Date/Time: Thu, 26 Nov 2026 04:01:33 +0000
Footprint POC EXT wont turn off
View Count: 351
[2026-04-01 14:28:35]
Jaydtrade - Posts: 125
I cannot get these lines to turn off no idea why. I have the setting set to ignore see screenshot below. Any help thanks
imageFootprint off.jpg / V - Attached On 2026-04-01 14:28:16 UTC - Size: 253.4 KB - 214 views
[2026-04-01 14:46:30]
Also Heikin Ashi Smoothed, I cannot hide the wicks on the candles, its literally locked I hit ignore and it does not flip, is there a way to fix this?
[2026-04-01 17:18:04]
The drawing of the POC Extension Lines is controlled by the Numbers Bars Input for "Highlight Point of Control In". Refer to the following:
Numbers Bars: Highlight Point Of Control In
The Subgraph is just to define the colors and width of that line.
[2026-04-06 15:53:48]
And what about the heikin ashi smoothed candle wicks? Is there a fix for hiding those? ignore doesnt work it auto forces visibility in the subgraph settings.
[2026-04-06 16:29:09]
For the Heikin-Ashi Smoothed study, you change the type of bar style by selecting the appropriate option in the setting for "Graph Draw Type" at the top of the "Subgraphs" tab for that study. Refer to the following:
Chart Studies: Subgraphs Tab >> Graph Draw Type
[2026-04-07 00:26:06]
Oh awesome thank you!
