Date/Time: Thu, 26 Nov 2026 03:41:36 +0000
Crude Crack Spreads for Quote Board
View Count: 666
| [2026-03-22 15:03:06] |
| User417302 - Posts: 71 |
I want to create both a 3:2:1 & 5:3:2 crude crack spreads to display on a quote board. I don't want to chart it out, I only want to see the quotes. How would I go about creating this so that it will display on a quote board? Thanks, |
| [2026-03-22 16:43:23] |
| User584084 - Posts: 348 |
1) Global Settings >> Symbol Settings 2) Check the 'Use Custom Symbol Settings Values' box above the Symbols list. 3) Click 'New' for a new custom symbol: Enter the following symbol for the 3:2:1 Crack Spread: (84*{RB-202605-NYMEX}+42*{HO-202605-NYMEX}-3*{CL-202605-NYMEX})/3. The symbols shown are for Interactive Brokers. Substitute the symbols you use for 'Denali' or other data feeds. 5:3:2 Crack Spread Symbol: (126*{RB-202605-NYMEX}+84*{HO-202605-NYMEX}-5*{CL-202605-NYMEX})/5 Formulas Used: 3:2:1 Crack Spread: (2 RB (2*42) + 1 HO (1*42) - 3 CL)/3 5:3:2 Crack Spread: (3 RB (3*42) + 2 HO (2*42) - 5 CL)/5 Note: RB contract: 42000 Gallons, HO contract: 42000 Gallons, CL Contract: 1000 Barrels. 4) Make sure the 'Use Formula Operators' field is set to 'yes' under settings. Date Time Of Last Edit: 2026-03-22 16:52:17
| [2026-03-23 17:00:50] |
What User584084 states is the way to get the spreads you are wanting. Just keep in mind that since these are not exchange traded spreads, you will not have all the Quote Board information for the symbol.
| [2026-03-24 15:44:04] |
| Sierra_Chart Engineering - Posts: 25489 |
You could use Custom Calculated Symbols: Custom Calculated Symbols Or you could also use the exchange traded spreads: Denali Exchange Data Feed: Denali Exchange Traded Spreads Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
