Date/Time: Thu, 26 Nov 2026 03:53:32 +0000
Multi Time Frame Display
View Count: 970
[2026-03-29 23:05:04]
Sierra_Chart Engineering - Posts: 25489
You are able to change the Draw Styles to Transparent Fill Rectangle Top/Bottom.
[2026-03-29 23:12:52]
User643802 - Posts: 26
I’m so confused. Can I or can I not? And how?
[2026-03-30 18:26:52]
Sorry - just one of those things that we forget about once in awhile.
This does work, but you need to set the Input for "Use Styles and Widths from Source Study" to "No" first. Then you can change the subgraphs as you want.
Study/Price Overlay Study: Use Styles and Widths from Source Study
Again, our apologies for the confusion.
[2026-03-30 18:50:17]
Just to confirm. You are saying what I can do is to make it display the wick like tradingview? As I tried but nothing changed and settings still get ignored
[2026-03-31 14:00:20]
To get exactly what you are wanting, you would need to add another study - the "Study Subgraph Reference", and use this to highlight the Open to Close, while the Study/Price Overlay highlights the High to Low.
Attached is a Study Collection that does this. Refer to the following for how to use a Study Collection provided by Sierra Chart:
Study Collections: Using a Study Collection Provided by Sierra Chart Support
attachmentMultiColumnRectangleWithWick.StdyCollct - Attached On 2026-03-31 14:00:17 UTC - Size: 32.9 KB - 164 views
