Date/Time: Sun, 01 Nov 2026 05:20:16 +0000
Version 2888 - few bugs
View Count: 514
| [2026-03-05 21:33:55] |
| Elvis.S - Posts: 15 |
hei hei, thank you for updating time&sale and DOM Delta, looks super nice. Played around with new features and found couple of bugs. Recent Bid vol and Recent Ask vol not visible after tick size change. Anything else than Auto-set from data feed will not display numbers or bars. The Current Traded Total, Bid, and Ask volume bars are not adjusting properly after a tick size change. After the tick size is modified, they start overlapping each other. Displayed numbers are working correctly with no issues. |
| [2026-03-10 18:45:39] |
| Sierra_Chart Engineering - Posts: 25338 |
This is not a bug. There is an internal change to solve another problem, and the proper way to combine prices is documented here: Global Trade Settings Windows: Combining Price Levels for Market Data Columns in the Chart/Trade DOM You cannot change the Tick Size in the chart when using these market data columns. There are inherent problems with that. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2026-03-10 18:47:08
