Date/Time: Thu, 26 Nov 2026 03:41:35 +0000
Study that tracks a condition or alert from another study
View Count: 355
| [2026-03-24 09:32:06] |
| User436410 - Posts: 5 |
Hi I am looking for a study/way to track the sign of another study (also from a study from another chart) and plot it under/over my candles. Does this exist in some way? Does this make sense? thx |
| [2026-03-24 15:31:53] |
This can be done, the general idea is to use the "Study/Price Overlay" to get the information from the other chart into the chart you want and then use the "Study Subgraph Above/Below Bar as Text". Refer to the following: Study/Price Overlay Study Study Subgraph Above/Below Bar as Text If you are just wanting to know the Positive/Negative value of that study, then you can use a "Spreadsheet Formula" with a formula like the following and then display that result instead: =IF(ID1.SG1 > 0, 1, -1) Where ID1 is the ID of the study you want to test and SG1 is the subgraph to be tested. Refer to the following: Spreadsheet Formula Study/Chart Alerts And Scanning https://www.sierrachart.com/index.php?page=doc/SpreadsheetFunctions.html#IF_Function For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
