Date/Time: Thu, 26 Nov 2026 03:19:23 +0000
SC got VERY!!!! unresponsive almost over night without me changing anything.
View Count: 428
[2026-02-27 11:32:36]
User138602 - Posts: 185
i am experiencing a very big drop in performance...its a dealbreaker. Did you change anything in the background and i have to recompile all my custom indicators?
I am asking this, because i cant think of anything else. I disabled opengl and the new sc internal timer....nothing improved. i have a seperate main instance as well. i use all your recomantations regarding performance, including disableding hyper threating and max system performance in windows. I can ashure you, thats not the problem. Running on AMD9700X and it was still fine some days ago. Version is prerelease 2886.
EDIT: I am back on oldest possible version 2867 and its a blast....everything is fluid. @SC you messed something up...
Date Time Of Last Edit: 2026-02-27 12:41:47
[2026-02-27 14:47:43]
Sierra_Chart Engineering - Posts: 25489
Refer to:
High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often: 30.44 - Performance Differences Between Versions of Sierra Chart
No this is not the case:
[2026-02-27 14:53:03]
One thing to check is the timer related settings. Refer to these settings:
General Settings Window: Chart Update Interval in Milliseconds (Global Settings >> General Settings >> General >> Update Intervals)
General Settings Window: Timer Management Enable (Global Settings >> General Settings >> General >> Update Intervals)
General Settings Window: Minimum Delay Between Chart Updates in Milliseconds (Global Settings >> General Settings >> General >> Update Intervals)
You may want to switch to OS timers.
There have been changes with Sierra Chart timer functionality in newer versions. Chart updates can occur as fast as 1 ms. So maybe that is the problem.
Date Time Of Last Edit: 2026-02-27 20:44:46
[2026-02-27 15:37:13]
I used the OS timer with your latest build 2882 and newer already...it didnt solve anything.
With v2867 i use the newly implemeted SC timer management on lowest possible setting: 10ms with no issues at all: the system is cruising along below 10% for all SC instances combined.
On v2882 the responce time between clicking on the menu bar and the menu showing up is 6sec!!! The cpu usage goes up from average 9-8% to 28-30%...everything is the same, except the SC version.
SC gets so unresponsive and sluggish...its mind blowing.
I know, this doesnt help you and if i could, i would tell you the exact reasons...but i cant. All i can is letting you know, the difference in performance comes from SC versions.
I fear the day, when i have to switch to higher versions and that will break the performance for me again.
EDIT: i tried out all available versions and the problem starts with v2873...so i am forced to stay at v2871.
EDIT2: i did run v2882 with OS TIMER in SAFE MODE....sluggish as hell. Trust me, something is broken.
Date Time Of Last Edit: 2026-02-27 18:28:59
[2026-02-27 20:11:21]
Problem solved...,
May bad @SC ....i didnt read the full documentation and i had the delay down to 1 ms...that did freeze the charts...2ms just works fine...SRY.
