Date/Time: Tue, 13 Oct 2026 16:40:07 +0000
I connect the account and server correctly but my is not showing on trade account monitor
View Count: 392
[2026-03-29 21:02:39]
User561643 - Posts: 1
2026-03-29 20:56:09.901 | Trade activity files set size: 1
2026-03-29 20:56:09.911 | Rithmic Direct - DTC | Processed connection points. Count: 474
2026-03-29 20:56:09.960 | Reading Internal Order ID file.
2026-03-29 20:56:09.961 | Reading Trade Orders file.
2026-03-29 20:56:09.961 | Reading Trade Positions file.
2026-03-29 20:56:09.962 | Reading Trade Account Data files.
2026-03-29 20:56:09.963 | Software version: 2891 64-bit
2026-03-29 20:56:09.963 | Primary Thread ID: 10296
2026-03-29 20:56:09.963 | Usage end date: 2026-04-18
2026-03-29 20:56:09.963 | Enabled for: Advanced Features 2.
2026-03-29 20:56:09.963 | Enabled for: Sierra Chart Historical Data Service.
2026-03-29 20:56:09.963 | Enabled for: Denali Real-Time Exchange Data Feed.
2026-03-29 20:56:09.963 | Enabled for: Delayed Denali Exchange Data Feed.
2026-03-29 20:56:09.963 | Allow Support for Sierra Chart Data Feeds is enabled.
2026-03-29 20:56:09.963 | Current selected Data/Trading service: Rithmic Direct - DTC
2026-03-29 20:56:09.963 | Custom symbol settings values: enabled
2026-03-29 20:56:09.963 | Chart Update Interval: 400
2026-03-29 20:56:09.963 | Intraday Data Storage Time Unit: 0
2026-03-29 20:56:09.963 | Time Zone: +00:00:00 (UTC+00)
2026-03-29 20:56:09.963 | 2026-03-29 20:56:09 Local computer time in UTC
2026-03-29 20:56:09.963 | 2026-03-29 20:56:09 Local computer time in SC Time Zone
2026-03-29 20:56:09.963 | 2026-03-29 20:56:04 Server time in UTC
2026-03-29 20:56:09.963 | Local computer UTC time and Server UTC time difference: 5 seconds.
2026-03-29 20:56:09.963 | Notice: Your computer's clock is off by 5 seconds. Set the 'Global Settings >> NTP Settings >> NTP Client Enable' to 'Yes'.
2026-03-29 20:56:09.963 | Program path: C:\SierraChart\
2026-03-29 20:56:09.964 | Data Files path: C:\SierraChart\Data\
2026-03-29 20:56:09.964 | OS Version Number: 10.0
2026-03-29 20:56:09.964 | Locale Setting: C
2026-03-29 20:56:09.964 | Crash reporter started: true
2026-03-29 20:56:09.992 | Checking for new symbol settings. Requested symbol settings MD5 for service code rithmic_v2.trading. Request ID: 1.
2026-03-29 20:56:09.994 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close.
2026-03-29 20:56:10.107 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (4) | Creating socket. Using TLS 1.2.
2026-03-29 20:56:10.107 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (4) | New receive buffer size: 0
2026-03-29 20:56:10.107 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (4) | Connecting to IP: 216.66.0.130.
2026-03-29 20:56:10.151 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side.
2026-03-29 20:56:10.151 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed.
2026-03-29 20:56:10.551 | Received 5 login tokens.
2026-03-29 20:56:10.991 | Symbol settings MD5 received. Request ID: 1.
2026-03-29 20:56:10.991 | Symbol settings are up-to-date for rithmic_v2.trading.
2026-03-29 20:56:11.638 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\RithmicConnections.json. Size: 110576
2026-03-29 20:56:11.640 | Rithmic Direct - DTC | Processed connection points. Count: 474
2026-03-29 20:56:11.897 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (4) | CloseSocket call.
2026-03-29 20:56:11.897 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (4) | Shutdown started. Waiting for graceful close.
2026-03-29 20:56:12.074 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (4) | Socket gracefully closed by remote side.
2026-03-29 20:56:12.074 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (4) | Closed.
2026-03-29 20:56:12.505 | Requested user files to download.
2026-03-29 20:56:14.516 | Connect to Data Feed | Service Package does not support this function or account is expired. Select 'Help >> Account Control Panel' for account management. *
2026-03-29 20:56:17.741 | Files to Open on Startup | Opening file: ExampleChartbook.cht
2026-03-29 20:56:17.785 | MNQM6.CME 1 Min #1 | Reloading chart.
2026-03-29 20:56:17.799 | MNQM6.CME 1 Min #1 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\MNQM6.CME.scid
2026-03-29 20:56:17.804 | MNQM6.CME 1 Min #1 | Chart data loading complete.
2026-03-29 20:56:18.202 | Using symbol data fast lookup vector
2026-03-29 20:56:18.202 | Symbol not allowed: MNQM6.CME *
[2026-03-29 22:03:55]
Sierra_Chart Engineering - Posts: 25163
You are not able to connect to Rithmic from a Sierra Chart trial account.
You can use the Trading Evaluator-Delayed service:
Simulated Futures Trading Service
Or just use the Delayed Exchange Data Feed:
Date Time Of Last Edit: 2026-03-29 22:38:29
[2026-03-30 13:01:17]
John - SC Support - Posts: 48189
If you want to change to a paid package in which you can connect to Rithmic, then you can do so by following these instructions:
Sierra Chart Purchase and License Information: Instructions
Note that in order to be able to connect to trading/data services, you need to be on one of the "Integrated" packages. The information for the packages is at the following link:
Description of Service Packages and Pricing
