Date/Time: Thu, 26 Nov 2026 03:31:17 +0000
unable to connect, error message 10060
View Count: 505
[2026-03-06 14:48:21]
greenugly - Posts: 25
please advise, thanks
[2026-03-06 15:35:12]
Refer to the following:
Data/Trading Service Connection and Symbol Issues: 1.2. Network Communication or Server Problem
[2026-03-07 18:11:29]
hi have tried all the steps but still unable to connect
windows error code 10060
[2026-03-07 20:46:04]
Sierra_Chart Engineering - Posts: 25489
Select "File >> Disconnect"
Connect to the data feed:
Select "File >> Connect to Data Feed"
Date Time Of Last Edit: 2026-03-07 20:46:25
[2026-03-09 13:20:16]
hi have sent using the "sendForAnalysis" button. thanks
[2026-03-09 14:15:10]
2026-03-09 13:18:44.392 | Denali Data Feed | Connecting to the server ds40.sierracharts.com. Port 443
Change this setting:
Sierra Chart Server Settings: CME Exchange Data Feed Server Address and Port Override (Global Settings >> Sierra Chart Server Settings >> General >> Special)
To:
ds45.sierracharts.com
[2026-03-14 08:18:59]
The New Zealand server for CME data is now available again. It is running on a much better network now. Use this address:
However, considering your location we would recommend using the Tokyo Japan server (DS45).
Date Time Of Last Edit: 2026-03-14 08:19:49
