Date/Time: Thu, 26 Nov 2026 04:01:29 +0000
Large Volume Trade Study
View Count: 651
| [2026-04-07 14:22:33] |
| VenoYoTiK - Posts: 30 |
Hello, the large volumee trade study does not show in my chart window. It doesn`t matter if I have the standard settings, a completely empty chart or the settings with the chart you see in the screenshots. It just doesn't show anything.
| [2026-04-07 17:02:08] |
We are not sure which chart you are trying to add this to, so keep in mind that the Large Volume Trade Indicator will not work with a TPO chart. Refer to the following: Time Price Opportunity (TPO) Profile Charts: Using Other Studies on a TPO Chart If not the above, then the next possible issue is that you need to have your data stored at 1 tick increments in order for the study to work. Refer to the fifth paragraph (highlighted in green) at the following link: Large Volume Trade Indicator: Description For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-04-07 17:20:46] |
Hello, I want to add it to the the Right upper Chart. The M1. And there I have everything as I know on 1 Tick. |
| [2026-04-07 17:39:30] |
Please be sure to check the setting for "Global Settings >> Data/Trade Service Settings >> Common Settings >> Intraday Data Storage Time Unit" is set to "1 Tick". Refer to the following: Data/Trade Service Settings: Intraday Data Storage Time Unit (Global Settings >> Data/Trade Service Settings >> Common Settings >> Common Settings) If that is set to 1 tick, then change the "Volume Threshold" for the "Large Volume Trade Indicator" to be "1". This will guarantee that you should have some markers showing. Let us know if you still do not have anything. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-04-08 07:56:38] |
Perfect that has helped. Thank You very much!
