Date/Time: Thu, 26 Nov 2026 03:53:27 +0000
Tool Config vs. Tool Properties Window
View Count: 345
| [2026-03-26 08:49:53] |
| Daniel - Backtesting.club - Posts: 177 |
The day before yesterday, I was creating a preset (config) for the Ray tool and couldn’t figure out how to save it so that it would save the text (line description) along with the line thickness and color. So I asked Grok to find out how to do this in Sierra Chart. He revealed to me that, in addition to the Tool Properties window (Ray Properties), there is also a Tool Config (Ray Config) window, where the option "Copy Tool Config Name To Text" is located. Given these facts, I have three questions. 1. Why can’t the text be saved as a preset along with the other settings (color, line thickness, etc.)? 2. Why are there two windows in Sierra Chart (Tool Config and Tool Properties) that contain almost identical settings? If I can set, save, or modify a preset in Ray Properties, what is the Ray Config window for? I placed these windows side by side (see screenshot), and the only differences are the Anchors tab and the Extend Left, Extend Right, and Copy Tool Config Name To Text settings. Nothing else. I don’t really see a reason for the separate Tool Config window to exist. 3. Why is the Copy Tool Config Name To Text setting hidden in Tool Config and not also in Tool Properties, where it would make sense? Thank you. Date Time Of Last Edit: 2026-03-26 08:55:24
| [2026-03-26 15:38:51] |
1. The way to do this is to use the "Tool Config Name" as the text to be used. Then set "Copy Tool Config Name to Text" to "Yes". It's not really any different from assigning a specific text to a configuration. 2. The Configuration is for what will be used when the drawing is initially drawn. As such, there are a few items that only apply in that state and do not apply to the "Properties" window. The "Copy Tool Config Name to Text" is a good example. Also, there are 24 configurations that you can setup for each tool. There is only a single "Properties" window for the specific drawing that you are modifying at that moment. 3. Although it could be part of the "Properties" window, it is not the way we programmed it, and not how we think about that particular item. That is something that is setup up front, when you want a specific text for a drawing and you know this before you draw it. Once you have the drawing done, then you can add whatever text you want to it. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
