.US.EPU25. Unique request ID: 12 2026-04-15 11:37:06.831 | Removing historical data download ID 12. 2026-04-15 11:37:06.832 | Real-time Intraday chart data file updates started for F.US.EPU25 2026-04-15 11:37:06.832 | Intraday chart data file opened for F.US.EPU25 2026-04-15 11:37:06.832 | HD Request # 12 | Enabling Intraday chart updating for symbol. 2026-04-15 11:37:06.832 | 2026-04-15 11:37:06.832 | Triggering next historical data download in queue. 2026-04-15 11:37:06.832 | HD Request # 13 | Downloading Intraday chart data for F.US.CLEV25 to the file F.US.CLEV25.scid. Service: nymex 2026-04-15 11:37:06.849 | HD Request # 13 | Download start date-time: 2025-09-22 14:29:55.000000. File last date-time: 2025-09-22 14:29:55.618000 2026-04-15 11:37:06.850 | HD Request # 13 | Using server: ds28.sierracharts.com port 10150 2026-04-15 11:37:06.850 | Socket (4) | Creating socket. 2026-04-15 11:37:06.850 | Socket (4) | New receive buffer size: 0 2026-04-15 11:37:06.850 | Socket (4) | Connecting to IP: 67.214.125.5. 2026-04-15 11:37:06.921 | Socket (3) | Socket gracefully closed by remote side. 2026-04-15 11:37:06.921 | Socket (3) | Closed. 2026-04-15 11:37:07.041 | HD Request # 13 | Setting DTC encoding to Binary VLS 2026-04-15 11:37:07.041 | HD Request # 13 | Sending historical data logon request message. 2026-04-15 11:37:07.164 | HD Request # 13 | Requesting Intraday data. Start date-time: 2025-09-22 14:29:55. Record interval: 0. Symbol: CLV25 2026-04-15 11:37:07.289 | HD Request # 13 | Decompressing data. 2026-04-15 11:37:07.383 | HD Request # 13 | Receiving Intraday data for F.US.CLEV25 starting at 2025-09-22 14:29:55.086000 2026-04-15 11:37:07.383 | Socket (4) | CloseSocket call. 2026-04-15 11:37:07.383 | Socket (4) | Shutdown started. Waiting for graceful close. 2026-04-15 11:37:07.383 | Historical data download thread signaled to stop. 2026-04-15 11:37:07.383 | HD Request # 13 | Received 2 Intraday data records from 2025-09-22 14:29:55.086000 to 2025-09-22 14:29:55.618000 (0.5 seconds. Delay: 204.9 days) and wrote 0 records for F.US.CLEV25 2026-04-15 11:37:07.384 | HD Request # 13 | Add time&sales data | Remembered last file record date-time: 2025-09-22 18:29:55.618000 2026-04-15 11:37:07.384 | HD Request # 13 | Completion time: 1s. 2026-04-15 11:37:07.384 | HD Request # 13 | Intraday data download complete for F.US.CLEV25. Unique request ID: 13 2026-04-15 11:37:07.384 | Removing historical data download ID 13. 2026-04-15 11:37:07.384 | Real-time Intraday chart data file updates started for F.US.CLEV25 2026-04-15 11:37:07.384 | Intraday chart data file opened for F.US.CLEV25 2026-04-15 11:37:07.384 | HD Request # 13 | Enabling Intraday chart updating for symbol. 2026-04-15 11:37:07.384 | 2026-04-15 11:37:07.384 | Triggering next historical data download in queue. 2026-04-15 11:37:07.384 | HD Request # 14 | Downloading Intraday chart data for F.US.BP6U25 to the file F.US.BP6U25.scid. Service: cme 2026-04-15 11:37:07.399 | HD Request # 14 | Download start date-time: 2025-09-15 10:02:50.000000. File last date-time: 2025-09-15 10:02:50.367000 2026-04-15 11:37:07.400 | HD Request # 14 | Using server: ds32.sierracharts.com port 10149 2026-04-15 11:37:07.415 | Socket (3) | Creating socket. 2026-04-15 11:37:07.415 | Socket (3) | New receive buffer size: 0 2026-04-15 11:37:07.415 | Socket (3) | Connecting to IP: 69.39.70.248. 2026-04-15 11:37:07.476 | Socket (4) | Socket gracefully closed by remote side. 2026-04-15 11:37:07.477 | Socket (4) | Closed. 2026-04-15 11:37:07.611 | HD Request # 14 | Setting DTC encoding to Binary VLS 2026-04-15 11:37:07.611 | HD Request # 14 | Sending historical data logon request message. 2026-04-15 11:37:07.735 | HD Request # 14 | Requesting Intraday data. Start date-time: 2025-09-15 10:02:50. Record interval: 0. Symbol: 6BU25 2026-04-15 11:37:07.830 | HD Request # 14 | Decompressing data. 2026-04-15 11:37:07.922 | HD Request # 14 | Receiving Intraday data for F.US.BP6U25 starting at 2025-09-15 10:02:50.367000 2026-04-15 11:37:07.922 | Socket (3) | CloseSocket call. 2026-04-15 11:37:07.922 | Socket (3) | Shutdown started. Waiting for graceful close. 2026-04-15 11:37:07.923 | Historical data download thread signaled to stop. 2026-04-15 11:37:07.923 | HD Request # 14 | Received 1 Intraday data record from 2025-09-15 10:02:50.367000 to 2025-09-15 10:02:50.367000 (0.0 seconds. Delay: 212.1 days) and wrote 0 records for F.US.BP6U25 2026-04-15 11:37:07.924 | HD Request # 14 | Add time&sales data | Remembered last file record date-time: 2025-09-15 14:02:50.367000 2026-04-15 11:37:07.924 | HD Request # 14 | Completion time: 0s. 2026-04-15 11:37:07.924 | HD Request # 14 | Intraday data download complete for F.US.BP6U25. Unique request ID: 14 2026-04-15 11:37:07.924 | Removing historical data download ID 14. 2026-04-15 11:37:07.924 | Real-time Intraday chart data file updates started for F.US.BP6U25 2026-04-15 11:37:07.924 | Intraday chart data file opened for F.US.BP6U25 2026-04-15 11:37:07.924 | HD Request # 14 | Enabling Intraday chart updating for symbol. 2026-04-15 11:37:07.924 | 2026-04-15 11:37:07.924 | No download requests in the queue to start downloads for. 2026-04-15 11:37:08.014 | Socket (3) | Socket gracefully closed by remote side. 2026-04-15 11:37:08.014 | Socket (3) | Closed. 2026-04-15 11:37:19.243 | CQG WebSocket socket (6) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. * 2026-04-15 11:37:19.244 | CQG WebSocket socket (6) | Write has completed. Shutdown being performed. 2026-04-15 11:37:19.244 | CQG WebSocket socket (6) | Shutdown started. Waiting for graceful close. 2026-04-15 11:37:19.244 | CQG WebSocket socket (6) | Socket gracefully closed by remote side. 2026-04-15 11:37:19.244 | CQG WebSocket socket (6) | Closed. 2026-04-15 19:51:05.551 | CQG WebSocket | Timeout waiting for pong message from server. 2026-04-15 19:51:05.552 | CQG WebAPI | WebSocket closed. 2026-04-15 19:51:05.553 | Connection to the external service has been lost. 2026-04-15 19:51:05.952 | DTC Client socket (2) | Socket gracefully closed by remote side. 2026-04-15 19:51:06.003 | Denali Data Feed | There has been no activity on the network socket for 6h 3m 33s. Will reconnect. 2026-04-15 19:51:06.013 | Denali Data Feed | Waiting for socket receive thread to end 2026-04-15 19:51:06.027 | DTC Client socket (2) | CloseSocket call. 2026-04-15 19:51:06.036 | Denali Data Feed | Disconnected from the server. 2026-04-15 19:51:06.039 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds. 2026-04-15 19:51:06.045 | CQG WebAPI | Sending Web API Logoff message. 2026-04-15 19:51:06.046 | CQG WebSocket socket (1) | CloseSocket call. 2026-04-15 19:51:06.046 | CQG WebSocket socket (1) | Max send buffers used during socket life: 3 2026-04-15 19:51:06.046 | CQG WebSocket socket (1) | Max send buffer size during socket life: 517 2026-04-15 19:51:06.046 | CQG WebSocket | WebSocket closed. 2026-04-15 19:51:06.046 | CQG WebAPI | WebSocket closed. 2026-04-15 19:51:06.064 | CQG WebAPI | Disconnected. 2026-04-15 19:51:06.065 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-04-15 19:51:06.145 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2026-04-15 19:51:06.147 | DTC Client socket (2) | Closed. 2026-04-15 19:51:06.147 | CQG WebSocket socket (1) | Write in progress. Shutdown being delayed. PendingSize=0 2026-04-15 19:51:08.059 | 2026-04-15 19:51:08.060 | CQG WebAPI | Connecting to server api.cqg.com 2026-04-15 19:51:08.060 | CQG WebSocket | Connecting to WebSocket server api.cqg.com:443 2026-04-15 19:51:08.402 | CQG WebSocket socket (2) | Creating socket. Using TLS 1.2. 2026-04-15 19:51:08.402 | CQG WebSocket socket (2) | New receive buffer size: 0 2026-04-15 19:51:08.402 | CQG WebSocket socket (2) | Connecting to IP: 195.166.124.175. 2026-04-15 19:51:08.480 | CQG WebSocket | Opening WebSocket. 2026-04-15 19:51:08.480 | CQG WebSocket | Sending WebSocket handshake. 2026-04-15 19:51:08.753 | CQG WebSocket | Server header | HTTP/1.1 101 Switching Protocols 2026-04-15 19:51:08.753 | CQG WebSocket | Server header | Connection: Upgrade 2026-04-15 19:51:08.753 | CQG WebSocket | Server header | Sec-WebSocket-Accept: BDBflFHnAsul3Wa5pJHlVYHCJN0= 2026-04-15 19:51:08.753 | CQG WebSocket | Server header | Server: WebSocket++/0.8.2 2026-04-15 19:51:08.753 | CQG WebSocket | Server header | Upgrade: websocket 2026-04-15 19:51:08.753 | CQG WebSocket | Server header | 2026-04-15 19:51:08.753 | CQG WebSocket | Web socket state is now open. 2026-04-15 19:51:08.753 | CQG WebAPI | WebSocket connected. 2026-04-15 19:51:08.754 | CQG WebAPI | Sending market data logon message. 2026-04-15 19:51:09.030 | Denali Data Feed | Connecting to the server ds25-2.sierracharts.com. Port 443 2026-04-15 19:51:09.035 | CQG WebAPI | Base Time: 2026-03-28T18:10:42. 2026-03-28 18:10:42 2026-04-15 19:51:09.035 | CQG WebAPI | Logon successful. Session Token = jZKycKzL89RkTZ/kcjXr0uaQlcHksQ5S8K8bXvKg9lcL6LtqqFhVvmSFx1Z4sEpWFYcxoN7ksU/ 2026-04-15 19:51:09.035 | CQG WebAPI | Connection to server complete. 2026-04-15 19:51:09.036 | DTC Client socket (3) | CloseSocket call. 2026-04-15 19:51:09.036 | Denali Data Feed | Disconnected from the server. 2026-04-15 19:51:09.044 | No download requests in the queue to start downloads for. | Number times message added: 3 2026-04-15 19:51:09.044 | Updated verified funded futures trading account ending date to: 2026-05-15 23:51:09 2026-04-15 19:51:09.072 | CQG WebAPI | Sending Trade Accounts request message. 2026-04-15 19:51:09.122 | Mapping F.US.EPU25 to ESU25. Service code: cme 2026-04-15 19:51:09.122 | Using symbol data fast lookup vector 2026-04-15 19:51:09.123 | Denali Data Feed | Starting real-time market data updates for: F.US.EPU25 (ESU25). ID: 1 Service code: cme 2026-04-15 19:51:09.123 | Denali Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 443 2026-04-15 19:51:09.123 | CQG WebAPI | Sending symbol resolution request for F.US.EPU25. ID: 431223 2026-04-15 19:51:09.123 | Denali Data Feed | Requesting security definition data for: F.US.EPU25 (ESU25). ID: 1 2026-04-15 19:51:09.125 | Added historical Intraday data request for F.US.EPU25 to the queue. 2026-04-15 19:51:09.125 | Intraday data recording state for symbol F.US.EPU25 is set to download 'Pending'. 2026-04-15 19:51:09.125 | Triggering next historical data download in queue. 2026-04-15 19:51:09.127 | Delaying start of download for F.US.EPU25. 2026-04-15 19:51:09.128 | Mapping F.US.BP6U25 to 6BU25. Service code: cme 2026-04-15 19:51:09.128 | Denali Data Feed | Starting real-time market data updates for: F.US.BP6U25 (6BU25). ID: 2 Service code: cme 2026-04-15 19:51:09.128 | CQG WebAPI | Sending symbol resolution request for F.US.BP6U25. ID: 431224 2026-04-15 19:51:09.128 | Denali Data Feed | Requesting security definition data for: F.US.BP6U25 (6BU25). ID: 2 2026-04-15 19:51:09.128 | Added historical Intraday data request for F.US.BP6U25 to the queue. 2026-04-15 19:51:09.128 | Intraday data recording state for symbol F.US.BP6U25 is set to download 'Pending'. 2026-04-15 19:51:09.128 | Triggering next historical data download in queue. 2026-04-15 19:51:09.134 | DTC Client socket (3) | Creating socket. 2026-04-15 19:51:09.134 | DTC Client socket (3) | New receive buffer size: 0 2026-04-15 19:51:09.134 | DTC Client socket (3) | Connecting to IP: 67.214.125.6. 2026-04-15 19:51:09.190 | CQG WebAPI | Brokerage name: AMP. Account Name: 220033 2026-04-15 19:51:09.190 | Updated verified funded futures trading account ending date to: 2026-05-15 23:51:09 2026-04-15 19:51:09.191 | CQG WebAPI | Sending collateral subscribe request. 2026-04-15 19:51:09.216 | Mapping F.US.CLEV25 to CLV25. Service code: nymex 2026-04-15 19:51:09.216 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEV25 (CLV25). ID: 3 Service code: nymex 2026-04-15 19:51:09.216 | CQG WebAPI | Sending symbol resolution request for F.US.CLEV25. ID: 431226 2026-04-15 19:51:09.216 | Denali Data Feed | Requesting security definition data for: F.US.CLEV25 (CLV25). ID: 3 2026-04-15 19:51:09.217 | Added historical Intraday data request for F.US.CLEV25 to the queue. 2026-04-15 19:51:09.217 | Intraday data recording state for symbol F.US.CLEV25 is set to download 'Pending'. 2026-04-15 19:51:09.217 | Triggering next historical data download in queue. 2026-04-15 19:51:09.247 | CQG WebAPI | Received symbol resolution report for symbol F.US.EPU25. Search Symbol: F.US.EPU25. Request ID: 431223. Contract ID: 1. 2026-04-15 19:51:09.247 | CQG WebAPI | Received symbol resolution report for symbol F.US.BP6U25. Search Symbol: F.US.BP6U25. Request ID: 431224. Contract ID: 2. 2026-04-15 19:51:09.248 | Denali Data Feed | Network connection to server complete. 2026-04-15 19:51:09.248 | Denali Data Feed | Starting socket receive thread. 2026-04-15 19:51:09.250 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard 2026-04-15 19:51:09.324 | CQG WebAPI | Sending positions subscribe request. RequestID: 431227 2026-04-15 19:51:09.325 | CQG WebAPI | Sending orders subscribe request. RequestID: 431228 2026-04-15 19:51:09.326 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEV25. Search Symbol: F.US.CLEV25. Request ID: 431226. Contract ID: 3. 2026-04-15 19:51:09.371 | Denali Data Feed | Setting DTC encoding to Binary VLS 2026-04-15 19:51:09.371 | Denali Data Feed | Sending logon request message. 2026-04-15 19:51:09.608 | Mapping F.US.EPH23 to ESH23. Service code: cme 2026-04-15 19:51:09.608 | Denali Data Feed | Starting real-time market data updates for: F.US.EPH23 (ESH23). ID: 4 Service code: cme 2026-04-15 19:51:09.608 | CQG WebAPI | Sending symbol resolution request for F.US.EPH23. ID: 431229 2026-04-15 19:51:09.608 | Denali Data Feed | Requesting security definition data for: F.US.EPH23 (ESH23). ID: 4 2026-04-15 19:51:09.608 | Mapping F.US.EPM23 to ESM23. Service code: cme 2026-04-15 19:51:09.609 | Denali Data Feed | Starting real-time market data updates for: F.US.EPM23 (ESM23). ID: 5 Service code: cme 2026-04-15 19:51:09.609 | CQG WebAPI | Sending symbol resolution request for F.US.EPM23. ID: 431230 2026-04-15 19:51:09.609 | Denali Data Feed | Requesting security definition data for: F.US.EPM23 (ESM23). ID: 5 2026-04-15 19:51:09.609 | Mapping F.US.EPU23 to ESU23. Service code: cme 2026-04-15 19:51:09.609 | Denali Data Feed | Starting real-time market data updates for: F.US.EPU23 (ESU23). ID: 6 Service code: cme 2026-04-15 19:51:09.609 | CQG WebAPI | Sending symbol resolution request for F.US.EPU23. ID: 431231 2026-04-15 19:51:09.609 | Denali Data Feed | Requesting security definition data for: F.US.EPU23 (ESU23). ID: 6 2026-04-15 19:51:09.609 | Mapping F.US.EPZ23 to ESZ23. Service code: cme 2026-04-15 19:51:09.609 | Denali Data Feed | Starting real-time market data updates for: F.US.EPZ23 (ESZ23). ID: 7 Service code: cme 2026-04-15 19:51:09.609 | CQG WebAPI | Sending symbol resolution request for F.US.EPZ23. ID: 431232 2026-04-15 19:51:09.609 | Denali Data Feed | Requesting security definition data for: F.US.EPZ23 (ESZ23). ID: 7 2026-04-15 19:51:09.609 | Mapping F.US.EPH24 to ESH24. Service code: cme 2026-04-15 19:51:09.609 | Denali Data Feed | Starting real-time market data updates for: F.US.EPH24 (ESH24). ID: 8 Service code: cme 2026-04-15 19:51:09.609 | CQG WebAPI | Sending symbol resolution request for F.US.EPH24. ID: 431233 2026-04-15 19:51:09.610 | Denali Data Feed | Requesting security definition data for: F.US.EPH24 (ESH24). ID: 8 2026-04-15 19:51:09.610 | Mapping F.US.CLEF23 to CLF23. Service code: nymex 2026-04-15 19:51:09.610 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEF23 (CLF23). ID: 9 Service code: nymex 2026-04-15 19:51:09.610 | CQG WebAPI | Sending symbol resolution request for F.US.CLEF23. ID: 431234 2026-04-15 19:51:09.610 | Denali Data Feed | Requesting security definition data for: F.US.CLEF23 (CLF23). ID: 9 2026-04-15 19:51:09.610 | Mapping F.US.CLEG23 to CLG23. Service code: nymex 2026-04-15 19:51:09.610 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEG23 (CLG23). ID: 10 Service code: nymex 2026-04-15 19:51:09.610 | CQG WebAPI | Sending symbol resolution request for F.US.CLEG23. ID: 431235 2026-04-15 19:51:09.610 | Denali Data Feed | Requesting security definition data for: F.US.CLEG23 (CLG23). ID: 10 2026-04-15 19:51:09.610 | Mapping F.US.CLEH23 to CLH23. Service code: nymex 2026-04-15 19:51:09.610 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEH23 (CLH23). ID: 11 Service code: nymex 2026-04-15 19:51:09.610 | CQG WebAPI | Sending symbol resolution request for F.US.CLEH23. ID: 431236 2026-04-15 19:51:09.610 | Denali Data Feed | Requesting security definition data for: F.US.CLEH23 (CLH23). ID: 11 2026-04-15 19:51:09.611 | Mapping F.US.CLEJ23 to CLJ23. Service code: nymex 2026-04-15 19:51:09.611 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEJ23 (CLJ23). ID: 12 Service code: nymex 2026-04-15 19:51:09.611 | CQG WebAPI | Sending symbol resolution request for F.US.CLEJ23. ID: 431237 2026-04-15 19:51:09.611 | Denali Data Feed | Requesting security definition data for: F.US.CLEJ23 (CLJ23). ID: 12 2026-04-15 19:51:09.611 | Mapping F.US.CLEK23 to CLK23. Service code: nymex 2026-04-15 19:51:09.611 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEK23 (CLK23). ID: 13 Service code: nymex 2026-04-15 19:51:09.611 | CQG WebAPI | Sending symbol resolution request for F.US.CLEK23. ID: 431238 2026-04-15 19:51:09.611 | Denali Data Feed | Requesting security definition data for: F.US.CLEK23 (CLK23). ID: 13 2026-04-15 19:51:09.611 | Mapping F.US.CLEM23 to CLM23. Service code: nymex 2026-04-15 19:51:09.611 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEM23 (CLM23). ID: 14 Service code: nymex 2026-04-15 19:51:09.611 | CQG WebAPI | Sending symbol resolution request for F.US.CLEM23. ID: 431239 2026-04-15 19:51:09.611 | Denali Data Feed | Requesting security definition data for: F.US.CLEM23 (CLM23). ID: 14 2026-04-15 19:51:09.612 | Mapping F.US.CLEN23 to CLN23. Service code: nymex 2026-04-15 19:51:09.612 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEN23 (CLN23). ID: 15 Service code: nymex 2026-04-15 19:51:09.612 | CQG WebAPI | Sending symbol resolution request for F.US.CLEN23. ID: 431240 2026-04-15 19:51:09.612 | Denali Data Feed | Requesting security definition data for: F.US.CLEN23 (CLN23). ID: 15 2026-04-15 19:51:09.612 | Mapping F.US.CLEQ23 to CLQ23. Service code: nymex 2026-04-15 19:51:09.612 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEQ23 (CLQ23). ID: 16 Service code: nymex 2026-04-15 19:51:09.612 | CQG WebAPI | Sending symbol resolution request for F.US.CLEQ23. ID: 431241 2026-04-15 19:51:09.612 | Denali Data Feed | Requesting security definition data for: F.US.CLEQ23 (CLQ23). ID: 16 2026-04-15 19:51:09.612 | Mapping F.US.CLEU23 to CLU23. Service code: nymex 2026-04-15 19:51:09.612 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEU23 (CLU23). ID: 17 Service code: nymex 2026-04-15 19:51:09.612 | CQG WebAPI | Sending symbol resolution request for F.US.CLEU23. ID: 431242 2026-04-15 19:51:09.612 | Denali Data Feed | Requesting security definition data for: F.US.CLEU23 (CLU23). ID: 17 2026-04-15 19:51:09.612 | Mapping F.US.CLEV23 to CLV23. Service code: nymex 2026-04-15 19:51:09.612 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEV23 (CLV23). ID: 18 Service code: nymex 2026-04-15 19:51:09.612 | CQG WebAPI | Sending symbol resolution request for F.US.CLEV23. ID: 431243 2026-04-15 19:51:09.612 | Denali Data Feed | Requesting security definition data for: F.US.CLEV23 (CLV23). ID: 18 2026-04-15 19:51:09.612 | Mapping F.US.CLEX23 to CLX23. Service code: nymex 2026-04-15 19:51:09.613 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEX23 (CLX23). ID: 19 Service code: nymex 2026-04-15 19:51:09.613 | CQG WebAPI | Sending symbol resolution request for F.US.CLEX23. ID: 431244 2026-04-15 19:51:09.613 | Denali Data Feed | Requesting security definition data for: F.US.CLEX23 (CLX23). ID: 19 2026-04-15 19:51:09.613 | Mapping F.US.CLEZ23 to CLZ23. Service code: nymex 2026-04-15 19:51:09.614 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEZ23 (CLZ23). ID: 20 Service code: nymex 2026-04-15 19:51:09.614 | CQG WebAPI | Sending symbol resolution request for F.US.CLEZ23. ID: 431245 2026-04-15 19:51:09.614 | Denali Data Feed | Requesting security definition data for: F.US.CLEZ23 (CLZ23). ID: 20 2026-04-15 19:51:09.614 | Mapping F.US.CLEF24 to CLF24. Service code: nymex 2026-04-15 19:51:09.614 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEF24 (CLF24). ID: 21 Service code: nymex 2026-04-15 19:51:09.614 | CQG WebAPI | Sending symbol resolution request for F.US.CLEF24. ID: 431246 2026-04-15 19:51:09.614 | Denali Data Feed | Requesting security definition data for: F.US.CLEF24 (CLF24). ID: 21 2026-04-15 19:51:09.614 | Mapping F.US.CLEG24 to CLG24. Service code: nymex 2026-04-15 19:51:09.614 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEG24 (CLG24). ID: 22 Service code: nymex 2026-04-15 19:51:09.614 | CQG WebAPI | Sending symbol resolution request for F.US.CLEG24. ID: 431247 2026-04-15 19:51:09.614 | Denali Data Feed | Requesting security definition data for: F.US.CLEG24 (CLG24). ID: 22 2026-04-15 19:51:09.709 | CQG WebAPI | Received symbol resolution report for symbol F.US.EPH23. Search Symbol: F.US.EPH23. Request ID: 431229. Contract ID: 4. 2026-04-15 19:51:09.709 | CQG WebAPI | Received symbol resolution report for symbol F.US.EPM23. Search Symbol: F.US.EPM23. Request ID: 431230. Contract ID: 5. 2026-04-15 19:51:09.709 | CQG WebAPI | Received symbol resolution report for symbol F.US.EPU23. Search Symbol: F.US.EPU23. Request ID: 431231. Contract ID: 6. 2026-04-15 19:51:09.784 | CQG WebAPI | Received symbol resolution report for symbol F.US.EPZ23. Search Symbol: F.US.EPZ23. Request ID: 431232. Contract ID: 7. 2026-04-15 19:51:09.784 | CQG WebAPI | Received symbol resolution report for symbol F.US.EPH24. Search Symbol: F.US.EPH24. Request ID: 431233. Contract ID: 8. 2026-04-15 19:51:09.784 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEF23. Search Symbol: F.US.CLEF23. Request ID: 431234. Contract ID: 9. 2026-04-15 19:51:09.784 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEG23. Search Symbol: F.US.CLEG23. Request ID: 431235. Contract ID: 10. 2026-04-15 19:51:09.798 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEH23. Search Symbol: F.US.CLEH23. Request ID: 431236. Contract ID: 11. 2026-04-15 19:51:09.798 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEM23. Search Symbol: F.US.CLEM23. Request ID: 431239. Contract ID: 12. 2026-04-15 19:51:09.798 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEJ23. Search Symbol: F.US.CLEJ23. Request ID: 431237. Contract ID: 13. 2026-04-15 19:51:09.798 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEN23. Search Symbol: F.US.CLEN23. Request ID: 431240. Contract ID: 14. 2026-04-15 19:51:09.798 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEU23. Search Symbol: F.US.CLEU23. Request ID: 431242. Contract ID: 15. 2026-04-15 19:51:09.798 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEQ23. Search Symbol: F.US.CLEQ23. Request ID: 431241. Contract ID: 16. 2026-04-15 19:51:09.798 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEV23. Search Symbol: F.US.CLEV23. Request ID: 431243. Contract ID: 17. 2026-04-15 19:51:09.798 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEK23. Search Symbol: F.US.CLEK23. Request ID: 431238. Contract ID: 18. 2026-04-15 19:51:09.798 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEZ23. Search Symbol: F.US.CLEZ23. Request ID: 431245. Contract ID: 19. 2026-04-15 19:51:09.798 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEF24. Search Symbol: F.US.CLEF24. Request ID: 431246. Contract ID: 20. 2026-04-15 19:51:09.804 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEG24. Search Symbol: F.US.CLEG24. Request ID: 431247. Contract ID: 21. 2026-04-15 19:51:09.804 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEX23. Search Symbol: F.US.CLEX23. Request ID: 431244. Contract ID: 22. 2026-04-15 19:51:09.928 | Denali Data Feed | Received logon response. 2026-04-15 19:51:09.928 | Denali Data Feed | Server Name: SC Realtime Server. 2026-04-15 19:51:09.928 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8 2026-04-15 19:51:09.928 | Denali Data Feed | Successfully connected. 2026-04-15 19:51:09.928 | Denali Data Feed | Trading is not supported. 2026-04-15 19:51:09.928 | Denali Data Feed | MarketDepthIsSupported: 1 2026-04-15 19:51:09.929 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.BP6U25 -> 6BU25 2026-04-15 19:51:09.929 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEF23 -> CLF23 2026-04-15 19:51:09.929 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEF24 -> CLF24 2026-04-15 19:51:09.929 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEG23 -> CLG23 2026-04-15 19:51:09.929 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEG24 -> CLG24 2026-04-15 19:51:09.929 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEH23 -> CLH23 2026-04-15 19:51:09.929 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEJ23 -> CLJ23 2026-04-15 19:51:09.929 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEK23 -> CLK23 2026-04-15 19:51:09.929 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEM23 -> CLM23 2026-04-15 19:51:09.929 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEN23 -> CLN23 2026-04-15 19:51:09.929 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEQ23 -> CLQ23 2026-04-15 19:51:09.929 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEU23 -> CLU23 2026-04-15 19:51:09.929 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEV23 -> CLV23 2026-04-15 19:51:09.929 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEV25 -> CLV25 2026-04-15 19:51:09.929 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEX23 -> CLX23 2026-04-15 19:51:09.929 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEZ23 -> CLZ23 2026-04-15 19:51:09.929 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.EPH23 -> ESH23 2026-04-15 19:51:09.929 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.EPH24 -> ESH24 2026-04-15 19:51:09.929 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.EPM23 -> ESM23 2026-04-15 19:51:09.929 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.EPU23 -> ESU23 2026-04-15 19:51:09.929 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.EPU25 -> ESU25 2026-04-15 19:51:09.929 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.EPZ23 -> ESZ23 2026-04-15 19:51:10.117 | Denali Data Feed | Real-time data for symbol F.US.BP6U25 is currently unavailable. 2026-04-15 19:51:10.117 | Denali Data Feed | Received security definition for symbol F.US.BP6U25 2026-04-15 19:51:10.117 | Denali Data Feed | Real-time data for symbol F.US.CLEF23 is currently unavailable. 2026-04-15 19:51:10.117 | Denali Data Feed | Received security definition for symbol F.US.CLEF23 2026-04-15 19:51:10.117 | Denali Data Feed | Real-time data for symbol F.US.CLEF24 is currently unavailable. 2026-04-15 19:51:10.117 | Denali Data Feed | Received security definition for symbol F.US.CLEF24 2026-04-15 19:51:10.117 | Denali Data Feed | Real-time data for symbol F.US.CLEG23 is currently unavailable. 2026-04-15 19:51:10.117 | Denali Data Feed | Received security definition for symbol F.US.CLEG23 2026-04-15 19:51:10.117 | Denali Data Feed | Real-time data for symbol F.US.CLEG24 is currently unavailable. 2026-04-15 19:51:10.117 | Denali Data Feed | Received security definition for symbol F.US.CLEG24 2026-04-15 19:51:10.117 | Denali Data Feed | Real-time data for symbol F.US.CLEH23 is currently unavailable. 2026-04-15 19:51:10.117 | Denali Data Feed | Received security definition for symbol F.US.CLEH23 2026-04-15 19:51:10.117 | Denali Data Feed | Real-time data for symbol F.US.CLEJ23 is currently unavailable. 2026-04-15 19:51:10.117 | Denali Data Feed | Received security definition for symbol F.US.CLEJ23 2026-04-15 19:51:10.117 | Denali Data Feed | Real-time data for symbol F.US.CLEK23 is currently unavailable. 2026-04-15 19:51:10.117 | Denali Data Feed | Received security definition for symbol F.US.CLEK23 2026-04-15 19:51:10.117 | Denali Data Feed | Real-time data for symbol F.US.CLEM23 is currently unavailable. 2026-04-15 19:51:10.117 | Denali Data Feed | Received security definition for symbol F.US.CLEM23 2026-04-15 19:51:10.117 | Denali Data Feed | Real-time data for symbol F.US.CLEN23 is currently unavailable. 2026-04-15 19:51:10.117 | Denali Data Feed | Received security definition for symbol F.US.CLEN23 2026-04-15 19:51:10.117 | Denali Data Feed | Real-time data for symbol F.US.CLEQ23 is currently unavailable. 2026-04-15 19:51:10.117 | Denali Data Feed | Received security definition for symbol F.US.CLEQ23 2026-04-15 19:51:10.117 | Denali Data Feed | Real-time data for symbol F.US.CLEU23 is currently unavailable. 2026-04-15 19:51:10.117 | Denali Data Feed | Received security definition for symbol F.US.CLEU23 2026-04-15 19:51:10.117 | Denali Data Feed | Real-time data for symbol F.US.CLEV23 is currently unavailable. 2026-04-15 19:51:10.117 | Denali Data Feed | Received security definition for symbol F.US.CLEV23 2026-04-15 19:51:10.117 | Denali Data Feed | Real-time data for symbol F.US.CLEV25 is currently unavailable. 2026-04-15 19:51:10.117 | Denali Data Feed | Received security definition for symbol F.US.CLEV25 2026-04-15 19:51:10.117 | Denali Data Feed | Real-time data for symbol F.US.CLEX23 is currently unavailable. 2026-04-15 19:51:10.117 | Denali Data Feed | Received security definition for symbol F.US.CLEX23 2026-04-15 19:51:10.117 | Denali Data Feed | Real-time data for symbol F.US.CLEZ23 is currently unavailable. 2026-04-15 19:51:10.117 | Denali Data Feed | Received security definition for symbol F.US.CLEZ23 2026-04-15 19:51:10.117 | Denali Data Feed | Real-time data for symbol F.US.EPH23 is currently unavailable. 2026-04-15 19:51:10.117 | Denali Data Feed | Received security definition for symbol F.US.EPH23 2026-04-15 19:51:10.117 | Denali Data Feed | Real-time data for symbol F.US.EPH24 is currently unavailable. 2026-04-15 19:51:10.117 | Denali Data Feed | Received security definition for symbol F.US.EPH24 2026-04-15 19:51:10.117 | Denali Data Feed | Real-time data for symbol F.US.EPM23 is currently unavailable. 2026-04-15 19:51:10.117 | Denali Data Feed | Received security definition for symbol F.US.EPM23 2026-04-15 19:51:10.117 | Denali Data Feed | Real-time data for symbol F.US.EPU23 is currently unavailable. 2026-04-15 19:51:10.117 | Denali Data Feed | Received security definition for symbol F.US.EPU23 2026-04-15 19:51:10.118 | Denali Data Feed | Real-time data for symbol F.US.EPU25 is currently unavailable. 2026-04-15 19:51:10.118 | Denali Data Feed | Received security definition for symbol F.US.EPU25 2026-04-15 19:51:10.118 | Denali Data Feed | Real-time data for symbol F.US.EPZ23 is currently unavailable. 2026-04-15 19:51:10.118 | Denali Data Feed | Received security definition for symbol F.US.EPZ23 2026-04-15 19:51:14.041 | Requesting market depth updates for: F.US.CLEV25 if supported. NumLevels=100 2026-04-15 19:51:14.241 | Denali Data Feed | Clearing market depth for F.US.CLEV25 2026-04-15 19:51:15.570 | HD Request # 15 | Downloading Intraday chart data for F.US.EPU25 to the file F.US.EPU25.scid. Service: cme 2026-04-15 19:51:15.590 | HD Request # 15 | Download start date-time: 2025-09-19 09:29:58.000000. File last date-time: 2025-09-19 09:29:58.698000 2026-04-15 19:51:15.593 | HD Request # 15 | Using server: ds26.sierracharts.com port 10150 2026-04-15 19:51:15.601 | Socket (4) | Creating socket. 2026-04-15 19:51:15.601 | Socket (4) | New receive buffer size: 0 2026-04-15 19:51:15.601 | Socket (4) | Connecting to IP: 64.152.155.17. 2026-04-15 19:51:15.780 | HD Request # 15 | Setting DTC encoding to Binary VLS 2026-04-15 19:51:15.780 | HD Request # 15 | Sending historical data logon request message. 2026-04-15 19:51:15.898 | HD Request # 15 | Requesting Intraday data. Start date-time: 2025-09-19 09:29:58. Record interval: 0. Symbol: ESU25 2026-04-15 19:51:15.987 | HD Request # 15 | Decompressing data. 2026-04-15 19:51:16.076 | HD Request # 15 | Receiving Intraday data for F.US.EPU25 starting at 2025-09-19 09:29:58.697000 2026-04-15 19:51:16.076 | Socket (4) | CloseSocket call. 2026-04-15 19:51:16.077 | Socket (4) | Shutdown started. Waiting for graceful close. 2026-04-15 19:51:16.077 | Historical data download thread signaled to stop. 2026-04-15 19:51:16.077 | HD Request # 15 | Received 5 Intraday data records from 2025-09-19 09:29:58.697000 to 2025-09-19 09:29:58.698000 (0.0 seconds. Delay: 208.4 days) and wrote 0 records for F.US.EPU25 2026-04-15 19:51:16.078 | HD Request # 15 | Add time&sales data | Remembered last file record date-time: 2025-09-19 13:29:58.698000 2026-04-15 19:51:16.078 | HD Request # 15 | Completion time: 1s. 2026-04-15 19:51:16.078 | HD Request # 15 | Intraday data download complete for F.US.EPU25. Unique request ID: 15 2026-04-15 19:51:16.078 | Removing historical data download ID 15. 2026-04-15 19:51:16.079 | Real-time Intraday chart data file updates started for F.US.EPU25 2026-04-15 19:51:16.079 | Intraday chart data file opened for F.US.EPU25 2026-04-15 19:51:16.079 | HD Request # 15 | Enabling Intraday chart updating for symbol. 2026-04-15 19:51:16.079 | 2026-04-15 19:51:16.079 | Triggering next historical data download in queue. 2026-04-15 19:51:16.079 | HD Request # 16 | Downloading Intraday chart data for F.US.BP6U25 to the file F.US.BP6U25.scid. Service: cme 2026-04-15 19:51:16.096 | HD Request # 16 | Download start date-time: 2025-09-15 10:02:50.000000. File last date-time: 2025-09-15 10:02:50.367000 2026-04-15 19:51:16.097 | HD Request # 16 | Using server: ds28.sierracharts.com port 10149 2026-04-15 19:51:16.106 | Socket (5) | Creating socket. 2026-04-15 19:51:16.106 | Socket (5) | New receive buffer size: 0 2026-04-15 19:51:16.106 | Socket (5) | Connecting to IP: 67.214.125.5. 2026-04-15 19:51:16.164 | Socket (4) | Socket gracefully closed by remote side. 2026-04-15 19:51:16.164 | Socket (4) | Closed. 2026-04-15 19:51:16.292 | HD Request # 16 | Setting DTC encoding to Binary VLS 2026-04-15 19:51:16.293 | HD Request # 16 | Sending historical data logon request message. 2026-04-15 19:51:16.415 | HD Request # 16 | Requesting Intraday data. Start date-time: 2025-09-15 10:02:50. Record interval: 0. Symbol: 6BU25 2026-04-15 19:51:16.508 | HD Request # 16 | Decompressing data. 2026-04-15 19:51:16.600 | HD Request # 16 | Receiving Intraday data for F.US.BP6U25 starting at 2025-09-15 10:02:50.367000 2026-04-15 19:51:16.600 | Socket (5) | CloseSocket call. 2026-04-15 19:51:16.600 | Socket (5) | Shutdown started. Waiting for graceful close. 2026-04-15 19:51:16.601 | Historical data download thread signaled to stop. 2026-04-15 19:51:16.601 | HD Request # 16 | Received 1 Intraday data record from 2025-09-15 10:02:50.367000 to 2025-09-15 10:02:50.367000 (0.0 seconds. Delay: 212.4 days) and wrote 0 records for F.US.BP6U25 2026-04-15 19:51:16.602 | HD Request # 16 | Add time&sales data | Remembered last file record date-time: 2025-09-15 14:02:50.367000 2026-04-15 19:51:16.602 | HD Request # 16 | Completion time: 0s. 2026-04-15 19:51:16.602 | HD Request # 16 | Intraday data download complete for F.US.BP6U25. Unique request ID: 16 2026-04-15 19:51:16.602 | Removing historical data download ID 16. 2026-04-15 19:51:16.602 | Real-time Intraday chart data file updates started for F.US.BP6U25 2026-04-15 19:51:16.602 | Intraday chart data file opened for F.US.BP6U25 2026-04-15 19:51:16.602 | HD Request # 16 | Enabling Intraday chart updating for symbol. 2026-04-15 19:51:16.602 | 2026-04-15 19:51:16.602 | Triggering next historical data download in queue. 2026-04-15 19:51:16.602 | HD Request # 17 | Downloading Intraday chart data for F.US.CLEV25 to the file F.US.CLEV25.scid. Service: nymex 2026-04-15 19:51:16.620 | HD Request # 17 | Download start date-time: 2025-09-22 14:29:55.000000. File last date-time: 2025-09-22 14:29:55.618000 2026-04-15 19:51:16.620 | HD Request # 17 | Using server: ds32.sierracharts.com port 10150 2026-04-15 19:51:16.631 | Socket (4) | Creating socket. 2026-04-15 19:51:16.631 | Socket (4) | New receive buffer size: 0 2026-04-15 19:51:16.631 | Socket (4) | Connecting to IP: 69.39.70.248. 2026-04-15 19:51:16.691 | Socket (5) | Socket gracefully closed by remote side. 2026-04-15 19:51:16.691 | Socket (5) | Closed. 2026-04-15 19:51:16.816 | HD Request # 17 | Setting DTC encoding to Binary VLS 2026-04-15 19:51:16.816 | HD Request # 17 | Sending historical data logon request message. 2026-04-15 19:51:16.938 | HD Request # 17 | Requesting Intraday data. Start date-time: 2025-09-22 14:29:55. Record interval: 0. Symbol: CLV25 2026-04-15 19:51:17.035 | HD Request # 17 | Decompressing data. 2026-04-15 19:51:17.126 | HD Request # 17 | Receiving Intraday data for F.US.CLEV25 starting at 2025-09-22 14:29:55.086000 2026-04-15 19:51:17.126 | Socket (4) | CloseSocket call. 2026-04-15 19:51:17.126 | Socket (4) | Shutdown started. Waiting for graceful close. 2026-04-15 19:51:17.127 | Historical data download thread signaled to stop. 2026-04-15 19:51:17.127 | HD Request # 17 | Received 2 Intraday data records from 2025-09-22 14:29:55.086000 to 2025-09-22 14:29:55.618000 (0.5 seconds. Delay: 205.2 days) and wrote 0 records for F.US.CLEV25 2026-04-15 19:51:17.127 | HD Request # 17 | Add time&sales data | Remembered last file record date-time: 2025-09-22 18:29:55.618000 2026-04-15 19:51:17.127 | HD Request # 17 | Completion time: 1s. 2026-04-15 19:51:17.127 | HD Request # 17 | Intraday data download complete for F.US.CLEV25. Unique request ID: 17 2026-04-15 19:51:17.127 | Removing historical data download ID 17. 2026-04-15 19:51:17.128 | Real-time Intraday chart data file updates started for F.US.CLEV25 2026-04-15 19:51:17.128 | Intraday chart data file opened for F.US.CLEV25 2026-04-15 19:51:17.128 | HD Request # 17 | Enabling Intraday chart updating for symbol. 2026-04-15 19:51:17.128 | 2026-04-15 19:51:17.128 | No download requests in the queue to start downloads for. 2026-04-15 19:51:17.217 | Socket (4) | Socket gracefully closed by remote side. 2026-04-15 19:51:17.217 | Socket (4) | Closed. 2026-04-15 19:51:29.542 | CQG WebSocket socket (1) | Write has completed. Shutdown being performed. 2026-04-15 19:51:29.542 | CQG WebSocket socket (1) | Shutdown started. Waiting for graceful close. 2026-04-15 19:51:29.543 | CQG WebSocket socket (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. * 2026-04-15 19:51:29.543 | CQG WebSocket socket (1) | Socket gracefully closed by remote side. 2026-04-15 19:51:29.543 | CQG WebSocket socket (1) | Closed. 2026-04-15 22:26:14.636 | The data feed was lost. There was no activity for at least 60.0 seconds. 2026-04-15 22:26:14.636 | Connection to the external service has been lost. 2026-04-15 22:26:14.672 | CQG WebSocket | Timeout waiting for pong message from server. 2026-04-15 22:26:14.672 | CQG WebAPI | WebSocket closed. 2026-04-15 22:26:14.672 | Denali Data Feed | There has been no activity on the network socket for 1h 35m 6s. Will reconnect. 2026-04-15 22:26:14.672 | Denali Data Feed | Waiting for socket receive thread to end 2026-04-15 22:26:14.673 | DTC Client socket (3) | CloseSocket call. 2026-04-15 22:26:14.673 | DTC Client socket (3) | Max send buffers used during socket life: 4 2026-04-15 22:26:14.673 | DTC Client socket (3) | Max send buffer size during socket life: 1556 2026-04-15 22:26:14.673 | Denali Data Feed | Disconnected from the server. 2026-04-15 22:26:14.673 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds. 2026-04-15 22:26:14.673 | CQG WebAPI | Sending Web API Logoff message. 2026-04-15 22:26:14.673 | CQG WebSocket socket (2) | CloseSocket call. 2026-04-15 22:26:14.673 | CQG WebSocket socket (2) | Max send buffers used during socket life: 3 2026-04-15 22:26:14.673 | CQG WebSocket socket (2) | Max send buffer size during socket life: 595 2026-04-15 22:26:14.673 | CQG WebSocket | WebSocket closed. 2026-04-15 22:26:14.673 | CQG WebAPI | WebSocket closed. 2026-04-15 22:26:14.673 | CQG WebAPI | Disconnected. 2026-04-15 22:26:14.673 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-04-15 22:26:14.690 | DTC Client socket (3) | Shutdown started. Waiting for graceful close. 2026-04-15 22:26:14.690 | CQG WebSocket socket (2) | Write in progress. Shutdown being delayed. PendingSize=0 2026-04-16 02:41:55.887 | DTC Client socket (3) | Socket gracefully closed by remote side. 2026-04-16 02:41:55.888 | DTC Client socket (3) | Closed. 2026-04-16 02:41:55.892 | CQG WebSocket socket (2) | Write has completed. Shutdown being performed. 2026-04-16 02:41:55.892 | CQG WebSocket socket (2) | Shutdown started. Waiting for graceful close. 2026-04-16 02:41:55.892 | CQG WebSocket socket (2) | Socket gracefully closed by remote side. 2026-04-16 02:41:55.892 | CQG WebSocket socket (2) | Closed. 2026-04-16 02:41:55.934 | Denali Data Feed | Connecting to the server ds7-2.sierracharts.com. Port 443 2026-04-16 02:41:55.934 | 2026-04-16 02:41:55.934 | CQG WebAPI | Connecting to server api.cqg.com 2026-04-16 02:41:55.934 | CQG WebSocket | Connecting to WebSocket server api.cqg.com:443 2026-04-16 02:41:56.366 | DTC Client socket (3) | Creating socket. 2026-04-16 02:41:56.366 | DTC Client socket (3) | New receive buffer size: 0 2026-04-16 02:41:56.366 | DTC Client socket (3) | Connecting to IP: 69.39.70.254. 2026-04-16 02:41:56.494 | CQG WebSocket socket (5) | Creating socket. Using TLS 1.2. 2026-04-16 02:41:56.494 | Denali Data Feed | Network connection to server complete. 2026-04-16 02:41:56.494 | Denali Data Feed | Starting socket receive thread. 2026-04-16 02:41:56.494 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard 2026-04-16 02:41:56.494 | CQG WebSocket socket (5) | New receive buffer size: 0 2026-04-16 02:41:56.494 | CQG WebSocket socket (5) | Connecting to IP: 195.166.124.175. 2026-04-16 02:41:56.504 | CQG WebSocket | Opening WebSocket. 2026-04-16 02:41:56.504 | CQG WebSocket | Sending WebSocket handshake. 2026-04-16 02:41:56.551 | CQG WebSocket | Server header | HTTP/1.1 101 Switching Protocols 2026-04-16 02:41:56.551 | CQG WebSocket | Server header | Connection: Upgrade 2026-04-16 02:41:56.551 | CQG WebSocket | Server header | Sec-WebSocket-Accept: PJdetgRgPvn1buERN8YLErtC/eg= 2026-04-16 02:41:56.551 | CQG WebSocket | Server header | Server: WebSocket++/0.8.2 2026-04-16 02:41:56.551 | CQG WebSocket | Server header | Upgrade: websocket 2026-04-16 02:41:56.551 | CQG WebSocket | Server header | 2026-04-16 02:41:56.551 | CQG WebSocket | Web socket state is now open. 2026-04-16 02:41:56.551 | CQG WebAPI | WebSocket connected. 2026-04-16 02:41:56.551 | CQG WebAPI | Sending market data logon message. 2026-04-16 02:41:56.606 | Denali Data Feed | Setting DTC encoding to Binary VLS 2026-04-16 02:41:56.606 | Denali Data Feed | Sending logon request message. 2026-04-16 02:41:56.827 | CQG WebAPI | Base Time: 2026-03-28T06:33:36. 2026-03-28 06:33:36 2026-04-16 02:41:56.827 | CQG WebAPI | Logon successful. Session Token = Cho7kY1CAi9Aum0tundamF3C0FWjw+HlC5smG5roiVoXiYUmofczUcVdhAts9mHBSRLCgjg9csf 2026-04-16 02:41:56.827 | CQG WebAPI | Connection to server complete. 2026-04-16 02:41:56.827 | Denali Data Feed | Waiting for socket receive thread to end 2026-04-16 02:41:56.827 | DTC Client socket (3) | CloseSocket call. 2026-04-16 02:41:56.828 | DTC Client socket (3) | Shutdown started. Waiting for graceful close. 2026-04-16 02:41:56.828 | Denali Data Feed | Disconnected from the server. 2026-04-16 02:41:56.830 | No download requests in the queue to start downloads for. | Number times message added: 3 2026-04-16 02:41:56.830 | Updated verified funded futures trading account ending date to: 2026-05-16 06:41:56 2026-04-16 02:41:56.852 | CQG WebAPI | Sending Trade Accounts request message. 2026-04-16 02:41:56.853 | Mapping F.US.EPU25 to ESU25. Service code: cme 2026-04-16 02:41:56.853 | Using symbol data fast lookup vector 2026-04-16 02:41:56.853 | Denali Data Feed | Starting real-time market data updates for: F.US.EPU25 (ESU25). ID: 1 Service code: cme 2026-04-16 02:41:56.853 | Denali Data Feed | Connecting to the server ds32-2.sierracharts.com. Port 10048 2026-04-16 02:41:56.854 | CQG WebAPI | Sending symbol resolution request for F.US.EPU25. ID: 431249 2026-04-16 02:41:56.854 | Denali Data Feed | Requesting security definition data for: F.US.EPU25 (ESU25). ID: 1 2026-04-16 02:41:56.854 | Added historical Intraday data request for F.US.EPU25 to the queue. 2026-04-16 02:41:56.854 | Intraday data recording state for symbol F.US.EPU25 is set to download 'Pending'. 2026-04-16 02:41:56.854 | Triggering next historical data download in queue. 2026-04-16 02:41:56.854 | Delaying start of download for F.US.EPU25. 2026-04-16 02:41:56.854 | Mapping F.US.BP6U25 to 6BU25. Service code: cme 2026-04-16 02:41:56.855 | Denali Data Feed | Starting real-time market data updates for: F.US.BP6U25 (6BU25). ID: 2 Service code: cme 2026-04-16 02:41:56.855 | CQG WebAPI | Sending symbol resolution request for F.US.BP6U25. ID: 431250 2026-04-16 02:41:56.855 | Denali Data Feed | Requesting security definition data for: F.US.BP6U25 (6BU25). ID: 2 2026-04-16 02:41:56.855 | Added historical Intraday data request for F.US.BP6U25 to the queue. 2026-04-16 02:41:56.855 | Intraday data recording state for symbol F.US.BP6U25 is set to download 'Pending'. 2026-04-16 02:41:56.855 | Triggering next historical data download in queue. 2026-04-16 02:41:56.905 | Mapping F.US.CLEV25 to CLV25. Service code: nymex 2026-04-16 02:41:56.905 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEV25 (CLV25). ID: 3 Service code: nymex 2026-04-16 02:41:56.905 | CQG WebAPI | Sending symbol resolution request for F.US.CLEV25. ID: 431251 2026-04-16 02:41:56.905 | Denali Data Feed | Requesting security definition data for: F.US.CLEV25 (CLV25). ID: 3 2026-04-16 02:41:56.905 | Added historical Intraday data request for F.US.CLEV25 to the queue. 2026-04-16 02:41:56.905 | Intraday data recording state for symbol F.US.CLEV25 is set to download 'Pending'. 2026-04-16 02:41:56.905 | Triggering next historical data download in queue. 2026-04-16 02:41:56.932 | CQG WebAPI | Received symbol resolution report for symbol F.US.EPU25. Search Symbol: F.US.EPU25. Request ID: 431249. Contract ID: 1. 2026-04-16 02:41:56.932 | CQG WebAPI | Brokerage name: AMP. Account Name: 220033 2026-04-16 02:41:56.932 | Updated verified funded futures trading account ending date to: 2026-05-16 06:41:56 2026-04-16 02:41:56.932 | CQG WebAPI | Sending collateral subscribe request. 2026-04-16 02:41:56.934 | DTC Client socket (3) | Socket gracefully closed by remote side. 2026-04-16 02:41:56.934 | DTC Client socket (3) | Closed. 2026-04-16 02:41:56.961 | CQG WebAPI | Received symbol resolution report for symbol F.US.BP6U25. Search Symbol: F.US.BP6U25. Request ID: 431250. Contract ID: 2. 2026-04-16 02:41:57.018 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEV25. Search Symbol: F.US.CLEV25. Request ID: 431251. Contract ID: 3. 2026-04-16 02:41:57.078 | CQG WebAPI | Sending positions subscribe request. RequestID: 431253 2026-04-16 02:41:57.078 | CQG WebAPI | Sending orders subscribe request. RequestID: 431254 2026-04-16 02:41:57.552 | Mapping F.US.EPH23 to ESH23. Service code: cme 2026-04-16 02:41:57.552 | Denali Data Feed | Starting real-time market data updates for: F.US.EPH23 (ESH23). ID: 4 Service code: cme 2026-04-16 02:41:57.552 | CQG WebAPI | Sending symbol resolution request for F.US.EPH23. ID: 431255 2026-04-16 02:41:57.552 | Denali Data Feed | Requesting security definition data for: F.US.EPH23 (ESH23). ID: 4 2026-04-16 02:41:57.553 | Mapping F.US.EPM23 to ESM23. Service code: cme 2026-04-16 02:41:57.553 | Denali Data Feed | Starting real-time market data updates for: F.US.EPM23 (ESM23). ID: 5 Service code: cme 2026-04-16 02:41:57.553 | CQG WebAPI | Sending symbol resolution request for F.US.EPM23. ID: 431256 2026-04-16 02:41:57.553 | Denali Data Feed | Requesting security definition data for: F.US.EPM23 (ESM23). ID: 5 2026-04-16 02:41:57.553 | Mapping F.US.EPU23 to ESU23. Service code: cme 2026-04-16 02:41:57.553 | Denali Data Feed | Starting real-time market data updates for: F.US.EPU23 (ESU23). ID: 6 Service code: cme 2026-04-16 02:41:57.553 | CQG WebAPI | Sending symbol resolution request for F.US.EPU23. ID: 431257 2026-04-16 02:41:57.553 | Denali Data Feed | Requesting security definition data for: F.US.EPU23 (ESU23). ID: 6 2026-04-16 02:41:57.553 | Mapping F.US.EPZ23 to ESZ23. Service code: cme 2026-04-16 02:41:57.553 | Denali Data Feed | Starting real-time market data updates for: F.US.EPZ23 (ESZ23). ID: 7 Service code: cme 2026-04-16 02:41:57.553 | CQG WebAPI | Sending symbol resolution request for F.US.EPZ23. ID: 431258 2026-04-16 02:41:57.553 | Denali Data Feed | Requesting security definition data for: F.US.EPZ23 (ESZ23). ID: 7 2026-04-16 02:41:57.553 | Mapping F.US.EPH24 to ESH24. Service code: cme 2026-04-16 02:41:57.554 | Denali Data Feed | Starting real-time market data updates for: F.US.EPH24 (ESH24). ID: 8 Service code: cme 2026-04-16 02:41:57.554 | CQG WebAPI | Sending symbol resolution request for F.US.EPH24. ID: 431259 2026-04-16 02:41:57.554 | Denali Data Feed | Requesting security definition data for: F.US.EPH24 (ESH24). ID: 8 2026-04-16 02:41:57.554 | Mapping F.US.CLEF23 to CLF23. Service code: nymex 2026-04-16 02:41:57.554 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEF23 (CLF23). ID: 9 Service code: nymex 2026-04-16 02:41:57.554 | CQG WebAPI | Sending symbol resolution request for F.US.CLEF23. ID: 431260 2026-04-16 02:41:57.554 | Denali Data Feed | Requesting security definition data for: F.US.CLEF23 (CLF23). ID: 9 2026-04-16 02:41:57.554 | Mapping F.US.CLEG23 to CLG23. Service code: nymex 2026-04-16 02:41:57.554 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEG23 (CLG23). ID: 10 Service code: nymex 2026-04-16 02:41:57.554 | CQG WebAPI | Sending symbol resolution request for F.US.CLEG23. ID: 431261 2026-04-16 02:41:57.554 | Denali Data Feed | Requesting security definition data for: F.US.CLEG23 (CLG23). ID: 10 2026-04-16 02:41:57.554 | Mapping F.US.CLEH23 to CLH23. Service code: nymex 2026-04-16 02:41:57.554 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEH23 (CLH23). ID: 11 Service code: nymex 2026-04-16 02:41:57.554 | CQG WebAPI | Sending symbol resolution request for F.US.CLEH23. ID: 431262 2026-04-16 02:41:57.554 | Denali Data Feed | Requesting security definition data for: F.US.CLEH23 (CLH23). ID: 11 2026-04-16 02:41:57.554 | Mapping F.US.CLEJ23 to CLJ23. Service code: nymex 2026-04-16 02:41:57.554 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEJ23 (CLJ23). ID: 12 Service code: nymex 2026-04-16 02:41:57.554 | CQG WebAPI | Sending symbol resolution request for F.US.CLEJ23. ID: 431263 2026-04-16 02:41:57.554 | Denali Data Feed | Requesting security definition data for: F.US.CLEJ23 (CLJ23). ID: 12 2026-04-16 02:41:57.555 | Mapping F.US.CLEK23 to CLK23. Service code: nymex 2026-04-16 02:41:57.555 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEK23 (CLK23). ID: 13 Service code: nymex 2026-04-16 02:41:57.555 | CQG WebAPI | Sending symbol resolution request for F.US.CLEK23. ID: 431264 2026-04-16 02:41:57.555 | Denali Data Feed | Requesting security definition data for: F.US.CLEK23 (CLK23). ID: 13 2026-04-16 02:41:57.555 | Mapping F.US.CLEM23 to CLM23. Service code: nymex 2026-04-16 02:41:57.555 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEM23 (CLM23). ID: 14 Service code: nymex 2026-04-16 02:41:57.555 | CQG WebAPI | Sending symbol resolution request for F.US.CLEM23. ID: 431265 2026-04-16 02:41:57.555 | Denali Data Feed | Requesting security definition data for: F.US.CLEM23 (CLM23). ID: 14 2026-04-16 02:41:57.555 | Mapping F.US.CLEN23 to CLN23. Service code: nymex 2026-04-16 02:41:57.555 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEN23 (CLN23). ID: 15 Service code: nymex 2026-04-16 02:41:57.555 | CQG WebAPI | Sending symbol resolution request for F.US.CLEN23. ID: 431266 2026-04-16 02:41:57.555 | Denali Data Feed | Requesting security definition data for: F.US.CLEN23 (CLN23). ID: 15 2026-04-16 02:41:57.555 | Mapping F.US.CLEQ23 to CLQ23. Service code: nymex 2026-04-16 02:41:57.555 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEQ23 (CLQ23). ID: 16 Service code: nymex 2026-04-16 02:41:57.555 | CQG WebAPI | Sending symbol resolution request for F.US.CLEQ23. ID: 431267 2026-04-16 02:41:57.555 | Denali Data Feed | Requesting security definition data for: F.US.CLEQ23 (CLQ23). ID: 16 2026-04-16 02:41:57.555 | Mapping F.US.CLEU23 to CLU23. Service code: nymex 2026-04-16 02:41:57.556 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEU23 (CLU23). ID: 17 Service code: nymex 2026-04-16 02:41:57.556 | CQG WebAPI | Sending symbol resolution request for F.US.CLEU23. ID: 431268 2026-04-16 02:41:57.556 | Denali Data Feed | Requesting security definition data for: F.US.CLEU23 (CLU23). ID: 17 2026-04-16 02:41:57.556 | Mapping F.US.CLEV23 to CLV23. Service code: nymex 2026-04-16 02:41:57.556 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEV23 (CLV23). ID: 18 Service code: nymex 2026-04-16 02:41:57.556 | CQG WebAPI | Sending symbol resolution request for F.US.CLEV23. ID: 431269 2026-04-16 02:41:57.556 | Denali Data Feed | Requesting security definition data for: F.US.CLEV23 (CLV23). ID: 18 2026-04-16 02:41:57.556 | Mapping F.US.CLEX23 to CLX23. Service code: nymex 2026-04-16 02:41:57.556 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEX23 (CLX23). ID: 19 Service code: nymex 2026-04-16 02:41:57.556 | CQG WebAPI | Sending symbol resolution request for F.US.CLEX23. ID: 431270 2026-04-16 02:41:57.556 | Denali Data Feed | Requesting security definition data for: F.US.CLEX23 (CLX23). ID: 19 2026-04-16 02:41:57.556 | Mapping F.US.CLEZ23 to CLZ23. Service code: nymex 2026-04-16 02:41:57.556 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEZ23 (CLZ23). ID: 20 Service code: nymex 2026-04-16 02:41:57.556 | CQG WebAPI | Sending symbol resolution request for F.US.CLEZ23. ID: 431271 2026-04-16 02:41:57.556 | Denali Data Feed | Requesting security definition data for: F.US.CLEZ23 (CLZ23). ID: 20 2026-04-16 02:41:57.556 | Mapping F.US.CLEF24 to CLF24. Service code: nymex 2026-04-16 02:41:57.556 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEF24 (CLF24). ID: 21 Service code: nymex 2026-04-16 02:41:57.556 | CQG WebAPI | Sending symbol resolution request for F.US.CLEF24. ID: 431272 2026-04-16 02:41:57.556 | Denali Data Feed | Requesting security definition data for: F.US.CLEF24 (CLF24). ID: 21 2026-04-16 02:41:57.556 | Mapping F.US.CLEG24 to CLG24. Service code: nymex 2026-04-16 02:41:57.556 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEG24 (CLG24). ID: 22 Service code: nymex 2026-04-16 02:41:57.556 | CQG WebAPI | Sending symbol resolution request for F.US.CLEG24. ID: 431273 2026-04-16 02:41:57.556 | Denali Data Feed | Requesting security definition data for: F.US.CLEG24 (CLG24). ID: 22 2026-04-16 02:41:57.645 | CQG WebAPI | Received symbol resolution report for symbol F.US.EPH23. Search Symbol: F.US.EPH23. Request ID: 431255. Contract ID: 4. 2026-04-16 02:41:57.645 | CQG WebAPI | Received symbol resolution report for symbol F.US.EPU23. Search Symbol: F.US.EPU23. Request ID: 431257. Contract ID: 5. 2026-04-16 02:41:57.645 | CQG WebAPI | Received symbol resolution report for symbol F.US.EPM23. Search Symbol: F.US.EPM23. Request ID: 431256. Contract ID: 6. 2026-04-16 02:41:57.739 | CQG WebAPI | Received symbol resolution report for symbol F.US.EPZ23. Search Symbol: F.US.EPZ23. Request ID: 431258. Contract ID: 7. 2026-04-16 02:41:57.739 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEF23. Search Symbol: F.US.CLEF23. Request ID: 431260. Contract ID: 8. 2026-04-16 02:41:57.739 | CQG WebAPI | Received symbol resolution report for symbol F.US.EPH24. Search Symbol: F.US.EPH24. Request ID: 431259. Contract ID: 9. 2026-04-16 02:41:57.739 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEG23. Search Symbol: F.US.CLEG23. Request ID: 431261. Contract ID: 10. 2026-04-16 02:41:57.739 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEH23. Search Symbol: F.US.CLEH23. Request ID: 431262. Contract ID: 11. 2026-04-16 02:41:57.739 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEN23. Search Symbol: F.US.CLEN23. Request ID: 431266. Contract ID: 12. 2026-04-16 02:41:57.739 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEM23. Search Symbol: F.US.CLEM23. Request ID: 431265. Contract ID: 13. 2026-04-16 02:41:57.739 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEK23. Search Symbol: F.US.CLEK23. Request ID: 431264. Contract ID: 14. 2026-04-16 02:41:57.739 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEJ23. Search Symbol: F.US.CLEJ23. Request ID: 431263. Contract ID: 15. 2026-04-16 02:41:57.739 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEQ23. Search Symbol: F.US.CLEQ23. Request ID: 431267. Contract ID: 16. 2026-04-16 02:41:57.752 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEX23. Search Symbol: F.US.CLEX23. Request ID: 431270. Contract ID: 17. 2026-04-16 02:41:57.752 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEU23. Search Symbol: F.US.CLEU23. Request ID: 431268. Contract ID: 18. 2026-04-16 02:41:57.752 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEZ23. Search Symbol: F.US.CLEZ23. Request ID: 431271. Contract ID: 19. 2026-04-16 02:41:57.752 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEF24. Search Symbol: F.US.CLEF24. Request ID: 431272. Contract ID: 20. 2026-04-16 02:41:57.752 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEG24. Search Symbol: F.US.CLEG24. Request ID: 431273. Contract ID: 21. 2026-04-16 02:41:57.752 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEV23. Search Symbol: F.US.CLEV23. Request ID: 431269. Contract ID: 22. 2026-04-16 02:41:57.928 | DTC Client socket (4) | Creating socket. 2026-04-16 02:41:57.928 | DTC Client socket (4) | New receive buffer size: 0 2026-04-16 02:41:57.928 | DTC Client socket (4) | Connecting to IP: 69.39.70.249. 2026-04-16 02:41:58.024 | Denali Data Feed | Network connection to server complete. 2026-04-16 02:41:58.024 | Denali Data Feed | Starting socket receive thread. 2026-04-16 02:41:58.024 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard 2026-04-16 02:41:58.130 | Denali Data Feed | Setting DTC encoding to Binary VLS 2026-04-16 02:41:58.130 | Denali Data Feed | Sending logon request message. 2026-04-16 02:41:58.694 | Denali Data Feed | Received logon response. 2026-04-16 02:41:58.694 | Denali Data Feed | Server Name: SC Realtime Server. 2026-04-16 02:41:58.694 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8 2026-04-16 02:41:58.694 | Denali Data Feed | Successfully connected. 2026-04-16 02:41:58.694 | Denali Data Feed | Trading is not supported. 2026-04-16 02:41:58.694 | Denali Data Feed | MarketDepthIsSupported: 1 2026-04-16 02:41:58.694 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.BP6U25 -> 6BU25 2026-04-16 02:41:58.694 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEF23 -> CLF23 2026-04-16 02:41:58.694 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEF24 -> CLF24 2026-04-16 02:41:58.694 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEG23 -> CLG23 2026-04-16 02:41:58.694 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEG24 -> CLG24 2026-04-16 02:41:58.694 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEH23 -> CLH23 2026-04-16 02:41:58.694 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEJ23 -> CLJ23 2026-04-16 02:41:58.694 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEK23 -> CLK23 2026-04-16 02:41:58.694 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEM23 -> CLM23 2026-04-16 02:41:58.694 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEN23 -> CLN23 2026-04-16 02:41:58.694 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEQ23 -> CLQ23 2026-04-16 02:41:58.694 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEU23 -> CLU23 2026-04-16 02:41:58.694 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEV23 -> CLV23 2026-04-16 02:41:58.694 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEV25 -> CLV25 2026-04-16 02:41:58.694 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEX23 -> CLX23 2026-04-16 02:41:58.694 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEZ23 -> CLZ23 2026-04-16 02:41:58.694 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.EPH23 -> ESH23 2026-04-16 02:41:58.694 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.EPH24 -> ESH24 2026-04-16 02:41:58.694 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.EPM23 -> ESM23 2026-04-16 02:41:58.694 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.EPU23 -> ESU23 2026-04-16 02:41:58.694 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.EPU25 -> ESU25 2026-04-16 02:41:58.694 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.EPZ23 -> ESZ23 2026-04-16 02:41:58.891 | Denali Data Feed | Real-time data for symbol F.US.BP6U25 is currently unavailable. 2026-04-16 02:41:58.891 | Denali Data Feed | Received security definition for symbol F.US.BP6U25 2026-04-16 02:41:58.891 | Denali Data Feed | Real-time data for symbol F.US.CLEF23 is currently unavailable. 2026-04-16 02:41:58.891 | Denali Data Feed | Received security definition for symbol F.US.CLEF23 2026-04-16 02:41:58.891 | Denali Data Feed | Real-time data for symbol F.US.CLEF24 is currently unavailable. 2026-04-16 02:41:58.891 | Denali Data Feed | Received security definition for symbol F.US.CLEF24 2026-04-16 02:41:58.891 | Denali Data Feed | Real-time data for symbol F.US.CLEG23 is currently unavailable. 2026-04-16 02:41:58.891 | Denali Data Feed | Received security definition for symbol F.US.CLEG23 2026-04-16 02:41:58.891 | Denali Data Feed | Real-time data for symbol F.US.CLEG24 is currently unavailable. 2026-04-16 02:41:58.891 | Denali Data Feed | Received security definition for symbol F.US.CLEG24 2026-04-16 02:41:58.891 | Denali Data Feed | Real-time data for symbol F.US.CLEH23 is currently unavailable. 2026-04-16 02:41:58.891 | Denali Data Feed | Received security definition for symbol F.US.CLEH23 2026-04-16 02:41:58.891 | Denali Data Feed | Real-time data for symbol F.US.CLEJ23 is currently unavailable. 2026-04-16 02:41:58.891 | Denali Data Feed | Received security definition for symbol F.US.CLEJ23 2026-04-16 02:41:58.891 | Denali Data Feed | Real-time data for symbol F.US.CLEK23 is currently unavailable. 2026-04-16 02:41:58.891 | Denali Data Feed | Received security definition for symbol F.US.CLEK23 2026-04-16 02:41:58.891 | Denali Data Feed | Real-time data for symbol F.US.CLEM23 is currently unavailable. 2026-04-16 02:41:58.891 | Denali Data Feed | Received security definition for symbol F.US.CLEM23 2026-04-16 02:41:58.891 | Denali Data Feed | Real-time data for symbol F.US.CLEN23 is currently unavailable. 2026-04-16 02:41:58.891 | Denali Data Feed | Received security definition for symbol F.US.CLEN23 2026-04-16 02:41:58.891 | Denali Data Feed | Real-time data for symbol F.US.CLEQ23 is currently unavailable. 2026-04-16 02:41:58.891 | Denali Data Feed | Received security definition for symbol F.US.CLEQ23 2026-04-16 02:41:58.891 | Denali Data Feed | Real-time data for symbol F.US.CLEU23 is currently unavailable. 2026-04-16 02:41:58.891 | Denali Data Feed | Received security definition for symbol F.US.CLEU23 2026-04-16 02:41:58.891 | Denali Data Feed | Real-time data for symbol F.US.CLEV23 is currently unavailable. 2026-04-16 02:41:58.891 | Denali Data Feed | Received security definition for symbol F.US.CLEV23 2026-04-16 02:41:58.891 | Denali Data Feed | Real-time data for symbol F.US.CLEV25 is currently unavailable. 2026-04-16 02:41:58.891 | Denali Data Feed | Received security definition for symbol F.US.CLEV25 2026-04-16 02:41:58.891 | Denali Data Feed | Real-time data for symbol F.US.CLEX23 is currently unavailable. 2026-04-16 02:41:58.891 | Denali Data Feed | Received security definition for symbol F.US.CLEX23 2026-04-16 02:41:58.891 | Denali Data Feed | Real-time data for symbol F.US.CLEZ23 is currently unavailable. 2026-04-16 02:41:58.891 | Denali Data Feed | Received security definition for symbol F.US.CLEZ23 2026-04-16 02:41:58.891 | Denali Data Feed | Real-time data for symbol F.US.EPH23 is currently unavailable. 2026-04-16 02:41:58.891 | Denali Data Feed | Received security definition for symbol F.US.EPH23 2026-04-16 02:41:58.891 | Denali Data Feed | Real-time data for symbol F.US.EPH24 is currently unavailable. 2026-04-16 02:41:58.891 | Denali Data Feed | Received security definition for symbol F.US.EPH24 2026-04-16 02:41:58.891 | Denali Data Feed | Real-time data for symbol F.US.EPM23 is currently unavailable. 2026-04-16 02:41:58.891 | Denali Data Feed | Received security definition for symbol F.US.EPM23 2026-04-16 02:41:58.891 | Denali Data Feed | Real-time data for symbol F.US.EPU23 is currently unavailable. 2026-04-16 02:41:58.891 | Denali Data Feed | Received security definition for symbol F.US.EPU23 2026-04-16 02:41:58.891 | Denali Data Feed | Real-time data for symbol F.US.EPU25 is currently unavailable. 2026-04-16 02:41:58.891 | Denali Data Feed | Received security definition for symbol F.US.EPU25 2026-04-16 02:41:58.891 | Denali Data Feed | Real-time data for symbol F.US.EPZ23 is currently unavailable. 2026-04-16 02:41:58.891 | Denali Data Feed | Received security definition for symbol F.US.EPZ23 2026-04-16 02:42:01.830 | Requesting market depth updates for: F.US.CLEV25 if supported. NumLevels=100 2026-04-16 02:42:02.004 | Denali Data Feed | Clearing market depth for F.US.CLEV25 2026-04-16 02:42:03.923 | HD Request # 18 | Downloading Intraday chart data for F.US.EPU25 to the file F.US.EPU25.scid. Service: cme 2026-04-16 02:42:03.937 | HD Request # 18 | Download start date-time: 2025-09-19 09:29:58.000000. File last date-time: 2025-09-19 09:29:58.698000 2026-04-16 02:42:03.937 | HD Request # 18 | Using server: ds26.sierracharts.com port 10149 2026-04-16 02:42:06.189 | Socket (1) | Creating socket. 2026-04-16 02:42:06.189 | Socket (1) | New receive buffer size: 0 2026-04-16 02:42:06.189 | Socket (1) | Connecting to IP: 64.152.155.17. 2026-04-16 02:42:06.695 | HD Request # 18 | Setting DTC encoding to Binary VLS 2026-04-16 02:42:06.695 | HD Request # 18 | Sending historical data logon request message. 2026-04-16 02:42:06.815 | HD Request # 18 | Requesting Intraday data. Start date-time: 2025-09-19 09:29:58. Record interval: 0. Symbol: ESU25 2026-04-16 02:42:06.904 | HD Request # 18 | Decompressing data. 2026-04-16 02:42:06.993 | HD Request # 18 | Receiving Intraday data for F.US.EPU25 starting at 2025-09-19 09:29:58.697000 2026-04-16 02:42:06.993 | Socket (1) | CloseSocket call. 2026-04-16 02:42:06.994 | Socket (1) | Shutdown started. Waiting for graceful close. 2026-04-16 02:42:06.995 | Historical data download thread signaled to stop. 2026-04-16 02:42:06.996 | HD Request # 18 | Received 5 Intraday data records from 2025-09-19 09:29:58.697000 to 2025-09-19 09:29:58.698000 (0.0 seconds. Delay: 208.7 days) and wrote 0 records for F.US.EPU25 2026-04-16 02:42:06.996 | HD Request # 18 | Add time&sales data | Remembered last file record date-time: 2025-09-19 13:29:58.698000 2026-04-16 02:42:06.996 | HD Request # 18 | Completion time: 3s. 2026-04-16 02:42:06.996 | HD Request # 18 | Intraday data download complete for F.US.EPU25. Unique request ID: 18 2026-04-16 02:42:06.996 | Removing historical data download ID 18. 2026-04-16 02:42:06.997 | Real-time Intraday chart data file updates started for F.US.EPU25 2026-04-16 02:42:06.997 | Intraday chart data file opened for F.US.EPU25 2026-04-16 02:42:06.997 | HD Request # 18 | Enabling Intraday chart updating for symbol. 2026-04-16 02:42:06.997 | 2026-04-16 02:42:06.997 | Triggering next historical data download in queue. 2026-04-16 02:42:06.997 | HD Request # 19 | Downloading Intraday chart data for F.US.BP6U25 to the file F.US.BP6U25.scid. Service: cme 2026-04-16 02:42:07.011 | HD Request # 19 | Download start date-time: 2025-09-15 10:02:50.000000. File last date-time: 2025-09-15 10:02:50.367000 2026-04-16 02:42:07.011 | HD Request # 19 | Using server: ds28.sierracharts.com port 10150 2026-04-16 02:42:07.021 | Socket (2) | Creating socket. 2026-04-16 02:42:07.021 | Socket (2) | New receive buffer size: 0 2026-04-16 02:42:07.021 | Socket (2) | Connecting to IP: 67.214.125.5. 2026-04-16 02:42:07.082 | Socket (1) | Socket gracefully closed by remote side. 2026-04-16 02:42:07.082 | Socket (1) | Closed. 2026-04-16 02:42:07.211 | HD Request # 19 | Setting DTC encoding to Binary VLS 2026-04-16 02:42:07.211 | HD Request # 19 | Sending historical data logon request message. 2026-04-16 02:42:07.337 | HD Request # 19 | Requesting Intraday data. Start date-time: 2025-09-15 10:02:50. Record interval: 0. Symbol: 6BU25 2026-04-16 02:42:07.435 | HD Request # 19 | Decompressing data. 2026-04-16 02:42:07.524 | HD Request # 19 | Receiving Intraday data for F.US.BP6U25 starting at 2025-09-15 10:02:50.367000 2026-04-16 02:42:07.524 | Socket (2) | CloseSocket call. 2026-04-16 02:42:07.524 | Socket (2) | Shutdown started. Waiting for graceful close. 2026-04-16 02:42:07.525 | Historical data download thread signaled to stop. 2026-04-16 02:42:07.525 | HD Request # 19 | Received 1 Intraday data record from 2025-09-15 10:02:50.367000 to 2025-09-15 10:02:50.367000 (0.0 seconds. Delay: 212.7 days) and wrote 0 records for F.US.BP6U25 2026-04-16 02:42:07.526 | HD Request # 19 | Add time&sales data | Remembered last file record date-time: 2025-09-15 14:02:50.367000 2026-04-16 02:42:07.526 | HD Request # 19 | Completion time: 1s. 2026-04-16 02:42:07.526 | HD Request # 19 | Intraday data download complete for F.US.BP6U25. Unique request ID: 19 2026-04-16 02:42:07.526 | Removing historical data download ID 19. 2026-04-16 02:42:07.526 | Real-time Intraday chart data file updates started for F.US.BP6U25 2026-04-16 02:42:07.526 | Intraday chart data file opened for F.US.BP6U25 2026-04-16 02:42:07.526 | HD Request # 19 | Enabling Intraday chart updating for symbol. 2026-04-16 02:42:07.526 | 2026-04-16 02:42:07.526 | Triggering next historical data download in queue. 2026-04-16 02:42:07.526 | HD Request # 20 | Downloading Intraday chart data for F.US.CLEV25 to the file F.US.CLEV25.scid. Service: nymex 2026-04-16 02:42:07.539 | HD Request # 20 | Download start date-time: 2025-09-22 14:29:55.000000. File last date-time: 2025-09-22 14:29:55.618000 2026-04-16 02:42:07.539 | HD Request # 20 | Using server: ds32.sierracharts.com port 10149 2026-04-16 02:42:07.548 | Socket (1) | Creating socket. 2026-04-16 02:42:07.548 | Socket (1) | New receive buffer size: 0 2026-04-16 02:42:07.548 | Socket (1) | Connecting to IP: 69.39.70.248. 2026-04-16 02:42:07.617 | Socket (2) | Socket gracefully closed by remote side. 2026-04-16 02:42:07.618 | Socket (2) | Closed. 2026-04-16 02:42:07.738 | HD Request # 20 | Setting DTC encoding to Binary VLS 2026-04-16 02:42:07.738 | HD Request # 20 | Sending historical data logon request message. 2026-04-16 02:42:07.864 | HD Request # 20 | Requesting Intraday data. Start date-time: 2025-09-22 14:29:55. Record interval: 0. Symbol: CLV25 2026-04-16 02:42:07.962 | HD Request # 20 | Decompressing data. 2026-04-16 02:42:08.059 | HD Request # 20 | Receiving Intraday data for F.US.CLEV25 starting at 2025-09-22 14:29:55.086000 2026-04-16 02:42:08.059 | Socket (1) | CloseSocket call. 2026-04-16 02:42:08.059 | Socket (1) | Shutdown started. Waiting for graceful close. 2026-04-16 02:42:08.153 | Socket (1) | Socket gracefully closed by remote side. 2026-04-16 02:42:08.153 | Socket (1) | Closed. 2026-04-16 02:42:08.346 | Historical data download thread signaled to stop. 2026-04-16 02:42:08.346 | HD Request # 20 | Received 2 Intraday data records from 2025-09-22 14:29:55.086000 to 2025-09-22 14:29:55.618000 (0.5 seconds. Delay: 205.5 days) and wrote 0 records for F.US.CLEV25 2026-04-16 02:42:08.346 | HD Request # 20 | Add time&sales data | Remembered last file record date-time: 2025-09-22 18:29:55.618000 2026-04-16 02:42:08.346 | HD Request # 20 | Completion time: 1s. 2026-04-16 02:42:08.346 | HD Request # 20 | Intraday data download complete for F.US.CLEV25. Unique request ID: 20 2026-04-16 02:42:08.346 | Removing historical data download ID 20. 2026-04-16 02:42:08.346 | Real-time Intraday chart data file updates started for F.US.CLEV25 2026-04-16 02:42:08.346 | Intraday chart data file opened for F.US.CLEV25 2026-04-16 02:42:08.346 | HD Request # 20 | Enabling Intraday chart updating for symbol. 2026-04-16 02:42:08.347 | 2026-04-16 02:42:08.347 | No download requests in the queue to start downloads for. 2026-04-16 02:42:16.928 | ExtendTheFundedTradingAccountStatusExpirationDate: Sending request. 2026-04-16 02:42:17.352 | ExtendTheFundedTradingAccountStatusExpirationDate | Result: {"Result":"The Funded Trading Account Status Expiration Date is more than 25 days into the future. The Date is currently: 2026-05-13"}. Success=true 2026-04-16 02:54:44.817 | The data feed was lost. There was no activity for at least 60.0 seconds. 2026-04-16 02:54:44.817 | Connection to the external service has been lost. 2026-04-16 02:54:44.848 | CQG WebSocket | Timeout waiting for pong message from server. 2026-04-16 02:54:44.848 | CQG WebAPI | WebSocket closed. 2026-04-16 02:54:44.850 | Denali Data Feed | There has been no activity on the network socket for 11m 35s. Will reconnect. 2026-04-16 02:54:44.850 | Denali Data Feed | Waiting for socket receive thread to end 2026-04-16 02:54:44.850 | DTC Client socket (4) | CloseSocket call. 2026-04-16 02:54:44.850 | Denali Data Feed | Disconnected from the server. 2026-04-16 02:54:44.850 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds. 2026-04-16 02:54:44.850 | CQG WebAPI | Sending Web API Logoff message. 2026-04-16 02:54:44.850 | CQG WebSocket socket (5) | CloseSocket call. 2026-04-16 02:54:44.850 | CQG WebSocket socket (5) | Max send buffers used during socket life: 3 2026-04-16 02:54:44.850 | CQG WebSocket socket (5) | Max send buffer size during socket life: 595 2026-04-16 02:54:44.850 | CQG WebSocket | WebSocket closed. 2026-04-16 02:54:44.850 | CQG WebAPI | WebSocket closed. 2026-04-16 02:54:44.850 | CQG WebAPI | Disconnected. 2026-04-16 02:54:44.850 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-04-16 02:54:44.858 | DTC Client socket (4) | Shutdown started. Waiting for graceful close. 2026-04-16 02:54:44.858 | CQG WebSocket socket (5) | Write in progress. Shutdown being delayed. PendingSize=0 2026-04-16 02:54:44.879 | CQG WebSocket socket (5) | Write has completed. Shutdown being performed. 2026-04-16 02:54:44.879 | CQG WebSocket socket (5) | Shutdown started. Waiting for graceful close. 2026-04-16 02:54:46.861 | 2026-04-16 02:54:46.862 | CQG WebAPI | Connecting to server api.cqg.com 2026-04-16 02:54:46.862 | CQG WebSocket | Connecting to WebSocket server api.cqg.com:443 2026-04-16 02:54:46.977 | CQG WebSocket socket (1) | Creating socket. Using TLS 1.2. 2026-04-16 02:54:47.004 | CQG WebSocket socket (1) | New receive buffer size: 0 2026-04-16 02:54:47.005 | CQG WebSocket socket (1) | Connecting to IP: 195.166.124.175. 2026-04-16 02:54:47.028 | CQG WebSocket | Opening WebSocket. 2026-04-16 02:54:47.028 | CQG WebSocket | Sending WebSocket handshake. 2026-04-16 02:54:47.067 | CQG WebSocket | Server header | HTTP/1.1 101 Switching Protocols 2026-04-16 02:54:47.067 | CQG WebSocket | Server header | Connection: Upgrade 2026-04-16 02:54:47.067 | CQG WebSocket | Server header | Sec-WebSocket-Accept: vI//CLxyMtqB7HIih7oHuDl/j/8= 2026-04-16 02:54:47.067 | CQG WebSocket | Server header | Server: WebSocket++/0.8.2 2026-04-16 02:54:47.067 | CQG WebSocket | Server header | Upgrade: websocket 2026-04-16 02:54:47.067 | CQG WebSocket | Server header | 2026-04-16 02:54:47.067 | CQG WebSocket | Web socket state is now open. 2026-04-16 02:54:47.067 | CQG WebAPI | WebSocket connected. 2026-04-16 02:54:47.067 | CQG WebAPI | Sending market data logon message. 2026-04-16 02:54:47.305 | CQG WebAPI | Base Time: 2026-03-28T06:33:36. 2026-03-28 06:33:36 2026-04-16 02:54:47.305 | CQG WebAPI | Logon successful. Session Token = J3r4JuMZ9wb/Si7mq0wGG07d7YWCM5+8sghZ8FoKf9ooPDj+rpMqin8I5pxsiBMVghhDp8+ZHKH 2026-04-16 02:54:47.305 | CQG WebAPI | Connection to server complete. 2026-04-16 02:54:47.305 | DTC Client socket (0) | CloseSocket call. 2026-04-16 02:54:47.305 | Denali Data Feed | Disconnected from the server. 2026-04-16 02:54:47.306 | No download requests in the queue to start downloads for. | Number times message added: 3 2026-04-16 02:54:47.307 | Updated verified funded futures trading account ending date to: 2026-05-16 06:54:47 2026-04-16 02:54:47.331 | CQG WebAPI | Sending Trade Accounts request message. 2026-04-16 02:54:47.441 | CQG WebAPI | Brokerage name: AMP. Account Name: 220033 2026-04-16 02:54:47.441 | Updated verified funded futures trading account ending date to: 2026-05-16 06:54:47 2026-04-16 02:54:47.441 | CQG WebAPI | Sending collateral subscribe request. 2026-04-16 02:54:47.550 | CQG WebAPI | Sending positions subscribe request. RequestID: 431276 2026-04-16 02:54:47.550 | CQG WebAPI | Sending orders subscribe request. RequestID: 431277 2026-04-16 02:54:47.593 | Mapping F.US.EPU25 to ESU25. Service code: cme 2026-04-16 02:54:47.593 | Using symbol data fast lookup vector 2026-04-16 02:54:47.593 | Denali Data Feed | Starting real-time market data updates for: F.US.EPU25 (ESU25). ID: 1 Service code: cme 2026-04-16 02:54:47.593 | Denali Data Feed | Connecting to the server ds26.sierracharts.com. Port 10048 2026-04-16 02:54:47.594 | CQG WebAPI | Sending symbol resolution request for F.US.EPU25. ID: 431278 2026-04-16 02:54:47.594 | Denali Data Feed | Requesting security definition data for: F.US.EPU25 (ESU25). ID: 1 2026-04-16 02:54:47.594 | Added historical Intraday data request for F.US.EPU25 to the queue. 2026-04-16 02:54:47.594 | Intraday data recording state for symbol F.US.EPU25 is set to download 'Pending'. 2026-04-16 02:54:47.594 | Triggering next historical data download in queue. 2026-04-16 02:54:47.594 | DTC Client socket (2) | Creating socket. 2026-04-16 02:54:47.594 | DTC Client socket (2) | New receive buffer size: 0 2026-04-16 02:54:47.594 | DTC Client socket (2) | Connecting to IP: 64.152.155.17. 2026-04-16 02:54:47.595 | Delaying start of download for F.US.EPU25. 2026-04-16 02:54:47.596 | Mapping F.US.BP6U25 to 6BU25. Service code: cme 2026-04-16 02:54:47.596 | Denali Data Feed | Starting real-time market data updates for: F.US.BP6U25 (6BU25). ID: 2 Service code: cme 2026-04-16 02:54:47.596 | CQG WebAPI | Sending symbol resolution request for F.US.BP6U25. ID: 431279 2026-04-16 02:54:47.596 | Denali Data Feed | Requesting security definition data for: F.US.BP6U25 (6BU25). ID: 2 2026-04-16 02:54:47.596 | Added historical Intraday data request for F.US.BP6U25 to the queue. 2026-04-16 02:54:47.596 | Intraday data recording state for symbol F.US.BP6U25 is set to download 'Pending'. 2026-04-16 02:54:47.596 | Triggering next historical data download in queue. 2026-04-16 02:54:47.628 | CQG WebAPI | Received symbol resolution report for symbol F.US.EPU25. Search Symbol: F.US.EPU25. Request ID: 431278. Contract ID: 1. 2026-04-16 02:54:47.628 | CQG WebAPI | Received symbol resolution report for symbol F.US.BP6U25. Search Symbol: F.US.BP6U25. Request ID: 431279. Contract ID: 2. 2026-04-16 02:54:47.637 | Mapping F.US.CLEV25 to CLV25. Service code: nymex 2026-04-16 02:54:47.637 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEV25 (CLV25). ID: 3 Service code: nymex 2026-04-16 02:54:47.637 | CQG WebAPI | Sending symbol resolution request for F.US.CLEV25. ID: 431280 2026-04-16 02:54:47.637 | Denali Data Feed | Requesting security definition data for: F.US.CLEV25 (CLV25). ID: 3 2026-04-16 02:54:47.637 | Added historical Intraday data request for F.US.CLEV25 to the queue. 2026-04-16 02:54:47.637 | Intraday data recording state for symbol F.US.CLEV25 is set to download 'Pending'. 2026-04-16 02:54:47.637 | Triggering next historical data download in queue. 2026-04-16 02:54:47.656 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEV25. Search Symbol: F.US.CLEV25. Request ID: 431280. Contract ID: 3. 2026-04-16 02:54:47.683 | Denali Data Feed | Network connection to server complete. 2026-04-16 02:54:47.683 | Denali Data Feed | Starting socket receive thread. 2026-04-16 02:54:47.683 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard 2026-04-16 02:54:47.783 | Denali Data Feed | Setting DTC encoding to Binary VLS 2026-04-16 02:54:47.783 | Denali Data Feed | Sending logon request message. 2026-04-16 02:54:48.067 | Mapping F.US.EPH23 to ESH23. Service code: cme 2026-04-16 02:54:48.067 | Denali Data Feed | Starting real-time market data updates for: F.US.EPH23 (ESH23). ID: 4 Service code: cme 2026-04-16 02:54:48.067 | CQG WebAPI | Sending symbol resolution request for F.US.EPH23. ID: 431281 2026-04-16 02:54:48.067 | Denali Data Feed | Requesting security definition data for: F.US.EPH23 (ESH23). ID: 4 2026-04-16 02:54:48.067 | Mapping F.US.EPM23 to ESM23. Service code: cme 2026-04-16 02:54:48.068 | Denali Data Feed | Starting real-time market data updates for: F.US.EPM23 (ESM23). ID: 5 Service code: cme 2026-04-16 02:54:48.068 | CQG WebAPI | Sending symbol resolution request for F.US.EPM23. ID: 431282 2026-04-16 02:54:48.068 | Denali Data Feed | Requesting security definition data for: F.US.EPM23 (ESM23). ID: 5 2026-04-16 02:54:48.068 | Mapping F.US.EPU23 to ESU23. Service code: cme 2026-04-16 02:54:48.068 | Denali Data Feed | Starting real-time market data updates for: F.US.EPU23 (ESU23). ID: 6 Service code: cme 2026-04-16 02:54:48.068 | CQG WebAPI | Sending symbol resolution request for F.US.EPU23. ID: 431283 2026-04-16 02:54:48.068 | Denali Data Feed | Requesting security definition data for: F.US.EPU23 (ESU23). ID: 6 2026-04-16 02:54:48.068 | Mapping F.US.EPZ23 to ESZ23. Service code: cme 2026-04-16 02:54:48.068 | Denali Data Feed | Starting real-time market data updates for: F.US.EPZ23 (ESZ23). ID: 7 Service code: cme 2026-04-16 02:54:48.068 | CQG WebAPI | Sending symbol resolution request for F.US.EPZ23. ID: 431284 2026-04-16 02:54:48.068 | Denali Data Feed | Requesting security definition data for: F.US.EPZ23 (ESZ23). ID: 7 2026-04-16 02:54:48.068 | Mapping F.US.EPH24 to ESH24. Service code: cme 2026-04-16 02:54:48.068 | Denali Data Feed | Starting real-time market data updates for: F.US.EPH24 (ESH24). ID: 8 Service code: cme 2026-04-16 02:54:48.068 | CQG WebAPI | Sending symbol resolution request for F.US.EPH24. ID: 431285 2026-04-16 02:54:48.068 | Denali Data Feed | Requesting security definition data for: F.US.EPH24 (ESH24). ID: 8 2026-04-16 02:54:48.068 | Mapping F.US.CLEF23 to CLF23. Service code: nymex 2026-04-16 02:54:48.068 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEF23 (CLF23). ID: 9 Service code: nymex 2026-04-16 02:54:48.068 | CQG WebAPI | Sending symbol resolution request for F.US.CLEF23. ID: 431286 2026-04-16 02:54:48.068 | Denali Data Feed | Requesting security definition data for: F.US.CLEF23 (CLF23). ID: 9 2026-04-16 02:54:48.068 | Mapping F.US.CLEG23 to CLG23. Service code: nymex 2026-04-16 02:54:48.069 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEG23 (CLG23). ID: 10 Service code: nymex 2026-04-16 02:54:48.069 | CQG WebAPI | Sending symbol resolution request for F.US.CLEG23. ID: 431287 2026-04-16 02:54:48.069 | Denali Data Feed | Requesting security definition data for: F.US.CLEG23 (CLG23). ID: 10 2026-04-16 02:54:48.069 | Mapping F.US.CLEH23 to CLH23. Service code: nymex 2026-04-16 02:54:48.069 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEH23 (CLH23). ID: 11 Service code: nymex 2026-04-16 02:54:48.069 | CQG WebAPI | Sending symbol resolution request for F.US.CLEH23. ID: 431288 2026-04-16 02:54:48.069 | Denali Data Feed | Requesting security definition data for: F.US.CLEH23 (CLH23). ID: 11 2026-04-16 02:54:48.069 | Mapping F.US.CLEJ23 to CLJ23. Service code: nymex 2026-04-16 02:54:48.069 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEJ23 (CLJ23). ID: 12 Service code: nymex 2026-04-16 02:54:48.069 | CQG WebAPI | Sending symbol resolution request for F.US.CLEJ23. ID: 431289 2026-04-16 02:54:48.069 | Denali Data Feed | Requesting security definition data for: F.US.CLEJ23 (CLJ23). ID: 12 2026-04-16 02:54:48.069 | Mapping F.US.CLEK23 to CLK23. Service code: nymex 2026-04-16 02:54:48.069 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEK23 (CLK23). ID: 13 Service code: nymex 2026-04-16 02:54:48.069 | CQG WebAPI | Sending symbol resolution request for F.US.CLEK23. ID: 431290 2026-04-16 02:54:48.069 | Denali Data Feed | Requesting security definition data for: F.US.CLEK23 (CLK23). ID: 13 2026-04-16 02:54:48.069 | Mapping F.US.CLEM23 to CLM23. Service code: nymex 2026-04-16 02:54:48.069 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEM23 (CLM23). ID: 14 Service code: nymex 2026-04-16 02:54:48.069 | CQG WebAPI | Sending symbol resolution request for F.US.CLEM23. ID: 431291 2026-04-16 02:54:48.069 | Denali Data Feed | Requesting security definition data for: F.US.CLEM23 (CLM23). ID: 14 2026-04-16 02:54:48.069 | Mapping F.US.CLEN23 to CLN23. Service code: nymex 2026-04-16 02:54:48.069 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEN23 (CLN23). ID: 15 Service code: nymex 2026-04-16 02:54:48.069 | CQG WebAPI | Sending symbol resolution request for F.US.CLEN23. ID: 431292 2026-04-16 02:54:48.069 | Denali Data Feed | Requesting security definition data for: F.US.CLEN23 (CLN23). ID: 15 2026-04-16 02:54:48.069 | Mapping F.US.CLEQ23 to CLQ23. Service code: nymex 2026-04-16 02:54:48.070 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEQ23 (CLQ23). ID: 16 Service code: nymex 2026-04-16 02:54:48.070 | CQG WebAPI | Sending symbol resolution request for F.US.CLEQ23. ID: 431293 2026-04-16 02:54:48.070 | Denali Data Feed | Requesting security definition data for: F.US.CLEQ23 (CLQ23). ID: 16 2026-04-16 02:54:48.070 | Mapping F.US.CLEU23 to CLU23. Service code: nymex 2026-04-16 02:54:48.070 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEU23 (CLU23). ID: 17 Service code: nymex 2026-04-16 02:54:48.070 | CQG WebAPI | Sending symbol resolution request for F.US.CLEU23. ID: 431294 2026-04-16 02:54:48.070 | Denali Data Feed | Requesting security definition data for: F.US.CLEU23 (CLU23). ID: 17 2026-04-16 02:54:48.070 | Mapping F.US.CLEV23 to CLV23. Service code: nymex 2026-04-16 02:54:48.070 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEV23 (CLV23). ID: 18 Service code: nymex 2026-04-16 02:54:48.070 | CQG WebAPI | Sending symbol resolution request for F.US.CLEV23. ID: 431295 2026-04-16 02:54:48.070 | Denali Data Feed | Requesting security definition data for: F.US.CLEV23 (CLV23). ID: 18 2026-04-16 02:54:48.070 | Mapping F.US.CLEX23 to CLX23. Service code: nymex 2026-04-16 02:54:48.070 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEX23 (CLX23). ID: 19 Service code: nymex 2026-04-16 02:54:48.070 | CQG WebAPI | Sending symbol resolution request for F.US.CLEX23. ID: 431296 2026-04-16 02:54:48.070 | Denali Data Feed | Requesting security definition data for: F.US.CLEX23 (CLX23). ID: 19 2026-04-16 02:54:48.070 | Mapping F.US.CLEZ23 to CLZ23. Service code: nymex 2026-04-16 02:54:48.070 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEZ23 (CLZ23). ID: 20 Service code: nymex 2026-04-16 02:54:48.071 | CQG WebAPI | Sending symbol resolution request for F.US.CLEZ23. ID: 431297 2026-04-16 02:54:48.071 | Denali Data Feed | Requesting security definition data for: F.US.CLEZ23 (CLZ23). ID: 20 2026-04-16 02:54:48.071 | Mapping F.US.CLEF24 to CLF24. Service code: nymex 2026-04-16 02:54:48.071 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEF24 (CLF24). ID: 21 Service code: nymex 2026-04-16 02:54:48.071 | CQG WebAPI | Sending symbol resolution request for F.US.CLEF24. ID: 431298 2026-04-16 02:54:48.071 | Denali Data Feed | Requesting security definition data for: F.US.CLEF24 (CLF24). ID: 21 2026-04-16 02:54:48.071 | Mapping F.US.CLEG24 to CLG24. Service code: nymex 2026-04-16 02:54:48.071 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEG24 (CLG24). ID: 22 Service code: nymex 2026-04-16 02:54:48.071 | CQG WebAPI | Sending symbol resolution request for F.US.CLEG24. ID: 431299 2026-04-16 02:54:48.071 | Denali Data Feed | Requesting security definition data for: F.US.CLEG24 (CLG24). ID: 22 2026-04-16 02:54:48.072 | CQG WebAPI | Received symbol resolution report for symbol F.US.EPH23. Search Symbol: F.US.EPH23. Request ID: 431281. Contract ID: 4. 2026-04-16 02:54:48.072 | CQG WebAPI | Received symbol resolution report for symbol F.US.EPM23. Search Symbol: F.US.EPM23. Request ID: 431282. Contract ID: 5. 2026-04-16 02:54:48.072 | CQG WebAPI | Received symbol resolution report for symbol F.US.EPU23. Search Symbol: F.US.EPU23. Request ID: 431283. Contract ID: 6. 2026-04-16 02:54:48.166 | CQG WebAPI | Received symbol resolution report for symbol F.US.EPZ23. Search Symbol: F.US.EPZ23. Request ID: 431284. Contract ID: 7. 2026-04-16 02:54:48.166 | CQG WebAPI | Received symbol resolution report for symbol F.US.EPH24. Search Symbol: F.US.EPH24. Request ID: 431285. Contract ID: 8. 2026-04-16 02:54:48.166 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEF23. Search Symbol: F.US.CLEF23. Request ID: 431286. Contract ID: 9. 2026-04-16 02:54:48.166 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEG23. Search Symbol: F.US.CLEG23. Request ID: 431287. Contract ID: 10. 2026-04-16 02:54:48.166 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEH23. Search Symbol: F.US.CLEH23. Request ID: 431288. Contract ID: 11. 2026-04-16 02:54:48.166 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEJ23. Search Symbol: F.US.CLEJ23. Request ID: 431289. Contract ID: 12. 2026-04-16 02:54:48.166 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEK23. Search Symbol: F.US.CLEK23. Request ID: 431290. Contract ID: 13. 2026-04-16 02:54:48.166 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEM23. Search Symbol: F.US.CLEM23. Request ID: 431291. Contract ID: 14. 2026-04-16 02:54:48.166 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEN23. Search Symbol: F.US.CLEN23. Request ID: 431292. Contract ID: 15. 2026-04-16 02:54:48.166 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEQ23. Search Symbol: F.US.CLEQ23. Request ID: 431293. Contract ID: 16. 2026-04-16 02:54:48.167 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEU23. Search Symbol: F.US.CLEU23. Request ID: 431294. Contract ID: 17. 2026-04-16 02:54:48.171 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEV23. Search Symbol: F.US.CLEV23. Request ID: 431295. Contract ID: 18. 2026-04-16 02:54:48.171 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEX23. Search Symbol: F.US.CLEX23. Request ID: 431296. Contract ID: 19. 2026-04-16 02:54:48.171 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEZ23. Search Symbol: F.US.CLEZ23. Request ID: 431297. Contract ID: 20. 2026-04-16 02:54:48.171 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEF24. Search Symbol: F.US.CLEF24. Request ID: 431298. Contract ID: 21. 2026-04-16 02:54:48.171 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEG24. Search Symbol: F.US.CLEG24. Request ID: 431299. Contract ID: 22. 2026-04-16 02:54:48.332 | Denali Data Feed | Received logon response. 2026-04-16 02:54:48.332 | Denali Data Feed | Server Name: SC Realtime Server. 2026-04-16 02:54:48.332 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8 2026-04-16 02:54:48.332 | Denali Data Feed | Successfully connected. 2026-04-16 02:54:48.332 | Denali Data Feed | Trading is not supported. 2026-04-16 02:54:48.332 | Denali Data Feed | MarketDepthIsSupported: 1 2026-04-16 02:54:48.332 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.BP6U25 -> 6BU25 2026-04-16 02:54:48.332 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEF23 -> CLF23 2026-04-16 02:54:48.332 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEF24 -> CLF24 2026-04-16 02:54:48.332 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEG23 -> CLG23 2026-04-16 02:54:48.332 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEG24 -> CLG24 2026-04-16 02:54:48.332 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEH23 -> CLH23 2026-04-16 02:54:48.332 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEJ23 -> CLJ23 2026-04-16 02:54:48.332 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEK23 -> CLK23 2026-04-16 02:54:48.332 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEM23 -> CLM23 2026-04-16 02:54:48.332 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEN23 -> CLN23 2026-04-16 02:54:48.332 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEQ23 -> CLQ23 2026-04-16 02:54:48.332 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEU23 -> CLU23 2026-04-16 02:54:48.332 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEV23 -> CLV23 2026-04-16 02:54:48.332 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEV25 -> CLV25 2026-04-16 02:54:48.332 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEX23 -> CLX23 2026-04-16 02:54:48.332 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEZ23 -> CLZ23 2026-04-16 02:54:48.332 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.EPH23 -> ESH23 2026-04-16 02:54:48.332 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.EPH24 -> ESH24 2026-04-16 02:54:48.332 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.EPM23 -> ESM23 2026-04-16 02:54:48.332 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.EPU23 -> ESU23 2026-04-16 02:54:48.332 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.EPU25 -> ESU25 2026-04-16 02:54:48.332 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.EPZ23 -> ESZ23 2026-04-16 02:54:48.533 | Denali Data Feed | Real-time data for symbol F.US.BP6U25 is currently unavailable. 2026-04-16 02:54:48.533 | Denali Data Feed | Received security definition for symbol F.US.BP6U25 2026-04-16 02:54:48.533 | Denali Data Feed | Real-time data for symbol F.US.CLEF23 is currently unavailable. 2026-04-16 02:54:48.533 | Denali Data Feed | Received security definition for symbol F.US.CLEF23 2026-04-16 02:54:48.533 | Denali Data Feed | Real-time data for symbol F.US.CLEF24 is currently unavailable. 2026-04-16 02:54:48.533 | Denali Data Feed | Received security definition for symbol F.US.CLEF24 2026-04-16 02:54:48.533 | Denali Data Feed | Real-time data for symbol F.US.CLEG23 is currently unavailable. 2026-04-16 02:54:48.533 | Denali Data Feed | Received security definition for symbol F.US.CLEG23 2026-04-16 02:54:48.533 | Denali Data Feed | Real-time data for symbol F.US.CLEG24 is currently unavailable. 2026-04-16 02:54:48.533 | Denali Data Feed | Received security definition for symbol F.US.CLEG24 2026-04-16 02:54:48.533 | Denali Data Feed | Real-time data for symbol F.US.CLEH23 is currently unavailable. 2026-04-16 02:54:48.533 | Denali Data Feed | Received security definition for symbol F.US.CLEH23 2026-04-16 02:54:48.533 | Denali Data Feed | Real-time data for symbol F.US.CLEJ23 is currently unavailable. 2026-04-16 02:54:48.533 | Denali Data Feed | Received security definition for symbol F.US.CLEJ23 2026-04-16 02:54:48.533 | Denali Data Feed | Real-time data for symbol F.US.CLEK23 is currently unavailable. 2026-04-16 02:54:48.533 | Denali Data Feed | Received security definition for symbol F.US.CLEK23 2026-04-16 02:54:48.533 | Denali Data Feed | Real-time data for symbol F.US.CLEM23 is currently unavailable. 2026-04-16 02:54:48.533 | Denali Data Feed | Received security definition for symbol F.US.CLEM23 2026-04-16 02:54:48.533 | Denali Data Feed | Real-time data for symbol F.US.CLEN23 is currently unavailable. 2026-04-16 02:54:48.533 | Denali Data Feed | Received security definition for symbol F.US.CLEN23 2026-04-16 02:54:48.533 | Denali Data Feed | Real-time data for symbol F.US.CLEQ23 is currently unavailable. 2026-04-16 02:54:48.533 | Denali Data Feed | Received security definition for symbol F.US.CLEQ23 2026-04-16 02:54:48.533 | Denali Data Feed | Real-time data for symbol F.US.CLEU23 is currently unavailable. 2026-04-16 02:54:48.533 | Denali Data Feed | Received security definition for symbol F.US.CLEU23 2026-04-16 02:54:48.533 | Denali Data Feed | Real-time data for symbol F.US.CLEV23 is currently unavailable. 2026-04-16 02:54:48.533 | Denali Data Feed | Received security definition for symbol F.US.CLEV23 2026-04-16 02:54:48.533 | Denali Data Feed | Real-time data for symbol F.US.CLEV25 is currently unavailable. 2026-04-16 02:54:48.533 | Denali Data Feed | Received security definition for symbol F.US.CLEV25 2026-04-16 02:54:48.533 | Denali Data Feed | Real-time data for symbol F.US.CLEX23 is currently unavailable. 2026-04-16 02:54:48.533 | Denali Data Feed | Received security definition for symbol F.US.CLEX23 2026-04-16 02:54:48.533 | Denali Data Feed | Real-time data for symbol F.US.CLEZ23 is currently unavailable. 2026-04-16 02:54:48.533 | Denali Data Feed | Received security definition for symbol F.US.CLEZ23 2026-04-16 02:54:48.533 | Denali Data Feed | Real-time data for symbol F.US.EPH23 is currently unavailable. 2026-04-16 02:54:48.533 | Denali Data Feed | Received security definition for symbol F.US.EPH23 2026-04-16 02:54:48.533 | Denali Data Feed | Real-time data for symbol F.US.EPH24 is currently unavailable. 2026-04-16 02:54:48.533 | Denali Data Feed | Received security definition for symbol F.US.EPH24 2026-04-16 02:54:48.533 | Denali Data Feed | Real-time data for symbol F.US.EPM23 is currently unavailable. 2026-04-16 02:54:48.533 | Denali Data Feed | Received security definition for symbol F.US.EPM23 2026-04-16 02:54:48.533 | Denali Data Feed | Real-time data for symbol F.US.EPU23 is currently unavailable. 2026-04-16 02:54:48.533 | Denali Data Feed | Received security definition for symbol F.US.EPU23 2026-04-16 02:54:48.533 | Denali Data Feed | Real-time data for symbol F.US.EPU25 is currently unavailable. 2026-04-16 02:54:48.533 | Denali Data Feed | Received security definition for symbol F.US.EPU25 2026-04-16 02:54:48.533 | Denali Data Feed | Real-time data for symbol F.US.EPZ23 is currently unavailable. 2026-04-16 02:54:48.533 | Denali Data Feed | Received security definition for symbol F.US.EPZ23 2026-04-16 02:54:52.301 | Requesting market depth updates for: F.US.CLEV25 if supported. NumLevels=100 2026-04-16 02:54:52.471 | Denali Data Feed | Clearing market depth for F.US.CLEV25 2026-04-16 02:54:53.855 | HD Request # 21 | Downloading Intraday chart data for F.US.EPU25 to the file F.US.EPU25.scid. Service: cme 2026-04-16 02:54:53.856 | HD Request # 21 | Download start date-time: 2025-09-19 09:29:58.000000. File last date-time: 2025-09-19 09:29:58.698000 2026-04-16 02:54:53.856 | HD Request # 21 | Using server: ds26.sierracharts.com port 10150 2026-04-16 02:54:53.856 | Socket (3) | Creating socket. 2026-04-16 02:54:53.856 | Socket (3) | New receive buffer size: 0 2026-04-16 02:54:53.856 | Socket (3) | Connecting to IP: 64.152.155.17. 2026-04-16 02:54:54.036 | HD Request # 21 | Setting DTC encoding to Binary VLS 2026-04-16 02:54:54.036 | HD Request # 21 | Sending historical data logon request message. 2026-04-16 02:54:54.156 | HD Request # 21 | Requesting Intraday data. Start date-time: 2025-09-19 09:29:58. Record interval: 0. Symbol: ESU25 2026-04-16 02:54:54.244 | HD Request # 21 | Decompressing data. 2026-04-16 02:54:54.333 | HD Request # 21 | Receiving Intraday data for F.US.EPU25 starting at 2025-09-19 09:29:58.697000 2026-04-16 02:54:54.333 | Socket (3) | CloseSocket call. 2026-04-16 02:54:54.333 | Socket (3) | Shutdown started. Waiting for graceful close. 2026-04-16 02:54:54.333 | Historical data download thread signaled to stop. 2026-04-16 02:54:54.333 | HD Request # 21 | Received 5 Intraday data records from 2025-09-19 09:29:58.697000 to 2025-09-19 09:29:58.698000 (0.0 seconds. Delay: 208.7 days) and wrote 0 records for F.US.EPU25 2026-04-16 02:54:54.334 | HD Request # 21 | Add time&sales data | Remembered last file record date-time: 2025-09-19 13:29:58.698000 2026-04-16 02:54:54.334 | HD Request # 21 | Completion time: 1s. 2026-04-16 02:54:54.334 | HD Request # 21 | Intraday data download complete for F.US.EPU25. Unique request ID: 21 2026-04-16 02:54:54.334 | Removing historical data download ID 21. 2026-04-16 02:54:54.334 | Real-time Intraday chart data file updates started for F.US.EPU25 2026-04-16 02:54:54.334 | Intraday chart data file opened for F.US.EPU25 2026-04-16 02:54:54.334 | HD Request # 21 | Enabling Intraday chart updating for symbol. 2026-04-16 02:54:54.334 | 2026-04-16 02:54:54.334 | Triggering next historical data download in queue. 2026-04-16 02:54:54.334 | HD Request # 22 | Downloading Intraday chart data for F.US.BP6U25 to the file F.US.BP6U25.scid. Service: cme 2026-04-16 02:54:54.335 | HD Request # 22 | Download start date-time: 2025-09-15 10:02:50.000000. File last date-time: 2025-09-15 10:02:50.367000 2026-04-16 02:54:54.335 | HD Request # 22 | Using server: ds28.sierracharts.com port 10149 2026-04-16 02:54:54.335 | Socket (6) | Creating socket. 2026-04-16 02:54:54.335 | Socket (6) | New receive buffer size: 0 2026-04-16 02:54:54.335 | Socket (6) | Connecting to IP: 67.214.125.5. 2026-04-16 02:54:54.421 | Socket (3) | Socket gracefully closed by remote side. 2026-04-16 02:54:54.421 | Socket (3) | Closed. 2026-04-16 02:54:54.524 | HD Request # 22 | Setting DTC encoding to Binary VLS 2026-04-16 02:54:54.524 | HD Request # 22 | Sending historical data logon request message. 2026-04-16 02:54:54.650 | HD Request # 22 | Requesting Intraday data. Start date-time: 2025-09-15 10:02:50. Record interval: 0. Symbol: 6BU25 2026-04-16 02:54:54.744 | HD Request # 22 | Decompressing data. 2026-04-16 02:54:54.837 | HD Request # 22 | Receiving Intraday data for F.US.BP6U25 starting at 2025-09-15 10:02:50.367000 2026-04-16 02:54:54.837 | Socket (6) | CloseSocket call. 2026-04-16 02:54:54.837 | Socket (6) | Shutdown started. Waiting for graceful close. 2026-04-16 02:54:54.838 | Historical data download thread signaled to stop. 2026-04-16 02:54:54.838 | HD Request # 22 | Received 1 Intraday data record from 2025-09-15 10:02:50.367000 to 2025-09-15 10:02:50.367000 (0.0 seconds. Delay: 212.7 days) and wrote 0 records for F.US.BP6U25 2026-04-16 02:54:54.839 | HD Request # 22 | Add time&sales data | Remembered last file record date-time: 2025-09-15 14:02:50.367000 2026-04-16 02:54:54.839 | HD Request # 22 | Completion time: 0s. 2026-04-16 02:54:54.839 | HD Request # 22 | Intraday data download complete for F.US.BP6U25. Unique request ID: 22 2026-04-16 02:54:54.839 | Removing historical data download ID 22. 2026-04-16 02:54:54.839 | Real-time Intraday chart data file updates started for F.US.BP6U25 2026-04-16 02:54:54.839 | Intraday chart data file opened for F.US.BP6U25 2026-04-16 02:54:54.839 | HD Request # 22 | Enabling Intraday chart updating for symbol. 2026-04-16 02:54:54.839 | 2026-04-16 02:54:54.839 | Triggering next historical data download in queue. 2026-04-16 02:54:54.839 | HD Request # 23 | Downloading Intraday chart data for F.US.CLEV25 to the file F.US.CLEV25.scid. Service: nymex 2026-04-16 02:54:54.839 | HD Request # 23 | Download start date-time: 2025-09-22 14:29:55.000000. File last date-time: 2025-09-22 14:29:55.618000 2026-04-16 02:54:54.839 | HD Request # 23 | Using server: ds32.sierracharts.com port 10150 2026-04-16 02:54:54.839 | Socket (3) | Creating socket. 2026-04-16 02:54:54.839 | Socket (3) | New receive buffer size: 0 2026-04-16 02:54:54.840 | Socket (3) | Connecting to IP: 69.39.70.248. 2026-04-16 02:54:54.930 | Socket (6) | Socket gracefully closed by remote side. 2026-04-16 02:54:54.930 | Socket (6) | Closed. 2026-04-16 02:54:55.029 | HD Request # 23 | Setting DTC encoding to Binary VLS 2026-04-16 02:54:55.029 | HD Request # 23 | Sending historical data logon request message. 2026-04-16 02:54:55.152 | HD Request # 23 | Requesting Intraday data. Start date-time: 2025-09-22 14:29:55. Record interval: 0. Symbol: CLV25 2026-04-16 02:54:55.249 | HD Request # 23 | Decompressing data. 2026-04-16 02:54:55.342 | HD Request # 23 | Receiving Intraday data for F.US.CLEV25 starting at 2025-09-22 14:29:55.086000 2026-04-16 02:54:55.342 | Socket (3) | CloseSocket call. 2026-04-16 02:54:55.342 | Socket (3) | Shutdown started. Waiting for graceful close. 2026-04-16 02:54:55.343 | Historical data download thread signaled to stop. 2026-04-16 02:54:55.343 | HD Request # 23 | Received 2 Intraday data records from 2025-09-22 14:29:55.086000 to 2025-09-22 14:29:55.618000 (0.5 seconds. Delay: 205.5 days) and wrote 0 records for F.US.CLEV25 2026-04-16 02:54:55.343 | HD Request # 23 | Add time&sales data | Remembered last file record date-time: 2025-09-22 18:29:55.618000 2026-04-16 02:54:55.343 | HD Request # 23 | Completion time: 1s. 2026-04-16 02:54:55.343 | HD Request # 23 | Intraday data download complete for F.US.CLEV25. Unique request ID: 23 2026-04-16 02:54:55.343 | Removing historical data download ID 23. 2026-04-16 02:54:55.343 | Real-time Intraday chart data file updates started for F.US.CLEV25 2026-04-16 02:54:55.343 | Intraday chart data file opened for F.US.CLEV25 2026-04-16 02:54:55.343 | HD Request # 23 | Enabling Intraday chart updating for symbol. 2026-04-16 02:54:55.343 | 2026-04-16 02:54:55.343 | No download requests in the queue to start downloads for. 2026-04-16 02:54:55.435 | Socket (3) | Socket gracefully closed by remote side. 2026-04-16 02:54:55.435 | Socket (3) | Closed. 2026-04-16 02:55:04.851 | DTC Client socket (4) | Socket gracefully closed by remote side. 2026-04-16 02:55:04.851 | DTC Client socket (4) | Closed. 2026-04-16 02:56:44.932 | CQG WebSocket socket (5) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. * 2026-04-16 02:56:44.932 | CQG WebSocket socket (5) | Socket gracefully closed by remote side. 2026-04-16 02:56:44.932 | CQG WebSocket socket (5) | Closed. 2026-04-16 04:51:10.724 | The data feed was lost. There was no activity for at least 60.0 seconds. 2026-04-16 04:51:10.724 | Connection to the external service has been lost. 2026-04-16 04:51:11.194 | CQG WebSocket | Timeout waiting for pong message from server. 2026-04-16 04:51:11.194 | CQG WebAPI | WebSocket closed. 2026-04-16 04:51:11.194 | Denali Data Feed | There has been no activity on the network socket for 9m 48s. Will reconnect. 2026-04-16 04:51:11.194 | Denali Data Feed | Waiting for socket receive thread to end 2026-04-16 04:51:11.196 | DTC Client socket (2) | CloseSocket call. 2026-04-16 04:51:11.196 | Denali Data Feed | Disconnected from the server. 2026-04-16 04:51:11.196 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds. 2026-04-16 04:51:11.197 | CQG WebAPI | Sending Web API Logoff message. 2026-04-16 04:51:11.197 | CQG WebSocket socket (1) | CloseSocket call. 2026-04-16 04:51:11.197 | CQG WebSocket socket (1) | Max send buffers used during socket life: 3 2026-04-16 04:51:11.197 | CQG WebSocket socket (1) | Max send buffer size during socket life: 595 2026-04-16 04:51:11.197 | CQG WebSocket | WebSocket closed. 2026-04-16 04:51:11.197 | CQG WebAPI | WebSocket closed. 2026-04-16 04:51:11.197 | CQG WebAPI | Disconnected. 2026-04-16 04:51:11.197 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-04-16 04:51:11.286 | DTC Client socket (2) | Socket gracefully closed by remote side. 2026-04-16 04:51:11.358 | DTC Client socket (2) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. * 2026-04-16 04:51:11.359 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2026-04-16 04:51:11.359 | DTC Client socket (2) | Closed. 2026-04-16 04:51:11.359 | CQG WebSocket socket (1) | Write in progress. Shutdown being delayed. PendingSize=0 2026-04-16 04:51:11.495 | CQG WebSocket socket (1) | Write has completed. Shutdown being performed. 2026-04-16 04:51:11.495 | CQG WebSocket socket (1) | Shutdown started. Waiting for graceful close. 2026-04-16 04:51:13.211 | 2026-04-16 04:51:13.211 | CQG WebAPI | Connecting to server api.cqg.com 2026-04-16 04:51:13.211 | CQG WebSocket | Connecting to WebSocket server api.cqg.com:443 2026-04-16 04:51:13.475 | CQG WebSocket socket (2) | Creating socket. Using TLS 1.2. 2026-04-16 04:51:13.475 | CQG WebSocket socket (2) | New receive buffer size: 0 2026-04-16 04:51:13.475 | CQG WebSocket socket (2) | Connecting to IP: 195.166.124.175. 2026-04-16 04:51:13.484 | CQG WebSocket | Opening WebSocket. 2026-04-16 04:51:13.484 | CQG WebSocket | Sending WebSocket handshake. 2026-04-16 04:51:13.726 | CQG WebSocket | Server header | HTTP/1.1 101 Switching Protocols 2026-04-16 04:51:13.726 | CQG WebSocket | Server header | Connection: Upgrade 2026-04-16 04:51:13.726 | CQG WebSocket | Server header | Sec-WebSocket-Accept: 7S6hTq7j7+VzUKdzUHNhcxn3ZQ0= 2026-04-16 04:51:13.726 | CQG WebSocket | Server header | Server: WebSocket++/0.8.2 2026-04-16 04:51:13.726 | CQG WebSocket | Server header | Upgrade: websocket 2026-04-16 04:51:13.726 | CQG WebSocket | Server header | 2026-04-16 04:51:13.726 | CQG WebSocket | Web socket state is now open. 2026-04-16 04:51:13.726 | CQG WebAPI | WebSocket connected. 2026-04-16 04:51:13.727 | CQG WebAPI | Sending market data logon message. 2026-04-16 04:51:13.983 | CQG WebAPI | Base Time: 2026-03-28T06:33:36. 2026-03-28 06:33:36 2026-04-16 04:51:13.983 | CQG WebAPI | Logon successful. Session Token = Z8kUI0rM1+mnUb2Z53082cdfKqdlMcOoyrqoJCIkRh0W4E/LGjCElRI2APoXpt9jHag/7JyE0FB 2026-04-16 04:51:13.983 | CQG WebAPI | Connection to server complete. 2026-04-16 04:51:13.983 | DTC Client socket (0) | CloseSocket call. 2026-04-16 04:51:13.983 | Denali Data Feed | Disconnected from the server. 2026-04-16 04:51:13.986 | No download requests in the queue to start downloads for. | Number times message added: 3 2026-04-16 04:51:13.986 | Updated verified funded futures trading account ending date to: 2026-05-16 08:51:13 2026-04-16 04:51:14.009 | CQG WebAPI | Sending Trade Accounts request message. 2026-04-16 04:51:14.010 | Mapping F.US.EPH23 to ESH23. Service code: cme 2026-04-16 04:51:14.010 | Using symbol data fast lookup vector 2026-04-16 04:51:14.010 | Denali Data Feed | Starting real-time market data updates for: F.US.EPH23 (ESH23). ID: 1 Service code: cme 2026-04-16 04:51:14.010 | Denali Data Feed | Connecting to the server ds7.sierracharts.com. Port 10048 2026-04-16 04:51:14.010 | CQG WebAPI | Sending symbol resolution request for F.US.EPH23. ID: 431301 2026-04-16 04:51:14.010 | Denali Data Feed | Requesting security definition data for: F.US.EPH23 (ESH23). ID: 1 2026-04-16 04:51:14.010 | Mapping F.US.EPM23 to ESM23. Service code: cme 2026-04-16 04:51:14.011 | Denali Data Feed | Starting real-time market data updates for: F.US.EPM23 (ESM23). ID: 2 Service code: cme 2026-04-16 04:51:14.011 | CQG WebAPI | Sending symbol resolution request for F.US.EPM23. ID: 431302 2026-04-16 04:51:14.011 | Denali Data Feed | Requesting security definition data for: F.US.EPM23 (ESM23). ID: 2 2026-04-16 04:51:14.011 | Mapping F.US.EPU23 to ESU23. Service code: cme 2026-04-16 04:51:14.011 | Denali Data Feed | Starting real-time market data updates for: F.US.EPU23 (ESU23). ID: 3 Service code: cme 2026-04-16 04:51:14.011 | CQG WebAPI | Sending symbol resolution request for F.US.EPU23. ID: 431303 2026-04-16 04:51:14.011 | Denali Data Feed | Requesting security definition data for: F.US.EPU23 (ESU23). ID: 3 2026-04-16 04:51:14.011 | Mapping F.US.EPZ23 to ESZ23. Service code: cme 2026-04-16 04:51:14.011 | Denali Data Feed | Starting real-time market data updates for: F.US.EPZ23 (ESZ23). ID: 4 Service code: cme 2026-04-16 04:51:14.011 | CQG WebAPI | Sending symbol resolution request for F.US.EPZ23. ID: 431304 2026-04-16 04:51:14.011 | Denali Data Feed | Requesting security definition data for: F.US.EPZ23 (ESZ23). ID: 4 2026-04-16 04:51:14.011 | Mapping F.US.EPH24 to ESH24. Service code: cme 2026-04-16 04:51:14.011 | Denali Data Feed | Starting real-time market data updates for: F.US.EPH24 (ESH24). ID: 5 Service code: cme 2026-04-16 04:51:14.011 | CQG WebAPI | Sending symbol resolution request for F.US.EPH24. ID: 431305 2026-04-16 04:51:14.011 | Denali Data Feed | Requesting security definition data for: F.US.EPH24 (ESH24). ID: 5 2026-04-16 04:51:14.011 | Mapping F.US.CLEF23 to CLF23. Service code: nymex 2026-04-16 04:51:14.012 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEF23 (CLF23). ID: 6 Service code: nymex 2026-04-16 04:51:14.012 | CQG WebAPI | Sending symbol resolution request for F.US.CLEF23. ID: 431306 2026-04-16 04:51:14.012 | Denali Data Feed | Requesting security definition data for: F.US.CLEF23 (CLF23). ID: 6 2026-04-16 04:51:14.012 | Mapping F.US.CLEG23 to CLG23. Service code: nymex 2026-04-16 04:51:14.012 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEG23 (CLG23). ID: 7 Service code: nymex 2026-04-16 04:51:14.012 | CQG WebAPI | Sending symbol resolution request for F.US.CLEG23. ID: 431307 2026-04-16 04:51:14.012 | Denali Data Feed | Requesting security definition data for: F.US.CLEG23 (CLG23). ID: 7 2026-04-16 04:51:14.012 | Mapping F.US.CLEH23 to CLH23. Service code: nymex 2026-04-16 04:51:14.012 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEH23 (CLH23). ID: 8 Service code: nymex 2026-04-16 04:51:14.012 | CQG WebAPI | Sending symbol resolution request for F.US.CLEH23. ID: 431308 2026-04-16 04:51:14.012 | Denali Data Feed | Requesting security definition data for: F.US.CLEH23 (CLH23). ID: 8 2026-04-16 04:51:14.012 | Mapping F.US.CLEJ23 to CLJ23. Service code: nymex 2026-04-16 04:51:14.013 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEJ23 (CLJ23). ID: 9 Service code: nymex 2026-04-16 04:51:14.013 | CQG WebAPI | Sending symbol resolution request for F.US.CLEJ23. ID: 431309 2026-04-16 04:51:14.013 | Denali Data Feed | Requesting security definition data for: F.US.CLEJ23 (CLJ23). ID: 9 2026-04-16 04:51:14.013 | Mapping F.US.CLEK23 to CLK23. Service code: nymex 2026-04-16 04:51:14.013 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEK23 (CLK23). ID: 10 Service code: nymex 2026-04-16 04:51:14.013 | CQG WebAPI | Sending symbol resolution request for F.US.CLEK23. ID: 431310 2026-04-16 04:51:14.013 | Denali Data Feed | Requesting security definition data for: F.US.CLEK23 (CLK23). ID: 10 2026-04-16 04:51:14.013 | Mapping F.US.CLEM23 to CLM23. Service code: nymex 2026-04-16 04:51:14.014 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEM23 (CLM23). ID: 11 Service code: nymex 2026-04-16 04:51:14.014 | CQG WebAPI | Sending symbol resolution request for F.US.CLEM23. ID: 431311 2026-04-16 04:51:14.014 | Denali Data Feed | Requesting security definition data for: F.US.CLEM23 (CLM23). ID: 11 2026-04-16 04:51:14.014 | Mapping F.US.CLEN23 to CLN23. Service code: nymex 2026-04-16 04:51:14.014 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEN23 (CLN23). ID: 12 Service code: nymex 2026-04-16 04:51:14.014 | CQG WebAPI | Sending symbol resolution request for F.US.CLEN23. ID: 431312 2026-04-16 04:51:14.014 | Denali Data Feed | Requesting security definition data for: F.US.CLEN23 (CLN23). ID: 12 2026-04-16 04:51:14.014 | Mapping F.US.CLEQ23 to CLQ23. Service code: nymex 2026-04-16 04:51:14.014 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEQ23 (CLQ23). ID: 13 Service code: nymex 2026-04-16 04:51:14.014 | CQG WebAPI | Sending symbol resolution request for F.US.CLEQ23. ID: 431313 2026-04-16 04:51:14.014 | Denali Data Feed | Requesting security definition data for: F.US.CLEQ23 (CLQ23). ID: 13 2026-04-16 04:51:14.014 | Mapping F.US.CLEU23 to CLU23. Service code: nymex 2026-04-16 04:51:14.014 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEU23 (CLU23). ID: 14 Service code: nymex 2026-04-16 04:51:14.014 | CQG WebAPI | Sending symbol resolution request for F.US.CLEU23. ID: 431314 2026-04-16 04:51:14.014 | Denali Data Feed | Requesting security definition data for: F.US.CLEU23 (CLU23). ID: 14 2026-04-16 04:51:14.014 | Mapping F.US.CLEV23 to CLV23. Service code: nymex 2026-04-16 04:51:14.014 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEV23 (CLV23). ID: 15 Service code: nymex 2026-04-16 04:51:14.014 | CQG WebAPI | Sending symbol resolution request for F.US.CLEV23. ID: 431315 2026-04-16 04:51:14.014 | Denali Data Feed | Requesting security definition data for: F.US.CLEV23 (CLV23). ID: 15 2026-04-16 04:51:14.014 | Mapping F.US.CLEX23 to CLX23. Service code: nymex 2026-04-16 04:51:14.015 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEX23 (CLX23). ID: 16 Service code: nymex 2026-04-16 04:51:14.015 | CQG WebAPI | Sending symbol resolution request for F.US.CLEX23. ID: 431316 2026-04-16 04:51:14.015 | Denali Data Feed | Requesting security definition data for: F.US.CLEX23 (CLX23). ID: 16 2026-04-16 04:51:14.015 | Mapping F.US.CLEZ23 to CLZ23. Service code: nymex 2026-04-16 04:51:14.015 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEZ23 (CLZ23). ID: 17 Service code: nymex 2026-04-16 04:51:14.015 | CQG WebAPI | Sending symbol resolution request for F.US.CLEZ23. ID: 431317 2026-04-16 04:51:14.015 | Denali Data Feed | Requesting security definition data for: F.US.CLEZ23 (CLZ23). ID: 17 2026-04-16 04:51:14.015 | Mapping F.US.CLEF24 to CLF24. Service code: nymex 2026-04-16 04:51:14.015 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEF24 (CLF24). ID: 18 Service code: nymex 2026-04-16 04:51:14.015 | CQG WebAPI | Sending symbol resolution request for F.US.CLEF24. ID: 431318 2026-04-16 04:51:14.015 | Denali Data Feed | Requesting security definition data for: F.US.CLEF24 (CLF24). ID: 18 2026-04-16 04:51:14.015 | Mapping F.US.CLEG24 to CLG24. Service code: nymex 2026-04-16 04:51:14.015 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEG24 (CLG24). ID: 19 Service code: nymex 2026-04-16 04:51:14.015 | CQG WebAPI | Sending symbol resolution request for F.US.CLEG24. ID: 431319 2026-04-16 04:51:14.015 | Denali Data Feed | Requesting security definition data for: F.US.CLEG24 (CLG24). ID: 19 2026-04-16 04:51:14.041 | DTC Client socket (3) | Creating socket. 2026-04-16 04:51:14.041 | DTC Client socket (3) | New receive buffer size: 0 2026-04-16 04:51:14.041 | DTC Client socket (3) | Connecting to IP: 69.39.70.253. 2026-04-16 04:51:14.046 | Mapping F.US.CLEV25 to CLV25. Service code: nymex 2026-04-16 04:51:14.046 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEV25 (CLV25). ID: 20 Service code: nymex 2026-04-16 04:51:14.046 | CQG WebAPI | Sending symbol resolution request for F.US.CLEV25. ID: 431320 2026-04-16 04:51:14.046 | Denali Data Feed | Requesting security definition data for: F.US.CLEV25 (CLV25). ID: 20 2026-04-16 04:51:14.047 | Added historical Intraday data request for F.US.CLEV25 to the queue. 2026-04-16 04:51:14.047 | Intraday data recording state for symbol F.US.CLEV25 is set to download 'Pending'. 2026-04-16 04:51:14.047 | Triggering next historical data download in queue. 2026-04-16 04:51:14.047 | Delaying start of download for F.US.CLEV25. 2026-04-16 04:51:14.055 | Mapping F.US.BP6U25 to 6BU25. Service code: cme 2026-04-16 04:51:14.055 | Denali Data Feed | Starting real-time market data updates for: F.US.BP6U25 (6BU25). ID: 21 Service code: cme 2026-04-16 04:51:14.055 | CQG WebAPI | Sending symbol resolution request for F.US.BP6U25. ID: 431321 2026-04-16 04:51:14.055 | Denali Data Feed | Requesting security definition data for: F.US.BP6U25 (6BU25). ID: 21 2026-04-16 04:51:14.055 | Added historical Intraday data request for F.US.BP6U25 to the queue. 2026-04-16 04:51:14.055 | Intraday data recording state for symbol F.US.BP6U25 is set to download 'Pending'. 2026-04-16 04:51:14.055 | Triggering next historical data download in queue. 2026-04-16 04:51:14.112 | CQG WebAPI | Received symbol resolution report for symbol F.US.EPH23. Search Symbol: F.US.EPH23. Request ID: 431301. Contract ID: 1. 2026-04-16 04:51:14.112 | CQG WebAPI | Brokerage name: AMP. Account Name: 220033 2026-04-16 04:51:14.112 | Updated verified funded futures trading account ending date to: 2026-05-16 08:51:14 2026-04-16 04:51:14.112 | CQG WebAPI | Sending collateral subscribe request. 2026-04-16 04:51:14.112 | CQG WebAPI | Received symbol resolution report for symbol F.US.EPM23. Search Symbol: F.US.EPM23. Request ID: 431302. Contract ID: 2. 2026-04-16 04:51:14.112 | CQG WebAPI | Received symbol resolution report for symbol F.US.EPU23. Search Symbol: F.US.EPU23. Request ID: 431303. Contract ID: 3. 2026-04-16 04:51:14.112 | CQG WebAPI | Received symbol resolution report for symbol F.US.EPZ23. Search Symbol: F.US.EPZ23. Request ID: 431304. Contract ID: 4. 2026-04-16 04:51:14.112 | CQG WebAPI | Received symbol resolution report for symbol F.US.EPH24. Search Symbol: F.US.EPH24. Request ID: 431305. Contract ID: 5. 2026-04-16 04:51:14.112 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEF23. Search Symbol: F.US.CLEF23. Request ID: 431306. Contract ID: 6. 2026-04-16 04:51:14.112 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEG23. Search Symbol: F.US.CLEG23. Request ID: 431307. Contract ID: 7. 2026-04-16 04:51:14.112 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEH23. Search Symbol: F.US.CLEH23. Request ID: 431308. Contract ID: 8. 2026-04-16 04:51:14.112 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEJ23. Search Symbol: F.US.CLEJ23. Request ID: 431309. Contract ID: 9. 2026-04-16 04:51:14.113 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEK23. Search Symbol: F.US.CLEK23. Request ID: 431310. Contract ID: 10. 2026-04-16 04:51:14.113 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEM23. Search Symbol: F.US.CLEM23. Request ID: 431311. Contract ID: 11. 2026-04-16 04:51:14.113 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEN23. Search Symbol: F.US.CLEN23. Request ID: 431312. Contract ID: 12. 2026-04-16 04:51:14.113 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEQ23. Search Symbol: F.US.CLEQ23. Request ID: 431313. Contract ID: 13. 2026-04-16 04:51:14.113 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEU23. Search Symbol: F.US.CLEU23. Request ID: 431314. Contract ID: 14. 2026-04-16 04:51:14.113 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEV23. Search Symbol: F.US.CLEV23. Request ID: 431315. Contract ID: 15. 2026-04-16 04:51:14.113 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEX23. Search Symbol: F.US.CLEX23. Request ID: 431316. Contract ID: 16. 2026-04-16 04:51:14.113 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEZ23. Search Symbol: F.US.CLEZ23. Request ID: 431317. Contract ID: 17. 2026-04-16 04:51:14.113 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEF24. Search Symbol: F.US.CLEF24. Request ID: 431318. Contract ID: 18. 2026-04-16 04:51:14.113 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEG24. Search Symbol: F.US.CLEG24. Request ID: 431319. Contract ID: 19. 2026-04-16 04:51:14.113 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEV25. Search Symbol: F.US.CLEV25. Request ID: 431320. Contract ID: 20. 2026-04-16 04:51:14.113 | CQG WebAPI | Received symbol resolution report for symbol F.US.BP6U25. Search Symbol: F.US.BP6U25. Request ID: 431321. Contract ID: 21. 2026-04-16 04:51:14.113 | Mapping F.US.EPU25 to ESU25. Service code: cme 2026-04-16 04:51:14.113 | Denali Data Feed | Starting real-time market data updates for: F.US.EPU25 (ESU25). ID: 22 Service code: cme 2026-04-16 04:51:14.113 | CQG WebAPI | Sending symbol resolution request for F.US.EPU25. ID: 431323 2026-04-16 04:51:14.114 | Denali Data Feed | Requesting security definition data for: F.US.EPU25 (ESU25). ID: 22 2026-04-16 04:51:14.114 | Added historical Intraday data request for F.US.EPU25 to the queue. 2026-04-16 04:51:14.114 | Intraday data recording state for symbol F.US.EPU25 is set to download 'Pending'. 2026-04-16 04:51:14.114 | Triggering next historical data download in queue. 2026-04-16 04:51:14.200 | CQG WebAPI | Received symbol resolution report for symbol F.US.EPU25. Search Symbol: F.US.EPU25. Request ID: 431323. Contract ID: 22. 2026-04-16 04:51:14.201 | Denali Data Feed | Network connection to server complete. 2026-04-16 04:51:14.201 | Denali Data Feed | Starting socket receive thread. 2026-04-16 04:51:14.201 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard 2026-04-16 04:51:14.233 | CQG WebAPI | Sending positions subscribe request. RequestID: 431324 2026-04-16 04:51:14.233 | CQG WebAPI | Sending orders subscribe request. RequestID: 431325 2026-04-16 04:51:14.325 | Denali Data Feed | Setting DTC encoding to Binary VLS 2026-04-16 04:51:14.325 | Denali Data Feed | Sending logon request message. 2026-04-16 04:51:14.853 | Denali Data Feed | Received logon response. 2026-04-16 04:51:14.853 | Denali Data Feed | Server Name: SC Realtime Server. 2026-04-16 04:51:14.853 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8 2026-04-16 04:51:14.853 | Denali Data Feed | Successfully connected. 2026-04-16 04:51:14.853 | Denali Data Feed | Trading is not supported. 2026-04-16 04:51:14.853 | Denali Data Feed | MarketDepthIsSupported: 1 2026-04-16 04:51:14.853 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.BP6U25 -> 6BU25 2026-04-16 04:51:14.853 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEF23 -> CLF23 2026-04-16 04:51:14.853 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEF24 -> CLF24 2026-04-16 04:51:14.853 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEG23 -> CLG23 2026-04-16 04:51:14.853 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEG24 -> CLG24 2026-04-16 04:51:14.853 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEH23 -> CLH23 2026-04-16 04:51:14.853 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEJ23 -> CLJ23 2026-04-16 04:51:14.853 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEK23 -> CLK23 2026-04-16 04:51:14.853 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEM23 -> CLM23 2026-04-16 04:51:14.853 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEN23 -> CLN23 2026-04-16 04:51:14.853 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEQ23 -> CLQ23 2026-04-16 04:51:14.853 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEU23 -> CLU23 2026-04-16 04:51:14.853 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEV23 -> CLV23 2026-04-16 04:51:14.853 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEV25 -> CLV25 2026-04-16 04:51:14.853 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEX23 -> CLX23 2026-04-16 04:51:14.853 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEZ23 -> CLZ23 2026-04-16 04:51:14.853 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.EPH23 -> ESH23 2026-04-16 04:51:14.853 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.EPH24 -> ESH24 2026-04-16 04:51:14.853 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.EPM23 -> ESM23 2026-04-16 04:51:14.853 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.EPU23 -> ESU23 2026-04-16 04:51:14.853 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.EPU25 -> ESU25 2026-04-16 04:51:14.853 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.EPZ23 -> ESZ23 2026-04-16 04:51:15.041 | Denali Data Feed | Real-time data for symbol F.US.BP6U25 is currently unavailable. 2026-04-16 04:51:15.041 | Denali Data Feed | Received security definition for symbol F.US.BP6U25 2026-04-16 04:51:15.041 | Denali Data Feed | Real-time data for symbol F.US.CLEF23 is currently unavailable. 2026-04-16 04:51:15.041 | Denali Data Feed | Received security definition for symbol F.US.CLEF23 2026-04-16 04:51:15.041 | Denali Data Feed | Real-time data for symbol F.US.CLEF24 is currently unavailable. 2026-04-16 04:51:15.041 | Denali Data Feed | Received security definition for symbol F.US.CLEF24 2026-04-16 04:51:15.041 | Denali Data Feed | Real-time data for symbol F.US.CLEG23 is currently unavailable. 2026-04-16 04:51:15.041 | Denali Data Feed | Received security definition for symbol F.US.CLEG23 2026-04-16 04:51:15.041 | Denali Data Feed | Real-time data for symbol F.US.CLEG24 is currently unavailable. 2026-04-16 04:51:15.041 | Denali Data Feed | Received security definition for symbol F.US.CLEG24 2026-04-16 04:51:15.041 | Denali Data Feed | Real-time data for symbol F.US.CLEH23 is currently unavailable. 2026-04-16 04:51:15.041 | Denali Data Feed | Received security definition for symbol F.US.CLEH23 2026-04-16 04:51:15.041 | Denali Data Feed | Real-time data for symbol F.US.CLEJ23 is currently unavailable. 2026-04-16 04:51:15.041 | Denali Data Feed | Received security definition for symbol F.US.CLEJ23 2026-04-16 04:51:15.041 | Denali Data Feed | Real-time data for symbol F.US.CLEK23 is currently unavailable. 2026-04-16 04:51:15.041 | Denali Data Feed | Received security definition for symbol F.US.CLEK23 2026-04-16 04:51:15.041 | Denali Data Feed | Real-time data for symbol F.US.CLEM23 is currently unavailable. 2026-04-16 04:51:15.041 | Denali Data Feed | Received security definition for symbol F.US.CLEM23 2026-04-16 04:51:15.041 | Denali Data Feed | Real-time data for symbol F.US.CLEN23 is currently unavailable. 2026-04-16 04:51:15.041 | Denali Data Feed | Received security definition for symbol F.US.CLEN23 2026-04-16 04:51:15.041 | Denali Data Feed | Real-time data for symbol F.US.CLEQ23 is currently unavailable. 2026-04-16 04:51:15.041 | Denali Data Feed | Received security definition for symbol F.US.CLEQ23 2026-04-16 04:51:15.041 | Denali Data Feed | Real-time data for symbol F.US.CLEU23 is currently unavailable. 2026-04-16 04:51:15.041 | Denali Data Feed | Received security definition for symbol F.US.CLEU23 2026-04-16 04:51:15.041 | Denali Data Feed | Real-time data for symbol F.US.CLEV23 is currently unavailable. 2026-04-16 04:51:15.041 | Denali Data Feed | Received security definition for symbol F.US.CLEV23 2026-04-16 04:51:15.041 | Denali Data Feed | Real-time data for symbol F.US.CLEV25 is currently unavailable. 2026-04-16 04:51:15.041 | Denali Data Feed | Received security definition for symbol F.US.CLEV25 2026-04-16 04:51:15.041 | Denali Data Feed | Real-time data for symbol F.US.CLEX23 is currently unavailable. 2026-04-16 04:51:15.041 | Denali Data Feed | Received security definition for symbol F.US.CLEX23 2026-04-16 04:51:15.041 | Denali Data Feed | Real-time data for symbol F.US.CLEZ23 is currently unavailable. 2026-04-16 04:51:15.041 | Denali Data Feed | Received security definition for symbol F.US.CLEZ23 2026-04-16 04:51:15.041 | Denali Data Feed | Real-time data for symbol F.US.EPH23 is currently unavailable. 2026-04-16 04:51:15.041 | Denali Data Feed | Received security definition for symbol F.US.EPH23 2026-04-16 04:51:15.041 | Denali Data Feed | Real-time data for symbol F.US.EPH24 is currently unavailable. 2026-04-16 04:51:15.041 | Denali Data Feed | Received security definition for symbol F.US.EPH24 2026-04-16 04:51:15.041 | Denali Data Feed | Real-time data for symbol F.US.EPM23 is currently unavailable. 2026-04-16 04:51:15.041 | Denali Data Feed | Received security definition for symbol F.US.EPM23 2026-04-16 04:51:15.041 | Denali Data Feed | Real-time data for symbol F.US.EPU23 is currently unavailable. 2026-04-16 04:51:15.041 | Denali Data Feed | Received security definition for symbol F.US.EPU23 2026-04-16 04:51:15.041 | Denali Data Feed | Real-time data for symbol F.US.EPU25 is currently unavailable. 2026-04-16 04:51:15.041 | Denali Data Feed | Received security definition for symbol F.US.EPU25 2026-04-16 04:51:15.041 | Denali Data Feed | Real-time data for symbol F.US.EPZ23 is currently unavailable. 2026-04-16 04:51:15.041 | Denali Data Feed | Received security definition for symbol F.US.EPZ23 2026-04-16 04:51:18.985 | Requesting market depth updates for: F.US.CLEV25 if supported. NumLevels=100 2026-04-16 04:51:19.167 | Denali Data Feed | Clearing market depth for F.US.CLEV25 2026-04-16 04:51:20.749 | HD Request # 24 | Downloading Intraday chart data for F.US.CLEV25 to the file F.US.CLEV25.scid. Service: nymex 2026-04-16 04:51:20.760 | HD Request # 24 | Download start date-time: 2025-09-22 14:29:55.000000. File last date-time: 2025-09-22 14:29:55.618000 2026-04-16 04:51:20.761 | HD Request # 24 | Using server: ds26.sierracharts.com port 10149 2026-04-16 04:51:20.762 | Socket (4) | Creating socket. 2026-04-16 04:51:20.762 | Socket (4) | New receive buffer size: 0 2026-04-16 04:51:20.762 | Socket (4) | Connecting to IP: 64.152.155.17. 2026-04-16 04:51:20.942 | HD Request # 24 | Setting DTC encoding to Binary VLS 2026-04-16 04:51:20.942 | HD Request # 24 | Sending historical data logon request message. 2026-04-16 04:51:21.060 | HD Request # 24 | Requesting Intraday data. Start date-time: 2025-09-22 14:29:55. Record interval: 0. Symbol: CLV25 2026-04-16 04:51:21.148 | HD Request # 24 | Decompressing data. 2026-04-16 04:51:21.237 | HD Request # 24 | Receiving Intraday data for F.US.CLEV25 starting at 2025-09-22 14:29:55.086000 2026-04-16 04:51:21.237 | Socket (4) | CloseSocket call. 2026-04-16 04:51:21.237 | Socket (4) | Shutdown started. Waiting for graceful close. 2026-04-16 04:51:21.237 | Historical data download thread signaled to stop. 2026-04-16 04:51:21.237 | HD Request # 24 | Received 2 Intraday data records from 2025-09-22 14:29:55.086000 to 2025-09-22 14:29:55.618000 (0.5 seconds. Delay: 205.6 days) and wrote 0 records for F.US.CLEV25 2026-04-16 04:51:21.238 | HD Request # 24 | Add time&sales data | Remembered last file record date-time: 2025-09-22 18:29:55.618000 2026-04-16 04:51:21.238 | HD Request # 24 | Completion time: 1s. 2026-04-16 04:51:21.238 | HD Request # 24 | Intraday data download complete for F.US.CLEV25. Unique request ID: 24 2026-04-16 04:51:21.238 | Removing historical data download ID 24. 2026-04-16 04:51:21.238 | Real-time Intraday chart data file updates started for F.US.CLEV25 2026-04-16 04:51:21.238 | Intraday chart data file opened for F.US.CLEV25 2026-04-16 04:51:21.238 | HD Request # 24 | Enabling Intraday chart updating for symbol. 2026-04-16 04:51:21.238 | 2026-04-16 04:51:21.238 | Triggering next historical data download in queue. 2026-04-16 04:51:21.238 | HD Request # 25 | Downloading Intraday chart data for F.US.BP6U25 to the file F.US.BP6U25.scid. Service: cme 2026-04-16 04:51:21.248 | HD Request # 25 | Download start date-time: 2025-09-15 10:02:50.000000. File last date-time: 2025-09-15 10:02:50.367000 2026-04-16 04:51:21.249 | HD Request # 25 | Using server: ds28.sierracharts.com port 10150 2026-04-16 04:51:21.249 | Socket (5) | Creating socket. 2026-04-16 04:51:21.250 | Socket (5) | New receive buffer size: 0 2026-04-16 04:51:21.250 | Socket (5) | Connecting to IP: 67.214.125.5. 2026-04-16 04:51:21.325 | Socket (4) | Socket gracefully closed by remote side. 2026-04-16 04:51:21.325 | Socket (4) | Closed. 2026-04-16 04:51:21.439 | HD Request # 25 | Setting DTC encoding to Binary VLS 2026-04-16 04:51:21.439 | HD Request # 25 | Sending historical data logon request message. 2026-04-16 04:51:21.563 | HD Request # 25 | Requesting Intraday data. Start date-time: 2025-09-15 10:02:50. Record interval: 0. Symbol: 6BU25 2026-04-16 04:51:21.657 | HD Request # 25 | Decompressing data. 2026-04-16 04:51:21.752 | HD Request # 25 | Receiving Intraday data for F.US.BP6U25 starting at 2025-09-15 10:02:50.367000 2026-04-16 04:51:21.753 | Socket (5) | CloseSocket call. 2026-04-16 04:51:21.753 | Socket (5) | Shutdown started. Waiting for graceful close. 2026-04-16 04:51:21.768 | Historical data download thread signaled to stop. 2026-04-16 04:51:21.768 | HD Request # 25 | Received 1 Intraday data record from 2025-09-15 10:02:50.367000 to 2025-09-15 10:02:50.367000 (0.0 seconds. Delay: 212.8 days) and wrote 0 records for F.US.BP6U25 2026-04-16 04:51:21.769 | HD Request # 25 | Add time&sales data | Remembered last file record date-time: 2025-09-15 14:02:50.367000 2026-04-16 04:51:21.769 | HD Request # 25 | Completion time: 0s. 2026-04-16 04:51:21.769 | HD Request # 25 | Intraday data download complete for F.US.BP6U25. Unique request ID: 25 2026-04-16 04:51:21.769 | Removing historical data download ID 25. 2026-04-16 04:51:21.769 | Real-time Intraday chart data file updates started for F.US.BP6U25 2026-04-16 04:51:21.769 | Intraday chart data file opened for F.US.BP6U25 2026-04-16 04:51:21.769 | HD Request # 25 | Enabling Intraday chart updating for symbol. 2026-04-16 04:51:21.769 | 2026-04-16 04:51:21.769 | Triggering next historical data download in queue. 2026-04-16 04:51:21.772 | HD Request # 26 | Downloading Intraday chart data for F.US.EPU25 to the file F.US.EPU25.scid. Service: cme 2026-04-16 04:51:21.808 | HD Request # 26 | Download start date-time: 2025-09-19 09:29:58.000000. File last date-time: 2025-09-19 09:29:58.698000 2026-04-16 04:51:21.808 | HD Request # 26 | Using server: ds32.sierracharts.com port 10149 2026-04-16 04:51:21.809 | Socket (4) | Creating socket. 2026-04-16 04:51:21.809 | Socket (4) | New receive buffer size: 0 2026-04-16 04:51:21.809 | Socket (4) | Connecting to IP: 69.39.70.248. 2026-04-16 04:51:21.846 | Socket (5) | Socket gracefully closed by remote side. 2026-04-16 04:51:21.846 | Socket (5) | Closed. 2026-04-16 04:51:22.000 | HD Request # 26 | Setting DTC encoding to Binary VLS 2026-04-16 04:51:22.000 | HD Request # 26 | Sending historical data logon request message. 2026-04-16 04:51:22.157 | HD Request # 26 | Requesting Intraday data. Start date-time: 2025-09-19 09:29:58. Record interval: 0. Symbol: ESU25 2026-04-16 04:51:22.252 | HD Request # 26 | Decompressing data. 2026-04-16 04:51:22.346 | HD Request # 26 | Receiving Intraday data for F.US.EPU25 starting at 2025-09-19 09:29:58.697000 2026-04-16 04:51:22.346 | Socket (4) | CloseSocket call. 2026-04-16 04:51:22.346 | Socket (4) | Shutdown started. Waiting for graceful close. 2026-04-16 04:51:22.348 | Historical data download thread signaled to stop. 2026-04-16 04:51:22.349 | HD Request # 26 | Received 5 Intraday data records from 2025-09-19 09:29:58.697000 to 2025-09-19 09:29:58.698000 (0.0 seconds. Delay: 208.8 days) and wrote 0 records for F.US.EPU25 2026-04-16 04:51:22.350 | HD Request # 26 | Add time&sales data | Remembered last file record date-time: 2025-09-19 13:29:58.698000 2026-04-16 04:51:22.350 | HD Request # 26 | Completion time: 1s. 2026-04-16 04:51:22.350 | HD Request # 26 | Intraday data download complete for F.US.EPU25. Unique request ID: 26 2026-04-16 04:51:22.350 | Removing historical data download ID 26. 2026-04-16 04:51:22.350 | Real-time Intraday chart data file updates started for F.US.EPU25 2026-04-16 04:51:22.350 | Intraday chart data file opened for F.US.EPU25 2026-04-16 04:51:22.350 | HD Request # 26 | Enabling Intraday chart updating for symbol. 2026-04-16 04:51:22.350 | 2026-04-16 04:51:22.350 | No download requests in the queue to start downloads for. 2026-04-16 04:51:22.440 | Socket (4) | Socket gracefully closed by remote side. 2026-04-16 04:51:22.440 | Socket (4) | Closed. 2026-04-16 04:53:11.550 | CQG WebSocket socket (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. * 2026-04-16 04:53:11.550 | CQG WebSocket socket (1) | Socket gracefully closed by remote side. 2026-04-16 04:53:11.551 | CQG WebSocket socket (1) | Closed. 2026-04-16 06:18:05.622 | CQG WebSocket | Timeout waiting for pong message from server. 2026-04-16 06:18:05.622 | CQG WebAPI | WebSocket closed. 2026-04-16 06:18:05.622 | Connection to the external service has been lost. 2026-04-16 06:18:05.652 | Denali Data Feed | There has been no activity on the network socket for 25m 39s. Will reconnect. 2026-04-16 06:18:05.652 | Denali Data Feed | Waiting for socket receive thread to end 2026-04-16 06:18:05.660 | DTC Client socket (3) | CloseSocket call. 2026-04-16 06:18:05.660 | Denali Data Feed | Disconnected from the server. 2026-04-16 06:18:05.660 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds. 2026-04-16 06:18:05.661 | CQG WebAPI | Sending Web API Logoff message. 2026-04-16 06:18:05.661 | CQG WebSocket socket (2) | CloseSocket call. 2026-04-16 06:18:05.661 | CQG WebSocket socket (2) | Max send buffers used during socket life: 3 2026-04-16 06:18:05.661 | CQG WebSocket socket (2) | Max send buffer size during socket life: 539 2026-04-16 06:18:05.661 | CQG WebSocket | WebSocket closed. 2026-04-16 06:18:05.661 | CQG WebAPI | WebSocket closed. 2026-04-16 06:18:05.661 | CQG WebAPI | Disconnected. 2026-04-16 06:18:05.661 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-04-16 06:18:05.672 | DTC Client socket (3) | Shutdown started. Waiting for graceful close. 2026-04-16 06:18:05.672 | CQG WebSocket socket (2) | Write in progress. Shutdown being delayed. PendingSize=0 2026-04-16 06:18:05.672 | DTC Client socket (3) | Socket gracefully closed by remote side. 2026-04-16 06:18:05.673 | DTC Client socket (3) | Closed. 2026-04-16 06:18:07.670 | 2026-04-16 06:18:07.670 | CQG WebAPI | Connecting to server api.cqg.com 2026-04-16 06:18:07.670 | CQG WebSocket | Connecting to WebSocket server api.cqg.com:443 2026-04-16 06:18:07.878 | CQG WebSocket socket (1) | Creating socket. Using TLS 1.2. 2026-04-16 06:18:07.878 | CQG WebSocket socket (1) | New receive buffer size: 0 2026-04-16 06:18:07.878 | CQG WebSocket socket (1) | Connecting to IP: 195.166.124.175. 2026-04-16 06:18:07.883 | CQG WebSocket | Opening WebSocket. 2026-04-16 06:18:07.883 | CQG WebSocket | Sending WebSocket handshake. 2026-04-16 06:18:07.898 | CQG WebSocket | Server header | HTTP/1.1 101 Switching Protocols 2026-04-16 06:18:07.898 | CQG WebSocket | Server header | Connection: Upgrade 2026-04-16 06:18:07.898 | CQG WebSocket | Server header | Sec-WebSocket-Accept: FobIDGCfGsXXSVaj1s4tGpme/2k= 2026-04-16 06:18:07.898 | CQG WebSocket | Server header | Server: WebSocket++/0.8.2 2026-04-16 06:18:07.898 | CQG WebSocket | Server header | Upgrade: websocket 2026-04-16 06:18:07.898 | CQG WebSocket | Server header | 2026-04-16 06:18:07.898 | CQG WebSocket | Web socket state is now open. 2026-04-16 06:18:07.898 | CQG WebAPI | WebSocket connected. 2026-04-16 06:18:07.898 | CQG WebAPI | Sending market data logon message. 2026-04-16 06:18:08.277 | CQG WebAPI | Base Time: 2026-03-28T06:33:36. 2026-03-28 06:33:36 2026-04-16 06:18:08.277 | CQG WebAPI | Logon successful. Session Token = uDUeY319H7uqqDWHgJj0B7/+CwF4GILR4Y0pd++zVKgdVq/gMNlF6avQ0M2dba9oujanD2WX4pf 2026-04-16 06:18:08.277 | CQG WebAPI | Connection to server complete. 2026-04-16 06:18:08.277 | DTC Client socket (0) | CloseSocket call. 2026-04-16 06:18:08.277 | Denali Data Feed | Disconnected from the server. 2026-04-16 06:18:08.279 | No download requests in the queue to start downloads for. | Number times message added: 3 2026-04-16 06:18:08.279 | Updated verified funded futures trading account ending date to: 2026-05-16 10:18:08 2026-04-16 06:18:08.304 | CQG WebAPI | Sending Trade Accounts request message. 2026-04-16 06:18:08.405 | CQG WebAPI | Brokerage name: AMP. Account Name: 220033 2026-04-16 06:18:08.405 | Updated verified funded futures trading account ending date to: 2026-05-16 10:18:08 2026-04-16 06:18:08.405 | CQG WebAPI | Sending collateral subscribe request. 2026-04-16 06:18:08.438 | Mapping F.US.CLEV25 to CLV25. Service code: nymex 2026-04-16 06:18:08.438 | Using symbol data fast lookup vector 2026-04-16 06:18:08.439 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEV25 (CLV25). ID: 1 Service code: nymex 2026-04-16 06:18:08.439 | Denali Data Feed | Connecting to the server ds28.sierracharts.com. Port 10048 2026-04-16 06:18:08.439 | CQG WebAPI | Sending symbol resolution request for F.US.CLEV25. ID: 431328 2026-04-16 06:18:08.439 | Denali Data Feed | Requesting security definition data for: F.US.CLEV25 (CLV25). ID: 1 2026-04-16 06:18:08.439 | Added historical Intraday data request for F.US.CLEV25 to the queue. 2026-04-16 06:18:08.439 | Intraday data recording state for symbol F.US.CLEV25 is set to download 'Pending'. 2026-04-16 06:18:08.439 | Triggering next historical data download in queue. 2026-04-16 06:18:08.439 | Delaying start of download for F.US.CLEV25. 2026-04-16 06:18:08.439 | DTC Client socket (3) | Creating socket. 2026-04-16 06:18:08.439 | DTC Client socket (3) | New receive buffer size: 0 2026-04-16 06:18:08.439 | DTC Client socket (3) | Connecting to IP: 67.214.125.5. 2026-04-16 06:18:08.447 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEV25. Search Symbol: F.US.CLEV25. Request ID: 431328. Contract ID: 1. 2026-04-16 06:18:08.447 | Mapping F.US.BP6U25 to 6BU25. Service code: cme 2026-04-16 06:18:08.447 | Denali Data Feed | Starting real-time market data updates for: F.US.BP6U25 (6BU25). ID: 2 Service code: cme 2026-04-16 06:18:08.447 | CQG WebAPI | Sending symbol resolution request for F.US.BP6U25. ID: 431329 2026-04-16 06:18:08.447 | Denali Data Feed | Requesting security definition data for: F.US.BP6U25 (6BU25). ID: 2 2026-04-16 06:18:08.447 | Added historical Intraday data request for F.US.BP6U25 to the queue. 2026-04-16 06:18:08.447 | Intraday data recording state for symbol F.US.BP6U25 is set to download 'Pending'. 2026-04-16 06:18:08.447 | Triggering next historical data download in queue. 2026-04-16 06:18:08.455 | CQG WebAPI | Received symbol resolution report for symbol F.US.BP6U25. Search Symbol: F.US.BP6U25. Request ID: 431329. Contract ID: 2. 2026-04-16 06:18:08.481 | Mapping F.US.EPU25 to ESU25. Service code: cme 2026-04-16 06:18:08.481 | Denali Data Feed | Starting real-time market data updates for: F.US.EPU25 (ESU25). ID: 3 Service code: cme 2026-04-16 06:18:08.481 | CQG WebAPI | Sending symbol resolution request for F.US.EPU25. ID: 431330 2026-04-16 06:18:08.481 | Denali Data Feed | Requesting security definition data for: F.US.EPU25 (ESU25). ID: 3 2026-04-16 06:18:08.481 | Added historical Intraday data request for F.US.EPU25 to the queue. 2026-04-16 06:18:08.481 | Intraday data recording state for symbol F.US.EPU25 is set to download 'Pending'. 2026-04-16 06:18:08.481 | Triggering next historical data download in queue. 2026-04-16 06:18:08.509 | CQG WebAPI | Received symbol resolution report for symbol F.US.EPU25. Search Symbol: F.US.EPU25. Request ID: 431330. Contract ID: 3. 2026-04-16 06:18:08.532 | CQG WebAPI | Sending positions subscribe request. RequestID: 431331 2026-04-16 06:18:08.532 | CQG WebAPI | Sending orders subscribe request. RequestID: 431332 2026-04-16 06:18:08.534 | Denali Data Feed | Network connection to server complete. 2026-04-16 06:18:08.534 | Denali Data Feed | Starting socket receive thread. 2026-04-16 06:18:08.534 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard 2026-04-16 06:18:08.640 | Denali Data Feed | Setting DTC encoding to Binary VLS 2026-04-16 06:18:08.640 | Denali Data Feed | Sending logon request message. 2026-04-16 06:18:08.859 | Mapping F.US.EPH23 to ESH23. Service code: cme 2026-04-16 06:18:08.860 | Denali Data Feed | Starting real-time market data updates for: F.US.EPH23 (ESH23). ID: 4 Service code: cme 2026-04-16 06:18:08.860 | CQG WebAPI | Sending symbol resolution request for F.US.EPH23. ID: 431333 2026-04-16 06:18:08.860 | Denali Data Feed | Requesting security definition data for: F.US.EPH23 (ESH23). ID: 4 2026-04-16 06:18:08.860 | Mapping F.US.EPM23 to ESM23. Service code: cme 2026-04-16 06:18:08.860 | Denali Data Feed | Starting real-time market data updates for: F.US.EPM23 (ESM23). ID: 5 Service code: cme 2026-04-16 06:18:08.860 | CQG WebAPI | Sending symbol resolution request for F.US.EPM23. ID: 431334 2026-04-16 06:18:08.860 | Denali Data Feed | Requesting security definition data for: F.US.EPM23 (ESM23). ID: 5 2026-04-16 06:18:08.860 | Mapping F.US.EPU23 to ESU23. Service code: cme 2026-04-16 06:18:08.861 | Denali Data Feed | Starting real-time market data updates for: F.US.EPU23 (ESU23). ID: 6 Service code: cme 2026-04-16 06:18:08.861 | CQG WebAPI | Sending symbol resolution request for F.US.EPU23. ID: 431335 2026-04-16 06:18:08.861 | Denali Data Feed | Requesting security definition data for: F.US.EPU23 (ESU23). ID: 6 2026-04-16 06:18:08.861 | Mapping F.US.EPZ23 to ESZ23. Service code: cme 2026-04-16 06:18:08.861 | Denali Data Feed | Starting real-time market data updates for: F.US.EPZ23 (ESZ23). ID: 7 Service code: cme 2026-04-16 06:18:08.861 | CQG WebAPI | Sending symbol resolution request for F.US.EPZ23. ID: 431336 2026-04-16 06:18:08.861 | Denali Data Feed | Requesting security definition data for: F.US.EPZ23 (ESZ23). ID: 7 2026-04-16 06:18:08.861 | Mapping F.US.EPH24 to ESH24. Service code: cme 2026-04-16 06:18:08.861 | Denali Data Feed | Starting real-time market data updates for: F.US.EPH24 (ESH24). ID: 8 Service code: cme 2026-04-16 06:18:08.861 | CQG WebAPI | Sending symbol resolution request for F.US.EPH24. ID: 431337 2026-04-16 06:18:08.861 | Denali Data Feed | Requesting security definition data for: F.US.EPH24 (ESH24). ID: 8 2026-04-16 06:18:08.861 | Mapping F.US.CLEF23 to CLF23. Service code: nymex 2026-04-16 06:18:08.862 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEF23 (CLF23). ID: 9 Service code: nymex 2026-04-16 06:18:08.862 | CQG WebAPI | Sending symbol resolution request for F.US.CLEF23. ID: 431338 2026-04-16 06:18:08.862 | Denali Data Feed | Requesting security definition data for: F.US.CLEF23 (CLF23). ID: 9 2026-04-16 06:18:08.862 | Mapping F.US.CLEG23 to CLG23. Service code: nymex 2026-04-16 06:18:08.862 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEG23 (CLG23). ID: 10 Service code: nymex 2026-04-16 06:18:08.862 | CQG WebAPI | Sending symbol resolution request for F.US.CLEG23. ID: 431339 2026-04-16 06:18:08.862 | Denali Data Feed | Requesting security definition data for: F.US.CLEG23 (CLG23). ID: 10 2026-04-16 06:18:08.862 | Mapping F.US.CLEH23 to CLH23. Service code: nymex 2026-04-16 06:18:08.862 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEH23 (CLH23). ID: 11 Service code: nymex 2026-04-16 06:18:08.862 | CQG WebAPI | Sending symbol resolution request for F.US.CLEH23. ID: 431340 2026-04-16 06:18:08.862 | Denali Data Feed | Requesting security definition data for: F.US.CLEH23 (CLH23). ID: 11 2026-04-16 06:18:08.862 | Mapping F.US.CLEJ23 to CLJ23. Service code: nymex 2026-04-16 06:18:08.862 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEJ23 (CLJ23). ID: 12 Service code: nymex 2026-04-16 06:18:08.862 | CQG WebAPI | Sending symbol resolution request for F.US.CLEJ23. ID: 431341 2026-04-16 06:18:08.862 | Denali Data Feed | Requesting security definition data for: F.US.CLEJ23 (CLJ23). ID: 12 2026-04-16 06:18:08.862 | Mapping F.US.CLEK23 to CLK23. Service code: nymex 2026-04-16 06:18:08.862 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEK23 (CLK23). ID: 13 Service code: nymex 2026-04-16 06:18:08.863 | CQG WebAPI | Sending symbol resolution request for F.US.CLEK23. ID: 431342 2026-04-16 06:18:08.863 | Denali Data Feed | Requesting security definition data for: F.US.CLEK23 (CLK23). ID: 13 2026-04-16 06:18:08.863 | Mapping F.US.CLEM23 to CLM23. Service code: nymex 2026-04-16 06:18:08.863 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEM23 (CLM23). ID: 14 Service code: nymex 2026-04-16 06:18:08.863 | CQG WebAPI | Sending symbol resolution request for F.US.CLEM23. ID: 431343 2026-04-16 06:18:08.863 | Denali Data Feed | Requesting security definition data for: F.US.CLEM23 (CLM23). ID: 14 2026-04-16 06:18:08.863 | Mapping F.US.CLEN23 to CLN23. Service code: nymex 2026-04-16 06:18:08.863 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEN23 (CLN23). ID: 15 Service code: nymex 2026-04-16 06:18:08.863 | CQG WebAPI | Sending symbol resolution request for F.US.CLEN23. ID: 431344 2026-04-16 06:18:08.863 | Denali Data Feed | Requesting security definition data for: F.US.CLEN23 (CLN23). ID: 15 2026-04-16 06:18:08.863 | Mapping F.US.CLEQ23 to CLQ23. Service code: nymex 2026-04-16 06:18:08.863 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEQ23 (CLQ23). ID: 16 Service code: nymex 2026-04-16 06:18:08.863 | CQG WebAPI | Sending symbol resolution request for F.US.CLEQ23. ID: 431345 2026-04-16 06:18:08.863 | Denali Data Feed | Requesting security definition data for: F.US.CLEQ23 (CLQ23). ID: 16 2026-04-16 06:18:08.863 | Mapping F.US.CLEU23 to CLU23. Service code: nymex 2026-04-16 06:18:08.863 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEU23 (CLU23). ID: 17 Service code: nymex 2026-04-16 06:18:08.863 | CQG WebAPI | Sending symbol resolution request for F.US.CLEU23. ID: 431346 2026-04-16 06:18:08.863 | Denali Data Feed | Requesting security definition data for: F.US.CLEU23 (CLU23). ID: 17 2026-04-16 06:18:08.864 | Mapping F.US.CLEV23 to CLV23. Service code: nymex 2026-04-16 06:18:08.864 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEV23 (CLV23). ID: 18 Service code: nymex 2026-04-16 06:18:08.864 | CQG WebAPI | Sending symbol resolution request for F.US.CLEV23. ID: 431347 2026-04-16 06:18:08.864 | Denali Data Feed | Requesting security definition data for: F.US.CLEV23 (CLV23). ID: 18 2026-04-16 06:18:08.864 | Mapping F.US.CLEX23 to CLX23. Service code: nymex 2026-04-16 06:18:08.864 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEX23 (CLX23). ID: 19 Service code: nymex 2026-04-16 06:18:08.864 | CQG WebAPI | Sending symbol resolution request for F.US.CLEX23. ID: 431348 2026-04-16 06:18:08.864 | Denali Data Feed | Requesting security definition data for: F.US.CLEX23 (CLX23). ID: 19 2026-04-16 06:18:08.864 | Mapping F.US.CLEZ23 to CLZ23. Service code: nymex 2026-04-16 06:18:08.864 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEZ23 (CLZ23). ID: 20 Service code: nymex 2026-04-16 06:18:08.864 | CQG WebAPI | Sending symbol resolution request for F.US.CLEZ23. ID: 431349 2026-04-16 06:18:08.864 | Denali Data Feed | Requesting security definition data for: F.US.CLEZ23 (CLZ23). ID: 20 2026-04-16 06:18:08.864 | Mapping F.US.CLEF24 to CLF24. Service code: nymex 2026-04-16 06:18:08.864 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEF24 (CLF24). ID: 21 Service code: nymex 2026-04-16 06:18:08.864 | CQG WebAPI | Sending symbol resolution request for F.US.CLEF24. ID: 431350 2026-04-16 06:18:08.864 | Denali Data Feed | Requesting security definition data for: F.US.CLEF24 (CLF24). ID: 21 2026-04-16 06:18:08.864 | Mapping F.US.CLEG24 to CLG24. Service code: nymex 2026-04-16 06:18:08.865 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEG24 (CLG24). ID: 22 Service code: nymex 2026-04-16 06:18:08.865 | CQG WebAPI | Sending symbol resolution request for F.US.CLEG24. ID: 431351 2026-04-16 06:18:08.865 | Denali Data Feed | Requesting security definition data for: F.US.CLEG24 (CLG24). ID: 22 2026-04-16 06:18:08.865 | CQG WebAPI | Received symbol resolution report for symbol F.US.EPH23. Search Symbol: F.US.EPH23. Request ID: 431333. Contract ID: 4. 2026-04-16 06:18:08.865 | CQG WebAPI | Received symbol resolution report for symbol F.US.EPM23. Search Symbol: F.US.EPM23. Request ID: 431334. Contract ID: 5. 2026-04-16 06:18:08.865 | CQG WebAPI | Received symbol resolution report for symbol F.US.EPU23. Search Symbol: F.US.EPU23. Request ID: 431335. Contract ID: 6. 2026-04-16 06:18:08.940 | CQG WebAPI | Received symbol resolution report for symbol F.US.EPZ23. Search Symbol: F.US.EPZ23. Request ID: 431336. Contract ID: 7. 2026-04-16 06:18:08.940 | CQG WebAPI | Received symbol resolution report for symbol F.US.EPH24. Search Symbol: F.US.EPH24. Request ID: 431337. Contract ID: 8. 2026-04-16 06:18:08.941 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEF23. Search Symbol: F.US.CLEF23. Request ID: 431338. Contract ID: 9. 2026-04-16 06:18:08.941 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEG23. Search Symbol: F.US.CLEG23. Request ID: 431339. Contract ID: 10. 2026-04-16 06:18:08.941 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEH23. Search Symbol: F.US.CLEH23. Request ID: 431340. Contract ID: 11. 2026-04-16 06:18:08.941 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEJ23. Search Symbol: F.US.CLEJ23. Request ID: 431341. Contract ID: 12. 2026-04-16 06:18:08.945 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEK23. Search Symbol: F.US.CLEK23. Request ID: 431342. Contract ID: 13. 2026-04-16 06:18:08.945 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEM23. Search Symbol: F.US.CLEM23. Request ID: 431343. Contract ID: 14. 2026-04-16 06:18:08.945 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEN23. Search Symbol: F.US.CLEN23. Request ID: 431344. Contract ID: 15. 2026-04-16 06:18:08.945 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEQ23. Search Symbol: F.US.CLEQ23. Request ID: 431345. Contract ID: 16. 2026-04-16 06:18:08.945 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEU23. Search Symbol: F.US.CLEU23. Request ID: 431346. Contract ID: 17. 2026-04-16 06:18:08.945 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEV23. Search Symbol: F.US.CLEV23. Request ID: 431347. Contract ID: 18. 2026-04-16 06:18:08.945 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEX23. Search Symbol: F.US.CLEX23. Request ID: 431348. Contract ID: 19. 2026-04-16 06:18:08.945 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEZ23. Search Symbol: F.US.CLEZ23. Request ID: 431349. Contract ID: 20. 2026-04-16 06:18:08.945 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEF24. Search Symbol: F.US.CLEF24. Request ID: 431350. Contract ID: 21. 2026-04-16 06:18:08.945 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEG24. Search Symbol: F.US.CLEG24. Request ID: 431351. Contract ID: 22. 2026-04-16 06:18:09.203 | Denali Data Feed | Received logon response. 2026-04-16 06:18:09.203 | Denali Data Feed | Server Name: SC Realtime Server. 2026-04-16 06:18:09.203 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8 2026-04-16 06:18:09.203 | Denali Data Feed | Successfully connected. 2026-04-16 06:18:09.203 | Denali Data Feed | Trading is not supported. 2026-04-16 06:18:09.203 | Denali Data Feed | MarketDepthIsSupported: 1 2026-04-16 06:18:09.203 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.BP6U25 -> 6BU25 2026-04-16 06:18:09.203 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEF23 -> CLF23 2026-04-16 06:18:09.203 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEF24 -> CLF24 2026-04-16 06:18:09.203 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEG23 -> CLG23 2026-04-16 06:18:09.203 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEG24 -> CLG24 2026-04-16 06:18:09.203 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEH23 -> CLH23 2026-04-16 06:18:09.203 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEJ23 -> CLJ23 2026-04-16 06:18:09.203 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEK23 -> CLK23 2026-04-16 06:18:09.203 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEM23 -> CLM23 2026-04-16 06:18:09.203 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEN23 -> CLN23 2026-04-16 06:18:09.203 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEQ23 -> CLQ23 2026-04-16 06:18:09.203 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEU23 -> CLU23 2026-04-16 06:18:09.203 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEV23 -> CLV23 2026-04-16 06:18:09.203 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEV25 -> CLV25 2026-04-16 06:18:09.203 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEX23 -> CLX23 2026-04-16 06:18:09.203 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEZ23 -> CLZ23 2026-04-16 06:18:09.203 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.EPH23 -> ESH23 2026-04-16 06:18:09.203 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.EPH24 -> ESH24 2026-04-16 06:18:09.203 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.EPM23 -> ESM23 2026-04-16 06:18:09.203 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.EPU23 -> ESU23 2026-04-16 06:18:09.203 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.EPU25 -> ESU25 2026-04-16 06:18:09.203 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.EPZ23 -> ESZ23 2026-04-16 06:18:09.391 | Denali Data Feed | Real-time data for symbol F.US.BP6U25 is currently unavailable. 2026-04-16 06:18:09.391 | Denali Data Feed | Received security definition for symbol F.US.BP6U25 2026-04-16 06:18:09.391 | Denali Data Feed | Real-time data for symbol F.US.CLEF23 is currently unavailable. 2026-04-16 06:18:09.391 | Denali Data Feed | Received security definition for symbol F.US.CLEF23 2026-04-16 06:18:09.391 | Denali Data Feed | Real-time data for symbol F.US.CLEF24 is currently unavailable. 2026-04-16 06:18:09.391 | Denali Data Feed | Received security definition for symbol F.US.CLEF24 2026-04-16 06:18:09.391 | Denali Data Feed | Real-time data for symbol F.US.CLEG23 is currently unavailable. 2026-04-16 06:18:09.391 | Denali Data Feed | Received security definition for symbol F.US.CLEG23 2026-04-16 06:18:09.391 | Denali Data Feed | Real-time data for symbol F.US.CLEG24 is currently unavailable. 2026-04-16 06:18:09.391 | Denali Data Feed | Received security definition for symbol F.US.CLEG24 2026-04-16 06:18:09.391 | Denali Data Feed | Real-time data for symbol F.US.CLEH23 is currently unavailable. 2026-04-16 06:18:09.391 | Denali Data Feed | Received security definition for symbol F.US.CLEH23 2026-04-16 06:18:09.391 | Denali Data Feed | Real-time data for symbol F.US.CLEJ23 is currently unavailable. 2026-04-16 06:18:09.391 | Denali Data Feed | Received security definition for symbol F.US.CLEJ23 2026-04-16 06:18:09.391 | Denali Data Feed | Real-time data for symbol F.US.CLEK23 is currently unavailable. 2026-04-16 06:18:09.391 | Denali Data Feed | Received security definition for symbol F.US.CLEK23 2026-04-16 06:18:09.391 | Denali Data Feed | Real-time data for symbol F.US.CLEM23 is currently unavailable. 2026-04-16 06:18:09.391 | Denali Data Feed | Received security definition for symbol F.US.CLEM23 2026-04-16 06:18:09.391 | Denali Data Feed | Real-time data for symbol F.US.CLEN23 is currently unavailable. 2026-04-16 06:18:09.391 | Denali Data Feed | Received security definition for symbol F.US.CLEN23 2026-04-16 06:18:09.391 | Denali Data Feed | Real-time data for symbol F.US.CLEQ23 is currently unavailable. 2026-04-16 06:18:09.391 | Denali Data Feed | Received security definition for symbol F.US.CLEQ23 2026-04-16 06:18:09.391 | Denali Data Feed | Real-time data for symbol F.US.CLEU23 is currently unavailable. 2026-04-16 06:18:09.391 | Denali Data Feed | Received security definition for symbol F.US.CLEU23 2026-04-16 06:18:09.391 | Denali Data Feed | Real-time data for symbol F.US.CLEV23 is currently unavailable. 2026-04-16 06:18:09.391 | Denali Data Feed | Received security definition for symbol F.US.CLEV23 2026-04-16 06:18:09.391 | Denali Data Feed | Real-time data for symbol F.US.CLEV25 is currently unavailable. 2026-04-16 06:18:09.391 | Denali Data Feed | Received security definition for symbol F.US.CLEV25 2026-04-16 06:18:09.391 | Denali Data Feed | Real-time data for symbol F.US.CLEX23 is currently unavailable. 2026-04-16 06:18:09.391 | Denali Data Feed | Received security definition for symbol F.US.CLEX23 2026-04-16 06:18:09.391 | Denali Data Feed | Real-time data for symbol F.US.CLEZ23 is currently unavailable. 2026-04-16 06:18:09.391 | Denali Data Feed | Received security definition for symbol F.US.CLEZ23 2026-04-16 06:18:09.391 | Denali Data Feed | Real-time data for symbol F.US.EPH23 is currently unavailable. 2026-04-16 06:18:09.391 | Denali Data Feed | Received security definition for symbol F.US.EPH23 2026-04-16 06:18:09.391 | Denali Data Feed | Real-time data for symbol F.US.EPH24 is currently unavailable. 2026-04-16 06:18:09.391 | Denali Data Feed | Received security definition for symbol F.US.EPH24 2026-04-16 06:18:09.391 | Denali Data Feed | Real-time data for symbol F.US.EPM23 is currently unavailable. 2026-04-16 06:18:09.391 | Denali Data Feed | Received security definition for symbol F.US.EPM23 2026-04-16 06:18:09.391 | Denali Data Feed | Real-time data for symbol F.US.EPU23 is currently unavailable. 2026-04-16 06:18:09.391 | Denali Data Feed | Received security definition for symbol F.US.EPU23 2026-04-16 06:18:09.391 | Denali Data Feed | Real-time data for symbol F.US.EPU25 is currently unavailable. 2026-04-16 06:18:09.391 | Denali Data Feed | Received security definition for symbol F.US.EPU25 2026-04-16 06:18:09.391 | Denali Data Feed | Real-time data for symbol F.US.EPZ23 is currently unavailable. 2026-04-16 06:18:09.391 | Denali Data Feed | Received security definition for symbol F.US.EPZ23 2026-04-16 06:18:13.289 | Requesting market depth updates for: F.US.CLEV25 if supported. NumLevels=100 2026-04-16 06:18:13.485 | Denali Data Feed | Clearing market depth for F.US.CLEV25 2026-04-16 06:18:14.616 | HD Request # 27 | Downloading Intraday chart data for F.US.CLEV25 to the file F.US.CLEV25.scid. Service: nymex 2026-04-16 06:18:14.617 | HD Request # 27 | Download start date-time: 2025-09-22 14:29:55.000000. File last date-time: 2025-09-22 14:29:55.618000 2026-04-16 06:18:14.617 | HD Request # 27 | Using server: ds26.sierracharts.com port 10150 2026-04-16 06:18:14.618 | Socket (4) | Creating socket. 2026-04-16 06:18:14.618 | Socket (4) | New receive buffer size: 0 2026-04-16 06:18:14.618 | Socket (4) | Connecting to IP: 64.152.155.17. 2026-04-16 06:18:14.798 | HD Request # 27 | Setting DTC encoding to Binary VLS 2026-04-16 06:18:14.798 | HD Request # 27 | Sending historical data logon request message. 2026-04-16 06:18:14.917 | HD Request # 27 | Requesting Intraday data. Start date-time: 2025-09-22 14:29:55. Record interval: 0. Symbol: CLV25 2026-04-16 06:18:15.006 | HD Request # 27 | Decompressing data. 2026-04-16 06:18:15.093 | HD Request # 27 | Receiving Intraday data for F.US.CLEV25 starting at 2025-09-22 14:29:55.086000 2026-04-16 06:18:15.093 | Socket (4) | CloseSocket call. 2026-04-16 06:18:15.093 | Socket (4) | Shutdown started. Waiting for graceful close. 2026-04-16 06:18:15.095 | Historical data download thread signaled to stop. 2026-04-16 06:18:15.095 | HD Request # 27 | Received 2 Intraday data records from 2025-09-22 14:29:55.086000 to 2025-09-22 14:29:55.618000 (0.5 seconds. Delay: 205.7 days) and wrote 0 records for F.US.CLEV25 2026-04-16 06:18:15.096 | HD Request # 27 | Add time&sales data | Remembered last file record date-time: 2025-09-22 18:29:55.618000 2026-04-16 06:18:15.097 | HD Request # 27 | Completion time: 1s. 2026-04-16 06:18:15.097 | HD Request # 27 | Intraday data download complete for F.US.CLEV25. Unique request ID: 27 2026-04-16 06:18:15.097 | Removing historical data download ID 27. 2026-04-16 06:18:15.097 | Real-time Intraday chart data file updates started for F.US.CLEV25 2026-04-16 06:18:15.097 | Intraday chart data file opened for F.US.CLEV25 2026-04-16 06:18:15.097 | HD Request # 27 | Enabling Intraday chart updating for symbol. 2026-04-16 06:18:15.097 | 2026-04-16 06:18:15.097 | Triggering next historical data download in queue. 2026-04-16 06:18:15.097 | HD Request # 28 | Downloading Intraday chart data for F.US.BP6U25 to the file F.US.BP6U25.scid. Service: cme 2026-04-16 06:18:15.097 | HD Request # 28 | Download start date-time: 2025-09-15 10:02:50.000000. File last date-time: 2025-09-15 10:02:50.367000 2026-04-16 06:18:15.097 | HD Request # 28 | Using server: ds28.sierracharts.com port 10149 2026-04-16 06:18:15.097 | Socket (5) | Creating socket. 2026-04-16 06:18:15.097 | Socket (5) | New receive buffer size: 0 2026-04-16 06:18:15.097 | Socket (5) | Connecting to IP: 67.214.125.5. 2026-04-16 06:18:15.182 | Socket (4) | Socket gracefully closed by remote side. 2026-04-16 06:18:15.182 | Socket (4) | Closed. 2026-04-16 06:18:15.288 | HD Request # 28 | Setting DTC encoding to Binary VLS 2026-04-16 06:18:15.289 | HD Request # 28 | Sending historical data logon request message. 2026-04-16 06:18:15.412 | HD Request # 28 | Requesting Intraday data. Start date-time: 2025-09-15 10:02:50. Record interval: 0. Symbol: 6BU25 2026-04-16 06:18:15.506 | HD Request # 28 | Decompressing data. 2026-04-16 06:18:15.599 | HD Request # 28 | Receiving Intraday data for F.US.BP6U25 starting at 2025-09-15 10:02:50.367000 2026-04-16 06:18:15.599 | Socket (5) | CloseSocket call. 2026-04-16 06:18:15.599 | Socket (5) | Shutdown started. Waiting for graceful close. 2026-04-16 06:18:15.601 | Historical data download thread signaled to stop. 2026-04-16 06:18:15.601 | HD Request # 28 | Received 1 Intraday data record from 2025-09-15 10:02:50.367000 to 2025-09-15 10:02:50.367000 (0.0 seconds. Delay: 212.8 days) and wrote 0 records for F.US.BP6U25 2026-04-16 06:18:15.602 | HD Request # 28 | Add time&sales data | Remembered last file record date-time: 2025-09-15 14:02:50.367000 2026-04-16 06:18:15.603 | HD Request # 28 | Completion time: 0s. 2026-04-16 06:18:15.603 | HD Request # 28 | Intraday data download complete for F.US.BP6U25. Unique request ID: 28 2026-04-16 06:18:15.603 | Removing historical data download ID 28. 2026-04-16 06:18:15.603 | Real-time Intraday chart data file updates started for F.US.BP6U25 2026-04-16 06:18:15.603 | Intraday chart data file opened for F.US.BP6U25 2026-04-16 06:18:15.603 | HD Request # 28 | Enabling Intraday chart updating for symbol. 2026-04-16 06:18:15.603 | 2026-04-16 06:18:15.603 | Triggering next historical data download in queue. 2026-04-16 06:18:15.603 | HD Request # 29 | Downloading Intraday chart data for F.US.EPU25 to the file F.US.EPU25.scid. Service: cme 2026-04-16 06:18:15.604 | HD Request # 29 | Download start date-time: 2025-09-19 09:29:58.000000. File last date-time: 2025-09-19 09:29:58.698000 2026-04-16 06:18:15.604 | HD Request # 29 | Using server: ds32.sierracharts.com port 10150 2026-04-16 06:18:15.605 | Socket (4) | Creating socket. 2026-04-16 06:18:15.605 | Socket (4) | New receive buffer size: 0 2026-04-16 06:18:15.605 | Socket (4) | Connecting to IP: 69.39.70.248. 2026-04-16 06:18:15.699 | Socket (5) | Socket gracefully closed by remote side. 2026-04-16 06:18:15.699 | Socket (5) | Closed. 2026-04-16 06:18:15.795 | HD Request # 29 | Setting DTC encoding to Binary VLS 2026-04-16 06:18:15.795 | HD Request # 29 | Sending historical data logon request message. 2026-04-16 06:18:15.919 | HD Request # 29 | Requesting Intraday data. Start date-time: 2025-09-19 09:29:58. Record interval: 0. Symbol: ESU25 2026-04-16 06:18:16.017 | HD Request # 29 | Decompressing data. 2026-04-16 06:18:16.110 | HD Request # 29 | Receiving Intraday data for F.US.EPU25 starting at 2025-09-19 09:29:58.697000 2026-04-16 06:18:16.110 | Socket (4) | CloseSocket call. 2026-04-16 06:18:16.110 | Socket (4) | Shutdown started. Waiting for graceful close. 2026-04-16 06:18:16.113 | Historical data download thread signaled to stop. 2026-04-16 06:18:16.113 | HD Request # 29 | Received 5 Intraday data records from 2025-09-19 09:29:58.697000 to 2025-09-19 09:29:58.698000 (0.0 seconds. Delay: 208.9 days) and wrote 0 records for F.US.EPU25 2026-04-16 06:18:16.113 | HD Request # 29 | Add time&sales data | Remembered last file record date-time: 2025-09-19 13:29:58.698000 2026-04-16 06:18:16.113 | HD Request # 29 | Completion time: 1s. 2026-04-16 06:18:16.113 | HD Request # 29 | Intraday data download complete for F.US.EPU25. Unique request ID: 29 2026-04-16 06:18:16.113 | Removing historical data download ID 29. 2026-04-16 06:18:16.113 | Real-time Intraday chart data file updates started for F.US.EPU25 2026-04-16 06:18:16.113 | Intraday chart data file opened for F.US.EPU25 2026-04-16 06:18:16.113 | HD Request # 29 | Enabling Intraday chart updating for symbol. 2026-04-16 06:18:16.113 | 2026-04-16 06:18:16.113 | No download requests in the queue to start downloads for. 2026-04-16 06:18:16.209 | Socket (4) | Socket gracefully closed by remote side. 2026-04-16 06:18:16.209 | Socket (4) | Closed. 2026-04-16 06:18:32.785 | CQG WebSocket socket (2) | Write has completed. Shutdown being performed. 2026-04-16 06:18:32.785 | CQG WebSocket socket (2) | Shutdown started. Waiting for graceful close. 2026-04-16 06:18:32.785 | CQG WebSocket socket (2) | Socket gracefully closed by remote side. 2026-04-16 06:18:32.785 | CQG WebSocket socket (2) | Closed. 2026-04-16 08:11:03.036 | CQG WebAPI | Sending Web API Logoff message. 2026-04-16 08:11:03.036 | CQG WebSocket socket (1) | CloseSocket call. 2026-04-16 08:11:03.036 | CQG WebSocket socket (1) | Max send buffers used during socket life: 3 2026-04-16 08:11:03.036 | CQG WebSocket socket (1) | Max send buffer size during socket life: 568 2026-04-16 08:11:03.036 | CQG WebSocket | WebSocket closed. 2026-04-16 08:11:03.036 | CQG WebAPI | WebSocket closed. 2026-04-16 08:11:03.037 | CQG WebSocket socket (1) | Write in progress. Shutdown being delayed. PendingSize=0 2026-04-16 08:11:03.037 | Denali Data Feed | Waiting for socket receive thread to end 2026-04-16 08:11:03.040 | CQG WebSocket socket (1) | Write has completed. Shutdown being performed. 2026-04-16 08:11:03.040 | CQG WebSocket socket (1) | Shutdown started. Waiting for graceful close. 2026-04-16 08:11:03.042 | DTC Client socket (3) | CloseSocket call. 2026-04-16 08:11:03.042 | DTC Client socket (3) | Shutdown started. Waiting for graceful close. 2026-04-16 08:11:03.042 | Denali Data Feed | Disconnected from the server. 2026-04-16 08:11:03.044 | CQG WebAPI | Disconnected. 2026-04-16 08:11:03.044 | CQG WebSocket socket (1) | Socket gracefully closed by remote side. 2026-04-16 08:11:03.045 | CQG WebSocket socket (1) | Closed. 2026-04-16 08:11:03.055 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-04-16 08:11:03.135 | DTC Client socket (3) | Socket gracefully closed by remote side. 2026-04-16 08:11:03.135 | DTC Client socket (3) | Closed. 2026-04-16 08:11:05.047 | 2026-04-16 08:11:05.049 | CQG WebAPI | Connecting to server api.cqg.com 2026-04-16 08:11:05.049 | CQG WebSocket | Connecting to WebSocket server api.cqg.com:443 2026-04-16 08:11:05.249 | CQG WebSocket socket (1) | Creating socket. Using TLS 1.2. 2026-04-16 08:11:05.255 | CQG WebSocket socket (1) | New receive buffer size: 0 2026-04-16 08:11:05.255 | CQG WebSocket socket (1) | Connecting to IP: 195.166.124.175. 2026-04-16 08:11:05.262 | CQG WebSocket | Opening WebSocket. 2026-04-16 08:11:05.262 | CQG WebSocket | Sending WebSocket handshake. 2026-04-16 08:11:05.295 | CQG WebSocket | Server header | HTTP/1.1 101 Switching Protocols 2026-04-16 08:11:05.295 | CQG WebSocket | Server header | Connection: Upgrade 2026-04-16 08:11:05.295 | CQG WebSocket | Server header | Sec-WebSocket-Accept: zABglq/N2LnyRCrd5k4H30mt41s= 2026-04-16 08:11:05.295 | CQG WebSocket | Server header | Server: WebSocket++/0.8.2 2026-04-16 08:11:05.295 | CQG WebSocket | Server header | Upgrade: websocket 2026-04-16 08:11:05.295 | CQG WebSocket | Server header | 2026-04-16 08:11:05.295 | CQG WebSocket | Web socket state is now open. 2026-04-16 08:11:05.295 | CQG WebAPI | WebSocket connected. 2026-04-16 08:11:05.296 | CQG WebAPI | Sending market data logon message. 2026-04-16 08:11:05.528 | CQG WebAPI | Base Time: 2026-03-28T06:33:36. 2026-03-28 06:33:36 2026-04-16 08:11:05.529 | CQG WebAPI | Logon successful. Session Token = Q4LQ1DLBmxdlklZ6ANttZSBeS3qDDSzRMENeKBZo9GkB/NXM6djiLU7EupXeD9vXTqMArvlR+Kj 2026-04-16 08:11:05.529 | CQG WebAPI | Connection to server complete. 2026-04-16 08:11:05.536 | No download requests in the queue to start downloads for. | Number times message added: 3 2026-04-16 08:11:05.537 | Updated verified funded futures trading account ending date to: 2026-05-16 12:11:05 2026-04-16 08:11:05.556 | CQG WebAPI | Sending Trade Accounts request message. 2026-04-16 08:11:05.666 | CQG WebAPI | Brokerage name: AMP. Account Name: 220033 2026-04-16 08:11:05.666 | Updated verified funded futures trading account ending date to: 2026-05-16 12:11:05 2026-04-16 08:11:05.666 | CQG WebAPI | Sending collateral subscribe request. 2026-04-16 08:11:05.790 | CQG WebAPI | Sending positions subscribe request. RequestID: 431354 2026-04-16 08:11:05.791 | CQG WebAPI | Sending orders subscribe request. RequestID: 431355 2026-04-16 08:11:05.838 | Mapping F.US.CLEV25 to CLV25. Service code: nymex 2026-04-16 08:11:05.838 | Using symbol data fast lookup vector 2026-04-16 08:11:05.839 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEV25 (CLV25). ID: 1 Service code: nymex 2026-04-16 08:11:05.839 | Denali Data Feed | Connecting to the server ds26-2.sierracharts.com. Port 443 2026-04-16 08:11:05.840 | CQG WebAPI | Sending symbol resolution request for F.US.CLEV25. ID: 431356 2026-04-16 08:11:05.840 | Denali Data Feed | Requesting security definition data for: F.US.CLEV25 (CLV25). ID: 1 2026-04-16 08:11:05.840 | Added historical Intraday data request for F.US.CLEV25 to the queue. 2026-04-16 08:11:05.840 | Intraday data recording state for symbol F.US.CLEV25 is set to download 'Pending'. 2026-04-16 08:11:05.840 | Triggering next historical data download in queue. 2026-04-16 08:11:05.841 | Delaying start of download for F.US.CLEV25. 2026-04-16 08:11:05.849 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEV25. Search Symbol: F.US.CLEV25. Request ID: 431356. Contract ID: 1. 2026-04-16 08:11:05.849 | Mapping F.US.BP6U25 to 6BU25. Service code: cme 2026-04-16 08:11:05.849 | Denali Data Feed | Starting real-time market data updates for: F.US.BP6U25 (6BU25). ID: 2 Service code: cme 2026-04-16 08:11:05.849 | CQG WebAPI | Sending symbol resolution request for F.US.BP6U25. ID: 431357 2026-04-16 08:11:05.850 | Denali Data Feed | Requesting security definition data for: F.US.BP6U25 (6BU25). ID: 2 2026-04-16 08:11:05.850 | Added historical Intraday data request for F.US.BP6U25 to the queue. 2026-04-16 08:11:05.850 | Intraday data recording state for symbol F.US.BP6U25 is set to download 'Pending'. 2026-04-16 08:11:05.850 | Triggering next historical data download in queue. 2026-04-16 08:11:05.857 | DTC Client socket (2) | Creating socket. 2026-04-16 08:11:05.857 | DTC Client socket (2) | New receive buffer size: 0 2026-04-16 08:11:05.857 | DTC Client socket (2) | Connecting to IP: 64.152.155.18. 2026-04-16 08:11:05.859 | CQG WebAPI | Received symbol resolution report for symbol F.US.BP6U25. Search Symbol: F.US.BP6U25. Request ID: 431357. Contract ID: 2. 2026-04-16 08:11:05.880 | Mapping F.US.EPU25 to ESU25. Service code: cme 2026-04-16 08:11:05.880 | Denali Data Feed | Starting real-time market data updates for: F.US.EPU25 (ESU25). ID: 3 Service code: cme 2026-04-16 08:11:05.880 | CQG WebAPI | Sending symbol resolution request for F.US.EPU25. ID: 431358 2026-04-16 08:11:05.880 | Denali Data Feed | Requesting security definition data for: F.US.EPU25 (ESU25). ID: 3 2026-04-16 08:11:05.880 | Added historical Intraday data request for F.US.EPU25 to the queue. 2026-04-16 08:11:05.880 | Intraday data recording state for symbol F.US.EPU25 is set to download 'Pending'. 2026-04-16 08:11:05.880 | Triggering next historical data download in queue. 2026-04-16 08:11:05.903 | CQG WebAPI | Received symbol resolution report for symbol F.US.EPU25. Search Symbol: F.US.EPU25. Request ID: 431358. Contract ID: 3. 2026-04-16 08:11:05.946 | Denali Data Feed | Network connection to server complete. 2026-04-16 08:11:05.946 | Denali Data Feed | Starting socket receive thread. 2026-04-16 08:11:05.947 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard 2026-04-16 08:11:05.948 | Mapping F.US.EPH23 to ESH23. Service code: cme 2026-04-16 08:11:05.948 | Denali Data Feed | Starting real-time market data updates for: F.US.EPH23 (ESH23). ID: 4 Service code: cme 2026-04-16 08:11:05.948 | CQG WebAPI | Sending symbol resolution request for F.US.EPH23. ID: 431359 2026-04-16 08:11:05.948 | Denali Data Feed | Requesting security definition data for: F.US.EPH23 (ESH23). ID: 4 2026-04-16 08:11:05.949 | Mapping F.US.EPM23 to ESM23. Service code: cme 2026-04-16 08:11:05.949 | Denali Data Feed | Starting real-time market data updates for: F.US.EPM23 (ESM23). ID: 5 Service code: cme 2026-04-16 08:11:05.949 | CQG WebAPI | Sending symbol resolution request for F.US.EPM23. ID: 431360 2026-04-16 08:11:05.949 | Denali Data Feed | Requesting security definition data for: F.US.EPM23 (ESM23). ID: 5 2026-04-16 08:11:05.949 | Mapping F.US.EPU23 to ESU23. Service code: cme 2026-04-16 08:11:05.949 | Denali Data Feed | Starting real-time market data updates for: F.US.EPU23 (ESU23). ID: 6 Service code: cme 2026-04-16 08:11:05.949 | CQG WebAPI | Sending symbol resolution request for F.US.EPU23. ID: 431361 2026-04-16 08:11:05.949 | Denali Data Feed | Requesting security definition data for: F.US.EPU23 (ESU23). ID: 6 2026-04-16 08:11:05.949 | Mapping F.US.EPZ23 to ESZ23. Service code: cme 2026-04-16 08:11:05.949 | Denali Data Feed | Starting real-time market data updates for: F.US.EPZ23 (ESZ23). ID: 7 Service code: cme 2026-04-16 08:11:05.949 | CQG WebAPI | Sending symbol resolution request for F.US.EPZ23. ID: 431362 2026-04-16 08:11:05.949 | Denali Data Feed | Requesting security definition data for: F.US.EPZ23 (ESZ23). ID: 7 2026-04-16 08:11:05.949 | Mapping F.US.EPH24 to ESH24. Service code: cme 2026-04-16 08:11:05.950 | Denali Data Feed | Starting real-time market data updates for: F.US.EPH24 (ESH24). ID: 8 Service code: cme 2026-04-16 08:11:05.950 | CQG WebAPI | Sending symbol resolution request for F.US.EPH24. ID: 431363 2026-04-16 08:11:05.950 | Denali Data Feed | Requesting security definition data for: F.US.EPH24 (ESH24). ID: 8 2026-04-16 08:11:05.950 | Mapping F.US.CLEF23 to CLF23. Service code: nymex 2026-04-16 08:11:05.950 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEF23 (CLF23). ID: 9 Service code: nymex 2026-04-16 08:11:05.950 | CQG WebAPI | Sending symbol resolution request for F.US.CLEF23. ID: 431364 2026-04-16 08:11:05.950 | Denali Data Feed | Requesting security definition data for: F.US.CLEF23 (CLF23). ID: 9 2026-04-16 08:11:05.950 | Mapping F.US.CLEG23 to CLG23. Service code: nymex 2026-04-16 08:11:05.950 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEG23 (CLG23). ID: 10 Service code: nymex 2026-04-16 08:11:05.950 | CQG WebAPI | Sending symbol resolution request for F.US.CLEG23. ID: 431365 2026-04-16 08:11:05.950 | Denali Data Feed | Requesting security definition data for: F.US.CLEG23 (CLG23). ID: 10 2026-04-16 08:11:05.950 | Mapping F.US.CLEH23 to CLH23. Service code: nymex 2026-04-16 08:11:05.950 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEH23 (CLH23). ID: 11 Service code: nymex 2026-04-16 08:11:05.950 | CQG WebAPI | Sending symbol resolution request for F.US.CLEH23. ID: 431366 2026-04-16 08:11:05.950 | Denali Data Feed | Requesting security definition data for: F.US.CLEH23 (CLH23). ID: 11 2026-04-16 08:11:05.950 | Mapping F.US.CLEJ23 to CLJ23. Service code: nymex 2026-04-16 08:11:05.950 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEJ23 (CLJ23). ID: 12 Service code: nymex 2026-04-16 08:11:05.950 | CQG WebAPI | Sending symbol resolution request for F.US.CLEJ23. ID: 431367 2026-04-16 08:11:05.950 | Denali Data Feed | Requesting security definition data for: F.US.CLEJ23 (CLJ23). ID: 12 2026-04-16 08:11:05.951 | Mapping F.US.CLEK23 to CLK23. Service code: nymex 2026-04-16 08:11:05.951 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEK23 (CLK23). ID: 13 Service code: nymex 2026-04-16 08:11:05.951 | CQG WebAPI | Sending symbol resolution request for F.US.CLEK23. ID: 431368 2026-04-16 08:11:05.951 | Denali Data Feed | Requesting security definition data for: F.US.CLEK23 (CLK23). ID: 13 2026-04-16 08:11:05.951 | Mapping F.US.CLEM23 to CLM23. Service code: nymex 2026-04-16 08:11:05.951 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEM23 (CLM23). ID: 14 Service code: nymex 2026-04-16 08:11:05.951 | CQG WebAPI | Sending symbol resolution request for F.US.CLEM23. ID: 431369 2026-04-16 08:11:05.951 | Denali Data Feed | Requesting security definition data for: F.US.CLEM23 (CLM23). ID: 14 2026-04-16 08:11:05.951 | Mapping F.US.CLEN23 to CLN23. Service code: nymex 2026-04-16 08:11:05.951 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEN23 (CLN23). ID: 15 Service code: nymex 2026-04-16 08:11:05.951 | CQG WebAPI | Sending symbol resolution request for F.US.CLEN23. ID: 431370 2026-04-16 08:11:05.951 | Denali Data Feed | Requesting security definition data for: F.US.CLEN23 (CLN23). ID: 15 2026-04-16 08:11:05.951 | Mapping F.US.CLEQ23 to CLQ23. Service code: nymex 2026-04-16 08:11:05.951 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEQ23 (CLQ23). ID: 16 Service code: nymex 2026-04-16 08:11:05.951 | CQG WebAPI | Sending symbol resolution request for F.US.CLEQ23. ID: 431371 2026-04-16 08:11:05.951 | Denali Data Feed | Requesting security definition data for: F.US.CLEQ23 (CLQ23). ID: 16 2026-04-16 08:11:05.951 | Mapping F.US.CLEU23 to CLU23. Service code: nymex 2026-04-16 08:11:05.951 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEU23 (CLU23). ID: 17 Service code: nymex 2026-04-16 08:11:05.951 | CQG WebAPI | Sending symbol resolution request for F.US.CLEU23. ID: 431372 2026-04-16 08:11:05.951 | Denali Data Feed | Requesting security definition data for: F.US.CLEU23 (CLU23). ID: 17 2026-04-16 08:11:05.951 | Mapping F.US.CLEV23 to CLV23. Service code: nymex 2026-04-16 08:11:05.952 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEV23 (CLV23). ID: 18 Service code: nymex 2026-04-16 08:11:05.952 | CQG WebAPI | Sending symbol resolution request for F.US.CLEV23. ID: 431373 2026-04-16 08:11:05.952 | Denali Data Feed | Requesting security definition data for: F.US.CLEV23 (CLV23). ID: 18 2026-04-16 08:11:05.952 | Mapping F.US.CLEX23 to CLX23. Service code: nymex 2026-04-16 08:11:05.952 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEX23 (CLX23). ID: 19 Service code: nymex 2026-04-16 08:11:05.952 | CQG WebAPI | Sending symbol resolution request for F.US.CLEX23. ID: 431374 2026-04-16 08:11:05.952 | Denali Data Feed | Requesting security definition data for: F.US.CLEX23 (CLX23). ID: 19 2026-04-16 08:11:05.952 | Mapping F.US.CLEZ23 to CLZ23. Service code: nymex 2026-04-16 08:11:05.952 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEZ23 (CLZ23). ID: 20 Service code: nymex 2026-04-16 08:11:05.952 | CQG WebAPI | Sending symbol resolution request for F.US.CLEZ23. ID: 431375 2026-04-16 08:11:05.952 | Denali Data Feed | Requesting security definition data for: F.US.CLEZ23 (CLZ23). ID: 20 2026-04-16 08:11:05.952 | Mapping F.US.CLEF24 to CLF24. Service code: nymex 2026-04-16 08:11:05.952 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEF24 (CLF24). ID: 21 Service code: nymex 2026-04-16 08:11:05.952 | CQG WebAPI | Sending symbol resolution request for F.US.CLEF24. ID: 431376 2026-04-16 08:11:05.952 | Denali Data Feed | Requesting security definition data for: F.US.CLEF24 (CLF24). ID: 21 2026-04-16 08:11:05.952 | Mapping F.US.CLEG24 to CLG24. Service code: nymex 2026-04-16 08:11:05.952 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEG24 (CLG24). ID: 22 Service code: nymex 2026-04-16 08:11:05.952 | CQG WebAPI | Sending symbol resolution request for F.US.CLEG24. ID: 431377 2026-04-16 08:11:05.952 | Denali Data Feed | Requesting security definition data for: F.US.CLEG24 (CLG24). ID: 22 2026-04-16 08:11:05.953 | CQG WebAPI | Received symbol resolution report for symbol F.US.EPH23. Search Symbol: F.US.EPH23. Request ID: 431359. Contract ID: 4. 2026-04-16 08:11:05.953 | CQG WebAPI | Received symbol resolution report for symbol F.US.EPM23. Search Symbol: F.US.EPM23. Request ID: 431360. Contract ID: 5. 2026-04-16 08:11:05.953 | CQG WebAPI | Received symbol resolution report for symbol F.US.EPU23. Search Symbol: F.US.EPU23. Request ID: 431361. Contract ID: 6. 2026-04-16 08:11:06.045 | CQG WebAPI | Received symbol resolution report for symbol F.US.EPZ23. Search Symbol: F.US.EPZ23. Request ID: 431362. Contract ID: 7. 2026-04-16 08:11:06.045 | CQG WebAPI | Received symbol resolution report for symbol F.US.EPH24. Search Symbol: F.US.EPH24. Request ID: 431363. Contract ID: 8. 2026-04-16 08:11:06.045 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEF23. Search Symbol: F.US.CLEF23. Request ID: 431364. Contract ID: 9. 2026-04-16 08:11:06.045 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEG23. Search Symbol: F.US.CLEG23. Request ID: 431365. Contract ID: 10. 2026-04-16 08:11:06.045 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEH23. Search Symbol: F.US.CLEH23. Request ID: 431366. Contract ID: 11. 2026-04-16 08:11:06.045 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEJ23. Search Symbol: F.US.CLEJ23. Request ID: 431367. Contract ID: 12. 2026-04-16 08:11:06.045 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEK23. Search Symbol: F.US.CLEK23. Request ID: 431368. Contract ID: 13. 2026-04-16 08:11:06.045 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEM23. Search Symbol: F.US.CLEM23. Request ID: 431369. Contract ID: 14. 2026-04-16 08:11:06.045 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEN23. Search Symbol: F.US.CLEN23. Request ID: 431370. Contract ID: 15. 2026-04-16 08:11:06.045 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEQ23. Search Symbol: F.US.CLEQ23. Request ID: 431371. Contract ID: 16. 2026-04-16 08:11:06.046 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEU23. Search Symbol: F.US.CLEU23. Request ID: 431372. Contract ID: 17. 2026-04-16 08:11:06.046 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEV23. Search Symbol: F.US.CLEV23. Request ID: 431373. Contract ID: 18. 2026-04-16 08:11:06.049 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEX23. Search Symbol: F.US.CLEX23. Request ID: 431374. Contract ID: 19. 2026-04-16 08:11:06.049 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEZ23. Search Symbol: F.US.CLEZ23. Request ID: 431375. Contract ID: 20. 2026-04-16 08:11:06.049 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEF24. Search Symbol: F.US.CLEF24. Request ID: 431376. Contract ID: 21. 2026-04-16 08:11:06.049 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEG24. Search Symbol: F.US.CLEG24. Request ID: 431377. Contract ID: 22. 2026-04-16 08:11:06.068 | Denali Data Feed | Setting DTC encoding to Binary VLS 2026-04-16 08:11:06.068 | Denali Data Feed | Sending logon request message. 2026-04-16 08:11:06.597 | Denali Data Feed | Received logon response. 2026-04-16 08:11:06.597 | Denali Data Feed | Server Name: SC Realtime Server. 2026-04-16 08:11:06.597 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8 2026-04-16 08:11:06.597 | Denali Data Feed | Successfully connected. 2026-04-16 08:11:06.597 | Denali Data Feed | Trading is not supported. 2026-04-16 08:11:06.597 | Denali Data Feed | MarketDepthIsSupported: 1 2026-04-16 08:11:06.598 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.BP6U25 -> 6BU25 2026-04-16 08:11:06.598 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEF23 -> CLF23 2026-04-16 08:11:06.598 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEF24 -> CLF24 2026-04-16 08:11:06.598 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEG23 -> CLG23 2026-04-16 08:11:06.598 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEG24 -> CLG24 2026-04-16 08:11:06.598 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEH23 -> CLH23 2026-04-16 08:11:06.598 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEJ23 -> CLJ23 2026-04-16 08:11:06.598 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEK23 -> CLK23 2026-04-16 08:11:06.598 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEM23 -> CLM23 2026-04-16 08:11:06.598 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEN23 -> CLN23 2026-04-16 08:11:06.598 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEQ23 -> CLQ23 2026-04-16 08:11:06.598 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEU23 -> CLU23 2026-04-16 08:11:06.598 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEV23 -> CLV23 2026-04-16 08:11:06.598 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEV25 -> CLV25 2026-04-16 08:11:06.598 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEX23 -> CLX23 2026-04-16 08:11:06.598 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEZ23 -> CLZ23 2026-04-16 08:11:06.598 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.EPH23 -> ESH23 2026-04-16 08:11:06.598 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.EPH24 -> ESH24 2026-04-16 08:11:06.598 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.EPM23 -> ESM23 2026-04-16 08:11:06.598 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.EPU23 -> ESU23 2026-04-16 08:11:06.598 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.EPU25 -> ESU25 2026-04-16 08:11:06.598 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.EPZ23 -> ESZ23 2026-04-16 08:11:06.783 | Denali Data Feed | Real-time data for symbol F.US.BP6U25 is currently unavailable. 2026-04-16 08:11:06.783 | Denali Data Feed | Received security definition for symbol F.US.BP6U25 2026-04-16 08:11:06.783 | Denali Data Feed | Real-time data for symbol F.US.CLEF23 is currently unavailable. 2026-04-16 08:11:06.783 | Denali Data Feed | Received security definition for symbol F.US.CLEF23 2026-04-16 08:11:06.783 | Denali Data Feed | Real-time data for symbol F.US.CLEF24 is currently unavailable. 2026-04-16 08:11:06.783 | Denali Data Feed | Received security definition for symbol F.US.CLEF24 2026-04-16 08:11:06.783 | Denali Data Feed | Real-time data for symbol F.US.CLEG23 is currently unavailable. 2026-04-16 08:11:06.783 | Denali Data Feed | Received security definition for symbol F.US.CLEG23 2026-04-16 08:11:06.783 | Denali Data Feed | Real-time data for symbol F.US.CLEG24 is currently unavailable. 2026-04-16 08:11:06.783 | Denali Data Feed | Received security definition for symbol F.US.CLEG24 2026-04-16 08:11:06.783 | Denali Data Feed | Real-time data for symbol F.US.CLEH23 is currently unavailable. 2026-04-16 08:11:06.783 | Denali Data Feed | Received security definition for symbol F.US.CLEH23 2026-04-16 08:11:06.783 | Denali Data Feed | Real-time data for symbol F.US.CLEJ23 is currently unavailable. 2026-04-16 08:11:06.783 | Denali Data Feed | Received security definition for symbol F.US.CLEJ23 2026-04-16 08:11:06.783 | Denali Data Feed | Real-time data for symbol F.US.CLEK23 is currently unavailable. 2026-04-16 08:11:06.783 | Denali Data Feed | Received security definition for symbol F.US.CLEK23 2026-04-16 08:11:06.783 | Denali Data Feed | Real-time data for symbol F.US.CLEM23 is currently unavailable. 2026-04-16 08:11:06.783 | Denali Data Feed | Received security definition for symbol F.US.CLEM23 2026-04-16 08:11:06.783 | Denali Data Feed | Real-time data for symbol F.US.CLEN23 is currently unavailable. 2026-04-16 08:11:06.783 | Denali Data Feed | Received security definition for symbol F.US.CLEN23 2026-04-16 08:11:06.783 | Denali Data Feed | Real-time data for symbol F.US.CLEQ23 is currently unavailable. 2026-04-16 08:11:06.783 | Denali Data Feed | Received security definition for symbol F.US.CLEQ23 2026-04-16 08:11:06.783 | Denali Data Feed | Real-time data for symbol F.US.CLEU23 is currently unavailable. 2026-04-16 08:11:06.783 | Denali Data Feed | Received security definition for symbol F.US.CLEU23 2026-04-16 08:11:06.783 | Denali Data Feed | Real-time data for symbol F.US.CLEV23 is currently unavailable. 2026-04-16 08:11:06.783 | Denali Data Feed | Received security definition for symbol F.US.CLEV23 2026-04-16 08:11:06.783 | Denali Data Feed | Real-time data for symbol F.US.CLEV25 is currently unavailable. 2026-04-16 08:11:06.783 | Denali Data Feed | Received security definition for symbol F.US.CLEV25 2026-04-16 08:11:06.783 | Denali Data Feed | Real-time data for symbol F.US.CLEX23 is currently unavailable. 2026-04-16 08:11:06.783 | Denali Data Feed | Received security definition for symbol F.US.CLEX23 2026-04-16 08:11:06.783 | Denali Data Feed | Real-time data for symbol F.US.CLEZ23 is currently unavailable. 2026-04-16 08:11:06.783 | Denali Data Feed | Received security definition for symbol F.US.CLEZ23 2026-04-16 08:11:06.783 | Denali Data Feed | Real-time data for symbol F.US.EPH23 is currently unavailable. 2026-04-16 08:11:06.783 | Denali Data Feed | Received security definition for symbol F.US.EPH23 2026-04-16 08:11:06.783 | Denali Data Feed | Real-time data for symbol F.US.EPH24 is currently unavailable. 2026-04-16 08:11:06.783 | Denali Data Feed | Received security definition for symbol F.US.EPH24 2026-04-16 08:11:06.783 | Denali Data Feed | Real-time data for symbol F.US.EPM23 is currently unavailable. 2026-04-16 08:11:06.783 | Denali Data Feed | Received security definition for symbol F.US.EPM23 2026-04-16 08:11:06.783 | Denali Data Feed | Real-time data for symbol F.US.EPU23 is currently unavailable. 2026-04-16 08:11:06.783 | Denali Data Feed | Received security definition for symbol F.US.EPU23 2026-04-16 08:11:06.783 | Denali Data Feed | Real-time data for symbol F.US.EPU25 is currently unavailable. 2026-04-16 08:11:06.783 | Denali Data Feed | Received security definition for symbol F.US.EPU25 2026-04-16 08:11:06.783 | Denali Data Feed | Real-time data for symbol F.US.EPZ23 is currently unavailable. 2026-04-16 08:11:06.783 | Denali Data Feed | Received security definition for symbol F.US.EPZ23 2026-04-16 08:11:10.527 | Requesting market depth updates for: F.US.CLEV25 if supported. NumLevels=100 2026-04-16 08:11:10.722 | Denali Data Feed | Clearing market depth for F.US.CLEV25 2026-04-16 08:11:11.002 | HD Request # 30 | Downloading Intraday chart data for F.US.CLEV25 to the file F.US.CLEV25.scid. Service: nymex 2026-04-16 08:11:11.006 | HD Request # 30 | Download start date-time: 2025-09-22 14:29:55.000000. File last date-time: 2025-09-22 14:29:55.618000 2026-04-16 08:11:11.008 | HD Request # 30 | Using server: ds26.sierracharts.com port 10149 2026-04-16 08:11:11.015 | Socket (3) | Creating socket. 2026-04-16 08:11:11.015 | Socket (3) | New receive buffer size: 0 2026-04-16 08:11:11.015 | Socket (3) | Connecting to IP: 64.152.155.17. 2026-04-16 08:11:11.195 | HD Request # 30 | Setting DTC encoding to Binary VLS 2026-04-16 08:11:11.195 | HD Request # 30 | Sending historical data logon request message. 2026-04-16 08:11:11.310 | HD Request # 30 | Requesting Intraday data. Start date-time: 2025-09-22 14:29:55. Record interval: 0. Symbol: CLV25 2026-04-16 08:11:11.399 | HD Request # 30 | Decompressing data. 2026-04-16 08:11:11.488 | HD Request # 30 | Receiving Intraday data for F.US.CLEV25 starting at 2025-09-22 14:29:55.086000 2026-04-16 08:11:11.488 | Socket (3) | CloseSocket call. 2026-04-16 08:11:11.488 | Socket (3) | Shutdown started. Waiting for graceful close. 2026-04-16 08:11:11.488 | Historical data download thread signaled to stop. 2026-04-16 08:11:11.488 | HD Request # 30 | Received 2 Intraday data records from 2025-09-22 14:29:55.086000 to 2025-09-22 14:29:55.618000 (0.5 seconds. Delay: 205.7 days) and wrote 0 records for F.US.CLEV25 2026-04-16 08:11:11.489 | HD Request # 30 | Add time&sales data | Remembered last file record date-time: 2025-09-22 18:29:55.618000 2026-04-16 08:11:11.489 | HD Request # 30 | Completion time: 0s. 2026-04-16 08:11:11.489 | HD Request # 30 | Intraday data download complete for F.US.CLEV25. Unique request ID: 30 2026-04-16 08:11:11.489 | Removing historical data download ID 30. 2026-04-16 08:11:11.489 | Real-time Intraday chart data file updates started for F.US.CLEV25 2026-04-16 08:11:11.489 | Intraday chart data file opened for F.US.CLEV25 2026-04-16 08:11:11.489 | HD Request # 30 | Enabling Intraday chart updating for symbol. 2026-04-16 08:11:11.489 | 2026-04-16 08:11:11.489 | Triggering next historical data download in queue. 2026-04-16 08:11:11.489 | HD Request # 31 | Downloading Intraday chart data for F.US.BP6U25 to the file F.US.BP6U25.scid. Service: cme 2026-04-16 08:11:11.490 | HD Request # 31 | Download start date-time: 2025-09-15 10:02:50.000000. File last date-time: 2025-09-15 10:02:50.367000 2026-04-16 08:11:11.490 | HD Request # 31 | Using server: ds28.sierracharts.com port 10150 2026-04-16 08:11:11.492 | Socket (4) | Creating socket. 2026-04-16 08:11:11.492 | Socket (4) | New receive buffer size: 0 2026-04-16 08:11:11.492 | Socket (4) | Connecting to IP: 67.214.125.5. 2026-04-16 08:11:11.575 | Socket (3) | Socket gracefully closed by remote side. 2026-04-16 08:11:11.576 | Socket (3) | Closed. 2026-04-16 08:11:11.687 | HD Request # 31 | Setting DTC encoding to Binary VLS 2026-04-16 08:11:11.687 | HD Request # 31 | Sending historical data logon request message. 2026-04-16 08:11:11.813 | HD Request # 31 | Requesting Intraday data. Start date-time: 2025-09-15 10:02:50. Record interval: 0. Symbol: 6BU25 2026-04-16 08:11:11.907 | HD Request # 31 | Decompressing data. 2026-04-16 08:11:12.001 | HD Request # 31 | Receiving Intraday data for F.US.BP6U25 starting at 2025-09-15 10:02:50.367000 2026-04-16 08:11:12.001 | Socket (4) | CloseSocket call. 2026-04-16 08:11:12.001 | Socket (4) | Shutdown started. Waiting for graceful close. 2026-04-16 08:11:12.001 | Historical data download thread signaled to stop. 2026-04-16 08:11:12.001 | HD Request # 31 | Received 1 Intraday data record from 2025-09-15 10:02:50.367000 to 2025-09-15 10:02:50.367000 (0.0 seconds. Delay: 212.9 days) and wrote 0 records for F.US.BP6U25 2026-04-16 08:11:12.002 | HD Request # 31 | Add time&sales data | Remembered last file record date-time: 2025-09-15 14:02:50.367000 2026-04-16 08:11:12.002 | HD Request # 31 | Completion time: 1s. 2026-04-16 08:11:12.002 | HD Request # 31 | Intraday data download complete for F.US.BP6U25. Unique request ID: 31 2026-04-16 08:11:12.002 | Removing historical data download ID 31. 2026-04-16 08:11:12.002 | Real-time Intraday chart data file updates started for F.US.BP6U25 2026-04-16 08:11:12.002 | Intraday chart data file opened for F.US.BP6U25 2026-04-16 08:11:12.002 | HD Request # 31 | Enabling Intraday chart updating for symbol. 2026-04-16 08:11:12.002 | 2026-04-16 08:11:12.002 | Triggering next historical data download in queue. 2026-04-16 08:11:12.002 | HD Request # 32 | Downloading Intraday chart data for F.US.EPU25 to the file F.US.EPU25.scid. Service: cme 2026-04-16 08:11:12.004 | HD Request # 32 | Download start date-time: 2025-09-19 09:29:58.000000. File last date-time: 2025-09-19 09:29:58.698000 2026-04-16 08:11:12.004 | HD Request # 32 | Using server: ds32.sierracharts.com port 10149 2026-04-16 08:11:12.004 | Socket (3) | Creating socket. 2026-04-16 08:11:12.004 | Socket (3) | New receive buffer size: 0 2026-04-16 08:11:12.004 | Socket (3) | Connecting to IP: 69.39.70.248. 2026-04-16 08:11:12.094 | Socket (4) | Socket gracefully closed by remote side. 2026-04-16 08:11:12.094 | Socket (4) | Closed. 2026-04-16 08:11:12.194 | HD Request # 32 | Setting DTC encoding to Binary VLS 2026-04-16 08:11:12.194 | HD Request # 32 | Sending historical data logon request message. 2026-04-16 08:11:12.319 | HD Request # 32 | Requesting Intraday data. Start date-time: 2025-09-19 09:29:58. Record interval: 0. Symbol: ESU25 2026-04-16 08:11:12.418 | HD Request # 32 | Decompressing data. 2026-04-16 08:11:12.511 | HD Request # 32 | Receiving Intraday data for F.US.EPU25 starting at 2025-09-19 09:29:58.697000 2026-04-16 08:11:12.511 | Socket (3) | CloseSocket call. 2026-04-16 08:11:12.511 | Socket (3) | Shutdown started. Waiting for graceful close. 2026-04-16 08:11:12.512 | Historical data download thread signaled to stop. 2026-04-16 08:11:12.512 | HD Request # 32 | Received 5 Intraday data records from 2025-09-19 09:29:58.697000 to 2025-09-19 09:29:58.698000 (0.0 seconds. Delay: 208.9 days) and wrote 0 records for F.US.EPU25 2026-04-16 08:11:12.513 | HD Request # 32 | Add time&sales data | Remembered last file record date-time: 2025-09-19 13:29:58.698000 2026-04-16 08:11:12.513 | HD Request # 32 | Completion time: 0s. 2026-04-16 08:11:12.513 | HD Request # 32 | Intraday data download complete for F.US.EPU25. Unique request ID: 32 2026-04-16 08:11:12.513 | Removing historical data download ID 32. 2026-04-16 08:11:12.513 | Real-time Intraday chart data file updates started for F.US.EPU25 2026-04-16 08:11:12.513 | Intraday chart data file opened for F.US.EPU25 2026-04-16 08:11:12.513 | HD Request # 32 | Enabling Intraday chart updating for symbol. 2026-04-16 08:11:12.513 | 2026-04-16 08:11:12.513 | No download requests in the queue to start downloads for. 2026-04-16 08:11:12.604 | Socket (3) | Socket gracefully closed by remote side. 2026-04-16 08:11:12.604 | Socket (3) | Closed. 2026-04-16 08:13:13.145 | F.US.BP6U25 [CBV][M] #2 | StartDateTimeForLoadingOrderFills: 2024-09-08 00:00:00 2026-04-16 08:13:13.186 | F.US.BP6U25 [CBV][M] 2000 Volume #5 | StartDateTimeForLoadingOrderFills: 2024-09-08 00:00:00 2026-04-16 08:13:13.218 | F.US.CLEV25[M] #15 | StartDateTimeForLoadingOrderFills: 2025-04-09 00:00:00 2026-04-16 08:15:17.775 | Enabling compression for file: C:\SierraChart\Data\F.US.CLEM26.scid 2026-04-16 08:15:17.781 | F.US.CLEM26 [CBV][M] #2 | Reloading chart. 2026-04-16 08:15:17.906 | Added historical Intraday data request for F.US.CLEK26 to the queue. 2026-04-16 08:15:17.906 | Triggering next historical data download in queue. 2026-04-16 08:15:17.924 | F.US.CLEM26 [CBV][M] #2 | Performing continuous chart historical Daily data download for symbol F.US.CLEK26 starting at last date in file. 2026-04-16 08:15:17.925 | Added historical Daily data request for F.US.CLEK26 to the queue. 2026-04-16 08:15:17.925 | Triggering next historical data download in queue. 2026-04-16 08:15:17.926 | Added historical Intraday data request for F.US.CLEM26 to the queue. 2026-04-16 08:15:17.936 | F.US.CLEM26 [CBV][M] #2 | Performing continuous chart historical Daily data download for symbol F.US.CLEM26 starting at last date in file. 2026-04-16 08:15:17.936 | Added historical Daily data request for F.US.CLEM26 to the queue. 2026-04-16 08:15:17.958 | F.US.CLEM26 [CBV][M] #2 | Waiting for historical downloads to complete with the IDs: 33, 34, 35, 36, 2026-04-16 08:15:18.052 | Mapping F.US.CLEK26 to CLK26. Service code: nymex 2026-04-16 08:15:18.054 | HD Request # 33 | Downloading Intraday chart data for F.US.CLEK26 to the file F.US.CLEK26.scid. Service: nymex 2026-04-16 08:15:18.055 | HD Request # 33 | Download start date-time: 2026-04-14 23:14:30.000000. File last date-time: 2026-04-14 23:14:30.082000 2026-04-16 08:15:18.057 | HD Request # 33 | Using server: ds26.sierracharts.com port 10150 2026-04-16 08:15:18.057 | Socket (3) | Creating socket. 2026-04-16 08:15:18.057 | Socket (3) | New receive buffer size: 0 2026-04-16 08:15:18.057 | Socket (3) | Connecting to IP: 64.152.155.17. 2026-04-16 08:15:18.058 | HD Request # 34 | Downloading Historical Daily chart data for F.US.CLEK26. Starting date: 2026-03-30. Service: cqg 2026-04-16 08:15:18.239 | HD Request # 33 | Setting DTC encoding to Binary VLS 2026-04-16 08:15:18.239 | HD Request # 33 | Sending historical data logon request message. 2026-04-16 08:15:18.366 | HD Request # 33 | Requesting Intraday data. Start date-time: 2026-04-14 23:14:30. Record interval: 0. Symbol: CLK26 2026-04-16 08:15:18.455 | HD Request # 33 | Decompressing data. 2026-04-16 08:15:18.504 | HD Request # 34 | Requesting historical Daily data for CLK26 starting at 2026-03-29. SC External HD service. 2026-04-16 08:15:18.644 | HD Request # 33 | Receiving Intraday data for F.US.CLEK26 starting at 2026-04-14 23:14:30.082000 2026-04-16 08:15:18.911 | HD Request # 33 | Timestamp of first Intraday data file record written: 2026-04-14 23:14:47.946000. 2026-04-16 08:15:18.914 | HD Request # 34 | Receiving historical Daily data for F.US.CLEK26 starting at 2026-03-30. 2026-04-16 08:15:18.914 | HD Request # 34 | Writing historical Daily data to the file F.US.CLEK26.dly. 2026-04-16 08:15:18.929 | HD Request # 34 | Bytes received: 719 2026-04-16 08:15:18.929 | HD Request # 34 | Received 13 Daily data records from 2026-03-30 00:00:00 to 2026-04-16 00:00:00 (18.0 days) and wrote 13 records for F.US.CLEK26 2026-04-16 08:15:18.929 | HD Request # 34 | Completion time: 0s. 2026-04-16 08:15:18.929 | HD Request # 34 | Daily data download complete for F.US.CLEK26. Unique request ID: 34 2026-04-16 08:15:18.929 | Removing historical data download ID 34. 2026-04-16 08:15:18.929 | 2026-04-16 08:15:18.929 | Triggering next historical data download in queue. 2026-04-16 08:15:18.929 | Mapping F.US.CLEM26 to CLM26. Service code: nymex 2026-04-16 08:15:18.930 | HD Request # 35 | Downloading Historical Daily chart data for F.US.CLEM26. Starting date: 1926-05-11. Service: cqg 2026-04-16 08:15:19.368 | HD Request # 35 | Requesting historical Daily data for CLM26 starting at 1926-05-10. SC External HD service. 2026-04-16 08:15:19.483 | Socket (3) | CloseSocket call. 2026-04-16 08:15:19.483 | Socket (3) | Shutdown started. Waiting for graceful close. 2026-04-16 08:15:19.484 | Historical data download thread signaled to stop. 2026-04-16 08:15:19.485 | HD Request # 33 | Received 140496 Intraday data records from 2026-04-14 23:14:30.082000 to 2026-04-16 08:15:16.505000 (33.0 hours. Delay: 3.0 seconds) and wrote 140495 records for F.US.CLEK26 2026-04-16 08:15:19.494 | HD Request # 33 | Add time&sales data | Remembered last file record date-time: 2026-04-16 12:15:16.505000 2026-04-16 08:15:19.494 | HD Request # 33 | Completion time: 1s. 2026-04-16 08:15:19.494 | HD Request # 33 | Intraday data download complete for F.US.CLEK26. Unique request ID: 33 2026-04-16 08:15:19.494 | Removing historical data download ID 33. 2026-04-16 08:15:19.494 | Real-time Intraday chart data file updates started for F.US.CLEK26 2026-04-16 08:15:19.494 | Intraday chart data file opened for F.US.CLEK26 2026-04-16 08:15:19.494 | HD Request # 33 | Enabling Intraday chart updating for symbol. 2026-04-16 08:15:19.494 | 2026-04-16 08:15:19.494 | Triggering next historical data download in queue. 2026-04-16 08:15:19.494 | HD Request # 36 | Downloading Intraday chart data for F.US.CLEM26 to the file F.US.CLEM26.scid. Service: nymex 2026-04-16 08:15:19.494 | HD Request # 36 | Download start date-time: 2026-03-31 20:00:00.000000. File last date-time: 00:00:00.000000 2026-04-16 08:15:19.495 | HD Request # 36 | Using server: ds28.sierracharts.com port 10149 2026-04-16 08:15:19.495 | Socket (6) | Creating socket. 2026-04-16 08:15:19.495 | Socket (6) | New receive buffer size: 0 2026-04-16 08:15:19.495 | Socket (6) | Connecting to IP: 67.214.125.5. 2026-04-16 08:15:19.570 | Socket (3) | Socket gracefully closed by remote side. 2026-04-16 08:15:19.570 | Socket (3) | Closed. 2026-04-16 08:15:19.593 | HD Request # 35 | Receiving historical Daily data for F.US.CLEM26 starting at 2017-11-21. 2026-04-16 08:15:19.594 | HD Request # 35 | Writing historical Daily data to the file F.US.CLEM26.dly. 2026-04-16 08:15:19.675 | HD Request # 35 | Bytes received: 100895 2026-04-16 08:15:19.675 | HD Request # 35 | Received 2112 Daily data records from 2017-11-21 00:00:00 to 2026-04-16 00:00:00 (8.4 years) and wrote 2112 records for F.US.CLEM26 2026-04-16 08:15:19.676 | HD Request # 35 | Completion time: 1s. 2026-04-16 08:15:19.676 | HD Request # 35 | Daily data download complete for F.US.CLEM26. Unique request ID: 36 2026-04-16 08:15:19.676 | Removing historical data download ID 36. 2026-04-16 08:15:19.676 | 2026-04-16 08:15:19.676 | No download requests in the queue to start downloads for. 2026-04-16 08:15:22.696 | HD Request # 36 | Setting DTC encoding to Binary VLS 2026-04-16 08:15:22.696 | HD Request # 36 | Sending historical data logon request message. 2026-04-16 08:15:22.821 | HD Request # 36 | Requesting Intraday data. Start date-time: 2026-03-31 20:00:00. Record interval: 0. Symbol: CLM26 2026-04-16 08:15:22.915 | HD Request # 36 | Decompressing data. 2026-04-16 08:15:23.354 | HD Request # 36 | Receiving Intraday data for F.US.CLEM26 starting at 2026-03-31 20:00:00.120000 2026-04-16 08:15:24.703 | HD Request # 36 | Timestamp of first Intraday data file record written: 2026-03-31 20:00:00.120000. 2026-04-16 08:15:38.301 | Socket (6) | CloseSocket call. 2026-04-16 08:15:38.301 | Socket (6) | Shutdown started. Waiting for graceful close. 2026-04-16 08:15:38.302 | Historical data download thread signaled to stop. 2026-04-16 08:15:38.302 | HD Request # 36 | Received 864200 Intraday data records from 2026-03-31 20:00:00.120000 to 2026-04-16 08:15:36.294000 (15.5 days. Delay: 2.0 seconds) and wrote 864200 records for F.US.CLEM26 2026-04-16 08:15:38.329 | HD Request # 36 | Add time&sales data | Remembered last file record date-time: 2026-04-16 12:15:36.294000 2026-04-16 08:15:38.329 | HD Request # 36 | Completion time: 19s. 2026-04-16 08:15:38.329 | HD Request # 36 | Intraday data download complete for F.US.CLEM26. Unique request ID: 35 2026-04-16 08:15:38.329 | Removing historical data download ID 35. 2026-04-16 08:15:38.329 | Real-time Intraday chart data file updates started for F.US.CLEM26 2026-04-16 08:15:38.329 | Intraday chart data file opened for F.US.CLEM26 2026-04-16 08:15:38.329 | HD Request # 36 | Enabling Intraday chart updating for symbol. 2026-04-16 08:15:38.329 | 2026-04-16 08:15:38.329 | No download requests in the queue to start downloads for. 2026-04-16 08:15:38.395 | Socket (6) | Socket gracefully closed by remote side. 2026-04-16 08:15:38.395 | Socket (6) | Closed. 2026-04-16 08:15:38.497 | F.US.CLEM26 [CBV][M] #2 | Download is complete for all contract months in chart. Proceeding with data load. 2026-04-16 08:15:38.499 | F.US.CLEM26 [CBV][M] #2 | Reloading chart. 2026-04-16 08:15:38.971 | Enabling compression for file: C:\SierraChart\Data\F.US.CLEM26.dly 2026-04-16 08:15:39.003 | F.US.CLEM26 [CBV][M] #2 | Reloading chart. 2026-04-16 08:15:39.591 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEM26 (CLM26). ID: 24 Service code: nymex 2026-04-16 08:15:39.592 | CQG WebAPI | Sending symbol resolution request for F.US.CLEM26. ID: 431378 2026-04-16 08:15:39.593 | Denali Data Feed | Requesting security definition data for: F.US.CLEM26 (CLM26). ID: 24 2026-04-16 08:15:39.597 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEM26. Search Symbol: F.US.CLEM26. Request ID: 431378. Contract ID: 23. 2026-04-16 08:15:39.770 | Denali Data Feed | Setting external service identifier for symbol F.US.CLEM26 to 670557 2026-04-16 08:15:39.770 | Denali Data Feed | Received security definition for symbol F.US.CLEM26 2026-04-16 08:15:41.416 | F.US.CLEM26 [CBV][M] #2 | StartDateTimeForLoadingOrderFills: 2025-04-08 00:00:00 2026-04-16 08:15:41.452 | F.US.CLEM26 [CBV][M] #2 | Chart data loading complete. 2026-04-16 08:15:57.096 | Opened cached Intraday file: C:\SierraChart\Data\F.US.CLEM26.scid. Thread ID: 16976 2026-04-16 08:16:17.483 | F.US.CLEM26 [CBV][M] 2000 Volume #5 | Reloading chart. 2026-04-16 08:16:21.546 | F.US.CLEM26 [CBV][M] 2000 Volume #5 | StartDateTimeForLoadingOrderFills: 2025-04-09 00:00:00 2026-04-16 08:16:21.589 | F.US.CLEM26 [CBV][M] 2000 Volume #5 | Chart data loading complete. 2026-04-16 08:30:37.172 | CQG WebAPI | Received LoggedOff message. Reason: Your session was closed due to a concurrent session. 2026-04-16 08:30:37.173 | Connection to the external service has been lost. 2026-04-16 08:30:37.244 | CQG WebAPI | Sending Web API Logoff message. 2026-04-16 08:30:37.244 | CQG WebSocket socket (1) | CloseSocket call. 2026-04-16 08:30:37.244 | CQG WebSocket socket (1) | Max send buffers used during socket life: 3 2026-04-16 08:30:37.244 | CQG WebSocket socket (1) | Max send buffer size during socket life: 595 2026-04-16 08:30:37.244 | CQG WebSocket | WebSocket closed. 2026-04-16 08:30:37.244 | CQG WebAPI | WebSocket closed. 2026-04-16 08:30:37.244 | CQG WebSocket socket (1) | Write in progress. Shutdown being delayed. PendingSize=0 2026-04-16 08:30:37.248 | CQG WebAPI | Disconnected. 2026-04-16 08:30:37.248 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-04-16 08:30:37.248 | CQG WebSocket socket (1) | Write has completed. Shutdown being performed. 2026-04-16 08:30:37.248 | CQG WebSocket socket (1) | Shutdown started. Waiting for graceful close. 2026-04-16 08:30:37.253 | CQG WebSocket socket (1) | Socket gracefully closed by remote side. 2026-04-16 08:30:37.253 | CQG WebSocket socket (1) | Closed. 2026-04-16 08:30:39.250 | 2026-04-16 08:30:39.251 | CQG WebAPI | Connecting to server api.cqg.com 2026-04-16 08:30:39.251 | CQG WebSocket | Connecting to WebSocket server api.cqg.com:443 2026-04-16 08:30:39.253 | CQG WebSocket socket (1) | Creating socket. Using TLS 1.2. 2026-04-16 08:30:39.254 | CQG WebSocket socket (1) | New receive buffer size: 0 2026-04-16 08:30:39.254 | CQG WebSocket socket (1) | Connecting to IP: 195.166.124.175. 2026-04-16 08:30:39.260 | CQG WebSocket | Opening WebSocket. 2026-04-16 08:30:39.260 | CQG WebSocket | Sending WebSocket handshake. 2026-04-16 08:30:39.280 | CQG WebSocket | Server header | HTTP/1.1 101 Switching Protocols 2026-04-16 08:30:39.280 | CQG WebSocket | Server header | Connection: Upgrade 2026-04-16 08:30:39.280 | CQG WebSocket | Server header | Sec-WebSocket-Accept: /fNBtkrppMh8n/V+6PN48vpwl08= 2026-04-16 08:30:39.280 | CQG WebSocket | Server header | Server: WebSocket++/0.8.2 2026-04-16 08:30:39.280 | CQG WebSocket | Server header | Upgrade: websocket 2026-04-16 08:30:39.280 | CQG WebSocket | Server header | 2026-04-16 08:30:39.280 | CQG WebSocket | Web socket state is now open. 2026-04-16 08:30:39.280 | CQG WebAPI | WebSocket connected. 2026-04-16 08:30:39.281 | CQG WebAPI | Sending market data logon message. 2026-04-16 08:30:39.515 | CQG WebAPI | Base Time: 2026-03-28T06:33:36. 2026-03-28 06:33:36 2026-04-16 08:30:39.516 | CQG WebAPI | Logon successful. Session Token = Hvtni0yoUXjLW0j9vSnWy6vZgap1WJ4tgiDC6VvgMSwwgpxn75AcxyA7UW69kmib5hFMI6I1Sk5 2026-04-16 08:30:39.516 | CQG WebAPI | Connection to server complete. 2026-04-16 08:30:39.517 | Denali Data Feed | Waiting for socket receive thread to end 2026-04-16 08:30:39.517 | DTC Client socket (2) | CloseSocket call. 2026-04-16 08:30:39.517 | DTC Client socket (2) | Max send buffers used during socket life: 3 2026-04-16 08:30:39.517 | DTC Client socket (2) | Max send buffer size during socket life: 1556 2026-04-16 08:30:39.518 | DTC Client socket (2) | Shutdown started. Waiting for graceful close. 2026-04-16 08:30:39.518 | Denali Data Feed | Disconnected from the server. 2026-04-16 08:30:39.527 | No download requests in the queue to start downloads for. | Number times message added: 3 2026-04-16 08:30:39.527 | Updated verified funded futures trading account ending date to: 2026-05-16 12:30:39 2026-04-16 08:30:39.546 | CQG WebAPI | Sending Trade Accounts request message. 2026-04-16 08:30:39.579 | Mapping F.US.CLEM26 to CLM26. Service code: nymex 2026-04-16 08:30:39.579 | Using symbol data fast lookup vector 2026-04-16 08:30:39.579 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEM26 (CLM26). ID: 1 Service code: nymex 2026-04-16 08:30:39.580 | Denali Data Feed | Connecting to the server ds25.sierracharts.com. Port 10048 2026-04-16 08:30:39.581 | CQG WebAPI | Sending symbol resolution request for F.US.CLEM26. ID: 431380 2026-04-16 08:30:39.581 | Denali Data Feed | Requesting security definition data for: F.US.CLEM26 (CLM26). ID: 1 2026-04-16 08:30:39.581 | Added historical Intraday data request for F.US.CLEM26 to the queue. 2026-04-16 08:30:39.581 | Intraday data recording state for symbol F.US.CLEM26 is set to download 'Pending'. 2026-04-16 08:30:39.581 | Triggering next historical data download in queue. 2026-04-16 08:30:39.605 | Delaying start of download for F.US.CLEM26. 2026-04-16 08:30:39.606 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEM26. Search Symbol: F.US.CLEM26. Request ID: 431380. Contract ID: 1. 2026-04-16 08:30:39.607 | CQG WebAPI | Brokerage name: AMP. Account Name: 220033 2026-04-16 08:30:39.607 | Updated verified funded futures trading account ending date to: 2026-05-16 12:30:39 2026-04-16 08:30:39.607 | CQG WebAPI | Sending collateral subscribe request. 2026-04-16 08:30:39.694 | DTC Client socket (3) | Creating socket. 2026-04-16 08:30:39.694 | DTC Client socket (3) | New receive buffer size: 0 2026-04-16 08:30:39.694 | DTC Client socket (3) | Connecting to IP: 64.152.155.20. 2026-04-16 08:30:39.721 | Mapping F.US.CLEV25 to CLV25. Service code: nymex 2026-04-16 08:30:39.722 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEV25 (CLV25). ID: 2 Service code: nymex 2026-04-16 08:30:39.722 | CQG WebAPI | Sending symbol resolution request for F.US.CLEV25. ID: 431382 2026-04-16 08:30:39.722 | Denali Data Feed | Requesting security definition data for: F.US.CLEV25 (CLV25). ID: 2 2026-04-16 08:30:39.722 | Added historical Intraday data request for F.US.CLEV25 to the queue. 2026-04-16 08:30:39.722 | Intraday data recording state for symbol F.US.CLEV25 is set to download 'Pending'. 2026-04-16 08:30:39.722 | Triggering next historical data download in queue. 2026-04-16 08:30:39.728 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEV25. Search Symbol: F.US.CLEV25. Request ID: 431382. Contract ID: 2. 2026-04-16 08:30:39.729 | Mapping F.US.EPU25 to ESU25. Service code: cme 2026-04-16 08:30:39.729 | Denali Data Feed | Starting real-time market data updates for: F.US.EPU25 (ESU25). ID: 3 Service code: cme 2026-04-16 08:30:39.729 | CQG WebAPI | Sending symbol resolution request for F.US.EPU25. ID: 431383 2026-04-16 08:30:39.729 | Denali Data Feed | Requesting security definition data for: F.US.EPU25 (ESU25). ID: 3 2026-04-16 08:30:39.729 | Added historical Intraday data request for F.US.EPU25 to the queue. 2026-04-16 08:30:39.729 | Intraday data recording state for symbol F.US.EPU25 is set to download 'Pending'. 2026-04-16 08:30:39.729 | Triggering next historical data download in queue. 2026-04-16 08:30:39.743 | CQG WebAPI | Received symbol resolution report for symbol F.US.EPU25. Search Symbol: F.US.EPU25. Request ID: 431383. Contract ID: 3. 2026-04-16 08:30:39.769 | DTC Client socket (2) | Socket gracefully closed by remote side. 2026-04-16 08:30:39.769 | DTC Client socket (2) | Closed. 2026-04-16 08:30:39.770 | CQG WebAPI | Sending positions subscribe request. RequestID: 431384 2026-04-16 08:30:39.770 | CQG WebAPI | Sending orders subscribe request. RequestID: 431385 2026-04-16 08:30:39.822 | Denali Data Feed | Network connection to server complete. 2026-04-16 08:30:39.822 | Denali Data Feed | Starting socket receive thread. 2026-04-16 08:30:39.822 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard 2026-04-16 08:30:39.963 | Denali Data Feed | Setting DTC encoding to Binary VLS 2026-04-16 08:30:39.963 | Denali Data Feed | Sending logon request message. 2026-04-16 08:30:40.174 | Mapping F.US.EPH23 to ESH23. Service code: cme 2026-04-16 08:30:40.174 | Denali Data Feed | Starting real-time market data updates for: F.US.EPH23 (ESH23). ID: 4 Service code: cme 2026-04-16 08:30:40.174 | CQG WebAPI | Sending symbol resolution request for F.US.EPH23. ID: 431386 2026-04-16 08:30:40.174 | Denali Data Feed | Requesting security definition data for: F.US.EPH23 (ESH23). ID: 4 2026-04-16 08:30:40.175 | Mapping F.US.EPM23 to ESM23. Service code: cme 2026-04-16 08:30:40.175 | Denali Data Feed | Starting real-time market data updates for: F.US.EPM23 (ESM23). ID: 5 Service code: cme 2026-04-16 08:30:40.175 | CQG WebAPI | Sending symbol resolution request for F.US.EPM23. ID: 431387 2026-04-16 08:30:40.175 | Denali Data Feed | Requesting security definition data for: F.US.EPM23 (ESM23). ID: 5 2026-04-16 08:30:40.175 | Mapping F.US.EPU23 to ESU23. Service code: cme 2026-04-16 08:30:40.175 | Denali Data Feed | Starting real-time market data updates for: F.US.EPU23 (ESU23). ID: 6 Service code: cme 2026-04-16 08:30:40.175 | CQG WebAPI | Sending symbol resolution request for F.US.EPU23. ID: 431388 2026-04-16 08:30:40.175 | Denali Data Feed | Requesting security definition data for: F.US.EPU23 (ESU23). ID: 6 2026-04-16 08:30:40.175 | Mapping F.US.EPZ23 to ESZ23. Service code: cme 2026-04-16 08:30:40.175 | Denali Data Feed | Starting real-time market data updates for: F.US.EPZ23 (ESZ23). ID: 7 Service code: cme 2026-04-16 08:30:40.175 | CQG WebAPI | Sending symbol resolution request for F.US.EPZ23. ID: 431389 2026-04-16 08:30:40.175 | Denali Data Feed | Requesting security definition data for: F.US.EPZ23 (ESZ23). ID: 7 2026-04-16 08:30:40.175 | Mapping F.US.EPH24 to ESH24. Service code: cme 2026-04-16 08:30:40.175 | Denali Data Feed | Starting real-time market data updates for: F.US.EPH24 (ESH24). ID: 8 Service code: cme 2026-04-16 08:30:40.175 | CQG WebAPI | Sending symbol resolution request for F.US.EPH24. ID: 431390 2026-04-16 08:30:40.175 | Denali Data Feed | Requesting security definition data for: F.US.EPH24 (ESH24). ID: 8 2026-04-16 08:30:40.175 | Mapping F.US.CLEF23 to CLF23. Service code: nymex 2026-04-16 08:30:40.175 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEF23 (CLF23). ID: 9 Service code: nymex 2026-04-16 08:30:40.175 | CQG WebAPI | Sending symbol resolution request for F.US.CLEF23. ID: 431391 2026-04-16 08:30:40.175 | Denali Data Feed | Requesting security definition data for: F.US.CLEF23 (CLF23). ID: 9 2026-04-16 08:30:40.176 | Mapping F.US.CLEG23 to CLG23. Service code: nymex 2026-04-16 08:30:40.176 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEG23 (CLG23). ID: 10 Service code: nymex 2026-04-16 08:30:40.176 | CQG WebAPI | Sending symbol resolution request for F.US.CLEG23. ID: 431392 2026-04-16 08:30:40.176 | Denali Data Feed | Requesting security definition data for: F.US.CLEG23 (CLG23). ID: 10 2026-04-16 08:30:40.176 | Mapping F.US.CLEH23 to CLH23. Service code: nymex 2026-04-16 08:30:40.176 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEH23 (CLH23). ID: 11 Service code: nymex 2026-04-16 08:30:40.176 | CQG WebAPI | Sending symbol resolution request for F.US.CLEH23. ID: 431393 2026-04-16 08:30:40.176 | Denali Data Feed | Requesting security definition data for: F.US.CLEH23 (CLH23). ID: 11 2026-04-16 08:30:40.176 | Mapping F.US.CLEJ23 to CLJ23. Service code: nymex 2026-04-16 08:30:40.176 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEJ23 (CLJ23). ID: 12 Service code: nymex 2026-04-16 08:30:40.176 | CQG WebAPI | Sending symbol resolution request for F.US.CLEJ23. ID: 431394 2026-04-16 08:30:40.176 | Denali Data Feed | Requesting security definition data for: F.US.CLEJ23 (CLJ23). ID: 12 2026-04-16 08:30:40.176 | Mapping F.US.CLEK23 to CLK23. Service code: nymex 2026-04-16 08:30:40.176 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEK23 (CLK23). ID: 13 Service code: nymex 2026-04-16 08:30:40.176 | CQG WebAPI | Sending symbol resolution request for F.US.CLEK23. ID: 431395 2026-04-16 08:30:40.176 | Denali Data Feed | Requesting security definition data for: F.US.CLEK23 (CLK23). ID: 13 2026-04-16 08:30:40.176 | Mapping F.US.CLEM23 to CLM23. Service code: nymex 2026-04-16 08:30:40.176 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEM23 (CLM23). ID: 14 Service code: nymex 2026-04-16 08:30:40.176 | CQG WebAPI | Sending symbol resolution request for F.US.CLEM23. ID: 431396 2026-04-16 08:30:40.176 | Denali Data Feed | Requesting security definition data for: F.US.CLEM23 (CLM23). ID: 14 2026-04-16 08:30:40.176 | Mapping F.US.CLEN23 to CLN23. Service code: nymex 2026-04-16 08:30:40.176 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEN23 (CLN23). ID: 15 Service code: nymex 2026-04-16 08:30:40.176 | CQG WebAPI | Sending symbol resolution request for F.US.CLEN23. ID: 431397 2026-04-16 08:30:40.176 | Denali Data Feed | Requesting security definition data for: F.US.CLEN23 (CLN23). ID: 15 2026-04-16 08:30:40.176 | Mapping F.US.CLEQ23 to CLQ23. Service code: nymex 2026-04-16 08:30:40.177 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEQ23 (CLQ23). ID: 16 Service code: nymex 2026-04-16 08:30:40.177 | CQG WebAPI | Sending symbol resolution request for F.US.CLEQ23. ID: 431398 2026-04-16 08:30:40.177 | Denali Data Feed | Requesting security definition data for: F.US.CLEQ23 (CLQ23). ID: 16 2026-04-16 08:30:40.177 | Mapping F.US.CLEU23 to CLU23. Service code: nymex 2026-04-16 08:30:40.177 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEU23 (CLU23). ID: 17 Service code: nymex 2026-04-16 08:30:40.177 | CQG WebAPI | Sending symbol resolution request for F.US.CLEU23. ID: 431399 2026-04-16 08:30:40.177 | Denali Data Feed | Requesting security definition data for: F.US.CLEU23 (CLU23). ID: 17 2026-04-16 08:30:40.177 | Mapping F.US.CLEV23 to CLV23. Service code: nymex 2026-04-16 08:30:40.177 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEV23 (CLV23). ID: 18 Service code: nymex 2026-04-16 08:30:40.177 | CQG WebAPI | Sending symbol resolution request for F.US.CLEV23. ID: 431400 2026-04-16 08:30:40.177 | Denali Data Feed | Requesting security definition data for: F.US.CLEV23 (CLV23). ID: 18 2026-04-16 08:30:40.177 | Mapping F.US.CLEX23 to CLX23. Service code: nymex 2026-04-16 08:30:40.177 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEX23 (CLX23). ID: 19 Service code: nymex 2026-04-16 08:30:40.177 | CQG WebAPI | Sending symbol resolution request for F.US.CLEX23. ID: 431401 2026-04-16 08:30:40.177 | Denali Data Feed | Requesting security definition data for: F.US.CLEX23 (CLX23). ID: 19 2026-04-16 08:30:40.177 | Mapping F.US.CLEZ23 to CLZ23. Service code: nymex 2026-04-16 08:30:40.177 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEZ23 (CLZ23). ID: 20 Service code: nymex 2026-04-16 08:30:40.177 | CQG WebAPI | Sending symbol resolution request for F.US.CLEZ23. ID: 431402 2026-04-16 08:30:40.177 | Denali Data Feed | Requesting security definition data for: F.US.CLEZ23 (CLZ23). ID: 20 2026-04-16 08:30:40.177 | Mapping F.US.CLEF24 to CLF24. Service code: nymex 2026-04-16 08:30:40.177 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEF24 (CLF24). ID: 21 Service code: nymex 2026-04-16 08:30:40.177 | CQG WebAPI | Sending symbol resolution request for F.US.CLEF24. ID: 431403 2026-04-16 08:30:40.177 | Denali Data Feed | Requesting security definition data for: F.US.CLEF24 (CLF24). ID: 21 2026-04-16 08:30:40.177 | Mapping F.US.CLEG24 to CLG24. Service code: nymex 2026-04-16 08:30:40.177 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEG24 (CLG24). ID: 22 Service code: nymex 2026-04-16 08:30:40.177 | CQG WebAPI | Sending symbol resolution request for F.US.CLEG24. ID: 431404 2026-04-16 08:30:40.177 | Denali Data Feed | Requesting security definition data for: F.US.CLEG24 (CLG24). ID: 22 2026-04-16 08:30:40.179 | CQG WebAPI | Received symbol resolution report for symbol F.US.EPH23. Search Symbol: F.US.EPH23. Request ID: 431386. Contract ID: 4. 2026-04-16 08:30:40.179 | CQG WebAPI | Received symbol resolution report for symbol F.US.EPM23. Search Symbol: F.US.EPM23. Request ID: 431387. Contract ID: 5. 2026-04-16 08:30:40.179 | CQG WebAPI | Received symbol resolution report for symbol F.US.EPU23. Search Symbol: F.US.EPU23. Request ID: 431388. Contract ID: 6. 2026-04-16 08:30:40.272 | CQG WebAPI | Received symbol resolution report for symbol F.US.EPZ23. Search Symbol: F.US.EPZ23. Request ID: 431389. Contract ID: 7. 2026-04-16 08:30:40.272 | CQG WebAPI | Received symbol resolution report for symbol F.US.EPH24. Search Symbol: F.US.EPH24. Request ID: 431390. Contract ID: 8. 2026-04-16 08:30:40.272 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEF23. Search Symbol: F.US.CLEF23. Request ID: 431391. Contract ID: 9. 2026-04-16 08:30:40.272 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEG23. Search Symbol: F.US.CLEG23. Request ID: 431392. Contract ID: 10. 2026-04-16 08:30:40.272 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEH23. Search Symbol: F.US.CLEH23. Request ID: 431393. Contract ID: 11. 2026-04-16 08:30:40.272 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEJ23. Search Symbol: F.US.CLEJ23. Request ID: 431394. Contract ID: 12. 2026-04-16 08:30:40.272 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEK23. Search Symbol: F.US.CLEK23. Request ID: 431395. Contract ID: 13. 2026-04-16 08:30:40.272 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEM23. Search Symbol: F.US.CLEM23. Request ID: 431396. Contract ID: 14. 2026-04-16 08:30:40.272 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEN23. Search Symbol: F.US.CLEN23. Request ID: 431397. Contract ID: 15. 2026-04-16 08:30:40.273 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEQ23. Search Symbol: F.US.CLEQ23. Request ID: 431398. Contract ID: 16. 2026-04-16 08:30:40.273 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEU23. Search Symbol: F.US.CLEU23. Request ID: 431399. Contract ID: 17. 2026-04-16 08:30:40.276 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEV23. Search Symbol: F.US.CLEV23. Request ID: 431400. Contract ID: 18. 2026-04-16 08:30:40.276 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEX23. Search Symbol: F.US.CLEX23. Request ID: 431401. Contract ID: 19. 2026-04-16 08:30:40.276 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEZ23. Search Symbol: F.US.CLEZ23. Request ID: 431402. Contract ID: 20. 2026-04-16 08:30:40.276 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEF24. Search Symbol: F.US.CLEF24. Request ID: 431403. Contract ID: 21. 2026-04-16 08:30:40.276 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEG24. Search Symbol: F.US.CLEG24. Request ID: 431404. Contract ID: 22. 2026-04-16 08:30:40.535 | Denali Data Feed | Received logon response. 2026-04-16 08:30:40.535 | Denali Data Feed | Server Name: SC Realtime Server. 2026-04-16 08:30:40.535 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8 2026-04-16 08:30:40.535 | Denali Data Feed | Successfully connected. 2026-04-16 08:30:40.535 | Denali Data Feed | Trading is not supported. 2026-04-16 08:30:40.535 | Denali Data Feed | MarketDepthIsSupported: 1 2026-04-16 08:30:40.536 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEF23 -> CLF23 2026-04-16 08:30:40.536 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEF24 -> CLF24 2026-04-16 08:30:40.536 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEG23 -> CLG23 2026-04-16 08:30:40.536 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEG24 -> CLG24 2026-04-16 08:30:40.536 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEH23 -> CLH23 2026-04-16 08:30:40.536 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEJ23 -> CLJ23 2026-04-16 08:30:40.536 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEK23 -> CLK23 2026-04-16 08:30:40.536 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEM23 -> CLM23 2026-04-16 08:30:40.536 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEM26 -> CLM26 2026-04-16 08:30:40.536 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEN23 -> CLN23 2026-04-16 08:30:40.536 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEQ23 -> CLQ23 2026-04-16 08:30:40.536 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEU23 -> CLU23 2026-04-16 08:30:40.536 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEV23 -> CLV23 2026-04-16 08:30:40.536 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEV25 -> CLV25 2026-04-16 08:30:40.536 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEX23 -> CLX23 2026-04-16 08:30:40.536 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEZ23 -> CLZ23 2026-04-16 08:30:40.536 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.EPH23 -> ESH23 2026-04-16 08:30:40.536 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.EPH24 -> ESH24 2026-04-16 08:30:40.536 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.EPM23 -> ESM23 2026-04-16 08:30:40.536 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.EPU23 -> ESU23 2026-04-16 08:30:40.536 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.EPU25 -> ESU25 2026-04-16 08:30:40.536 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.EPZ23 -> ESZ23 2026-04-16 08:30:40.751 | Denali Data Feed | Real-time data for symbol F.US.CLEF23 is currently unavailable. 2026-04-16 08:30:40.752 | Denali Data Feed | Received security definition for symbol F.US.CLEF23 2026-04-16 08:30:40.752 | Denali Data Feed | Real-time data for symbol F.US.CLEF24 is currently unavailable. 2026-04-16 08:30:40.752 | Denali Data Feed | Received security definition for symbol F.US.CLEF24 2026-04-16 08:30:40.752 | Denali Data Feed | Real-time data for symbol F.US.CLEG23 is currently unavailable. 2026-04-16 08:30:40.752 | Denali Data Feed | Received security definition for symbol F.US.CLEG23 2026-04-16 08:30:40.752 | Denali Data Feed | Real-time data for symbol F.US.CLEG24 is currently unavailable. 2026-04-16 08:30:40.752 | Denali Data Feed | Received security definition for symbol F.US.CLEG24 2026-04-16 08:30:40.752 | Denali Data Feed | Real-time data for symbol F.US.CLEH23 is currently unavailable. 2026-04-16 08:30:40.752 | Denali Data Feed | Received security definition for symbol F.US.CLEH23 2026-04-16 08:30:40.752 | Denali Data Feed | Real-time data for symbol F.US.CLEJ23 is currently unavailable. 2026-04-16 08:30:40.752 | Denali Data Feed | Received security definition for symbol F.US.CLEJ23 2026-04-16 08:30:40.752 | Denali Data Feed | Real-time data for symbol F.US.CLEK23 is currently unavailable. 2026-04-16 08:30:40.752 | Denali Data Feed | Received security definition for symbol F.US.CLEK23 2026-04-16 08:30:40.752 | Denali Data Feed | Real-time data for symbol F.US.CLEM23 is currently unavailable. 2026-04-16 08:30:40.752 | Denali Data Feed | Received security definition for symbol F.US.CLEM23 2026-04-16 08:30:40.752 | Denali Data Feed | Setting external service identifier for symbol F.US.CLEM26 to 670557 2026-04-16 08:30:40.752 | Denali Data Feed | Received security definition for symbol F.US.CLEM26 2026-04-16 08:30:40.752 | Denali Data Feed | Real-time data for symbol F.US.CLEN23 is currently unavailable. 2026-04-16 08:30:40.752 | Denali Data Feed | Received security definition for symbol F.US.CLEN23 2026-04-16 08:30:40.752 | Denali Data Feed | Real-time data for symbol F.US.CLEQ23 is currently unavailable. 2026-04-16 08:30:40.752 | Denali Data Feed | Received security definition for symbol F.US.CLEQ23 2026-04-16 08:30:40.752 | Denali Data Feed | Real-time data for symbol F.US.CLEU23 is currently unavailable. 2026-04-16 08:30:40.752 | Denali Data Feed | Received security definition for symbol F.US.CLEU23 2026-04-16 08:30:40.752 | Denali Data Feed | Real-time data for symbol F.US.CLEV23 is currently unavailable. 2026-04-16 08:30:40.752 | Denali Data Feed | Received security definition for symbol F.US.CLEV23 2026-04-16 08:30:40.752 | Denali Data Feed | Real-time data for symbol F.US.CLEV25 is currently unavailable. 2026-04-16 08:30:40.752 | Denali Data Feed | Received security definition for symbol F.US.CLEV25 2026-04-16 08:30:40.752 | Denali Data Feed | Real-time data for symbol F.US.CLEX23 is currently unavailable. 2026-04-16 08:30:40.752 | Denali Data Feed | Received security definition for symbol F.US.CLEX23 2026-04-16 08:30:40.752 | Denali Data Feed | Real-time data for symbol F.US.CLEZ23 is currently unavailable. 2026-04-16 08:30:40.752 | Denali Data Feed | Received security definition for symbol F.US.CLEZ23 2026-04-16 08:30:40.752 | Denali Data Feed | Real-time data for symbol F.US.EPH23 is currently unavailable. 2026-04-16 08:30:40.752 | Denali Data Feed | Received security definition for symbol F.US.EPH23 2026-04-16 08:30:40.752 | Denali Data Feed | Real-time data for symbol F.US.EPH24 is currently unavailable. 2026-04-16 08:30:40.752 | Denali Data Feed | Received security definition for symbol F.US.EPH24 2026-04-16 08:30:40.752 | Denali Data Feed | Real-time data for symbol F.US.EPM23 is currently unavailable. 2026-04-16 08:30:40.752 | Denali Data Feed | Received security definition for symbol F.US.EPM23 2026-04-16 08:30:40.752 | Denali Data Feed | Real-time data for symbol F.US.EPU23 is currently unavailable. 2026-04-16 08:30:40.752 | Denali Data Feed | Received security definition for symbol F.US.EPU23 2026-04-16 08:30:40.752 | Denali Data Feed | Real-time data for symbol F.US.EPU25 is currently unavailable. 2026-04-16 08:30:40.752 | Denali Data Feed | Received security definition for symbol F.US.EPU25 2026-04-16 08:30:40.752 | Denali Data Feed | Real-time data for symbol F.US.EPZ23 is currently unavailable. 2026-04-16 08:30:40.752 | Denali Data Feed | Received security definition for symbol F.US.EPZ23 2026-04-16 08:30:44.522 | Requesting market depth updates for: F.US.CLEV25 if supported. NumLevels=100 2026-04-16 08:30:44.703 | Denali Data Feed | Clearing market depth for F.US.CLEV25 2026-04-16 08:30:45.145 | HD Request # 37 | Downloading Intraday chart data for F.US.CLEM26 to the file F.US.CLEM26.scid. Service: nymex 2026-04-16 08:30:45.147 | HD Request # 37 | Download start date-time: 2026-04-16 08:30:37.000000. File last date-time: 2026-04-16 08:30:37.402001 2026-04-16 08:30:45.148 | HD Request # 37 | Using server: ds32.sierracharts.com port 10150 2026-04-16 08:30:45.149 | Socket (2) | Creating socket. 2026-04-16 08:30:45.149 | Socket (2) | New receive buffer size: 0 2026-04-16 08:30:45.149 | Socket (2) | Connecting to IP: 69.39.70.248. 2026-04-16 08:30:45.341 | HD Request # 37 | Setting DTC encoding to Binary VLS 2026-04-16 08:30:45.341 | HD Request # 37 | Sending historical data logon request message. 2026-04-16 08:30:45.466 | HD Request # 37 | Requesting Intraday data. Start date-time: 2026-04-16 08:30:37. Record interval: 0. Symbol: CLM26 2026-04-16 08:30:45.559 | HD Request # 37 | Decompressing data. 2026-04-16 08:30:45.654 | HD Request # 37 | Receiving Intraday data for F.US.CLEM26 starting at 2026-04-16 08:30:37.242000 2026-04-16 08:30:45.654 | Socket (2) | CloseSocket call. 2026-04-16 08:30:45.655 | Socket (2) | Shutdown started. Waiting for graceful close. 2026-04-16 08:30:45.656 | Historical data download thread signaled to stop. 2026-04-16 08:30:45.656 | HD Request # 37 | Timestamp of first Intraday data file record written: 2026-04-16 08:30:37.590000. 2026-04-16 08:30:45.656 | HD Request # 37 | Received 62 Intraday data records from 2026-04-16 08:30:37.242000 to 2026-04-16 08:30:43.574000 (6.3 seconds. Delay: 2.1 seconds) and wrote 59 records for F.US.CLEM26 2026-04-16 08:30:45.664 | HD Request # 37 | Add time&sales data | Remembered last file record date-time: 2026-04-16 12:30:43.574000 2026-04-16 08:30:45.664 | Added 3 Time and Sales records to Intraday data file for F.US.CLEM26 after download. 2026-04-16 08:30:45.665 | HD Request # 37 | Completion time: 0s. 2026-04-16 08:30:45.665 | HD Request # 37 | Intraday data download complete for F.US.CLEM26. Unique request ID: 37 2026-04-16 08:30:45.665 | Removing historical data download ID 37. 2026-04-16 08:30:45.665 | Real-time Intraday chart data file updates started for F.US.CLEM26 2026-04-16 08:30:45.665 | Intraday chart data file opened for F.US.CLEM26 2026-04-16 08:30:45.665 | HD Request # 37 | Enabling Intraday chart updating for symbol. 2026-04-16 08:30:45.665 | 2026-04-16 08:30:45.665 | Triggering next historical data download in queue. 2026-04-16 08:30:45.665 | HD Request # 38 | Downloading Intraday chart data for F.US.CLEV25 to the file F.US.CLEV25.scid. Service: nymex 2026-04-16 08:30:45.667 | HD Request # 38 | Download start date-time: 2025-09-22 14:29:55.000000. File last date-time: 2025-09-22 14:29:55.618000 2026-04-16 08:30:45.667 | HD Request # 38 | Using server: ds26.sierracharts.com port 10149 2026-04-16 08:30:45.668 | Socket (4) | Creating socket. 2026-04-16 08:30:45.668 | Socket (4) | New receive buffer size: 0 2026-04-16 08:30:45.668 | Socket (4) | Connecting to IP: 64.152.155.17. 2026-04-16 08:30:45.748 | Socket (2) | Socket gracefully closed by remote side. 2026-04-16 08:30:45.748 | Socket (2) | Closed. 2026-04-16 08:30:45.985 | HD Request # 38 | Setting DTC encoding to Binary VLS 2026-04-16 08:30:45.985 | HD Request # 38 | Sending historical data logon request message. 2026-04-16 08:30:46.171 | HD Request # 38 | Requesting Intraday data. Start date-time: 2025-09-22 14:29:55. Record interval: 0. Symbol: CLV25 2026-04-16 08:30:46.327 | HD Request # 38 | Decompressing data. 2026-04-16 08:30:46.482 | HD Request # 38 | Receiving Intraday data for F.US.CLEV25 starting at 2025-09-22 14:29:55.086000 2026-04-16 08:30:46.482 | Socket (4) | CloseSocket call. 2026-04-16 08:30:46.483 | Socket (4) | Shutdown started. Waiting for graceful close. 2026-04-16 08:30:46.484 | Historical data download thread signaled to stop. 2026-04-16 08:30:46.484 | HD Request # 38 | Received 2 Intraday data records from 2025-09-22 14:29:55.086000 to 2025-09-22 14:29:55.618000 (0.5 seconds. Delay: 205.8 days) and wrote 0 records for F.US.CLEV25 2026-04-16 08:30:46.484 | HD Request # 38 | Add time&sales data | Remembered last file record date-time: 2025-09-22 18:29:55.618000 2026-04-16 08:30:46.484 | HD Request # 38 | Completion time: 1s. 2026-04-16 08:30:46.484 | HD Request # 38 | Intraday data download complete for F.US.CLEV25. Unique request ID: 38 2026-04-16 08:30:46.484 | Removing historical data download ID 38. 2026-04-16 08:30:46.484 | Real-time Intraday chart data file updates started for F.US.CLEV25 2026-04-16 08:30:46.484 | Intraday chart data file opened for F.US.CLEV25 2026-04-16 08:30:46.484 | HD Request # 38 | Enabling Intraday chart updating for symbol. 2026-04-16 08:30:46.484 | 2026-04-16 08:30:46.484 | Triggering next historical data download in queue. 2026-04-16 08:30:46.484 | HD Request # 39 | Downloading Intraday chart data for F.US.EPU25 to the file F.US.EPU25.scid. Service: cme 2026-04-16 08:30:46.488 | HD Request # 39 | Download start date-time: 2025-09-19 09:29:58.000000. File last date-time: 2025-09-19 09:29:58.698000 2026-04-16 08:30:46.488 | HD Request # 39 | Using server: ds28.sierracharts.com port 10150 2026-04-16 08:30:46.489 | Socket (2) | Creating socket. 2026-04-16 08:30:46.489 | Socket (2) | New receive buffer size: 0 2026-04-16 08:30:46.489 | Socket (2) | Connecting to IP: 67.214.125.5. 2026-04-16 08:30:46.678 | HD Request # 39 | Setting DTC encoding to Binary VLS 2026-04-16 08:30:46.678 | HD Request # 39 | Sending historical data logon request message. 2026-04-16 08:30:46.807 | HD Request # 39 | Requesting Intraday data. Start date-time: 2025-09-19 09:29:58. Record interval: 0. Symbol: ESU25 2026-04-16 08:30:46.902 | HD Request # 39 | Decompressing data. 2026-04-16 08:30:46.995 | HD Request # 39 | Receiving Intraday data for F.US.EPU25 starting at 2025-09-19 09:29:58.697000 2026-04-16 08:30:46.995 | Socket (2) | CloseSocket call. 2026-04-16 08:30:46.995 | Socket (2) | Shutdown started. Waiting for graceful close. 2026-04-16 08:30:46.995 | Historical data download thread signaled to stop. 2026-04-16 08:30:46.995 | HD Request # 39 | Received 5 Intraday data records from 2025-09-19 09:29:58.697000 to 2025-09-19 09:29:58.698000 (0.0 seconds. Delay: 209.0 days) and wrote 0 records for F.US.EPU25 2026-04-16 08:30:46.996 | HD Request # 39 | Add time&sales data | Remembered last file record date-time: 2025-09-19 13:29:58.698000 2026-04-16 08:30:46.996 | HD Request # 39 | Completion time: 0s. 2026-04-16 08:30:46.996 | HD Request # 39 | Intraday data download complete for F.US.EPU25. Unique request ID: 39 2026-04-16 08:30:46.996 | Removing historical data download ID 39. 2026-04-16 08:30:46.996 | Real-time Intraday chart data file updates started for F.US.EPU25 2026-04-16 08:30:46.996 | Intraday chart data file opened for F.US.EPU25 2026-04-16 08:30:46.996 | HD Request # 39 | Enabling Intraday chart updating for symbol. 2026-04-16 08:30:46.996 | 2026-04-16 08:30:46.996 | No download requests in the queue to start downloads for. 2026-04-16 08:30:47.005 | Socket (4) | Socket gracefully closed by remote side. 2026-04-16 08:30:47.005 | Socket (4) | Closed. 2026-04-16 08:30:47.088 | Socket (2) | Socket gracefully closed by remote side. 2026-04-16 08:30:47.088 | Socket (2) | Closed. 2026-04-16 08:30:48.582 | Opened cached Intraday file: C:\SierraChart\Data\F.US.CLEM26.scid. Thread ID: 16976 2026-04-16 08:30:48.735 | CQG WebAPI | Received LoggedOff message. Reason: Your session was closed due to a concurrent session. 2026-04-16 08:30:48.735 | Connection to the external service has been lost. 2026-04-16 08:30:48.772 | CQG WebAPI | Sending Web API Logoff message. 2026-04-16 08:30:48.772 | CQG WebSocket socket (1) | CloseSocket call. 2026-04-16 08:30:48.772 | CQG WebSocket socket (1) | Max send buffers used during socket life: 3 2026-04-16 08:30:48.772 | CQG WebSocket socket (1) | Max send buffer size during socket life: 595 2026-04-16 08:30:48.772 | CQG WebSocket | WebSocket closed. 2026-04-16 08:30:48.772 | CQG WebAPI | WebSocket closed. 2026-04-16 08:30:48.772 | CQG WebSocket socket (1) | Write in progress. Shutdown being delayed. PendingSize=0 2026-04-16 08:30:48.772 | CQG WebAPI | Disconnected. 2026-04-16 08:30:48.772 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-04-16 08:30:48.776 | CQG WebSocket socket (1) | Write has completed. Shutdown being performed. 2026-04-16 08:30:48.776 | CQG WebSocket socket (1) | Shutdown started. Waiting for graceful close. 2026-04-16 08:30:48.781 | CQG WebSocket socket (1) | Socket gracefully closed by remote side. 2026-04-16 08:30:48.781 | CQG WebSocket socket (1) | Closed. 2026-04-16 08:30:50.773 | 2026-04-16 08:30:50.773 | CQG WebAPI | Connecting to server api.cqg.com 2026-04-16 08:30:50.773 | CQG WebSocket | Connecting to WebSocket server api.cqg.com:443 2026-04-16 08:30:50.774 | CQG WebSocket socket (1) | Creating socket. Using TLS 1.2. 2026-04-16 08:30:50.774 | CQG WebSocket socket (1) | New receive buffer size: 0 2026-04-16 08:30:50.774 | CQG WebSocket socket (1) | Connecting to IP: 195.166.124.175. 2026-04-16 08:30:50.781 | CQG WebSocket | Opening WebSocket. 2026-04-16 08:30:50.781 | CQG WebSocket | Sending WebSocket handshake. 2026-04-16 08:30:50.803 | CQG WebSocket | Server header | HTTP/1.1 101 Switching Protocols 2026-04-16 08:30:50.803 | CQG WebSocket | Server header | Connection: Upgrade 2026-04-16 08:30:50.803 | CQG WebSocket | Server header | Sec-WebSocket-Accept: ZGLztuOEoA/1XFfMtwSuexBcbto= 2026-04-16 08:30:50.803 | CQG WebSocket | Server header | Server: WebSocket++/0.8.2 2026-04-16 08:30:50.803 | CQG WebSocket | Server header | Upgrade: websocket 2026-04-16 08:30:50.803 | CQG WebSocket | Server header | 2026-04-16 08:30:50.803 | CQG WebSocket | Web socket state is now open. 2026-04-16 08:30:50.803 | CQG WebAPI | WebSocket connected. 2026-04-16 08:30:50.803 | CQG WebAPI | Sending market data logon message. 2026-04-16 08:30:51.041 | CQG WebAPI | Base Time: 2026-03-28T06:33:36. 2026-03-28 06:33:36 2026-04-16 08:30:51.041 | CQG WebAPI | Logon successful. Session Token = Wn8cpYgkHTqbPs9OMLdpMQhCodcH/kv9XSVOcxTC0UcaqS6kcq+IOfVnEGSf2EYJefxOIGHDvRl 2026-04-16 08:30:51.041 | CQG WebAPI | Connection to server complete. 2026-04-16 08:30:51.041 | Denali Data Feed | Waiting for socket receive thread to end 2026-04-16 08:30:51.041 | DTC Client socket (3) | CloseSocket call. 2026-04-16 08:30:51.041 | DTC Client socket (3) | Max send buffers used during socket life: 4 2026-04-16 08:30:51.041 | DTC Client socket (3) | Max send buffer size during socket life: 1560 2026-04-16 08:30:51.042 | DTC Client socket (3) | Shutdown started. Waiting for graceful close. 2026-04-16 08:30:51.042 | Denali Data Feed | Disconnected from the server. 2026-04-16 08:30:51.043 | No download requests in the queue to start downloads for. | Number times message added: 3 2026-04-16 08:30:51.043 | Updated verified funded futures trading account ending date to: 2026-05-16 12:30:51 2026-04-16 08:30:51.082 | CQG WebAPI | Sending Trade Accounts request message. 2026-04-16 08:30:51.087 | Mapping F.US.CLEM26 to CLM26. Service code: nymex 2026-04-16 08:30:51.087 | Using symbol data fast lookup vector 2026-04-16 08:30:51.087 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEM26 (CLM26). ID: 1 Service code: nymex 2026-04-16 08:30:51.087 | Denali Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 443 2026-04-16 08:30:51.087 | CQG WebAPI | Sending symbol resolution request for F.US.CLEM26. ID: 431406 2026-04-16 08:30:51.087 | Denali Data Feed | Requesting security definition data for: F.US.CLEM26 (CLM26). ID: 1 2026-04-16 08:30:51.087 | Added historical Intraday data request for F.US.CLEM26 to the queue. 2026-04-16 08:30:51.087 | Intraday data recording state for symbol F.US.CLEM26 is set to download 'Pending'. 2026-04-16 08:30:51.087 | Triggering next historical data download in queue. 2026-04-16 08:30:51.094 | DTC Client socket (2) | Creating socket. 2026-04-16 08:30:51.095 | DTC Client socket (2) | New receive buffer size: 0 2026-04-16 08:30:51.095 | DTC Client socket (2) | Connecting to IP: 67.214.125.6. 2026-04-16 08:30:51.102 | Delaying start of download for F.US.CLEM26. 2026-04-16 08:30:51.124 | Mapping F.US.CLEV25 to CLV25. Service code: nymex 2026-04-16 08:30:51.124 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEV25 (CLV25). ID: 2 Service code: nymex 2026-04-16 08:30:51.124 | CQG WebAPI | Sending symbol resolution request for F.US.CLEV25. ID: 431407 2026-04-16 08:30:51.124 | Denali Data Feed | Requesting security definition data for: F.US.CLEV25 (CLV25). ID: 2 2026-04-16 08:30:51.125 | Added historical Intraday data request for F.US.CLEV25 to the queue. 2026-04-16 08:30:51.125 | Intraday data recording state for symbol F.US.CLEV25 is set to download 'Pending'. 2026-04-16 08:30:51.125 | Triggering next historical data download in queue. 2026-04-16 08:30:51.131 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEM26. Search Symbol: F.US.CLEM26. Request ID: 431406. Contract ID: 1. 2026-04-16 08:30:51.131 | CQG WebAPI | Brokerage name: AMP. Account Name: 220033 2026-04-16 08:30:51.131 | Updated verified funded futures trading account ending date to: 2026-05-16 12:30:51 2026-04-16 08:30:51.131 | CQG WebAPI | Sending collateral subscribe request. 2026-04-16 08:30:51.131 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEV25. Search Symbol: F.US.CLEV25. Request ID: 431407. Contract ID: 2. 2026-04-16 08:30:51.132 | Mapping F.US.EPU25 to ESU25. Service code: cme 2026-04-16 08:30:51.132 | Denali Data Feed | Starting real-time market data updates for: F.US.EPU25 (ESU25). ID: 3 Service code: cme 2026-04-16 08:30:51.132 | CQG WebAPI | Sending symbol resolution request for F.US.EPU25. ID: 431409 2026-04-16 08:30:51.132 | Denali Data Feed | Requesting security definition data for: F.US.EPU25 (ESU25). ID: 3 2026-04-16 08:30:51.132 | Added historical Intraday data request for F.US.EPU25 to the queue. 2026-04-16 08:30:51.132 | Intraday data recording state for symbol F.US.EPU25 is set to download 'Pending'. 2026-04-16 08:30:51.132 | Triggering next historical data download in queue. 2026-04-16 08:30:51.144 | CQG WebAPI | Received symbol resolution report for symbol F.US.EPU25. Search Symbol: F.US.EPU25. Request ID: 431409. Contract ID: 3. 2026-04-16 08:30:51.188 | Denali Data Feed | Network connection to server complete. 2026-04-16 08:30:51.188 | Denali Data Feed | Starting socket receive thread. 2026-04-16 08:30:51.188 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard 2026-04-16 08:30:51.281 | DTC Client socket (3) | Socket gracefully closed by remote side. 2026-04-16 08:30:51.281 | DTC Client socket (3) | Closed. 2026-04-16 08:30:51.286 | CQG WebAPI | Sending positions subscribe request. RequestID: 431410 2026-04-16 08:30:51.286 | CQG WebAPI | Sending orders subscribe request. RequestID: 431411 2026-04-16 08:30:51.304 | Denali Data Feed | Setting DTC encoding to Binary VLS 2026-04-16 08:30:51.304 | Denali Data Feed | Sending logon request message. 2026-04-16 08:30:51.549 | Mapping F.US.EPH23 to ESH23. Service code: cme 2026-04-16 08:30:51.549 | Denali Data Feed | Starting real-time market data updates for: F.US.EPH23 (ESH23). ID: 4 Service code: cme 2026-04-16 08:30:51.549 | CQG WebAPI | Sending symbol resolution request for F.US.EPH23. ID: 431412 2026-04-16 08:30:51.549 | Denali Data Feed | Requesting security definition data for: F.US.EPH23 (ESH23). ID: 4 2026-04-16 08:30:51.549 | Mapping F.US.EPM23 to ESM23. Service code: cme 2026-04-16 08:30:51.550 | Denali Data Feed | Starting real-time market data updates for: F.US.EPM23 (ESM23). ID: 5 Service code: cme 2026-04-16 08:30:51.550 | CQG WebAPI | Sending symbol resolution request for F.US.EPM23. ID: 431413 2026-04-16 08:30:51.550 | Denali Data Feed | Requesting security definition data for: F.US.EPM23 (ESM23). ID: 5 2026-04-16 08:30:51.550 | Mapping F.US.EPU23 to ESU23. Service code: cme 2026-04-16 08:30:51.550 | Denali Data Feed | Starting real-time market data updates for: F.US.EPU23 (ESU23). ID: 6 Service code: cme 2026-04-16 08:30:51.550 | CQG WebAPI | Sending symbol resolution request for F.US.EPU23. ID: 431414 2026-04-16 08:30:51.550 | Denali Data Feed | Requesting security definition data for: F.US.EPU23 (ESU23). ID: 6 2026-04-16 08:30:51.550 | Mapping F.US.EPZ23 to ESZ23. Service code: cme 2026-04-16 08:30:51.550 | Denali Data Feed | Starting real-time market data updates for: F.US.EPZ23 (ESZ23). ID: 7 Service code: cme 2026-04-16 08:30:51.550 | CQG WebAPI | Sending symbol resolution request for F.US.EPZ23. ID: 431415 2026-04-16 08:30:51.550 | Denali Data Feed | Requesting security definition data for: F.US.EPZ23 (ESZ23). ID: 7 2026-04-16 08:30:51.550 | Mapping F.US.EPH24 to ESH24. Service code: cme 2026-04-16 08:30:51.550 | Denali Data Feed | Starting real-time market data updates for: F.US.EPH24 (ESH24). ID: 8 Service code: cme 2026-04-16 08:30:51.550 | CQG WebAPI | Sending symbol resolution request for F.US.EPH24. ID: 431416 2026-04-16 08:30:51.550 | Denali Data Feed | Requesting security definition data for: F.US.EPH24 (ESH24). ID: 8 2026-04-16 08:30:51.550 | Mapping F.US.CLEF23 to CLF23. Service code: nymex 2026-04-16 08:30:51.550 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEF23 (CLF23). ID: 9 Service code: nymex 2026-04-16 08:30:51.550 | CQG WebAPI | Sending symbol resolution request for F.US.CLEF23. ID: 431417 2026-04-16 08:30:51.550 | Denali Data Feed | Requesting security definition data for: F.US.CLEF23 (CLF23). ID: 9 2026-04-16 08:30:51.550 | Mapping F.US.CLEG23 to CLG23. Service code: nymex 2026-04-16 08:30:51.550 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEG23 (CLG23). ID: 10 Service code: nymex 2026-04-16 08:30:51.550 | CQG WebAPI | Sending symbol resolution request for F.US.CLEG23. ID: 431418 2026-04-16 08:30:51.550 | Denali Data Feed | Requesting security definition data for: F.US.CLEG23 (CLG23). ID: 10 2026-04-16 08:30:51.550 | Mapping F.US.CLEH23 to CLH23. Service code: nymex 2026-04-16 08:30:51.550 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEH23 (CLH23). ID: 11 Service code: nymex 2026-04-16 08:30:51.550 | CQG WebAPI | Sending symbol resolution request for F.US.CLEH23. ID: 431419 2026-04-16 08:30:51.550 | Denali Data Feed | Requesting security definition data for: F.US.CLEH23 (CLH23). ID: 11 2026-04-16 08:30:51.550 | Mapping F.US.CLEJ23 to CLJ23. Service code: nymex 2026-04-16 08:30:51.550 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEJ23 (CLJ23). ID: 12 Service code: nymex 2026-04-16 08:30:51.550 | CQG WebAPI | Sending symbol resolution request for F.US.CLEJ23. ID: 431420 2026-04-16 08:30:51.550 | Denali Data Feed | Requesting security definition data for: F.US.CLEJ23 (CLJ23). ID: 12 2026-04-16 08:30:51.550 | Mapping F.US.CLEK23 to CLK23. Service code: nymex 2026-04-16 08:30:51.550 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEK23 (CLK23). ID: 13 Service code: nymex 2026-04-16 08:30:51.550 | CQG WebAPI | Sending symbol resolution request for F.US.CLEK23. ID: 431421 2026-04-16 08:30:51.550 | Denali Data Feed | Requesting security definition data for: F.US.CLEK23 (CLK23). ID: 13 2026-04-16 08:30:51.551 | Mapping F.US.CLEM23 to CLM23. Service code: nymex 2026-04-16 08:30:51.551 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEM23 (CLM23). ID: 14 Service code: nymex 2026-04-16 08:30:51.551 | CQG WebAPI | Sending symbol resolution request for F.US.CLEM23. ID: 431422 2026-04-16 08:30:51.551 | Denali Data Feed | Requesting security definition data for: F.US.CLEM23 (CLM23). ID: 14 2026-04-16 08:30:51.551 | Mapping F.US.CLEN23 to CLN23. Service code: nymex 2026-04-16 08:30:51.551 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEN23 (CLN23). ID: 15 Service code: nymex 2026-04-16 08:30:51.551 | CQG WebAPI | Sending symbol resolution request for F.US.CLEN23. ID: 431423 2026-04-16 08:30:51.551 | Denali Data Feed | Requesting security definition data for: F.US.CLEN23 (CLN23). ID: 15 2026-04-16 08:30:51.551 | Mapping F.US.CLEQ23 to CLQ23. Service code: nymex 2026-04-16 08:30:51.551 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEQ23 (CLQ23). ID: 16 Service code: nymex 2026-04-16 08:30:51.551 | CQG WebAPI | Sending symbol resolution request for F.US.CLEQ23. ID: 431424 2026-04-16 08:30:51.551 | Denali Data Feed | Requesting security definition data for: F.US.CLEQ23 (CLQ23). ID: 16 2026-04-16 08:30:51.551 | Mapping F.US.CLEU23 to CLU23. Service code: nymex 2026-04-16 08:30:51.551 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEU23 (CLU23). ID: 17 Service code: nymex 2026-04-16 08:30:51.551 | CQG WebAPI | Sending symbol resolution request for F.US.CLEU23. ID: 431425 2026-04-16 08:30:51.551 | Denali Data Feed | Requesting security definition data for: F.US.CLEU23 (CLU23). ID: 17 2026-04-16 08:30:51.551 | Mapping F.US.CLEV23 to CLV23. Service code: nymex 2026-04-16 08:30:51.551 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEV23 (CLV23). ID: 18 Service code: nymex 2026-04-16 08:30:51.551 | CQG WebAPI | Sending symbol resolution request for F.US.CLEV23. ID: 431426 2026-04-16 08:30:51.551 | Denali Data Feed | Requesting security definition data for: F.US.CLEV23 (CLV23). ID: 18 2026-04-16 08:30:51.551 | Mapping F.US.CLEX23 to CLX23. Service code: nymex 2026-04-16 08:30:51.551 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEX23 (CLX23). ID: 19 Service code: nymex 2026-04-16 08:30:51.551 | CQG WebAPI | Sending symbol resolution request for F.US.CLEX23. ID: 431427 2026-04-16 08:30:51.551 | Denali Data Feed | Requesting security definition data for: F.US.CLEX23 (CLX23). ID: 19 2026-04-16 08:30:51.551 | Mapping F.US.CLEZ23 to CLZ23. Service code: nymex 2026-04-16 08:30:51.551 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEZ23 (CLZ23). ID: 20 Service code: nymex 2026-04-16 08:30:51.551 | CQG WebAPI | Sending symbol resolution request for F.US.CLEZ23. ID: 431428 2026-04-16 08:30:51.551 | Denali Data Feed | Requesting security definition data for: F.US.CLEZ23 (CLZ23). ID: 20 2026-04-16 08:30:51.551 | Mapping F.US.CLEF24 to CLF24. Service code: nymex 2026-04-16 08:30:51.551 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEF24 (CLF24). ID: 21 Service code: nymex 2026-04-16 08:30:51.551 | CQG WebAPI | Sending symbol resolution request for F.US.CLEF24. ID: 431429 2026-04-16 08:30:51.553 | Denali Data Feed | Requesting security definition data for: F.US.CLEF24 (CLF24). ID: 21 2026-04-16 08:30:51.553 | Mapping F.US.CLEG24 to CLG24. Service code: nymex 2026-04-16 08:30:51.554 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEG24 (CLG24). ID: 22 Service code: nymex 2026-04-16 08:30:51.554 | CQG WebAPI | Sending symbol resolution request for F.US.CLEG24. ID: 431430 2026-04-16 08:30:51.554 | Denali Data Feed | Requesting security definition data for: F.US.CLEG24 (CLG24). ID: 22 2026-04-16 08:30:51.561 | CQG WebAPI | Received symbol resolution report for symbol F.US.EPH23. Search Symbol: F.US.EPH23. Request ID: 431412. Contract ID: 4. 2026-04-16 08:30:51.562 | CQG WebAPI | Received symbol resolution report for symbol F.US.EPM23. Search Symbol: F.US.EPM23. Request ID: 431413. Contract ID: 5. 2026-04-16 08:30:51.562 | CQG WebAPI | Received symbol resolution report for symbol F.US.EPU23. Search Symbol: F.US.EPU23. Request ID: 431414. Contract ID: 6. 2026-04-16 08:30:51.566 | CQG WebAPI | Received symbol resolution report for symbol F.US.EPZ23. Search Symbol: F.US.EPZ23. Request ID: 431415. Contract ID: 7. 2026-04-16 08:30:51.566 | CQG WebAPI | Received symbol resolution report for symbol F.US.EPH24. Search Symbol: F.US.EPH24. Request ID: 431416. Contract ID: 8. 2026-04-16 08:30:51.566 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEF23. Search Symbol: F.US.CLEF23. Request ID: 431417. Contract ID: 9. 2026-04-16 08:30:51.566 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEG23. Search Symbol: F.US.CLEG23. Request ID: 431418. Contract ID: 10. 2026-04-16 08:30:51.566 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEH23. Search Symbol: F.US.CLEH23. Request ID: 431419. Contract ID: 11. 2026-04-16 08:30:51.566 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEJ23. Search Symbol: F.US.CLEJ23. Request ID: 431420. Contract ID: 12. 2026-04-16 08:30:51.566 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEK23. Search Symbol: F.US.CLEK23. Request ID: 431421. Contract ID: 13. 2026-04-16 08:30:51.566 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEM23. Search Symbol: F.US.CLEM23. Request ID: 431422. Contract ID: 14. 2026-04-16 08:30:51.566 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEN23. Search Symbol: F.US.CLEN23. Request ID: 431423. Contract ID: 15. 2026-04-16 08:30:51.566 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEQ23. Search Symbol: F.US.CLEQ23. Request ID: 431424. Contract ID: 16. 2026-04-16 08:30:51.567 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEU23. Search Symbol: F.US.CLEU23. Request ID: 431425. Contract ID: 17. 2026-04-16 08:30:51.570 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEV23. Search Symbol: F.US.CLEV23. Request ID: 431426. Contract ID: 18. 2026-04-16 08:30:51.570 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEX23. Search Symbol: F.US.CLEX23. Request ID: 431427. Contract ID: 19. 2026-04-16 08:30:51.570 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEZ23. Search Symbol: F.US.CLEZ23. Request ID: 431428. Contract ID: 20. 2026-04-16 08:30:51.570 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEF24. Search Symbol: F.US.CLEF24. Request ID: 431429. Contract ID: 21. 2026-04-16 08:30:51.570 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEG24. Search Symbol: F.US.CLEG24. Request ID: 431430. Contract ID: 22. 2026-04-16 08:30:51.836 | Denali Data Feed | Received logon response. 2026-04-16 08:30:51.836 | Denali Data Feed | Server Name: SC Realtime Server. 2026-04-16 08:30:51.836 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8 2026-04-16 08:30:51.836 | Denali Data Feed | Successfully connected. 2026-04-16 08:30:51.836 | Denali Data Feed | Trading is not supported. 2026-04-16 08:30:51.836 | Denali Data Feed | MarketDepthIsSupported: 1 2026-04-16 08:30:51.836 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEF23 -> CLF23 2026-04-16 08:30:51.836 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEF24 -> CLF24 2026-04-16 08:30:51.836 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEG23 -> CLG23 2026-04-16 08:30:51.836 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEG24 -> CLG24 2026-04-16 08:30:51.836 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEH23 -> CLH23 2026-04-16 08:30:51.836 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEJ23 -> CLJ23 2026-04-16 08:30:51.836 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEK23 -> CLK23 2026-04-16 08:30:51.836 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEM23 -> CLM23 2026-04-16 08:30:51.836 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEM26 -> CLM26 2026-04-16 08:30:51.836 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEN23 -> CLN23 2026-04-16 08:30:51.836 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEQ23 -> CLQ23 2026-04-16 08:30:51.836 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEU23 -> CLU23 2026-04-16 08:30:51.836 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEV23 -> CLV23 2026-04-16 08:30:51.836 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEV25 -> CLV25 2026-04-16 08:30:51.836 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEX23 -> CLX23 2026-04-16 08:30:51.836 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEZ23 -> CLZ23 2026-04-16 08:30:51.836 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.EPH23 -> ESH23 2026-04-16 08:30:51.836 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.EPH24 -> ESH24 2026-04-16 08:30:51.836 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.EPM23 -> ESM23 2026-04-16 08:30:51.836 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.EPU23 -> ESU23 2026-04-16 08:30:51.836 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.EPU25 -> ESU25 2026-04-16 08:30:51.836 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.EPZ23 -> ESZ23 2026-04-16 08:30:52.022 | Denali Data Feed | Real-time data for symbol F.US.CLEF23 is currently unavailable. 2026-04-16 08:30:52.022 | Denali Data Feed | Received security definition for symbol F.US.CLEF23 2026-04-16 08:30:52.022 | Denali Data Feed | Real-time data for symbol F.US.CLEF24 is currently unavailable. 2026-04-16 08:30:52.022 | Denali Data Feed | Received security definition for symbol F.US.CLEF24 2026-04-16 08:30:52.022 | Denali Data Feed | Real-time data for symbol F.US.CLEG23 is currently unavailable. 2026-04-16 08:30:52.022 | Denali Data Feed | Received security definition for symbol F.US.CLEG23 2026-04-16 08:30:52.022 | Denali Data Feed | Real-time data for symbol F.US.CLEG24 is currently unavailable. 2026-04-16 08:30:52.022 | Denali Data Feed | Received security definition for symbol F.US.CLEG24 2026-04-16 08:30:52.022 | Denali Data Feed | Real-time data for symbol F.US.CLEH23 is currently unavailable. 2026-04-16 08:30:52.022 | Denali Data Feed | Received security definition for symbol F.US.CLEH23 2026-04-16 08:30:52.022 | Denali Data Feed | Real-time data for symbol F.US.CLEJ23 is currently unavailable. 2026-04-16 08:30:52.022 | Denali Data Feed | Received security definition for symbol F.US.CLEJ23 2026-04-16 08:30:52.022 | Denali Data Feed | Real-time data for symbol F.US.CLEK23 is currently unavailable. 2026-04-16 08:30:52.022 | Denali Data Feed | Received security definition for symbol F.US.CLEK23 2026-04-16 08:30:52.022 | Denali Data Feed | Real-time data for symbol F.US.CLEM23 is currently unavailable. 2026-04-16 08:30:52.022 | Denali Data Feed | Received security definition for symbol F.US.CLEM23 2026-04-16 08:30:52.022 | Denali Data Feed | Setting external service identifier for symbol F.US.CLEM26 to 670557 2026-04-16 08:30:52.022 | Denali Data Feed | Received security definition for symbol F.US.CLEM26 2026-04-16 08:30:52.022 | Denali Data Feed | Real-time data for symbol F.US.CLEN23 is currently unavailable. 2026-04-16 08:30:52.022 | Denali Data Feed | Received security definition for symbol F.US.CLEN23 2026-04-16 08:30:52.022 | Denali Data Feed | Real-time data for symbol F.US.CLEQ23 is currently unavailable. 2026-04-16 08:30:52.022 | Denali Data Feed | Received security definition for symbol F.US.CLEQ23 2026-04-16 08:30:52.022 | Denali Data Feed | Real-time data for symbol F.US.CLEU23 is currently unavailable. 2026-04-16 08:30:52.022 | Denali Data Feed | Received security definition for symbol F.US.CLEU23 2026-04-16 08:30:52.022 | Denali Data Feed | Real-time data for symbol F.US.CLEV23 is currently unavailable. 2026-04-16 08:30:52.022 | Denali Data Feed | Received security definition for symbol F.US.CLEV23 2026-04-16 08:30:52.022 | Denali Data Feed | Real-time data for symbol F.US.CLEV25 is currently unavailable. 2026-04-16 08:30:52.022 | Denali Data Feed | Received security definition for symbol F.US.CLEV25 2026-04-16 08:30:52.022 | Denali Data Feed | Real-time data for symbol F.US.CLEX23 is currently unavailable. 2026-04-16 08:30:52.022 | Denali Data Feed | Received security definition for symbol F.US.CLEX23 2026-04-16 08:30:52.022 | Denali Data Feed | Real-time data for symbol F.US.CLEZ23 is currently unavailable. 2026-04-16 08:30:52.022 | Denali Data Feed | Received security definition for symbol F.US.CLEZ23 2026-04-16 08:30:52.022 | Denali Data Feed | Real-time data for symbol F.US.EPH23 is currently unavailable. 2026-04-16 08:30:52.022 | Denali Data Feed | Received security definition for symbol F.US.EPH23 2026-04-16 08:30:52.022 | Denali Data Feed | Real-time data for symbol F.US.EPH24 is currently unavailable. 2026-04-16 08:30:52.022 | Denali Data Feed | Received security definition for symbol F.US.EPH24 2026-04-16 08:30:52.022 | Denali Data Feed | Real-time data for symbol F.US.EPM23 is currently unavailable. 2026-04-16 08:30:52.022 | Denali Data Feed | Received security definition for symbol F.US.EPM23 2026-04-16 08:30:52.022 | Denali Data Feed | Real-time data for symbol F.US.EPU23 is currently unavailable. 2026-04-16 08:30:52.022 | Denali Data Feed | Received security definition for symbol F.US.EPU23 2026-04-16 08:30:52.022 | Denali Data Feed | Real-time data for symbol F.US.EPU25 is currently unavailable. 2026-04-16 08:30:52.022 | Denali Data Feed | Received security definition for symbol F.US.EPU25 2026-04-16 08:30:52.022 | Denali Data Feed | Real-time data for symbol F.US.EPZ23 is currently unavailable. 2026-04-16 08:30:52.022 | Denali Data Feed | Received security definition for symbol F.US.EPZ23 2026-04-16 08:30:56.038 | Requesting market depth updates for: F.US.CLEV25 if supported. NumLevels=100 2026-04-16 08:30:56.242 | Denali Data Feed | Clearing market depth for F.US.CLEV25 2026-04-16 08:30:57.142 | HD Request # 40 | Downloading Intraday chart data for F.US.CLEM26 to the file F.US.CLEM26.scid. Service: nymex 2026-04-16 08:30:57.143 | HD Request # 40 | Download start date-time: 2026-04-16 08:30:48.000000. File last date-time: 2026-04-16 08:30:48.768000 2026-04-16 08:30:57.143 | HD Request # 40 | Using server: ds32.sierracharts.com port 10149 2026-04-16 08:30:57.143 | Socket (3) | Creating socket. 2026-04-16 08:30:57.143 | Socket (3) | New receive buffer size: 0 2026-04-16 08:30:57.143 | Socket (3) | Connecting to IP: 69.39.70.248. 2026-04-16 08:30:57.336 | HD Request # 40 | Setting DTC encoding to Binary VLS 2026-04-16 08:30:57.336 | HD Request # 40 | Sending historical data logon request message. 2026-04-16 08:30:57.469 | HD Request # 40 | Requesting Intraday data. Start date-time: 2026-04-16 08:30:48. Record interval: 0. Symbol: CLM26 2026-04-16 08:30:57.563 | HD Request # 40 | Decompressing data. 2026-04-16 08:30:57.657 | HD Request # 40 | Receiving Intraday data for F.US.CLEM26 starting at 2026-04-16 08:30:48.574000 2026-04-16 08:30:57.657 | Socket (3) | CloseSocket call. 2026-04-16 08:30:57.657 | Socket (3) | Shutdown started. Waiting for graceful close. 2026-04-16 08:30:57.659 | Historical data download thread signaled to stop. 2026-04-16 08:30:57.659 | HD Request # 40 | Timestamp of first Intraday data file record written: 2026-04-16 08:30:50.318000. 2026-04-16 08:30:57.659 | HD Request # 40 | Received 4 Intraday data records from 2026-04-16 08:30:48.574000 to 2026-04-16 08:30:52.500000 (3.9 seconds. Delay: 5.2 seconds) and wrote 2 records for F.US.CLEM26 2026-04-16 08:30:57.666 | HD Request # 40 | Add time&sales data | Remembered last file record date-time: 2026-04-16 12:30:52.500000 2026-04-16 08:30:57.666 | Added 3 Time and Sales records to Intraday data file for F.US.CLEM26 after download. 2026-04-16 08:30:57.666 | HD Request # 40 | Completion time: 0s. 2026-04-16 08:30:57.666 | HD Request # 40 | Intraday data download complete for F.US.CLEM26. Unique request ID: 40 2026-04-16 08:30:57.666 | Removing historical data download ID 40. 2026-04-16 08:30:57.666 | Real-time Intraday chart data file updates started for F.US.CLEM26 2026-04-16 08:30:57.666 | Intraday chart data file opened for F.US.CLEM26 2026-04-16 08:30:57.666 | HD Request # 40 | Enabling Intraday chart updating for symbol. 2026-04-16 08:30:57.666 | 2026-04-16 08:30:57.666 | Triggering next historical data download in queue. 2026-04-16 08:30:57.666 | HD Request # 41 | Downloading Intraday chart data for F.US.CLEV25 to the file F.US.CLEV25.scid. Service: nymex 2026-04-16 08:30:57.666 | HD Request # 41 | Download start date-time: 2025-09-22 14:29:55.000000. File last date-time: 2025-09-22 14:29:55.618000 2026-04-16 08:30:57.666 | HD Request # 41 | Using server: ds26.sierracharts.com port 10150 2026-04-16 08:30:57.666 | Socket (4) | Creating socket. 2026-04-16 08:30:57.666 | Socket (4) | New receive buffer size: 0 2026-04-16 08:30:57.666 | Socket (4) | Connecting to IP: 64.152.155.17. 2026-04-16 08:30:57.751 | Socket (3) | Socket gracefully closed by remote side. 2026-04-16 08:30:57.751 | Socket (3) | Closed. 2026-04-16 08:30:57.988 | HD Request # 41 | Setting DTC encoding to Binary VLS 2026-04-16 08:30:57.988 | HD Request # 41 | Sending historical data logon request message. 2026-04-16 08:30:58.175 | HD Request # 41 | Requesting Intraday data. Start date-time: 2025-09-22 14:29:55. Record interval: 0. Symbol: CLV25 2026-04-16 08:30:58.334 | HD Request # 41 | Decompressing data. 2026-04-16 08:30:58.493 | HD Request # 41 | Receiving Intraday data for F.US.CLEV25 starting at 2025-09-22 14:29:55.086000 2026-04-16 08:30:58.493 | Socket (4) | CloseSocket call. 2026-04-16 08:30:58.493 | Socket (4) | Shutdown started. Waiting for graceful close. 2026-04-16 08:30:58.497 | Historical data download thread signaled to stop. 2026-04-16 08:30:58.497 | HD Request # 41 | Received 2 Intraday data records from 2025-09-22 14:29:55.086000 to 2025-09-22 14:29:55.618000 (0.5 seconds. Delay: 205.8 days) and wrote 0 records for F.US.CLEV25 2026-04-16 08:30:58.498 | HD Request # 41 | Add time&sales data | Remembered last file record date-time: 2025-09-22 18:29:55.618000 2026-04-16 08:30:58.498 | HD Request # 41 | Completion time: 1s. 2026-04-16 08:30:58.498 | HD Request # 41 | Intraday data download complete for F.US.CLEV25. Unique request ID: 41 2026-04-16 08:30:58.498 | Removing historical data download ID 41. 2026-04-16 08:30:58.498 | Real-time Intraday chart data file updates started for F.US.CLEV25 2026-04-16 08:30:58.498 | Intraday chart data file opened for F.US.CLEV25 2026-04-16 08:30:58.498 | HD Request # 41 | Enabling Intraday chart updating for symbol. 2026-04-16 08:30:58.498 | 2026-04-16 08:30:58.498 | Triggering next historical data download in queue. 2026-04-16 08:30:58.498 | HD Request # 42 | Downloading Intraday chart data for F.US.EPU25 to the file F.US.EPU25.scid. Service: cme 2026-04-16 08:30:58.498 | HD Request # 42 | Download start date-time: 2025-09-19 09:29:58.000000. File last date-time: 2025-09-19 09:29:58.698000 2026-04-16 08:30:58.498 | HD Request # 42 | Using server: ds28.sierracharts.com port 10149 2026-04-16 08:30:58.498 | Socket (3) | Creating socket. 2026-04-16 08:30:58.498 | Socket (3) | New receive buffer size: 0 2026-04-16 08:30:58.498 | Socket (3) | Connecting to IP: 67.214.125.5. 2026-04-16 08:30:58.651 | Socket (4) | Socket gracefully closed by remote side. 2026-04-16 08:30:58.651 | Socket (4) | Closed. 2026-04-16 08:30:58.689 | HD Request # 42 | Setting DTC encoding to Binary VLS 2026-04-16 08:30:58.689 | HD Request # 42 | Sending historical data logon request message. 2026-04-16 08:30:58.815 | HD Request # 42 | Requesting Intraday data. Start date-time: 2025-09-19 09:29:58. Record interval: 0. Symbol: ESU25 2026-04-16 08:30:58.909 | HD Request # 42 | Decompressing data. 2026-04-16 08:30:59.003 | HD Request # 42 | Receiving Intraday data for F.US.EPU25 starting at 2025-09-19 09:29:58.697000 2026-04-16 08:30:59.003 | Socket (3) | CloseSocket call. 2026-04-16 08:30:59.003 | Socket (3) | Shutdown started. Waiting for graceful close. 2026-04-16 08:30:59.004 | Historical data download thread signaled to stop. 2026-04-16 08:30:59.004 | HD Request # 42 | Received 5 Intraday data records from 2025-09-19 09:29:58.697000 to 2025-09-19 09:29:58.698000 (0.0 seconds. Delay: 209.0 days) and wrote 0 records for F.US.EPU25 2026-04-16 08:30:59.005 | HD Request # 42 | Add time&sales data | Remembered last file record date-time: 2025-09-19 13:29:58.698000 2026-04-16 08:30:59.005 | HD Request # 42 | Completion time: 1s. 2026-04-16 08:30:59.005 | HD Request # 42 | Intraday data download complete for F.US.EPU25. Unique request ID: 42 2026-04-16 08:30:59.005 | Removing historical data download ID 42. 2026-04-16 08:30:59.005 | Real-time Intraday chart data file updates started for F.US.EPU25 2026-04-16 08:30:59.005 | Intraday chart data file opened for F.US.EPU25 2026-04-16 08:30:59.005 | HD Request # 42 | Enabling Intraday chart updating for symbol. 2026-04-16 08:30:59.005 | 2026-04-16 08:30:59.005 | No download requests in the queue to start downloads for. 2026-04-16 08:30:59.097 | Socket (3) | Socket gracefully closed by remote side. 2026-04-16 08:30:59.097 | Socket (3) | Closed. 2026-04-16 08:31:00.591 | CQG WebAPI | Received LoggedOff message. Reason: Your session was closed due to a concurrent session. 2026-04-16 08:31:00.591 | Connection to the external service has been lost. 2026-04-16 08:31:00.627 | CQG WebAPI | Sending Web API Logoff message. 2026-04-16 08:31:00.627 | CQG WebSocket socket (1) | CloseSocket call. 2026-04-16 08:31:00.627 | CQG WebSocket socket (1) | Max send buffers used during socket life: 3 2026-04-16 08:31:00.627 | CQG WebSocket socket (1) | Max send buffer size during socket life: 595 2026-04-16 08:31:00.627 | CQG WebSocket | WebSocket closed. 2026-04-16 08:31:00.627 | CQG WebAPI | WebSocket closed. 2026-04-16 08:31:00.627 | CQG WebSocket socket (1) | Write in progress. Shutdown being delayed. PendingSize=0 2026-04-16 08:31:00.627 | Opened cached Intraday file: C:\SierraChart\Data\F.US.CLEM26.scid. Thread ID: 11208 2026-04-16 08:31:00.627 | CQG WebAPI | Disconnected. 2026-04-16 08:31:00.627 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-04-16 08:31:00.631 | CQG WebSocket socket (1) | Write has completed. Shutdown being performed. 2026-04-16 08:31:00.631 | CQG WebSocket socket (1) | Shutdown started. Waiting for graceful close. 2026-04-16 08:31:00.636 | CQG WebSocket socket (1) | Socket gracefully closed by remote side. 2026-04-16 08:31:00.636 | CQG WebSocket socket (1) | Closed. 2026-04-16 08:31:02.625 | 2026-04-16 08:31:02.625 | CQG WebAPI | Connecting to server api.cqg.com 2026-04-16 08:31:02.625 | CQG WebSocket | Connecting to WebSocket server api.cqg.com:443 2026-04-16 08:31:02.627 | CQG WebSocket socket (1) | Creating socket. Using TLS 1.2. 2026-04-16 08:31:02.627 | CQG WebSocket socket (1) | New receive buffer size: 0 2026-04-16 08:31:02.627 | CQG WebSocket socket (1) | Connecting to IP: 195.166.124.175. 2026-04-16 08:31:02.632 | CQG WebSocket | Opening WebSocket. 2026-04-16 08:31:02.632 | CQG WebSocket | Sending WebSocket handshake. 2026-04-16 08:31:02.649 | CQG WebSocket | Server header | HTTP/1.1 101 Switching Protocols 2026-04-16 08:31:02.649 | CQG WebSocket | Server header | Connection: Upgrade 2026-04-16 08:31:02.649 | CQG WebSocket | Server header | Sec-WebSocket-Accept: sAFrydRJ40REtXBAK6hfpuvgigg= 2026-04-16 08:31:02.649 | CQG WebSocket | Server header | Server: WebSocket++/0.8.2 2026-04-16 08:31:02.649 | CQG WebSocket | Server header | Upgrade: websocket 2026-04-16 08:31:02.649 | CQG WebSocket | Server header | 2026-04-16 08:31:02.649 | CQG WebSocket | Web socket state is now open. 2026-04-16 08:31:02.649 | CQG WebAPI | WebSocket connected. 2026-04-16 08:31:02.649 | CQG WebAPI | Sending market data logon message. 2026-04-16 08:31:02.909 | CQG WebAPI | Base Time: 2026-03-28T06:33:36. 2026-03-28 06:33:36 2026-04-16 08:31:02.909 | CQG WebAPI | Logon successful. Session Token = qaTz1ym+1/6snjgHPcGdecnT/SO8UPXN5PH3sKvOE6cEUZ7AmIzjEyG8lk1AuyeJGnBEHCZwUOt 2026-04-16 08:31:02.909 | CQG WebAPI | Connection to server complete. 2026-04-16 08:31:02.909 | Denali Data Feed | Waiting for socket receive thread to end 2026-04-16 08:31:02.910 | DTC Client socket (2) | CloseSocket call. 2026-04-16 08:31:02.910 | Denali Data Feed | Disconnected from the server. 2026-04-16 08:31:02.910 | DTC Client socket (2) | Shutdown started. Waiting for graceful close. 2026-04-16 08:31:02.911 | No download requests in the queue to start downloads for. | Number times message added: 3 2026-04-16 08:31:02.911 | Updated verified funded futures trading account ending date to: 2026-05-16 12:31:02 2026-04-16 08:31:02.928 | CQG WebAPI | Sending Trade Accounts request message. 2026-04-16 08:31:02.928 | Mapping F.US.EPH23 to ESH23. Service code: cme 2026-04-16 08:31:02.928 | Using symbol data fast lookup vector 2026-04-16 08:31:02.928 | Denali Data Feed | Starting real-time market data updates for: F.US.EPH23 (ESH23). ID: 1 Service code: cme 2026-04-16 08:31:02.928 | Denali Data Feed | Connecting to the server ds32.sierracharts.com. Port 443 2026-04-16 08:31:02.928 | CQG WebAPI | Sending symbol resolution request for F.US.EPH23. ID: 431432 2026-04-16 08:31:02.928 | Denali Data Feed | Requesting security definition data for: F.US.EPH23 (ESH23). ID: 1 2026-04-16 08:31:02.928 | Mapping F.US.EPM23 to ESM23. Service code: cme 2026-04-16 08:31:02.928 | Denali Data Feed | Starting real-time market data updates for: F.US.EPM23 (ESM23). ID: 2 Service code: cme 2026-04-16 08:31:02.928 | CQG WebAPI | Sending symbol resolution request for F.US.EPM23. ID: 431433 2026-04-16 08:31:02.928 | Denali Data Feed | Requesting security definition data for: F.US.EPM23 (ESM23). ID: 2 2026-04-16 08:31:02.928 | Mapping F.US.EPU23 to ESU23. Service code: cme 2026-04-16 08:31:02.928 | Denali Data Feed | Starting real-time market data updates for: F.US.EPU23 (ESU23). ID: 3 Service code: cme 2026-04-16 08:31:02.928 | CQG WebAPI | Sending symbol resolution request for F.US.EPU23. ID: 431434 2026-04-16 08:31:02.928 | Denali Data Feed | Requesting security definition data for: F.US.EPU23 (ESU23). ID: 3 2026-04-16 08:31:02.928 | Mapping F.US.EPZ23 to ESZ23. Service code: cme 2026-04-16 08:31:02.929 | Denali Data Feed | Starting real-time market data updates for: F.US.EPZ23 (ESZ23). ID: 4 Service code: cme 2026-04-16 08:31:02.929 | CQG WebAPI | Sending symbol resolution request for F.US.EPZ23. ID: 431435 2026-04-16 08:31:02.929 | Denali Data Feed | Requesting security definition data for: F.US.EPZ23 (ESZ23). ID: 4 2026-04-16 08:31:02.929 | Mapping F.US.EPH24 to ESH24. Service code: cme 2026-04-16 08:31:02.929 | Denali Data Feed | Starting real-time market data updates for: F.US.EPH24 (ESH24). ID: 5 Service code: cme 2026-04-16 08:31:02.929 | CQG WebAPI | Sending symbol resolution request for F.US.EPH24. ID: 431436 2026-04-16 08:31:02.929 | Denali Data Feed | Requesting security definition data for: F.US.EPH24 (ESH24). ID: 5 2026-04-16 08:31:02.929 | Mapping F.US.CLEF23 to CLF23. Service code: nymex 2026-04-16 08:31:02.929 | DTC Client socket (3) | Creating socket. 2026-04-16 08:31:02.929 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEF23 (CLF23). ID: 6 Service code: nymex 2026-04-16 08:31:02.929 | CQG WebAPI | Sending symbol resolution request for F.US.CLEF23. ID: 431437 2026-04-16 08:31:02.929 | Denali Data Feed | Requesting security definition data for: F.US.CLEF23 (CLF23). ID: 6 2026-04-16 08:31:02.929 | DTC Client socket (3) | New receive buffer size: 0 2026-04-16 08:31:02.929 | Mapping F.US.CLEG23 to CLG23. Service code: nymex 2026-04-16 08:31:02.929 | DTC Client socket (3) | Connecting to IP: 69.39.70.248. 2026-04-16 08:31:02.929 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEG23 (CLG23). ID: 7 Service code: nymex 2026-04-16 08:31:02.929 | CQG WebAPI | Sending symbol resolution request for F.US.CLEG23. ID: 431438 2026-04-16 08:31:02.929 | Denali Data Feed | Requesting security definition data for: F.US.CLEG23 (CLG23). ID: 7 2026-04-16 08:31:02.929 | Mapping F.US.CLEH23 to CLH23. Service code: nymex 2026-04-16 08:31:02.929 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEH23 (CLH23). ID: 8 Service code: nymex 2026-04-16 08:31:02.929 | CQG WebAPI | Sending symbol resolution request for F.US.CLEH23. ID: 431439 2026-04-16 08:31:02.929 | Denali Data Feed | Requesting security definition data for: F.US.CLEH23 (CLH23). ID: 8 2026-04-16 08:31:02.929 | Mapping F.US.CLEJ23 to CLJ23. Service code: nymex 2026-04-16 08:31:02.929 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEJ23 (CLJ23). ID: 9 Service code: nymex 2026-04-16 08:31:02.929 | CQG WebAPI | Sending symbol resolution request for F.US.CLEJ23. ID: 431440 2026-04-16 08:31:02.929 | Denali Data Feed | Requesting security definition data for: F.US.CLEJ23 (CLJ23). ID: 9 2026-04-16 08:31:02.929 | Mapping F.US.CLEK23 to CLK23. Service code: nymex 2026-04-16 08:31:02.929 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEK23 (CLK23). ID: 10 Service code: nymex 2026-04-16 08:31:02.929 | CQG WebAPI | Sending symbol resolution request for F.US.CLEK23. ID: 431441 2026-04-16 08:31:02.929 | Denali Data Feed | Requesting security definition data for: F.US.CLEK23 (CLK23). ID: 10 2026-04-16 08:31:02.929 | Mapping F.US.CLEM23 to CLM23. Service code: nymex 2026-04-16 08:31:02.929 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEM23 (CLM23). ID: 11 Service code: nymex 2026-04-16 08:31:02.929 | CQG WebAPI | Sending symbol resolution request for F.US.CLEM23. ID: 431442 2026-04-16 08:31:02.929 | Denali Data Feed | Requesting security definition data for: F.US.CLEM23 (CLM23). ID: 11 2026-04-16 08:31:02.929 | Mapping F.US.CLEN23 to CLN23. Service code: nymex 2026-04-16 08:31:02.930 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEN23 (CLN23). ID: 12 Service code: nymex 2026-04-16 08:31:02.930 | CQG WebAPI | Sending symbol resolution request for F.US.CLEN23. ID: 431443 2026-04-16 08:31:02.930 | Denali Data Feed | Requesting security definition data for: F.US.CLEN23 (CLN23). ID: 12 2026-04-16 08:31:02.930 | Mapping F.US.CLEQ23 to CLQ23. Service code: nymex 2026-04-16 08:31:02.930 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEQ23 (CLQ23). ID: 13 Service code: nymex 2026-04-16 08:31:02.930 | CQG WebAPI | Sending symbol resolution request for F.US.CLEQ23. ID: 431444 2026-04-16 08:31:02.930 | Denali Data Feed | Requesting security definition data for: F.US.CLEQ23 (CLQ23). ID: 13 2026-04-16 08:31:02.930 | Mapping F.US.CLEU23 to CLU23. Service code: nymex 2026-04-16 08:31:02.930 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEU23 (CLU23). ID: 14 Service code: nymex 2026-04-16 08:31:02.930 | CQG WebAPI | Sending symbol resolution request for F.US.CLEU23. ID: 431445 2026-04-16 08:31:02.930 | Denali Data Feed | Requesting security definition data for: F.US.CLEU23 (CLU23). ID: 14 2026-04-16 08:31:02.930 | Mapping F.US.CLEV23 to CLV23. Service code: nymex 2026-04-16 08:31:02.930 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEV23 (CLV23). ID: 15 Service code: nymex 2026-04-16 08:31:02.930 | CQG WebAPI | Sending symbol resolution request for F.US.CLEV23. ID: 431446 2026-04-16 08:31:02.930 | Denali Data Feed | Requesting security definition data for: F.US.CLEV23 (CLV23). ID: 15 2026-04-16 08:31:02.930 | Mapping F.US.CLEX23 to CLX23. Service code: nymex 2026-04-16 08:31:02.930 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEX23 (CLX23). ID: 16 Service code: nymex 2026-04-16 08:31:02.930 | CQG WebAPI | Sending symbol resolution request for F.US.CLEX23. ID: 431447 2026-04-16 08:31:02.930 | Denali Data Feed | Requesting security definition data for: F.US.CLEX23 (CLX23). ID: 16 2026-04-16 08:31:02.930 | Mapping F.US.CLEZ23 to CLZ23. Service code: nymex 2026-04-16 08:31:02.930 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEZ23 (CLZ23). ID: 17 Service code: nymex 2026-04-16 08:31:02.930 | CQG WebAPI | Sending symbol resolution request for F.US.CLEZ23. ID: 431448 2026-04-16 08:31:02.930 | Denali Data Feed | Requesting security definition data for: F.US.CLEZ23 (CLZ23). ID: 17 2026-04-16 08:31:02.930 | Mapping F.US.CLEF24 to CLF24. Service code: nymex 2026-04-16 08:31:02.930 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEF24 (CLF24). ID: 18 Service code: nymex 2026-04-16 08:31:02.930 | CQG WebAPI | Sending symbol resolution request for F.US.CLEF24. ID: 431449 2026-04-16 08:31:02.930 | Denali Data Feed | Requesting security definition data for: F.US.CLEF24 (CLF24). ID: 18 2026-04-16 08:31:02.930 | Mapping F.US.CLEG24 to CLG24. Service code: nymex 2026-04-16 08:31:02.930 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEG24 (CLG24). ID: 19 Service code: nymex 2026-04-16 08:31:02.930 | CQG WebAPI | Sending symbol resolution request for F.US.CLEG24. ID: 431450 2026-04-16 08:31:02.930 | Denali Data Feed | Requesting security definition data for: F.US.CLEG24 (CLG24). ID: 19 2026-04-16 08:31:02.932 | Mapping F.US.CLEV25 to CLV25. Service code: nymex 2026-04-16 08:31:02.932 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEV25 (CLV25). ID: 20 Service code: nymex 2026-04-16 08:31:02.932 | CQG WebAPI | Sending symbol resolution request for F.US.CLEV25. ID: 431451 2026-04-16 08:31:02.932 | Denali Data Feed | Requesting security definition data for: F.US.CLEV25 (CLV25). ID: 20 2026-04-16 08:31:02.932 | Added historical Intraday data request for F.US.CLEV25 to the queue. 2026-04-16 08:31:02.932 | Intraday data recording state for symbol F.US.CLEV25 is set to download 'Pending'. 2026-04-16 08:31:02.932 | Triggering next historical data download in queue. 2026-04-16 08:31:02.933 | Delaying start of download for F.US.CLEV25. 2026-04-16 08:31:02.941 | Mapping F.US.EPU25 to ESU25. Service code: cme 2026-04-16 08:31:02.941 | Denali Data Feed | Starting real-time market data updates for: F.US.EPU25 (ESU25). ID: 21 Service code: cme 2026-04-16 08:31:02.941 | CQG WebAPI | Sending symbol resolution request for F.US.EPU25. ID: 431452 2026-04-16 08:31:02.941 | Denali Data Feed | Requesting security definition data for: F.US.EPU25 (ESU25). ID: 21 2026-04-16 08:31:02.941 | Added historical Intraday data request for F.US.EPU25 to the queue. 2026-04-16 08:31:02.941 | Intraday data recording state for symbol F.US.EPU25 is set to download 'Pending'. 2026-04-16 08:31:02.941 | Triggering next historical data download in queue. 2026-04-16 08:31:02.985 | CQG WebAPI | Received symbol resolution report for symbol F.US.EPH23. Search Symbol: F.US.EPH23. Request ID: 431432. Contract ID: 1. 2026-04-16 08:31:02.985 | CQG WebAPI | Brokerage name: AMP. Account Name: 220033 2026-04-16 08:31:02.985 | Updated verified funded futures trading account ending date to: 2026-05-16 12:31:02 2026-04-16 08:31:02.985 | CQG WebAPI | Sending collateral subscribe request. 2026-04-16 08:31:02.985 | CQG WebAPI | Received symbol resolution report for symbol F.US.EPM23. Search Symbol: F.US.EPM23. Request ID: 431433. Contract ID: 2. 2026-04-16 08:31:02.989 | CQG WebAPI | Received symbol resolution report for symbol F.US.EPU23. Search Symbol: F.US.EPU23. Request ID: 431434. Contract ID: 3. 2026-04-16 08:31:02.989 | CQG WebAPI | Received symbol resolution report for symbol F.US.EPZ23. Search Symbol: F.US.EPZ23. Request ID: 431435. Contract ID: 4. 2026-04-16 08:31:02.989 | CQG WebAPI | Received symbol resolution report for symbol F.US.EPH24. Search Symbol: F.US.EPH24. Request ID: 431436. Contract ID: 5. 2026-04-16 08:31:02.990 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEF23. Search Symbol: F.US.CLEF23. Request ID: 431437. Contract ID: 6. 2026-04-16 08:31:02.990 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEG23. Search Symbol: F.US.CLEG23. Request ID: 431438. Contract ID: 7. 2026-04-16 08:31:02.990 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEH23. Search Symbol: F.US.CLEH23. Request ID: 431439. Contract ID: 8. 2026-04-16 08:31:02.990 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEJ23. Search Symbol: F.US.CLEJ23. Request ID: 431440. Contract ID: 9. 2026-04-16 08:31:02.990 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEK23. Search Symbol: F.US.CLEK23. Request ID: 431441. Contract ID: 10. 2026-04-16 08:31:02.990 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEM23. Search Symbol: F.US.CLEM23. Request ID: 431442. Contract ID: 11. 2026-04-16 08:31:02.993 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEN23. Search Symbol: F.US.CLEN23. Request ID: 431443. Contract ID: 12. 2026-04-16 08:31:02.993 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEQ23. Search Symbol: F.US.CLEQ23. Request ID: 431444. Contract ID: 13. 2026-04-16 08:31:02.993 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEU23. Search Symbol: F.US.CLEU23. Request ID: 431445. Contract ID: 14. 2026-04-16 08:31:02.993 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEV23. Search Symbol: F.US.CLEV23. Request ID: 431446. Contract ID: 15. 2026-04-16 08:31:02.993 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEX23. Search Symbol: F.US.CLEX23. Request ID: 431447. Contract ID: 16. 2026-04-16 08:31:02.993 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEZ23. Search Symbol: F.US.CLEZ23. Request ID: 431448. Contract ID: 17. 2026-04-16 08:31:02.993 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEF24. Search Symbol: F.US.CLEF24. Request ID: 431449. Contract ID: 18. 2026-04-16 08:31:02.993 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEG24. Search Symbol: F.US.CLEG24. Request ID: 431450. Contract ID: 19. 2026-04-16 08:31:02.994 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEV25. Search Symbol: F.US.CLEV25. Request ID: 431451. Contract ID: 20. 2026-04-16 08:31:02.994 | CQG WebAPI | Received symbol resolution report for symbol F.US.EPU25. Search Symbol: F.US.EPU25. Request ID: 431452. Contract ID: 21. 2026-04-16 08:31:03.003 | DTC Client socket (2) | Socket gracefully closed by remote side. 2026-04-16 08:31:03.003 | DTC Client socket (2) | Closed. 2026-04-16 08:31:03.022 | Denali Data Feed | Network connection to server complete. 2026-04-16 08:31:03.022 | Denali Data Feed | Starting socket receive thread. 2026-04-16 08:31:03.022 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard 2026-04-16 08:31:03.147 | Denali Data Feed | Setting DTC encoding to Binary VLS 2026-04-16 08:31:03.147 | Denali Data Feed | Sending logon request message. 2026-04-16 08:31:03.158 | CQG WebAPI | Sending positions subscribe request. RequestID: 431454 2026-04-16 08:31:03.158 | CQG WebAPI | Sending orders subscribe request. RequestID: 431455 2026-04-16 08:31:03.192 | Mapping F.US.CLEM26 to CLM26. Service code: nymex 2026-04-16 08:31:03.192 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEM26 (CLM26). ID: 22 Service code: nymex 2026-04-16 08:31:03.192 | CQG WebAPI | Sending symbol resolution request for F.US.CLEM26. ID: 431456 2026-04-16 08:31:03.192 | Denali Data Feed | Requesting security definition data for: F.US.CLEM26 (CLM26). ID: 22 2026-04-16 08:31:03.193 | Added historical Intraday data request for F.US.CLEM26 to the queue. 2026-04-16 08:31:03.193 | Intraday data recording state for symbol F.US.CLEM26 is set to download 'Pending'. 2026-04-16 08:31:03.193 | Triggering next historical data download in queue. 2026-04-16 08:31:03.214 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEM26. Search Symbol: F.US.CLEM26. Request ID: 431456. Contract ID: 22. 2026-04-16 08:31:03.742 | Denali Data Feed | Received logon response. 2026-04-16 08:31:03.742 | Denali Data Feed | Server Name: SC Realtime Server. 2026-04-16 08:31:03.742 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8 2026-04-16 08:31:03.742 | Denali Data Feed | Successfully connected. 2026-04-16 08:31:03.742 | Denali Data Feed | Trading is not supported. 2026-04-16 08:31:03.742 | Denali Data Feed | MarketDepthIsSupported: 1 2026-04-16 08:31:03.742 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEF23 -> CLF23 2026-04-16 08:31:03.742 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEF24 -> CLF24 2026-04-16 08:31:03.742 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEG23 -> CLG23 2026-04-16 08:31:03.742 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEG24 -> CLG24 2026-04-16 08:31:03.742 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEH23 -> CLH23 2026-04-16 08:31:03.742 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEJ23 -> CLJ23 2026-04-16 08:31:03.742 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEK23 -> CLK23 2026-04-16 08:31:03.742 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEM23 -> CLM23 2026-04-16 08:31:03.742 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEM26 -> CLM26 2026-04-16 08:31:03.742 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEN23 -> CLN23 2026-04-16 08:31:03.742 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEQ23 -> CLQ23 2026-04-16 08:31:03.742 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEU23 -> CLU23 2026-04-16 08:31:03.742 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEV23 -> CLV23 2026-04-16 08:31:03.742 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEV25 -> CLV25 2026-04-16 08:31:03.742 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEX23 -> CLX23 2026-04-16 08:31:03.742 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEZ23 -> CLZ23 2026-04-16 08:31:03.742 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.EPH23 -> ESH23 2026-04-16 08:31:03.742 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.EPH24 -> ESH24 2026-04-16 08:31:03.742 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.EPM23 -> ESM23 2026-04-16 08:31:03.742 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.EPU23 -> ESU23 2026-04-16 08:31:03.742 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.EPU25 -> ESU25 2026-04-16 08:31:03.742 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.EPZ23 -> ESZ23 2026-04-16 08:31:03.927 | Denali Data Feed | Real-time data for symbol F.US.CLEF23 is currently unavailable. 2026-04-16 08:31:03.927 | Denali Data Feed | Received security definition for symbol F.US.CLEF23 2026-04-16 08:31:03.927 | Denali Data Feed | Real-time data for symbol F.US.CLEF24 is currently unavailable. 2026-04-16 08:31:03.927 | Denali Data Feed | Received security definition for symbol F.US.CLEF24 2026-04-16 08:31:03.927 | Denali Data Feed | Real-time data for symbol F.US.CLEG23 is currently unavailable. 2026-04-16 08:31:03.927 | Denali Data Feed | Received security definition for symbol F.US.CLEG23 2026-04-16 08:31:03.927 | Denali Data Feed | Real-time data for symbol F.US.CLEG24 is currently unavailable. 2026-04-16 08:31:03.927 | Denali Data Feed | Received security definition for symbol F.US.CLEG24 2026-04-16 08:31:03.927 | Denali Data Feed | Real-time data for symbol F.US.CLEH23 is currently unavailable. 2026-04-16 08:31:03.927 | Denali Data Feed | Received security definition for symbol F.US.CLEH23 2026-04-16 08:31:03.927 | Denali Data Feed | Real-time data for symbol F.US.CLEJ23 is currently unavailable. 2026-04-16 08:31:03.927 | Denali Data Feed | Received security definition for symbol F.US.CLEJ23 2026-04-16 08:31:03.927 | Denali Data Feed | Real-time data for symbol F.US.CLEK23 is currently unavailable. 2026-04-16 08:31:03.927 | Denali Data Feed | Received security definition for symbol F.US.CLEK23 2026-04-16 08:31:03.927 | Denali Data Feed | Real-time data for symbol F.US.CLEM23 is currently unavailable. 2026-04-16 08:31:03.927 | Denali Data Feed | Received security definition for symbol F.US.CLEM23 2026-04-16 08:31:03.927 | Denali Data Feed | Setting external service identifier for symbol F.US.CLEM26 to 670557 2026-04-16 08:31:03.927 | Denali Data Feed | Received security definition for symbol F.US.CLEM26 2026-04-16 08:31:03.927 | Denali Data Feed | Real-time data for symbol F.US.CLEN23 is currently unavailable. 2026-04-16 08:31:03.927 | Denali Data Feed | Received security definition for symbol F.US.CLEN23 2026-04-16 08:31:03.927 | Denali Data Feed | Real-time data for symbol F.US.CLEQ23 is currently unavailable. 2026-04-16 08:31:03.927 | Denali Data Feed | Received security definition for symbol F.US.CLEQ23 2026-04-16 08:31:03.927 | Denali Data Feed | Real-time data for symbol F.US.CLEU23 is currently unavailable. 2026-04-16 08:31:03.927 | Denali Data Feed | Received security definition for symbol F.US.CLEU23 2026-04-16 08:31:03.927 | Denali Data Feed | Real-time data for symbol F.US.CLEV23 is currently unavailable. 2026-04-16 08:31:03.927 | Denali Data Feed | Received security definition for symbol F.US.CLEV23 2026-04-16 08:31:03.927 | Denali Data Feed | Real-time data for symbol F.US.CLEV25 is currently unavailable. 2026-04-16 08:31:03.927 | Denali Data Feed | Received security definition for symbol F.US.CLEV25 2026-04-16 08:31:03.927 | Denali Data Feed | Real-time data for symbol F.US.CLEX23 is currently unavailable. 2026-04-16 08:31:03.927 | Denali Data Feed | Received security definition for symbol F.US.CLEX23 2026-04-16 08:31:03.927 | Denali Data Feed | Real-time data for symbol F.US.CLEZ23 is currently unavailable. 2026-04-16 08:31:03.927 | Denali Data Feed | Received security definition for symbol F.US.CLEZ23 2026-04-16 08:31:03.927 | Denali Data Feed | Real-time data for symbol F.US.EPH23 is currently unavailable. 2026-04-16 08:31:03.927 | Denali Data Feed | Received security definition for symbol F.US.EPH23 2026-04-16 08:31:03.927 | Denali Data Feed | Real-time data for symbol F.US.EPH24 is currently unavailable. 2026-04-16 08:31:03.927 | Denali Data Feed | Received security definition for symbol F.US.EPH24 2026-04-16 08:31:03.927 | Denali Data Feed | Real-time data for symbol F.US.EPM23 is currently unavailable. 2026-04-16 08:31:03.927 | Denali Data Feed | Received security definition for symbol F.US.EPM23 2026-04-16 08:31:03.927 | Denali Data Feed | Real-time data for symbol F.US.EPU23 is currently unavailable. 2026-04-16 08:31:03.927 | Denali Data Feed | Received security definition for symbol F.US.EPU23 2026-04-16 08:31:03.927 | Denali Data Feed | Real-time data for symbol F.US.EPU25 is currently unavailable. 2026-04-16 08:31:03.927 | Denali Data Feed | Received security definition for symbol F.US.EPU25 2026-04-16 08:31:03.927 | Denali Data Feed | Real-time data for symbol F.US.EPZ23 is currently unavailable. 2026-04-16 08:31:03.927 | Denali Data Feed | Received security definition for symbol F.US.EPZ23 2026-04-16 08:31:07.917 | Requesting market depth updates for: F.US.CLEV25 if supported. NumLevels=100 2026-04-16 08:31:08.115 | Denali Data Feed | Clearing market depth for F.US.CLEV25 2026-04-16 08:31:08.166 | HD Request # 43 | Downloading Intraday chart data for F.US.CLEV25 to the file F.US.CLEV25.scid. Service: nymex 2026-04-16 08:31:08.167 | HD Request # 43 | Download start date-time: 2025-09-22 14:29:55.000000. File last date-time: 2025-09-22 14:29:55.618000 2026-04-16 08:31:08.167 | HD Request # 43 | Using server: ds32.sierracharts.com port 10150 2026-04-16 08:31:08.167 | Socket (2) | Creating socket. 2026-04-16 08:31:08.167 | Socket (2) | New receive buffer size: 0 2026-04-16 08:31:08.167 | Socket (2) | Connecting to IP: 69.39.70.248. 2026-04-16 08:31:08.357 | HD Request # 43 | Setting DTC encoding to Binary VLS 2026-04-16 08:31:08.357 | HD Request # 43 | Sending historical data logon request message. 2026-04-16 08:31:08.450 | HD Request # 43 | Requesting Intraday data. Start date-time: 2025-09-22 14:29:55. Record interval: 0. Symbol: CLV25 2026-04-16 08:31:08.547 | HD Request # 43 | Decompressing data. 2026-04-16 08:31:08.640 | HD Request # 43 | Receiving Intraday data for F.US.CLEV25 starting at 2025-09-22 14:29:55.086000 2026-04-16 08:31:08.640 | Socket (2) | CloseSocket call. 2026-04-16 08:31:08.641 | Socket (2) | Shutdown started. Waiting for graceful close. 2026-04-16 08:31:08.642 | Historical data download thread signaled to stop. 2026-04-16 08:31:08.642 | HD Request # 43 | Received 2 Intraday data records from 2025-09-22 14:29:55.086000 to 2025-09-22 14:29:55.618000 (0.5 seconds. Delay: 205.8 days) and wrote 0 records for F.US.CLEV25 2026-04-16 08:31:08.642 | HD Request # 43 | Add time&sales data | Remembered last file record date-time: 2025-09-22 18:29:55.618000 2026-04-16 08:31:08.642 | HD Request # 43 | Completion time: 0s. 2026-04-16 08:31:08.642 | HD Request # 43 | Intraday data download complete for F.US.CLEV25. Unique request ID: 43 2026-04-16 08:31:08.642 | Removing historical data download ID 43. 2026-04-16 08:31:08.642 | Real-time Intraday chart data file updates started for F.US.CLEV25 2026-04-16 08:31:08.642 | Intraday chart data file opened for F.US.CLEV25 2026-04-16 08:31:08.642 | HD Request # 43 | Enabling Intraday chart updating for symbol. 2026-04-16 08:31:08.642 | 2026-04-16 08:31:08.642 | Triggering next historical data download in queue. 2026-04-16 08:31:08.642 | HD Request # 44 | Downloading Intraday chart data for F.US.EPU25 to the file F.US.EPU25.scid. Service: cme 2026-04-16 08:31:08.643 | HD Request # 44 | Download start date-time: 2025-09-19 09:29:58.000000. File last date-time: 2025-09-19 09:29:58.698000 2026-04-16 08:31:08.643 | HD Request # 44 | Using server: ds26.sierracharts.com port 10149 2026-04-16 08:31:08.643 | Socket (4) | Creating socket. 2026-04-16 08:31:08.643 | Socket (4) | New receive buffer size: 0 2026-04-16 08:31:08.643 | Socket (4) | Connecting to IP: 64.152.155.17. 2026-04-16 08:31:08.734 | Socket (2) | Socket gracefully closed by remote side. 2026-04-16 08:31:08.734 | Socket (2) | Closed. 2026-04-16 08:31:08.965 | HD Request # 44 | Setting DTC encoding to Binary VLS 2026-04-16 08:31:08.965 | HD Request # 44 | Sending historical data logon request message. 2026-04-16 08:31:09.122 | HD Request # 44 | Requesting Intraday data. Start date-time: 2025-09-19 09:29:58. Record interval: 0. Symbol: ESU25 2026-04-16 08:31:09.276 | HD Request # 44 | Decompressing data. 2026-04-16 08:31:09.425 | HD Request # 44 | Receiving Intraday data for F.US.EPU25 starting at 2025-09-19 09:29:58.697000 2026-04-16 08:31:09.425 | Socket (4) | CloseSocket call. 2026-04-16 08:31:09.425 | Socket (4) | Shutdown started. Waiting for graceful close. 2026-04-16 08:31:09.426 | Historical data download thread signaled to stop. 2026-04-16 08:31:09.426 | HD Request # 44 | Received 5 Intraday data records from 2025-09-19 09:29:58.697000 to 2025-09-19 09:29:58.698000 (0.0 seconds. Delay: 209.0 days) and wrote 0 records for F.US.EPU25 2026-04-16 08:31:09.426 | HD Request # 44 | Add time&sales data | Remembered last file record date-time: 2025-09-19 13:29:58.698000 2026-04-16 08:31:09.426 | HD Request # 44 | Completion time: 1s. 2026-04-16 08:31:09.426 | HD Request # 44 | Intraday data download complete for F.US.EPU25. Unique request ID: 44 2026-04-16 08:31:09.426 | Removing historical data download ID 44. 2026-04-16 08:31:09.426 | Real-time Intraday chart data file updates started for F.US.EPU25 2026-04-16 08:31:09.426 | Intraday chart data file opened for F.US.EPU25 2026-04-16 08:31:09.426 | HD Request # 44 | Enabling Intraday chart updating for symbol. 2026-04-16 08:31:09.427 | 2026-04-16 08:31:09.427 | Triggering next historical data download in queue. 2026-04-16 08:31:09.427 | HD Request # 45 | Downloading Intraday chart data for F.US.CLEM26 to the file F.US.CLEM26.scid. Service: nymex 2026-04-16 08:31:09.427 | HD Request # 45 | Download start date-time: 2026-04-16 08:31:00.000000. File last date-time: 2026-04-16 08:31:00.307000 2026-04-16 08:31:09.427 | HD Request # 45 | Using server: ds28.sierracharts.com port 10150 2026-04-16 08:31:09.427 | Socket (2) | Creating socket. 2026-04-16 08:31:09.427 | Socket (2) | New receive buffer size: 0 2026-04-16 08:31:09.427 | Socket (2) | Connecting to IP: 67.214.125.5. 2026-04-16 08:31:09.574 | Socket (4) | Socket gracefully closed by remote side. 2026-04-16 08:31:09.574 | Socket (4) | Closed. 2026-04-16 08:31:09.618 | HD Request # 45 | Setting DTC encoding to Binary VLS 2026-04-16 08:31:09.618 | HD Request # 45 | Sending historical data logon request message. 2026-04-16 08:31:09.719 | HD Request # 45 | Requesting Intraday data. Start date-time: 2026-04-16 08:31:00. Record interval: 0. Symbol: CLM26 2026-04-16 08:31:09.812 | HD Request # 45 | Decompressing data. 2026-04-16 08:31:09.905 | HD Request # 45 | Receiving Intraday data for F.US.CLEM26 starting at 2026-04-16 08:31:00.303000 2026-04-16 08:31:09.906 | Socket (2) | CloseSocket call. 2026-04-16 08:31:09.906 | Socket (2) | Shutdown started. Waiting for graceful close. 2026-04-16 08:31:09.907 | Historical data download thread signaled to stop. 2026-04-16 08:31:09.907 | HD Request # 45 | Timestamp of first Intraday data file record written: 2026-04-16 08:31:02.630000. 2026-04-16 08:31:09.907 | HD Request # 45 | Received 44 Intraday data records from 2026-04-16 08:31:00.303000 to 2026-04-16 08:31:07.455000 (7.2 seconds. Delay: 2.5 seconds) and wrote 42 records for F.US.CLEM26 2026-04-16 08:31:09.922 | HD Request # 45 | Add time&sales data | Remembered last file record date-time: 2026-04-16 12:31:07.455000 2026-04-16 08:31:09.922 | Added 25 Time and Sales records to Intraday data file for F.US.CLEM26 after download. 2026-04-16 08:31:09.923 | HD Request # 45 | Completion time: 0s. 2026-04-16 08:31:09.923 | HD Request # 45 | Intraday data download complete for F.US.CLEM26. Unique request ID: 45 2026-04-16 08:31:09.923 | Removing historical data download ID 45. 2026-04-16 08:31:09.923 | Real-time Intraday chart data file updates started for F.US.CLEM26 2026-04-16 08:31:09.923 | Intraday chart data file opened for F.US.CLEM26 2026-04-16 08:31:09.923 | HD Request # 45 | Enabling Intraday chart updating for symbol. 2026-04-16 08:31:09.923 | 2026-04-16 08:31:09.923 | No download requests in the queue to start downloads for. 2026-04-16 08:31:09.999 | Socket (2) | Socket gracefully closed by remote side. 2026-04-16 08:31:09.999 | Socket (2) | Closed. 2026-04-16 08:31:13.602 | Opened cached Intraday file: C:\SierraChart\Data\F.US.CLEM26.scid. Thread ID: 16976 2026-04-16 08:44:04.711 | CQG WebAPI | Sending symbol resolution request for F.US.EPM26. ID: 431457 2026-04-16 08:44:04.715 | CQG WebAPI | Received symbol resolution report for symbol F.US.EPM26. Search Symbol: F.US.EPM26. Request ID: 431457. Contract ID: 23. 2026-04-16 08:44:04.715 | Mapping F.US.EPM26 to ESM26. Service code: cme 2026-04-16 08:44:04.716 | CQG WebAPI | Sent symbols for underlying request with ID: 431458 2026-04-16 08:44:04.721 | CQG WebAPI | Sent child symbols request with ID: 431459 2026-04-16 08:44:04.736 | CQG WebAPI | Processing child symbols report with ID: 431459 | Number times message added: 74 2026-04-16 08:44:04.862 | CQG WebAPI | Sent child symbols request with ID: 431460 2026-04-16 08:44:04.895 | CQG WebAPI | Processing child symbols report with ID: 431460 | Number times message added: 83 2026-04-16 08:44:04.966 | CQG WebAPI | Sent child symbols request with ID: 431461 2026-04-16 08:44:05.180 | CQG WebAPI | Processing child symbols report with ID: 431461 | Number times message added: 70 2026-04-16 08:44:05.238 | CQG WebAPI | Sent child symbols request with ID: 431462 2026-04-16 08:44:05.434 | CQG WebAPI | Processing child symbols report with ID: 431462 | Number times message added: 70 2026-04-16 08:44:05.495 | CQG WebAPI | Sent child symbols request with ID: 431463 2026-04-16 08:44:05.698 | CQG WebAPI | Processing child symbols report with ID: 431463 | Number times message added: 69 2026-04-16 08:44:05.733 | CQG WebAPI | Sent child symbols request with ID: 431464 2026-04-16 08:44:05.871 | CQG WebAPI | Processing child symbols report with ID: 431464 | Number times message added: 63 2026-04-16 08:44:05.905 | CQG WebAPI | Sent child symbols request with ID: 431465 2026-04-16 08:44:06.038 | CQG WebAPI | Processing child symbols report with ID: 431465 | Number times message added: 67 2026-04-16 08:44:06.072 | CQG WebAPI | Sent child symbols request with ID: 431466 2026-04-16 08:44:06.185 | CQG WebAPI | Processing child symbols report with ID: 431466 | Number times message added: 44 2026-04-16 08:44:06.207 | CQG WebAPI | Sent child symbols request with ID: 431467 2026-04-16 08:44:06.320 | CQG WebAPI | Processing child symbols report with ID: 431467 | Number times message added: 44 2026-04-16 08:44:06.347 | CQG WebAPI | Sent child symbols request with ID: 431468 2026-04-16 08:44:06.476 | CQG WebAPI | Processing child symbols report with ID: 431468 | Number times message added: 44 2026-04-16 08:44:06.489 | CQG WebAPI | Sent child symbols request with ID: 431469 2026-04-16 08:44:06.607 | CQG WebAPI | Processing child symbols report with ID: 431469 | Number times message added: 48 2026-04-16 08:44:06.640 | CQG WebAPI | Sent child symbols request with ID: 431470 2026-04-16 08:44:06.694 | CQG WebAPI | Symbols request in progress. Ignoring new request. 2026-04-16 08:44:06.774 | CQG WebAPI | Processing child symbols report with ID: 431470 | Number times message added: 47 2026-04-16 08:44:06.807 | CQG WebAPI | Sent child symbols request with ID: 431471 2026-04-16 08:44:06.937 | CQG WebAPI | Processing child symbols report with ID: 431471 | Number times message added: 44 2026-04-16 08:44:06.949 | CQG WebAPI | Sent child symbols request with ID: 431472 2026-04-16 08:44:07.063 | CQG WebAPI | Processing child symbols report with ID: 431472 | Number times message added: 44 2026-04-16 08:44:07.082 | CQG WebAPI | Sent child symbols request with ID: 431473 2026-04-16 08:44:07.206 | CQG WebAPI | Processing child symbols report with ID: 431473 | Number times message added: 41 2026-04-16 08:44:07.210 | CQG WebAPI | Sent child symbols request with ID: 431474 2026-04-16 08:44:07.320 | CQG WebAPI | Processing child symbols report with ID: 431474 | Number times message added: 40 2026-04-16 08:44:07.336 | CQG WebAPI | Sent child symbols request with ID: 431475 2026-04-16 08:44:07.450 | CQG WebAPI | Processing child symbols report with ID: 431475 | Number times message added: 37 2026-04-16 08:44:07.468 | CQG WebAPI | Sent child symbols request with ID: 431476 2026-04-16 08:44:07.579 | CQG WebAPI | Processing child symbols report with ID: 431476 | Number times message added: 36 2026-04-16 08:44:07.594 | CQG WebAPI | Sent child symbols request with ID: 431477 2026-04-16 08:44:07.705 | CQG WebAPI | Processing child symbols report with ID: 431477 | Number times message added: 36 2026-04-16 08:44:07.719 | CQG WebAPI | Sent child symbols request with ID: 431478 2026-04-16 08:44:07.831 | CQG WebAPI | Processing child symbols report with ID: 431478 | Number times message added: 35 2026-04-16 08:44:07.845 | CQG WebAPI | Sent child symbols request with ID: 431479 2026-04-16 08:44:07.957 | CQG WebAPI | Processing child symbols report with ID: 431479 | Number times message added: 35 2026-04-16 08:44:08.006 | CQG WebAPI | Sent child symbols request with ID: 431480 2026-04-16 08:44:08.034 | CQG WebAPI | Processing child symbols report with ID: 431480 | Number times message added: 46 2026-04-16 08:44:08.038 | CQG WebAPI | Sent child symbols request with ID: 431481 2026-04-16 08:44:08.143 | CQG WebAPI | Processing child symbols report with ID: 431481 | Number times message added: 17 2026-04-16 08:44:08.194 | CQG WebAPI | Sent child symbols request with ID: 431482 2026-04-16 08:44:08.298 | CQG WebAPI | Processing child symbols report with ID: 431482 | Number times message added: 17 2026-04-16 08:44:08.350 | CQG WebAPI | Sent child symbols request with ID: 431483 2026-04-16 08:44:08.452 | CQG WebAPI | Processing child symbols report with ID: 431483 | Number times message added: 16 2026-04-16 08:44:08.458 | CQG WebAPI | Sent child symbols request with ID: 431484 2026-04-16 08:44:08.562 | CQG WebAPI | Processing child symbols report with ID: 431484 | Number times message added: 18 2026-04-16 08:44:08.567 | CQG WebAPI | Sent child symbols request with ID: 431485 2026-04-16 08:44:08.673 | CQG WebAPI | Processing child symbols report with ID: 431485 | Number times message added: 17 2026-04-16 08:44:08.679 | CQG WebAPI | Sent child symbols request with ID: 431486 2026-04-16 08:44:08.790 | CQG WebAPI | Processing child symbols report with ID: 431486 | Number times message added: 16 2026-04-16 08:44:08.799 | CQG WebAPI | Sent child symbols request with ID: 431487 2026-04-16 08:44:08.907 | CQG WebAPI | Processing child symbols report with ID: 431487 | Number times message added: 26 2026-04-16 08:44:08.920 | CQG WebAPI | Sent child symbols request with ID: 431488 2026-04-16 08:44:09.021 | CQG WebAPI | Processing child symbols report with ID: 431488 | Number times message added: 8 2026-04-16 08:44:09.022 | CQG WebAPI | Sent child symbols request with ID: 431489 2026-04-16 08:44:09.121 | CQG WebAPI | Processing child symbols report with ID: 431489 | Number times message added: 8 2026-04-16 08:44:09.122 | CQG WebAPI | Sent child symbols request with ID: 431490 2026-04-16 08:44:09.131 | CQG WebAPI | Processing child symbols report with ID: 431490 | Number times message added: 32 2026-04-16 08:44:09.143 | CQG WebAPI | Adding 14612 option symbols to Find Symbol window. 2026-04-16 08:44:10.045 | F.US.EPM26 1 Min #1 | Reloading chart. 2026-04-16 08:44:10.437 | Denali Data Feed | Starting real-time market data updates for: F.US.EPM26 (ESM26). ID: 23 Service code: cme 2026-04-16 08:44:10.437 | Denali Data Feed | Requesting security definition data for: F.US.EPM26 (ESM26). ID: 23 2026-04-16 08:44:10.437 | Added historical Intraday data request for F.US.EPM26 to the queue. 2026-04-16 08:44:10.437 | Intraday data recording state for symbol F.US.EPM26 is set to download 'Pending'. 2026-04-16 08:44:10.437 | Triggering next historical data download in queue. 2026-04-16 08:44:10.440 | Delaying start of download for F.US.EPM26. 2026-04-16 08:44:10.638 | Denali Data Feed | Setting external service identifier for symbol F.US.EPM26 to 42140864 2026-04-16 08:44:10.638 | Denali Data Feed | Received security definition for symbol F.US.EPM26 2026-04-16 08:44:14.445 | F.US.EPM26[M] 1 Min #1 | Chart data loading complete. 2026-04-16 08:44:15.222 | HD Request # 46 | Downloading Intraday chart data for F.US.EPM26 to the file F.US.EPM26.scid. Service: cme 2026-04-16 08:44:15.222 | HD Request # 46 | Download start date-time: 2026-04-14 23:14:44.000000. File last date-time: 2026-04-14 23:14:44.700000 2026-04-16 08:44:15.223 | HD Request # 46 | Using server: ds32.sierracharts.com port 10149 2026-04-16 08:44:15.223 | Socket (2) | Creating socket. 2026-04-16 08:44:15.223 | Socket (2) | New receive buffer size: 0 2026-04-16 08:44:15.223 | Socket (2) | Connecting to IP: 69.39.70.248. 2026-04-16 08:44:15.413 | HD Request # 46 | Setting DTC encoding to Binary VLS 2026-04-16 08:44:15.413 | HD Request # 46 | Sending historical data logon request message. 2026-04-16 08:44:15.544 | HD Request # 46 | Requesting Intraday data. Start date-time: 2026-04-14 23:14:44. Record interval: 0. Symbol: ESM26 2026-04-16 08:44:15.639 | HD Request # 46 | Decompressing data. 2026-04-16 08:44:15.748 | HD Request # 46 | Receiving Intraday data for F.US.EPM26 starting at 2026-04-14 23:14:44.700000 2026-04-16 08:44:16.136 | HD Request # 46 | Timestamp of first Intraday data file record written: 2026-04-14 23:14:45.794000. 2026-04-16 08:44:18.546 | Socket (2) | CloseSocket call. 2026-04-16 08:44:18.546 | Socket (2) | Shutdown started. Waiting for graceful close. 2026-04-16 08:44:18.546 | Historical data download thread signaled to stop. 2026-04-16 08:44:18.546 | HD Request # 46 | Received 1001355 Intraday data records from 2026-04-14 23:14:44.700000 to 2026-04-16 08:44:15.649000 (33.5 hours. Delay: 2.9 seconds) and wrote 1001354 records for F.US.EPM26 2026-04-16 08:44:18.557 | HD Request # 46 | Add time&sales data | Remembered last file record date-time: 2026-04-16 12:44:15.649000 2026-04-16 08:44:18.557 | Added 5 Time and Sales records to Intraday data file for F.US.EPM26 after download. 2026-04-16 08:44:18.557 | HD Request # 46 | Completion time: 3s. 2026-04-16 08:44:18.557 | HD Request # 46 | Intraday data download complete for F.US.EPM26. Unique request ID: 46 2026-04-16 08:44:18.557 | Removing historical data download ID 46. 2026-04-16 08:44:18.557 | Real-time Intraday chart data file updates started for F.US.EPM26 2026-04-16 08:44:18.557 | Intraday chart data file opened for F.US.EPM26 2026-04-16 08:44:18.557 | HD Request # 46 | Enabling Intraday chart updating for symbol. 2026-04-16 08:44:18.557 | 2026-04-16 08:44:18.557 | No download requests in the queue to start downloads for. 2026-04-16 08:44:18.958 | Socket (2) | Socket gracefully closed by remote side. 2026-04-16 08:44:18.958 | Socket (2) | Closed. 2026-04-16 08:44:19.839 | Opened cached Intraday file: C:\SierraChart\Data\F.US.EPM26.scid. Thread ID: 16976 2026-04-16 08:52:09.213 | F.US.CLEM26 [CBV][M] 2000 Volume #5 | StartDateTimeForLoadingOrderFills: 00:00:00 2026-04-16 08:52:09.277 | F.US.CLEM26 [CBV][M] #2 | StartDateTimeForLoadingOrderFills: 00:00:00 2026-04-16 08:52:09.326 | F.US.CLEV25[M] #15 | StartDateTimeForLoadingOrderFills: 00:00:00 2026-04-16 08:52:15.811 | F.US.CLEM26 [CBV][M] #2 | StartDateTimeForLoadingOrderFills: 00:00:00 2026-04-16 09:13:49.817 | F.US.CLEM26 [CBV][M] #2 | StartDateTimeForLoadingOrderFills: 2025-04-09 00:00:00 2026-04-16 09:13:49.893 | F.US.CLEM26 [CBV][M] 2000 Volume #5 | StartDateTimeForLoadingOrderFills: 2025-04-09 00:00:00 2026-04-16 09:13:49.911 | F.US.CLEV25[M] #15 | StartDateTimeForLoadingOrderFills: 2025-04-09 00:00:00 2026-04-16 09:18:41.917 | F.US.CLEM26 [CBV][M] 2000 Volume #5 | StartDateTimeForLoadingOrderFills: 00:00:00 2026-04-16 09:18:41.975 | F.US.CLEM26 [CBV][M] #2 | StartDateTimeForLoadingOrderFills: 00:00:00 2026-04-16 09:18:42.024 | F.US.CLEV25[M] #15 | StartDateTimeForLoadingOrderFills: 00:00:00 2026-04-16 09:20:08.199 | F.US.EPM26 [CBV][M] 2000 Volume #5 | Reloading chart. 2026-04-16 09:20:08.283 | Added historical Intraday data request for F.US.EPM26 to the queue. 2026-04-16 09:20:08.283 | Intraday data recording state for symbol F.US.EPM26 is set to download 'Pending'. 2026-04-16 09:20:08.283 | Triggering next historical data download in queue. 2026-04-16 09:20:08.301 | F.US.EPM26 [CBV][M] 2000 Volume #5 | Performing continuous chart historical Daily data download for symbol F.US.EPM26 starting at last date in file. 2026-04-16 09:20:08.302 | Added historical Daily data request for F.US.EPM26 to the queue. 2026-04-16 09:20:08.302 | Triggering next historical data download in queue. 2026-04-16 09:20:08.322 | F.US.EPM26 [CBV][M] 2000 Volume #5 | Waiting for historical downloads to complete with the IDs: 47, 48, 2026-04-16 09:20:08.384 | HD Request # 47 | Downloading Intraday chart data for F.US.EPM26 to the file F.US.EPM26.scid. Service: cme 2026-04-16 09:20:08.385 | HD Request # 47 | Download start date-time: 2026-04-16 09:20:08.000000. File last date-time: 2026-04-16 09:20:08.202003 2026-04-16 09:20:08.387 | HD Request # 47 | Using server: ds26.sierracharts.com port 10150 2026-04-16 09:20:08.388 | HD Request # 48 | Downloading Historical Daily chart data for F.US.EPM26. Starting date: 2026-03-31. Service: cqg 2026-04-16 09:20:09.452 | Socket (2) | Creating socket. 2026-04-16 09:20:09.452 | Socket (2) | New receive buffer size: 0 2026-04-16 09:20:09.452 | Socket (2) | Connecting to IP: 64.152.155.17. 2026-04-16 09:20:09.633 | HD Request # 47 | Setting DTC encoding to Binary VLS 2026-04-16 09:20:09.633 | HD Request # 47 | Sending historical data logon request message. 2026-04-16 09:20:09.758 | HD Request # 47 | Requesting Intraday data. Start date-time: 2026-04-16 09:20:08. Record interval: 0. Symbol: ESM26 2026-04-16 09:20:09.847 | HD Request # 47 | Decompressing data. 2026-04-16 09:20:09.886 | HD Request # 48 | Requesting historical Daily data for ESM26 starting at 2026-03-30. SC External HD service. 2026-04-16 09:20:09.935 | HD Request # 47 | Receiving Intraday data for F.US.EPM26 starting at 2026-04-16 09:20:08.200000 2026-04-16 09:20:09.936 | Socket (2) | CloseSocket call. 2026-04-16 09:20:09.936 | Socket (2) | Shutdown started. Waiting for graceful close. 2026-04-16 09:20:09.936 | Historical data download thread signaled to stop. 2026-04-16 09:20:09.936 | HD Request # 47 | Timestamp of first Intraday data file record written: 2026-04-16 09:20:09.817000. 2026-04-16 09:20:09.937 | HD Request # 47 | Received 27 Intraday data records from 2026-04-16 09:20:08.200000 to 2026-04-16 09:20:09.817004 (1.6 seconds. Delay: 0.1 seconds) and wrote 5 records for F.US.EPM26 2026-04-16 09:20:09.947 | HD Request # 47 | Add time&sales data | Remembered last file record date-time: 2026-04-16 13:20:09.817004 2026-04-16 09:20:09.947 | HD Request # 47 | Completion time: 1s. 2026-04-16 09:20:09.947 | HD Request # 47 | Intraday data download complete for F.US.EPM26. Unique request ID: 47 2026-04-16 09:20:09.947 | Removing historical data download ID 47. 2026-04-16 09:20:09.947 | Real-time Intraday chart data file updates started for F.US.EPM26 2026-04-16 09:20:09.947 | Intraday chart data file opened for F.US.EPM26 2026-04-16 09:20:09.947 | HD Request # 47 | Enabling Intraday chart updating for symbol. 2026-04-16 09:20:09.947 | 2026-04-16 09:20:09.947 | No download requests in the queue to start downloads for. 2026-04-16 09:20:10.023 | Socket (2) | Socket gracefully closed by remote side. 2026-04-16 09:20:10.023 | Socket (2) | Closed. 2026-04-16 09:20:10.102 | HD Request # 48 | Receiving historical Daily data for F.US.EPM26 starting at 2026-03-31. 2026-04-16 09:20:10.103 | HD Request # 48 | Writing historical Daily data to the file F.US.EPM26.dly. 2026-04-16 09:20:10.107 | HD Request # 48 | Bytes received: 836 2026-04-16 09:20:10.107 | HD Request # 48 | Received 14 Daily data records from 2026-03-31 00:00:00 to 2026-04-16 00:00:00 (17.0 days) and wrote 13 records for F.US.EPM26 2026-04-16 09:20:10.107 | HD Request # 48 | Completion time: 2s. 2026-04-16 09:20:10.107 | HD Request # 48 | Daily data download complete for F.US.EPM26. Unique request ID: 48 2026-04-16 09:20:10.107 | Removing historical data download ID 48. 2026-04-16 09:20:10.107 | 2026-04-16 09:20:10.107 | No download requests in the queue to start downloads for. 2026-04-16 09:20:10.217 | F.US.EPM26 [CBV][M] 2000 Volume #5 | Download is complete for all contract months in chart. Proceeding with data load. 2026-04-16 09:20:10.217 | F.US.EPM26 [CBV][M] 2000 Volume #5 | Reloading chart. | Number times message added: 1 2026-04-16 09:20:13.579 | Opened cached Intraday file: C:\SierraChart\Data\F.US.EPM26.scid. Thread ID: 16976 2026-04-16 09:20:27.308 | F.US.EPM26 [CBV][M] 2000 Volume #5 | StartDateTimeForLoadingOrderFills: 00:00:00 2026-04-16 09:20:27.369 | F.US.EPM26 [CBV][M] 2000 Volume #5 | Chart data loading complete. 2026-04-16 09:20:37.009 | F.US.EPM26 [CBV][M] #2 | Reloading chart. 2026-04-16 09:20:44.141 | F.US.EPM26 [CBV][M] #2 | StartDateTimeForLoadingOrderFills: 00:00:00 2026-04-16 09:20:44.164 | F.US.EPM26 [CBV][M] #2 | Chart data loading complete. 2026-04-16 09:22:33.387 | F.US.EPM26 [CBV][M] #2 | StartDateTimeForLoadingOrderFills: 00:00:00 2026-04-16 09:25:08.950 | F.US.EPM26 [CBV][M] #2 | StartDateTimeForLoadingOrderFills: 2025-04-09 00:00:00 2026-04-16 09:25:08.974 | F.US.EPM26 [CBV][M] 2000 Volume #5 | StartDateTimeForLoadingOrderFills: 2025-04-09 00:00:00 2026-04-16 09:25:09.061 | F.US.CLEV25[M] #15 | StartDateTimeForLoadingOrderFills: 2025-04-09 00:00:00 2026-04-16 09:28:11.347 | F.US.EPU26 [CBV][M] #2 | Reloading chart. 2026-04-16 09:28:11.357 | Added historical Intraday data request for F.US.EPU26 to the queue. 2026-04-16 09:28:11.357 | Triggering next historical data download in queue. 2026-04-16 09:28:11.373 | F.US.EPU26 [CBV][M] #2 | Performing continuous chart historical Daily data download for symbol F.US.EPU26 starting at last date in file. 2026-04-16 09:28:11.373 | Added historical Daily data request for F.US.EPU26 to the queue. 2026-04-16 09:28:11.373 | Triggering next historical data download in queue. 2026-04-16 09:28:11.397 | F.US.EPU26 [CBV][M] #2 | Waiting for historical downloads to complete with the IDs: 49, 50, 2026-04-16 09:28:11.462 | Mapping F.US.EPU26 to ESU26. Service code: cme 2026-04-16 09:28:11.463 | HD Request # 49 | Downloading Intraday chart data for F.US.EPU26 to the file F.US.EPU26.scid. Service: cme 2026-04-16 09:28:11.464 | HD Request # 49 | Download start date-time: 2026-04-02 11:51:59.000000. File last date-time: 2026-04-02 11:51:59.888000 2026-04-16 09:28:11.465 | HD Request # 49 | Using server: ds28.sierracharts.com port 10149 2026-04-16 09:28:11.466 | HD Request # 50 | Downloading Historical Daily chart data for F.US.EPU26. Starting date: 2026-03-30. Service: cqg 2026-04-16 09:28:11.478 | Socket (2) | Creating socket. 2026-04-16 09:28:11.479 | Socket (2) | New receive buffer size: 0 2026-04-16 09:28:11.479 | Socket (2) | Connecting to IP: 67.214.125.5. 2026-04-16 09:28:11.672 | HD Request # 49 | Setting DTC encoding to Binary VLS 2026-04-16 09:28:11.672 | HD Request # 49 | Sending historical data logon request message. 2026-04-16 09:28:11.805 | HD Request # 49 | Requesting Intraday data. Start date-time: 2026-04-02 11:51:59. Record interval: 0. Symbol: ESU26 2026-04-16 09:28:11.898 | HD Request # 49 | Decompressing data. 2026-04-16 09:28:11.906 | HD Request # 50 | Requesting historical Daily data for ESU26 starting at 2026-03-29. SC External HD service. 2026-04-16 09:28:12.099 | HD Request # 49 | Receiving Intraday data for F.US.EPU26 starting at 2026-04-02 11:51:59.888000 2026-04-16 09:28:12.110 | HD Request # 50 | Receiving historical Daily data for F.US.EPU26 starting at 2026-03-30. 2026-04-16 09:28:12.110 | HD Request # 50 | Writing historical Daily data to the file F.US.EPU26.dly. 2026-04-16 09:28:12.124 | HD Request # 50 | Bytes received: 745 2026-04-16 09:28:12.124 | HD Request # 50 | Received 14 Daily data records from 2026-03-30 00:00:00 to 2026-04-16 00:00:00 (18.0 days) and wrote 14 records for F.US.EPU26 2026-04-16 09:28:12.124 | HD Request # 50 | Completion time: 1s. 2026-04-16 09:28:12.124 | HD Request # 50 | Daily data download complete for F.US.EPU26. Unique request ID: 50 2026-04-16 09:28:12.124 | Removing historical data download ID 50. 2026-04-16 09:28:12.124 | 2026-04-16 09:28:12.124 | No download requests in the queue to start downloads for. 2026-04-16 09:28:12.191 | Socket (2) | CloseSocket call. 2026-04-16 09:28:12.191 | Socket (2) | Shutdown started. Waiting for graceful close. 2026-04-16 09:28:12.193 | Historical data download thread signaled to stop. 2026-04-16 09:28:12.193 | HD Request # 49 | Timestamp of first Intraday data file record written: 2026-04-02 12:05:31.201000. 2026-04-16 09:28:12.193 | HD Request # 49 | Received 6257 Intraday data records from 2026-04-02 11:51:59.888000 to 2026-04-16 09:28:00.141000 (13.9 days. Delay: 12.1 seconds) and wrote 6256 records for F.US.EPU26 2026-04-16 09:28:12.202 | HD Request # 49 | Add time&sales data | Remembered last file record date-time: 2026-04-16 13:28:00.141000 2026-04-16 09:28:12.202 | HD Request # 49 | Completion time: 1s. 2026-04-16 09:28:12.202 | HD Request # 49 | Intraday data download complete for F.US.EPU26. Unique request ID: 49 2026-04-16 09:28:12.202 | Removing historical data download ID 49. 2026-04-16 09:28:12.202 | Real-time Intraday chart data file updates started for F.US.EPU26 2026-04-16 09:28:12.202 | Intraday chart data file opened for F.US.EPU26 2026-04-16 09:28:12.202 | HD Request # 49 | Enabling Intraday chart updating for symbol. 2026-04-16 09:28:12.202 | 2026-04-16 09:28:12.202 | No download requests in the queue to start downloads for. 2026-04-16 09:28:12.283 | Socket (2) | Socket gracefully closed by remote side. 2026-04-16 09:28:12.283 | Socket (2) | Closed. 2026-04-16 09:28:12.574 | F.US.EPU26 [CBV][M] #2 | Download is complete for all contract months in chart. Proceeding with data load. 2026-04-16 09:28:12.575 | F.US.EPU26 [CBV][M] #2 | Reloading chart. 2026-04-16 09:28:12.603 | Unable to determine transition date based on volume from files: F.US.EPM26.dly, F.US.EPU26.dly 2026-04-16 09:28:12.603 | The F.US.EPU26.dly symbol may not be the active contract month. 2026-04-16 09:28:12.985 | F.US.EPU26 [CBV][M] #2 | Reloading chart. 2026-04-16 09:28:13.056 | Unable to determine transition date based on volume from files: F.US.EPM26.dly, F.US.EPU26.dly 2026-04-16 09:28:13.056 | The F.US.EPU26.dly symbol may not be the active contract month. 2026-04-16 09:28:13.394 | Denali Data Feed | Starting real-time market data updates for: F.US.EPU26 (ESU26). ID: 24 Service code: cme 2026-04-16 09:28:13.394 | CQG WebAPI | Sending symbol resolution request for F.US.EPU26. ID: 431495 2026-04-16 09:28:13.395 | Denali Data Feed | Requesting security definition data for: F.US.EPU26 (ESU26). ID: 24 2026-04-16 09:28:13.400 | CQG WebAPI | Received symbol resolution report for symbol F.US.EPU26. Search Symbol: F.US.EPU26. Request ID: 431495. Contract ID: 14636. 2026-04-16 09:28:13.563 | Denali Data Feed | Setting external service identifier for symbol F.US.EPU26 to 42140870 2026-04-16 09:28:13.563 | Denali Data Feed | Received security definition for symbol F.US.EPU26 2026-04-16 09:28:22.115 | F.US.EPU26 [CBV][M] #2 | StartDateTimeForLoadingOrderFills: 2025-04-09 00:00:00 2026-04-16 09:28:22.137 | F.US.EPU26 [CBV][M] #2 | Chart data loading complete. 2026-04-16 09:29:03.996 | F.US.CLEK26 [CBV][M] #2 | Reloading chart. 2026-04-16 09:29:04.444 | Mapping F.US.CLEK26 to CLK26. Service code: nymex 2026-04-16 09:29:04.444 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEK26 (CLK26). ID: 25 Service code: nymex 2026-04-16 09:29:04.444 | CQG WebAPI | Sending symbol resolution request for F.US.CLEK26. ID: 431496 2026-04-16 09:29:04.444 | Denali Data Feed | Requesting security definition data for: F.US.CLEK26 (CLK26). ID: 25 2026-04-16 09:29:04.444 | Added historical Intraday data request for F.US.CLEK26 to the queue. 2026-04-16 09:29:04.444 | Intraday data recording state for symbol F.US.CLEK26 is set to download 'Pending'. 2026-04-16 09:29:04.444 | Triggering next historical data download in queue. 2026-04-16 09:29:04.444 | Delaying start of download for F.US.CLEK26. 2026-04-16 09:29:04.448 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEK26. Search Symbol: F.US.CLEK26. Request ID: 431496. Contract ID: 14637. 2026-04-16 09:29:04.633 | Denali Data Feed | Setting external service identifier for symbol F.US.CLEK26 to 169926 2026-04-16 09:29:04.633 | Denali Data Feed | Received security definition for symbol F.US.CLEK26 2026-04-16 09:29:06.921 | F.US.CLEK26 [CBV][M] #2 | StartDateTimeForLoadingOrderFills: 2025-04-08 00:00:00 2026-04-16 09:29:06.950 | F.US.CLEK26 [CBV][M] #2 | Chart data loading complete. 2026-04-16 09:29:09.664 | HD Request # 51 | Downloading Intraday chart data for F.US.CLEK26 to the file F.US.CLEK26.scid. Service: nymex 2026-04-16 09:29:09.664 | HD Request # 51 | Download start date-time: 2026-04-16 08:15:16.000000. File last date-time: 2026-04-16 08:15:16.505000 2026-04-16 09:29:09.664 | HD Request # 51 | Using server: ds32.sierracharts.com port 10150 2026-04-16 09:29:09.676 | Socket (2) | Creating socket. 2026-04-16 09:29:09.676 | Socket (2) | New receive buffer size: 0 2026-04-16 09:29:09.676 | Socket (2) | Connecting to IP: 69.39.70.248. 2026-04-16 09:29:09.866 | HD Request # 51 | Setting DTC encoding to Binary VLS 2026-04-16 09:29:09.866 | HD Request # 51 | Sending historical data logon request message. 2026-04-16 09:29:09.990 | HD Request # 51 | Requesting Intraday data. Start date-time: 2026-04-16 08:15:16. Record interval: 0. Symbol: CLK26 2026-04-16 09:29:10.084 | HD Request # 51 | Decompressing data. 2026-04-16 09:29:10.191 | HD Request # 51 | Receiving Intraday data for F.US.CLEK26 starting at 2026-04-16 08:15:16.505000 2026-04-16 09:29:10.285 | Socket (2) | CloseSocket call. 2026-04-16 09:29:10.285 | Socket (2) | Shutdown started. Waiting for graceful close. 2026-04-16 09:29:10.286 | Historical data download thread signaled to stop. 2026-04-16 09:29:10.287 | HD Request # 51 | Timestamp of first Intraday data file record written: 2026-04-16 08:15:36.095000. 2026-04-16 09:29:10.287 | HD Request # 51 | Received 6950 Intraday data records from 2026-04-16 08:15:16.505000 to 2026-04-16 09:29:06.380000 (73.8 minutes. Delay: 3.9 seconds) and wrote 6949 records for F.US.CLEK26 2026-04-16 09:29:10.297 | HD Request # 51 | Add time&sales data | Remembered last file record date-time: 2026-04-16 13:29:06.380000 2026-04-16 09:29:10.297 | Added 1 Time and Sales records to Intraday data file for F.US.CLEK26 after download. 2026-04-16 09:29:10.297 | HD Request # 51 | Completion time: 1s. 2026-04-16 09:29:10.297 | HD Request # 51 | Intraday data download complete for F.US.CLEK26. Unique request ID: 51 2026-04-16 09:29:10.297 | Removing historical data download ID 51. 2026-04-16 09:29:10.297 | Real-time Intraday chart data file updates started for F.US.CLEK26 2026-04-16 09:29:10.297 | Intraday chart data file opened for F.US.CLEK26 2026-04-16 09:29:10.297 | HD Request # 51 | Enabling Intraday chart updating for symbol. 2026-04-16 09:29:10.297 | 2026-04-16 09:29:10.297 | No download requests in the queue to start downloads for. 2026-04-16 09:29:10.378 | Socket (2) | Socket gracefully closed by remote side. 2026-04-16 09:29:10.378 | Socket (2) | Closed. 2026-04-16 09:29:14.538 | Opened cached Intraday file: C:\SierraChart\Data\F.US.CLEK26.scid. Thread ID: 16976 2026-04-16 09:29:33.386 | F.US.CLEK26 [CBV][M] 2000 Volume #5 | Reloading chart. 2026-04-16 09:29:37.936 | F.US.CLEK26 [CBV][M] 2000 Volume #5 | StartDateTimeForLoadingOrderFills: 2025-04-09 00:00:00 2026-04-16 09:29:37.972 | F.US.CLEK26 [CBV][M] 2000 Volume #5 | Chart data loading complete. 2026-04-16 09:30:04.611 | Opened cached Intraday file: C:\SierraChart\Data\F.US.EPU26.scid. Thread ID: 16976 2026-04-16 09:32:53.844 | F.US.CLEK26 [CBV][M] #2 | Reloading chart. 2026-04-16 09:32:54.184 | F.US.CLEK26 [CBV][M] 2000 Volume #5 | Reloading chart. 2026-04-16 09:32:55.699 | F.US.CLEK26 [CBV][M] #2 | StartDateTimeForLoadingOrderFills: 2025-04-09 00:00:00 2026-04-16 09:32:55.733 | F.US.CLEK26 [CBV][M] #2 | Chart data loading complete. 2026-04-16 09:32:58.156 | F.US.CLEK26 [CBV][M] 2000 Volume #5 | StartDateTimeForLoadingOrderFills: 2025-04-09 00:00:00 2026-04-16 09:32:58.194 | F.US.CLEK26 [CBV][M] 2000 Volume #5 | Chart data loading complete. 2026-04-16 09:33:09.238 | F.US.CLEM26 [CBV][M] #2 | Reloading chart. 2026-04-16 09:33:09.679 | F.US.CLEM26 [CBV][M] 2000 Volume #5 | Reloading chart. 2026-04-16 09:33:11.354 | F.US.CLEM26 [CBV][M] #2 | StartDateTimeForLoadingOrderFills: 2025-04-09 00:00:00 2026-04-16 09:33:11.388 | F.US.CLEM26 [CBV][M] #2 | Chart data loading complete. 2026-04-16 09:33:13.889 | F.US.CLEM26 [CBV][M] 2000 Volume #5 | StartDateTimeForLoadingOrderFills: 2025-04-09 00:00:00 2026-04-16 09:33:13.928 | F.US.CLEM26 [CBV][M] 2000 Volume #5 | Chart data loading complete. 2026-04-16 14:26:30.977 | CQG WebSocket | Timeout waiting for pong message from server. 2026-04-16 14:26:30.978 | CQG WebAPI | WebSocket closed. 2026-04-16 14:26:30.978 | Connection to the external service has been lost. 2026-04-16 14:26:31.112 | Denali Data Feed | There has been no activity on the network socket for 1h 29m 10s. Will reconnect. 2026-04-16 14:26:31.113 | Denali Data Feed | Waiting for socket receive thread to end 2026-04-16 14:26:31.117 | DTC Client socket (3) | CloseSocket call. 2026-04-16 14:26:31.117 | Denali Data Feed | Disconnected from the server. 2026-04-16 14:26:31.117 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds. 2026-04-16 14:26:31.118 | CQG WebAPI | Sending Web API Logoff message. 2026-04-16 14:26:31.119 | CQG WebSocket socket (1) | CloseSocket call. 2026-04-16 14:26:31.119 | CQG WebSocket socket (1) | Max send buffers used during socket life: 3 2026-04-16 14:26:31.119 | CQG WebSocket socket (1) | Max send buffer size during socket life: 636 2026-04-16 14:26:31.119 | CQG WebSocket | WebSocket closed. 2026-04-16 14:26:31.119 | CQG WebAPI | WebSocket closed. 2026-04-16 14:26:31.122 | CQG WebAPI | Disconnected. 2026-04-16 14:26:31.122 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-04-16 14:26:31.167 | DTC Client socket (3) | Shutdown started. Waiting for graceful close. 2026-04-16 14:26:31.167 | CQG WebSocket socket (1) | Write in progress. Shutdown being delayed. PendingSize=0 2026-04-16 14:26:31.170 | DTC Client socket (3) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. * 2026-04-16 14:26:31.170 | DTC Client socket (3) | Socket gracefully closed by remote side. 2026-04-16 14:26:31.171 | DTC Client socket (3) | Closed. 2026-04-16 14:26:33.133 | 2026-04-16 14:26:33.156 | CQG WebAPI | Connecting to server api.cqg.com 2026-04-16 14:26:33.156 | CQG WebSocket | Connecting to WebSocket server api.cqg.com:443 2026-04-16 14:26:33.494 | CQG WebSocket socket (2) | Creating socket. Using TLS 1.2. 2026-04-16 14:26:33.513 | CQG WebSocket socket (2) | New receive buffer size: 0 2026-04-16 14:26:33.513 | CQG WebSocket socket (2) | Connecting to IP: 195.166.124.175. 2026-04-16 14:26:33.537 | CQG WebSocket | Opening WebSocket. 2026-04-16 14:26:33.537 | CQG WebSocket | Sending WebSocket handshake. 2026-04-16 14:26:33.564 | CQG WebSocket | Server header | HTTP/1.1 101 Switching Protocols 2026-04-16 14:26:33.564 | CQG WebSocket | Server header | Connection: Upgrade 2026-04-16 14:26:33.564 | CQG WebSocket | Server header | Sec-WebSocket-Accept: JiCYH+heumrKgD+QGeOkNT+c3F4= 2026-04-16 14:26:33.564 | CQG WebSocket | Server header | Server: WebSocket++/0.8.2 2026-04-16 14:26:33.564 | CQG WebSocket | Server header | Upgrade: websocket 2026-04-16 14:26:33.564 | CQG WebSocket | Server header | 2026-04-16 14:26:33.564 | CQG WebSocket | Web socket state is now open. 2026-04-16 14:26:33.564 | CQG WebAPI | WebSocket connected. 2026-04-16 14:26:33.565 | CQG WebAPI | Sending market data logon message. 2026-04-16 14:26:33.809 | CQG WebAPI | Base Time: 2026-04-12T15:44:25. 2026-04-12 15:44:25 2026-04-16 14:26:33.810 | CQG WebAPI | Logon successful. Session Token = T9eoq0Osx7qyQAvm+70fm0RyjCoQD/usw/Fjo+Nb3Rs+vfzNjnjx1QhzqWiwjSURR978kY0EgI/ 2026-04-16 14:26:33.810 | CQG WebAPI | Connection to server complete. 2026-04-16 14:26:33.811 | DTC Client socket (0) | CloseSocket call. 2026-04-16 14:26:33.811 | Denali Data Feed | Disconnected from the server. 2026-04-16 14:26:33.838 | No download requests in the queue to start downloads for. | Number times message added: 3 2026-04-16 14:26:33.839 | Updated verified funded futures trading account ending date to: 2026-05-16 18:26:33 2026-04-16 14:26:33.866 | CQG WebAPI | Sending Trade Accounts request message. 2026-04-16 14:26:33.953 | CQG WebAPI | Brokerage name: AMP. Account Name: 220033 2026-04-16 14:26:33.953 | Updated verified funded futures trading account ending date to: 2026-05-16 18:26:33 2026-04-16 14:26:33.953 | CQG WebAPI | Sending collateral subscribe request. 2026-04-16 14:26:33.982 | Mapping F.US.CLEV25 to CLV25. Service code: nymex 2026-04-16 14:26:33.983 | Using symbol data fast lookup vector 2026-04-16 14:26:33.984 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEV25 (CLV25). ID: 1 Service code: nymex 2026-04-16 14:26:33.986 | Denali Data Feed | Connecting to the server ds28.sierracharts.com. Port 10048 2026-04-16 14:26:33.986 | CQG WebAPI | Sending symbol resolution request for F.US.CLEV25. ID: 431532 2026-04-16 14:26:33.986 | Denali Data Feed | Requesting security definition data for: F.US.CLEV25 (CLV25). ID: 1 2026-04-16 14:26:33.987 | Added historical Intraday data request for F.US.CLEV25 to the queue. 2026-04-16 14:26:33.987 | Intraday data recording state for symbol F.US.CLEV25 is set to download 'Pending'. 2026-04-16 14:26:33.987 | Triggering next historical data download in queue. 2026-04-16 14:26:33.995 | Delaying start of download for F.US.CLEV25. 2026-04-16 14:26:33.997 | Mapping F.US.EPU25 to ESU25. Service code: cme 2026-04-16 14:26:33.998 | Denali Data Feed | Starting real-time market data updates for: F.US.EPU25 (ESU25). ID: 2 Service code: cme 2026-04-16 14:26:33.998 | CQG WebAPI | Sending symbol resolution request for F.US.EPU25. ID: 431533 2026-04-16 14:26:33.998 | Denali Data Feed | Requesting security definition data for: F.US.EPU25 (ESU25). ID: 2 2026-04-16 14:26:33.998 | Added historical Intraday data request for F.US.EPU25 to the queue. 2026-04-16 14:26:33.998 | Intraday data recording state for symbol F.US.EPU25 is set to download 'Pending'. 2026-04-16 14:26:33.998 | Triggering next historical data download in queue. 2026-04-16 14:26:34.001 | DTC Client socket (3) | Creating socket. 2026-04-16 14:26:34.001 | DTC Client socket (3) | New receive buffer size: 0 2026-04-16 14:26:34.001 | DTC Client socket (3) | Connecting to IP: 67.214.125.5. 2026-04-16 14:26:34.044 | CQG WebAPI | Received symbol resolution report for symbol F.US.EPU25. Search Symbol: F.US.EPU25. Request ID: 431533. Contract ID: 1. 2026-04-16 14:26:34.052 | Mapping F.US.CLEM26 to CLM26. Service code: nymex 2026-04-16 14:26:34.052 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEM26 (CLM26). ID: 3 Service code: nymex 2026-04-16 14:26:34.052 | CQG WebAPI | Sending symbol resolution request for F.US.CLEM26. ID: 431534 2026-04-16 14:26:34.052 | Denali Data Feed | Requesting security definition data for: F.US.CLEM26 (CLM26). ID: 3 2026-04-16 14:26:34.053 | Added historical Intraday data request for F.US.CLEM26 to the queue. 2026-04-16 14:26:34.053 | Intraday data recording state for symbol F.US.CLEM26 is set to download 'Pending'. 2026-04-16 14:26:34.053 | Triggering next historical data download in queue. 2026-04-16 14:26:34.167 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEM26. Search Symbol: F.US.CLEM26. Request ID: 431534. Contract ID: 2. 2026-04-16 14:26:34.167 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEV25. Search Symbol: F.US.CLEV25. Request ID: 431532. Contract ID: 3. 2026-04-16 14:26:34.168 | CQG WebAPI | Sending positions subscribe request. RequestID: 431535 2026-04-16 14:26:34.169 | CQG WebAPI | Sending orders subscribe request. RequestID: 431536 2026-04-16 14:26:34.169 | Denali Data Feed | Network connection to server complete. 2026-04-16 14:26:34.169 | Denali Data Feed | Starting socket receive thread. 2026-04-16 14:26:34.170 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard 2026-04-16 14:26:34.339 | Mapping F.US.EPH23 to ESH23. Service code: cme 2026-04-16 14:26:34.339 | Denali Data Feed | Starting real-time market data updates for: F.US.EPH23 (ESH23). ID: 4 Service code: cme 2026-04-16 14:26:34.339 | CQG WebAPI | Sending symbol resolution request for F.US.EPH23. ID: 431537 2026-04-16 14:26:34.339 | Denali Data Feed | Requesting security definition data for: F.US.EPH23 (ESH23). ID: 4 2026-04-16 14:26:34.339 | Mapping F.US.EPM23 to ESM23. Service code: cme 2026-04-16 14:26:34.340 | Denali Data Feed | Starting real-time market data updates for: F.US.EPM23 (ESM23). ID: 5 Service code: cme 2026-04-16 14:26:34.340 | CQG WebAPI | Sending symbol resolution request for F.US.EPM23. ID: 431538 2026-04-16 14:26:34.340 | Denali Data Feed | Requesting security definition data for: F.US.EPM23 (ESM23). ID: 5 2026-04-16 14:26:34.342 | Mapping F.US.EPU23 to ESU23. Service code: cme 2026-04-16 14:26:34.343 | Denali Data Feed | Starting real-time market data updates for: F.US.EPU23 (ESU23). ID: 6 Service code: cme 2026-04-16 14:26:34.343 | CQG WebAPI | Sending symbol resolution request for F.US.EPU23. ID: 431539 2026-04-16 14:26:34.343 | Denali Data Feed | Requesting security definition data for: F.US.EPU23 (ESU23). ID: 6 2026-04-16 14:26:34.343 | Mapping F.US.EPZ23 to ESZ23. Service code: cme 2026-04-16 14:26:34.343 | Denali Data Feed | Starting real-time market data updates for: F.US.EPZ23 (ESZ23). ID: 7 Service code: cme 2026-04-16 14:26:34.343 | CQG WebAPI | Sending symbol resolution request for F.US.EPZ23. ID: 431540 2026-04-16 14:26:34.343 | Denali Data Feed | Requesting security definition data for: F.US.EPZ23 (ESZ23). ID: 7 2026-04-16 14:26:34.356 | Mapping F.US.EPH24 to ESH24. Service code: cme 2026-04-16 14:26:34.356 | Denali Data Feed | Starting real-time market data updates for: F.US.EPH24 (ESH24). ID: 8 Service code: cme 2026-04-16 14:26:34.356 | CQG WebAPI | Sending symbol resolution request for F.US.EPH24. ID: 431541 2026-04-16 14:26:34.356 | Denali Data Feed | Requesting security definition data for: F.US.EPH24 (ESH24). ID: 8 2026-04-16 14:26:34.357 | Mapping F.US.CLEF23 to CLF23. Service code: nymex 2026-04-16 14:26:34.357 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEF23 (CLF23). ID: 9 Service code: nymex 2026-04-16 14:26:34.357 | CQG WebAPI | Sending symbol resolution request for F.US.CLEF23. ID: 431542 2026-04-16 14:26:34.357 | Denali Data Feed | Requesting security definition data for: F.US.CLEF23 (CLF23). ID: 9 2026-04-16 14:26:34.357 | Mapping F.US.CLEG23 to CLG23. Service code: nymex 2026-04-16 14:26:34.357 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEG23 (CLG23). ID: 10 Service code: nymex 2026-04-16 14:26:34.357 | CQG WebAPI | Sending symbol resolution request for F.US.CLEG23. ID: 431543 2026-04-16 14:26:34.357 | Denali Data Feed | Requesting security definition data for: F.US.CLEG23 (CLG23). ID: 10 2026-04-16 14:26:34.358 | Mapping F.US.CLEH23 to CLH23. Service code: nymex 2026-04-16 14:26:34.359 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEH23 (CLH23). ID: 11 Service code: nymex 2026-04-16 14:26:34.359 | CQG WebAPI | Sending symbol resolution request for F.US.CLEH23. ID: 431544 2026-04-16 14:26:34.359 | Denali Data Feed | Requesting security definition data for: F.US.CLEH23 (CLH23). ID: 11 2026-04-16 14:26:34.359 | Mapping F.US.CLEJ23 to CLJ23. Service code: nymex 2026-04-16 14:26:34.359 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEJ23 (CLJ23). ID: 12 Service code: nymex 2026-04-16 14:26:34.360 | CQG WebAPI | Sending symbol resolution request for F.US.CLEJ23. ID: 431545 2026-04-16 14:26:34.360 | Denali Data Feed | Requesting security definition data for: F.US.CLEJ23 (CLJ23). ID: 12 2026-04-16 14:26:34.360 | Mapping F.US.CLEK23 to CLK23. Service code: nymex 2026-04-16 14:26:34.360 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEK23 (CLK23). ID: 13 Service code: nymex 2026-04-16 14:26:34.360 | CQG WebAPI | Sending symbol resolution request for F.US.CLEK23. ID: 431546 2026-04-16 14:26:34.360 | Denali Data Feed | Requesting security definition data for: F.US.CLEK23 (CLK23). ID: 13 2026-04-16 14:26:34.360 | Mapping F.US.CLEM23 to CLM23. Service code: nymex 2026-04-16 14:26:34.360 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEM23 (CLM23). ID: 14 Service code: nymex 2026-04-16 14:26:34.360 | CQG WebAPI | Sending symbol resolution request for F.US.CLEM23. ID: 431547 2026-04-16 14:26:34.360 | Denali Data Feed | Requesting security definition data for: F.US.CLEM23 (CLM23). ID: 14 2026-04-16 14:26:34.360 | Mapping F.US.CLEN23 to CLN23. Service code: nymex 2026-04-16 14:26:34.360 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEN23 (CLN23). ID: 15 Service code: nymex 2026-04-16 14:26:34.360 | CQG WebAPI | Sending symbol resolution request for F.US.CLEN23. ID: 431548 2026-04-16 14:26:34.360 | Denali Data Feed | Requesting security definition data for: F.US.CLEN23 (CLN23). ID: 15 2026-04-16 14:26:34.360 | Mapping F.US.CLEQ23 to CLQ23. Service code: nymex 2026-04-16 14:26:34.360 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEQ23 (CLQ23). ID: 16 Service code: nymex 2026-04-16 14:26:34.360 | CQG WebAPI | Sending symbol resolution request for F.US.CLEQ23. ID: 431549 2026-04-16 14:26:34.360 | Denali Data Feed | Requesting security definition data for: F.US.CLEQ23 (CLQ23). ID: 16 2026-04-16 14:26:34.360 | Mapping F.US.CLEU23 to CLU23. Service code: nymex 2026-04-16 14:26:34.361 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEU23 (CLU23). ID: 17 Service code: nymex 2026-04-16 14:26:34.361 | CQG WebAPI | Sending symbol resolution request for F.US.CLEU23. ID: 431550 2026-04-16 14:26:34.361 | Denali Data Feed | Requesting security definition data for: F.US.CLEU23 (CLU23). ID: 17 2026-04-16 14:26:34.361 | Mapping F.US.CLEV23 to CLV23. Service code: nymex 2026-04-16 14:26:34.361 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEV23 (CLV23). ID: 18 Service code: nymex 2026-04-16 14:26:34.361 | CQG WebAPI | Sending symbol resolution request for F.US.CLEV23. ID: 431551 2026-04-16 14:26:34.361 | Denali Data Feed | Requesting security definition data for: F.US.CLEV23 (CLV23). ID: 18 2026-04-16 14:26:34.361 | Mapping F.US.CLEX23 to CLX23. Service code: nymex 2026-04-16 14:26:34.361 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEX23 (CLX23). ID: 19 Service code: nymex 2026-04-16 14:26:34.361 | CQG WebAPI | Sending symbol resolution request for F.US.CLEX23. ID: 431552 2026-04-16 14:26:34.361 | Denali Data Feed | Requesting security definition data for: F.US.CLEX23 (CLX23). ID: 19 2026-04-16 14:26:34.361 | Mapping F.US.CLEZ23 to CLZ23. Service code: nymex 2026-04-16 14:26:34.362 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEZ23 (CLZ23). ID: 20 Service code: nymex 2026-04-16 14:26:34.362 | CQG WebAPI | Sending symbol resolution request for F.US.CLEZ23. ID: 431553 2026-04-16 14:26:34.362 | Denali Data Feed | Requesting security definition data for: F.US.CLEZ23 (CLZ23). ID: 20 2026-04-16 14:26:34.362 | Mapping F.US.CLEF24 to CLF24. Service code: nymex 2026-04-16 14:26:34.362 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEF24 (CLF24). ID: 21 Service code: nymex 2026-04-16 14:26:34.362 | CQG WebAPI | Sending symbol resolution request for F.US.CLEF24. ID: 431554 2026-04-16 14:26:34.362 | Denali Data Feed | Requesting security definition data for: F.US.CLEF24 (CLF24). ID: 21 2026-04-16 14:26:34.362 | Mapping F.US.CLEG24 to CLG24. Service code: nymex 2026-04-16 14:26:34.362 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEG24 (CLG24). ID: 22 Service code: nymex 2026-04-16 14:26:34.362 | CQG WebAPI | Sending symbol resolution request for F.US.CLEG24. ID: 431555 2026-04-16 14:26:34.362 | Denali Data Feed | Requesting security definition data for: F.US.CLEG24 (CLG24). ID: 22 2026-04-16 14:26:34.363 | CQG WebAPI | Received symbol resolution report for symbol F.US.EPH23. Search Symbol: F.US.EPH23. Request ID: 431537. Contract ID: 5. 2026-04-16 14:26:34.363 | CQG WebAPI | Received symbol resolution report for symbol F.US.EPM23. Search Symbol: F.US.EPM23. Request ID: 431538. Contract ID: 6. 2026-04-16 14:26:34.364 | CQG WebAPI | Received symbol resolution report for symbol F.US.EPU23. Search Symbol: F.US.EPU23. Request ID: 431539. Contract ID: 7. 2026-04-16 14:26:34.364 | CQG WebAPI | Received symbol resolution report for symbol F.US.EPZ23. Search Symbol: F.US.EPZ23. Request ID: 431540. Contract ID: 8. 2026-04-16 14:26:34.364 | Denali Data Feed | Setting DTC encoding to Binary VLS 2026-04-16 14:26:34.365 | Denali Data Feed | Sending logon request message. 2026-04-16 14:26:34.430 | CQG WebAPI | Received symbol resolution report for symbol F.US.EPH24. Search Symbol: F.US.EPH24. Request ID: 431541. Contract ID: 9. 2026-04-16 14:26:34.458 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEG23. Search Symbol: F.US.CLEG23. Request ID: 431543. Contract ID: 10. 2026-04-16 14:26:34.458 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEF23. Search Symbol: F.US.CLEF23. Request ID: 431542. Contract ID: 11. 2026-04-16 14:26:34.527 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEH23. Search Symbol: F.US.CLEH23. Request ID: 431544. Contract ID: 12. 2026-04-16 14:26:34.527 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEJ23. Search Symbol: F.US.CLEJ23. Request ID: 431545. Contract ID: 13. 2026-04-16 14:26:34.527 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEK23. Search Symbol: F.US.CLEK23. Request ID: 431546. Contract ID: 14. 2026-04-16 14:26:34.527 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEM23. Search Symbol: F.US.CLEM23. Request ID: 431547. Contract ID: 15. 2026-04-16 14:26:34.527 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEN23. Search Symbol: F.US.CLEN23. Request ID: 431548. Contract ID: 16. 2026-04-16 14:26:34.527 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEQ23. Search Symbol: F.US.CLEQ23. Request ID: 431549. Contract ID: 17. 2026-04-16 14:26:34.544 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEV23. Search Symbol: F.US.CLEV23. Request ID: 431551. Contract ID: 18. 2026-04-16 14:26:34.544 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEU23. Search Symbol: F.US.CLEU23. Request ID: 431550. Contract ID: 19. 2026-04-16 14:26:34.544 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEX23. Search Symbol: F.US.CLEX23. Request ID: 431552. Contract ID: 20. 2026-04-16 14:26:34.544 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEZ23. Search Symbol: F.US.CLEZ23. Request ID: 431553. Contract ID: 21. 2026-04-16 14:26:34.544 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEG24. Search Symbol: F.US.CLEG24. Request ID: 431555. Contract ID: 22. 2026-04-16 14:26:34.544 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEF24. Search Symbol: F.US.CLEF24. Request ID: 431554. Contract ID: 23. 2026-04-16 14:26:34.907 | Denali Data Feed | Received logon response. 2026-04-16 14:26:34.907 | Denali Data Feed | Server Name: SC Realtime Server. 2026-04-16 14:26:34.907 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8 2026-04-16 14:26:34.907 | Denali Data Feed | Successfully connected. 2026-04-16 14:26:34.907 | Denali Data Feed | Trading is not supported. 2026-04-16 14:26:34.907 | Denali Data Feed | MarketDepthIsSupported: 1 2026-04-16 14:26:34.907 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEF23 -> CLF23 2026-04-16 14:26:34.907 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEF24 -> CLF24 2026-04-16 14:26:34.907 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEG23 -> CLG23 2026-04-16 14:26:34.907 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEG24 -> CLG24 2026-04-16 14:26:34.907 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEH23 -> CLH23 2026-04-16 14:26:34.907 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEJ23 -> CLJ23 2026-04-16 14:26:34.907 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEK23 -> CLK23 2026-04-16 14:26:34.907 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEM23 -> CLM23 2026-04-16 14:26:34.907 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEM26 -> CLM26 2026-04-16 14:26:34.907 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEN23 -> CLN23 2026-04-16 14:26:34.907 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEQ23 -> CLQ23 2026-04-16 14:26:34.907 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEU23 -> CLU23 2026-04-16 14:26:34.907 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEV23 -> CLV23 2026-04-16 14:26:34.907 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEV25 -> CLV25 2026-04-16 14:26:34.907 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEX23 -> CLX23 2026-04-16 14:26:34.907 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEZ23 -> CLZ23 2026-04-16 14:26:34.907 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.EPH23 -> ESH23 2026-04-16 14:26:34.907 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.EPH24 -> ESH24 2026-04-16 14:26:34.907 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.EPM23 -> ESM23 2026-04-16 14:26:34.907 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.EPU23 -> ESU23 2026-04-16 14:26:34.907 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.EPU25 -> ESU25 2026-04-16 14:26:34.907 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.EPZ23 -> ESZ23 2026-04-16 14:26:35.179 | Denali Data Feed | Real-time data for symbol F.US.CLEF23 is currently unavailable. 2026-04-16 14:26:35.180 | Denali Data Feed | Received security definition for symbol F.US.CLEF23 2026-04-16 14:26:35.180 | Denali Data Feed | Real-time data for symbol F.US.CLEF24 is currently unavailable. 2026-04-16 14:26:35.180 | Denali Data Feed | Received security definition for symbol F.US.CLEF24 2026-04-16 14:26:35.180 | Denali Data Feed | Real-time data for symbol F.US.CLEG23 is currently unavailable. 2026-04-16 14:26:35.180 | Denali Data Feed | Received security definition for symbol F.US.CLEG23 2026-04-16 14:26:35.180 | Denali Data Feed | Real-time data for symbol F.US.CLEG24 is currently unavailable. 2026-04-16 14:26:35.180 | Denali Data Feed | Received security definition for symbol F.US.CLEG24 2026-04-16 14:26:35.180 | Denali Data Feed | Real-time data for symbol F.US.CLEH23 is currently unavailable. 2026-04-16 14:26:35.180 | Denali Data Feed | Received security definition for symbol F.US.CLEH23 2026-04-16 14:26:35.180 | Denali Data Feed | Real-time data for symbol F.US.CLEJ23 is currently unavailable. 2026-04-16 14:26:35.180 | Denali Data Feed | Received security definition for symbol F.US.CLEJ23 2026-04-16 14:26:35.180 | Denali Data Feed | Real-time data for symbol F.US.CLEK23 is currently unavailable. 2026-04-16 14:26:35.180 | Denali Data Feed | Received security definition for symbol F.US.CLEK23 2026-04-16 14:26:35.180 | Denali Data Feed | Real-time data for symbol F.US.CLEM23 is currently unavailable. 2026-04-16 14:26:35.180 | Denali Data Feed | Received security definition for symbol F.US.CLEM23 2026-04-16 14:26:35.181 | Denali Data Feed | Setting external service identifier for symbol F.US.CLEM26 to 670557 2026-04-16 14:26:35.181 | Denali Data Feed | Received security definition for symbol F.US.CLEM26 2026-04-16 14:26:35.181 | Denali Data Feed | Real-time data for symbol F.US.CLEN23 is currently unavailable. 2026-04-16 14:26:35.181 | Denali Data Feed | Received security definition for symbol F.US.CLEN23 2026-04-16 14:26:35.181 | Denali Data Feed | Real-time data for symbol F.US.CLEQ23 is currently unavailable. 2026-04-16 14:26:35.181 | Denali Data Feed | Received security definition for symbol F.US.CLEQ23 2026-04-16 14:26:35.181 | Denali Data Feed | Real-time data for symbol F.US.CLEU23 is currently unavailable. 2026-04-16 14:26:35.181 | Denali Data Feed | Received security definition for symbol F.US.CLEU23 2026-04-16 14:26:35.181 | Denali Data Feed | Real-time data for symbol F.US.CLEV23 is currently unavailable. 2026-04-16 14:26:35.181 | Denali Data Feed | Received security definition for symbol F.US.CLEV23 2026-04-16 14:26:35.181 | Denali Data Feed | Real-time data for symbol F.US.CLEV25 is currently unavailable. 2026-04-16 14:26:35.181 | Denali Data Feed | Received security definition for symbol F.US.CLEV25 2026-04-16 14:26:35.181 | Denali Data Feed | Real-time data for symbol F.US.CLEX23 is currently unavailable. 2026-04-16 14:26:35.181 | Denali Data Feed | Received security definition for symbol F.US.CLEX23 2026-04-16 14:26:35.181 | Denali Data Feed | Real-time data for symbol F.US.CLEZ23 is currently unavailable. 2026-04-16 14:26:35.181 | Denali Data Feed | Received security definition for symbol F.US.CLEZ23 2026-04-16 14:26:35.181 | Denali Data Feed | Real-time data for symbol F.US.EPH23 is currently unavailable. 2026-04-16 14:26:35.181 | Denali Data Feed | Received security definition for symbol F.US.EPH23 2026-04-16 14:26:35.181 | Denali Data Feed | Real-time data for symbol F.US.EPH24 is currently unavailable. 2026-04-16 14:26:35.181 | Denali Data Feed | Received security definition for symbol F.US.EPH24 2026-04-16 14:26:35.181 | Denali Data Feed | Real-time data for symbol F.US.EPM23 is currently unavailable. 2026-04-16 14:26:35.181 | Denali Data Feed | Received security definition for symbol F.US.EPM23 2026-04-16 14:26:35.181 | Denali Data Feed | Real-time data for symbol F.US.EPU23 is currently unavailable. 2026-04-16 14:26:35.181 | Denali Data Feed | Received security definition for symbol F.US.EPU23 2026-04-16 14:26:35.181 | Denali Data Feed | Real-time data for symbol F.US.EPU25 is currently unavailable. 2026-04-16 14:26:35.181 | Denali Data Feed | Received security definition for symbol F.US.EPU25 2026-04-16 14:26:35.181 | Denali Data Feed | Real-time data for symbol F.US.EPZ23 is currently unavailable. 2026-04-16 14:26:35.181 | Denali Data Feed | Received security definition for symbol F.US.EPZ23 2026-04-16 14:26:38.833 | Requesting market depth updates for: F.US.CLEV25 if supported. NumLevels=100 2026-04-16 14:26:39.008 | Denali Data Feed | Clearing market depth for F.US.CLEV25 2026-04-16 14:26:40.997 | HD Request # 52 | Downloading Intraday chart data for F.US.CLEV25 to the file F.US.CLEV25.scid. Service: nymex 2026-04-16 14:26:41.000 | HD Request # 52 | Download start date-time: 2025-09-22 14:29:55.000000. File last date-time: 2025-09-22 14:29:55.618000 2026-04-16 14:26:41.001 | HD Request # 52 | Using server: ds26.sierracharts.com port 10149 2026-04-16 14:26:41.003 | Socket (4) | Creating socket. 2026-04-16 14:26:41.004 | Socket (4) | New receive buffer size: 0 2026-04-16 14:26:41.004 | Socket (4) | Connecting to IP: 64.152.155.17. 2026-04-16 14:26:41.184 | HD Request # 52 | Setting DTC encoding to Binary VLS 2026-04-16 14:26:41.184 | HD Request # 52 | Sending historical data logon request message. 2026-04-16 14:26:41.300 | HD Request # 52 | Requesting Intraday data. Start date-time: 2025-09-22 14:29:55. Record interval: 0. Symbol: CLV25 2026-04-16 14:26:41.389 | HD Request # 52 | Decompressing data. 2026-04-16 14:26:41.480 | HD Request # 52 | Receiving Intraday data for F.US.CLEV25 starting at 2025-09-22 14:29:55.086000 2026-04-16 14:26:41.480 | Socket (4) | CloseSocket call. 2026-04-16 14:26:41.484 | Socket (4) | Shutdown started. Waiting for graceful close. 2026-04-16 14:26:41.484 | Historical data download thread signaled to stop. 2026-04-16 14:26:41.485 | HD Request # 52 | Received 2 Intraday data records from 2025-09-22 14:29:55.086000 to 2025-09-22 14:29:55.618000 (0.5 seconds. Delay: 206.0 days) and wrote 0 records for F.US.CLEV25 2026-04-16 14:26:41.485 | HD Request # 52 | Add time&sales data | Remembered last file record date-time: 2025-09-22 18:29:55.618000 2026-04-16 14:26:41.486 | HD Request # 52 | Completion time: 1s. 2026-04-16 14:26:41.486 | HD Request # 52 | Intraday data download complete for F.US.CLEV25. Unique request ID: 52 2026-04-16 14:26:41.486 | Removing historical data download ID 52. 2026-04-16 14:26:41.486 | Real-time Intraday chart data file updates started for F.US.CLEV25 2026-04-16 14:26:41.486 | Intraday chart data file opened for F.US.CLEV25 2026-04-16 14:26:41.486 | HD Request # 52 | Enabling Intraday chart updating for symbol. 2026-04-16 14:26:41.486 | 2026-04-16 14:26:41.486 | Triggering next historical data download in queue. 2026-04-16 14:26:41.486 | HD Request # 53 | Downloading Intraday chart data for F.US.EPU25 to the file F.US.EPU25.scid. Service: cme 2026-04-16 14:26:41.490 | HD Request # 53 | Download start date-time: 2025-09-19 09:29:58.000000. File last date-time: 2025-09-19 09:29:58.698000 2026-04-16 14:26:41.491 | HD Request # 53 | Using server: ds28.sierracharts.com port 10150 2026-04-16 14:26:41.491 | Socket (5) | Creating socket. 2026-04-16 14:26:41.491 | Socket (5) | New receive buffer size: 0 2026-04-16 14:26:41.491 | Socket (5) | Connecting to IP: 67.214.125.5. 2026-04-16 14:26:41.571 | Socket (4) | Socket gracefully closed by remote side. 2026-04-16 14:26:41.572 | Socket (4) | Closed. 2026-04-16 14:26:41.855 | HD Request # 53 | Setting DTC encoding to Binary VLS 2026-04-16 14:26:41.855 | HD Request # 53 | Sending historical data logon request message. 2026-04-16 14:26:42.005 | HD Request # 53 | Requesting Intraday data. Start date-time: 2025-09-19 09:29:58. Record interval: 0. Symbol: ESU25 2026-04-16 14:26:42.100 | HD Request # 53 | Decompressing data. 2026-04-16 14:26:42.193 | HD Request # 53 | Receiving Intraday data for F.US.EPU25 starting at 2025-09-19 09:29:58.697000 2026-04-16 14:26:42.193 | Socket (5) | CloseSocket call. 2026-04-16 14:26:42.194 | Socket (5) | Shutdown started. Waiting for graceful close. 2026-04-16 14:26:42.194 | Historical data download thread signaled to stop. 2026-04-16 14:26:42.194 | HD Request # 53 | Received 5 Intraday data records from 2025-09-19 09:29:58.697000 to 2025-09-19 09:29:58.698000 (0.0 seconds. Delay: 209.2 days) and wrote 0 records for F.US.EPU25 2026-04-16 14:26:42.195 | HD Request # 53 | Add time&sales data | Remembered last file record date-time: 2025-09-19 13:29:58.698000 2026-04-16 14:26:42.195 | HD Request # 53 | Completion time: 1s. 2026-04-16 14:26:42.195 | HD Request # 53 | Intraday data download complete for F.US.EPU25. Unique request ID: 53 2026-04-16 14:26:42.195 | Removing historical data download ID 53. 2026-04-16 14:26:42.195 | Real-time Intraday chart data file updates started for F.US.EPU25 2026-04-16 14:26:42.195 | Intraday chart data file opened for F.US.EPU25 2026-04-16 14:26:42.195 | HD Request # 53 | Enabling Intraday chart updating for symbol. 2026-04-16 14:26:42.195 | 2026-04-16 14:26:42.195 | Triggering next historical data download in queue. 2026-04-16 14:26:42.195 | HD Request # 54 | Downloading Intraday chart data for F.US.CLEM26 to the file F.US.CLEM26.scid. Service: nymex 2026-04-16 14:26:42.196 | HD Request # 54 | Download start date-time: 2026-04-16 12:57:19.000000. File last date-time: 2026-04-16 12:57:19.058002 2026-04-16 14:26:42.197 | HD Request # 54 | Using server: ds32.sierracharts.com port 10149 2026-04-16 14:26:42.197 | Socket (4) | Creating socket. 2026-04-16 14:26:42.198 | Socket (4) | New receive buffer size: 0 2026-04-16 14:26:42.198 | Socket (4) | Connecting to IP: 69.39.70.248. 2026-04-16 14:26:42.287 | Socket (5) | Socket gracefully closed by remote side. 2026-04-16 14:26:42.287 | Socket (5) | Closed. 2026-04-16 14:26:42.387 | HD Request # 54 | Setting DTC encoding to Binary VLS 2026-04-16 14:26:42.387 | HD Request # 54 | Sending historical data logon request message. 2026-04-16 14:26:42.513 | HD Request # 54 | Requesting Intraday data. Start date-time: 2026-04-16 12:57:19. Record interval: 0. Symbol: CLM26 2026-04-16 14:26:42.609 | HD Request # 54 | Decompressing data. 2026-04-16 14:26:42.727 | HD Request # 54 | Receiving Intraday data for F.US.CLEM26 starting at 2026-04-16 12:57:19.058000 2026-04-16 14:26:42.913 | Socket (4) | CloseSocket call. 2026-04-16 14:26:42.914 | Socket (4) | Shutdown started. Waiting for graceful close. 2026-04-16 14:26:42.914 | Historical data download thread signaled to stop. 2026-04-16 14:26:42.915 | HD Request # 54 | Timestamp of first Intraday data file record written: 2026-04-16 12:57:27.030000. 2026-04-16 14:26:42.915 | HD Request # 54 | Received 13674 Intraday data records from 2026-04-16 12:57:19.058000 to 2026-04-16 14:26:41.465000 (89.4 minutes. Delay: 1.5 seconds) and wrote 13671 records for F.US.CLEM26 2026-04-16 14:26:42.927 | HD Request # 54 | Add time&sales data | Remembered last file record date-time: 2026-04-16 18:26:41.465000 2026-04-16 14:26:42.927 | HD Request # 54 | Completion time: 0s. 2026-04-16 14:26:42.927 | HD Request # 54 | Intraday data download complete for F.US.CLEM26. Unique request ID: 54 2026-04-16 14:26:42.927 | Removing historical data download ID 54. 2026-04-16 14:26:42.927 | Real-time Intraday chart data file updates started for F.US.CLEM26 2026-04-16 14:26:42.927 | Intraday chart data file opened for F.US.CLEM26 2026-04-16 14:26:42.927 | HD Request # 54 | Enabling Intraday chart updating for symbol. 2026-04-16 14:26:42.927 | 2026-04-16 14:26:42.927 | No download requests in the queue to start downloads for. 2026-04-16 14:26:43.005 | Socket (4) | Socket gracefully closed by remote side. 2026-04-16 14:26:43.006 | Socket (4) | Closed. 2026-04-16 14:26:48.588 | Opened cached Intraday file: C:\SierraChart\Data\F.US.CLEM26.scid. Thread ID: 16976 2026-04-16 14:26:50.238 | CQG WebSocket socket (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. * 2026-04-16 14:26:50.238 | CQG WebSocket socket (1) | Write has completed. Shutdown being performed. 2026-04-16 14:26:50.238 | CQG WebSocket socket (1) | Shutdown started. Waiting for graceful close. 2026-04-16 14:26:50.239 | CQG WebSocket socket (1) | Socket gracefully closed by remote side. 2026-04-16 14:26:50.240 | CQG WebSocket socket (1) | Closed. 2026-04-16 21:43:55.023 | The data feed was lost. There was no activity for at least 60.0 seconds. 2026-04-16 21:43:55.024 | Connection to the external service has been lost. 2026-04-16 21:43:55.091 | DTC Client socket (3) | Socket gracefully closed by remote side. 2026-04-16 21:43:55.143 | CQG WebSocket | Timeout waiting for pong message from server. 2026-04-16 21:43:55.144 | CQG WebAPI | WebSocket closed. 2026-04-16 21:43:55.144 | Denali Data Feed | There has been no activity on the network socket for 6h 16m 41s. Will reconnect. 2026-04-16 21:43:55.144 | Denali Data Feed | Waiting for socket receive thread to end 2026-04-16 21:43:55.152 | DTC Client socket (3) | CloseSocket call. 2026-04-16 21:43:55.152 | Denali Data Feed | Disconnected from the server. 2026-04-16 21:43:55.153 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds. 2026-04-16 21:43:55.154 | CQG WebAPI | Sending Web API Logoff message. 2026-04-16 21:43:55.155 | CQG WebSocket socket (2) | CloseSocket call. 2026-04-16 21:43:55.155 | CQG WebSocket socket (2) | Max send buffers used during socket life: 3 2026-04-16 21:43:55.155 | CQG WebSocket socket (2) | Max send buffer size during socket life: 491 2026-04-16 21:43:55.155 | CQG WebSocket | WebSocket closed. 2026-04-16 21:43:55.155 | CQG WebAPI | WebSocket closed. 2026-04-16 21:43:55.159 | CQG WebAPI | Disconnected. 2026-04-16 21:43:55.160 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-04-16 21:43:55.171 | DTC Client socket (3) | Write in progress. Shutdown being delayed. PendingSize=0 2026-04-16 21:43:55.171 | CQG WebSocket socket (2) | Write in progress. Shutdown being delayed. PendingSize=0 2026-04-16 21:43:55.388 | DTC Client socket (3) | Write has completed. Shutdown being performed. 2026-04-16 21:43:55.388 | DTC Client socket (3) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2026-04-16 21:43:55.388 | DTC Client socket (3) | Closed. 2026-04-16 21:43:56.151 | Sierra Chart account data changed. Requesting updated account information. 2026-04-16 21:43:57.158 | 2026-04-16 21:43:57.160 | CQG WebAPI | Connecting to server api.cqg.com 2026-04-16 21:43:57.160 | CQG WebSocket | Connecting to WebSocket server api.cqg.com:443 2026-04-16 21:43:57.535 | CQG WebSocket socket (1) | Creating socket. Using TLS 1.2. 2026-04-16 21:43:57.535 | CQG WebSocket socket (1) | New receive buffer size: 0 2026-04-16 21:43:57.535 | CQG WebSocket socket (1) | Connecting to IP: 195.166.124.175. 2026-04-16 21:43:59.302 | Successfully processed Sierra Chart account data. 2026-04-16 21:43:59.303 | Requested user files to download. 2026-04-16 21:43:59.303 | CQG WebSocket | Opening WebSocket. 2026-04-16 21:43:59.303 | CQG WebSocket | Sending WebSocket handshake. 2026-04-16 21:43:59.307 | Denali Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 443 2026-04-16 21:43:59.351 | CQG WebSocket | Server header | HTTP/1.1 101 Switching Protocols 2026-04-16 21:43:59.351 | CQG WebSocket | Server header | Connection: Upgrade 2026-04-16 21:43:59.351 | CQG WebSocket | Server header | Sec-WebSocket-Accept: 9gZtYZy8cMvoKaxxfiywHFZAj44= 2026-04-16 21:43:59.351 | CQG WebSocket | Server header | Server: WebSocket++/0.8.2 2026-04-16 21:43:59.351 | CQG WebSocket | Server header | Upgrade: websocket 2026-04-16 21:43:59.351 | CQG WebSocket | Server header | 2026-04-16 21:43:59.351 | CQG WebSocket | Web socket state is now open. 2026-04-16 21:43:59.351 | CQG WebAPI | WebSocket connected. 2026-04-16 21:43:59.352 | CQG WebAPI | Sending market data logon message. 2026-04-16 21:43:59.409 | DTC Client socket (5) | Creating socket. 2026-04-16 21:43:59.409 | DTC Client socket (5) | New receive buffer size: 0 2026-04-16 21:43:59.409 | DTC Client socket (5) | Connecting to IP: 67.214.125.6. 2026-04-16 21:43:59.536 | Denali Data Feed | Network connection to server complete. 2026-04-16 21:43:59.536 | Denali Data Feed | Starting socket receive thread. 2026-04-16 21:43:59.536 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard 2026-04-16 21:43:59.607 | CQG WebAPI | Base Time: 2026-03-28T18:10:42. 2026-03-28 18:10:42 2026-04-16 21:43:59.607 | CQG WebAPI | Logon successful. Session Token = D/hUHC/dnLEGQtNRAcqFGMIbdOH6PU27jZqVR114FLMbX7m4yLjURzzwB5E6hpt9bPnkMtHML2S 2026-04-16 21:43:59.607 | CQG WebAPI | Connection to server complete. 2026-04-16 21:43:59.607 | Denali Data Feed | Waiting for socket receive thread to end 2026-04-16 21:43:59.608 | DTC Client socket (5) | CloseSocket call. 2026-04-16 21:43:59.608 | Denali Data Feed | Disconnected from the server. 2026-04-16 21:43:59.608 | DTC Client socket (5) | Write in progress. Shutdown being delayed. PendingSize=0 2026-04-16 21:43:59.618 | No download requests in the queue to start downloads for. | Number times message added: 3 2026-04-16 21:43:59.618 | Updated verified funded futures trading account ending date to: 2026-05-17 01:43:59 2026-04-16 21:43:59.640 | DTC Client socket (5) | Write has completed. Shutdown being performed. 2026-04-16 21:43:59.640 | DTC Client socket (5) | Shutdown started. Waiting for graceful close. 2026-04-16 21:43:59.649 | CQG WebAPI | Sending Trade Accounts request message. 2026-04-16 21:43:59.732 | DTC Client socket (5) | Socket gracefully closed by remote side. 2026-04-16 21:43:59.732 | DTC Client socket (5) | Closed. 2026-04-16 21:43:59.744 | CQG WebAPI | Brokerage name: AMP. Account Name: 220033 2026-04-16 21:43:59.744 | Updated verified funded futures trading account ending date to: 2026-05-17 01:43:59 2026-04-16 21:43:59.744 | CQG WebAPI | Sending collateral subscribe request. 2026-04-16 21:43:59.859 | CQG WebAPI | Sending positions subscribe request. RequestID: 431558 2026-04-16 21:43:59.859 | CQG WebAPI | Sending orders subscribe request. RequestID: 431559 2026-04-16 21:43:59.920 | Mapping F.US.CLEM26 to CLM26. Service code: nymex 2026-04-16 21:43:59.920 | Using symbol data fast lookup vector 2026-04-16 21:43:59.921 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEM26 (CLM26). ID: 1 Service code: nymex 2026-04-16 21:43:59.921 | Denali Data Feed | Connecting to the server ds32-2.sierracharts.com. Port 443 2026-04-16 21:43:59.921 | CQG WebAPI | Sending symbol resolution request for F.US.CLEM26. ID: 431560 2026-04-16 21:43:59.921 | Denali Data Feed | Requesting security definition data for: F.US.CLEM26 (CLM26). ID: 1 2026-04-16 21:43:59.922 | Added historical Intraday data request for F.US.CLEM26 to the queue. 2026-04-16 21:43:59.922 | Intraday data recording state for symbol F.US.CLEM26 is set to download 'Pending'. 2026-04-16 21:43:59.922 | Triggering next historical data download in queue. 2026-04-16 21:43:59.934 | DTC Client socket (3) | Creating socket. 2026-04-16 21:43:59.934 | DTC Client socket (3) | New receive buffer size: 0 2026-04-16 21:43:59.934 | DTC Client socket (3) | Connecting to IP: 69.39.70.249. 2026-04-16 21:44:00.064 | Delaying start of download for F.US.CLEM26. 2026-04-16 21:44:00.066 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEM26. Search Symbol: F.US.CLEM26. Request ID: 431560. Contract ID: 1. 2026-04-16 21:44:00.113 | Denali Data Feed | Network connection to server complete. 2026-04-16 21:44:00.113 | Denali Data Feed | Starting socket receive thread. 2026-04-16 21:44:00.113 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard 2026-04-16 21:44:00.232 | Mapping F.US.CLEV25 to CLV25. Service code: nymex 2026-04-16 21:44:00.233 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEV25 (CLV25). ID: 2 Service code: nymex 2026-04-16 21:44:00.233 | CQG WebAPI | Sending symbol resolution request for F.US.CLEV25. ID: 431561 2026-04-16 21:44:00.233 | Denali Data Feed | Requesting security definition data for: F.US.CLEV25 (CLV25). ID: 2 2026-04-16 21:44:00.233 | Added historical Intraday data request for F.US.CLEV25 to the queue. 2026-04-16 21:44:00.234 | Intraday data recording state for symbol F.US.CLEV25 is set to download 'Pending'. 2026-04-16 21:44:00.234 | Triggering next historical data download in queue. 2026-04-16 21:44:00.248 | Mapping F.US.EPU25 to ESU25. Service code: cme 2026-04-16 21:44:00.248 | Denali Data Feed | Starting real-time market data updates for: F.US.EPU25 (ESU25). ID: 3 Service code: cme 2026-04-16 21:44:00.248 | CQG WebAPI | Sending symbol resolution request for F.US.EPU25. ID: 431562 2026-04-16 21:44:00.248 | Denali Data Feed | Requesting security definition data for: F.US.EPU25 (ESU25). ID: 3 2026-04-16 21:44:00.248 | Added historical Intraday data request for F.US.EPU25 to the queue. 2026-04-16 21:44:00.248 | Intraday data recording state for symbol F.US.EPU25 is set to download 'Pending'. 2026-04-16 21:44:00.249 | Triggering next historical data download in queue. 2026-04-16 21:44:00.309 | Denali Data Feed | Setting DTC encoding to Binary VLS 2026-04-16 21:44:00.309 | Denali Data Feed | Sending logon request message. 2026-04-16 21:44:00.341 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEV25. Search Symbol: F.US.CLEV25. Request ID: 431561. Contract ID: 3. 2026-04-16 21:44:00.354 | CQG WebAPI | Received symbol resolution report for symbol F.US.EPU25. Search Symbol: F.US.EPU25. Request ID: 431562. Contract ID: 4. 2026-04-16 21:44:00.726 | Mapping F.US.EPH23 to ESH23. Service code: cme 2026-04-16 21:44:00.726 | Denali Data Feed | Starting real-time market data updates for: F.US.EPH23 (ESH23). ID: 4 Service code: cme 2026-04-16 21:44:00.726 | CQG WebAPI | Sending symbol resolution request for F.US.EPH23. ID: 431563 2026-04-16 21:44:00.726 | Denali Data Feed | Requesting security definition data for: F.US.EPH23 (ESH23). ID: 4 2026-04-16 21:44:00.727 | Mapping F.US.EPM23 to ESM23. Service code: cme 2026-04-16 21:44:00.727 | Denali Data Feed | Starting real-time market data updates for: F.US.EPM23 (ESM23). ID: 5 Service code: cme 2026-04-16 21:44:00.727 | CQG WebAPI | Sending symbol resolution request for F.US.EPM23. ID: 431564 2026-04-16 21:44:00.727 | Denali Data Feed | Requesting security definition data for: F.US.EPM23 (ESM23). ID: 5 2026-04-16 21:44:00.727 | Mapping F.US.EPU23 to ESU23. Service code: cme 2026-04-16 21:44:00.727 | Denali Data Feed | Starting real-time market data updates for: F.US.EPU23 (ESU23). ID: 6 Service code: cme 2026-04-16 21:44:00.727 | CQG WebAPI | Sending symbol resolution request for F.US.EPU23. ID: 431565 2026-04-16 21:44:00.727 | Denali Data Feed | Requesting security definition data for: F.US.EPU23 (ESU23). ID: 6 2026-04-16 21:44:00.727 | Mapping F.US.EPZ23 to ESZ23. Service code: cme 2026-04-16 21:44:00.728 | Denali Data Feed | Starting real-time market data updates for: F.US.EPZ23 (ESZ23). ID: 7 Service code: cme 2026-04-16 21:44:00.728 | CQG WebAPI | Sending symbol resolution request for F.US.EPZ23. ID: 431566 2026-04-16 21:44:00.728 | Denali Data Feed | Requesting security definition data for: F.US.EPZ23 (ESZ23). ID: 7 2026-04-16 21:44:00.728 | Mapping F.US.EPH24 to ESH24. Service code: cme 2026-04-16 21:44:00.728 | Denali Data Feed | Starting real-time market data updates for: F.US.EPH24 (ESH24). ID: 8 Service code: cme 2026-04-16 21:44:00.728 | CQG WebAPI | Sending symbol resolution request for F.US.EPH24. ID: 431567 2026-04-16 21:44:00.728 | Denali Data Feed | Requesting security definition data for: F.US.EPH24 (ESH24). ID: 8 2026-04-16 21:44:00.728 | Mapping F.US.CLEF23 to CLF23. Service code: nymex 2026-04-16 21:44:00.729 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEF23 (CLF23). ID: 9 Service code: nymex 2026-04-16 21:44:00.729 | CQG WebAPI | Sending symbol resolution request for F.US.CLEF23. ID: 431568 2026-04-16 21:44:00.729 | Denali Data Feed | Requesting security definition data for: F.US.CLEF23 (CLF23). ID: 9 2026-04-16 21:44:00.729 | Mapping F.US.CLEG23 to CLG23. Service code: nymex 2026-04-16 21:44:00.730 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEG23 (CLG23). ID: 10 Service code: nymex 2026-04-16 21:44:00.730 | CQG WebAPI | Sending symbol resolution request for F.US.CLEG23. ID: 431569 2026-04-16 21:44:00.730 | Denali Data Feed | Requesting security definition data for: F.US.CLEG23 (CLG23). ID: 10 2026-04-16 21:44:00.731 | Mapping F.US.CLEH23 to CLH23. Service code: nymex 2026-04-16 21:44:00.731 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEH23 (CLH23). ID: 11 Service code: nymex 2026-04-16 21:44:00.731 | CQG WebAPI | Sending symbol resolution request for F.US.CLEH23. ID: 431570 2026-04-16 21:44:00.731 | Denali Data Feed | Requesting security definition data for: F.US.CLEH23 (CLH23). ID: 11 2026-04-16 21:44:00.731 | Mapping F.US.CLEJ23 to CLJ23. Service code: nymex 2026-04-16 21:44:00.731 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEJ23 (CLJ23). ID: 12 Service code: nymex 2026-04-16 21:44:00.731 | CQG WebAPI | Sending symbol resolution request for F.US.CLEJ23. ID: 431571 2026-04-16 21:44:00.731 | Denali Data Feed | Requesting security definition data for: F.US.CLEJ23 (CLJ23). ID: 12 2026-04-16 21:44:00.732 | Mapping F.US.CLEK23 to CLK23. Service code: nymex 2026-04-16 21:44:00.732 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEK23 (CLK23). ID: 13 Service code: nymex 2026-04-16 21:44:00.732 | CQG WebAPI | Sending symbol resolution request for F.US.CLEK23. ID: 431572 2026-04-16 21:44:00.732 | Denali Data Feed | Requesting security definition data for: F.US.CLEK23 (CLK23). ID: 13 2026-04-16 21:44:00.732 | Mapping F.US.CLEM23 to CLM23. Service code: nymex 2026-04-16 21:44:00.732 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEM23 (CLM23). ID: 14 Service code: nymex 2026-04-16 21:44:00.732 | CQG WebAPI | Sending symbol resolution request for F.US.CLEM23. ID: 431573 2026-04-16 21:44:00.732 | Denali Data Feed | Requesting security definition data for: F.US.CLEM23 (CLM23). ID: 14 2026-04-16 21:44:00.732 | Mapping F.US.CLEN23 to CLN23. Service code: nymex 2026-04-16 21:44:00.733 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEN23 (CLN23). ID: 15 Service code: nymex 2026-04-16 21:44:00.733 | CQG WebAPI | Sending symbol resolution request for F.US.CLEN23. ID: 431574 2026-04-16 21:44:00.733 | Denali Data Feed | Requesting security definition data for: F.US.CLEN23 (CLN23). ID: 15 2026-04-16 21:44:00.733 | Mapping F.US.CLEQ23 to CLQ23. Service code: nymex 2026-04-16 21:44:00.733 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEQ23 (CLQ23). ID: 16 Service code: nymex 2026-04-16 21:44:00.733 | CQG WebAPI | Sending symbol resolution request for F.US.CLEQ23. ID: 431575 2026-04-16 21:44:00.733 | Denali Data Feed | Requesting security definition data for: F.US.CLEQ23 (CLQ23). ID: 16 2026-04-16 21:44:00.733 | Mapping F.US.CLEU23 to CLU23. Service code: nymex 2026-04-16 21:44:00.733 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEU23 (CLU23). ID: 17 Service code: nymex 2026-04-16 21:44:00.733 | CQG WebAPI | Sending symbol resolution request for F.US.CLEU23. ID: 431576 2026-04-16 21:44:00.733 | Denali Data Feed | Requesting security definition data for: F.US.CLEU23 (CLU23). ID: 17 2026-04-16 21:44:00.733 | Mapping F.US.CLEV23 to CLV23. Service code: nymex 2026-04-16 21:44:00.733 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEV23 (CLV23). ID: 18 Service code: nymex 2026-04-16 21:44:00.733 | CQG WebAPI | Sending symbol resolution request for F.US.CLEV23. ID: 431577 2026-04-16 21:44:00.733 | Denali Data Feed | Requesting security definition data for: F.US.CLEV23 (CLV23). ID: 18 2026-04-16 21:44:00.733 | Mapping F.US.CLEX23 to CLX23. Service code: nymex 2026-04-16 21:44:00.733 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEX23 (CLX23). ID: 19 Service code: nymex 2026-04-16 21:44:00.733 | CQG WebAPI | Sending symbol resolution request for F.US.CLEX23. ID: 431578 2026-04-16 21:44:00.734 | Denali Data Feed | Requesting security definition data for: F.US.CLEX23 (CLX23). ID: 19 2026-04-16 21:44:00.734 | Mapping F.US.CLEZ23 to CLZ23. Service code: nymex 2026-04-16 21:44:00.734 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEZ23 (CLZ23). ID: 20 Service code: nymex 2026-04-16 21:44:00.734 | CQG WebAPI | Sending symbol resolution request for F.US.CLEZ23. ID: 431579 2026-04-16 21:44:00.734 | Denali Data Feed | Requesting security definition data for: F.US.CLEZ23 (CLZ23). ID: 20 2026-04-16 21:44:00.734 | Mapping F.US.CLEF24 to CLF24. Service code: nymex 2026-04-16 21:44:00.734 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEF24 (CLF24). ID: 21 Service code: nymex 2026-04-16 21:44:00.734 | CQG WebAPI | Sending symbol resolution request for F.US.CLEF24. ID: 431580 2026-04-16 21:44:00.734 | Denali Data Feed | Requesting security definition data for: F.US.CLEF24 (CLF24). ID: 21 2026-04-16 21:44:00.734 | Mapping F.US.CLEG24 to CLG24. Service code: nymex 2026-04-16 21:44:00.734 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEG24 (CLG24). ID: 22 Service code: nymex 2026-04-16 21:44:00.734 | CQG WebAPI | Sending symbol resolution request for F.US.CLEG24. ID: 431581 2026-04-16 21:44:00.734 | Denali Data Feed | Requesting security definition data for: F.US.CLEG24 (CLG24). ID: 22 2026-04-16 21:44:00.735 | CQG WebAPI | Received symbol resolution report for symbol F.US.EPH23. Search Symbol: F.US.EPH23. Request ID: 431563. Contract ID: 5. 2026-04-16 21:44:00.735 | CQG WebAPI | Received symbol resolution report for symbol F.US.EPM23. Search Symbol: F.US.EPM23. Request ID: 431564. Contract ID: 6. 2026-04-16 21:44:00.735 | CQG WebAPI | Received symbol resolution report for symbol F.US.EPU23. Search Symbol: F.US.EPU23. Request ID: 431565. Contract ID: 7. 2026-04-16 21:44:00.735 | CQG WebAPI | Received symbol resolution report for symbol F.US.EPZ23. Search Symbol: F.US.EPZ23. Request ID: 431566. Contract ID: 8. 2026-04-16 21:44:00.735 | CQG WebAPI | Received symbol resolution report for symbol F.US.EPH24. Search Symbol: F.US.EPH24. Request ID: 431567. Contract ID: 9. 2026-04-16 21:44:00.816 | Denali Data Feed | Received logon response. 2026-04-16 21:44:00.816 | Denali Data Feed | Server Name: SC Realtime Server. 2026-04-16 21:44:00.816 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8 2026-04-16 21:44:00.816 | Denali Data Feed | Successfully connected. 2026-04-16 21:44:00.816 | Denali Data Feed | Trading is not supported. 2026-04-16 21:44:00.816 | Denali Data Feed | MarketDepthIsSupported: 1 2026-04-16 21:44:00.816 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEF23 -> CLF23 2026-04-16 21:44:00.816 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEF24 -> CLF24 2026-04-16 21:44:00.816 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEG23 -> CLG23 2026-04-16 21:44:00.816 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEG24 -> CLG24 2026-04-16 21:44:00.816 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEH23 -> CLH23 2026-04-16 21:44:00.816 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEJ23 -> CLJ23 2026-04-16 21:44:00.816 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEK23 -> CLK23 2026-04-16 21:44:00.816 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEM23 -> CLM23 2026-04-16 21:44:00.816 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEM26 -> CLM26 2026-04-16 21:44:00.816 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEN23 -> CLN23 2026-04-16 21:44:00.816 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEQ23 -> CLQ23 2026-04-16 21:44:00.816 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEU23 -> CLU23 2026-04-16 21:44:00.816 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEV23 -> CLV23 2026-04-16 21:44:00.816 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEV25 -> CLV25 2026-04-16 21:44:00.816 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEX23 -> CLX23 2026-04-16 21:44:00.816 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEZ23 -> CLZ23 2026-04-16 21:44:00.816 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.EPH23 -> ESH23 2026-04-16 21:44:00.816 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.EPH24 -> ESH24 2026-04-16 21:44:00.816 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.EPM23 -> ESM23 2026-04-16 21:44:00.816 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.EPU23 -> ESU23 2026-04-16 21:44:00.816 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.EPU25 -> ESU25 2026-04-16 21:44:00.816 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.EPZ23 -> ESZ23 2026-04-16 21:44:00.830 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEF23. Search Symbol: F.US.CLEF23. Request ID: 431568. Contract ID: 10. 2026-04-16 21:44:00.830 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEG23. Search Symbol: F.US.CLEG23. Request ID: 431569. Contract ID: 11. 2026-04-16 21:44:00.830 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEH23. Search Symbol: F.US.CLEH23. Request ID: 431570. Contract ID: 12. 2026-04-16 21:44:00.830 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEM23. Search Symbol: F.US.CLEM23. Request ID: 431573. Contract ID: 13. 2026-04-16 21:44:00.830 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEJ23. Search Symbol: F.US.CLEJ23. Request ID: 431571. Contract ID: 14. 2026-04-16 21:44:00.830 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEK23. Search Symbol: F.US.CLEK23. Request ID: 431572. Contract ID: 15. 2026-04-16 21:44:00.830 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEN23. Search Symbol: F.US.CLEN23. Request ID: 431574. Contract ID: 16. 2026-04-16 21:44:00.830 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEQ23. Search Symbol: F.US.CLEQ23. Request ID: 431575. Contract ID: 17. 2026-04-16 21:44:00.830 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEV23. Search Symbol: F.US.CLEV23. Request ID: 431577. Contract ID: 18. 2026-04-16 21:44:00.830 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEU23. Search Symbol: F.US.CLEU23. Request ID: 431576. Contract ID: 19. 2026-04-16 21:44:00.836 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEX23. Search Symbol: F.US.CLEX23. Request ID: 431578. Contract ID: 20. 2026-04-16 21:44:00.839 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEZ23. Search Symbol: F.US.CLEZ23. Request ID: 431579. Contract ID: 21. 2026-04-16 21:44:00.839 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEF24. Search Symbol: F.US.CLEF24. Request ID: 431580. Contract ID: 22. 2026-04-16 21:44:00.917 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEG24. Search Symbol: F.US.CLEG24. Request ID: 431581. Contract ID: 23. 2026-04-16 21:44:01.001 | Denali Data Feed | Real-time data for symbol F.US.CLEF23 is currently unavailable. 2026-04-16 21:44:01.002 | Denali Data Feed | Received security definition for symbol F.US.CLEF23 2026-04-16 21:44:01.002 | Denali Data Feed | Real-time data for symbol F.US.CLEF24 is currently unavailable. 2026-04-16 21:44:01.002 | Denali Data Feed | Received security definition for symbol F.US.CLEF24 2026-04-16 21:44:01.002 | Denali Data Feed | Real-time data for symbol F.US.CLEG23 is currently unavailable. 2026-04-16 21:44:01.002 | Denali Data Feed | Received security definition for symbol F.US.CLEG23 2026-04-16 21:44:01.002 | Denali Data Feed | Real-time data for symbol F.US.CLEG24 is currently unavailable. 2026-04-16 21:44:01.002 | Denali Data Feed | Received security definition for symbol F.US.CLEG24 2026-04-16 21:44:01.002 | Denali Data Feed | Real-time data for symbol F.US.CLEH23 is currently unavailable. 2026-04-16 21:44:01.002 | Denali Data Feed | Received security definition for symbol F.US.CLEH23 2026-04-16 21:44:01.002 | Denali Data Feed | Real-time data for symbol F.US.CLEJ23 is currently unavailable. 2026-04-16 21:44:01.002 | Denali Data Feed | Received security definition for symbol F.US.CLEJ23 2026-04-16 21:44:01.002 | Denali Data Feed | Real-time data for symbol F.US.CLEK23 is currently unavailable. 2026-04-16 21:44:01.002 | Denali Data Feed | Received security definition for symbol F.US.CLEK23 2026-04-16 21:44:01.002 | Denali Data Feed | Real-time data for symbol F.US.CLEM23 is currently unavailable. 2026-04-16 21:44:01.002 | Denali Data Feed | Received security definition for symbol F.US.CLEM23 2026-04-16 21:44:01.002 | Denali Data Feed | Setting external service identifier for symbol F.US.CLEM26 to 670557 2026-04-16 21:44:01.002 | Denali Data Feed | Received security definition for symbol F.US.CLEM26 2026-04-16 21:44:01.002 | Denali Data Feed | Real-time data for symbol F.US.CLEN23 is currently unavailable. 2026-04-16 21:44:01.002 | Denali Data Feed | Received security definition for symbol F.US.CLEN23 2026-04-16 21:44:01.002 | Denali Data Feed | Real-time data for symbol F.US.CLEQ23 is currently unavailable. 2026-04-16 21:44:01.002 | Denali Data Feed | Received security definition for symbol F.US.CLEQ23 2026-04-16 21:44:01.002 | Denali Data Feed | Real-time data for symbol F.US.CLEU23 is currently unavailable. 2026-04-16 21:44:01.002 | Denali Data Feed | Received security definition for symbol F.US.CLEU23 2026-04-16 21:44:01.002 | Denali Data Feed | Real-time data for symbol F.US.CLEV23 is currently unavailable. 2026-04-16 21:44:01.002 | Denali Data Feed | Received security definition for symbol F.US.CLEV23 2026-04-16 21:44:01.002 | Denali Data Feed | Real-time data for symbol F.US.CLEV25 is currently unavailable. 2026-04-16 21:44:01.002 | Denali Data Feed | Received security definition for symbol F.US.CLEV25 2026-04-16 21:44:01.002 | Denali Data Feed | Real-time data for symbol F.US.CLEX23 is currently unavailable. 2026-04-16 21:44:01.002 | Denali Data Feed | Received security definition for symbol F.US.CLEX23 2026-04-16 21:44:01.002 | Denali Data Feed | Real-time data for symbol F.US.CLEZ23 is currently unavailable. 2026-04-16 21:44:01.002 | Denali Data Feed | Received security definition for symbol F.US.CLEZ23 2026-04-16 21:44:01.002 | Denali Data Feed | Real-time data for symbol F.US.EPH23 is currently unavailable. 2026-04-16 21:44:01.002 | Denali Data Feed | Received security definition for symbol F.US.EPH23 2026-04-16 21:44:01.002 | Denali Data Feed | Real-time data for symbol F.US.EPH24 is currently unavailable. 2026-04-16 21:44:01.002 | Denali Data Feed | Received security definition for symbol F.US.EPH24 2026-04-16 21:44:01.002 | Denali Data Feed | Real-time data for symbol F.US.EPM23 is currently unavailable. 2026-04-16 21:44:01.002 | Denali Data Feed | Received security definition for symbol F.US.EPM23 2026-04-16 21:44:01.002 | Denali Data Feed | Real-time data for symbol F.US.EPU23 is currently unavailable. 2026-04-16 21:44:01.002 | Denali Data Feed | Received security definition for symbol F.US.EPU23 2026-04-16 21:44:01.002 | Denali Data Feed | Real-time data for symbol F.US.EPU25 is currently unavailable. 2026-04-16 21:44:01.002 | Denali Data Feed | Received security definition for symbol F.US.EPU25 2026-04-16 21:44:01.003 | Denali Data Feed | Real-time data for symbol F.US.EPZ23 is currently unavailable. 2026-04-16 21:44:01.003 | Denali Data Feed | Received security definition for symbol F.US.EPZ23 2026-04-16 21:44:04.619 | Requesting market depth updates for: F.US.CLEV25 if supported. NumLevels=100 2026-04-16 21:44:04.814 | Denali Data Feed | Clearing market depth for F.US.CLEV25 2026-04-16 21:44:06.069 | HD Request # 55 | Downloading Intraday chart data for F.US.CLEM26 to the file F.US.CLEM26.scid. Service: nymex 2026-04-16 21:44:06.071 | HD Request # 55 | Download start date-time: 2026-04-16 15:27:14.000000. File last date-time: 2026-04-16 15:27:14.071002 2026-04-16 21:44:06.073 | HD Request # 55 | Using server: ds26.sierracharts.com port 10150 2026-04-16 21:44:06.083 | Socket (4) | Creating socket. 2026-04-16 21:44:06.084 | Socket (4) | New receive buffer size: 0 2026-04-16 21:44:06.084 | Socket (4) | Connecting to IP: 64.152.155.17. 2026-04-16 21:44:06.267 | HD Request # 55 | Setting DTC encoding to Binary VLS 2026-04-16 21:44:06.267 | HD Request # 55 | Sending historical data logon request message. 2026-04-16 21:44:06.391 | HD Request # 55 | Requesting Intraday data. Start date-time: 2026-04-16 15:27:14. Record interval: 0. Symbol: CLM26 2026-04-16 21:44:06.479 | HD Request # 55 | Decompressing data. 2026-04-16 21:44:06.668 | HD Request # 55 | Receiving Intraday data for F.US.CLEM26 starting at 2026-04-16 15:27:14.071000 2026-04-16 21:44:06.755 | Socket (4) | CloseSocket call. 2026-04-16 21:44:06.755 | Socket (4) | Shutdown started. Waiting for graceful close. 2026-04-16 21:44:06.756 | Historical data download thread signaled to stop. 2026-04-16 21:44:06.757 | HD Request # 55 | Timestamp of first Intraday data file record written: 2026-04-16 15:27:16.478000. 2026-04-16 21:44:06.757 | HD Request # 55 | Received 9838 Intraday data records from 2026-04-16 15:27:14.071000 to 2026-04-16 21:43:32.180002 (6.3 hours. Delay: 34.6 seconds) and wrote 9835 records for F.US.CLEM26 2026-04-16 21:44:06.771 | HD Request # 55 | Add time&sales data | Remembered last file record date-time: 2026-04-17 01:43:32.180002 2026-04-16 21:44:06.772 | Added 5 Time and Sales records to Intraday data file for F.US.CLEM26 after download. 2026-04-16 21:44:06.772 | HD Request # 55 | Completion time: 0s. 2026-04-16 21:44:06.772 | HD Request # 55 | Intraday data download complete for F.US.CLEM26. Unique request ID: 55 2026-04-16 21:44:06.772 | Removing historical data download ID 55. 2026-04-16 21:44:06.772 | Real-time Intraday chart data file updates started for F.US.CLEM26 2026-04-16 21:44:06.772 | Intraday chart data file opened for F.US.CLEM26 2026-04-16 21:44:06.772 | HD Request # 55 | Enabling Intraday chart updating for symbol. 2026-04-16 21:44:06.772 | 2026-04-16 21:44:06.772 | Triggering next historical data download in queue. 2026-04-16 21:44:06.772 | HD Request # 56 | Downloading Intraday chart data for F.US.CLEV25 to the file F.US.CLEV25.scid. Service: nymex 2026-04-16 21:44:06.786 | HD Request # 56 | Download start date-time: 2025-09-22 14:29:55.000000. File last date-time: 2025-09-22 14:29:55.618000 2026-04-16 21:44:06.786 | HD Request # 56 | Using server: ds28.sierracharts.com port 10149 2026-04-16 21:44:06.796 | Socket (5) | Creating socket. 2026-04-16 21:44:06.796 | Socket (5) | New receive buffer size: 0 2026-04-16 21:44:06.796 | Socket (5) | Connecting to IP: 67.214.125.5. 2026-04-16 21:44:06.843 | Socket (4) | Socket gracefully closed by remote side. 2026-04-16 21:44:06.843 | Socket (4) | Closed. 2026-04-16 21:44:09.322 | Opened cached Intraday file: C:\SierraChart\Data\F.US.CLEM26.scid. Thread ID: 16976 2026-04-16 21:44:09.987 | HD Request # 56 | Setting DTC encoding to Binary VLS 2026-04-16 21:44:09.987 | HD Request # 56 | Sending historical data logon request message. 2026-04-16 21:44:10.113 | HD Request # 56 | Requesting Intraday data. Start date-time: 2025-09-22 14:29:55. Record interval: 0. Symbol: CLV25 2026-04-16 21:44:10.206 | HD Request # 56 | Decompressing data. 2026-04-16 21:44:10.298 | HD Request # 56 | Receiving Intraday data for F.US.CLEV25 starting at 2025-09-22 14:29:55.086000 2026-04-16 21:44:10.298 | Socket (5) | CloseSocket call. 2026-04-16 21:44:10.298 | Socket (5) | Shutdown started. Waiting for graceful close. 2026-04-16 21:44:10.299 | Historical data download thread signaled to stop. 2026-04-16 21:44:10.299 | HD Request # 56 | Received 2 Intraday data records from 2025-09-22 14:29:55.086000 to 2025-09-22 14:29:55.618000 (0.5 seconds. Delay: 206.3 days) and wrote 0 records for F.US.CLEV25 2026-04-16 21:44:10.300 | HD Request # 56 | Add time&sales data | Remembered last file record date-time: 2025-09-22 18:29:55.618000 2026-04-16 21:44:10.300 | HD Request # 56 | Completion time: 4s. 2026-04-16 21:44:10.300 | HD Request # 56 | Intraday data download complete for F.US.CLEV25. Unique request ID: 56 2026-04-16 21:44:10.300 | Removing historical data download ID 56. 2026-04-16 21:44:10.300 | Real-time Intraday chart data file updates started for F.US.CLEV25 2026-04-16 21:44:10.300 | Intraday chart data file opened for F.US.CLEV25 2026-04-16 21:44:10.300 | HD Request # 56 | Enabling Intraday chart updating for symbol. 2026-04-16 21:44:10.300 | 2026-04-16 21:44:10.300 | Triggering next historical data download in queue. 2026-04-16 21:44:10.300 | HD Request # 57 | Downloading Intraday chart data for F.US.EPU25 to the file F.US.EPU25.scid. Service: cme 2026-04-16 21:44:10.314 | HD Request # 57 | Download start date-time: 2025-09-19 09:29:58.000000. File last date-time: 2025-09-19 09:29:58.698000 2026-04-16 21:44:10.314 | HD Request # 57 | Using server: ds32.sierracharts.com port 10150 2026-04-16 21:44:10.325 | Socket (4) | Creating socket. 2026-04-16 21:44:10.325 | Socket (4) | New receive buffer size: 0 2026-04-16 21:44:10.325 | Socket (4) | Connecting to IP: 69.39.70.248. 2026-04-16 21:44:10.389 | Socket (5) | Socket gracefully closed by remote side. 2026-04-16 21:44:10.389 | Socket (5) | Closed. 2026-04-16 21:44:10.511 | HD Request # 57 | Setting DTC encoding to Binary VLS 2026-04-16 21:44:10.511 | HD Request # 57 | Sending historical data logon request message. 2026-04-16 21:44:10.634 | HD Request # 57 | Requesting Intraday data. Start date-time: 2025-09-19 09:29:58. Record interval: 0. Symbol: ESU25 2026-04-16 21:44:10.729 | HD Request # 57 | Decompressing data. 2026-04-16 21:44:10.820 | HD Request # 57 | Receiving Intraday data for F.US.EPU25 starting at 2025-09-19 09:29:58.697000 2026-04-16 21:44:10.820 | Socket (4) | CloseSocket call. 2026-04-16 21:44:10.820 | Socket (4) | Shutdown started. Waiting for graceful close. 2026-04-16 21:44:10.821 | Historical data download thread signaled to stop. 2026-04-16 21:44:10.821 | HD Request # 57 | Received 5 Intraday data records from 2025-09-19 09:29:58.697000 to 2025-09-19 09:29:58.698000 (0.0 seconds. Delay: 209.5 days) and wrote 0 records for F.US.EPU25 2026-04-16 21:44:10.821 | HD Request # 57 | Add time&sales data | Remembered last file record date-time: 2025-09-19 13:29:58.698000 2026-04-16 21:44:10.821 | HD Request # 57 | Completion time: 0s. 2026-04-16 21:44:10.821 | HD Request # 57 | Intraday data download complete for F.US.EPU25. Unique request ID: 57 2026-04-16 21:44:10.821 | Removing historical data download ID 57. 2026-04-16 21:44:10.821 | Real-time Intraday chart data file updates started for F.US.EPU25 2026-04-16 21:44:10.821 | Intraday chart data file opened for F.US.EPU25 2026-04-16 21:44:10.821 | HD Request # 57 | Enabling Intraday chart updating for symbol. 2026-04-16 21:44:10.821 | 2026-04-16 21:44:10.821 | No download requests in the queue to start downloads for. 2026-04-16 21:44:10.911 | Socket (4) | Socket gracefully closed by remote side. 2026-04-16 21:44:10.911 | Socket (4) | Closed. 2026-04-16 21:44:14.327 | CQG WebSocket socket (2) | Write has completed. Shutdown being performed. 2026-04-16 21:44:14.327 | CQG WebSocket socket (2) | Shutdown started. Waiting for graceful close. 2026-04-16 21:44:14.328 | CQG WebSocket socket (2) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. * 2026-04-16 21:44:14.328 | CQG WebSocket socket (2) | Socket gracefully closed by remote side. 2026-04-16 21:44:14.328 | CQG WebSocket socket (2) | Closed. 2026-04-16 21:44:19.741 | ExtendTheFundedTradingAccountStatusExpirationDate: Sending request. 2026-04-16 21:44:20.173 | ExtendTheFundedTradingAccountStatusExpirationDate | Result: {"Result":"The Funded Trading Account Status Expiration Date is more than 25 days into the future. The Date is currently: 2026-05-13"}. Success=true 2026-04-17 02:46:33.400 | DTC Client socket (3) | Socket gracefully closed by remote side. 2026-04-17 02:46:33.690 | The data feed was lost. There was no activity for at least 60.0 seconds. 2026-04-17 02:46:33.691 | Connection to the external service has been lost. 2026-04-17 02:46:33.963 | DTC Client socket (3) | Socket send error. Windows error code 10054: An existing connection was forcibly closed by the remote host. 2026-04-17 02:46:33.969 | DTC Client socket (3) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. * 2026-04-17 02:46:33.969 | DTC Client socket (3) | Socket gracefully closed by remote side. 2026-04-17 02:46:33.993 | CQG WebSocket | Timeout waiting for pong message from server. 2026-04-17 02:46:33.993 | CQG WebAPI | WebSocket closed. 2026-04-17 02:46:33.994 | DTC Client socket (3) | Socket receive error. Windows error code 10053: An established connection was aborted by the software in your host machine. 2026-04-17 02:46:33.995 | DTC Client socket (3) | CloseSocket call. 2026-04-17 02:46:33.995 | DTC Client socket (3) | Signaling for receive thread to end. Bytes in receive buffer: 0 2026-04-17 02:46:34.002 | DTC Client socket (3) | Max send buffers used during socket life: 4 2026-04-17 02:46:34.002 | DTC Client socket (3) | Max send buffer size during socket life: 1560 2026-04-17 02:46:34.002 | DTC Client socket (3) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2026-04-17 02:46:34.002 | DTC Client socket (3) | Closed. 2026-04-17 02:46:34.004 | CQG WebAPI | Sending Web API Logoff message. 2026-04-17 02:46:34.004 | CQG WebSocket socket (1) | CloseSocket call. 2026-04-17 02:46:34.004 | CQG WebSocket socket (1) | Max send buffers used during socket life: 3 2026-04-17 02:46:34.004 | CQG WebSocket socket (1) | Max send buffer size during socket life: 465 2026-04-17 02:46:34.008 | CQG WebSocket | WebSocket closed. 2026-04-17 02:46:34.008 | CQG WebSocket socket (1) | Write in progress. Shutdown being delayed. PendingSize=63 2026-04-17 02:46:34.008 | CQG WebAPI | WebSocket closed. 2026-04-17 02:46:34.010 | CQG WebAPI | Disconnected. 2026-04-17 02:46:34.011 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-04-17 02:46:34.012 | Denali Data Feed | Server has requested a logoff. Reason: No heartbeat messages received for 68.3 seconds. Stopping connection. 2026-04-17 02:46:34.012 | DTC Client socket (0) | CloseSocket call. 2026-04-17 02:46:34.012 | Denali Data Feed | Disconnected from the server. 2026-04-17 02:46:34.012 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds. 2026-04-17 02:46:36.012 | 2026-04-17 02:46:36.013 | CQG WebAPI | Connecting to server api.cqg.com 2026-04-17 02:46:36.013 | CQG WebSocket | Connecting to WebSocket server api.cqg.com:443 2026-04-17 02:46:36.192 | CQG WebSocket socket (2) | Creating socket. Using TLS 1.2. 2026-04-17 02:46:36.193 | CQG WebSocket socket (2) | New receive buffer size: 0 2026-04-17 02:46:36.193 | CQG WebSocket socket (2) | Connecting to IP: 195.166.124.175. 2026-04-17 02:46:36.210 | CQG WebSocket | Opening WebSocket. 2026-04-17 02:46:36.210 | CQG WebSocket | Sending WebSocket handshake. 2026-04-17 02:46:36.275 | CQG WebSocket | Server header | HTTP/1.1 101 Switching Protocols 2026-04-17 02:46:36.275 | CQG WebSocket | Server header | Connection: Upgrade 2026-04-17 02:46:36.275 | CQG WebSocket | Server header | Sec-WebSocket-Accept: ynBE+OeIiGRDGor5QdqygA1Bd/0= 2026-04-17 02:46:36.275 | CQG WebSocket | Server header | Server: WebSocket++/0.8.2 2026-04-17 02:46:36.275 | CQG WebSocket | Server header | Upgrade: websocket 2026-04-17 02:46:36.275 | CQG WebSocket | Server header | 2026-04-17 02:46:36.275 | CQG WebSocket | Web socket state is now open. 2026-04-17 02:46:36.275 | CQG WebAPI | WebSocket connected. 2026-04-17 02:46:36.276 | CQG WebAPI | Sending market data logon message. 2026-04-17 02:46:36.523 | CQG WebAPI | Base Time: 2026-04-12T15:44:25. 2026-04-12 15:44:25 2026-04-17 02:46:36.524 | CQG WebAPI | Logon successful. Session Token = AIKM3wglp59+tr/UkDoIA4UbRig1XiampBczvwc+wmwQLYGQZY3RU33GMjBVbls0s+i36rQoHJ6 2026-04-17 02:46:36.524 | CQG WebAPI | Connection to server complete. 2026-04-17 02:46:36.525 | DTC Client socket (0) | CloseSocket call. 2026-04-17 02:46:36.525 | Denali Data Feed | Disconnected from the server. 2026-04-17 02:46:36.540 | No download requests in the queue to start downloads for. | Number times message added: 3 2026-04-17 02:46:36.541 | Updated verified funded futures trading account ending date to: 2026-05-17 06:46:36 2026-04-17 02:46:36.574 | CQG WebAPI | Sending Trade Accounts request message. 2026-04-17 02:46:36.599 | Mapping F.US.EPH23 to ESH23. Service code: cme 2026-04-17 02:46:36.599 | Using symbol data fast lookup vector 2026-04-17 02:46:36.600 | Denali Data Feed | Starting real-time market data updates for: F.US.EPH23 (ESH23). ID: 1 Service code: cme 2026-04-17 02:46:36.602 | Denali Data Feed | Connecting to the server ds7-2.sierracharts.com. Port 10048 2026-04-17 02:46:36.602 | CQG WebAPI | Sending symbol resolution request for F.US.EPH23. ID: 431583 2026-04-17 02:46:36.602 | Denali Data Feed | Requesting security definition data for: F.US.EPH23 (ESH23). ID: 1 2026-04-17 02:46:36.602 | Mapping F.US.EPM23 to ESM23. Service code: cme 2026-04-17 02:46:36.602 | Denali Data Feed | Starting real-time market data updates for: F.US.EPM23 (ESM23). ID: 2 Service code: cme 2026-04-17 02:46:36.602 | CQG WebAPI | Sending symbol resolution request for F.US.EPM23. ID: 431584 2026-04-17 02:46:36.602 | Denali Data Feed | Requesting security definition data for: F.US.EPM23 (ESM23). ID: 2 2026-04-17 02:46:36.603 | Mapping F.US.EPU23 to ESU23. Service code: cme 2026-04-17 02:46:36.603 | Denali Data Feed | Starting real-time market data updates for: F.US.EPU23 (ESU23). ID: 3 Service code: cme 2026-04-17 02:46:36.603 | CQG WebAPI | Sending symbol resolution request for F.US.EPU23. ID: 431585 2026-04-17 02:46:36.604 | Denali Data Feed | Requesting security definition data for: F.US.EPU23 (ESU23). ID: 3 2026-04-17 02:46:36.605 | Mapping F.US.EPZ23 to ESZ23. Service code: cme 2026-04-17 02:46:36.605 | Denali Data Feed | Starting real-time market data updates for: F.US.EPZ23 (ESZ23). ID: 4 Service code: cme 2026-04-17 02:46:36.605 | CQG WebAPI | Sending symbol resolution request for F.US.EPZ23. ID: 431586 2026-04-17 02:46:36.605 | Denali Data Feed | Requesting security definition data for: F.US.EPZ23 (ESZ23). ID: 4 2026-04-17 02:46:36.605 | Mapping F.US.EPH24 to ESH24. Service code: cme 2026-04-17 02:46:36.605 | Denali Data Feed | Starting real-time market data updates for: F.US.EPH24 (ESH24). ID: 5 Service code: cme 2026-04-17 02:46:36.605 | CQG WebAPI | Sending symbol resolution request for F.US.EPH24. ID: 431587 2026-04-17 02:46:36.605 | Denali Data Feed | Requesting security definition data for: F.US.EPH24 (ESH24). ID: 5 2026-04-17 02:46:36.606 | Mapping F.US.CLEF23 to CLF23. Service code: nymex 2026-04-17 02:46:36.606 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEF23 (CLF23). ID: 6 Service code: nymex 2026-04-17 02:46:36.606 | CQG WebAPI | Sending symbol resolution request for F.US.CLEF23. ID: 431588 2026-04-17 02:46:36.606 | Denali Data Feed | Requesting security definition data for: F.US.CLEF23 (CLF23). ID: 6 2026-04-17 02:46:36.606 | Mapping F.US.CLEG23 to CLG23. Service code: nymex 2026-04-17 02:46:36.606 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEG23 (CLG23). ID: 7 Service code: nymex 2026-04-17 02:46:36.607 | CQG WebAPI | Sending symbol resolution request for F.US.CLEG23. ID: 431589 2026-04-17 02:46:36.607 | Denali Data Feed | Requesting security definition data for: F.US.CLEG23 (CLG23). ID: 7 2026-04-17 02:46:36.607 | Mapping F.US.CLEH23 to CLH23. Service code: nymex 2026-04-17 02:46:36.607 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEH23 (CLH23). ID: 8 Service code: nymex 2026-04-17 02:46:36.607 | CQG WebAPI | Sending symbol resolution request for F.US.CLEH23. ID: 431590 2026-04-17 02:46:36.607 | Denali Data Feed | Requesting security definition data for: F.US.CLEH23 (CLH23). ID: 8 2026-04-17 02:46:36.607 | Mapping F.US.CLEJ23 to CLJ23. Service code: nymex 2026-04-17 02:46:36.607 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEJ23 (CLJ23). ID: 9 Service code: nymex 2026-04-17 02:46:36.607 | CQG WebAPI | Sending symbol resolution request for F.US.CLEJ23. ID: 431591 2026-04-17 02:46:36.607 | Denali Data Feed | Requesting security definition data for: F.US.CLEJ23 (CLJ23). ID: 9 2026-04-17 02:46:36.608 | Mapping F.US.CLEK23 to CLK23. Service code: nymex 2026-04-17 02:46:36.608 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEK23 (CLK23). ID: 10 Service code: nymex 2026-04-17 02:46:36.608 | CQG WebAPI | Sending symbol resolution request for F.US.CLEK23. ID: 431592 2026-04-17 02:46:36.608 | Denali Data Feed | Requesting security definition data for: F.US.CLEK23 (CLK23). ID: 10 2026-04-17 02:46:36.608 | Mapping F.US.CLEM23 to CLM23. Service code: nymex 2026-04-17 02:46:36.609 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEM23 (CLM23). ID: 11 Service code: nymex 2026-04-17 02:46:36.609 | CQG WebAPI | Sending symbol resolution request for F.US.CLEM23. ID: 431593 2026-04-17 02:46:36.609 | Denali Data Feed | Requesting security definition data for: F.US.CLEM23 (CLM23). ID: 11 2026-04-17 02:46:36.609 | Mapping F.US.CLEN23 to CLN23. Service code: nymex 2026-04-17 02:46:36.609 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEN23 (CLN23). ID: 12 Service code: nymex 2026-04-17 02:46:36.609 | CQG WebAPI | Sending symbol resolution request for F.US.CLEN23. ID: 431594 2026-04-17 02:46:36.609 | Denali Data Feed | Requesting security definition data for: F.US.CLEN23 (CLN23). ID: 12 2026-04-17 02:46:36.609 | Mapping F.US.CLEQ23 to CLQ23. Service code: nymex 2026-04-17 02:46:36.609 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEQ23 (CLQ23). ID: 13 Service code: nymex 2026-04-17 02:46:36.609 | CQG WebAPI | Sending symbol resolution request for F.US.CLEQ23. ID: 431595 2026-04-17 02:46:36.609 | Denali Data Feed | Requesting security definition data for: F.US.CLEQ23 (CLQ23). ID: 13 2026-04-17 02:46:36.609 | Mapping F.US.CLEU23 to CLU23. Service code: nymex 2026-04-17 02:46:36.610 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEU23 (CLU23). ID: 14 Service code: nymex 2026-04-17 02:46:36.610 | CQG WebAPI | Sending symbol resolution request for F.US.CLEU23. ID: 431596 2026-04-17 02:46:36.610 | Denali Data Feed | Requesting security definition data for: F.US.CLEU23 (CLU23). ID: 14 2026-04-17 02:46:36.610 | Mapping F.US.CLEV23 to CLV23. Service code: nymex 2026-04-17 02:46:36.610 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEV23 (CLV23). ID: 15 Service code: nymex 2026-04-17 02:46:36.610 | CQG WebAPI | Sending symbol resolution request for F.US.CLEV23. ID: 431597 2026-04-17 02:46:36.610 | Denali Data Feed | Requesting security definition data for: F.US.CLEV23 (CLV23). ID: 15 2026-04-17 02:46:36.610 | Mapping F.US.CLEX23 to CLX23. Service code: nymex 2026-04-17 02:46:36.610 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEX23 (CLX23). ID: 16 Service code: nymex 2026-04-17 02:46:36.610 | CQG WebAPI | Sending symbol resolution request for F.US.CLEX23. ID: 431598 2026-04-17 02:46:36.610 | Denali Data Feed | Requesting security definition data for: F.US.CLEX23 (CLX23). ID: 16 2026-04-17 02:46:36.610 | Mapping F.US.CLEZ23 to CLZ23. Service code: nymex 2026-04-17 02:46:36.610 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEZ23 (CLZ23). ID: 17 Service code: nymex 2026-04-17 02:46:36.610 | CQG WebAPI | Sending symbol resolution request for F.US.CLEZ23. ID: 431599 2026-04-17 02:46:36.610 | Denali Data Feed | Requesting security definition data for: F.US.CLEZ23 (CLZ23). ID: 17 2026-04-17 02:46:36.610 | Mapping F.US.CLEF24 to CLF24. Service code: nymex 2026-04-17 02:46:36.611 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEF24 (CLF24). ID: 18 Service code: nymex 2026-04-17 02:46:36.611 | CQG WebAPI | Sending symbol resolution request for F.US.CLEF24. ID: 431600 2026-04-17 02:46:36.611 | Denali Data Feed | Requesting security definition data for: F.US.CLEF24 (CLF24). ID: 18 2026-04-17 02:46:36.611 | Mapping F.US.CLEG24 to CLG24. Service code: nymex 2026-04-17 02:46:36.611 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEG24 (CLG24). ID: 19 Service code: nymex 2026-04-17 02:46:36.611 | CQG WebAPI | Sending symbol resolution request for F.US.CLEG24. ID: 431601 2026-04-17 02:46:36.611 | Denali Data Feed | Requesting security definition data for: F.US.CLEG24 (CLG24). ID: 19 2026-04-17 02:46:36.612 | DTC Client socket (3) | Creating socket. 2026-04-17 02:46:36.612 | DTC Client socket (3) | New receive buffer size: 0 2026-04-17 02:46:36.612 | DTC Client socket (3) | Connecting to IP: 69.39.70.254. 2026-04-17 02:46:36.622 | CQG WebAPI | Received symbol resolution report for symbol F.US.EPH23. Search Symbol: F.US.EPH23. Request ID: 431583. Contract ID: 1. 2026-04-17 02:46:36.622 | CQG WebAPI | Brokerage name: AMP. Account Name: 220033 2026-04-17 02:46:36.622 | Updated verified funded futures trading account ending date to: 2026-05-17 06:46:36 2026-04-17 02:46:36.623 | CQG WebAPI | Sending collateral subscribe request. 2026-04-17 02:46:36.623 | CQG WebAPI | Received symbol resolution report for symbol F.US.EPM23. Search Symbol: F.US.EPM23. Request ID: 431584. Contract ID: 2. 2026-04-17 02:46:36.623 | CQG WebAPI | Received symbol resolution report for symbol F.US.EPU23. Search Symbol: F.US.EPU23. Request ID: 431585. Contract ID: 3. 2026-04-17 02:46:36.629 | CQG WebAPI | Received symbol resolution report for symbol F.US.EPZ23. Search Symbol: F.US.EPZ23. Request ID: 431586. Contract ID: 4. 2026-04-17 02:46:36.629 | CQG WebAPI | Received symbol resolution report for symbol F.US.EPH24. Search Symbol: F.US.EPH24. Request ID: 431587. Contract ID: 5. 2026-04-17 02:46:36.705 | Denali Data Feed | Network connection to server complete. 2026-04-17 02:46:36.705 | Denali Data Feed | Starting socket receive thread. 2026-04-17 02:46:36.705 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard 2026-04-17 02:46:36.714 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEF23. Search Symbol: F.US.CLEF23. Request ID: 431588. Contract ID: 6. 2026-04-17 02:46:36.714 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEG23. Search Symbol: F.US.CLEG23. Request ID: 431589. Contract ID: 7. 2026-04-17 02:46:36.714 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEJ23. Search Symbol: F.US.CLEJ23. Request ID: 431591. Contract ID: 8. 2026-04-17 02:46:36.714 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEH23. Search Symbol: F.US.CLEH23. Request ID: 431590. Contract ID: 9. 2026-04-17 02:46:36.714 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEK23. Search Symbol: F.US.CLEK23. Request ID: 431592. Contract ID: 10. 2026-04-17 02:46:36.714 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEM23. Search Symbol: F.US.CLEM23. Request ID: 431593. Contract ID: 11. 2026-04-17 02:46:36.716 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEN23. Search Symbol: F.US.CLEN23. Request ID: 431594. Contract ID: 12. 2026-04-17 02:46:36.716 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEV23. Search Symbol: F.US.CLEV23. Request ID: 431597. Contract ID: 13. 2026-04-17 02:46:36.716 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEU23. Search Symbol: F.US.CLEU23. Request ID: 431596. Contract ID: 14. 2026-04-17 02:46:36.716 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEQ23. Search Symbol: F.US.CLEQ23. Request ID: 431595. Contract ID: 15. 2026-04-17 02:46:36.725 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEZ23. Search Symbol: F.US.CLEZ23. Request ID: 431599. Contract ID: 16. 2026-04-17 02:46:36.725 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEX23. Search Symbol: F.US.CLEX23. Request ID: 431598. Contract ID: 17. 2026-04-17 02:46:36.788 | CQG WebAPI | Sending positions subscribe request. RequestID: 431603 2026-04-17 02:46:36.789 | CQG WebAPI | Sending orders subscribe request. RequestID: 431604 2026-04-17 02:46:36.800 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEG24. Search Symbol: F.US.CLEG24. Request ID: 431601. Contract ID: 18. 2026-04-17 02:46:36.800 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEF24. Search Symbol: F.US.CLEF24. Request ID: 431600. Contract ID: 19. 2026-04-17 02:46:36.817 | Denali Data Feed | Setting DTC encoding to Binary VLS 2026-04-17 02:46:36.817 | Denali Data Feed | Sending logon request message. 2026-04-17 02:46:36.915 | Mapping F.US.CLEM26 to CLM26. Service code: nymex 2026-04-17 02:46:36.915 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEM26 (CLM26). ID: 20 Service code: nymex 2026-04-17 02:46:36.915 | CQG WebAPI | Sending symbol resolution request for F.US.CLEM26. ID: 431605 2026-04-17 02:46:36.916 | Denali Data Feed | Requesting security definition data for: F.US.CLEM26 (CLM26). ID: 20 2026-04-17 02:46:36.917 | Added historical Intraday data request for F.US.CLEM26 to the queue. 2026-04-17 02:46:36.917 | Intraday data recording state for symbol F.US.CLEM26 is set to download 'Pending'. 2026-04-17 02:46:36.917 | Triggering next historical data download in queue. 2026-04-17 02:46:36.965 | Delaying start of download for F.US.CLEM26. 2026-04-17 02:46:36.965 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEM26. Search Symbol: F.US.CLEM26. Request ID: 431605. Contract ID: 20. 2026-04-17 02:46:36.984 | Mapping F.US.CLEV25 to CLV25. Service code: nymex 2026-04-17 02:46:36.984 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEV25 (CLV25). ID: 21 Service code: nymex 2026-04-17 02:46:36.984 | CQG WebAPI | Sending symbol resolution request for F.US.CLEV25. ID: 431606 2026-04-17 02:46:36.984 | Denali Data Feed | Requesting security definition data for: F.US.CLEV25 (CLV25). ID: 21 2026-04-17 02:46:36.984 | Added historical Intraday data request for F.US.CLEV25 to the queue. 2026-04-17 02:46:36.984 | Intraday data recording state for symbol F.US.CLEV25 is set to download 'Pending'. 2026-04-17 02:46:36.984 | Triggering next historical data download in queue. 2026-04-17 02:46:36.993 | Mapping F.US.EPU25 to ESU25. Service code: cme 2026-04-17 02:46:36.993 | Denali Data Feed | Starting real-time market data updates for: F.US.EPU25 (ESU25). ID: 22 Service code: cme 2026-04-17 02:46:36.993 | CQG WebAPI | Sending symbol resolution request for F.US.EPU25. ID: 431607 2026-04-17 02:46:36.993 | Denali Data Feed | Requesting security definition data for: F.US.EPU25 (ESU25). ID: 22 2026-04-17 02:46:36.993 | Added historical Intraday data request for F.US.EPU25 to the queue. 2026-04-17 02:46:36.993 | Intraday data recording state for symbol F.US.EPU25 is set to download 'Pending'. 2026-04-17 02:46:36.993 | Triggering next historical data download in queue. 2026-04-17 02:46:37.082 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEV25. Search Symbol: F.US.CLEV25. Request ID: 431606. Contract ID: 21. 2026-04-17 02:46:37.084 | CQG WebAPI | Received symbol resolution report for symbol F.US.EPU25. Search Symbol: F.US.EPU25. Request ID: 431607. Contract ID: 22. 2026-04-17 02:46:37.372 | Denali Data Feed | Received logon response. 2026-04-17 02:46:37.372 | Denali Data Feed | Server Name: SC Realtime Server. 2026-04-17 02:46:37.372 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8 2026-04-17 02:46:37.372 | Denali Data Feed | Successfully connected. 2026-04-17 02:46:37.372 | Denali Data Feed | Trading is not supported. 2026-04-17 02:46:37.372 | Denali Data Feed | MarketDepthIsSupported: 1 2026-04-17 02:46:37.372 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEF23 -> CLF23 2026-04-17 02:46:37.372 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEF24 -> CLF24 2026-04-17 02:46:37.372 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEG23 -> CLG23 2026-04-17 02:46:37.372 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEG24 -> CLG24 2026-04-17 02:46:37.372 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEH23 -> CLH23 2026-04-17 02:46:37.372 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEJ23 -> CLJ23 2026-04-17 02:46:37.372 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEK23 -> CLK23 2026-04-17 02:46:37.372 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEM23 -> CLM23 2026-04-17 02:46:37.372 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEM26 -> CLM26 2026-04-17 02:46:37.372 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEN23 -> CLN23 2026-04-17 02:46:37.372 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEQ23 -> CLQ23 2026-04-17 02:46:37.372 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEU23 -> CLU23 2026-04-17 02:46:37.372 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEV23 -> CLV23 2026-04-17 02:46:37.372 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEV25 -> CLV25 2026-04-17 02:46:37.372 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEX23 -> CLX23 2026-04-17 02:46:37.372 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEZ23 -> CLZ23 2026-04-17 02:46:37.372 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.EPH23 -> ESH23 2026-04-17 02:46:37.372 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.EPH24 -> ESH24 2026-04-17 02:46:37.372 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.EPM23 -> ESM23 2026-04-17 02:46:37.372 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.EPU23 -> ESU23 2026-04-17 02:46:37.372 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.EPU25 -> ESU25 2026-04-17 02:46:37.373 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.EPZ23 -> ESZ23 2026-04-17 02:46:37.573 | Denali Data Feed | Real-time data for symbol F.US.CLEF23 is currently unavailable. 2026-04-17 02:46:37.573 | Denali Data Feed | Received security definition for symbol F.US.CLEF23 2026-04-17 02:46:37.574 | Denali Data Feed | Real-time data for symbol F.US.CLEF24 is currently unavailable. 2026-04-17 02:46:37.574 | Denali Data Feed | Received security definition for symbol F.US.CLEF24 2026-04-17 02:46:37.574 | Denali Data Feed | Real-time data for symbol F.US.CLEG23 is currently unavailable. 2026-04-17 02:46:37.574 | Denali Data Feed | Received security definition for symbol F.US.CLEG23 2026-04-17 02:46:37.574 | Denali Data Feed | Real-time data for symbol F.US.CLEG24 is currently unavailable. 2026-04-17 02:46:37.574 | Denali Data Feed | Received security definition for symbol F.US.CLEG24 2026-04-17 02:46:37.574 | Denali Data Feed | Real-time data for symbol F.US.CLEH23 is currently unavailable. 2026-04-17 02:46:37.574 | Denali Data Feed | Received security definition for symbol F.US.CLEH23 2026-04-17 02:46:37.574 | Denali Data Feed | Real-time data for symbol F.US.CLEJ23 is currently unavailable. 2026-04-17 02:46:37.574 | Denali Data Feed | Received security definition for symbol F.US.CLEJ23 2026-04-17 02:46:37.574 | Denali Data Feed | Real-time data for symbol F.US.CLEK23 is currently unavailable. 2026-04-17 02:46:37.574 | Denali Data Feed | Received security definition for symbol F.US.CLEK23 2026-04-17 02:46:37.574 | Denali Data Feed | Real-time data for symbol F.US.CLEM23 is currently unavailable. 2026-04-17 02:46:37.574 | Denali Data Feed | Received security definition for symbol F.US.CLEM23 2026-04-17 02:46:37.574 | Denali Data Feed | Setting external service identifier for symbol F.US.CLEM26 to 670557 2026-04-17 02:46:37.574 | Denali Data Feed | Received security definition for symbol F.US.CLEM26 2026-04-17 02:46:37.574 | Denali Data Feed | Real-time data for symbol F.US.CLEN23 is currently unavailable. 2026-04-17 02:46:37.574 | Denali Data Feed | Received security definition for symbol F.US.CLEN23 2026-04-17 02:46:37.574 | Denali Data Feed | Real-time data for symbol F.US.CLEQ23 is currently unavailable. 2026-04-17 02:46:37.574 | Denali Data Feed | Received security definition for symbol F.US.CLEQ23 2026-04-17 02:46:37.574 | Denali Data Feed | Real-time data for symbol F.US.CLEU23 is currently unavailable. 2026-04-17 02:46:37.574 | Denali Data Feed | Received security definition for symbol F.US.CLEU23 2026-04-17 02:46:37.574 | Denali Data Feed | Real-time data for symbol F.US.CLEV23 is currently unavailable. 2026-04-17 02:46:37.574 | Denali Data Feed | Received security definition for symbol F.US.CLEV23 2026-04-17 02:46:37.574 | Denali Data Feed | Real-time data for symbol F.US.CLEV25 is currently unavailable. 2026-04-17 02:46:37.574 | Denali Data Feed | Received security definition for symbol F.US.CLEV25 2026-04-17 02:46:37.574 | Denali Data Feed | Real-time data for symbol F.US.CLEX23 is currently unavailable. 2026-04-17 02:46:37.574 | Denali Data Feed | Received security definition for symbol F.US.CLEX23 2026-04-17 02:46:37.574 | Denali Data Feed | Real-time data for symbol F.US.CLEZ23 is currently unavailable. 2026-04-17 02:46:37.575 | Denali Data Feed | Received security definition for symbol F.US.CLEZ23 2026-04-17 02:46:37.575 | Denali Data Feed | Real-time data for symbol F.US.EPH23 is currently unavailable. 2026-04-17 02:46:37.575 | Denali Data Feed | Received security definition for symbol F.US.EPH23 2026-04-17 02:46:37.575 | Denali Data Feed | Real-time data for symbol F.US.EPH24 is currently unavailable. 2026-04-17 02:46:37.575 | Denali Data Feed | Received security definition for symbol F.US.EPH24 2026-04-17 02:46:37.575 | Denali Data Feed | Real-time data for symbol F.US.EPM23 is currently unavailable. 2026-04-17 02:46:37.575 | Denali Data Feed | Received security definition for symbol F.US.EPM23 2026-04-17 02:46:37.575 | Denali Data Feed | Real-time data for symbol F.US.EPU23 is currently unavailable. 2026-04-17 02:46:37.575 | Denali Data Feed | Received security definition for symbol F.US.EPU23 2026-04-17 02:46:37.575 | Denali Data Feed | Real-time data for symbol F.US.EPU25 is currently unavailable. 2026-04-17 02:46:37.575 | Denali Data Feed | Received security definition for symbol F.US.EPU25 2026-04-17 02:46:37.575 | Denali Data Feed | Real-time data for symbol F.US.EPZ23 is currently unavailable. 2026-04-17 02:46:37.575 | Denali Data Feed | Received security definition for symbol F.US.EPZ23 2026-04-17 02:46:41.532 | Requesting market depth updates for: F.US.CLEV25 if supported. NumLevels=100 2026-04-17 02:46:41.711 | Denali Data Feed | Clearing market depth for F.US.CLEV25 2026-04-17 02:46:42.351 | HD Request # 58 | Downloading Intraday chart data for F.US.CLEM26 to the file F.US.CLEM26.scid. Service: nymex 2026-04-17 02:46:42.354 | HD Request # 58 | Download start date-time: 2026-04-17 01:04:18.000000. File last date-time: 2026-04-17 01:04:18.919000 2026-04-17 02:46:42.356 | HD Request # 58 | Using server: ds26.sierracharts.com port 10149 2026-04-17 02:46:42.361 | Socket (4) | Creating socket. 2026-04-17 02:46:42.362 | Socket (4) | New receive buffer size: 0 2026-04-17 02:46:42.362 | Socket (4) | Connecting to IP: 64.152.155.17. 2026-04-17 02:46:42.550 | HD Request # 58 | Setting DTC encoding to Binary VLS 2026-04-17 02:46:42.550 | HD Request # 58 | Sending historical data logon request message. 2026-04-17 02:46:42.674 | HD Request # 58 | Requesting Intraday data. Start date-time: 2026-04-17 01:04:18. Record interval: 0. Symbol: CLM26 2026-04-17 02:46:42.764 | HD Request # 58 | Decompressing data. 2026-04-17 02:46:42.950 | HD Request # 58 | Receiving Intraday data for F.US.CLEM26 starting at 2026-04-17 01:04:18.918000 2026-04-17 02:46:42.952 | Socket (4) | CloseSocket call. 2026-04-17 02:46:42.952 | Socket (4) | Shutdown started. Waiting for graceful close. 2026-04-17 02:46:42.953 | Historical data download thread signaled to stop. 2026-04-17 02:46:42.953 | HD Request # 58 | Timestamp of first Intraday data file record written: 2026-04-17 01:04:27.138000. 2026-04-17 02:46:42.954 | HD Request # 58 | Received 3326 Intraday data records from 2026-04-17 01:04:18.918000 to 2026-04-17 02:46:42.996000 (102.4 minutes. Delay: -0.0 seconds) and wrote 3324 records for F.US.CLEM26 2026-04-17 02:46:42.970 | HD Request # 58 | Add time&sales data | Remembered last file record date-time: 2026-04-17 06:46:42.996000 2026-04-17 02:46:42.970 | HD Request # 58 | Completion time: 0s. 2026-04-17 02:46:42.970 | HD Request # 58 | Intraday data download complete for F.US.CLEM26. Unique request ID: 58 2026-04-17 02:46:42.970 | Removing historical data download ID 58. 2026-04-17 02:46:42.970 | Real-time Intraday chart data file updates started for F.US.CLEM26 2026-04-17 02:46:42.970 | Intraday chart data file opened for F.US.CLEM26 2026-04-17 02:46:42.971 | HD Request # 58 | Enabling Intraday chart updating for symbol. 2026-04-17 02:46:42.971 | 2026-04-17 02:46:42.971 | Triggering next historical data download in queue. 2026-04-17 02:46:42.971 | HD Request # 59 | Downloading Intraday chart data for F.US.CLEV25 to the file F.US.CLEV25.scid. Service: nymex 2026-04-17 02:46:42.973 | HD Request # 59 | Download start date-time: 2025-09-22 14:29:55.000000. File last date-time: 2025-09-22 14:29:55.618000 2026-04-17 02:46:42.974 | HD Request # 59 | Using server: ds28.sierracharts.com port 10150 2026-04-17 02:46:42.974 | Socket (5) | Creating socket. 2026-04-17 02:46:42.974 | Socket (5) | New receive buffer size: 0 2026-04-17 02:46:42.974 | Socket (5) | Connecting to IP: 67.214.125.5. 2026-04-17 02:46:43.043 | Socket (4) | Socket gracefully closed by remote side. 2026-04-17 02:46:43.043 | Socket (4) | Closed. 2026-04-17 02:46:43.165 | HD Request # 59 | Setting DTC encoding to Binary VLS 2026-04-17 02:46:43.165 | HD Request # 59 | Sending historical data logon request message. 2026-04-17 02:46:43.286 | HD Request # 59 | Requesting Intraday data. Start date-time: 2025-09-22 14:29:55. Record interval: 0. Symbol: CLV25 2026-04-17 02:46:43.379 | HD Request # 59 | Decompressing data. 2026-04-17 02:46:43.477 | HD Request # 59 | Receiving Intraday data for F.US.CLEV25 starting at 2025-09-22 14:29:55.086000 2026-04-17 02:46:43.477 | Socket (5) | CloseSocket call. 2026-04-17 02:46:43.477 | Socket (5) | Shutdown started. Waiting for graceful close. 2026-04-17 02:46:43.485 | Historical data download thread signaled to stop. 2026-04-17 02:46:43.485 | HD Request # 59 | Received 2 Intraday data records from 2025-09-22 14:29:55.086000 to 2025-09-22 14:29:55.618000 (0.5 seconds. Delay: 206.5 days) and wrote 0 records for F.US.CLEV25 2026-04-17 02:46:43.486 | HD Request # 59 | Add time&sales data | Remembered last file record date-time: 2025-09-22 18:29:55.618000 2026-04-17 02:46:43.486 | HD Request # 59 | Completion time: 1s. 2026-04-17 02:46:43.486 | HD Request # 59 | Intraday data download complete for F.US.CLEV25. Unique request ID: 59 2026-04-17 02:46:43.486 | Removing historical data download ID 59. 2026-04-17 02:46:43.486 | Real-time Intraday chart data file updates started for F.US.CLEV25 2026-04-17 02:46:43.486 | Intraday chart data file opened for F.US.CLEV25 2026-04-17 02:46:43.486 | HD Request # 59 | Enabling Intraday chart updating for symbol. 2026-04-17 02:46:43.486 | 2026-04-17 02:46:43.486 | Triggering next historical data download in queue. 2026-04-17 02:46:43.486 | HD Request # 60 | Downloading Intraday chart data for F.US.EPU25 to the file F.US.EPU25.scid. Service: cme 2026-04-17 02:46:43.488 | HD Request # 60 | Download start date-time: 2025-09-19 09:29:58.000000. File last date-time: 2025-09-19 09:29:58.698000 2026-04-17 02:46:43.488 | HD Request # 60 | Using server: ds32.sierracharts.com port 10149 2026-04-17 02:46:43.489 | Socket (4) | Creating socket. 2026-04-17 02:46:43.489 | Socket (4) | New receive buffer size: 0 2026-04-17 02:46:43.489 | Socket (4) | Connecting to IP: 69.39.70.248. 2026-04-17 02:46:43.569 | Socket (5) | Socket gracefully closed by remote side. 2026-04-17 02:46:43.569 | Socket (5) | Closed. 2026-04-17 02:46:43.675 | HD Request # 60 | Setting DTC encoding to Binary VLS 2026-04-17 02:46:43.675 | HD Request # 60 | Sending historical data logon request message. 2026-04-17 02:46:43.797 | HD Request # 60 | Requesting Intraday data. Start date-time: 2025-09-19 09:29:58. Record interval: 0. Symbol: ESU25 2026-04-17 02:46:43.894 | HD Request # 60 | Decompressing data. 2026-04-17 02:46:44.021 | HD Request # 60 | Receiving Intraday data for F.US.EPU25 starting at 2025-09-19 09:29:58.697000 2026-04-17 02:46:44.021 | Socket (4) | CloseSocket call. 2026-04-17 02:46:44.021 | Socket (4) | Shutdown started. Waiting for graceful close. 2026-04-17 02:46:44.022 | Historical data download thread signaled to stop. 2026-04-17 02:46:44.022 | HD Request # 60 | Received 5 Intraday data records from 2025-09-19 09:29:58.697000 to 2025-09-19 09:29:58.698000 (0.0 seconds. Delay: 209.7 days) and wrote 0 records for F.US.EPU25 2026-04-17 02:46:44.022 | HD Request # 60 | Add time&sales data | Remembered last file record date-time: 2025-09-19 13:29:58.698000 2026-04-17 02:46:44.022 | HD Request # 60 | Completion time: 1s. 2026-04-17 02:46:44.022 | HD Request # 60 | Intraday data download complete for F.US.EPU25. Unique request ID: 60 2026-04-17 02:46:44.022 | Removing historical data download ID 60. 2026-04-17 02:46:44.022 | Real-time Intraday chart data file updates started for F.US.EPU25 2026-04-17 02:46:44.022 | Intraday chart data file opened for F.US.EPU25 2026-04-17 02:46:44.022 | HD Request # 60 | Enabling Intraday chart updating for symbol. 2026-04-17 02:46:44.022 | 2026-04-17 02:46:44.022 | No download requests in the queue to start downloads for. 2026-04-17 02:46:44.113 | Socket (4) | Socket gracefully closed by remote side. 2026-04-17 02:46:44.114 | Socket (4) | Closed. 2026-04-17 02:46:49.513 | Opened cached Intraday file: C:\SierraChart\Data\F.US.CLEM26.scid. Thread ID: 16976 2026-04-17 02:46:53.137 | CQG WebSocket socket (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. * 2026-04-17 02:46:53.137 | CQG WebSocket socket (1) | Write has completed. Shutdown being performed. 2026-04-17 02:46:53.137 | CQG WebSocket socket (1) | Shutdown started. Waiting for graceful close. 2026-04-17 02:46:53.137 | CQG WebSocket socket (1) | Socket gracefully closed by remote side. 2026-04-17 02:46:53.137 | CQG WebSocket socket (1) | Closed. 2026-04-17 08:21:03.650 | CQG WebSocket | Timeout waiting for pong message from server. 2026-04-17 08:21:03.651 | CQG WebAPI | WebSocket closed. 2026-04-17 08:21:03.651 | Connection to the external service has been lost. 2026-04-17 08:21:03.710 | DTC Client socket (3) | Socket gracefully closed by remote side. 2026-04-17 08:21:03.970 | Denali Data Feed | There has been no activity on the network socket for 2h 8m 54s. Will reconnect. 2026-04-17 08:21:04.073 | Denali Data Feed | Waiting for socket receive thread to end 2026-04-17 08:21:04.193 | DTC Client socket (3) | Socket gracefully closed by remote side. 2026-04-17 08:21:04.319 | DTC Client socket (3) | CloseSocket call. 2026-04-17 08:21:04.319 | DTC Client socket (3) | Max send buffers used during socket life: 3 2026-04-17 08:21:04.319 | DTC Client socket (3) | Max send buffer size during socket life: 1560 2026-04-17 08:21:04.374 | Denali Data Feed | Disconnected from the server. 2026-04-17 08:21:04.374 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds. 2026-04-17 08:21:04.380 | CQG WebAPI | Sending Web API Logoff message. 2026-04-17 08:21:04.381 | CQG WebSocket socket (2) | CloseSocket call. 2026-04-17 08:21:04.381 | CQG WebSocket socket (2) | Max send buffers used during socket life: 3 2026-04-17 08:21:04.381 | CQG WebSocket socket (2) | Max send buffer size during socket life: 504 2026-04-17 08:21:04.381 | CQG WebSocket | WebSocket closed. 2026-04-17 08:21:04.381 | CQG WebAPI | WebSocket closed. 2026-04-17 08:21:04.385 | CQG WebAPI | Disconnected. 2026-04-17 08:21:04.385 | DTC Client socket (3) | Shutdown error. Windows error code 10054: An existing connection was forcibly closed by the remote host. * 2026-04-17 08:21:04.385 | DTC Client socket (3) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2026-04-17 08:21:04.385 | DTC Client socket (3) | Closed. 2026-04-17 08:21:04.385 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-04-17 08:21:04.385 | CQG WebSocket socket (2) | Write in progress. Shutdown being delayed. PendingSize=0 2026-04-17 08:21:06.408 | 2026-04-17 08:21:06.412 | CQG WebAPI | Connecting to server api.cqg.com 2026-04-17 08:21:06.412 | CQG WebSocket | Connecting to WebSocket server api.cqg.com:443 2026-04-17 08:21:06.644 | CQG WebSocket socket (1) | Creating socket. Using TLS 1.2. 2026-04-17 08:21:06.645 | CQG WebSocket socket (1) | New receive buffer size: 0 2026-04-17 08:21:06.645 | CQG WebSocket socket (1) | Connecting to IP: 195.166.124.175. 2026-04-17 08:21:06.696 | CQG WebSocket | Opening WebSocket. 2026-04-17 08:21:06.696 | CQG WebSocket | Sending WebSocket handshake. 2026-04-17 08:21:06.781 | CQG WebSocket | Server header | HTTP/1.1 101 Switching Protocols 2026-04-17 08:21:06.781 | CQG WebSocket | Server header | Connection: Upgrade 2026-04-17 08:21:06.781 | CQG WebSocket | Server header | Sec-WebSocket-Accept: ATo/jGvFIusltv+/0USqpNwa0mk= 2026-04-17 08:21:06.781 | CQG WebSocket | Server header | Server: WebSocket++/0.8.2 2026-04-17 08:21:06.781 | CQG WebSocket | Server header | Upgrade: websocket 2026-04-17 08:21:06.781 | CQG WebSocket | Server header | 2026-04-17 08:21:06.781 | CQG WebSocket | Web socket state is now open. 2026-04-17 08:21:06.781 | CQG WebAPI | WebSocket connected. 2026-04-17 08:21:06.782 | CQG WebAPI | Sending market data logon message. 2026-04-17 08:21:07.028 | CQG WebAPI | Base Time: 2026-04-12T15:44:25. 2026-04-12 15:44:25 2026-04-17 08:21:07.028 | CQG WebAPI | Logon successful. Session Token = 0i0MUQqOqScu9h8w4wQEP3TcT98vLmhbwRGYoIdbI5ImHELYEJMlyltX5D3GRpp8ehRxBaUhv6L 2026-04-17 08:21:07.028 | CQG WebAPI | Connection to server complete. 2026-04-17 08:21:07.029 | DTC Client socket (0) | CloseSocket call. 2026-04-17 08:21:07.029 | Denali Data Feed | Disconnected from the server. 2026-04-17 08:21:07.046 | No download requests in the queue to start downloads for. | Number times message added: 3 2026-04-17 08:21:07.047 | Updated verified funded futures trading account ending date to: 2026-05-17 12:21:07 2026-04-17 08:21:07.089 | CQG WebAPI | Sending Trade Accounts request message. 2026-04-17 08:21:07.164 | CQG WebAPI | Brokerage name: AMP. Account Name: 220033 2026-04-17 08:21:07.164 | Updated verified funded futures trading account ending date to: 2026-05-17 12:21:07 2026-04-17 08:21:07.164 | CQG WebAPI | Sending collateral subscribe request. 2026-04-17 08:21:07.307 | CQG WebAPI | Sending positions subscribe request. RequestID: 431612 2026-04-17 08:21:07.308 | CQG WebAPI | Sending orders subscribe request. RequestID: 431613 2026-04-17 08:21:07.319 | Mapping F.US.CLEM26 to CLM26. Service code: nymex 2026-04-17 08:21:07.319 | Using symbol data fast lookup vector 2026-04-17 08:21:07.320 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEM26 (CLM26). ID: 1 Service code: nymex 2026-04-17 08:21:07.321 | Denali Data Feed | Connecting to the server ds26-2.sierracharts.com. Port 443 2026-04-17 08:21:07.321 | CQG WebAPI | Sending symbol resolution request for F.US.CLEM26. ID: 431614 2026-04-17 08:21:07.321 | Denali Data Feed | Requesting security definition data for: F.US.CLEM26 (CLM26). ID: 1 2026-04-17 08:21:07.323 | Added historical Intraday data request for F.US.CLEM26 to the queue. 2026-04-17 08:21:07.323 | Intraday data recording state for symbol F.US.CLEM26 is set to download 'Pending'. 2026-04-17 08:21:07.323 | Triggering next historical data download in queue. 2026-04-17 08:21:07.359 | DTC Client socket (3) | Creating socket. 2026-04-17 08:21:07.359 | DTC Client socket (3) | New receive buffer size: 0 2026-04-17 08:21:07.359 | DTC Client socket (3) | Connecting to IP: 64.152.155.18. 2026-04-17 08:21:07.380 | Delaying start of download for F.US.CLEM26. 2026-04-17 08:21:07.381 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEM26. Search Symbol: F.US.CLEM26. Request ID: 431614. Contract ID: 1. 2026-04-17 08:21:07.539 | Denali Data Feed | Network connection to server complete. 2026-04-17 08:21:07.539 | Denali Data Feed | Starting socket receive thread. 2026-04-17 08:21:07.539 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard 2026-04-17 08:21:07.542 | Mapping F.US.CLEV25 to CLV25. Service code: nymex 2026-04-17 08:21:07.543 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEV25 (CLV25). ID: 2 Service code: nymex 2026-04-17 08:21:07.543 | CQG WebAPI | Sending symbol resolution request for F.US.CLEV25. ID: 431615 2026-04-17 08:21:07.543 | Denali Data Feed | Requesting security definition data for: F.US.CLEV25 (CLV25). ID: 2 2026-04-17 08:21:07.543 | Added historical Intraday data request for F.US.CLEV25 to the queue. 2026-04-17 08:21:07.543 | Intraday data recording state for symbol F.US.CLEV25 is set to download 'Pending'. 2026-04-17 08:21:07.543 | Triggering next historical data download in queue. 2026-04-17 08:21:07.553 | Mapping F.US.EPU25 to ESU25. Service code: cme 2026-04-17 08:21:07.554 | Denali Data Feed | Starting real-time market data updates for: F.US.EPU25 (ESU25). ID: 3 Service code: cme 2026-04-17 08:21:07.554 | CQG WebAPI | Sending symbol resolution request for F.US.EPU25. ID: 431616 2026-04-17 08:21:07.554 | Denali Data Feed | Requesting security definition data for: F.US.EPU25 (ESU25). ID: 3 2026-04-17 08:21:07.554 | Added historical Intraday data request for F.US.EPU25 to the queue. 2026-04-17 08:21:07.554 | Intraday data recording state for symbol F.US.EPU25 is set to download 'Pending'. 2026-04-17 08:21:07.554 | Triggering next historical data download in queue. 2026-04-17 08:21:07.665 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEV25. Search Symbol: F.US.CLEV25. Request ID: 431615. Contract ID: 2. 2026-04-17 08:21:07.665 | CQG WebAPI | Received symbol resolution report for symbol F.US.EPU25. Search Symbol: F.US.EPU25. Request ID: 431616. Contract ID: 3. 2026-04-17 08:21:07.688 | Denali Data Feed | Setting DTC encoding to Binary VLS 2026-04-17 08:21:07.688 | Denali Data Feed | Sending logon request message. 2026-04-17 08:21:07.721 | Mapping F.US.EPH23 to ESH23. Service code: cme 2026-04-17 08:21:07.721 | Denali Data Feed | Starting real-time market data updates for: F.US.EPH23 (ESH23). ID: 4 Service code: cme 2026-04-17 08:21:07.721 | CQG WebAPI | Sending symbol resolution request for F.US.EPH23. ID: 431617 2026-04-17 08:21:07.721 | Denali Data Feed | Requesting security definition data for: F.US.EPH23 (ESH23). ID: 4 2026-04-17 08:21:07.722 | Mapping F.US.EPM23 to ESM23. Service code: cme 2026-04-17 08:21:07.722 | Denali Data Feed | Starting real-time market data updates for: F.US.EPM23 (ESM23). ID: 5 Service code: cme 2026-04-17 08:21:07.722 | CQG WebAPI | Sending symbol resolution request for F.US.EPM23. ID: 431618 2026-04-17 08:21:07.722 | Denali Data Feed | Requesting security definition data for: F.US.EPM23 (ESM23). ID: 5 2026-04-17 08:21:07.722 | Mapping F.US.EPU23 to ESU23. Service code: cme 2026-04-17 08:21:07.723 | Denali Data Feed | Starting real-time market data updates for: F.US.EPU23 (ESU23). ID: 6 Service code: cme 2026-04-17 08:21:07.723 | CQG WebAPI | Sending symbol resolution request for F.US.EPU23. ID: 431619 2026-04-17 08:21:07.723 | Denali Data Feed | Requesting security definition data for: F.US.EPU23 (ESU23). ID: 6 2026-04-17 08:21:07.723 | Mapping F.US.EPZ23 to ESZ23. Service code: cme 2026-04-17 08:21:07.723 | Denali Data Feed | Starting real-time market data updates for: F.US.EPZ23 (ESZ23). ID: 7 Service code: cme 2026-04-17 08:21:07.723 | CQG WebAPI | Sending symbol resolution request for F.US.EPZ23. ID: 431620 2026-04-17 08:21:07.723 | Denali Data Feed | Requesting security definition data for: F.US.EPZ23 (ESZ23). ID: 7 2026-04-17 08:21:07.723 | Mapping F.US.EPH24 to ESH24. Service code: cme 2026-04-17 08:21:07.724 | Denali Data Feed | Starting real-time market data updates for: F.US.EPH24 (ESH24). ID: 8 Service code: cme 2026-04-17 08:21:07.724 | CQG WebAPI | Sending symbol resolution request for F.US.EPH24. ID: 431621 2026-04-17 08:21:07.724 | Denali Data Feed | Requesting security definition data for: F.US.EPH24 (ESH24). ID: 8 2026-04-17 08:21:07.724 | Mapping F.US.CLEF23 to CLF23. Service code: nymex 2026-04-17 08:21:07.724 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEF23 (CLF23). ID: 9 Service code: nymex 2026-04-17 08:21:07.724 | CQG WebAPI | Sending symbol resolution request for F.US.CLEF23. ID: 431622 2026-04-17 08:21:07.724 | Denali Data Feed | Requesting security definition data for: F.US.CLEF23 (CLF23). ID: 9 2026-04-17 08:21:07.725 | Mapping F.US.CLEG23 to CLG23. Service code: nymex 2026-04-17 08:21:07.725 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEG23 (CLG23). ID: 10 Service code: nymex 2026-04-17 08:21:07.725 | CQG WebAPI | Sending symbol resolution request for F.US.CLEG23. ID: 431623 2026-04-17 08:21:07.725 | Denali Data Feed | Requesting security definition data for: F.US.CLEG23 (CLG23). ID: 10 2026-04-17 08:21:07.725 | Mapping F.US.CLEH23 to CLH23. Service code: nymex 2026-04-17 08:21:07.726 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEH23 (CLH23). ID: 11 Service code: nymex 2026-04-17 08:21:07.726 | CQG WebAPI | Sending symbol resolution request for F.US.CLEH23. ID: 431624 2026-04-17 08:21:07.726 | Denali Data Feed | Requesting security definition data for: F.US.CLEH23 (CLH23). ID: 11 2026-04-17 08:21:07.726 | Mapping F.US.CLEJ23 to CLJ23. Service code: nymex 2026-04-17 08:21:07.727 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEJ23 (CLJ23). ID: 12 Service code: nymex 2026-04-17 08:21:07.727 | CQG WebAPI | Sending symbol resolution request for F.US.CLEJ23. ID: 431625 2026-04-17 08:21:07.727 | Denali Data Feed | Requesting security definition data for: F.US.CLEJ23 (CLJ23). ID: 12 2026-04-17 08:21:07.727 | Mapping F.US.CLEK23 to CLK23. Service code: nymex 2026-04-17 08:21:07.727 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEK23 (CLK23). ID: 13 Service code: nymex 2026-04-17 08:21:07.727 | CQG WebAPI | Sending symbol resolution request for F.US.CLEK23. ID: 431626 2026-04-17 08:21:07.727 | Denali Data Feed | Requesting security definition data for: F.US.CLEK23 (CLK23). ID: 13 2026-04-17 08:21:07.727 | Mapping F.US.CLEM23 to CLM23. Service code: nymex 2026-04-17 08:21:07.727 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEM23 (CLM23). ID: 14 Service code: nymex 2026-04-17 08:21:07.727 | CQG WebAPI | Sending symbol resolution request for F.US.CLEM23. ID: 431627 2026-04-17 08:21:07.727 | Denali Data Feed | Requesting security definition data for: F.US.CLEM23 (CLM23). ID: 14 2026-04-17 08:21:07.727 | Mapping F.US.CLEN23 to CLN23. Service code: nymex 2026-04-17 08:21:07.727 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEN23 (CLN23). ID: 15 Service code: nymex 2026-04-17 08:21:07.727 | CQG WebAPI | Sending symbol resolution request for F.US.CLEN23. ID: 431628 2026-04-17 08:21:07.727 | Denali Data Feed | Requesting security definition data for: F.US.CLEN23 (CLN23). ID: 15 2026-04-17 08:21:07.727 | Mapping F.US.CLEQ23 to CLQ23. Service code: nymex 2026-04-17 08:21:07.728 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEQ23 (CLQ23). ID: 16 Service code: nymex 2026-04-17 08:21:07.728 | CQG WebAPI | Sending symbol resolution request for F.US.CLEQ23. ID: 431629 2026-04-17 08:21:07.728 | Denali Data Feed | Requesting security definition data for: F.US.CLEQ23 (CLQ23). ID: 16 2026-04-17 08:21:07.728 | Mapping F.US.CLEU23 to CLU23. Service code: nymex 2026-04-17 08:21:07.728 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEU23 (CLU23). ID: 17 Service code: nymex 2026-04-17 08:21:07.729 | CQG WebAPI | Sending symbol resolution request for F.US.CLEU23. ID: 431630 2026-04-17 08:21:07.729 | Denali Data Feed | Requesting security definition data for: F.US.CLEU23 (CLU23). ID: 17 2026-04-17 08:21:07.729 | Mapping F.US.CLEV23 to CLV23. Service code: nymex 2026-04-17 08:21:07.729 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEV23 (CLV23). ID: 18 Service code: nymex 2026-04-17 08:21:07.729 | CQG WebAPI | Sending symbol resolution request for F.US.CLEV23. ID: 431631 2026-04-17 08:21:07.729 | Denali Data Feed | Requesting security definition data for: F.US.CLEV23 (CLV23). ID: 18 2026-04-17 08:21:07.729 | Mapping F.US.CLEX23 to CLX23. Service code: nymex 2026-04-17 08:21:07.730 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEX23 (CLX23). ID: 19 Service code: nymex 2026-04-17 08:21:07.730 | CQG WebAPI | Sending symbol resolution request for F.US.CLEX23. ID: 431632 2026-04-17 08:21:07.730 | Denali Data Feed | Requesting security definition data for: F.US.CLEX23 (CLX23). ID: 19 2026-04-17 08:21:07.730 | Mapping F.US.CLEZ23 to CLZ23. Service code: nymex 2026-04-17 08:21:07.730 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEZ23 (CLZ23). ID: 20 Service code: nymex 2026-04-17 08:21:07.730 | CQG WebAPI | Sending symbol resolution request for F.US.CLEZ23. ID: 431633 2026-04-17 08:21:07.730 | Denali Data Feed | Requesting security definition data for: F.US.CLEZ23 (CLZ23). ID: 20 2026-04-17 08:21:07.730 | Mapping F.US.CLEF24 to CLF24. Service code: nymex 2026-04-17 08:21:07.730 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEF24 (CLF24). ID: 21 Service code: nymex 2026-04-17 08:21:07.730 | CQG WebAPI | Sending symbol resolution request for F.US.CLEF24. ID: 431634 2026-04-17 08:21:07.730 | Denali Data Feed | Requesting security definition data for: F.US.CLEF24 (CLF24). ID: 21 2026-04-17 08:21:07.731 | Mapping F.US.CLEG24 to CLG24. Service code: nymex 2026-04-17 08:21:07.731 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEG24 (CLG24). ID: 22 Service code: nymex 2026-04-17 08:21:07.731 | CQG WebAPI | Sending symbol resolution request for F.US.CLEG24. ID: 431635 2026-04-17 08:21:07.731 | Denali Data Feed | Requesting security definition data for: F.US.CLEG24 (CLG24). ID: 22 2026-04-17 08:21:07.731 | CQG WebAPI | Received symbol resolution report for symbol F.US.EPH23. Search Symbol: F.US.EPH23. Request ID: 431617. Contract ID: 4. 2026-04-17 08:21:07.731 | CQG WebAPI | Received symbol resolution report for symbol F.US.EPU23. Search Symbol: F.US.EPU23. Request ID: 431619. Contract ID: 5. 2026-04-17 08:21:07.739 | CQG WebAPI | Received symbol resolution report for symbol F.US.EPH24. Search Symbol: F.US.EPH24. Request ID: 431621. Contract ID: 6. 2026-04-17 08:21:07.818 | CQG WebAPI | Received symbol resolution report for symbol F.US.EPM23. Search Symbol: F.US.EPM23. Request ID: 431618. Contract ID: 7. 2026-04-17 08:21:07.823 | CQG WebAPI | Received symbol resolution report for symbol F.US.EPZ23. Search Symbol: F.US.EPZ23. Request ID: 431620. Contract ID: 8. 2026-04-17 08:21:07.823 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEF23. Search Symbol: F.US.CLEF23. Request ID: 431622. Contract ID: 9. 2026-04-17 08:21:07.826 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEG23. Search Symbol: F.US.CLEG23. Request ID: 431623. Contract ID: 10. 2026-04-17 08:21:07.826 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEH23. Search Symbol: F.US.CLEH23. Request ID: 431624. Contract ID: 11. 2026-04-17 08:21:07.827 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEM23. Search Symbol: F.US.CLEM23. Request ID: 431627. Contract ID: 12. 2026-04-17 08:21:07.827 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEJ23. Search Symbol: F.US.CLEJ23. Request ID: 431625. Contract ID: 13. 2026-04-17 08:21:07.827 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEK23. Search Symbol: F.US.CLEK23. Request ID: 431626. Contract ID: 14. 2026-04-17 08:21:07.827 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEQ23. Search Symbol: F.US.CLEQ23. Request ID: 431629. Contract ID: 15. 2026-04-17 08:21:07.827 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEN23. Search Symbol: F.US.CLEN23. Request ID: 431628. Contract ID: 16. 2026-04-17 08:21:07.830 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEU23. Search Symbol: F.US.CLEU23. Request ID: 431630. Contract ID: 17. 2026-04-17 08:21:07.830 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEX23. Search Symbol: F.US.CLEX23. Request ID: 431632. Contract ID: 18. 2026-04-17 08:21:07.830 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEV23. Search Symbol: F.US.CLEV23. Request ID: 431631. Contract ID: 19. 2026-04-17 08:21:07.830 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEZ23. Search Symbol: F.US.CLEZ23. Request ID: 431633. Contract ID: 20. 2026-04-17 08:21:07.830 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEF24. Search Symbol: F.US.CLEF24. Request ID: 431634. Contract ID: 21. 2026-04-17 08:21:07.911 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEG24. Search Symbol: F.US.CLEG24. Request ID: 431635. Contract ID: 22. 2026-04-17 08:21:08.255 | Denali Data Feed | Received logon response. 2026-04-17 08:21:08.255 | Denali Data Feed | Server Name: SC Realtime Server. 2026-04-17 08:21:08.255 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8 2026-04-17 08:21:08.255 | Denali Data Feed | Successfully connected. 2026-04-17 08:21:08.255 | Denali Data Feed | Trading is not supported. 2026-04-17 08:21:08.255 | Denali Data Feed | MarketDepthIsSupported: 1 2026-04-17 08:21:08.256 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEF23 -> CLF23 2026-04-17 08:21:08.256 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEF24 -> CLF24 2026-04-17 08:21:08.256 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEG23 -> CLG23 2026-04-17 08:21:08.256 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEG24 -> CLG24 2026-04-17 08:21:08.256 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEH23 -> CLH23 2026-04-17 08:21:08.256 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEJ23 -> CLJ23 2026-04-17 08:21:08.256 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEK23 -> CLK23 2026-04-17 08:21:08.256 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEM23 -> CLM23 2026-04-17 08:21:08.256 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEM26 -> CLM26 2026-04-17 08:21:08.256 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEN23 -> CLN23 2026-04-17 08:21:08.256 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEQ23 -> CLQ23 2026-04-17 08:21:08.256 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEU23 -> CLU23 2026-04-17 08:21:08.256 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEV23 -> CLV23 2026-04-17 08:21:08.256 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEV25 -> CLV25 2026-04-17 08:21:08.256 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEX23 -> CLX23 2026-04-17 08:21:08.256 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEZ23 -> CLZ23 2026-04-17 08:21:08.256 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.EPH23 -> ESH23 2026-04-17 08:21:08.256 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.EPH24 -> ESH24 2026-04-17 08:21:08.256 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.EPM23 -> ESM23 2026-04-17 08:21:08.256 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.EPU23 -> ESU23 2026-04-17 08:21:08.256 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.EPU25 -> ESU25 2026-04-17 08:21:08.256 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.EPZ23 -> ESZ23 2026-04-17 08:21:08.438 | Denali Data Feed | Real-time data for symbol F.US.CLEF23 is currently unavailable. 2026-04-17 08:21:08.439 | Denali Data Feed | Received security definition for symbol F.US.CLEF23 2026-04-17 08:21:08.439 | Denali Data Feed | Real-time data for symbol F.US.CLEF24 is currently unavailable. 2026-04-17 08:21:08.439 | Denali Data Feed | Received security definition for symbol F.US.CLEF24 2026-04-17 08:21:08.439 | Denali Data Feed | Real-time data for symbol F.US.CLEG23 is currently unavailable. 2026-04-17 08:21:08.439 | Denali Data Feed | Received security definition for symbol F.US.CLEG23 2026-04-17 08:21:08.439 | Denali Data Feed | Real-time data for symbol F.US.CLEG24 is currently unavailable. 2026-04-17 08:21:08.439 | Denali Data Feed | Received security definition for symbol F.US.CLEG24 2026-04-17 08:21:08.439 | Denali Data Feed | Real-time data for symbol F.US.CLEH23 is currently unavailable. 2026-04-17 08:21:08.439 | Denali Data Feed | Received security definition for symbol F.US.CLEH23 2026-04-17 08:21:08.531 | Denali Data Feed | Real-time data for symbol F.US.CLEJ23 is currently unavailable. 2026-04-17 08:21:08.531 | Denali Data Feed | Received security definition for symbol F.US.CLEJ23 2026-04-17 08:21:08.531 | Denali Data Feed | Real-time data for symbol F.US.CLEK23 is currently unavailable. 2026-04-17 08:21:08.531 | Denali Data Feed | Received security definition for symbol F.US.CLEK23 2026-04-17 08:21:08.531 | Denali Data Feed | Real-time data for symbol F.US.CLEM23 is currently unavailable. 2026-04-17 08:21:08.531 | Denali Data Feed | Received security definition for symbol F.US.CLEM23 2026-04-17 08:21:08.532 | Denali Data Feed | Setting external service identifier for symbol F.US.CLEM26 to 670557 2026-04-17 08:21:08.532 | Denali Data Feed | Received security definition for symbol F.US.CLEM26 2026-04-17 08:21:08.532 | Denali Data Feed | Real-time data for symbol F.US.CLEN23 is currently unavailable. 2026-04-17 08:21:08.532 | Denali Data Feed | Received security definition for symbol F.US.CLEN23 2026-04-17 08:21:08.532 | Denali Data Feed | Real-time data for symbol F.US.CLEQ23 is currently unavailable. 2026-04-17 08:21:08.532 | Denali Data Feed | Received security definition for symbol F.US.CLEQ23 2026-04-17 08:21:08.532 | Denali Data Feed | Real-time data for symbol F.US.CLEU23 is currently unavailable. 2026-04-17 08:21:08.532 | Denali Data Feed | Received security definition for symbol F.US.CLEU23 2026-04-17 08:21:08.532 | Denali Data Feed | Real-time data for symbol F.US.CLEV23 is currently unavailable. 2026-04-17 08:21:08.532 | Denali Data Feed | Received security definition for symbol F.US.CLEV23 2026-04-17 08:21:08.532 | Denali Data Feed | Real-time data for symbol F.US.CLEV25 is currently unavailable. 2026-04-17 08:21:08.532 | Denali Data Feed | Received security definition for symbol F.US.CLEV25 2026-04-17 08:21:08.532 | Denali Data Feed | Real-time data for symbol F.US.CLEX23 is currently unavailable. 2026-04-17 08:21:08.532 | Denali Data Feed | Received security definition for symbol F.US.CLEX23 2026-04-17 08:21:08.532 | Denali Data Feed | Real-time data for symbol F.US.CLEZ23 is currently unavailable. 2026-04-17 08:21:08.532 | Denali Data Feed | Received security definition for symbol F.US.CLEZ23 2026-04-17 08:21:08.532 | Denali Data Feed | Real-time data for symbol F.US.EPH23 is currently unavailable. 2026-04-17 08:21:08.532 | Denali Data Feed | Received security definition for symbol F.US.EPH23 2026-04-17 08:21:08.532 | Denali Data Feed | Real-time data for symbol F.US.EPH24 is currently unavailable. 2026-04-17 08:21:08.532 | Denali Data Feed | Received security definition for symbol F.US.EPH24 2026-04-17 08:21:08.532 | Denali Data Feed | Real-time data for symbol F.US.EPM23 is currently unavailable. 2026-04-17 08:21:08.532 | Denali Data Feed | Received security definition for symbol F.US.EPM23 2026-04-17 08:21:08.532 | Denali Data Feed | Real-time data for symbol F.US.EPU23 is currently unavailable. 2026-04-17 08:21:08.532 | Denali Data Feed | Received security definition for symbol F.US.EPU23 2026-04-17 08:21:08.532 | Denali Data Feed | Real-time data for symbol F.US.EPU25 is currently unavailable. 2026-04-17 08:21:08.532 | Denali Data Feed | Received security definition for symbol F.US.EPU25 2026-04-17 08:21:08.532 | Denali Data Feed | Real-time data for symbol F.US.EPZ23 is currently unavailable. 2026-04-17 08:21:08.532 | Denali Data Feed | Received security definition for symbol F.US.EPZ23 2026-04-17 08:21:12.030 | Requesting market depth updates for: F.US.CLEV25 if supported. NumLevels=100 2026-04-17 08:21:12.230 | Denali Data Feed | Clearing market depth for F.US.CLEV25 2026-04-17 08:21:13.643 | HD Request # 61 | Downloading Intraday chart data for F.US.CLEM26 to the file F.US.CLEM26.scid. Service: nymex 2026-04-17 08:21:13.647 | HD Request # 61 | Download start date-time: 2026-04-17 06:13:18.000000. File last date-time: 2026-04-17 06:13:18.698000 2026-04-17 08:21:13.649 | HD Request # 61 | Using server: ds26.sierracharts.com port 10150 2026-04-17 08:21:13.658 | Socket (4) | Creating socket. 2026-04-17 08:21:13.658 | Socket (4) | New receive buffer size: 0 2026-04-17 08:21:13.658 | Socket (4) | Connecting to IP: 64.152.155.17. 2026-04-17 08:21:13.836 | HD Request # 61 | Setting DTC encoding to Binary VLS 2026-04-17 08:21:13.836 | HD Request # 61 | Sending historical data logon request message. 2026-04-17 08:21:13.949 | HD Request # 61 | Requesting Intraday data. Start date-time: 2026-04-17 06:13:18. Record interval: 0. Symbol: CLM26 2026-04-17 08:21:14.399 | HD Request # 61 | Decompressing data. 2026-04-17 08:21:14.402 | HD Request # 61 | Receiving Intraday data for F.US.CLEM26 starting at 2026-04-17 06:13:18.698000 2026-04-17 08:21:14.488 | Socket (4) | CloseSocket call. 2026-04-17 08:21:14.488 | Socket (4) | Shutdown started. Waiting for graceful close. 2026-04-17 08:21:14.489 | Historical data download thread signaled to stop. 2026-04-17 08:21:14.489 | HD Request # 61 | Timestamp of first Intraday data file record written: 2026-04-17 06:13:20.112000. 2026-04-17 08:21:14.489 | HD Request # 61 | Received 10279 Intraday data records from 2026-04-17 06:13:18.698000 to 2026-04-17 08:21:12.732000 (2.1 hours. Delay: 1.8 seconds) and wrote 10278 records for F.US.CLEM26 2026-04-17 08:21:14.501 | HD Request # 61 | Add time&sales data | Remembered last file record date-time: 2026-04-17 12:21:12.732000 2026-04-17 08:21:14.501 | Added 5 Time and Sales records to Intraday data file for F.US.CLEM26 after download. 2026-04-17 08:21:14.501 | HD Request # 61 | Completion time: 1s. 2026-04-17 08:21:14.501 | HD Request # 61 | Intraday data download complete for F.US.CLEM26. Unique request ID: 61 2026-04-17 08:21:14.501 | Removing historical data download ID 61. 2026-04-17 08:21:14.501 | Real-time Intraday chart data file updates started for F.US.CLEM26 2026-04-17 08:21:14.501 | Intraday chart data file opened for F.US.CLEM26 2026-04-17 08:21:14.501 | HD Request # 61 | Enabling Intraday chart updating for symbol. 2026-04-17 08:21:14.501 | 2026-04-17 08:21:14.501 | Triggering next historical data download in queue. 2026-04-17 08:21:14.501 | HD Request # 62 | Downloading Intraday chart data for F.US.CLEV25 to the file F.US.CLEV25.scid. Service: nymex 2026-04-17 08:21:14.513 | HD Request # 62 | Download start date-time: 2025-09-22 14:29:55.000000. File last date-time: 2025-09-22 14:29:55.618000 2026-04-17 08:21:14.513 | HD Request # 62 | Using server: ds28.sierracharts.com port 10149 2026-04-17 08:21:14.520 | Socket (5) | Creating socket. 2026-04-17 08:21:14.520 | Socket (5) | New receive buffer size: 0 2026-04-17 08:21:14.520 | Socket (5) | Connecting to IP: 67.214.125.5. 2026-04-17 08:21:14.576 | Socket (4) | Socket gracefully closed by remote side. 2026-04-17 08:21:14.576 | Socket (4) | Closed. 2026-04-17 08:21:14.707 | HD Request # 62 | Setting DTC encoding to Binary VLS 2026-04-17 08:21:14.708 | HD Request # 62 | Sending historical data logon request message. 2026-04-17 08:21:14.835 | HD Request # 62 | Requesting Intraday data. Start date-time: 2025-09-22 14:29:55. Record interval: 0. Symbol: CLV25 2026-04-17 08:21:14.927 | HD Request # 62 | Decompressing data. 2026-04-17 08:21:15.019 | HD Request # 62 | Receiving Intraday data for F.US.CLEV25 starting at 2025-09-22 14:29:55.086000 2026-04-17 08:21:15.019 | Socket (5) | CloseSocket call. 2026-04-17 08:21:15.019 | Socket (5) | Shutdown started. Waiting for graceful close. 2026-04-17 08:21:15.019 | Historical data download thread signaled to stop. 2026-04-17 08:21:15.019 | HD Request # 62 | Received 2 Intraday data records from 2025-09-22 14:29:55.086000 to 2025-09-22 14:29:55.618000 (0.5 seconds. Delay: 206.7 days) and wrote 0 records for F.US.CLEV25 2026-04-17 08:21:15.020 | HD Request # 62 | Add time&sales data | Remembered last file record date-time: 2025-09-22 18:29:55.618000 2026-04-17 08:21:15.020 | HD Request # 62 | Completion time: 1s. 2026-04-17 08:21:15.020 | HD Request # 62 | Intraday data download complete for F.US.CLEV25. Unique request ID: 62 2026-04-17 08:21:15.020 | Removing historical data download ID 62. 2026-04-17 08:21:15.020 | Real-time Intraday chart data file updates started for F.US.CLEV25 2026-04-17 08:21:15.020 | Intraday chart data file opened for F.US.CLEV25 2026-04-17 08:21:15.020 | HD Request # 62 | Enabling Intraday chart updating for symbol. 2026-04-17 08:21:15.020 | 2026-04-17 08:21:15.020 | Triggering next historical data download in queue. 2026-04-17 08:21:15.020 | HD Request # 63 | Downloading Intraday chart data for F.US.EPU25 to the file F.US.EPU25.scid. Service: cme 2026-04-17 08:21:15.033 | HD Request # 63 | Download start date-time: 2025-09-19 09:29:58.000000. File last date-time: 2025-09-19 09:29:58.698000 2026-04-17 08:21:15.034 | HD Request # 63 | Using server: ds32.sierracharts.com port 10150 2026-04-17 08:21:15.040 | Socket (4) | Creating socket. 2026-04-17 08:21:15.041 | Socket (4) | New receive buffer size: 0 2026-04-17 08:21:15.041 | Socket (4) | Connecting to IP: 69.39.70.248. 2026-04-17 08:21:15.110 | Socket (5) | Socket gracefully closed by remote side. 2026-04-17 08:21:15.110 | Socket (5) | Closed. 2026-04-17 08:21:15.227 | HD Request # 63 | Setting DTC encoding to Binary VLS 2026-04-17 08:21:15.227 | HD Request # 63 | Sending historical data logon request message. 2026-04-17 08:21:15.347 | HD Request # 63 | Requesting Intraday data. Start date-time: 2025-09-19 09:29:58. Record interval: 0. Symbol: ESU25 2026-04-17 08:21:15.442 | HD Request # 63 | Decompressing data. 2026-04-17 08:21:15.535 | HD Request # 63 | Receiving Intraday data for F.US.EPU25 starting at 2025-09-19 09:29:58.697000 2026-04-17 08:21:15.536 | Socket (4) | CloseSocket call. 2026-04-17 08:21:15.536 | Socket (4) | Shutdown started. Waiting for graceful close. 2026-04-17 08:21:15.639 | Historical data download thread signaled to stop. 2026-04-17 08:21:15.639 | HD Request # 63 | Received 5 Intraday data records from 2025-09-19 09:29:58.697000 to 2025-09-19 09:29:58.698000 (0.0 seconds. Delay: 210.0 days) and wrote 0 records for F.US.EPU25 2026-04-17 08:21:15.640 | HD Request # 63 | Add time&sales data | Remembered last file record date-time: 2025-09-19 13:29:58.698000 2026-04-17 08:21:15.640 | HD Request # 63 | Completion time: 0s. 2026-04-17 08:21:15.640 | HD Request # 63 | Intraday data download complete for F.US.EPU25. Unique request ID: 63 2026-04-17 08:21:15.640 | Removing historical data download ID 63. 2026-04-17 08:21:15.640 | Real-time Intraday chart data file updates started for F.US.EPU25 2026-04-17 08:21:15.640 | Intraday chart data file opened for F.US.EPU25 2026-04-17 08:21:15.640 | HD Request # 63 | Enabling Intraday chart updating for symbol. 2026-04-17 08:21:15.640 | 2026-04-17 08:21:15.640 | No download requests in the queue to start downloads for. 2026-04-17 08:21:15.701 | Socket (4) | Socket gracefully closed by remote side. 2026-04-17 08:21:15.702 | Socket (4) | Closed. 2026-04-17 08:21:17.606 | Opened cached Intraday file: C:\SierraChart\Data\F.US.CLEM26.scid. Thread ID: 16976 2026-04-17 08:21:25.765 | CQG WebSocket socket (2) | Write has completed. Shutdown being performed. 2026-04-17 08:21:25.765 | CQG WebSocket socket (2) | Shutdown started. Waiting for graceful close. 2026-04-17 08:21:25.765 | CQG WebSocket socket (2) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. * 2026-04-17 08:21:25.765 | CQG WebSocket socket (2) | Socket gracefully closed by remote side. 2026-04-17 08:21:25.765 | CQG WebSocket socket (2) | Closed. 2026-04-17 11:48:39.210 | DTC Client socket (3) | Socket gracefully closed by remote side. 2026-04-17 11:48:39.350 | DTC Client socket (3) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. * 2026-04-17 11:48:39.359 | CQG WebSocket | Timeout waiting for pong message from server. 2026-04-17 11:48:39.359 | CQG WebAPI | WebSocket closed. 2026-04-17 11:48:39.360 | Connection to the external service has been lost. 2026-04-17 11:48:39.851 | DTC Client socket (3) | CloseSocket call. 2026-04-17 11:48:39.851 | DTC Client socket (3) | Signaling for receive thread to end. Bytes in receive buffer: 0 2026-04-17 11:48:39.924 | DTC Client socket (3) | Socket receive error. Windows error code 10053: An established connection was aborted by the software in your host machine. 2026-04-17 11:48:39.934 | DTC Client socket (3) | Max send buffers used during socket life: 4 2026-04-17 11:48:39.934 | DTC Client socket (3) | Max send buffer size during socket life: 1560 2026-04-17 11:48:39.935 | CQG WebAPI | Sending Web API Logoff message. 2026-04-17 11:48:39.936 | CQG WebSocket socket (1) | CloseSocket call. 2026-04-17 11:48:39.936 | CQG WebSocket socket (1) | Max send buffers used during socket life: 3 2026-04-17 11:48:39.936 | CQG WebSocket socket (1) | Max send buffer size during socket life: 517 2026-04-17 11:48:39.936 | CQG WebSocket | WebSocket closed. 2026-04-17 11:48:39.936 | CQG WebAPI | WebSocket closed. 2026-04-17 11:48:39.939 | CQG WebAPI | Disconnected. 2026-04-17 11:48:39.940 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-04-17 11:48:39.944 | Denali Data Feed | Server has requested a logoff. Reason: No heartbeat messages received for 76.5 seconds. Stopping connection. 2026-04-17 11:48:39.945 | DTC Client socket (0) | CloseSocket call. 2026-04-17 11:48:39.947 | Denali Data Feed | Disconnected from the server. 2026-04-17 11:48:39.948 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds. 2026-04-17 11:48:39.971 | DTC Client socket (3) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2026-04-17 11:48:39.971 | DTC Client socket (3) | Closed. 2026-04-17 11:48:39.971 | CQG WebSocket socket (1) | Write in progress. Shutdown being delayed. PendingSize=0 2026-04-17 11:48:40.007 | CQG WebSocket socket (1) | Write has completed. Shutdown being performed. 2026-04-17 11:48:40.007 | CQG WebSocket socket (1) | Shutdown started. Waiting for graceful close. 2026-04-17 11:48:41.943 | 2026-04-17 11:48:41.950 | CQG WebAPI | Connecting to server api.cqg.com 2026-04-17 11:48:41.950 | CQG WebSocket | Connecting to WebSocket server api.cqg.com:443 2026-04-17 11:48:42.266 | CQG WebSocket socket (2) | Creating socket. Using TLS 1.2. 2026-04-17 11:48:42.266 | CQG WebSocket socket (2) | New receive buffer size: 0 2026-04-17 11:48:42.266 | CQG WebSocket socket (2) | Connecting to IP: 195.166.124.175. 2026-04-17 11:48:42.271 | CQG WebSocket | Opening WebSocket. 2026-04-17 11:48:42.271 | CQG WebSocket | Sending WebSocket handshake. 2026-04-17 11:48:42.308 | CQG WebSocket | Server header | HTTP/1.1 101 Switching Protocols 2026-04-17 11:48:42.308 | CQG WebSocket | Server header | Connection: Upgrade 2026-04-17 11:48:42.308 | CQG WebSocket | Server header | Sec-WebSocket-Accept: d9msAuo63EJgvECULfkzcnFifZE= 2026-04-17 11:48:42.308 | CQG WebSocket | Server header | Server: WebSocket++/0.8.2 2026-04-17 11:48:42.308 | CQG WebSocket | Server header | Upgrade: websocket 2026-04-17 11:48:42.308 | CQG WebSocket | Server header | 2026-04-17 11:48:42.308 | CQG WebSocket | Web socket state is now open. 2026-04-17 11:48:42.308 | CQG WebAPI | WebSocket connected. 2026-04-17 11:48:42.309 | CQG WebAPI | Sending market data logon message. 2026-04-17 11:48:42.569 | CQG WebAPI | Base Time: 2026-04-12T15:44:25. 2026-04-12 15:44:25 2026-04-17 11:48:42.569 | CQG WebAPI | Logon successful. Session Token = biilSVE5bvU3D5gFIJkkiQ0g9Jknk3V3JTUYXp19d80NEiNoK5o0zE9P7VK/jPrerP23R8Ehb06 2026-04-17 11:48:42.569 | CQG WebAPI | Connection to server complete. 2026-04-17 11:48:42.569 | DTC Client socket (0) | CloseSocket call. 2026-04-17 11:48:42.569 | Denali Data Feed | Disconnected from the server. 2026-04-17 11:48:42.585 | No download requests in the queue to start downloads for. | Number times message added: 3 2026-04-17 11:48:42.586 | Updated verified funded futures trading account ending date to: 2026-05-17 15:48:42 2026-04-17 11:48:42.610 | CQG WebAPI | Sending Trade Accounts request message. 2026-04-17 11:48:42.720 | CQG WebAPI | Brokerage name: AMP. Account Name: 220033 2026-04-17 11:48:42.720 | Updated verified funded futures trading account ending date to: 2026-05-17 15:48:42 2026-04-17 11:48:42.720 | CQG WebAPI | Sending collateral subscribe request. 2026-04-17 11:48:42.834 | CQG WebAPI | Sending positions subscribe request. RequestID: 431642 2026-04-17 11:48:42.835 | CQG WebAPI | Sending orders subscribe request. RequestID: 431643 2026-04-17 11:48:42.974 | Mapping F.US.CLEV25 to CLV25. Service code: nymex 2026-04-17 11:48:42.974 | Using symbol data fast lookup vector 2026-04-17 11:48:42.975 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEV25 (CLV25). ID: 1 Service code: nymex 2026-04-17 11:48:42.976 | Denali Data Feed | Connecting to the server ds28.sierracharts.com. Port 443 2026-04-17 11:48:42.977 | CQG WebAPI | Sending symbol resolution request for F.US.CLEV25. ID: 431644 2026-04-17 11:48:42.977 | Denali Data Feed | Requesting security definition data for: F.US.CLEV25 (CLV25). ID: 1 2026-04-17 11:48:42.977 | Added historical Intraday data request for F.US.CLEV25 to the queue. 2026-04-17 11:48:42.978 | Intraday data recording state for symbol F.US.CLEV25 is set to download 'Pending'. 2026-04-17 11:48:42.978 | Triggering next historical data download in queue. 2026-04-17 11:48:42.978 | DTC Client socket (3) | Creating socket. 2026-04-17 11:48:42.978 | DTC Client socket (3) | New receive buffer size: 0 2026-04-17 11:48:42.978 | DTC Client socket (3) | Connecting to IP: 67.214.125.5. 2026-04-17 11:48:42.985 | Delaying start of download for F.US.CLEV25. 2026-04-17 11:48:42.987 | Mapping F.US.EPU25 to ESU25. Service code: cme 2026-04-17 11:48:42.987 | Denali Data Feed | Starting real-time market data updates for: F.US.EPU25 (ESU25). ID: 2 Service code: cme 2026-04-17 11:48:42.987 | CQG WebAPI | Sending symbol resolution request for F.US.EPU25. ID: 431645 2026-04-17 11:48:42.987 | Denali Data Feed | Requesting security definition data for: F.US.EPU25 (ESU25). ID: 2 2026-04-17 11:48:42.987 | Added historical Intraday data request for F.US.EPU25 to the queue. 2026-04-17 11:48:42.987 | Intraday data recording state for symbol F.US.EPU25 is set to download 'Pending'. 2026-04-17 11:48:42.987 | Triggering next historical data download in queue. 2026-04-17 11:48:43.003 | Mapping F.US.CLEM26 to CLM26. Service code: nymex 2026-04-17 11:48:43.003 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEM26 (CLM26). ID: 3 Service code: nymex 2026-04-17 11:48:43.003 | CQG WebAPI | Sending symbol resolution request for F.US.CLEM26. ID: 431646 2026-04-17 11:48:43.003 | Denali Data Feed | Requesting security definition data for: F.US.CLEM26 (CLM26). ID: 3 2026-04-17 11:48:43.003 | Added historical Intraday data request for F.US.CLEM26 to the queue. 2026-04-17 11:48:43.003 | Intraday data recording state for symbol F.US.CLEM26 is set to download 'Pending'. 2026-04-17 11:48:43.003 | Triggering next historical data download in queue. 2026-04-17 11:48:43.026 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEM26. Search Symbol: F.US.CLEM26. Request ID: 431646. Contract ID: 1. 2026-04-17 11:48:43.074 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEV25. Search Symbol: F.US.CLEV25. Request ID: 431644. Contract ID: 2. 2026-04-17 11:48:43.075 | Denali Data Feed | Network connection to server complete. 2026-04-17 11:48:43.075 | Denali Data Feed | Starting socket receive thread. 2026-04-17 11:48:43.075 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard 2026-04-17 11:48:43.167 | CQG WebAPI | Received symbol resolution report for symbol F.US.EPU25. Search Symbol: F.US.EPU25. Request ID: 431645. Contract ID: 3. 2026-04-17 11:48:43.171 | Denali Data Feed | Setting DTC encoding to Binary VLS 2026-04-17 11:48:43.172 | Denali Data Feed | Sending logon request message. 2026-04-17 11:48:43.702 | Denali Data Feed | Received logon response. 2026-04-17 11:48:43.702 | Denali Data Feed | Server Name: SC Realtime Server. 2026-04-17 11:48:43.702 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8 2026-04-17 11:48:43.702 | Denali Data Feed | Successfully connected. 2026-04-17 11:48:43.702 | Denali Data Feed | Trading is not supported. 2026-04-17 11:48:43.702 | Denali Data Feed | MarketDepthIsSupported: 1 2026-04-17 11:48:43.702 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEM26 -> CLM26 2026-04-17 11:48:43.703 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEV25 -> CLV25 2026-04-17 11:48:43.703 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.EPU25 -> ESU25 2026-04-17 11:48:43.890 | Denali Data Feed | Setting external service identifier for symbol F.US.CLEM26 to 670557 2026-04-17 11:48:43.890 | Denali Data Feed | Received security definition for symbol F.US.CLEM26 2026-04-17 11:48:43.890 | Denali Data Feed | Real-time data for symbol F.US.CLEV25 is currently unavailable. 2026-04-17 11:48:43.890 | Denali Data Feed | Received security definition for symbol F.US.CLEV25 2026-04-17 11:48:43.890 | Denali Data Feed | Real-time data for symbol F.US.EPU25 is currently unavailable. 2026-04-17 11:48:43.890 | Denali Data Feed | Received security definition for symbol F.US.EPU25 2026-04-17 11:48:47.582 | Requesting market depth updates for: F.US.CLEV25 if supported. NumLevels=100 2026-04-17 11:48:47.702 | Denali Data Feed | Clearing market depth for F.US.CLEV25 2026-04-17 11:48:48.921 | HD Request # 64 | Downloading Intraday chart data for F.US.CLEV25 to the file F.US.CLEV25.scid. Service: nymex 2026-04-17 11:48:48.923 | HD Request # 64 | Download start date-time: 2025-09-22 14:29:55.000000. File last date-time: 2025-09-22 14:29:55.618000 2026-04-17 11:48:48.924 | HD Request # 64 | Using server: ds26.sierracharts.com port 10149 2026-04-17 11:48:48.926 | Socket (4) | Creating socket. 2026-04-17 11:48:48.926 | Socket (4) | New receive buffer size: 0 2026-04-17 11:48:48.926 | Socket (4) | Connecting to IP: 64.152.155.17. 2026-04-17 11:48:49.106 | HD Request # 64 | Setting DTC encoding to Binary VLS 2026-04-17 11:48:49.106 | HD Request # 64 | Sending historical data logon request message. 2026-04-17 11:48:49.225 | HD Request # 64 | Requesting Intraday data. Start date-time: 2025-09-22 14:29:55. Record interval: 0. Symbol: CLV25 2026-04-17 11:48:49.312 | HD Request # 64 | Decompressing data. 2026-04-17 11:48:49.401 | HD Request # 64 | Receiving Intraday data for F.US.CLEV25 starting at 2025-09-22 14:29:55.086000 2026-04-17 11:48:49.401 | Socket (4) | CloseSocket call. 2026-04-17 11:48:49.401 | Socket (4) | Shutdown started. Waiting for graceful close. 2026-04-17 11:48:49.402 | Historical data download thread signaled to stop. 2026-04-17 11:48:49.402 | HD Request # 64 | Received 2 Intraday data records from 2025-09-22 14:29:55.086000 to 2025-09-22 14:29:55.618000 (0.5 seconds. Delay: 206.9 days) and wrote 0 records for F.US.CLEV25 2026-04-17 11:48:49.403 | HD Request # 64 | Add time&sales data | Remembered last file record date-time: 2025-09-22 18:29:55.618000 2026-04-17 11:48:49.403 | HD Request # 64 | Completion time: 1s. 2026-04-17 11:48:49.403 | HD Request # 64 | Intraday data download complete for F.US.CLEV25. Unique request ID: 64 2026-04-17 11:48:49.403 | Removing historical data download ID 64. 2026-04-17 11:48:49.403 | Real-time Intraday chart data file updates started for F.US.CLEV25 2026-04-17 11:48:49.403 | Intraday chart data file opened for F.US.CLEV25 2026-04-17 11:48:49.403 | HD Request # 64 | Enabling Intraday chart updating for symbol. 2026-04-17 11:48:49.403 | 2026-04-17 11:48:49.403 | Triggering next historical data download in queue. 2026-04-17 11:48:49.404 | HD Request # 65 | Downloading Intraday chart data for F.US.EPU25 to the file F.US.EPU25.scid. Service: cme 2026-04-17 11:48:49.405 | HD Request # 65 | Download start date-time: 2025-09-19 09:29:58.000000. File last date-time: 2025-09-19 09:29:58.698000 2026-04-17 11:48:49.405 | HD Request # 65 | Using server: ds28.sierracharts.com port 10150 2026-04-17 11:48:49.406 | Socket (5) | Creating socket. 2026-04-17 11:48:49.406 | Socket (5) | New receive buffer size: 0 2026-04-17 11:48:49.406 | Socket (5) | Connecting to IP: 67.214.125.5. 2026-04-17 11:48:49.489 | Socket (4) | Socket gracefully closed by remote side. 2026-04-17 11:48:49.489 | Socket (4) | Closed. 2026-04-17 11:48:49.592 | HD Request # 65 | Setting DTC encoding to Binary VLS 2026-04-17 11:48:49.592 | HD Request # 65 | Sending historical data logon request message. 2026-04-17 11:48:50.014 | HD Request # 65 | Requesting Intraday data. Start date-time: 2025-09-19 09:29:58. Record interval: 0. Symbol: ESU25 2026-04-17 11:48:50.107 | HD Request # 65 | Decompressing data. 2026-04-17 11:48:50.198 | HD Request # 65 | Receiving Intraday data for F.US.EPU25 starting at 2025-09-19 09:29:58.697000 2026-04-17 11:48:50.198 | Socket (5) | CloseSocket call. 2026-04-17 11:48:50.199 | Socket (5) | Shutdown started. Waiting for graceful close. 2026-04-17 11:48:50.200 | Historical data download thread signaled to stop. 2026-04-17 11:48:50.200 | HD Request # 65 | Received 5 Intraday data records from 2025-09-19 09:29:58.697000 to 2025-09-19 09:29:58.698000 (0.0 seconds. Delay: 210.1 days) and wrote 0 records for F.US.EPU25 2026-04-17 11:48:50.200 | HD Request # 65 | Add time&sales data | Remembered last file record date-time: 2025-09-19 13:29:58.698000 2026-04-17 11:48:50.200 | HD Request # 65 | Completion time: 1s. 2026-04-17 11:48:50.200 | HD Request # 65 | Intraday data download complete for F.US.EPU25. Unique request ID: 65 2026-04-17 11:48:50.200 | Removing historical data download ID 65. 2026-04-17 11:48:50.200 | Real-time Intraday chart data file updates started for F.US.EPU25 2026-04-17 11:48:50.200 | Intraday chart data file opened for F.US.EPU25 2026-04-17 11:48:50.200 | HD Request # 65 | Enabling Intraday chart updating for symbol. 2026-04-17 11:48:50.200 | 2026-04-17 11:48:50.200 | Triggering next historical data download in queue. 2026-04-17 11:48:50.200 | HD Request # 66 | Downloading Intraday chart data for F.US.CLEM26 to the file F.US.CLEM26.scid. Service: nymex 2026-04-17 11:48:50.200 | HD Request # 66 | Download start date-time: 2026-04-17 11:39:35.000000. File last date-time: 2026-04-17 11:39:35.085000 2026-04-17 11:48:50.201 | HD Request # 66 | Using server: ds32.sierracharts.com port 10149 2026-04-17 11:48:50.201 | Socket (4) | Creating socket. 2026-04-17 11:48:50.201 | Socket (4) | New receive buffer size: 0 2026-04-17 11:48:50.201 | Socket (4) | Connecting to IP: 69.39.70.248. 2026-04-17 11:48:50.289 | Socket (5) | Socket gracefully closed by remote side. 2026-04-17 11:48:50.289 | Socket (5) | Closed. 2026-04-17 11:48:50.388 | HD Request # 66 | Setting DTC encoding to Binary VLS 2026-04-17 11:48:50.388 | HD Request # 66 | Sending historical data logon request message. 2026-04-17 11:48:50.511 | HD Request # 66 | Requesting Intraday data. Start date-time: 2026-04-17 11:39:35. Record interval: 0. Symbol: CLM26 2026-04-17 11:48:50.603 | HD Request # 66 | Decompressing data. 2026-04-17 11:48:50.795 | HD Request # 66 | Receiving Intraday data for F.US.CLEM26 starting at 2026-04-17 11:39:35.018000 2026-04-17 11:48:50.796 | Socket (4) | CloseSocket call. 2026-04-17 11:48:50.796 | Socket (4) | Shutdown started. Waiting for graceful close. 2026-04-17 11:48:50.799 | Historical data download thread signaled to stop. 2026-04-17 11:48:50.800 | HD Request # 66 | Timestamp of first Intraday data file record written: 2026-04-17 11:39:35.448000. 2026-04-17 11:48:50.800 | HD Request # 66 | Received 2898 Intraday data records from 2026-04-17 11:39:35.018000 to 2026-04-17 11:48:50.418000 (9.3 minutes. Delay: 0.4 seconds) and wrote 2895 records for F.US.CLEM26 2026-04-17 11:48:50.809 | HD Request # 66 | Add time&sales data | Remembered last file record date-time: 2026-04-17 15:48:50.418000 2026-04-17 11:48:50.809 | HD Request # 66 | Completion time: 0s. 2026-04-17 11:48:50.809 | HD Request # 66 | Intraday data download complete for F.US.CLEM26. Unique request ID: 66 2026-04-17 11:48:50.809 | Removing historical data download ID 66. 2026-04-17 11:48:50.809 | Real-time Intraday chart data file updates started for F.US.CLEM26 2026-04-17 11:48:50.809 | Intraday chart data file opened for F.US.CLEM26 2026-04-17 11:48:50.809 | HD Request # 66 | Enabling Intraday chart updating for symbol. 2026-04-17 11:48:50.809 | 2026-04-17 11:48:50.809 | No download requests in the queue to start downloads for. 2026-04-17 11:48:50.888 | Socket (4) | Socket gracefully closed by remote side. 2026-04-17 11:48:50.888 | Socket (4) | Closed. 2026-04-17 11:48:53.349 | Opened cached Intraday file: C:\SierraChart\Data\F.US.CLEM26.scid. Thread ID: 16976 2026-04-17 11:50:40.063 | CQG WebSocket socket (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. * 2026-04-17 11:50:40.063 | CQG WebSocket socket (1) | Socket gracefully closed by remote side. 2026-04-17 11:50:40.064 | CQG WebSocket socket (1) | Closed. 2026-04-17 16:21:17.000 | CQG WebSocket | Timeout waiting for pong message from server. 2026-04-17 16:21:17.001 | CQG WebAPI | WebSocket closed. 2026-04-17 16:21:17.001 | Connection to the external service has been lost. 2026-04-17 16:21:17.565 | DTC Client socket (3) | Socket send error. Windows error code 10054: An existing connection was forcibly closed by the remote host. 2026-04-17 16:21:17.626 | DTC Client socket (3) | Socket gracefully closed by remote side. 2026-04-17 16:21:17.655 | DTC Client socket (3) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. * 2026-04-17 16:21:17.655 | CQG WebAPI | Sending Web API Logoff message. 2026-04-17 16:21:17.667 | CQG WebSocket socket (2) | CloseSocket call. 2026-04-17 16:21:17.667 | CQG WebSocket socket (2) | Max send buffers used during socket life: 3 2026-04-17 16:21:17.667 | CQG WebSocket socket (2) | Max send buffer size during socket life: 309 2026-04-17 16:21:17.667 | CQG WebSocket | WebSocket closed. 2026-04-17 16:21:17.667 | CQG WebAPI | WebSocket closed. 2026-04-17 16:21:17.670 | CQG WebSocket socket (2) | Write in progress. Shutdown being delayed. PendingSize=8 2026-04-17 16:21:17.685 | CQG WebAPI | Disconnected. 2026-04-17 16:21:17.687 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-04-17 16:21:17.692 | DTC Client socket (3) | Socket receive error. Windows error code 10053: An established connection was aborted by the software in your host machine. 2026-04-17 16:21:17.695 | DTC Client socket (3) | CloseSocket call. 2026-04-17 16:21:17.695 | DTC Client socket (3) | Signaling for receive thread to end. Bytes in receive buffer: 0 2026-04-17 16:21:17.840 | DTC Client socket (3) | Max send buffers used during socket life: 4 2026-04-17 16:21:17.840 | DTC Client socket (3) | Max send buffer size during socket life: 212 2026-04-17 16:21:17.841 | Denali Data Feed | Server has requested a logoff. Reason: No heartbeat messages received for 79.8 seconds. Stopping connection. 2026-04-17 16:21:17.841 | DTC Client socket (0) | CloseSocket call. 2026-04-17 16:21:17.842 | Denali Data Feed | Disconnected from the server. 2026-04-17 16:21:17.842 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds. 2026-04-17 16:21:17.874 | DTC Client socket (3) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2026-04-17 16:21:17.875 | DTC Client socket (3) | Closed. 2026-04-17 16:21:19.681 | 2026-04-17 16:21:19.683 | CQG WebAPI | Connecting to server api.cqg.com 2026-04-17 16:21:19.683 | CQG WebSocket | Connecting to WebSocket server api.cqg.com:443 2026-04-17 16:21:19.787 | CQG WebSocket socket (1) | Creating socket. Using TLS 1.2. 2026-04-17 16:21:19.787 | CQG WebSocket socket (1) | New receive buffer size: 0 2026-04-17 16:21:19.787 | CQG WebSocket socket (1) | Connecting to IP: 195.166.124.175. 2026-04-17 16:21:19.813 | CQG WebSocket | Opening WebSocket. 2026-04-17 16:21:19.813 | CQG WebSocket | Sending WebSocket handshake. 2026-04-17 16:21:19.884 | CQG WebSocket | Server header | HTTP/1.1 101 Switching Protocols 2026-04-17 16:21:19.884 | CQG WebSocket | Server header | Connection: Upgrade 2026-04-17 16:21:19.884 | CQG WebSocket | Server header | Sec-WebSocket-Accept: a8a54TciFwH86Jit1xpBWuZKnhM= 2026-04-17 16:21:19.884 | CQG WebSocket | Server header | Server: WebSocket++/0.8.2 2026-04-17 16:21:19.884 | CQG WebSocket | Server header | Upgrade: websocket 2026-04-17 16:21:19.884 | CQG WebSocket | Server header | 2026-04-17 16:21:19.884 | CQG WebSocket | Web socket state is now open. 2026-04-17 16:21:19.884 | CQG WebAPI | WebSocket connected. 2026-04-17 16:21:19.885 | CQG WebAPI | Sending market data logon message. 2026-04-17 16:21:20.276 | CQG WebAPI | Base Time: 2026-04-12T15:43:05. 2026-04-12 15:43:05 2026-04-17 16:21:20.276 | CQG WebAPI | Logon successful. Session Token = pEcBoi52TEFU1uRzhsZUBBzutymwAMWM/yTWbM9qjY89k7gvkn6WlfH1YUg+OGTsDcMbi+IyBV1 2026-04-17 16:21:20.276 | CQG WebAPI | Connection to server complete. 2026-04-17 16:21:20.277 | DTC Client socket (0) | CloseSocket call. 2026-04-17 16:21:20.277 | Denali Data Feed | Disconnected from the server. 2026-04-17 16:21:20.289 | No download requests in the queue to start downloads for. | Number times message added: 3 2026-04-17 16:21:20.289 | Updated verified funded futures trading account ending date to: 2026-05-17 20:21:20 2026-04-17 16:21:20.313 | CQG WebAPI | Sending Trade Accounts request message. 2026-04-17 16:21:20.548 | CQG WebAPI | Sending positions subscribe request. RequestID: 431648 2026-04-17 16:21:20.549 | CQG WebAPI | Sending orders subscribe request. RequestID: 431649 2026-04-17 16:21:20.569 | Mapping F.US.CLEV25 to CLV25. Service code: nymex 2026-04-17 16:21:20.569 | Using symbol data fast lookup vector 2026-04-17 16:21:20.571 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEV25 (CLV25). ID: 1 Service code: nymex 2026-04-17 16:21:20.573 | Denali Data Feed | Connecting to the server ds25.sierracharts.com. Port 443 2026-04-17 16:21:20.573 | CQG WebAPI | Sending symbol resolution request for F.US.CLEV25. ID: 431650 2026-04-17 16:21:20.573 | Denali Data Feed | Requesting security definition data for: F.US.CLEV25 (CLV25). ID: 1 2026-04-17 16:21:20.574 | Added historical Intraday data request for F.US.CLEV25 to the queue. 2026-04-17 16:21:20.574 | Intraday data recording state for symbol F.US.CLEV25 is set to download 'Pending'. 2026-04-17 16:21:20.574 | Triggering next historical data download in queue. 2026-04-17 16:21:20.590 | CQG WebAPI | Brokerage name: AMP. Account Name: 220033 2026-04-17 16:21:20.590 | Updated verified funded futures trading account ending date to: 2026-05-17 20:21:20 2026-04-17 16:21:20.590 | CQG WebAPI | Sending collateral subscribe request. 2026-04-17 16:21:20.591 | Delaying start of download for F.US.CLEV25. 2026-04-17 16:21:20.592 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEV25. Search Symbol: F.US.CLEV25. Request ID: 431650. Contract ID: 1. 2026-04-17 16:21:20.593 | DTC Client socket (3) | Creating socket. 2026-04-17 16:21:20.594 | DTC Client socket (3) | New receive buffer size: 0 2026-04-17 16:21:20.594 | DTC Client socket (3) | Connecting to IP: 64.152.155.20. 2026-04-17 16:21:20.617 | Mapping F.US.EPU25 to ESU25. Service code: cme 2026-04-17 16:21:20.619 | Denali Data Feed | Starting real-time market data updates for: F.US.EPU25 (ESU25). ID: 2 Service code: cme 2026-04-17 16:21:20.619 | CQG WebAPI | Sending symbol resolution request for F.US.EPU25. ID: 431652 2026-04-17 16:21:20.619 | Denali Data Feed | Requesting security definition data for: F.US.EPU25 (ESU25). ID: 2 2026-04-17 16:21:20.619 | Added historical Intraday data request for F.US.EPU25 to the queue. 2026-04-17 16:21:20.619 | Intraday data recording state for symbol F.US.EPU25 is set to download 'Pending'. 2026-04-17 16:21:20.619 | Triggering next historical data download in queue. 2026-04-17 16:21:20.692 | CQG WebAPI | Received symbol resolution report for symbol F.US.EPU25. Search Symbol: F.US.EPU25. Request ID: 431652. Contract ID: 2. 2026-04-17 16:21:20.719 | Denali Data Feed | Network connection to server complete. 2026-04-17 16:21:20.719 | Denali Data Feed | Starting socket receive thread. 2026-04-17 16:21:20.720 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard 2026-04-17 16:21:20.722 | Mapping F.US.CLEM26 to CLM26. Service code: nymex 2026-04-17 16:21:20.723 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEM26 (CLM26). ID: 3 Service code: nymex 2026-04-17 16:21:20.724 | CQG WebAPI | Sending symbol resolution request for F.US.CLEM26. ID: 431653 2026-04-17 16:21:20.725 | Denali Data Feed | Requesting security definition data for: F.US.CLEM26 (CLM26). ID: 3 2026-04-17 16:21:20.726 | Added historical Intraday data request for F.US.CLEM26 to the queue. 2026-04-17 16:21:20.726 | Intraday data recording state for symbol F.US.CLEM26 is set to download 'Pending'. 2026-04-17 16:21:20.726 | Triggering next historical data download in queue. 2026-04-17 16:21:20.973 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEM26. Search Symbol: F.US.CLEM26. Request ID: 431653. Contract ID: 3. 2026-04-17 16:21:21.068 | Denali Data Feed | Setting DTC encoding to Binary VLS 2026-04-17 16:21:21.068 | Denali Data Feed | Sending logon request message. 2026-04-17 16:21:21.920 | Denali Data Feed | Received logon response. 2026-04-17 16:21:21.920 | Denali Data Feed | Server Name: SC Realtime Server. 2026-04-17 16:21:21.920 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8 2026-04-17 16:21:21.920 | Denali Data Feed | Successfully connected. 2026-04-17 16:21:21.920 | Denali Data Feed | Trading is not supported. 2026-04-17 16:21:21.920 | Denali Data Feed | MarketDepthIsSupported: 1 2026-04-17 16:21:21.921 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEM26 -> CLM26 2026-04-17 16:21:21.921 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEV25 -> CLV25 2026-04-17 16:21:21.921 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.EPU25 -> ESU25 2026-04-17 16:21:22.097 | Denali Data Feed | Setting external service identifier for symbol F.US.CLEM26 to 670557 2026-04-17 16:21:22.097 | Denali Data Feed | Received security definition for symbol F.US.CLEM26 2026-04-17 16:21:22.097 | Denali Data Feed | Real-time data for symbol F.US.CLEV25 is currently unavailable. 2026-04-17 16:21:22.097 | Denali Data Feed | Received security definition for symbol F.US.CLEV25 2026-04-17 16:21:22.097 | Denali Data Feed | Real-time data for symbol F.US.EPU25 is currently unavailable. 2026-04-17 16:21:22.097 | Denali Data Feed | Received security definition for symbol F.US.EPU25 2026-04-17 16:21:25.287 | Requesting market depth updates for: F.US.CLEV25 if supported. NumLevels=100 2026-04-17 16:21:25.469 | Denali Data Feed | Clearing market depth for F.US.CLEV25 2026-04-17 16:21:27.018 | HD Request # 67 | Downloading Intraday chart data for F.US.CLEV25 to the file F.US.CLEV25.scid. Service: nymex 2026-04-17 16:21:27.021 | HD Request # 67 | Download start date-time: 2025-09-22 14:29:55.000000. File last date-time: 2025-09-22 14:29:55.618000 2026-04-17 16:21:27.022 | HD Request # 67 | Using server: ds26.sierracharts.com port 10150 2026-04-17 16:21:27.032 | Socket (4) | Creating socket. 2026-04-17 16:21:27.032 | Socket (4) | New receive buffer size: 0 2026-04-17 16:21:27.032 | Socket (4) | Connecting to IP: 64.152.155.17. 2026-04-17 16:21:27.217 | HD Request # 67 | Setting DTC encoding to Binary VLS 2026-04-17 16:21:27.217 | HD Request # 67 | Sending historical data logon request message. 2026-04-17 16:21:27.338 | HD Request # 67 | Requesting Intraday data. Start date-time: 2025-09-22 14:29:55. Record interval: 0. Symbol: CLV25 2026-04-17 16:21:27.431 | HD Request # 67 | Decompressing data. 2026-04-17 16:21:27.524 | HD Request # 67 | Receiving Intraday data for F.US.CLEV25 starting at 2025-09-22 14:29:55.086000 2026-04-17 16:21:27.524 | Socket (4) | CloseSocket call. 2026-04-17 16:21:27.524 | Socket (4) | Shutdown started. Waiting for graceful close. 2026-04-17 16:21:27.591 | Historical data download thread signaled to stop. 2026-04-17 16:21:27.591 | HD Request # 67 | Received 2 Intraday data records from 2025-09-22 14:29:55.086000 to 2025-09-22 14:29:55.618000 (0.5 seconds. Delay: 207.1 days) and wrote 0 records for F.US.CLEV25 2026-04-17 16:21:27.592 | HD Request # 67 | Add time&sales data | Remembered last file record date-time: 2025-09-22 18:29:55.618000 2026-04-17 16:21:27.592 | HD Request # 67 | Completion time: 0s. 2026-04-17 16:21:27.592 | HD Request # 67 | Intraday data download complete for F.US.CLEV25. Unique request ID: 67 2026-04-17 16:21:27.592 | Removing historical data download ID 67. 2026-04-17 16:21:27.593 | Real-time Intraday chart data file updates started for F.US.CLEV25 2026-04-17 16:21:27.593 | Intraday chart data file opened for F.US.CLEV25 2026-04-17 16:21:27.593 | HD Request # 67 | Enabling Intraday chart updating for symbol. 2026-04-17 16:21:27.593 | 2026-04-17 16:21:27.593 | Triggering next historical data download in queue. 2026-04-17 16:21:27.593 | HD Request # 68 | Downloading Intraday chart data for F.US.EPU25 to the file F.US.EPU25.scid. Service: cme 2026-04-17 16:21:27.595 | HD Request # 68 | Download start date-time: 2025-09-19 09:29:58.000000. File last date-time: 2025-09-19 09:29:58.698000 2026-04-17 16:21:27.595 | HD Request # 68 | Using server: ds28.sierracharts.com port 10149 2026-04-17 16:21:27.624 | Socket (4) | Socket gracefully closed by remote side. 2026-04-17 16:21:27.624 | Socket (4) | Closed. 2026-04-17 16:21:27.666 | Socket (5) | Creating socket. 2026-04-17 16:21:27.666 | Socket (5) | New receive buffer size: 0 2026-04-17 16:21:27.666 | Socket (5) | Connecting to IP: 67.214.125.5. 2026-04-17 16:21:27.871 | HD Request # 68 | Setting DTC encoding to Binary VLS 2026-04-17 16:21:27.871 | HD Request # 68 | Sending historical data logon request message. 2026-04-17 16:21:27.998 | HD Request # 68 | Requesting Intraday data. Start date-time: 2025-09-19 09:29:58. Record interval: 0. Symbol: ESU25 2026-04-17 16:21:28.095 | HD Request # 68 | Decompressing data. 2026-04-17 16:21:28.194 | HD Request # 68 | Receiving Intraday data for F.US.EPU25 starting at 2025-09-19 09:29:58.697000 2026-04-17 16:21:28.195 | Socket (5) | CloseSocket call. 2026-04-17 16:21:28.195 | Socket (5) | Shutdown started. Waiting for graceful close. 2026-04-17 16:21:28.201 | Historical data download thread signaled to stop. 2026-04-17 16:21:28.201 | HD Request # 68 | Received 5 Intraday data records from 2025-09-19 09:29:58.697000 to 2025-09-19 09:29:58.698000 (0.0 seconds. Delay: 210.3 days) and wrote 0 records for F.US.EPU25 2026-04-17 16:21:28.202 | HD Request # 68 | Add time&sales data | Remembered last file record date-time: 2025-09-19 13:29:58.698000 2026-04-17 16:21:28.202 | HD Request # 68 | Completion time: 1s. 2026-04-17 16:21:28.202 | HD Request # 68 | Intraday data download complete for F.US.EPU25. Unique request ID: 68 2026-04-17 16:21:28.202 | Removing historical data download ID 68. 2026-04-17 16:21:28.202 | Real-time Intraday chart data file updates started for F.US.EPU25 2026-04-17 16:21:28.202 | Intraday chart data file opened for F.US.EPU25 2026-04-17 16:21:28.202 | HD Request # 68 | Enabling Intraday chart updating for symbol. 2026-04-17 16:21:28.202 | 2026-04-17 16:21:28.202 | Triggering next historical data download in queue. 2026-04-17 16:21:28.202 | HD Request # 69 | Downloading Intraday chart data for F.US.CLEM26 to the file F.US.CLEM26.scid. Service: nymex 2026-04-17 16:21:28.204 | HD Request # 69 | Download start date-time: 2026-04-17 12:55:08.000000. File last date-time: 2026-04-17 12:55:08.069001 2026-04-17 16:21:28.204 | HD Request # 69 | Using server: ds32.sierracharts.com port 10150 2026-04-17 16:21:28.241 | Socket (4) | Creating socket. 2026-04-17 16:21:28.241 | Socket (4) | New receive buffer size: 0 2026-04-17 16:21:28.241 | Socket (4) | Connecting to IP: 69.39.70.248. 2026-04-17 16:21:28.315 | Socket (5) | Socket gracefully closed by remote side. 2026-04-17 16:21:28.316 | Socket (5) | Closed. 2026-04-17 16:21:28.459 | HD Request # 69 | Setting DTC encoding to Binary VLS 2026-04-17 16:21:28.459 | HD Request # 69 | Sending historical data logon request message. 2026-04-17 16:21:28.930 | HD Request # 69 | Requesting Intraday data. Start date-time: 2026-04-17 12:55:08. Record interval: 0. Symbol: CLM26 2026-04-17 16:21:29.025 | HD Request # 69 | Decompressing data. 2026-04-17 16:21:29.229 | HD Request # 69 | Receiving Intraday data for F.US.CLEM26 starting at 2026-04-17 12:55:08.069000 2026-04-17 16:21:29.518 | HD Request # 69 | Timestamp of first Intraday data file record written: 2026-04-17 12:55:09.138000. 2026-04-17 16:21:29.608 | Socket (4) | CloseSocket call. 2026-04-17 16:21:29.608 | Socket (4) | Shutdown started. Waiting for graceful close. 2026-04-17 16:21:29.643 | Historical data download thread signaled to stop. 2026-04-17 16:21:29.644 | HD Request # 69 | Received 44588 Intraday data records from 2026-04-17 12:55:08.069000 to 2026-04-17 16:21:23.376000 (3.4 hours. Delay: 6.3 seconds) and wrote 44586 records for F.US.CLEM26 2026-04-17 16:21:29.694 | HD Request # 69 | Add time&sales data | Remembered last file record date-time: 2026-04-17 20:21:23.376000 2026-04-17 16:21:29.694 | Added 8 Time and Sales records to Intraday data file for F.US.CLEM26 after download. 2026-04-17 16:21:29.695 | HD Request # 69 | Completion time: 1s. 2026-04-17 16:21:29.695 | HD Request # 69 | Intraday data download complete for F.US.CLEM26. Unique request ID: 69 2026-04-17 16:21:29.695 | Removing historical data download ID 69. 2026-04-17 16:21:29.695 | Real-time Intraday chart data file updates started for F.US.CLEM26 2026-04-17 16:21:29.695 | Intraday chart data file opened for F.US.CLEM26 2026-04-17 16:21:29.695 | HD Request # 69 | Enabling Intraday chart updating for symbol. 2026-04-17 16:21:29.695 | 2026-04-17 16:21:29.695 | No download requests in the queue to start downloads for. 2026-04-17 16:21:29.700 | Socket (4) | Socket gracefully closed by remote side. 2026-04-17 16:21:29.700 | Socket (4) | Closed. 2026-04-17 16:21:33.964 | Opened cached Intraday file: C:\SierraChart\Data\F.US.CLEM26.scid. Thread ID: 16976 2026-04-17 16:21:36.587 | CQG WebSocket socket (2) | Write has completed. Shutdown being performed. 2026-04-17 16:21:36.587 | CQG WebSocket socket (2) | Shutdown started. Waiting for graceful close. 2026-04-17 16:21:36.587 | CQG WebSocket socket (2) | Socket gracefully closed by remote side. 2026-04-17 16:21:36.587 | CQG WebSocket socket (2) | Closed. 2026-04-17 22:11:02.008 | The data feed was lost. There was no activity for at least 60.0 seconds. 2026-04-17 22:11:02.008 | Connection to the external service has been lost. 2026-04-17 22:11:02.142 | CQG WebSocket | Timeout waiting for pong message from server. 2026-04-17 22:11:02.143 | CQG WebAPI | WebSocket closed. 2026-04-17 22:11:02.143 | Denali Data Feed | There has been no activity on the network socket for 3h 34m 45s. Will reconnect. 2026-04-17 22:11:02.144 | Denali Data Feed | Waiting for socket receive thread to end 2026-04-17 22:11:02.148 | DTC Client socket (3) | CloseSocket call. 2026-04-17 22:11:02.148 | DTC Client socket (3) | Max send buffers used during socket life: 3 2026-04-17 22:11:02.148 | DTC Client socket (3) | Max send buffer size during socket life: 212 2026-04-17 22:11:02.148 | Denali Data Feed | Disconnected from the server. 2026-04-17 22:11:02.148 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds. 2026-04-17 22:11:02.152 | CQG WebAPI | Sending Web API Logoff message. 2026-04-17 22:11:02.152 | CQG WebSocket socket (1) | CloseSocket call. 2026-04-17 22:11:02.152 | CQG WebSocket | WebSocket closed. 2026-04-17 22:11:02.152 | CQG WebAPI | WebSocket closed. 2026-04-17 22:11:02.155 | CQG WebAPI | Disconnected. 2026-04-17 22:11:02.156 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-04-17 22:11:02.164 | DTC Client socket (3) | Shutdown started. Waiting for graceful close. 2026-04-17 22:11:02.164 | CQG WebSocket socket (1) | Write in progress. Shutdown being delayed. PendingSize=0 2026-04-17 22:11:04.400 | 2026-04-17 22:11:04.403 | CQG WebAPI | Connecting to server api.cqg.com 2026-04-17 22:11:04.403 | CQG WebSocket | Connecting to WebSocket server api.cqg.com:443 2026-04-17 22:11:04.647 | CQG WebSocket socket (2) | Creating socket. Using TLS 1.2. 2026-04-17 22:11:04.648 | CQG WebSocket socket (2) | New receive buffer size: 0 2026-04-17 22:11:04.648 | CQG WebSocket socket (2) | Connecting to IP: 195.166.124.175. 2026-04-17 22:11:04.768 | CQG WebSocket | Opening WebSocket. 2026-04-17 22:11:04.768 | CQG WebSocket | Sending WebSocket handshake. 2026-04-17 22:11:04.846 | CQG WebSocket | Server header | HTTP/1.1 101 Switching Protocols 2026-04-17 22:11:04.846 | CQG WebSocket | Server header | Connection: Upgrade 2026-04-17 22:11:04.846 | CQG WebSocket | Server header | Sec-WebSocket-Accept: H2+lmoa9811M3rmdggwK+8zB+/Q= 2026-04-17 22:11:04.846 | CQG WebSocket | Server header | Server: WebSocket++/0.8.2 2026-04-17 22:11:04.846 | CQG WebSocket | Server header | Upgrade: websocket 2026-04-17 22:11:04.846 | CQG WebSocket | Server header | 2026-04-17 22:11:04.846 | CQG WebSocket | Web socket state is now open. 2026-04-17 22:11:04.846 | CQG WebAPI | WebSocket connected. 2026-04-17 22:11:04.847 | CQG WebAPI | Sending market data logon message. 2026-04-17 22:11:05.117 | CQG WebAPI | Base Time: 2026-03-28T18:10:39. 2026-03-28 18:10:39 2026-04-17 22:11:05.118 | CQG WebAPI | Logon successful. Session Token = JpGHfDfj3NvtXOj9hgo9JTbvH+/U0KN2va6rSr39+b8NHvMiA5GgOby0gh7q1iRaQ5TffduwvQs 2026-04-17 22:11:05.118 | CQG WebAPI | Connection to server complete. 2026-04-17 22:11:05.118 | DTC Client socket (0) | CloseSocket call. 2026-04-17 22:11:05.118 | Denali Data Feed | Disconnected from the server. 2026-04-17 22:11:05.135 | No download requests in the queue to start downloads for. | Number times message added: 3 2026-04-17 22:11:05.136 | Updated verified funded futures trading account ending date to: 2026-05-18 02:11:05 2026-04-17 22:11:05.175 | CQG WebAPI | Sending Trade Accounts request message. 2026-04-17 22:11:05.188 | Mapping F.US.CLEM26 to CLM26. Service code: nymex 2026-04-17 22:11:05.188 | Using symbol data fast lookup vector 2026-04-17 22:11:05.192 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEM26 (CLM26). ID: 1 Service code: nymex 2026-04-17 22:11:05.194 | Denali Data Feed | Connecting to the server ds32.sierracharts.com. Port 10048 2026-04-17 22:11:05.195 | CQG WebAPI | Sending symbol resolution request for F.US.CLEM26. ID: 431655 2026-04-17 22:11:05.195 | Denali Data Feed | Requesting security definition data for: F.US.CLEM26 (CLM26). ID: 1 2026-04-17 22:11:05.201 | Added historical Intraday data request for F.US.CLEM26 to the queue. 2026-04-17 22:11:05.201 | Intraday data recording state for symbol F.US.CLEM26 is set to download 'Pending'. 2026-04-17 22:11:05.201 | Triggering next historical data download in queue. 2026-04-17 22:11:05.454 | DTC Client socket (4) | Creating socket. 2026-04-17 22:11:05.455 | DTC Client socket (4) | New receive buffer size: 0 2026-04-17 22:11:05.455 | DTC Client socket (4) | Connecting to IP: 69.39.70.248. 2026-04-17 22:11:05.744 | Delaying start of download for F.US.CLEM26. 2026-04-17 22:11:05.746 | CQG WebAPI | Sending positions subscribe request. RequestID: 431656 2026-04-17 22:11:05.749 | CQG WebAPI | Sending orders subscribe request. RequestID: 431657 2026-04-17 22:11:05.753 | CQG WebAPI | Brokerage name: AMP. Account Name: 220033 2026-04-17 22:11:05.753 | Updated verified funded futures trading account ending date to: 2026-05-18 02:11:05 2026-04-17 22:11:05.753 | CQG WebAPI | Sending collateral subscribe request. 2026-04-17 22:11:05.754 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEM26. Search Symbol: F.US.CLEM26. Request ID: 431655. Contract ID: 1. 2026-04-17 22:11:05.755 | Denali Data Feed | Network connection to server complete. 2026-04-17 22:11:05.755 | Denali Data Feed | Starting socket receive thread. 2026-04-17 22:11:05.755 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard 2026-04-17 22:11:05.889 | Mapping F.US.CLEV25 to CLV25. Service code: nymex 2026-04-17 22:11:05.893 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEV25 (CLV25). ID: 2 Service code: nymex 2026-04-17 22:11:05.893 | CQG WebAPI | Sending symbol resolution request for F.US.CLEV25. ID: 431659 2026-04-17 22:11:05.893 | Denali Data Feed | Requesting security definition data for: F.US.CLEV25 (CLV25). ID: 2 2026-04-17 22:11:05.893 | Added historical Intraday data request for F.US.CLEV25 to the queue. 2026-04-17 22:11:05.893 | Intraday data recording state for symbol F.US.CLEV25 is set to download 'Pending'. 2026-04-17 22:11:05.893 | Triggering next historical data download in queue. 2026-04-17 22:11:06.189 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEV25. Search Symbol: F.US.CLEV25. Request ID: 431659. Contract ID: 2. 2026-04-17 22:11:06.205 | Denali Data Feed | Setting DTC encoding to Binary VLS 2026-04-17 22:11:06.206 | Denali Data Feed | Sending logon request message. 2026-04-17 22:11:06.208 | Mapping F.US.EPU25 to ESU25. Service code: cme 2026-04-17 22:11:06.212 | Denali Data Feed | Starting real-time market data updates for: F.US.EPU25 (ESU25). ID: 3 Service code: cme 2026-04-17 22:11:06.212 | CQG WebAPI | Sending symbol resolution request for F.US.EPU25. ID: 431660 2026-04-17 22:11:06.212 | Denali Data Feed | Requesting security definition data for: F.US.EPU25 (ESU25). ID: 3 2026-04-17 22:11:06.212 | Added historical Intraday data request for F.US.EPU25 to the queue. 2026-04-17 22:11:06.212 | Intraday data recording state for symbol F.US.EPU25 is set to download 'Pending'. 2026-04-17 22:11:06.212 | Triggering next historical data download in queue. 2026-04-17 22:11:06.329 | CQG WebAPI | Received symbol resolution report for symbol F.US.EPU25. Search Symbol: F.US.EPU25. Request ID: 431660. Contract ID: 3. 2026-04-17 22:11:07.107 | Denali Data Feed | Received logon response. 2026-04-17 22:11:07.107 | Denali Data Feed | Server Name: SC Realtime Server. 2026-04-17 22:11:07.107 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8 2026-04-17 22:11:07.107 | Denali Data Feed | Successfully connected. 2026-04-17 22:11:07.107 | Denali Data Feed | Trading is not supported. 2026-04-17 22:11:07.107 | Denali Data Feed | MarketDepthIsSupported: 1 2026-04-17 22:11:07.108 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEM26 -> CLM26 2026-04-17 22:11:07.108 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEV25 -> CLV25 2026-04-17 22:11:07.108 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.EPU25 -> ESU25 2026-04-17 22:11:07.312 | Denali Data Feed | Setting external service identifier for symbol F.US.CLEM26 to 670557 2026-04-17 22:11:07.312 | Denali Data Feed | Received security definition for symbol F.US.CLEM26 2026-04-17 22:11:07.312 | Denali Data Feed | Real-time data for symbol F.US.CLEV25 is currently unavailable. 2026-04-17 22:11:07.312 | Denali Data Feed | Received security definition for symbol F.US.CLEV25 2026-04-17 22:11:07.312 | Denali Data Feed | Real-time data for symbol F.US.EPU25 is currently unavailable. 2026-04-17 22:11:07.312 | Denali Data Feed | Received security definition for symbol F.US.EPU25 2026-04-17 22:11:10.120 | Requesting market depth updates for: F.US.CLEV25 if supported. NumLevels=100 2026-04-17 22:11:10.318 | Denali Data Feed | Clearing market depth for F.US.CLEV25 2026-04-17 22:11:12.095 | HD Request # 70 | Downloading Intraday chart data for F.US.CLEM26 to the file F.US.CLEM26.scid. Service: nymex 2026-04-17 22:11:12.096 | HD Request # 70 | Download start date-time: 2026-04-17 16:59:59.000000. File last date-time: 2026-04-17 16:59:59.113000 2026-04-17 22:11:12.098 | HD Request # 70 | Using server: ds26.sierracharts.com port 10149 2026-04-17 22:11:12.108 | Socket (5) | Creating socket. 2026-04-17 22:11:12.108 | Socket (5) | New receive buffer size: 0 2026-04-17 22:11:12.108 | Socket (5) | Connecting to IP: 64.152.155.17. 2026-04-17 22:11:12.289 | HD Request # 70 | Setting DTC encoding to Binary VLS 2026-04-17 22:11:12.289 | HD Request # 70 | Sending historical data logon request message. 2026-04-17 22:11:12.409 | HD Request # 70 | Requesting Intraday data. Start date-time: 2026-04-17 16:59:59. Record interval: 0. Symbol: CLM26 2026-04-17 22:11:12.496 | HD Request # 70 | Decompressing data. 2026-04-17 22:11:12.585 | HD Request # 70 | Receiving Intraday data for F.US.CLEM26 starting at 2026-04-17 16:59:59.113000 2026-04-17 22:11:12.586 | Socket (5) | CloseSocket call. 2026-04-17 22:11:12.586 | Socket (5) | Shutdown started. Waiting for graceful close. 2026-04-17 22:11:12.586 | Historical data download thread signaled to stop. 2026-04-17 22:11:12.587 | HD Request # 70 | Received 1 Intraday data record from 2026-04-17 16:59:59.113000 to 2026-04-17 16:59:59.113000 (0.0 seconds. Delay: 5.2 hours) and wrote 0 records for F.US.CLEM26 2026-04-17 22:11:12.587 | HD Request # 70 | Add time&sales data | Remembered last file record date-time: 2026-04-17 20:59:59.113000 2026-04-17 22:11:12.592 | HD Request # 70 | Completion time: 0s. 2026-04-17 22:11:12.592 | HD Request # 70 | Intraday data download complete for F.US.CLEM26. Unique request ID: 70 2026-04-17 22:11:12.592 | Removing historical data download ID 70. 2026-04-17 22:11:12.592 | Real-time Intraday chart data file updates started for F.US.CLEM26 2026-04-17 22:11:12.592 | Intraday chart data file opened for F.US.CLEM26 2026-04-17 22:11:12.592 | HD Request # 70 | Enabling Intraday chart updating for symbol. 2026-04-17 22:11:12.593 | 2026-04-17 22:11:12.593 | Triggering next historical data download in queue. 2026-04-17 22:11:12.593 | HD Request # 71 | Downloading Intraday chart data for F.US.CLEV25 to the file F.US.CLEV25.scid. Service: nymex 2026-04-17 22:11:12.613 | HD Request # 71 | Download start date-time: 2025-09-22 14:29:55.000000. File last date-time: 2025-09-22 14:29:55.618000 2026-04-17 22:11:12.613 | HD Request # 71 | Using server: ds28.sierracharts.com port 10150 2026-04-17 22:11:12.638 | Socket (6) | Creating socket. 2026-04-17 22:11:12.638 | Socket (6) | New receive buffer size: 0 2026-04-17 22:11:12.638 | Socket (6) | Connecting to IP: 67.214.125.5. 2026-04-17 22:11:12.674 | Socket (5) | Socket gracefully closed by remote side. 2026-04-17 22:11:12.674 | Socket (5) | Closed. 2026-04-17 22:11:12.828 | HD Request # 71 | Setting DTC encoding to Binary VLS 2026-04-17 22:11:12.828 | HD Request # 71 | Sending historical data logon request message. 2026-04-17 22:11:12.951 | HD Request # 71 | Requesting Intraday data. Start date-time: 2025-09-22 14:29:55. Record interval: 0. Symbol: CLV25 2026-04-17 22:11:13.044 | HD Request # 71 | Decompressing data. 2026-04-17 22:11:13.137 | HD Request # 71 | Receiving Intraday data for F.US.CLEV25 starting at 2025-09-22 14:29:55.086000 2026-04-17 22:11:13.137 | Socket (6) | CloseSocket call. 2026-04-17 22:11:13.138 | Socket (6) | Shutdown started. Waiting for graceful close. 2026-04-17 22:11:13.138 | Historical data download thread signaled to stop. 2026-04-17 22:11:13.138 | HD Request # 71 | Received 2 Intraday data records from 2025-09-22 14:29:55.086000 to 2025-09-22 14:29:55.618000 (0.5 seconds. Delay: 207.3 days) and wrote 0 records for F.US.CLEV25 2026-04-17 22:11:13.139 | HD Request # 71 | Add time&sales data | Remembered last file record date-time: 2025-09-22 18:29:55.618000 2026-04-17 22:11:13.139 | HD Request # 71 | Completion time: 1s. 2026-04-17 22:11:13.139 | HD Request # 71 | Intraday data download complete for F.US.CLEV25. Unique request ID: 71 2026-04-17 22:11:13.139 | Removing historical data download ID 71. 2026-04-17 22:11:13.139 | Real-time Intraday chart data file updates started for F.US.CLEV25 2026-04-17 22:11:13.139 | Intraday chart data file opened for F.US.CLEV25 2026-04-17 22:11:13.139 | HD Request # 71 | Enabling Intraday chart updating for symbol. 2026-04-17 22:11:13.139 | 2026-04-17 22:11:13.139 | Triggering next historical data download in queue. 2026-04-17 22:11:13.139 | HD Request # 72 | Downloading Intraday chart data for F.US.EPU25 to the file F.US.EPU25.scid. Service: cme 2026-04-17 22:11:13.155 | HD Request # 72 | Download start date-time: 2025-09-19 09:29:58.000000. File last date-time: 2025-09-19 09:29:58.698000 2026-04-17 22:11:13.156 | HD Request # 72 | Using server: ds32.sierracharts.com port 10149 2026-04-17 22:11:13.157 | Socket (5) | Creating socket. 2026-04-17 22:11:13.158 | Socket (5) | New receive buffer size: 0 2026-04-17 22:11:13.158 | Socket (5) | Connecting to IP: 69.39.70.248. 2026-04-17 22:11:13.232 | Socket (6) | Socket gracefully closed by remote side. 2026-04-17 22:11:13.232 | Socket (6) | Closed. 2026-04-17 22:11:13.346 | HD Request # 72 | Setting DTC encoding to Binary VLS 2026-04-17 22:11:13.346 | HD Request # 72 | Sending historical data logon request message. 2026-04-17 22:11:13.474 | HD Request # 72 | Requesting Intraday data. Start date-time: 2025-09-19 09:29:58. Record interval: 0. Symbol: ESU25 2026-04-17 22:11:13.568 | HD Request # 72 | Decompressing data. 2026-04-17 22:11:13.671 | HD Request # 72 | Receiving Intraday data for F.US.EPU25 starting at 2025-09-19 09:29:58.697000 2026-04-17 22:11:13.672 | Socket (5) | CloseSocket call. 2026-04-17 22:11:13.672 | Socket (5) | Shutdown started. Waiting for graceful close. 2026-04-17 22:11:13.673 | Historical data download thread signaled to stop. 2026-04-17 22:11:13.674 | HD Request # 72 | Received 5 Intraday data records from 2025-09-19 09:29:58.697000 to 2025-09-19 09:29:58.698000 (0.0 seconds. Delay: 210.5 days) and wrote 0 records for F.US.EPU25 2026-04-17 22:11:13.675 | HD Request # 72 | Add time&sales data | Remembered last file record date-time: 2025-09-19 13:29:58.698000 2026-04-17 22:11:13.675 | HD Request # 72 | Completion time: 0s. 2026-04-17 22:11:13.675 | HD Request # 72 | Intraday data download complete for F.US.EPU25. Unique request ID: 72 2026-04-17 22:11:13.675 | Removing historical data download ID 72. 2026-04-17 22:11:13.675 | Real-time Intraday chart data file updates started for F.US.EPU25 2026-04-17 22:11:13.675 | Intraday chart data file opened for F.US.EPU25 2026-04-17 22:11:13.675 | HD Request # 72 | Enabling Intraday chart updating for symbol. 2026-04-17 22:11:13.675 | 2026-04-17 22:11:13.675 | No download requests in the queue to start downloads for. 2026-04-17 22:11:13.779 | Socket (5) | Socket gracefully closed by remote side. 2026-04-17 22:11:13.781 | Socket (5) | Closed. 2026-04-17 22:11:21.128 | DTC Client socket (3) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. * 2026-04-17 22:11:21.128 | DTC Client socket (3) | Socket gracefully closed by remote side. 2026-04-17 22:11:21.128 | DTC Client socket (3) | Closed. 2026-04-17 22:11:25.747 | ExtendTheFundedTradingAccountStatusExpirationDate: Sending request. 2026-04-17 22:11:26.203 | ExtendTheFundedTradingAccountStatusExpirationDate | Result: {"Result":"Funded Trading Account Status Expiration Date Extended"}. Success=true 2026-04-18 22:27:36.068 | The data feed was lost. There was no activity for at least 60.0 seconds. 2026-04-18 22:27:36.069 | Connection to the external service has been lost. 2026-04-18 22:27:36.197 | CQG WebSocket socket (1) | Write has completed. Shutdown being performed. 2026-04-18 22:27:36.197 | CQG WebSocket socket (1) | Shutdown started. Waiting for graceful close. 2026-04-18 22:27:36.197 | CQG WebSocket socket (1) | Socket gracefully closed by remote side. 2026-04-18 22:27:36.197 | CQG WebSocket socket (1) | Closed. 2026-04-18 22:27:36.201 | DTC Client socket (4) | Socket gracefully closed by remote side. 2026-04-18 22:27:36.286 | CQG WebSocket | Timeout waiting for pong message from server. 2026-04-18 22:27:36.286 | CQG WebAPI | WebSocket closed. 2026-04-18 22:27:36.287 | Denali Data Feed | There has been no activity on the network socket for 1d 16m 7s. Will reconnect. 2026-04-18 22:27:36.287 | Denali Data Feed | Waiting for socket receive thread to end 2026-04-18 22:27:36.288 | DTC Client socket (4) | CloseSocket call. 2026-04-18 22:27:36.288 | Denali Data Feed | Disconnected from the server. 2026-04-18 22:27:36.288 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds. 2026-04-18 22:27:36.289 | CQG WebAPI | Sending Web API Logoff message. 2026-04-18 22:27:36.289 | CQG WebSocket socket (2) | CloseSocket call. 2026-04-18 22:27:36.289 | CQG WebSocket | WebSocket closed. 2026-04-18 22:27:36.289 | CQG WebAPI | WebSocket closed. 2026-04-18 22:27:36.291 | CQG WebAPI | Disconnected. 2026-04-18 22:27:36.291 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-04-18 22:27:36.358 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2026-04-18 22:27:36.358 | DTC Client socket (4) | Closed. 2026-04-18 22:27:36.358 | CQG WebSocket socket (2) | Write in progress. Shutdown being delayed. PendingSize=0 2026-04-18 22:27:36.361 | DTC Client socket (4) | Socket gracefully closed by remote side. 2026-04-18 22:27:38.298 | 2026-04-18 22:27:38.299 | CQG WebAPI | Connecting to server api.cqg.com 2026-04-18 22:27:38.299 | CQG WebSocket | Connecting to WebSocket server api.cqg.com:443 2026-04-18 22:27:38.642 | CQG WebSocket socket (1) | Creating socket. Using TLS 1.2. 2026-04-18 22:27:38.644 | CQG WebSocket socket (1) | New receive buffer size: 0 2026-04-18 22:27:38.644 | CQG WebSocket socket (1) | Connecting to IP: 195.166.124.175. 2026-04-18 22:27:38.651 | CQG WebSocket | Opening WebSocket. 2026-04-18 22:27:38.651 | CQG WebSocket | Sending WebSocket handshake. 2026-04-18 22:27:38.676 | CQG WebSocket | Server header | HTTP/1.1 101 Switching Protocols 2026-04-18 22:27:38.676 | CQG WebSocket | Server header | Connection: Upgrade 2026-04-18 22:27:38.676 | CQG WebSocket | Server header | Sec-WebSocket-Accept: bPIKmdsrwgBX1C8vPPCXoGnx/p4= 2026-04-18 22:27:38.677 | CQG WebSocket | Server header | Server: WebSocket++/0.8.2 2026-04-18 22:27:38.677 | CQG WebSocket | Server header | Upgrade: websocket 2026-04-18 22:27:38.677 | CQG WebSocket | Server header | 2026-04-18 22:27:38.677 | CQG WebSocket | Web socket state is now open. 2026-04-18 22:27:38.677 | CQG WebAPI | WebSocket connected. 2026-04-18 22:27:38.677 | CQG WebAPI | Sending market data logon message. 2026-04-18 22:27:38.927 | CQG WebAPI | Base Time: 2026-04-12T15:43:05. 2026-04-12 15:43:05 2026-04-18 22:27:38.927 | CQG WebAPI | Logon successful. Session Token = PB1u0SxG3mWnjwSbkEVC0ChUTYmR2SiZZfg2O/I8yvwnxifQFV2E9WkQnOzy0BRvVbnG+IS501E 2026-04-18 22:27:38.927 | CQG WebAPI | Connection to server complete. 2026-04-18 22:27:38.927 | DTC Client socket (0) | CloseSocket call. 2026-04-18 22:27:38.927 | Denali Data Feed | Disconnected from the server. 2026-04-18 22:27:38.931 | No download requests in the queue to start downloads for. | Number times message added: 3 2026-04-18 22:27:38.931 | Updated verified funded futures trading account ending date to: 2026-05-19 02:27:38 2026-04-18 22:27:38.955 | CQG WebAPI | Sending Trade Accounts request message. 2026-04-18 22:27:39.067 | CQG WebAPI | Brokerage name: AMP. Account Name: 220033 2026-04-18 22:27:39.067 | Updated verified funded futures trading account ending date to: 2026-05-19 02:27:39 2026-04-18 22:27:39.067 | CQG WebAPI | Sending collateral subscribe request. 2026-04-18 22:27:39.092 | Mapping F.US.CLEV25 to CLV25. Service code: nymex 2026-04-18 22:27:39.092 | Using symbol data fast lookup vector 2026-04-18 22:27:39.092 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEV25 (CLV25). ID: 1 Service code: nymex 2026-04-18 22:27:39.093 | Denali Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 10048 2026-04-18 22:27:39.093 | CQG WebAPI | Sending symbol resolution request for F.US.CLEV25. ID: 431663 2026-04-18 22:27:39.093 | Denali Data Feed | Requesting security definition data for: F.US.CLEV25 (CLV25). ID: 1 2026-04-18 22:27:39.094 | Added historical Intraday data request for F.US.CLEV25 to the queue. 2026-04-18 22:27:39.094 | Intraday data recording state for symbol F.US.CLEV25 is set to download 'Pending'. 2026-04-18 22:27:39.094 | Triggering next historical data download in queue. 2026-04-18 22:27:39.094 | Delaying start of download for F.US.CLEV25. 2026-04-18 22:27:39.095 | Mapping F.US.EPU25 to ESU25. Service code: cme 2026-04-18 22:27:39.095 | Denali Data Feed | Starting real-time market data updates for: F.US.EPU25 (ESU25). ID: 2 Service code: cme 2026-04-18 22:27:39.095 | CQG WebAPI | Sending symbol resolution request for F.US.EPU25. ID: 431664 2026-04-18 22:27:39.095 | Denali Data Feed | Requesting security definition data for: F.US.EPU25 (ESU25). ID: 2 2026-04-18 22:27:39.096 | Added historical Intraday data request for F.US.EPU25 to the queue. 2026-04-18 22:27:39.096 | Intraday data recording state for symbol F.US.EPU25 is set to download 'Pending'. 2026-04-18 22:27:39.096 | Triggering next historical data download in queue. 2026-04-18 22:27:39.113 | Mapping F.US.CLEM26 to CLM26. Service code: nymex 2026-04-18 22:27:39.113 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEM26 (CLM26). ID: 3 Service code: nymex 2026-04-18 22:27:39.114 | CQG WebAPI | Sending symbol resolution request for F.US.CLEM26. ID: 431665 2026-04-18 22:27:39.114 | Denali Data Feed | Requesting security definition data for: F.US.CLEM26 (CLM26). ID: 3 2026-04-18 22:27:39.114 | Added historical Intraday data request for F.US.CLEM26 to the queue. 2026-04-18 22:27:39.114 | Intraday data recording state for symbol F.US.CLEM26 is set to download 'Pending'. 2026-04-18 22:27:39.114 | Triggering next historical data download in queue. 2026-04-18 22:27:39.206 | DTC Client socket (3) | Creating socket. 2026-04-18 22:27:39.206 | DTC Client socket (3) | New receive buffer size: 0 2026-04-18 22:27:39.206 | DTC Client socket (3) | Connecting to IP: 67.214.125.6. 2026-04-18 22:27:39.246 | CQG WebAPI | Sending positions subscribe request. RequestID: 431666 2026-04-18 22:27:39.246 | CQG WebAPI | Sending orders subscribe request. RequestID: 431667 2026-04-18 22:27:39.246 | CQG WebAPI | Received symbol resolution report for symbol F.US.EPU25. Search Symbol: F.US.EPU25. Request ID: 431664. Contract ID: 1. 2026-04-18 22:27:39.247 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEV25. Search Symbol: F.US.CLEV25. Request ID: 431663. Contract ID: 2. 2026-04-18 22:27:39.247 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEM26. Search Symbol: F.US.CLEM26. Request ID: 431665. Contract ID: 3. 2026-04-18 22:27:39.308 | Denali Data Feed | Network connection to server complete. 2026-04-18 22:27:39.308 | Denali Data Feed | Starting socket receive thread. 2026-04-18 22:27:39.308 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard 2026-04-18 22:27:39.412 | Denali Data Feed | Setting DTC encoding to Binary VLS 2026-04-18 22:27:39.412 | Denali Data Feed | Sending logon request message. 2026-04-18 22:27:39.938 | Denali Data Feed | Received logon response. 2026-04-18 22:27:39.938 | Denali Data Feed | Server Name: SC Realtime Server. 2026-04-18 22:27:39.938 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8 2026-04-18 22:27:39.938 | Denali Data Feed | Successfully connected. 2026-04-18 22:27:39.938 | Denali Data Feed | Trading is not supported. 2026-04-18 22:27:39.938 | Denali Data Feed | MarketDepthIsSupported: 1 2026-04-18 22:27:39.938 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEM26 -> CLM26 2026-04-18 22:27:39.938 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEV25 -> CLV25 2026-04-18 22:27:39.938 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.EPU25 -> ESU25 2026-04-18 22:27:40.136 | Denali Data Feed | Setting external service identifier for symbol F.US.CLEM26 to 670557 2026-04-18 22:27:40.136 | Denali Data Feed | Received security definition for symbol F.US.CLEM26 2026-04-18 22:27:40.136 | Denali Data Feed | Real-time data for symbol F.US.CLEV25 is currently unavailable. 2026-04-18 22:27:40.136 | Denali Data Feed | Received security definition for symbol F.US.CLEV25 2026-04-18 22:27:40.136 | Denali Data Feed | Real-time data for symbol F.US.EPU25 is currently unavailable. 2026-04-18 22:27:40.136 | Denali Data Feed | Received security definition for symbol F.US.EPU25 2026-04-18 22:27:43.943 | Requesting market depth updates for: F.US.CLEV25 if supported. NumLevels=100 2026-04-18 22:27:44.125 | Denali Data Feed | Clearing market depth for F.US.CLEV25 2026-04-18 22:27:45.064 | HD Request # 73 | Downloading Intraday chart data for F.US.CLEV25 to the file F.US.CLEV25.scid. Service: nymex 2026-04-18 22:27:45.077 | HD Request # 73 | Download start date-time: 2025-09-22 14:29:55.000000. File last date-time: 2025-09-22 14:29:55.618000 2026-04-18 22:27:45.078 | HD Request # 73 | Using server: ds26.sierracharts.com port 10150 2026-04-18 22:27:45.088 | Socket (4) | Creating socket. 2026-04-18 22:27:45.088 | Socket (4) | New receive buffer size: 0 2026-04-18 22:27:45.088 | Socket (4) | Connecting to IP: 64.152.155.17. 2026-04-18 22:27:45.267 | HD Request # 73 | Setting DTC encoding to Binary VLS 2026-04-18 22:27:45.267 | HD Request # 73 | Sending historical data logon request message. 2026-04-18 22:27:45.383 | HD Request # 73 | Requesting Intraday data. Start date-time: 2025-09-22 14:29:55. Record interval: 0. Symbol: CLV25 2026-04-18 22:27:45.472 | HD Request # 73 | Decompressing data. 2026-04-18 22:27:45.561 | HD Request # 73 | Receiving Intraday data for F.US.CLEV25 starting at 2025-09-22 14:29:55.086000 2026-04-18 22:27:45.561 | Socket (4) | CloseSocket call. 2026-04-18 22:27:45.561 | Socket (4) | Shutdown started. Waiting for graceful close. 2026-04-18 22:27:45.562 | Historical data download thread signaled to stop. 2026-04-18 22:27:45.562 | HD Request # 73 | Received 2 Intraday data records from 2025-09-22 14:29:55.086000 to 2025-09-22 14:29:55.618000 (0.5 seconds. Delay: 208.3 days) and wrote 0 records for F.US.CLEV25 2026-04-18 22:27:45.563 | HD Request # 73 | Add time&sales data | Remembered last file record date-time: 2025-09-22 18:29:55.618000 2026-04-18 22:27:45.563 | HD Request # 73 | Completion time: 0s. 2026-04-18 22:27:45.563 | HD Request # 73 | Intraday data download complete for F.US.CLEV25. Unique request ID: 73 2026-04-18 22:27:45.563 | Removing historical data download ID 73. 2026-04-18 22:27:45.563 | Real-time Intraday chart data file updates started for F.US.CLEV25 2026-04-18 22:27:45.563 | Intraday chart data file opened for F.US.CLEV25 2026-04-18 22:27:45.563 | HD Request # 73 | Enabling Intraday chart updating for symbol. 2026-04-18 22:27:45.563 | 2026-04-18 22:27:45.563 | Triggering next historical data download in queue. 2026-04-18 22:27:45.564 | HD Request # 74 | Downloading Intraday chart data for F.US.EPU25 to the file F.US.EPU25.scid. Service: cme 2026-04-18 22:27:45.575 | HD Request # 74 | Download start date-time: 2025-09-19 09:29:58.000000. File last date-time: 2025-09-19 09:29:58.698000 2026-04-18 22:27:45.575 | HD Request # 74 | Using server: ds28.sierracharts.com port 10149 2026-04-18 22:27:45.585 | Socket (5) | Creating socket. 2026-04-18 22:27:45.585 | Socket (5) | New receive buffer size: 0 2026-04-18 22:27:45.586 | Socket (5) | Connecting to IP: 67.214.125.5. 2026-04-18 22:27:45.650 | Socket (4) | Socket gracefully closed by remote side. 2026-04-18 22:27:45.650 | Socket (4) | Closed. 2026-04-18 22:27:45.772 | HD Request # 74 | Setting DTC encoding to Binary VLS 2026-04-18 22:27:45.772 | HD Request # 74 | Sending historical data logon request message. 2026-04-18 22:27:45.897 | HD Request # 74 | Requesting Intraday data. Start date-time: 2025-09-19 09:29:58. Record interval: 0. Symbol: ESU25 2026-04-18 22:27:45.990 | HD Request # 74 | Decompressing data. 2026-04-18 22:27:46.082 | HD Request # 74 | Receiving Intraday data for F.US.EPU25 starting at 2025-09-19 09:29:58.697000 2026-04-18 22:27:46.082 | Socket (5) | CloseSocket call. 2026-04-18 22:27:46.083 | Socket (5) | Shutdown started. Waiting for graceful close. 2026-04-18 22:27:46.083 | Historical data download thread signaled to stop. 2026-04-18 22:27:46.083 | HD Request # 74 | Received 5 Intraday data records from 2025-09-19 09:29:58.697000 to 2025-09-19 09:29:58.698000 (0.0 seconds. Delay: 211.5 days) and wrote 0 records for F.US.EPU25 2026-04-18 22:27:46.084 | HD Request # 74 | Add time&sales data | Remembered last file record date-time: 2025-09-19 13:29:58.698000 2026-04-18 22:27:46.084 | HD Request # 74 | Completion time: 1s. 2026-04-18 22:27:46.084 | HD Request # 74 | Intraday data download complete for F.US.EPU25. Unique request ID: 74 2026-04-18 22:27:46.084 | Removing historical data download ID 74. 2026-04-18 22:27:46.084 | Real-time Intraday chart data file updates started for F.US.EPU25 2026-04-18 22:27:46.084 | Intraday chart data file opened for F.US.EPU25 2026-04-18 22:27:46.084 | HD Request # 74 | Enabling Intraday chart updating for symbol. 2026-04-18 22:27:46.084 | 2026-04-18 22:27:46.084 | Triggering next historical data download in queue. 2026-04-18 22:27:46.084 | HD Request # 75 | Downloading Intraday chart data for F.US.CLEM26 to the file F.US.CLEM26.scid. Service: nymex 2026-04-18 22:27:46.098 | HD Request # 75 | Download start date-time: 2026-04-17 16:59:59.000000. File last date-time: 2026-04-17 16:59:59.113000 2026-04-18 22:27:46.098 | HD Request # 75 | Using server: ds32.sierracharts.com port 10150 2026-04-18 22:27:46.110 | Socket (4) | Creating socket. 2026-04-18 22:27:46.110 | Socket (4) | New receive buffer size: 0 2026-04-18 22:27:46.110 | Socket (4) | Connecting to IP: 69.39.70.248. 2026-04-18 22:27:46.176 | Socket (5) | Socket gracefully closed by remote side. 2026-04-18 22:27:46.176 | Socket (5) | Closed. 2026-04-18 22:27:46.301 | HD Request # 75 | Setting DTC encoding to Binary VLS 2026-04-18 22:27:46.301 | HD Request # 75 | Sending historical data logon request message. 2026-04-18 22:27:46.424 | HD Request # 75 | Requesting Intraday data. Start date-time: 2026-04-17 16:59:59. Record interval: 0. Symbol: CLM26 2026-04-18 22:27:46.516 | HD Request # 75 | Decompressing data. 2026-04-18 22:27:46.608 | HD Request # 75 | Receiving Intraday data for F.US.CLEM26 starting at 2026-04-17 16:59:59.113000 2026-04-18 22:27:46.608 | Socket (4) | CloseSocket call. 2026-04-18 22:27:46.608 | Socket (4) | Shutdown started. Waiting for graceful close. 2026-04-18 22:27:46.609 | Historical data download thread signaled to stop. 2026-04-18 22:27:46.609 | HD Request # 75 | Received 1 Intraday data record from 2026-04-17 16:59:59.113000 to 2026-04-17 16:59:59.113000 (0.0 seconds. Delay: 29.5 hours) and wrote 0 records for F.US.CLEM26 2026-04-18 22:27:46.610 | HD Request # 75 | Add time&sales data | Remembered last file record date-time: 2026-04-17 20:59:59.113000 2026-04-18 22:27:46.610 | HD Request # 75 | Completion time: 0s. 2026-04-18 22:27:46.610 | HD Request # 75 | Intraday data download complete for F.US.CLEM26. Unique request ID: 75 2026-04-18 22:27:46.610 | Removing historical data download ID 75. 2026-04-18 22:27:46.610 | Real-time Intraday chart data file updates started for F.US.CLEM26 2026-04-18 22:27:46.610 | Intraday chart data file opened for F.US.CLEM26 2026-04-18 22:27:46.610 | HD Request # 75 | Enabling Intraday chart updating for symbol. 2026-04-18 22:27:46.610 | 2026-04-18 22:27:46.610 | No download requests in the queue to start downloads for. 2026-04-18 22:27:46.724 | Socket (4) | Socket gracefully closed by remote side. 2026-04-18 22:27:46.724 | Socket (4) | Closed. 2026-04-19 13:49:17.600 | The data feed was lost. There was no activity for at least 60.0 seconds. 2026-04-19 13:49:17.600 | Connection to the external service has been lost. 2026-04-19 13:49:17.686 | CQG WebSocket socket (2) | Write has completed. Shutdown being performed. 2026-04-19 13:49:17.686 | CQG WebSocket socket (2) | Shutdown started. Waiting for graceful close. 2026-04-19 13:49:17.686 | CQG WebSocket socket (2) | Socket gracefully closed by remote side. 2026-04-19 13:49:17.686 | CQG WebSocket socket (2) | Closed. 2026-04-19 13:49:17.705 | DTC Client socket (3) | Socket gracefully closed by remote side. | Number times message added: 1 2026-04-19 13:49:17.802 | CQG WebSocket | Timeout waiting for pong message from server. 2026-04-19 13:49:17.802 | CQG WebAPI | WebSocket closed. 2026-04-19 13:49:17.804 | ExtendTheFundedTradingAccountStatusExpirationDate: Sending request. 2026-04-19 13:49:17.814 | CQG WebAPI | Sending Web API Logoff message. 2026-04-19 13:49:17.814 | CQG WebSocket socket (1) | CloseSocket call. 2026-04-19 13:49:17.814 | CQG WebSocket socket (1) | Max send buffers used during socket life: 3 2026-04-19 13:49:17.814 | CQG WebSocket socket (1) | Max send buffer size during socket life: 309 2026-04-19 13:49:17.814 | CQG WebSocket | WebSocket closed. 2026-04-19 13:49:17.814 | CQG WebAPI | WebSocket closed. 2026-04-19 13:49:17.816 | CQG WebAPI | Disconnected. 2026-04-19 13:49:17.817 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-04-19 13:49:17.818 | DTC Client socket (3) | CloseSocket call. 2026-04-19 13:49:17.818 | DTC Client socket (3) | Signaling for receive thread to end. Bytes in receive buffer: 0 2026-04-19 13:49:17.818 | DTC Client socket (3) | Max send buffers used during socket life: 3 2026-04-19 13:49:17.818 | DTC Client socket (3) | Max send buffer size during socket life: 212 2026-04-19 13:49:17.819 | Denali Data Feed | Server has requested a logoff. Reason: No heartbeat messages received for 60.6 seconds. Stopping connection. 2026-04-19 13:49:17.819 | DTC Client socket (0) | CloseSocket call. 2026-04-19 13:49:17.819 | Denali Data Feed | Disconnected from the server. 2026-04-19 13:49:17.819 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds. 2026-04-19 13:49:17.850 | CQG WebSocket socket (1) | Write in progress. Shutdown being delayed. PendingSize=0 2026-04-19 13:49:17.851 | DTC Client socket (3) | Write in progress. Shutdown being delayed. PendingSize=0 2026-04-19 13:49:17.851 | DTC Client socket (3) | Socket gracefully closed by remote side. 2026-04-19 13:49:18.171 | DTC Client socket (3) | Write has completed. Shutdown being performed. 2026-04-19 13:49:18.171 | DTC Client socket (3) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2026-04-19 13:49:18.171 | DTC Client socket (3) | Closed. 2026-04-19 13:49:18.948 | ExtendTheFundedTradingAccountStatusExpirationDate | Result: {"Result":"The Funded Trading Account Status Expiration Date is more than 25 days into the future. The Date is currently: 2026-05-18"}. Success=true 2026-04-19 13:49:19.806 | 2026-04-19 13:49:19.807 | CQG WebAPI | Connecting to server api.cqg.com 2026-04-19 13:49:19.807 | CQG WebSocket | Connecting to WebSocket server api.cqg.com:443 2026-04-19 13:49:20.115 | CQG WebSocket socket (2) | Creating socket. Using TLS 1.2. 2026-04-19 13:49:20.115 | CQG WebSocket socket (2) | New receive buffer size: 0 2026-04-19 13:49:20.115 | CQG WebSocket socket (2) | Connecting to IP: 195.166.124.175. 2026-04-19 13:49:20.126 | CQG WebSocket | Opening WebSocket. 2026-04-19 13:49:20.126 | CQG WebSocket | Sending WebSocket handshake. 2026-04-19 13:49:20.150 | CQG WebSocket | Server header | HTTP/1.1 101 Switching Protocols 2026-04-19 13:49:20.150 | CQG WebSocket | Server header | Connection: Upgrade 2026-04-19 13:49:20.150 | CQG WebSocket | Server header | Sec-WebSocket-Accept: mqgOfnHkaI5UMtJHtSe1ZmVhwhg= 2026-04-19 13:49:20.150 | CQG WebSocket | Server header | Server: WebSocket++/0.8.2 2026-04-19 13:49:20.150 | CQG WebSocket | Server header | Upgrade: websocket 2026-04-19 13:49:20.150 | CQG WebSocket | Server header | 2026-04-19 13:49:20.150 | CQG WebSocket | Web socket state is now open. 2026-04-19 13:49:20.150 | CQG WebAPI | WebSocket connected. 2026-04-19 13:49:20.151 | CQG WebAPI | Sending market data logon message. 2026-04-19 13:49:20.399 | CQG WebAPI | Base Time: 2026-03-28T18:10:39. 2026-03-28 18:10:39 2026-04-19 13:49:20.399 | CQG WebAPI | Logon successful. Session Token = 7eaVaoydJ+5ME74ehg6zOGN4LBOjI4b75wMAO8uzRYk4KU8DtyKQ1w22UC4/E8HjFrEVKefSJDl 2026-04-19 13:49:20.399 | CQG WebAPI | Connection to server complete. 2026-04-19 13:49:20.400 | DTC Client socket (0) | CloseSocket call. 2026-04-19 13:49:20.400 | Denali Data Feed | Disconnected from the server. 2026-04-19 13:49:20.405 | No download requests in the queue to start downloads for. | Number times message added: 3 2026-04-19 13:49:20.405 | Updated verified funded futures trading account ending date to: 2026-05-19 17:49:20 2026-04-19 13:49:20.429 | CQG WebAPI | Sending Trade Accounts request message. 2026-04-19 13:49:20.528 | CQG WebAPI | Brokerage name: AMP. Account Name: 220033 2026-04-19 13:49:20.528 | Updated verified funded futures trading account ending date to: 2026-05-19 17:49:20 2026-04-19 13:49:20.528 | CQG WebAPI | Sending collateral subscribe request. 2026-04-19 13:49:20.658 | CQG WebAPI | Sending positions subscribe request. RequestID: 431670 2026-04-19 13:49:20.659 | CQG WebAPI | Sending orders subscribe request. RequestID: 431671 2026-04-19 13:49:20.737 | Mapping F.US.CLEV25 to CLV25. Service code: nymex 2026-04-19 13:49:20.737 | Using symbol data fast lookup vector 2026-04-19 13:49:20.738 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEV25 (CLV25). ID: 1 Service code: nymex 2026-04-19 13:49:20.740 | Denali Data Feed | Connecting to the server ds26.sierracharts.com. Port 443 2026-04-19 13:49:20.740 | CQG WebAPI | Sending symbol resolution request for F.US.CLEV25. ID: 431672 2026-04-19 13:49:20.740 | Denali Data Feed | Requesting security definition data for: F.US.CLEV25 (CLV25). ID: 1 2026-04-19 13:49:20.741 | Added historical Intraday data request for F.US.CLEV25 to the queue. 2026-04-19 13:49:20.741 | Intraday data recording state for symbol F.US.CLEV25 is set to download 'Pending'. 2026-04-19 13:49:20.741 | Triggering next historical data download in queue. 2026-04-19 13:49:20.749 | Delaying start of download for F.US.CLEV25. 2026-04-19 13:49:20.752 | Mapping F.US.EPU25 to ESU25. Service code: cme 2026-04-19 13:49:20.752 | Denali Data Feed | Starting real-time market data updates for: F.US.EPU25 (ESU25). ID: 2 Service code: cme 2026-04-19 13:49:20.753 | CQG WebAPI | Sending symbol resolution request for F.US.EPU25. ID: 431673 2026-04-19 13:49:20.753 | Denali Data Feed | Requesting security definition data for: F.US.EPU25 (ESU25). ID: 2 2026-04-19 13:49:20.753 | Added historical Intraday data request for F.US.EPU25 to the queue. 2026-04-19 13:49:20.753 | Intraday data recording state for symbol F.US.EPU25 is set to download 'Pending'. 2026-04-19 13:49:20.753 | Triggering next historical data download in queue. 2026-04-19 13:49:20.771 | Mapping F.US.CLEM26 to CLM26. Service code: nymex 2026-04-19 13:49:20.771 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEM26 (CLM26). ID: 3 Service code: nymex 2026-04-19 13:49:20.771 | CQG WebAPI | Sending symbol resolution request for F.US.CLEM26. ID: 431674 2026-04-19 13:49:20.771 | Denali Data Feed | Requesting security definition data for: F.US.CLEM26 (CLM26). ID: 3 2026-04-19 13:49:20.771 | Added historical Intraday data request for F.US.CLEM26 to the queue. 2026-04-19 13:49:20.771 | Intraday data recording state for symbol F.US.CLEM26 is set to download 'Pending'. 2026-04-19 13:49:20.771 | Triggering next historical data download in queue. 2026-04-19 13:49:20.799 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEM26. Search Symbol: F.US.CLEM26. Request ID: 431674. Contract ID: 1. 2026-04-19 13:49:20.856 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEV25. Search Symbol: F.US.CLEV25. Request ID: 431672. Contract ID: 2. 2026-04-19 13:49:20.856 | CQG WebAPI | Received symbol resolution report for symbol F.US.EPU25. Search Symbol: F.US.EPU25. Request ID: 431673. Contract ID: 3. 2026-04-19 13:49:20.956 | DTC Client socket (3) | Creating socket. 2026-04-19 13:49:20.956 | DTC Client socket (3) | New receive buffer size: 0 2026-04-19 13:49:20.956 | DTC Client socket (3) | Connecting to IP: 64.152.155.17. 2026-04-19 13:49:21.046 | Denali Data Feed | Network connection to server complete. 2026-04-19 13:49:21.046 | Denali Data Feed | Starting socket receive thread. 2026-04-19 13:49:21.046 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard 2026-04-19 13:49:21.140 | Denali Data Feed | Setting DTC encoding to Binary VLS 2026-04-19 13:49:21.141 | Denali Data Feed | Sending logon request message. 2026-04-19 13:49:21.705 | Denali Data Feed | Received logon response. 2026-04-19 13:49:21.705 | Denali Data Feed | Server Name: SC Realtime Server. 2026-04-19 13:49:21.705 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8 2026-04-19 13:49:21.705 | Denali Data Feed | Successfully connected. 2026-04-19 13:49:21.705 | Denali Data Feed | Trading is not supported. 2026-04-19 13:49:21.705 | Denali Data Feed | MarketDepthIsSupported: 1 2026-04-19 13:49:21.705 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEM26 -> CLM26 2026-04-19 13:49:21.705 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEV25 -> CLV25 2026-04-19 13:49:21.705 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.EPU25 -> ESU25 2026-04-19 13:49:21.897 | Denali Data Feed | Setting external service identifier for symbol F.US.CLEM26 to 670557 2026-04-19 13:49:21.897 | Denali Data Feed | Received security definition for symbol F.US.CLEM26 2026-04-19 13:49:21.897 | Denali Data Feed | Real-time data for symbol F.US.CLEV25 is currently unavailable. 2026-04-19 13:49:21.897 | Denali Data Feed | Received security definition for symbol F.US.CLEV25 2026-04-19 13:49:21.897 | Denali Data Feed | Real-time data for symbol F.US.EPU25 is currently unavailable. 2026-04-19 13:49:21.897 | Denali Data Feed | Received security definition for symbol F.US.EPU25 2026-04-19 13:49:25.412 | Requesting market depth updates for: F.US.CLEV25 if supported. NumLevels=100 2026-04-19 13:49:25.618 | Denali Data Feed | Clearing market depth for F.US.CLEV25 2026-04-19 13:49:26.595 | HD Request # 76 | Downloading Intraday chart data for F.US.CLEV25 to the file F.US.CLEV25.scid. Service: nymex 2026-04-19 13:49:26.611 | HD Request # 76 | Download start date-time: 2025-09-22 14:29:55.000000. File last date-time: 2025-09-22 14:29:55.618000 2026-04-19 13:49:26.611 | HD Request # 76 | Using server: ds26.sierracharts.com port 10149 2026-04-19 13:49:26.613 | Socket (4) | Creating socket. 2026-04-19 13:49:26.613 | Socket (4) | New receive buffer size: 0 2026-04-19 13:49:26.613 | Socket (4) | Connecting to IP: 64.152.155.17. 2026-04-19 13:49:26.801 | HD Request # 76 | Setting DTC encoding to Binary VLS 2026-04-19 13:49:26.801 | HD Request # 76 | Sending historical data logon request message. 2026-04-19 13:49:26.925 | HD Request # 76 | Requesting Intraday data. Start date-time: 2025-09-22 14:29:55. Record interval: 0. Symbol: CLV25 2026-04-19 13:49:27.019 | HD Request # 76 | Decompressing data. 2026-04-19 13:49:27.107 | HD Request # 76 | Receiving Intraday data for F.US.CLEV25 starting at 2025-09-22 14:29:55.086000 2026-04-19 13:49:27.107 | Socket (4) | CloseSocket call. 2026-04-19 13:49:27.107 | Socket (4) | Shutdown started. Waiting for graceful close. 2026-04-19 13:49:27.108 | Historical data download thread signaled to stop. 2026-04-19 13:49:27.108 | HD Request # 76 | Received 2 Intraday data records from 2025-09-22 14:29:55.086000 to 2025-09-22 14:29:55.618000 (0.5 seconds. Delay: 209.0 days) and wrote 0 records for F.US.CLEV25 2026-04-19 13:49:27.109 | HD Request # 76 | Add time&sales data | Remembered last file record date-time: 2025-09-22 18:29:55.618000 2026-04-19 13:49:27.109 | HD Request # 76 | Completion time: 1s. 2026-04-19 13:49:27.109 | HD Request # 76 | Intraday data download complete for F.US.CLEV25. Unique request ID: 76 2026-04-19 13:49:27.109 | Removing historical data download ID 76. 2026-04-19 13:49:27.109 | Real-time Intraday chart data file updates started for F.US.CLEV25 2026-04-19 13:49:27.109 | Intraday chart data file opened for F.US.CLEV25 2026-04-19 13:49:27.109 | HD Request # 76 | Enabling Intraday chart updating for symbol. 2026-04-19 13:49:27.109 | 2026-04-19 13:49:27.109 | Triggering next historical data download in queue. 2026-04-19 13:49:27.109 | HD Request # 77 | Downloading Intraday chart data for F.US.EPU25 to the file F.US.EPU25.scid. Service: cme 2026-04-19 13:49:27.126 | HD Request # 77 | Download start date-time: 2025-09-19 09:29:58.000000. File last date-time: 2025-09-19 09:29:58.698000 2026-04-19 13:49:27.126 | HD Request # 77 | Using server: ds28.sierracharts.com port 10150 2026-04-19 13:49:27.137 | Socket (5) | Creating socket. 2026-04-19 13:49:27.137 | Socket (5) | New receive buffer size: 0 2026-04-19 13:49:27.137 | Socket (5) | Connecting to IP: 67.214.125.5. 2026-04-19 13:49:27.216 | Socket (4) | Socket gracefully closed by remote side. 2026-04-19 13:49:27.216 | Socket (4) | Closed. 2026-04-19 13:49:30.340 | HD Request # 77 | Setting DTC encoding to Binary VLS 2026-04-19 13:49:30.340 | HD Request # 77 | Sending historical data logon request message. 2026-04-19 13:49:30.475 | HD Request # 77 | Requesting Intraday data. Start date-time: 2025-09-19 09:29:58. Record interval: 0. Symbol: ESU25 2026-04-19 13:49:30.568 | HD Request # 77 | Decompressing data. 2026-04-19 13:49:30.662 | HD Request # 77 | Receiving Intraday data for F.US.EPU25 starting at 2025-09-19 09:29:58.697000 2026-04-19 13:49:30.662 | Socket (5) | CloseSocket call. 2026-04-19 13:49:30.662 | Socket (5) | Shutdown started. Waiting for graceful close. 2026-04-19 13:49:30.663 | Historical data download thread signaled to stop. 2026-04-19 13:49:30.663 | HD Request # 77 | Received 5 Intraday data records from 2025-09-19 09:29:58.697000 to 2025-09-19 09:29:58.698000 (0.0 seconds. Delay: 212.2 days) and wrote 0 records for F.US.EPU25 2026-04-19 13:49:30.665 | HD Request # 77 | Add time&sales data | Remembered last file record date-time: 2025-09-19 13:29:58.698000 2026-04-19 13:49:30.665 | HD Request # 77 | Completion time: 3s. 2026-04-19 13:49:30.665 | HD Request # 77 | Intraday data download complete for F.US.EPU25. Unique request ID: 77 2026-04-19 13:49:30.665 | Removing historical data download ID 77. 2026-04-19 13:49:30.665 | Real-time Intraday chart data file updates started for F.US.EPU25 2026-04-19 13:49:30.665 | Intraday chart data file opened for F.US.EPU25 2026-04-19 13:49:30.665 | HD Request # 77 | Enabling Intraday chart updating for symbol. 2026-04-19 13:49:30.665 | 2026-04-19 13:49:30.666 | Triggering next historical data download in queue. 2026-04-19 13:49:30.666 | HD Request # 78 | Downloading Intraday chart data for F.US.CLEM26 to the file F.US.CLEM26.scid. Service: nymex 2026-04-19 13:49:30.680 | HD Request # 78 | Download start date-time: 2026-04-17 16:59:59.000000. File last date-time: 2026-04-17 16:59:59.113000 2026-04-19 13:49:30.680 | HD Request # 78 | Using server: ds32.sierracharts.com port 10149 2026-04-19 13:49:30.692 | Socket (4) | Creating socket. 2026-04-19 13:49:30.692 | Socket (4) | New receive buffer size: 0 2026-04-19 13:49:30.692 | Socket (4) | Connecting to IP: 69.39.70.248. 2026-04-19 13:49:30.754 | Socket (5) | Socket gracefully closed by remote side. 2026-04-19 13:49:30.754 | Socket (5) | Closed. 2026-04-19 13:49:30.879 | HD Request # 78 | Setting DTC encoding to Binary VLS 2026-04-19 13:49:30.879 | HD Request # 78 | Sending historical data logon request message. 2026-04-19 13:49:31.000 | HD Request # 78 | Requesting Intraday data. Start date-time: 2026-04-17 16:59:59. Record interval: 0. Symbol: CLM26 2026-04-19 13:49:31.093 | HD Request # 78 | Decompressing data. 2026-04-19 13:49:31.186 | HD Request # 78 | Receiving Intraday data for F.US.CLEM26 starting at 2026-04-17 16:59:59.113000 2026-04-19 13:49:31.186 | Socket (4) | CloseSocket call. 2026-04-19 13:49:31.186 | Socket (4) | Shutdown started. Waiting for graceful close. 2026-04-19 13:49:31.186 | Historical data download thread signaled to stop. 2026-04-19 13:49:31.186 | HD Request # 78 | Received 1 Intraday data record from 2026-04-17 16:59:59.113000 to 2026-04-17 16:59:59.113000 (0.0 seconds. Delay: 44.8 hours) and wrote 0 records for F.US.CLEM26 2026-04-19 13:49:31.187 | HD Request # 78 | Add time&sales data | Remembered last file record date-time: 2026-04-17 20:59:59.113000 2026-04-19 13:49:31.187 | HD Request # 78 | Completion time: 1s. 2026-04-19 13:49:31.187 | HD Request # 78 | Intraday data download complete for F.US.CLEM26. Unique request ID: 78 2026-04-19 13:49:31.187 | Removing historical data download ID 78. 2026-04-19 13:49:31.187 | Real-time Intraday chart data file updates started for F.US.CLEM26 2026-04-19 13:49:31.187 | Intraday chart data file opened for F.US.CLEM26 2026-04-19 13:49:31.187 | HD Request # 78 | Enabling Intraday chart updating for symbol. 2026-04-19 13:49:31.187 | 2026-04-19 13:49:31.187 | No download requests in the queue to start downloads for. 2026-04-19 13:49:31.276 | Socket (4) | Socket gracefully closed by remote side. 2026-04-19 13:49:31.276 | Socket (4) | Closed. 2026-04-19 13:49:37.028 | CQG WebSocket socket (1) | Write has completed. Shutdown being performed. 2026-04-19 13:49:37.028 | CQG WebSocket socket (1) | Shutdown started. Waiting for graceful close. 2026-04-19 13:49:37.028 | CQG WebSocket socket (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. * 2026-04-19 13:49:37.028 | CQG WebSocket socket (1) | Socket gracefully closed by remote side. 2026-04-19 13:49:37.028 | CQG WebSocket socket (1) | Closed. 2026-04-19 14:24:30.704 | F.US.EPM26 [CBV][M] #2 | Reloading chart. 2026-04-19 14:24:30.774 | Added historical Intraday data request for F.US.EPM26 to the queue. 2026-04-19 14:24:30.774 | Triggering next historical data download in queue. 2026-04-19 14:24:30.789 | F.US.EPM26 [CBV][M] #2 | Performing continuous chart historical Daily data download for symbol F.US.EPM26 starting at last date in file. 2026-04-19 14:24:30.789 | Added historical Daily data request for F.US.EPM26 to the queue. 2026-04-19 14:24:30.789 | Triggering next historical data download in queue. 2026-04-19 14:24:30.813 | F.US.EPM26 [CBV][M] #2 | Waiting for historical downloads to complete with the IDs: 79, 80, 2026-04-19 14:24:30.859 | Mapping F.US.EPM26 to ESM26. Service code: cme 2026-04-19 14:24:30.861 | HD Request # 79 | Downloading Intraday chart data for F.US.EPM26 to the file F.US.EPM26.scid. Service: cme 2026-04-19 14:24:30.861 | HD Request # 79 | Download start date-time: 2026-04-16 12:57:21.000000. File last date-time: 2026-04-16 12:57:21.594005 2026-04-19 14:24:30.862 | HD Request # 79 | Using server: ds26.sierracharts.com port 10150 2026-04-19 14:24:30.864 | HD Request # 80 | Downloading Historical Daily chart data for F.US.EPM26. Starting date: 2026-04-14. Service: cqg 2026-04-19 14:24:30.869 | Socket (1) | Creating socket. 2026-04-19 14:24:30.869 | Socket (1) | New receive buffer size: 0 2026-04-19 14:24:30.869 | Socket (1) | Connecting to IP: 64.152.155.17. 2026-04-19 14:24:31.047 | HD Request # 79 | Setting DTC encoding to Binary VLS 2026-04-19 14:24:31.047 | HD Request # 79 | Sending historical data logon request message. 2026-04-19 14:24:31.173 | HD Request # 79 | Requesting Intraday data. Start date-time: 2026-04-16 12:57:21. Record interval: 0. Symbol: ESM26 2026-04-19 14:24:31.262 | HD Request # 79 | Decompressing data. 2026-04-19 14:24:31.300 | HD Request # 80 | Requesting historical Daily data for ESM26 starting at 2026-04-13. SC External HD service. 2026-04-19 14:24:31.367 | HD Request # 79 | Receiving Intraday data for F.US.EPM26 starting at 2026-04-16 12:57:21.396000 2026-04-19 14:24:31.632 | HD Request # 79 | Timestamp of first Intraday data file record written: 2026-04-16 12:57:22.622000. 2026-04-19 14:24:31.642 | HD Request # 80 | Receiving historical Daily data for F.US.EPM26 starting at 2026-04-14. 2026-04-19 14:24:31.643 | HD Request # 80 | Writing historical Daily data to the file F.US.EPM26.dly. 2026-04-19 14:24:31.647 | HD Request # 80 | Bytes received: 297 2026-04-19 14:24:31.648 | HD Request # 80 | Received 5 Daily data records from 2026-04-14 00:00:00 to 2026-04-17 00:00:00 (4.0 days) and wrote 4 records for F.US.EPM26 2026-04-19 14:24:31.648 | HD Request # 80 | Completion time: 1s. 2026-04-19 14:24:31.648 | HD Request # 80 | Daily data download complete for F.US.EPM26. Unique request ID: 80 2026-04-19 14:24:31.648 | Removing historical data download ID 80. 2026-04-19 14:24:31.648 | 2026-04-19 14:24:31.648 | No download requests in the queue to start downloads for. 2026-04-19 14:24:43.737 | Socket (1) | CloseSocket call. 2026-04-19 14:24:43.738 | Socket (1) | Shutdown started. Waiting for graceful close. 2026-04-19 14:24:43.741 | Historical data download thread signaled to stop. 2026-04-19 14:24:43.742 | HD Request # 79 | Received 1488011 Intraday data records from 2026-04-16 12:57:21.396000 to 2026-04-17 16:59:58.639000 (28.0 hours. Delay: 45.4 hours) and wrote 1487995 records for F.US.EPM26 2026-04-19 14:24:43.770 | HD Request # 79 | Add time&sales data | Remembered last file record date-time: 2026-04-17 20:59:58.639000 2026-04-19 14:24:43.770 | HD Request # 79 | Completion time: 13s. 2026-04-19 14:24:43.770 | HD Request # 79 | Intraday data download complete for F.US.EPM26. Unique request ID: 79 2026-04-19 14:24:43.770 | Removing historical data download ID 79. 2026-04-19 14:24:43.770 | Real-time Intraday chart data file updates started for F.US.EPM26 2026-04-19 14:24:43.770 | Intraday chart data file opened for F.US.EPM26 2026-04-19 14:24:43.770 | HD Request # 79 | Enabling Intraday chart updating for symbol. 2026-04-19 14:24:43.770 | 2026-04-19 14:24:43.770 | No download requests in the queue to start downloads for. 2026-04-19 14:24:43.825 | Socket (1) | Socket gracefully closed by remote side. 2026-04-19 14:24:43.825 | Socket (1) | Closed. 2026-04-19 14:24:44.101 | F.US.EPM26 [CBV][M] #2 | Download is complete for all contract months in chart. Proceeding with data load. 2026-04-19 14:24:44.102 | F.US.EPM26 [CBV][M] #2 | Reloading chart. | Number times message added: 1 2026-04-19 14:24:44.921 | Denali Data Feed | Starting real-time market data updates for: F.US.EPM26 (ESM26). ID: 4 Service code: cme 2026-04-19 14:24:44.922 | CQG WebAPI | Sending symbol resolution request for F.US.EPM26. ID: 431675 2026-04-19 14:24:44.923 | Denali Data Feed | Requesting security definition data for: F.US.EPM26 (ESM26). ID: 4 2026-04-19 14:24:44.928 | CQG WebAPI | Received symbol resolution report for symbol F.US.EPM26. Search Symbol: F.US.EPM26. Request ID: 431675. Contract ID: 4. 2026-04-19 14:24:45.113 | Denali Data Feed | Setting external service identifier for symbol F.US.EPM26 to 42140864 2026-04-19 14:24:45.113 | Denali Data Feed | Received security definition for symbol F.US.EPM26 2026-04-19 14:24:54.413 | F.US.EPM26 [CBV][M] #2 | StartDateTimeForLoadingOrderFills: 2025-04-10 00:00:00 2026-04-19 14:24:54.444 | F.US.EPM26 [CBV][M] #2 | Chart data loading complete. 2026-04-19 14:25:50.271 | F.US.CLEK26 [CBV][M] #2 | Reloading chart. 2026-04-19 14:25:50.364 | Added historical Intraday data request for F.US.CLEK26 to the queue. 2026-04-19 14:25:50.364 | Triggering next historical data download in queue. 2026-04-19 14:25:50.380 | F.US.CLEK26 [CBV][M] #2 | Performing continuous chart historical Daily data download for symbol F.US.CLEK26 starting at last date in file. 2026-04-19 14:25:50.380 | Added historical Daily data request for F.US.CLEK26 to the queue. 2026-04-19 14:25:50.380 | Triggering next historical data download in queue. 2026-04-19 14:25:50.400 | F.US.CLEK26 [CBV][M] #2 | Waiting for historical downloads to complete with the IDs: 81, 82, 2026-04-19 14:25:50.444 | Mapping F.US.CLEK26 to CLK26. Service code: nymex 2026-04-19 14:25:50.445 | HD Request # 81 | Downloading Intraday chart data for F.US.CLEK26 to the file F.US.CLEK26.scid. Service: nymex 2026-04-19 14:25:50.445 | HD Request # 81 | Download start date-time: 2026-04-16 12:57:18.000000. File last date-time: 2026-04-16 12:57:18.614000 2026-04-19 14:25:50.445 | HD Request # 81 | Using server: ds28.sierracharts.com port 10149 2026-04-19 14:25:50.446 | Socket (1) | Creating socket. 2026-04-19 14:25:50.446 | Socket (1) | New receive buffer size: 0 2026-04-19 14:25:50.446 | Socket (1) | Connecting to IP: 67.214.125.5. 2026-04-19 14:25:50.453 | HD Request # 82 | Downloading Historical Daily chart data for F.US.CLEK26. Starting date: 2026-04-14. Service: cqg 2026-04-19 14:25:50.640 | HD Request # 81 | Setting DTC encoding to Binary VLS 2026-04-19 14:25:50.640 | HD Request # 81 | Sending historical data logon request message. 2026-04-19 14:25:50.765 | HD Request # 81 | Requesting Intraday data. Start date-time: 2026-04-16 12:57:18. Record interval: 0. Symbol: CLK26 2026-04-19 14:25:50.858 | HD Request # 81 | Decompressing data. 2026-04-19 14:25:50.893 | HD Request # 82 | Requesting historical Daily data for CLK26 starting at 2026-04-13. SC External HD service. 2026-04-19 14:25:51.126 | HD Request # 82 | Receiving historical Daily data for F.US.CLEK26 starting at 2026-04-14. 2026-04-19 14:25:51.127 | HD Request # 82 | Writing historical Daily data to the file F.US.CLEK26.dly. 2026-04-19 14:25:51.141 | HD Request # 82 | Bytes received: 263 2026-04-19 14:25:51.141 | HD Request # 82 | Received 5 Daily data records from 2026-04-14 00:00:00 to 2026-04-17 00:00:00 (4.0 days) and wrote 4 records for F.US.CLEK26 2026-04-19 14:25:51.141 | HD Request # 82 | Completion time: 1s. 2026-04-19 14:25:51.141 | HD Request # 82 | Daily data download complete for F.US.CLEK26. Unique request ID: 82 2026-04-19 14:25:51.141 | Removing historical data download ID 82. 2026-04-19 14:25:51.141 | 2026-04-19 14:25:51.141 | No download requests in the queue to start downloads for. 2026-04-19 14:25:51.167 | HD Request # 81 | Receiving Intraday data for F.US.CLEK26 starting at 2026-04-16 12:57:18.241000 2026-04-19 14:25:52.189 | HD Request # 81 | Timestamp of first Intraday data file record written: 2026-04-16 12:57:24.742000. 2026-04-19 14:25:52.638 | Socket (1) | CloseSocket call. 2026-04-19 14:25:52.638 | Socket (1) | Shutdown started. Waiting for graceful close. 2026-04-19 14:25:52.640 | Historical data download thread signaled to stop. 2026-04-19 14:25:52.641 | HD Request # 81 | Received 56223 Intraday data records from 2026-04-16 12:57:18.241000 to 2026-04-17 16:59:58.679000 (28.0 hours. Delay: 45.4 hours) and wrote 56218 records for F.US.CLEK26 2026-04-19 14:25:52.649 | HD Request # 81 | Add time&sales data | Remembered last file record date-time: 2026-04-17 20:59:58.679000 2026-04-19 14:25:52.649 | HD Request # 81 | Completion time: 2s. 2026-04-19 14:25:52.649 | HD Request # 81 | Intraday data download complete for F.US.CLEK26. Unique request ID: 81 2026-04-19 14:25:52.649 | Removing historical data download ID 81. 2026-04-19 14:25:52.649 | Real-time Intraday chart data file updates started for F.US.CLEK26 2026-04-19 14:25:52.649 | Intraday chart data file opened for F.US.CLEK26 2026-04-19 14:25:52.649 | HD Request # 81 | Enabling Intraday chart updating for symbol. 2026-04-19 14:25:52.649 | 2026-04-19 14:25:52.649 | No download requests in the queue to start downloads for. 2026-04-19 14:25:52.699 | F.US.CLEK26 [CBV][M] #2 | Download is complete for all contract months in chart. Proceeding with data load. 2026-04-19 14:25:52.702 | F.US.CLEK26 [CBV][M] #2 | Reloading chart. 2026-04-19 14:25:52.730 | Socket (1) | Socket gracefully closed by remote side. 2026-04-19 14:25:52.730 | Socket (1) | Closed. 2026-04-19 14:25:53.119 | F.US.CLEK26 [CBV][M] #2 | Reloading chart. 2026-04-19 14:25:53.573 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEK26 (CLK26). ID: 5 Service code: nymex 2026-04-19 14:25:53.573 | CQG WebAPI | Sending symbol resolution request for F.US.CLEK26. ID: 431676 2026-04-19 14:25:53.573 | Denali Data Feed | Requesting security definition data for: F.US.CLEK26 (CLK26). ID: 5 2026-04-19 14:25:53.577 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEK26. Search Symbol: F.US.CLEK26. Request ID: 431676. Contract ID: 5. 2026-04-19 14:25:53.850 | Denali Data Feed | Setting external service identifier for symbol F.US.CLEK26 to 169926 2026-04-19 14:25:53.850 | Denali Data Feed | Received security definition for symbol F.US.CLEK26 2026-04-19 14:25:55.645 | F.US.CLEK26 [CBV][M] #2 | StartDateTimeForLoadingOrderFills: 2025-04-10 00:00:00 2026-04-19 14:25:55.681 | F.US.CLEK26 [CBV][M] #2 | Chart data loading complete. 2026-04-19 14:26:13.111 | F.US.CLEK26 [CBV][M] 2000 Volume #5 | Reloading chart. 2026-04-19 14:26:16.936 | F.US.CLEK26 [CBV][M] 2000 Volume #5 | StartDateTimeForLoadingOrderFills: 2025-04-10 00:00:00 2026-04-19 14:26:16.993 | F.US.CLEK26 [CBV][M] 2000 Volume #5 | Chart data loading complete. 2026-04-19 14:31:16.858 | F.US.CLEM26 [CBV][M] #2 | Reloading chart. 2026-04-19 14:31:16.873 | Added historical Intraday data request for F.US.CLEM26 to the queue. 2026-04-19 14:31:16.873 | Intraday data recording state for symbol F.US.CLEM26 is set to download 'Pending'. 2026-04-19 14:31:16.873 | Triggering next historical data download in queue. 2026-04-19 14:31:16.889 | F.US.CLEM26 [CBV][M] #2 | Performing continuous chart historical Daily data download for symbol F.US.CLEM26 starting at last date in file. 2026-04-19 14:31:16.890 | Added historical Daily data request for F.US.CLEM26 to the queue. 2026-04-19 14:31:16.890 | Triggering next historical data download in queue. 2026-04-19 14:31:16.913 | F.US.CLEM26 [CBV][M] #2 | Waiting for historical downloads to complete with the IDs: 83, 84, 2026-04-19 14:31:16.918 | F.US.CLEM26 [CBV][M] 2000 Volume #5 | Reloading chart. 2026-04-19 14:31:16.946 | F.US.CLEM26 [CBV][M] 2000 Volume #5 | Waiting for historical downloads to complete with the IDs: 83, 84, 2026-04-19 14:31:16.963 | HD Request # 83 | Downloading Intraday chart data for F.US.CLEM26 to the file F.US.CLEM26.scid. Service: nymex 2026-04-19 14:31:16.964 | HD Request # 83 | Download start date-time: 2026-04-17 16:59:59.000000. File last date-time: 2026-04-17 16:59:59.113000 2026-04-19 14:31:16.965 | HD Request # 83 | Using server: ds32.sierracharts.com port 10150 2026-04-19 14:31:16.967 | HD Request # 84 | Downloading Historical Daily chart data for F.US.CLEM26. Starting date: 2026-04-14. Service: cqg 2026-04-19 14:31:16.971 | Socket (1) | Creating socket. 2026-04-19 14:31:16.971 | Socket (1) | New receive buffer size: 0 2026-04-19 14:31:16.971 | Socket (1) | Connecting to IP: 69.39.70.248. 2026-04-19 14:31:17.161 | HD Request # 83 | Setting DTC encoding to Binary VLS 2026-04-19 14:31:17.161 | HD Request # 83 | Sending historical data logon request message. 2026-04-19 14:31:17.296 | HD Request # 83 | Requesting Intraday data. Start date-time: 2026-04-17 16:59:59. Record interval: 0. Symbol: CLM26 2026-04-19 14:31:17.389 | HD Request # 83 | Decompressing data. 2026-04-19 14:31:17.411 | HD Request # 84 | Requesting historical Daily data for CLM26 starting at 2026-04-13. SC External HD service. 2026-04-19 14:31:17.481 | HD Request # 83 | Receiving Intraday data for F.US.CLEM26 starting at 2026-04-17 16:59:59.113000 2026-04-19 14:31:17.481 | Socket (1) | CloseSocket call. 2026-04-19 14:31:17.481 | Socket (1) | Shutdown started. Waiting for graceful close. 2026-04-19 14:31:17.484 | Historical data download thread signaled to stop. 2026-04-19 14:31:17.484 | HD Request # 83 | Received 1 Intraday data record from 2026-04-17 16:59:59.113000 to 2026-04-17 16:59:59.113000 (0.0 seconds. Delay: 45.5 hours) and wrote 0 records for F.US.CLEM26 2026-04-19 14:31:17.485 | HD Request # 83 | Add time&sales data | Remembered last file record date-time: 2026-04-17 20:59:59.113000 2026-04-19 14:31:17.486 | HD Request # 83 | Completion time: 1s. 2026-04-19 14:31:17.486 | HD Request # 83 | Intraday data download complete for F.US.CLEM26. Unique request ID: 83 2026-04-19 14:31:17.486 | Removing historical data download ID 83. 2026-04-19 14:31:17.486 | Real-time Intraday chart data file updates started for F.US.CLEM26 2026-04-19 14:31:17.486 | Intraday chart data file opened for F.US.CLEM26 2026-04-19 14:31:17.486 | HD Request # 83 | Enabling Intraday chart updating for symbol. 2026-04-19 14:31:17.486 | 2026-04-19 14:31:17.486 | No download requests in the queue to start downloads for. 2026-04-19 14:31:17.573 | Socket (1) | Socket gracefully closed by remote side. 2026-04-19 14:31:17.573 | Socket (1) | Closed. 2026-04-19 14:31:17.615 | HD Request # 84 | Receiving historical Daily data for F.US.CLEM26 starting at 2026-04-14. 2026-04-19 14:31:17.615 | HD Request # 84 | Writing historical Daily data to the file F.US.CLEM26.dly. 2026-04-19 14:31:17.629 | HD Request # 84 | Bytes received: 267 2026-04-19 14:31:17.629 | HD Request # 84 | Received 5 Daily data records from 2026-04-14 00:00:00 to 2026-04-17 00:00:00 (4.0 days) and wrote 4 records for F.US.CLEM26 2026-04-19 14:31:17.629 | HD Request # 84 | Completion time: 1s. 2026-04-19 14:31:17.629 | HD Request # 84 | Daily data download complete for F.US.CLEM26. Unique request ID: 84 2026-04-19 14:31:17.629 | Removing historical data download ID 84. 2026-04-19 14:31:17.629 | 2026-04-19 14:31:17.629 | No download requests in the queue to start downloads for. 2026-04-19 14:31:17.670 | F.US.CLEM26 [CBV][M] #2 | Download is complete for all contract months in chart. Proceeding with data load. 2026-04-19 14:31:17.670 | F.US.CLEM26 [CBV][M] #2 | Reloading chart. 2026-04-19 14:31:18.085 | F.US.CLEM26 [CBV][M] 2000 Volume #5 | Download is complete for all contract months in chart. Proceeding with data load. 2026-04-19 14:31:18.087 | F.US.CLEM26 [CBV][M] 2000 Volume #5 | Reloading chart. 2026-04-19 14:31:18.577 | F.US.CLEM26 [CBV][M] #2 | Reloading chart. 2026-04-19 14:31:19.163 | F.US.CLEM26 [CBV][M] 2000 Volume #5 | Reloading chart. 2026-04-19 14:31:20.694 | F.US.CLEM26 [CBV][M] #2 | StartDateTimeForLoadingOrderFills: 2025-04-10 00:00:00 2026-04-19 14:31:20.725 | F.US.CLEM26 [CBV][M] #2 | Chart data loading complete. 2026-04-19 14:31:22.817 | F.US.CLEM26 [CBV][M] 2000 Volume #5 | StartDateTimeForLoadingOrderFills: 2025-04-10 00:00:00 2026-04-19 14:31:22.857 | F.US.CLEM26 [CBV][M] 2000 Volume #5 | Chart data loading complete. 2026-04-19 22:14:14.213 | The data feed was lost. There was no activity for at least 60.0 seconds. 2026-04-19 22:14:14.213 | Connection to the external service has been lost. 2026-04-19 22:14:14.360 | CQG WebSocket | Timeout waiting for pong message from server. 2026-04-19 22:14:14.364 | CQG WebAPI | WebSocket closed. 2026-04-19 22:14:14.367 | Denali Data Feed | There has been no activity on the network socket for 6h 42m 12s. Will reconnect. 2026-04-19 22:14:14.369 | Denali Data Feed | Waiting for socket receive thread to end 2026-04-19 22:14:14.370 | DTC Client socket (3) | CloseSocket call. 2026-04-19 22:14:14.370 | DTC Client socket (3) | Max send buffers used during socket life: 3 2026-04-19 22:14:14.370 | DTC Client socket (3) | Max send buffer size during socket life: 212 2026-04-19 22:14:14.370 | Denali Data Feed | Disconnected from the server. 2026-04-19 22:14:14.371 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds. 2026-04-19 22:14:14.372 | CQG WebAPI | Sending Web API Logoff message. 2026-04-19 22:14:14.372 | CQG WebSocket socket (2) | CloseSocket call. 2026-04-19 22:14:14.372 | CQG WebSocket | WebSocket closed. 2026-04-19 22:14:14.372 | CQG WebAPI | WebSocket closed. 2026-04-19 22:14:14.375 | CQG WebAPI | Disconnected. 2026-04-19 22:14:14.376 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-04-19 22:14:14.386 | DTC Client socket (3) | Write in progress. Shutdown being delayed. PendingSize=0 2026-04-19 22:14:14.386 | CQG WebSocket socket (2) | Write in progress. Shutdown being delayed. PendingSize=0 2026-04-19 22:14:14.567 | DTC Client socket (3) | Write has completed. Shutdown being performed. 2026-04-19 22:14:14.567 | DTC Client socket (3) | Shutdown started. Waiting for graceful close. 2026-04-19 22:14:14.567 | DTC Client socket (3) | Socket gracefully closed by remote side. 2026-04-19 22:14:14.567 | DTC Client socket (3) | Closed. 2026-04-19 22:14:16.382 | 2026-04-19 22:14:16.382 | CQG WebAPI | Connecting to server api.cqg.com 2026-04-19 22:14:16.382 | CQG WebSocket | Connecting to WebSocket server api.cqg.com:443 2026-04-19 22:14:16.578 | CQG WebSocket socket (1) | Creating socket. Using TLS 1.2. 2026-04-19 22:14:16.578 | CQG WebSocket socket (1) | New receive buffer size: 0 2026-04-19 22:14:16.578 | CQG WebSocket socket (1) | Connecting to IP: 195.166.124.175. 2026-04-19 22:14:16.583 | CQG WebSocket | Opening WebSocket. 2026-04-19 22:14:16.583 | CQG WebSocket | Sending WebSocket handshake. 2026-04-19 22:14:16.605 | CQG WebSocket | Server header | HTTP/1.1 101 Switching Protocols 2026-04-19 22:14:16.605 | CQG WebSocket | Server header | Connection: Upgrade 2026-04-19 22:14:16.605 | CQG WebSocket | Server header | Sec-WebSocket-Accept: pPDcQeQEIVBO1M4PNQpqvJaItdM= 2026-04-19 22:14:16.605 | CQG WebSocket | Server header | Server: WebSocket++/0.8.2 2026-04-19 22:14:16.605 | CQG WebSocket | Server header | Upgrade: websocket 2026-04-19 22:14:16.605 | CQG WebSocket | Server header | 2026-04-19 22:14:16.605 | CQG WebSocket | Web socket state is now open. 2026-04-19 22:14:16.605 | CQG WebAPI | WebSocket connected. 2026-04-19 22:14:16.606 | CQG WebAPI | Sending market data logon message. 2026-04-20 03:39:05.086 | Denali Data Feed | Connecting to the server ds25-2.sierracharts.com. Port 10048 2026-04-20 03:39:05.087 | Service connection timed out. Will disconnect and retry. * 2026-04-20 03:39:05.087 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-04-20 03:39:05.087 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-04-20 03:39:05.087 | CQG WebSocket | Timeout waiting for pong message from server. 2026-04-20 03:39:05.087 | CQG WebAPI | WebSocket closed. 2026-04-20 03:39:05.107 | CQG WebSocket socket (1) | CloseSocket call. 2026-04-20 03:39:05.107 | CQG WebSocket | WebSocket closed. 2026-04-20 03:39:05.108 | CQG WebAPI | WebSocket closed. 2026-04-20 03:39:05.108 | CQG WebAPI | Disconnected. 2026-04-20 03:39:05.108 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-04-20 03:39:05.130 | CQG WebSocket socket (2) | Write has completed. Shutdown being performed. 2026-04-20 03:39:05.130 | CQG WebSocket socket (2) | Shutdown started. Waiting for graceful close. 2026-04-20 03:39:05.130 | CQG WebSocket socket (2) | Socket gracefully closed by remote side. 2026-04-20 03:39:05.130 | CQG WebSocket socket (2) | Closed. 2026-04-20 03:39:05.132 | CQG WebSocket socket (1) | Write in progress. Shutdown being delayed. PendingSize=0 2026-04-20 03:39:05.163 | DTC Client socket (5) | Creating socket. 2026-04-20 03:39:05.163 | DTC Client socket (5) | New receive buffer size: 0 2026-04-20 03:39:05.163 | DTC Client socket (5) | Connecting to IP: 64.152.155.21. 2026-04-20 03:39:05.381 | Denali Data Feed | Network connection to server complete. 2026-04-20 03:39:05.381 | Denali Data Feed | Starting socket receive thread. 2026-04-20 03:39:05.381 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard 2026-04-20 03:39:05.598 | Denali Data Feed | Setting DTC encoding to Binary VLS 2026-04-20 03:39:05.708 | Denali Data Feed | Sending logon request message. 2026-04-20 03:39:06.399 | Denali Data Feed | Received logon response. 2026-04-20 03:39:06.399 | Denali Data Feed | Server Name: SC Realtime Server. 2026-04-20 03:39:06.399 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8 2026-04-20 03:39:06.399 | Denali Data Feed | Successfully connected. 2026-04-20 03:39:06.399 | Denali Data Feed | Trading is not supported. 2026-04-20 03:39:06.399 | Denali Data Feed | MarketDepthIsSupported: 1 2026-04-20 03:39:06.400 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEK26 -> CLK26 2026-04-20 03:39:06.400 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEM26 -> CLM26 2026-04-20 03:39:06.400 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEV25 -> CLV25. Market Depth data restarted. 2026-04-20 03:39:06.400 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.EPM26 -> ESM26 2026-04-20 03:39:06.400 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.EPU25 -> ESU25 2026-04-20 03:39:06.615 | Denali Data Feed | Clearing market depth for F.US.CLEV25 2026-04-20 03:39:06.615 | Denali Data Feed | Setting external service identifier for symbol F.US.CLEK26 to 169926 2026-04-20 03:39:06.615 | Denali Data Feed | Received security definition for symbol F.US.CLEK26 2026-04-20 03:39:06.615 | Denali Data Feed | Setting external service identifier for symbol F.US.CLEM26 to 670557 2026-04-20 03:39:06.615 | Denali Data Feed | Received security definition for symbol F.US.CLEM26 2026-04-20 03:39:06.615 | Denali Data Feed | Real-time data for symbol F.US.CLEV25 is currently unavailable. 2026-04-20 03:39:06.615 | Denali Data Feed | Received security definition for symbol F.US.CLEV25 2026-04-20 03:39:06.615 | Denali Data Feed | Setting external service identifier for symbol F.US.EPM26 to 42140864 2026-04-20 03:39:06.615 | Denali Data Feed | Received security definition for symbol F.US.EPM26 2026-04-20 03:39:06.615 | Denali Data Feed | Real-time data for symbol F.US.EPU25 is currently unavailable. 2026-04-20 03:39:06.615 | Denali Data Feed | Received security definition for symbol F.US.EPU25 2026-04-20 03:39:07.136 | 2026-04-20 03:39:07.136 | CQG WebAPI | Connecting to server api.cqg.com 2026-04-20 03:39:07.136 | CQG WebSocket | Connecting to WebSocket server api.cqg.com:443 2026-04-20 03:39:07.332 | CQG WebSocket socket (2) | Creating socket. Using TLS 1.2. 2026-04-20 03:39:07.332 | CQG WebSocket socket (2) | New receive buffer size: 0 2026-04-20 03:39:07.332 | CQG WebSocket socket (2) | Connecting to IP: 195.166.124.175. 2026-04-20 03:39:07.337 | CQG WebSocket | Opening WebSocket. 2026-04-20 03:39:07.337 | CQG WebSocket | Sending WebSocket handshake. 2026-04-20 03:39:07.352 | CQG WebSocket | Server header | HTTP/1.1 101 Switching Protocols 2026-04-20 03:39:07.352 | CQG WebSocket | Server header | Connection: Upgrade 2026-04-20 03:39:07.352 | CQG WebSocket | Server header | Sec-WebSocket-Accept: h26UjhbPJt/gwr/7fld7++XWfm8= 2026-04-20 03:39:07.352 | CQG WebSocket | Server header | Server: WebSocket++/0.8.2 2026-04-20 03:39:07.352 | CQG WebSocket | Server header | Upgrade: websocket 2026-04-20 03:39:07.352 | CQG WebSocket | Server header | 2026-04-20 03:39:07.352 | CQG WebSocket | Web socket state is now open. 2026-04-20 03:39:07.352 | CQG WebAPI | WebSocket connected. 2026-04-20 03:39:07.352 | CQG WebAPI | Sending market data logon message. 2026-04-20 03:39:07.605 | CQG WebAPI | Base Time: 2026-03-28T06:49:02. 2026-03-28 06:49:02 2026-04-20 03:39:07.605 | CQG WebAPI | Logon successful. Session Token = DRFV1itm/E16j8fxWefco2L9ZrXGl5WBj6/AvAQbGMY58rU6qAnOiAAp3DWwR+90PgsMbSJO7x5 2026-04-20 03:39:07.605 | CQG WebAPI | Connection to server complete. 2026-04-20 03:39:07.605 | Denali Data Feed | Waiting for socket receive thread to end 2026-04-20 03:39:07.606 | DTC Client socket (5) | CloseSocket call. 2026-04-20 03:39:07.606 | DTC Client socket (5) | Shutdown started. Waiting for graceful close. 2026-04-20 03:39:07.606 | Denali Data Feed | Disconnected from the server. 2026-04-20 03:39:07.613 | No download requests in the queue to start downloads for. | Number times message added: 3 2026-04-20 03:39:07.614 | Updated verified funded futures trading account ending date to: 2026-05-20 07:39:07 2026-04-20 03:39:07.646 | CQG WebAPI | Sending Trade Accounts request message. 2026-04-20 03:39:07.695 | DTC Client socket (5) | Socket gracefully closed by remote side. 2026-04-20 03:39:07.695 | DTC Client socket (5) | Closed. 2026-04-20 03:39:07.743 | CQG WebAPI | Brokerage name: AMP. Account Name: 220033 2026-04-20 03:39:07.743 | Updated verified funded futures trading account ending date to: 2026-05-20 07:39:07 2026-04-20 03:39:07.743 | CQG WebAPI | Sending collateral subscribe request. 2026-04-20 03:39:07.795 | Mapping F.US.CLEM26 to CLM26. Service code: nymex 2026-04-20 03:39:07.795 | Using symbol data fast lookup vector 2026-04-20 03:39:07.795 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEM26 (CLM26). ID: 1 Service code: nymex 2026-04-20 03:39:07.795 | Denali Data Feed | Connecting to the server ds28.sierracharts.com. Port 443 2026-04-20 03:39:07.796 | CQG WebAPI | Sending symbol resolution request for F.US.CLEM26. ID: 431679 2026-04-20 03:39:07.796 | Denali Data Feed | Requesting security definition data for: F.US.CLEM26 (CLM26). ID: 1 2026-04-20 03:39:07.796 | Added historical Intraday data request for F.US.CLEM26 to the queue. 2026-04-20 03:39:07.796 | Intraday data recording state for symbol F.US.CLEM26 is set to download 'Pending'. 2026-04-20 03:39:07.796 | Triggering next historical data download in queue. 2026-04-20 03:39:07.808 | Delaying start of download for F.US.CLEM26. 2026-04-20 03:39:07.820 | DTC Client socket (3) | Creating socket. 2026-04-20 03:39:07.821 | DTC Client socket (3) | New receive buffer size: 0 2026-04-20 03:39:07.821 | DTC Client socket (3) | Connecting to IP: 67.214.125.5. 2026-04-20 03:39:07.844 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEM26. Search Symbol: F.US.CLEM26. Request ID: 431679. Contract ID: 1. 2026-04-20 03:39:07.844 | Mapping F.US.CLEV25 to CLV25. Service code: nymex 2026-04-20 03:39:07.844 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEV25 (CLV25). ID: 2 Service code: nymex 2026-04-20 03:39:07.844 | CQG WebAPI | Sending symbol resolution request for F.US.CLEV25. ID: 431680 2026-04-20 03:39:07.844 | Denali Data Feed | Requesting security definition data for: F.US.CLEV25 (CLV25). ID: 2 2026-04-20 03:39:07.844 | Added historical Intraday data request for F.US.CLEV25 to the queue. 2026-04-20 03:39:07.844 | Intraday data recording state for symbol F.US.CLEV25 is set to download 'Pending'. 2026-04-20 03:39:07.844 | Triggering next historical data download in queue. 2026-04-20 03:39:07.928 | CQG WebAPI | Sending positions subscribe request. RequestID: 431681 2026-04-20 03:39:07.928 | CQG WebAPI | Sending orders subscribe request. RequestID: 431682 2026-04-20 03:39:07.929 | Denali Data Feed | Network connection to server complete. 2026-04-20 03:39:07.929 | Denali Data Feed | Starting socket receive thread. 2026-04-20 03:39:07.929 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard 2026-04-20 03:39:07.932 | Mapping F.US.EPU25 to ESU25. Service code: cme 2026-04-20 03:39:07.932 | Denali Data Feed | Starting real-time market data updates for: F.US.EPU25 (ESU25). ID: 3 Service code: cme 2026-04-20 03:39:07.932 | CQG WebAPI | Sending symbol resolution request for F.US.EPU25. ID: 431683 2026-04-20 03:39:07.932 | Denali Data Feed | Requesting security definition data for: F.US.EPU25 (ESU25). ID: 3 2026-04-20 03:39:07.933 | Added historical Intraday data request for F.US.EPU25 to the queue. 2026-04-20 03:39:07.933 | Intraday data recording state for symbol F.US.EPU25 is set to download 'Pending'. 2026-04-20 03:39:07.933 | Triggering next historical data download in queue. 2026-04-20 03:39:07.994 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEV25. Search Symbol: F.US.CLEV25. Request ID: 431680. Contract ID: 2. 2026-04-20 03:39:08.040 | CQG WebAPI | Received symbol resolution report for symbol F.US.EPU25. Search Symbol: F.US.EPU25. Request ID: 431683. Contract ID: 3. 2026-04-20 03:39:08.041 | Denali Data Feed | Setting DTC encoding to Binary VLS 2026-04-20 03:39:08.041 | Denali Data Feed | Sending logon request message. 2026-04-20 03:39:08.570 | Denali Data Feed | Received logon response. 2026-04-20 03:39:08.570 | Denali Data Feed | Server Name: SC Realtime Server. 2026-04-20 03:39:08.570 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8 2026-04-20 03:39:08.570 | Denali Data Feed | Successfully connected. 2026-04-20 03:39:08.570 | Denali Data Feed | Trading is not supported. 2026-04-20 03:39:08.570 | Denali Data Feed | MarketDepthIsSupported: 1 2026-04-20 03:39:08.570 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEM26 -> CLM26 2026-04-20 03:39:08.570 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEV25 -> CLV25 2026-04-20 03:39:08.570 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.EPU25 -> ESU25 2026-04-20 03:39:08.756 | Denali Data Feed | Setting external service identifier for symbol F.US.CLEM26 to 670557 2026-04-20 03:39:08.756 | Denali Data Feed | Received security definition for symbol F.US.CLEM26 2026-04-20 03:39:08.756 | Denali Data Feed | Real-time data for symbol F.US.CLEV25 is currently unavailable. 2026-04-20 03:39:08.757 | Denali Data Feed | Received security definition for symbol F.US.CLEV25 2026-04-20 03:39:08.757 | Denali Data Feed | Real-time data for symbol F.US.EPU25 is currently unavailable. 2026-04-20 03:39:08.757 | Denali Data Feed | Received security definition for symbol F.US.EPU25 2026-04-20 03:39:12.609 | Requesting market depth updates for: F.US.CLEV25 if supported. NumLevels=100 2026-04-20 03:39:12.787 | Denali Data Feed | Clearing market depth for F.US.CLEV25 2026-04-20 03:39:13.108 | HD Request # 85 | Downloading Intraday chart data for F.US.CLEM26 to the file F.US.CLEM26.scid. Service: nymex 2026-04-20 03:39:13.125 | HD Request # 85 | Download start date-time: 2026-04-17 16:59:59.000000. File last date-time: 2026-04-17 16:59:59.113000 2026-04-20 03:39:13.127 | HD Request # 85 | Using server: ds26.sierracharts.com port 10149 2026-04-20 03:39:13.134 | Socket (4) | Creating socket. 2026-04-20 03:39:13.134 | Socket (4) | New receive buffer size: 0 2026-04-20 03:39:13.134 | Socket (4) | Connecting to IP: 64.152.155.17. 2026-04-20 03:39:13.313 | HD Request # 85 | Setting DTC encoding to Binary VLS 2026-04-20 03:39:13.313 | HD Request # 85 | Sending historical data logon request message. 2026-04-20 03:39:13.430 | HD Request # 85 | Requesting Intraday data. Start date-time: 2026-04-17 16:59:59. Record interval: 0. Symbol: CLM26 2026-04-20 03:39:13.518 | HD Request # 85 | Decompressing data. 2026-04-20 03:39:13.712 | HD Request # 85 | Receiving Intraday data for F.US.CLEM26 starting at 2026-04-17 16:59:59.113000 2026-04-20 03:39:14.062 | HD Request # 85 | Timestamp of first Intraday data file record written: 2026-04-19 18:00:00.000000. 2026-04-20 03:39:14.148 | Socket (4) | CloseSocket call. 2026-04-20 03:39:14.148 | Socket (4) | Shutdown started. Waiting for graceful close. 2026-04-20 03:39:14.148 | Historical data download thread signaled to stop. 2026-04-20 03:39:14.149 | HD Request # 85 | Received 53593 Intraday data records from 2026-04-17 16:59:59.113000 to 2026-04-20 03:39:14.942000 (2.4 days. Delay: -0.8 seconds) and wrote 53592 records for F.US.CLEM26 2026-04-20 03:39:14.160 | HD Request # 85 | Add time&sales data | Remembered last file record date-time: 2026-04-20 07:39:14.942000 2026-04-20 03:39:14.161 | Added 1 Time and Sales records to Intraday data file for F.US.CLEM26 after download. 2026-04-20 03:39:14.162 | HD Request # 85 | Completion time: 1s. 2026-04-20 03:39:14.162 | HD Request # 85 | Intraday data download complete for F.US.CLEM26. Unique request ID: 85 2026-04-20 03:39:14.162 | Removing historical data download ID 85. 2026-04-20 03:39:14.162 | Real-time Intraday chart data file updates started for F.US.CLEM26 2026-04-20 03:39:14.162 | Intraday chart data file opened for F.US.CLEM26 2026-04-20 03:39:14.162 | HD Request # 85 | Enabling Intraday chart updating for symbol. 2026-04-20 03:39:14.162 | 2026-04-20 03:39:14.162 | Triggering next historical data download in queue. 2026-04-20 03:39:14.162 | HD Request # 86 | Downloading Intraday chart data for F.US.CLEV25 to the file F.US.CLEV25.scid. Service: nymex 2026-04-20 03:39:14.175 | HD Request # 86 | Download start date-time: 2025-09-22 14:29:55.000000. File last date-time: 2025-09-22 14:29:55.618000 2026-04-20 03:39:14.175 | HD Request # 86 | Using server: ds28.sierracharts.com port 10150 2026-04-20 03:39:14.175 | Socket (5) | Creating socket. 2026-04-20 03:39:14.175 | Socket (5) | New receive buffer size: 0 2026-04-20 03:39:14.175 | Socket (5) | Connecting to IP: 67.214.125.5. 2026-04-20 03:39:14.236 | Socket (4) | Socket gracefully closed by remote side. 2026-04-20 03:39:14.236 | Socket (4) | Closed. 2026-04-20 03:39:14.361 | HD Request # 86 | Setting DTC encoding to Binary VLS 2026-04-20 03:39:14.361 | HD Request # 86 | Sending historical data logon request message. 2026-04-20 03:39:14.485 | HD Request # 86 | Requesting Intraday data. Start date-time: 2025-09-22 14:29:55. Record interval: 0. Symbol: CLV25 2026-04-20 03:39:14.577 | HD Request # 86 | Decompressing data. 2026-04-20 03:39:14.711 | HD Request # 86 | Receiving Intraday data for F.US.CLEV25 starting at 2025-09-22 14:29:55.086000 2026-04-20 03:39:14.711 | Socket (5) | CloseSocket call. 2026-04-20 03:39:14.711 | Socket (5) | Shutdown started. Waiting for graceful close. 2026-04-20 03:39:14.723 | Historical data download thread signaled to stop. 2026-04-20 03:39:14.723 | HD Request # 86 | Received 2 Intraday data records from 2025-09-22 14:29:55.086000 to 2025-09-22 14:29:55.618000 (0.5 seconds. Delay: 209.5 days) and wrote 0 records for F.US.CLEV25 2026-04-20 03:39:14.724 | HD Request # 86 | Add time&sales data | Remembered last file record date-time: 2025-09-22 18:29:55.618000 2026-04-20 03:39:14.724 | HD Request # 86 | Completion time: 0s. 2026-04-20 03:39:14.724 | HD Request # 86 | Intraday data download complete for F.US.CLEV25. Unique request ID: 86 2026-04-20 03:39:14.724 | Removing historical data download ID 86. 2026-04-20 03:39:14.724 | Real-time Intraday chart data file updates started for F.US.CLEV25 2026-04-20 03:39:14.724 | Intraday chart data file opened for F.US.CLEV25 2026-04-20 03:39:14.724 | HD Request # 86 | Enabling Intraday chart updating for symbol. 2026-04-20 03:39:14.724 | 2026-04-20 03:39:14.724 | Triggering next historical data download in queue. 2026-04-20 03:39:14.724 | HD Request # 87 | Downloading Intraday chart data for F.US.EPU25 to the file F.US.EPU25.scid. Service: cme 2026-04-20 03:39:14.739 | HD Request # 87 | Download start date-time: 2025-09-19 09:29:58.000000. File last date-time: 2025-09-19 09:29:58.698000 2026-04-20 03:39:14.739 | HD Request # 87 | Using server: ds32.sierracharts.com port 10149 2026-04-20 03:39:14.747 | Socket (4) | Creating socket. 2026-04-20 03:39:14.747 | Socket (4) | New receive buffer size: 0 2026-04-20 03:39:14.747 | Socket (4) | Connecting to IP: 69.39.70.248. 2026-04-20 03:39:14.803 | Socket (5) | Socket gracefully closed by remote side. 2026-04-20 03:39:14.803 | Socket (5) | Closed. 2026-04-20 03:39:14.934 | HD Request # 87 | Setting DTC encoding to Binary VLS 2026-04-20 03:39:14.934 | HD Request # 87 | Sending historical data logon request message. 2026-04-20 03:39:15.053 | HD Request # 87 | Requesting Intraday data. Start date-time: 2025-09-19 09:29:58. Record interval: 0. Symbol: ESU25 2026-04-20 03:39:15.148 | HD Request # 87 | Decompressing data. 2026-04-20 03:39:15.239 | HD Request # 87 | Receiving Intraday data for F.US.EPU25 starting at 2025-09-19 09:29:58.697000 2026-04-20 03:39:15.240 | Socket (4) | CloseSocket call. 2026-04-20 03:39:15.240 | Socket (4) | Shutdown started. Waiting for graceful close. 2026-04-20 03:39:15.240 | Historical data download thread signaled to stop. 2026-04-20 03:39:15.240 | HD Request # 87 | Received 5 Intraday data records from 2025-09-19 09:29:58.697000 to 2025-09-19 09:29:58.698000 (0.0 seconds. Delay: 212.8 days) and wrote 0 records for F.US.EPU25 2026-04-20 03:39:15.241 | HD Request # 87 | Add time&sales data | Remembered last file record date-time: 2025-09-19 13:29:58.698000 2026-04-20 03:39:15.241 | HD Request # 87 | Completion time: 1s. 2026-04-20 03:39:15.241 | HD Request # 87 | Intraday data download complete for F.US.EPU25. Unique request ID: 87 2026-04-20 03:39:15.241 | Removing historical data download ID 87. 2026-04-20 03:39:15.241 | Real-time Intraday chart data file updates started for F.US.EPU25 2026-04-20 03:39:15.241 | Intraday chart data file opened for F.US.EPU25 2026-04-20 03:39:15.241 | HD Request # 87 | Enabling Intraday chart updating for symbol. 2026-04-20 03:39:15.241 | 2026-04-20 03:39:15.241 | No download requests in the queue to start downloads for. 2026-04-20 03:39:15.331 | Socket (4) | Socket gracefully closed by remote side. 2026-04-20 03:39:15.331 | Socket (4) | Closed. 2026-04-20 03:39:18.807 | Opened cached Intraday file: C:\SierraChart\Data\F.US.CLEM26.scid. Thread ID: 16976 2026-04-20 03:39:30.932 | CQG WebSocket socket (1) | Write has completed. Shutdown being performed. 2026-04-20 03:39:30.932 | CQG WebSocket socket (1) | Shutdown started. Waiting for graceful close. 2026-04-20 03:39:30.933 | CQG WebSocket socket (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. * 2026-04-20 03:39:30.933 | CQG WebSocket socket (1) | Socket gracefully closed by remote side. 2026-04-20 03:39:30.933 | CQG WebSocket socket (1) | Closed. 2026-04-20 03:39:34.394 | ExtendTheFundedTradingAccountStatusExpirationDate: Sending request. 2026-04-20 03:39:34.824 | ExtendTheFundedTradingAccountStatusExpirationDate | Result: {"Result":"The Funded Trading Account Status Expiration Date is more than 25 days into the future. The Date is currently: 2026-05-18"}. Success=true 2026-04-20 10:40:51.776 | Saved Chartbook: ExampleChartbook.cht. Time: 0.0008 seconds. 2026-04-20 10:40:51.836 | Saved Chartbook: G7FX_STAGE3VWAPMARKETPROFILECUMULATIVEDELTACHARTBOOK_updatedJan2023-230106-183807.Cht. Time: 0.0424 seconds. 2026-04-20 10:40:55.690 | Unsubscribed from market depth data for F.US.CLEV25 2026-04-20 10:43:23.383 | File >> Disconnect selected. 2026-04-20 10:43:23.386 | CQG WebAPI | Sending Web API Logoff message. 2026-04-20 10:43:23.386 | CQG WebSocket socket (2) | CloseSocket call. 2026-04-20 10:43:23.386 | CQG WebSocket socket (2) | Max send buffers used during socket life: 3 2026-04-20 10:43:23.386 | CQG WebSocket socket (2) | Max send buffer size during socket life: 309 2026-04-20 10:43:23.386 | CQG WebSocket | WebSocket closed. 2026-04-20 10:43:23.386 | CQG WebAPI | WebSocket closed. 2026-04-20 10:43:23.386 | CQG WebSocket socket (2) | Write in progress. Shutdown being delayed. PendingSize=0 2026-04-20 10:43:23.388 | Denali Data Feed | Waiting for socket receive thread to end 2026-04-20 10:43:23.389 | DTC Client socket (3) | CloseSocket call. 2026-04-20 10:43:23.389 | DTC Client socket (3) | Shutdown started. Waiting for graceful close. 2026-04-20 10:43:23.389 | Denali Data Feed | Disconnected from the server. 2026-04-20 10:43:23.390 | CQG WebAPI | Disconnected. 2026-04-20 10:43:23.390 | CQG WebSocket socket (2) | Write has completed. Shutdown being performed. 2026-04-20 10:43:23.390 | CQG WebSocket socket (2) | Shutdown started. Waiting for graceful close. 2026-04-20 10:43:23.395 | CQG WebSocket socket (2) | Socket gracefully closed by remote side. 2026-04-20 10:43:23.395 | CQG WebSocket socket (2) | Closed. 2026-04-20 10:43:23.572 | DTC Client socket (3) | Socket gracefully closed by remote side. 2026-04-20 10:43:23.572 | DTC Client socket (3) | Closed. 2026-04-20 10:43:41.228 | 2026-04-20 10:43:41.229 | CQG WebAPI | Connecting to server api.cqg.com 2026-04-20 10:43:41.229 | CQG WebSocket | Connecting to WebSocket server api.cqg.com:443 2026-04-20 10:43:41.425 | CQG WebSocket socket (1) | Creating socket. Using TLS 1.2. 2026-04-20 10:43:41.426 | CQG WebSocket socket (1) | New receive buffer size: 0 2026-04-20 10:43:41.426 | CQG WebSocket socket (1) | Connecting to IP: 195.166.124.175. 2026-04-20 10:43:41.432 | CQG WebSocket | Opening WebSocket. 2026-04-20 10:43:41.432 | CQG WebSocket | Sending WebSocket handshake. 2026-04-20 10:43:41.454 | CQG WebSocket | Server header | HTTP/1.1 101 Switching Protocols 2026-04-20 10:43:41.454 | CQG WebSocket | Server header | Connection: Upgrade 2026-04-20 10:43:41.454 | CQG WebSocket | Server header | Sec-WebSocket-Accept: F5oAgxVadvP0/2XSxBrqKv5kzus= 2026-04-20 10:43:41.454 | CQG WebSocket | Server header | Server: WebSocket++/0.8.2 2026-04-20 10:43:41.454 | CQG WebSocket | Server header | Upgrade: websocket 2026-04-20 10:43:41.454 | CQG WebSocket | Server header | 2026-04-20 10:43:41.454 | CQG WebSocket | Web socket state is now open. 2026-04-20 10:43:41.454 | CQG WebAPI | WebSocket connected. 2026-04-20 10:43:41.456 | CQG WebAPI | Sending market data logon message. 2026-04-20 10:43:41.709 | CQG WebAPI | Base Time: 2026-03-28T06:49:02. 2026-03-28 06:49:02 2026-04-20 10:43:41.709 | CQG WebAPI | Logon successful. Session Token = x4AhT2xBvCK1HQGMrOP78r3Gs2KkT/FsScW86JCbFRwRrxZlOXVJVZdd/0n5Hw+YhXXJhhdlb+y 2026-04-20 10:43:41.709 | CQG WebAPI | Connection to server complete. 2026-04-20 10:43:41.713 | No download requests in the queue to start downloads for. | Number times message added: 3 2026-04-20 10:43:41.713 | Updated verified funded futures trading account ending date to: 2026-05-20 14:43:41 2026-04-20 10:43:41.714 | CQG WebAPI | Sending Trade Accounts request message. 2026-04-20 10:43:41.845 | CQG WebAPI | Brokerage name: AMP. Account Name: 220033 2026-04-20 10:43:41.845 | Updated verified funded futures trading account ending date to: 2026-05-20 14:43:41 2026-04-20 10:43:41.845 | CQG WebAPI | Sending collateral subscribe request. 2026-04-20 10:43:41.966 | CQG WebAPI | Sending positions subscribe request. RequestID: 431690 2026-04-20 10:43:41.967 | CQG WebAPI | Sending orders subscribe request. RequestID: 431691 2026-04-20 12:52:16.197 | The data feed was lost. There was no activity for at least 60.0 seconds. 2026-04-20 12:52:16.199 | Connection to the external service has been lost. 2026-04-20 12:52:16.200 | CQG WebSocket | Timeout waiting for pong message from server. 2026-04-20 12:52:16.200 | CQG WebAPI | WebSocket closed. 2026-04-20 12:52:16.207 | CQG WebAPI | Sending Web API Logoff message. 2026-04-20 12:52:16.207 | CQG WebSocket socket (1) | CloseSocket call. 2026-04-20 12:52:16.207 | CQG WebSocket | WebSocket closed. 2026-04-20 12:52:16.207 | CQG WebAPI | WebSocket closed. 2026-04-20 12:52:16.210 | CQG WebAPI | Disconnected. 2026-04-20 12:52:16.211 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-04-20 12:52:16.247 | CQG WebSocket socket (1) | Write in progress. Shutdown being delayed. PendingSize=0 2026-04-20 12:52:18.208 | 2026-04-20 12:52:18.209 | CQG WebAPI | Connecting to server api.cqg.com 2026-04-20 12:52:18.209 | CQG WebSocket | Connecting to WebSocket server api.cqg.com:443 2026-04-20 12:52:18.559 | CQG WebSocket socket (4) | Creating socket. Using TLS 1.2. 2026-04-20 12:52:18.566 | CQG WebSocket socket (4) | New receive buffer size: 0 2026-04-20 12:52:18.566 | CQG WebSocket socket (4) | Connecting to IP: 195.166.124.175. 2026-04-20 12:52:18.648 | CQG WebSocket | Opening WebSocket. 2026-04-20 12:52:18.648 | CQG WebSocket | Sending WebSocket handshake. 2026-04-20 12:52:18.694 | CQG WebSocket | Server header | HTTP/1.1 101 Switching Protocols 2026-04-20 12:52:18.694 | CQG WebSocket | Server header | Connection: Upgrade 2026-04-20 12:52:18.694 | CQG WebSocket | Server header | Sec-WebSocket-Accept: 3l9hTQWw9OaLspvZ3VMJ7XesZaQ= 2026-04-20 12:52:18.694 | CQG WebSocket | Server header | Server: WebSocket++/0.8.2 2026-04-20 12:52:18.694 | CQG WebSocket | Server header | Upgrade: websocket 2026-04-20 12:52:18.694 | CQG WebSocket | Server header | 2026-04-20 12:52:18.694 | CQG WebSocket | Web socket state is now open. 2026-04-20 12:52:18.694 | CQG WebAPI | WebSocket connected. 2026-04-20 12:52:18.694 | CQG WebAPI | Sending market data logon message. 2026-04-20 12:52:18.950 | CQG WebAPI | Base Time: 2026-03-28T06:49:02. 2026-03-28 06:49:02 2026-04-20 12:52:18.950 | CQG WebAPI | Logon successful. Session Token = BA9V4OdN13e3HWuVScCUgVN/50syFTwxHV/fqhzK/oYa3J2fLJrX1TuIY9dCPQ1HVDcYMwQgm0c 2026-04-20 12:52:18.950 | CQG WebAPI | Connection to server complete. 2026-04-20 12:52:18.962 | No download requests in the queue to start downloads for. | Number times message added: 3 2026-04-20 12:52:18.966 | Updated verified funded futures trading account ending date to: 2026-05-20 16:52:18 2026-04-20 12:52:18.967 | CQG WebAPI | Sending Trade Accounts request message. 2026-04-20 12:52:19.129 | CQG WebAPI | Brokerage name: AMP. Account Name: 220033 2026-04-20 12:52:19.129 | Updated verified funded futures trading account ending date to: 2026-05-20 16:52:19 2026-04-20 12:52:19.129 | CQG WebAPI | Sending collateral subscribe request. 2026-04-20 12:52:19.213 | CQG WebAPI | Sending positions subscribe request. RequestID: 431694 2026-04-20 12:52:19.214 | CQG WebAPI | Sending orders subscribe request. RequestID: 431695 2026-04-20 12:52:28.117 | CQG WebSocket socket (1) | Write has completed. Shutdown being performed. 2026-04-20 12:52:28.117 | CQG WebSocket socket (1) | Shutdown started. Waiting for graceful close. 2026-04-20 12:52:28.118 | CQG WebSocket socket (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. * 2026-04-20 12:52:28.118 | CQG WebSocket socket (1) | Socket gracefully closed by remote side. 2026-04-20 12:52:28.118 | CQG WebSocket socket (1) | Closed. 2026-04-20 20:13:28.721 | The data feed was lost. There was no activity for at least 60.0 seconds. 2026-04-20 20:13:28.722 | Connection to the external service has been lost. 2026-04-20 20:13:28.724 | CQG WebSocket | Timeout waiting for pong message from server. 2026-04-20 20:13:28.724 | CQG WebAPI | WebSocket closed. 2026-04-20 20:13:28.747 | CQG WebAPI | Sending Web API Logoff message. 2026-04-20 20:13:28.747 | CQG WebSocket socket (4) | CloseSocket call. 2026-04-20 20:13:28.747 | CQG WebSocket | WebSocket closed. 2026-04-20 20:13:28.747 | CQG WebAPI | WebSocket closed. 2026-04-20 20:13:28.750 | CQG WebAPI | Disconnected. 2026-04-20 20:13:28.751 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-04-20 20:13:28.805 | CQG WebSocket socket (4) | Write in progress. Shutdown being delayed. PendingSize=0 2026-04-20 20:13:30.750 | 2026-04-20 20:13:30.751 | CQG WebAPI | Connecting to server api.cqg.com 2026-04-20 20:13:30.751 | CQG WebSocket | Connecting to WebSocket server api.cqg.com:443 2026-04-20 20:13:31.077 | CQG WebSocket socket (3) | Creating socket. Using TLS 1.2. 2026-04-20 20:13:31.077 | CQG WebSocket socket (3) | New receive buffer size: 0 2026-04-20 20:13:31.077 | CQG WebSocket socket (3) | Connecting to IP: 195.166.124.175. 2026-04-20 20:13:31.086 | CQG WebSocket | Opening WebSocket. 2026-04-20 20:13:31.086 | CQG WebSocket | Sending WebSocket handshake. 2026-04-20 20:13:31.382 | CQG WebSocket | Server header | HTTP/1.1 101 Switching Protocols 2026-04-20 20:13:31.382 | CQG WebSocket | Server header | Connection: Upgrade 2026-04-20 20:13:31.382 | CQG WebSocket | Server header | Sec-WebSocket-Accept: GM4iksfCdutn1eGYMmHd0lstR44= 2026-04-20 20:13:31.382 | CQG WebSocket | Server header | Server: WebSocket++/0.8.2 2026-04-20 20:13:31.382 | CQG WebSocket | Server header | Upgrade: websocket 2026-04-20 20:13:31.382 | CQG WebSocket | Server header | 2026-04-20 20:13:31.382 | CQG WebSocket | Web socket state is now open. 2026-04-20 20:13:31.382 | CQG WebAPI | WebSocket connected. 2026-04-20 20:13:31.384 | CQG WebAPI | Sending market data logon message. 2026-04-20 20:13:31.681 | CQG WebAPI | Base Time: 2026-03-28T18:10:42. 2026-03-28 18:10:42 2026-04-20 20:13:31.681 | CQG WebAPI | Logon successful. Session Token = nBXxd4PhXLVOUvhBjlX2MFLuyLUHcxbxQFyZ9kxTWpwCmp3Cf4bWjgqwE22db6T1fpTaxpf1W7e 2026-04-20 20:13:31.681 | CQG WebAPI | Connection to server complete. 2026-04-20 20:13:31.689 | No download requests in the queue to start downloads for. | Number times message added: 3 2026-04-20 20:13:31.690 | Updated verified funded futures trading account ending date to: 2026-05-21 00:13:31 2026-04-20 20:13:31.690 | CQG WebAPI | Sending Trade Accounts request message. 2026-04-20 20:13:31.801 | CQG WebAPI | Brokerage name: AMP. Account Name: 220033 2026-04-20 20:13:31.801 | Updated verified funded futures trading account ending date to: 2026-05-21 00:13:31 2026-04-20 20:13:31.801 | CQG WebAPI | Sending collateral subscribe request. 2026-04-20 20:13:31.941 | CQG WebAPI | Sending positions subscribe request. RequestID: 431698 2026-04-20 20:13:31.941 | CQG WebAPI | Sending orders subscribe request. RequestID: 431699 2026-04-20 20:13:47.978 | CQG WebSocket socket (4) | Write has completed. Shutdown being performed. 2026-04-20 20:13:47.978 | CQG WebSocket socket (4) | Shutdown started. Waiting for graceful close. 2026-04-20 20:13:47.978 | CQG WebSocket socket (4) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. * 2026-04-20 20:13:47.978 | CQG WebSocket socket (4) | Socket gracefully closed by remote side. 2026-04-20 20:13:47.979 | CQG WebSocket socket (4) | Closed. 2026-04-20 20:13:51.806 | ExtendTheFundedTradingAccountStatusExpirationDate: Sending request. 2026-04-20 20:13:52.242 | ExtendTheFundedTradingAccountStatusExpirationDate | Result: {"Result":"The Funded Trading Account Status Expiration Date is more than 25 days into the future. The Date is currently: 2026-05-18"}. Success=true 2026-04-20 22:28:29.147 | The data feed was lost. There was no activity for at least 60.0 seconds. 2026-04-20 22:28:29.148 | Connection to the external service has been lost. 2026-04-20 22:28:29.152 | CQG WebSocket | Timeout waiting for pong message from server. 2026-04-20 22:28:29.152 | CQG WebAPI | WebSocket closed. 2026-04-20 22:28:29.175 | CQG WebAPI | Sending Web API Logoff message. 2026-04-20 22:28:29.175 | CQG WebSocket socket (3) | CloseSocket call. 2026-04-20 22:28:29.175 | CQG WebSocket | WebSocket closed. 2026-04-20 22:28:29.175 | CQG WebAPI | WebSocket closed. 2026-04-20 22:28:29.178 | CQG WebAPI | Disconnected. 2026-04-20 22:28:29.178 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-04-20 22:28:29.188 | CQG WebSocket socket (3) | Write in progress. Shutdown being delayed. PendingSize=0 2026-04-20 22:28:31.188 | 2026-04-20 22:28:31.189 | CQG WebAPI | Connecting to server api.cqg.com 2026-04-20 22:28:31.189 | CQG WebSocket | Connecting to WebSocket server api.cqg.com:443 2026-04-20 22:28:31.465 | CQG WebSocket socket (1) | Creating socket. Using TLS 1.2. 2026-04-20 22:28:31.465 | CQG WebSocket socket (1) | New receive buffer size: 0 2026-04-20 22:28:31.465 | CQG WebSocket socket (1) | Connecting to IP: 195.166.124.175. 2026-04-20 22:28:31.471 | CQG WebSocket | Opening WebSocket. 2026-04-20 22:28:31.471 | CQG WebSocket | Sending WebSocket handshake. 2026-04-20 22:28:31.497 | CQG WebSocket | Server header | HTTP/1.1 101 Switching Protocols 2026-04-20 22:28:31.497 | CQG WebSocket | Server header | Connection: Upgrade 2026-04-20 22:28:31.497 | CQG WebSocket | Server header | Sec-WebSocket-Accept: sUdn7m4jqtqvACSG7wirrwMaeX8= 2026-04-20 22:28:31.497 | CQG WebSocket | Server header | Server: WebSocket++/0.8.2 2026-04-20 22:28:31.497 | CQG WebSocket | Server header | Upgrade: websocket 2026-04-20 22:28:31.497 | CQG WebSocket | Server header | 2026-04-20 22:28:31.497 | CQG WebSocket | Web socket state is now open. 2026-04-20 22:28:31.497 | CQG WebAPI | WebSocket connected. 2026-04-20 22:28:31.497 | CQG WebAPI | Sending market data logon message. 2026-04-20 22:28:31.744 | CQG WebAPI | Base Time: 2026-03-28T18:10:39. 2026-03-28 18:10:39 2026-04-20 22:28:31.744 | CQG WebAPI | Logon successful. Session Token = PyxNgYL34awyytbMDgKmTugYeARRqQofjXgEVU+x4toDEpLT0XOHnvPz9xPSG1ndM1CpLhuz9jn 2026-04-20 22:28:31.744 | CQG WebAPI | Connection to server complete. 2026-04-20 22:28:31.753 | No download requests in the queue to start downloads for. | Number times message added: 3 2026-04-20 22:28:31.754 | Updated verified funded futures trading account ending date to: 2026-05-21 02:28:31 2026-04-20 22:28:31.754 | CQG WebAPI | Sending Trade Accounts request message. 2026-04-20 22:28:31.881 | CQG WebAPI | Brokerage name: AMP. Account Name: 220033 2026-04-20 22:28:31.881 | Updated verified funded futures trading account ending date to: 2026-05-21 02:28:31 2026-04-20 22:28:31.881 | CQG WebAPI | Sending collateral subscribe request. 2026-04-20 22:28:31.999 | CQG WebAPI | Sending positions subscribe request. RequestID: 431702 2026-04-20 22:28:31.999 | CQG WebAPI | Sending orders subscribe request. RequestID: 431703 2026-04-21 03:04:04.122 | The data feed was lost. There was no activity for at least 60.0 seconds. 2026-04-21 03:04:04.122 | Connection to the external service has been lost. 2026-04-21 03:04:04.124 | CQG WebSocket | Timeout waiting for pong message from server. 2026-04-21 03:04:04.124 | CQG WebAPI | WebSocket closed. 2026-04-21 03:04:04.132 | CQG WebAPI | Sending Web API Logoff message. 2026-04-21 03:04:04.132 | CQG WebSocket socket (1) | CloseSocket call. 2026-04-21 03:04:04.132 | CQG WebSocket | WebSocket closed. 2026-04-21 03:04:04.132 | CQG WebAPI | WebSocket closed. 2026-04-21 03:04:04.132 | CQG WebAPI | Disconnected. 2026-04-21 03:04:04.132 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-04-21 03:04:04.285 | CQG WebSocket socket (3) | Write has completed. Shutdown being performed. 2026-04-21 03:04:04.285 | CQG WebSocket socket (3) | Shutdown started. Waiting for graceful close. 2026-04-21 03:04:04.285 | CQG WebSocket socket (3) | Socket gracefully closed by remote side. 2026-04-21 03:04:04.285 | CQG WebSocket socket (3) | Closed. 2026-04-21 03:04:04.291 | CQG WebSocket socket (1) | Write in progress. Shutdown being delayed. PendingSize=0 2026-04-21 03:04:06.134 | 2026-04-21 03:04:06.134 | CQG WebAPI | Connecting to server api.cqg.com 2026-04-21 03:04:06.134 | CQG WebSocket | Connecting to WebSocket server api.cqg.com:443 2026-04-21 03:04:06.284 | CQG WebSocket socket (2) | Creating socket. Using TLS 1.2. 2026-04-21 03:04:06.285 | CQG WebSocket socket (2) | New receive buffer size: 0 2026-04-21 03:04:06.285 | CQG WebSocket socket (2) | Connecting to IP: 195.166.124.175. 2026-04-21 03:04:06.295 | CQG WebSocket | Opening WebSocket. 2026-04-21 03:04:06.295 | CQG WebSocket | Sending WebSocket handshake. 2026-04-21 03:04:06.319 | CQG WebSocket | Server header | HTTP/1.1 101 Switching Protocols 2026-04-21 03:04:06.319 | CQG WebSocket | Server header | Connection: Upgrade 2026-04-21 03:04:06.319 | CQG WebSocket | Server header | Sec-WebSocket-Accept: kGktJBxPN3EeLirWINevAKE67p8= 2026-04-21 03:04:06.319 | CQG WebSocket | Server header | Server: WebSocket++/0.8.2 2026-04-21 03:04:06.319 | CQG WebSocket | Server header | Upgrade: websocket 2026-04-21 03:04:06.319 | CQG WebSocket | Server header | 2026-04-21 03:04:06.319 | CQG WebSocket | Web socket state is now open. 2026-04-21 03:04:06.319 | CQG WebAPI | WebSocket connected. 2026-04-21 03:04:06.319 | CQG WebAPI | Sending market data logon message. 2026-04-21 03:04:06.565 | CQG WebAPI | Base Time: 2026-03-28T18:10:39. 2026-03-28 18:10:39 2026-04-21 03:04:06.565 | CQG WebAPI | Logon successful. Session Token = wK2l1Wa286p9nQpLEFWOzyjk2KeQRXSwDO2ZCv8KYpwi9tLpchHjCpyp4FR40GgO4PYQCORL+ec 2026-04-21 03:04:06.565 | CQG WebAPI | Connection to server complete. 2026-04-21 03:04:06.567 | No download requests in the queue to start downloads for. | Number times message added: 3 2026-04-21 03:04:06.567 | Updated verified funded futures trading account ending date to: 2026-05-21 07:04:06 2026-04-21 03:04:06.567 | CQG WebAPI | Sending Trade Accounts request message. 2026-04-21 03:04:06.710 | CQG WebAPI | Brokerage name: AMP. Account Name: 220033 2026-04-21 03:04:06.710 | Updated verified funded futures trading account ending date to: 2026-05-21 07:04:06 2026-04-21 03:04:06.710 | CQG WebAPI | Sending collateral subscribe request. 2026-04-21 03:04:06.831 | CQG WebAPI | Sending positions subscribe request. RequestID: 431706 2026-04-21 03:04:06.831 | CQG WebAPI | Sending orders subscribe request. RequestID: 431707 2026-04-21 03:04:58.087 | CQG WebSocket socket (1) | Write has completed. Shutdown being performed. 2026-04-21 03:04:58.088 | CQG WebSocket socket (1) | Shutdown started. Waiting for graceful close. 2026-04-21 03:04:58.088 | CQG WebSocket socket (1) | Socket gracefully closed by remote side. 2026-04-21 03:04:58.088 | CQG WebSocket socket (1) | Closed. 2026-04-21 09:57:59.391 | F.US.EPM26 #1 | Reloading chart. 2026-04-21 09:57:59.394 | F.US.EPM26 #1 | StartDateTimeForLoadingOrderFills: 2025-04-14 00:00:00 2026-04-21 09:57:59.426 | F.US.EPM26 #1 | Chart data loading complete. 2026-04-21 09:57:59.782 | Mapping F.US.EPM26 to ESM26. Service code: cme 2026-04-21 09:57:59.782 | Using symbol data fast lookup vector 2026-04-21 09:57:59.783 | Denali Data Feed | Starting real-time market data updates for: F.US.EPM26 (ESM26). ID: 1 Service code: cme 2026-04-21 09:57:59.784 | Denali Data Feed | Connecting to the server ds7.sierracharts.com. Port 10048 2026-04-21 09:57:59.785 | CQG WebAPI | Sending symbol resolution request for F.US.EPM26. ID: 431708 2026-04-21 09:57:59.785 | Denali Data Feed | Requesting security definition data for: F.US.EPM26 (ESM26). ID: 1 2026-04-21 09:57:59.786 | Added historical Intraday data request for F.US.EPM26 to the queue. 2026-04-21 09:57:59.786 | Intraday data recording state for symbol F.US.EPM26 is set to download 'Pending'. 2026-04-21 09:57:59.786 | Triggering next historical data download in queue. 2026-04-21 09:57:59.788 | Delaying start of download for F.US.EPM26. 2026-04-21 09:57:59.791 | CQG WebAPI | Received symbol resolution report for symbol F.US.EPM26. Search Symbol: F.US.EPM26. Request ID: 431708. Contract ID: 1. 2026-04-21 09:57:59.798 | DTC Client socket (1) | Creating socket. 2026-04-21 09:57:59.799 | DTC Client socket (1) | New receive buffer size: 0 2026-04-21 09:57:59.799 | DTC Client socket (1) | Connecting to IP: 69.39.70.253. 2026-04-21 09:57:59.893 | Denali Data Feed | Network connection to server complete. 2026-04-21 09:57:59.893 | Denali Data Feed | Starting socket receive thread. 2026-04-21 09:57:59.893 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard 2026-04-21 09:58:00.005 | Denali Data Feed | Setting DTC encoding to Binary VLS 2026-04-21 09:58:00.005 | Denali Data Feed | Sending logon request message. 2026-04-21 09:58:00.536 | Denali Data Feed | Received logon response. 2026-04-21 09:58:00.536 | Denali Data Feed | Server Name: SC Realtime Server. 2026-04-21 09:58:00.536 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8 2026-04-21 09:58:00.536 | Denali Data Feed | Successfully connected. 2026-04-21 09:58:00.536 | Denali Data Feed | Trading is not supported. 2026-04-21 09:58:00.536 | Denali Data Feed | MarketDepthIsSupported: 1 2026-04-21 09:58:00.536 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.EPM26 -> ESM26 2026-04-21 09:58:00.722 | Denali Data Feed | Setting external service identifier for symbol F.US.EPM26 to 42140864 2026-04-21 09:58:00.722 | Denali Data Feed | Received security definition for symbol F.US.EPM26 2026-04-21 09:58:03.372 | Requesting market depth updates for: F.US.EPM26 if supported. NumLevels=100 2026-04-21 09:58:03.536 | Denali Data Feed | Clearing market depth for F.US.EPM26 2026-04-21 09:58:05.486 | HD Request # 88 | Downloading Intraday chart data for F.US.EPM26 to the file F.US.EPM26.scid. Service: cme 2026-04-21 09:58:05.487 | HD Request # 88 | Download start date-time: 2026-04-17 16:59:58.000000. File last date-time: 2026-04-17 16:59:58.639000 2026-04-21 09:58:05.488 | HD Request # 88 | Using server: ds26.sierracharts.com port 10150 2026-04-21 09:58:05.495 | Socket (3) | Creating socket. 2026-04-21 09:58:05.495 | Socket (3) | New receive buffer size: 0 2026-04-21 09:58:05.495 | Socket (3) | Connecting to IP: 64.152.155.17. 2026-04-21 09:58:05.676 | HD Request # 88 | Setting DTC encoding to Binary VLS 2026-04-21 09:58:05.676 | HD Request # 88 | Sending historical data logon request message. 2026-04-21 09:58:05.794 | HD Request # 88 | Requesting Intraday data. Start date-time: 2026-04-17 16:59:58. Record interval: 0. Symbol: ESM26 2026-04-21 09:58:05.882 | HD Request # 88 | Decompressing data. 2026-04-21 09:58:05.984 | HD Request # 88 | Receiving Intraday data for F.US.EPM26 starting at 2026-04-17 16:59:58.315000 2026-04-21 09:58:06.425 | HD Request # 88 | Timestamp of first Intraday data file record written: 2026-04-19 18:00:00.000000. 2026-04-21 09:58:08.379 | Unsubscribed from market depth data for F.US.EPM26 2026-04-21 09:58:21.964 | Socket (3) | CloseSocket call. 2026-04-21 09:58:21.965 | Socket (3) | Shutdown started. Waiting for graceful close. 2026-04-21 09:58:21.966 | Historical data download thread signaled to stop. 2026-04-21 09:58:21.967 | HD Request # 88 | Received 1157259 Intraday data records from 2026-04-17 16:59:58.315000 to 2026-04-21 09:58:20.777004 (3.7 days. Delay: 1.2 seconds) and wrote 1157256 records for F.US.EPM26 2026-04-21 09:58:21.991 | HD Request # 88 | Add time&sales data | Remembered last file record date-time: 2026-04-21 13:58:20.777004 2026-04-21 09:58:21.991 | Added 54 Time and Sales records to Intraday data file for F.US.EPM26 after download. 2026-04-21 09:58:21.992 | HD Request # 88 | Completion time: 16s. 2026-04-21 09:58:21.992 | HD Request # 88 | Intraday data download complete for F.US.EPM26. Unique request ID: 88 2026-04-21 09:58:21.992 | Removing historical data download ID 88. 2026-04-21 09:58:21.992 | Real-time Intraday chart data file updates started for F.US.EPM26 2026-04-21 09:58:21.992 | Intraday chart data file opened for F.US.EPM26 2026-04-21 09:58:21.992 | HD Request # 88 | Enabling Intraday chart updating for symbol. 2026-04-21 09:58:21.992 | 2026-04-21 09:58:21.992 | No download requests in the queue to start downloads for. 2026-04-21 09:58:22.052 | Socket (3) | Socket gracefully closed by remote side. 2026-04-21 09:58:22.052 | Socket (3) | Closed. 2026-04-21 09:58:26.601 | Opened cached Intraday file: C:\SierraChart\Data\F.US.EPM26.scid. Thread ID: 16976 |
| [2026-04-21 19:43:41] |
| John - SC Support - Posts: 48342 |
You have the following showing up throughout your log: CQG WebSocket socket (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. *
So you are having a connectivity issue. Refer to the following: Data/Trading Service Connection and Symbol Issues: 1.2. Network Communication or Server Problem -- Also, early on in your log there are references to incorrect symbols - such as "6BU25-CME". We are not certain if you later change those symbols or not. If you did not, then you would need to have the correct symbols in order to get data. With the chartbooks open, select "Edit >> Translate Symbols to Current Service" to update the symbols to the current selected service (CQG in your case). For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
