Date/Time: Sun, 01 Nov 2026 04:41:28 +0000
Recent Bid/Ask Volume Columns Go Blank When Tick Size Changed to 1.00
View Count: 1759
| [2026-03-05 20:42:49] |
| User386278 - Posts: 2 |
Hello, I’m seeing inconsistent behavior with the Recent Bid Volume / Recent Ask Volume columns in the Chart/Trade DOM across two Sierra Chart installs. Setup: • Denali Exchange Data Feed • Teton CME Routing (AMP) • Symbol: NQH26 In my main Sierra install, I can do the following and everything works normally: 1. Open a DOM for NQH26 2. Chart → Chart Settings → Symbol 3. Change Tick Size from 0.25 to 1.00 The ladder aggregates to 1.00 and the Recent Bid/Ask columns still populate normally (Screenshot: https://www.sierrachart.com/image.php?Image=1772743312283.png) However, in a second Sierra install: • With Tick Size = 0.25, Recent Bid/Ask works normally (Screenshot: https://www.sierrachart.com/image.php?Image=1772743101397.png) • When I change Tick Size = 1.00, the Recent Bid/Ask columns go completely blank, even though price and market depth are updating normally. (Screenshot: https://www.sierrachart.com/image.php?Image=1772743135908.png) I verified: • Same DOM settings (timeout, clear recent bid/ask, etc.) • Same Chart settings (Market Depth Combine Increments in Ticks = 1, Apply Combine Increments in Ticks to Other Market Data Columns = Yes) • Same symbol • Same data feed and routing • Even after deleting Sierra4.config and recreating the DOM manually, the issue remains in the second install. Is there any install-level setting or data state that would cause Recent Bid/Ask to stop displaying when Tick Size is changed to 1.00 in one install but not another? Thank you. |
| [2026-03-08 20:50:39] |
| Elvis.S - Posts: 15 |
Its after recent update to version 2888, its PreRelease so i assume its unstable currently. I made post regarding that Version 2888 - few bugs Havent got any response from team but im sure they fix it, they are too perfectionists to leave it like that |
| [2026-03-08 21:14:41] |
Ah that makes sense, thanks for the reply. Makes me feel better as I spent hours trying to fix it before giving up and posting here. I'll make sure not to update my main instance til it's fixed. |
| [2026-03-08 21:22:36] |
| Sierra_Chart Engineering - Posts: 25338 |
We apologize for the delay on this. The data for these market data columns, is stored according to the original Tick Size of the symbol. When you change the Tick Size in the chart there are inherent problems. There were recent changes to solve another problem with equities data. So you just need to make sure the chart Tick Size is set to the default and follow the instructions here: Global Trade Settings Windows: Combining Price Levels for Market Data Columns in the Chart/Trade DOM Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-04-08 16:49:43] |
| 284630 - Posts: 15 |
Hi Sierra Team, Is it possible to implement the function of modifying the tick size to display the recent bid/ask volume? Sometimes, in addition to aggregating tick data, I also hope that when placing orders on the DOM, the stepping can follow the aggregated tick size. |
| [2026-04-08 19:00:16] |
| John - SC Support - Posts: 48377 |
We are not certain what you are asking here. Refer to the following for how to apply the "Combine Increment in Ticks" to the other columns in the DOM, including the "Recent Bid/Ask" columns: Chart Settings: Apply Combine Increment in Ticks to Other Market Data Columns (Chart >> Chart Settings >> Market Depth menu) Sometimes, in addition to aggregating tick data, I also hope that when placing orders on the DOM, the stepping can follow the aggregated tick size.
If we are understanding this correctly, you prefer the ability to modify the Tick Size, so that when you place an order it will be at the aggregated price value instead of in between. For instance, for ES, if you set a Tick Size of 1.00, then you will have prices at whole price increments (6804.00, 6805.00, 6806.00, etc.) and you want to only be able to enter your orders at those prices and not at increments of 0.25 (the standard tick size). Please verify that we are understanding this correctly. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-04-10 06:20:11] |
Please verify that we are understanding this correctly. Yes, I want to place orders only in increments of these integer multiples, but when I change the minimum price increment, the recent bid/ask volume in the DOM no longer displays. |
| [2026-04-10 06:59:39] |
There is not a solution to this. The Tick Size cannot be changed from the default. Maybe it would help to change the Scale Increment for the main price graph: Chart Scale and Scale Adjusting: Scale Increment (Scale Settings) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2026-04-10 06:59:50
| [2026-07-30 12:33:29] |
| User860690 - Posts: 14 |
hi, i think im facing similar issues. i recently updated to the latest version and notice that the dom does not displayed combined values correctly. this is without combine, using default tick size 0.25: https://markuphero.com/share/6a6b29fcde093c619782c7dc displays correctly this is tick size = 1, bought/sold column is not populated. https://markuphero.com/share/6a6b2a29de093c619782c7e1 (other columns displays ok but not bought/sold column) this is tick size = 0.25, but group 4 tick as 1: https://markuphero.com/share/6a6b2b0ade093c619782c7f8 (the values combined, but the text/labels are not properly aligned. before the update all was working fine. i think the new update something changed. is it possible to group the ticks so price increments in 1, while keep all the recent bid/ask, volume combined? easier on the eyes and can look wider. |
| [2026-07-30 15:33:53] |
In this line: this is tick size = 0.25, but group 4 tick as 1: https://markuphero.com/share/6a6b2b0ade093c619782c7f8 (the values combined, but the text/labels are not properly aligned.
You state "the text/labels are not properly aligned". We do not know what you are referring to in this case, as everything shows as properly aligned. The only difference is the height of the Volume Bars. Refer to this setting that controls how that works: Global Trade Settings Windows: Chart DOM Volume Bars Filled Combined Price Level (Global Settings >> Chart DOM Settings >> Other >> Other Settings) And as noted in the previous responses in this thread, you can no longer use a different "Tick Size" and get the Market Depth columns properly. You need to use the "Combine Increment in Ticks" option. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
