Date/Time: Tue, 27 Oct 2026 17:54:30 +0000
Teton CME Routing – No trade accounts assigned (AMP 216357)
View Count: 402
| [2026-02-23 20:46:38] |
| User300932 - Posts: 2 |
My AMP account 216357 is enabled for Teton CME Routing on AMP side. When connecting in Sierra Chart using Teton CME Routing, I receive the message: "No trade accounts assigned." Please confirm that my Sierra Chart username is properly mapped to AMP account 216357 for Teton CME Routing. |
| [2026-02-23 22:02:40] |
| Sierra_Chart Engineering - Posts: 25297 |
This we are not able to tell: Please confirm that my Sierra Chart username is properly mapped to AMP account 216357 for Teton CME Routing. However, there could be another problem, and we can tell from the Message Log. Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Connect to the data feed: Select "File >> Disconnect" Select "File >> Connect to Data Feed" After about 30 seconds, provide a copy of the Message Log following these instructions: Support Board Posting Information: How to Post Your Message Log (Required In Some Cases) We will then determine what the problem is. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2026-02-23 22:03:22
| [2026-02-25 23:47:20] |
2026-02-25 23:35:34.222 | Software version: 2882 64-bit 2026-02-25 23:35:34.222 | Primary Thread ID: 22168 2026-02-25 23:35:34.222 | Usage end date: 2026-06-02 2026-02-25 23:35:34.222 | Enabled for: Advanced Features 2. 2026-02-25 23:35:34.222 | Enabled for: Sierra Chart Historical Data Service. 2026-02-25 23:35:34.222 | Enabled for: Denali Real-Time Exchange Data Feed. 2026-02-25 23:35:34.222 | Enabled for: Delayed Denali Exchange Data Feed. 2026-02-25 23:35:34.222 | Enabled for exchange2: NYMEX 2026-02-25 23:35:34.222 | Allow Support for Sierra Chart Data Feeds is enabled. 2026-02-25 23:35:34.222 | Current selected Data/Trading service: SC Data 2026-02-25 23:35:34.222 | Custom symbol settings values: enabled 2026-02-25 23:35:34.222 | Chart Update Interval: 400 2026-02-25 23:35:34.222 | Intraday Data Storage Time Unit: 0 2026-02-25 23:35:34.222 | Time Zone: +00:00:00 (UTC+00) 2026-02-25 23:35:34.222 | 2026-02-25 23:35:34 Local computer time in UTC 2026-02-25 23:35:34.222 | 2026-02-25 23:35:34 Local computer time in SC Time Zone 2026-02-25 23:35:34.222 | 2026-02-25 23:27:17 Server time in UTC 2026-02-25 23:35:34.222 | Local computer UTC time and Server UTC time difference: 2 seconds. 2026-02-25 23:35:34.222 | Program path: C:\SierraChart\ 2026-02-25 23:35:34.222 | Data Files path: C:\SierraChart\Data\ 2026-02-25 23:35:34.223 | OS Version Number: 10.0 2026-02-25 23:35:34.223 | Locale Setting: C 2026-02-25 23:35:34.223 | Crash reporter started: true 2026-02-25 23:35:34.223 | 2026-02-25 23:37:19.540 | File >> Disconnect selected. 2026-02-25 23:37:19.542 | SC Data with Depth | Waiting for socket receive thread to end 2026-02-25 23:37:19.543 | DTC Client socket (1) | CloseSocket call. 2026-02-25 23:37:19.543 | DTC Client socket (1) | Shutdown started. Waiting for graceful close. 2026-02-25 23:37:19.543 | SC Data with Depth | Disconnected from the server. 2026-02-25 23:37:19.543 | Delayed Data Feed | Waiting for socket receive thread to end 2026-02-25 23:37:19.543 | DTC Client socket (2) | CloseSocket call. 2026-02-25 23:37:19.543 | DTC Client socket (2) | Shutdown started. Waiting for graceful close. 2026-02-25 23:37:19.543 | Delayed Data Feed | Disconnected from the server. 2026-02-25 23:37:19.543 | Delayed Data Feed | Waiting for socket receive thread to end 2026-02-25 23:37:19.544 | DTC Client socket (3) | CloseSocket call. 2026-02-25 23:37:19.544 | DTC Client socket (3) | Shutdown started. Waiting for graceful close. 2026-02-25 23:37:19.544 | Delayed Data Feed | Disconnected from the server. 2026-02-25 23:37:19.544 | Delayed Data Feed | Waiting for socket receive thread to end 2026-02-25 23:37:19.544 | DTC Client socket (4) | CloseSocket call. 2026-02-25 23:37:19.544 | Delayed Data Feed | Disconnected from the server. 2026-02-25 23:37:19.544 | SC Data | Disconnected. 2026-02-25 23:37:19.544 | DTC Client socket (4) | Shutdown started. Waiting for graceful close. 2026-02-25 23:37:19.659 | DTC Client socket (4) | Socket gracefully closed by remote side. 2026-02-25 23:37:19.660 | DTC Client socket (4) | Closed. 2026-02-25 23:37:19.664 | DTC Client socket (3) | Socket gracefully closed by remote side. 2026-02-25 23:37:19.664 | DTC Client socket (3) | Closed. 2026-02-25 23:37:19.745 | DTC Client socket (2) | Socket gracefully closed by remote side. 2026-02-25 23:37:19.745 | DTC Client socket (2) | Closed. 2026-02-25 23:37:19.840 | DTC Client socket (1) | Socket gracefully closed by remote side. 2026-02-25 23:37:19.840 | DTC Client socket (1) | Closed. 2026-02-25 23:37:57.774 | 2026-02-25 23:37:57.775 | SC Data | Connection to server complete. 2026-02-25 23:37:57.775 | No download requests in the queue to start downloads for. | Number times message added: 3 2026-02-25 23:37:57.924 | Using symbol data fast lookup vector 2026-02-25 23:37:57.924 | SC Data with Depth | Starting real-time market data updates for: BTCUSDT_PERP_BINANCE. ID: 1 Service code: binance_cryptocurrency.exchange.data 2026-02-25 23:37:57.924 | SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 443 2026-02-25 23:37:57.924 | SC Data with Depth | Requesting security definition data for: BTCUSDT_PERP_BINANCE. ID: 1 2026-02-25 23:37:57.924 | Added historical Intraday data request for BTCUSDT_PERP_BINANCE to the queue. 2026-02-25 23:37:57.924 | Intraday data recording state for symbol BTCUSDT_PERP_BINANCE is set to download 'Pending'. 2026-02-25 23:37:57.924 | Triggering next historical data download in queue. 2026-02-25 23:37:57.925 | DTC Client socket (1) | Creating socket. 2026-02-25 23:37:57.925 | DTC Client socket (1) | New receive buffer size: 0 2026-02-25 23:37:57.925 | DTC Client socket (1) | Connecting to IP: 64.152.155.113. 2026-02-25 23:37:57.926 | Delaying start of download for BTCUSDT_PERP_BINANCE. 2026-02-25 23:37:57.926 | Mapping AAPL to AAPL. Service code: us_equities_utp_cta_exchange.data 2026-02-25 23:37:57.926 | Delayed Data Feed | Starting real-time market data updates for: AAPL (AAPL). ID: 2 Service code: us_equities_utp_cta_exchange.data 2026-02-25 23:37:57.926 | Delayed Data Feed | Connecting to the server ds31.sierracharts.com. Port 10043 2026-02-25 23:37:57.926 | Delayed Data Feed | Requesting security definition data for: AAPL (AAPL). ID: 2 2026-02-25 23:37:57.926 | Added historical Intraday data request for AAPL to the queue. 2026-02-25 23:37:57.926 | Intraday data recording state for symbol AAPL is set to download 'Pending'. 2026-02-25 23:37:57.926 | Triggering next historical data download in queue. 2026-02-25 23:37:57.928 | Mapping YMH26-CBOT to YMH26. Service code: cbot 2026-02-25 23:37:57.928 | Delayed Data Feed | Starting real-time market data updates for: YMH26-CBOT (YMH26). ID: 3 Service code: cbot 2026-02-25 23:37:57.928 | Delayed Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 10043 2026-02-25 23:37:57.928 | Delayed Data Feed | Requesting security definition data for: YMH26-CBOT (YMH26). ID: 3 2026-02-25 23:37:57.928 | Added historical Intraday data request for YMH26-CBOT to the queue. 2026-02-25 23:37:57.928 | Intraday data recording state for symbol YMH26-CBOT is set to download 'Pending'. 2026-02-25 23:37:57.928 | Triggering next historical data download in queue. 2026-02-25 23:37:57.931 | Using Bid/Ask average for last trade price for XAUUSD 2026-02-25 23:37:57.931 | SC Data with Depth | Starting real-time market data updates for: XAUUSD. ID: 4 Service code: fxcm 2026-02-25 23:37:57.931 | SC Data with Depth | Requesting security definition data for: XAUUSD. ID: 4 2026-02-25 23:37:57.932 | Added historical Intraday data request for XAUUSD to the queue. 2026-02-25 23:37:57.932 | Intraday data recording state for symbol XAUUSD is set to download 'Pending'. 2026-02-25 23:37:57.932 | Triggering next historical data download in queue. 2026-02-25 23:37:57.934 | SC Data with Depth | Starting real-time market data updates for: TICK-NYSE. ID: 5 Service code: statscalc 2026-02-25 23:37:57.934 | SC Data with Depth | Requesting security definition data for: TICK-NYSE. ID: 5 2026-02-25 23:37:57.934 | Added historical Intraday data request for TICK-NYSE to the queue. 2026-02-25 23:37:57.934 | Intraday data recording state for symbol TICK-NYSE is set to download 'Pending'. 2026-02-25 23:37:57.934 | Triggering next historical data download in queue. 2026-02-25 23:37:57.935 | Mapping MESH26-CME to MESH26. Service code: cme 2026-02-25 23:37:57.935 | Delayed Data Feed | Starting real-time market data updates for: MESH26-CME (MESH26). ID: 6 Service code: cme 2026-02-25 23:37:57.935 | Delayed Data Feed | Requesting security definition data for: MESH26-CME (MESH26). ID: 6 2026-02-25 23:37:57.935 | Added historical Intraday data request for MESH26-CME to the queue. 2026-02-25 23:37:57.935 | Intraday data recording state for symbol MESH26-CME is set to download 'Pending'. 2026-02-25 23:37:57.935 | Triggering next historical data download in queue. 2026-02-25 23:37:57.940 | Mapping AMZN-NQTV to AMZN-NQTV. Service code: nasdaq_exchange.data 2026-02-25 23:37:57.940 | Delayed Data Feed | Starting real-time market data updates for: AMZN-NQTV (AMZN-NQTV). ID: 7 Service code: nasdaq_exchange.data 2026-02-25 23:37:57.940 | Delayed Data Feed | Connecting to the server ds31.sierracharts.com. Port 10043 2026-02-25 23:37:57.941 | Delayed Data Feed | Requesting security definition data for: AMZN-NQTV (AMZN-NQTV). ID: 7 2026-02-25 23:37:57.941 | Added historical Intraday data request for AMZN-NQTV to the queue. 2026-02-25 23:37:57.941 | Intraday data recording state for symbol AMZN-NQTV is set to download 'Pending'. 2026-02-25 23:37:57.941 | Triggering next historical data download in queue. 2026-02-25 23:37:57.942 | Using Bid/Ask average for last trade price for EURUSD 2026-02-25 23:37:57.942 | SC Data with Depth | Starting real-time market data updates for: EURUSD. ID: 8 Service code: fxcm 2026-02-25 23:37:57.942 | SC Data with Depth | Requesting security definition data for: EURUSD. ID: 8 2026-02-25 23:37:57.942 | Added historical Intraday data request for EURUSD to the queue. 2026-02-25 23:37:57.942 | Intraday data recording state for symbol EURUSD is set to download 'Pending'. 2026-02-25 23:37:57.942 | Triggering next historical data download in queue. 2026-02-25 23:37:57.948 | DTC Client socket (2) | Creating socket. 2026-02-25 23:37:57.948 | DTC Client socket (2) | New receive buffer size: 0 2026-02-25 23:37:57.948 | DTC Client socket (2) | Connecting to IP: 64.152.155.116. 2026-02-25 23:37:57.963 | DTC Client socket (3) | Creating socket. 2026-02-25 23:37:57.963 | DTC Client socket (3) | New receive buffer size: 0 2026-02-25 23:37:57.963 | DTC Client socket (3) | Connecting to IP: 67.214.125.6. 2026-02-25 23:37:57.964 | DTC Client socket (4) | Creating socket. 2026-02-25 23:37:57.964 | DTC Client socket (4) | New receive buffer size: 0 2026-02-25 23:37:57.964 | DTC Client socket (4) | Connecting to IP: 64.152.155.116. 2026-02-25 23:37:58.035 | SC Data with Depth | Network connection to server complete. 2026-02-25 23:37:58.035 | SC Data with Depth | Starting socket receive thread. 2026-02-25 23:37:58.036 | SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard 2026-02-25 23:37:58.059 | Delayed Data Feed | Network connection to server complete. 2026-02-25 23:37:58.059 | Delayed Data Feed | Starting socket receive thread. 2026-02-25 23:37:58.059 | Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard 2026-02-25 23:37:58.074 | Delayed Data Feed | Network connection to server complete. 2026-02-25 23:37:58.074 | Delayed Data Feed | Starting socket receive thread. 2026-02-25 23:37:58.074 | Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard 2026-02-25 23:37:58.079 | Delayed Data Feed | Network connection to server complete. 2026-02-25 23:37:58.079 | Delayed Data Feed | Starting socket receive thread. 2026-02-25 23:37:58.079 | Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard 2026-02-25 23:37:58.161 | SC Data with Depth | Setting DTC encoding to Binary VLS 2026-02-25 23:37:58.161 | SC Data with Depth | Sending logon request message. 2026-02-25 23:37:58.177 | Delayed Data Feed | Setting DTC encoding to Binary VLS 2026-02-25 23:37:58.177 | Delayed Data Feed | Sending logon request message. 2026-02-25 23:37:58.208 | Delayed Data Feed | Setting DTC encoding to Binary VLS 2026-02-25 23:37:58.208 | Delayed Data Feed | Sending logon request message. 2026-02-25 23:37:58.229 | Delayed Data Feed | Setting DTC encoding to Binary VLS 2026-02-25 23:37:58.229 | Delayed Data Feed | Sending logon request message. 2026-02-25 23:37:58.345 | SC Data with Depth | Received logon response. 2026-02-25 23:37:58.345 | SC Data with Depth | Server Name: SC Realtime Server. 2026-02-25 23:37:58.345 | SC Data with Depth | Server protocol version: 8. Client protocol version: 8 2026-02-25 23:37:58.345 | SC Data with Depth | Successfully connected. 2026-02-25 23:37:58.345 | SC Data with Depth | Trading is not supported. 2026-02-25 23:37:58.345 | SC Data with Depth | MarketDepthIsSupported: 1 2026-02-25 23:37:58.345 | SC Data with Depth | Restarting real-time data updates for symbol: BTCUSDT_PERP_BINANCE 2026-02-25 23:37:58.345 | SC Data with Depth | Restarting real-time data updates for symbol: EURUSD 2026-02-25 23:37:58.345 | SC Data with Depth | Restarting real-time data updates for symbol: TICK-NYSE 2026-02-25 23:37:58.345 | SC Data with Depth | Restarting real-time data updates for symbol: XAUUSD 2026-02-25 23:37:58.396 | Delayed Data Feed | Received logon response. 2026-02-25 23:37:58.396 | Delayed Data Feed | Server Name: SC Realtime Server. 2026-02-25 23:37:58.396 | Delayed Data Feed | Server protocol version: 8. Client protocol version: 8 2026-02-25 23:37:58.396 | Delayed Data Feed | Successfully connected. 2026-02-25 23:37:58.396 | Delayed Data Feed | Trading is not supported. 2026-02-25 23:37:58.396 | Delayed Data Feed | MarketDepthIsSupported: 1 2026-02-25 23:37:58.396 | Delayed Data Feed | Restarting real-time data updates for symbol: AAPL -> AAPL 2026-02-25 23:37:58.427 | Delayed Data Feed | Received logon response. 2026-02-25 23:37:58.427 | Delayed Data Feed | Server Name: SC Realtime Server. 2026-02-25 23:37:58.427 | Delayed Data Feed | Server protocol version: 8. Client protocol version: 8 2026-02-25 23:37:58.427 | Delayed Data Feed | Successfully connected. 2026-02-25 23:37:58.427 | Delayed Data Feed | Trading is not supported. 2026-02-25 23:37:58.427 | Delayed Data Feed | MarketDepthIsSupported: 1 2026-02-25 23:37:58.427 | Delayed Data Feed | Restarting real-time data updates for symbol: AMZN-NQTV -> AMZN-NQTV 2026-02-25 23:37:58.545 | SC Data with Depth | Setting external service identifier for symbol BTCUSDT_PERP_BINANCE to 46 2026-02-25 23:37:58.545 | SC Data with Depth | Received security definition for symbol BTCUSDT_PERP_BINANCE 2026-02-25 23:37:58.545 | SC Data with Depth | Setting external service identifier for symbol EURUSD to 18 2026-02-25 23:37:58.545 | SC Data with Depth | Received security definition for symbol EURUSD 2026-02-25 23:37:58.545 | SC Data with Depth | Setting external service identifier for symbol TICK-NYSE to 1 2026-02-25 23:37:58.545 | SC Data with Depth | Received security definition for symbol TICK-NYSE 2026-02-25 23:37:58.545 | SC Data with Depth | Setting external service identifier for symbol XAUUSD to 62 2026-02-25 23:37:58.545 | SC Data with Depth | Received security definition for symbol XAUUSD 2026-02-25 23:37:58.615 | Delayed Data Feed | Setting external service identifier for symbol AAPL to 18 2026-02-25 23:37:58.615 | Delayed Data Feed | Received security definition for symbol AAPL 2026-02-25 23:37:58.646 | Delayed Data Feed | Setting external service identifier for symbol AMZN-NQTV to 535 2026-02-25 23:37:58.646 | Delayed Data Feed | Received security definition for symbol AMZN-NQTV 2026-02-25 23:37:58.761 | Delayed Data Feed | Received logon response. 2026-02-25 23:37:58.761 | Delayed Data Feed | Server Name: SC Realtime Server. 2026-02-25 23:37:58.761 | Delayed Data Feed | Server protocol version: 8. Client protocol version: 8 2026-02-25 23:37:58.761 | Delayed Data Feed | Successfully connected. 2026-02-25 23:37:58.761 | Delayed Data Feed | Trading is not supported. 2026-02-25 23:37:58.761 | Delayed Data Feed | MarketDepthIsSupported: 1 2026-02-25 23:37:58.761 | Delayed Data Feed | Restarting real-time data updates for symbol: MESH26-CME -> MESH26 2026-02-25 23:37:58.761 | Delayed Data Feed | Restarting real-time data updates for symbol: YMH26-CBOT -> YMH26 2026-02-25 23:37:58.982 | Delayed Data Feed | Setting external service identifier for symbol MESH26-CME to 42003800 2026-02-25 23:37:58.982 | Delayed Data Feed | Received security definition for symbol MESH26-CME 2026-02-25 23:37:58.982 | Delayed Data Feed | Setting external service identifier for symbol YMH26-CBOT to 42005850 2026-02-25 23:37:58.982 | Delayed Data Feed | Received security definition for symbol YMH26-CBOT 2026-02-25 23:38:03.314 | HD Request # 9 | Downloading Intraday chart data for BTCUSDT_PERP_BINANCE to the file BTCUSDT_PERP_BINANCE.scid. Service: binance_cryptocurrency.exchange.data 2026-02-25 23:38:03.315 | HD Request # 9 | Download start date-time: 2026-02-25 23:37:18.000000. File last date-time: 2026-02-25 23:37:18.705000 2026-02-25 23:38:03.315 | HD Request # 9 | Using server: ds12.sierracharts.com port 10150 2026-02-25 23:38:03.315 | Socket (5) | Creating socket. 2026-02-25 23:38:03.315 | Socket (5) | New receive buffer size: 0 2026-02-25 23:38:03.315 | Socket (5) | Connecting to IP: 69.39.70.241. 2026-02-25 23:38:03.559 | HD Request # 9 | Setting DTC encoding to Binary VLS 2026-02-25 23:38:03.559 | HD Request # 9 | Sending historical data logon request message. 2026-02-25 23:38:03.759 | HD Request # 9 | Requesting Intraday data. Start date-time: 2026-02-25 23:37:18. Record interval: 0. Symbol: BTCUSDT_PERP_BINANCE 2026-02-25 23:38:03.881 | HD Request # 9 | Decompressing data. 2026-02-25 23:38:04.002 | HD Request # 9 | Receiving Intraday data for BTCUSDT_PERP_BINANCE starting at 2026-02-25 23:37:18.000000 2026-02-25 23:38:04.002 | Socket (5) | CloseSocket call. 2026-02-25 23:38:04.002 | Socket (5) | Shutdown started. Waiting for graceful close. 2026-02-25 23:38:04.002 | Historical data download thread signaled to stop. 2026-02-25 23:38:04.002 | HD Request # 9 | Timestamp of first Intraday data file record written: 2026-02-25 23:37:19.000000. 2026-02-25 23:38:04.002 | HD Request # 9 | Received 45 Intraday data records from 2026-02-25 23:37:18.000000 to 2026-02-25 23:38:02.000000 (44.0 seconds. Delay: 2.0 seconds) and wrote 44 records for BTCUSDT_PERP_BINANCE 2026-02-25 23:38:04.010 | HD Request # 9 | Add time&sales data | Remembered last file record date-time: 2026-02-25 23:38:02.000000 2026-02-25 23:38:04.010 | Added 160 Time and Sales records to Intraday data file for BTCUSDT_PERP_BINANCE after download. 2026-02-25 23:38:04.010 | HD Request # 9 | Completion time: 1s. 2026-02-25 23:38:04.010 | HD Request # 9 | Intraday data download complete for BTCUSDT_PERP_BINANCE. Unique request ID: 9 2026-02-25 23:38:04.010 | Removing historical data download ID 9. 2026-02-25 23:38:04.010 | Real-time Intraday chart data file updates started for BTCUSDT_PERP_BINANCE 2026-02-25 23:38:04.010 | Intraday chart data file opened for BTCUSDT_PERP_BINANCE 2026-02-25 23:38:04.010 | HD Request # 9 | Enabling Intraday chart updating for symbol. 2026-02-25 23:38:04.010 | 2026-02-25 23:38:04.010 | Triggering next historical data download in queue. 2026-02-25 23:38:04.010 | HD Request # 10 | Downloading Intraday chart data for AAPL to the file AAPL.scid. Service: us_equities_utp_cta_exchange.data 2026-02-25 23:38:04.011 | HD Request # 10 | Download start date-time: 2026-02-25 23:22:16.000000. File last date-time: 2026-02-25 23:22:16.572000 2026-02-25 23:38:04.011 | HD Request # 10 | Using server: ds31.sierracharts.com port 10149 2026-02-25 23:38:04.011 | Socket (6) | Creating socket. 2026-02-25 23:38:04.011 | Socket (6) | New receive buffer size: 0 2026-02-25 23:38:04.011 | Socket (6) | Connecting to IP: 64.152.155.116. 2026-02-25 23:38:04.123 | Socket (5) | Socket gracefully closed by remote side. 2026-02-25 23:38:04.123 | Socket (5) | Closed. 2026-02-25 23:38:04.234 | HD Request # 10 | Setting DTC encoding to Binary VLS 2026-02-25 23:38:04.234 | HD Request # 10 | Sending historical data logon request message. 2026-02-25 23:38:04.382 | HD Request # 10 | Requesting Intraday data. Start date-time: 2026-02-25 23:22:16. Record interval: 0. Symbol: AAPL 2026-02-25 23:38:04.497 | HD Request # 10 | Decompressing data. 2026-02-25 23:38:04.608 | HD Request # 10 | Receiving Intraday data for AAPL starting at 2026-02-25 23:22:16.572000 2026-02-25 23:38:04.609 | Socket (6) | CloseSocket call. 2026-02-25 23:38:04.609 | Socket (6) | Shutdown started. Waiting for graceful close. 2026-02-25 23:38:04.610 | Historical data download thread signaled to stop. 2026-02-25 23:38:04.610 | HD Request # 10 | Timestamp of first Intraday data file record written: 2026-02-25 23:22:22.823000. 2026-02-25 23:38:04.610 | HD Request # 10 | Received 9 Intraday data records from 2026-02-25 23:22:16.572000 to 2026-02-25 23:23:02.532000 (46.0 seconds. Delay: 15.0 minutes) and wrote 8 records for AAPL 2026-02-25 23:38:04.618 | HD Request # 10 | Add time&sales data | Remembered last file record date-time: 2026-02-25 23:23:02.532000 2026-02-25 23:38:04.618 | HD Request # 10 | Completion time: 0s. 2026-02-25 23:38:04.618 | HD Request # 10 | Intraday data download complete for AAPL. Unique request ID: 10 2026-02-25 23:38:04.618 | Removing historical data download ID 10. 2026-02-25 23:38:04.618 | Real-time Intraday chart data file updates started for AAPL 2026-02-25 23:38:04.618 | Intraday chart data file opened for AAPL 2026-02-25 23:38:04.618 | HD Request # 10 | Enabling Intraday chart updating for symbol. 2026-02-25 23:38:04.618 | 2026-02-25 23:38:04.618 | Triggering next historical data download in queue. 2026-02-25 23:38:04.618 | HD Request # 11 | Downloading Intraday chart data for YMH26-CBOT to the file YMH26-CBOT.scid. Service: cbot 2026-02-25 23:38:04.618 | HD Request # 11 | Download start date-time: 2026-02-25 23:26:49.000000. File last date-time: 2026-02-25 23:26:49.446001 2026-02-25 23:38:04.618 | HD Request # 11 | Using server: ds32.sierracharts.com port 10150 2026-02-25 23:38:04.635 | Socket (5) | Creating socket. 2026-02-25 23:38:04.635 | Socket (5) | New receive buffer size: 0 2026-02-25 23:38:04.635 | Socket (5) | Connecting to IP: 69.39.70.248. 2026-02-25 23:38:04.721 | Socket (6) | Socket gracefully closed by remote side. 2026-02-25 23:38:04.721 | Socket (6) | Closed. 2026-02-25 23:38:04.894 | HD Request # 11 | Setting DTC encoding to Binary VLS 2026-02-25 23:38:04.894 | HD Request # 11 | Sending historical data logon request message. 2026-02-25 23:38:05.041 | HD Request # 11 | Requesting Intraday data. Start date-time: 2026-02-25 23:26:49. Record interval: 0. Symbol: YMH26 2026-02-25 23:38:05.159 | HD Request # 11 | Decompressing data. 2026-02-25 23:38:05.276 | HD Request # 11 | Receiving Intraday data for YMH26-CBOT starting at 2026-02-25 23:26:49.446000 2026-02-25 23:38:05.276 | Socket (5) | CloseSocket call. 2026-02-25 23:38:05.276 | Socket (5) | Shutdown started. Waiting for graceful close. 2026-02-25 23:38:05.277 | Historical data download thread signaled to stop. 2026-02-25 23:38:05.277 | HD Request # 11 | Timestamp of first Intraday data file record written: 2026-02-25 23:27:10.260000. 2026-02-25 23:38:05.277 | HD Request # 11 | Received 8 Intraday data records from 2026-02-25 23:26:49.446000 to 2026-02-25 23:27:52.138002 (62.7 seconds. Delay: 10.2 minutes) and wrote 6 records for YMH26-CBOT 2026-02-25 23:38:05.283 | HD Request # 11 | Add time&sales data | Remembered last file record date-time: 2026-02-25 23:27:52.138002 2026-02-25 23:38:05.283 | HD Request # 11 | Completion time: 1s. 2026-02-25 23:38:05.283 | HD Request # 11 | Intraday data download complete for YMH26-CBOT. Unique request ID: 11 2026-02-25 23:38:05.283 | Removing historical data download ID 11. 2026-02-25 23:38:05.283 | Real-time Intraday chart data file updates started for YMH26-CBOT 2026-02-25 23:38:05.283 | Intraday chart data file opened for YMH26-CBOT 2026-02-25 23:38:05.283 | HD Request # 11 | Enabling Intraday chart updating for symbol. 2026-02-25 23:38:05.283 | 2026-02-25 23:38:05.283 | Triggering next historical data download in queue. 2026-02-25 23:38:05.283 | HD Request # 12 | Downloading Intraday chart data for XAUUSD to the file XAUUSD.scid. Service: fxcm 2026-02-25 23:38:05.283 | HD Request # 12 | Download start date-time: 2026-02-25 23:37:18.000000. File last date-time: 2026-02-25 23:37:18.144000 2026-02-25 23:38:05.283 | HD Request # 12 | Using server: ds4.sierracharts.com port 10149 2026-02-25 23:38:05.283 | Socket (6) | Creating socket. 2026-02-25 23:38:05.284 | Socket (6) | New receive buffer size: 0 2026-02-25 23:38:05.284 | Socket (6) | Connecting to IP: 64.152.155.113. 2026-02-25 23:38:05.392 | Socket (5) | Socket gracefully closed by remote side. 2026-02-25 23:38:05.392 | Socket (5) | Closed. 2026-02-25 23:38:05.512 | HD Request # 12 | Setting DTC encoding to Binary VLS 2026-02-25 23:38:05.512 | HD Request # 12 | Sending historical data logon request message. 2026-02-25 23:38:05.642 | HD Request # 12 | Requesting Intraday data. Start date-time: 2026-02-25 23:37:18. Record interval: 0. Symbol: XAUUSD 2026-02-25 23:38:05.753 | HD Request # 12 | Decompressing data. 2026-02-25 23:38:05.857 | Opened cached Intraday file: C:\SierraChart\Data\BTCUSDT_PERP_BINANCE.scid. Thread ID: 10648 2026-02-25 23:38:05.869 | HD Request # 12 | Receiving Intraday data for XAUUSD starting at 2026-02-25 23:37:18.144000 2026-02-25 23:38:05.869 | Socket (6) | CloseSocket call. 2026-02-25 23:38:05.870 | Socket (6) | Shutdown started. Waiting for graceful close. 2026-02-25 23:38:05.870 | Historical data download thread signaled to stop. 2026-02-25 23:38:05.871 | HD Request # 12 | Timestamp of first Intraday data file record written: 2026-02-25 23:37:19.560000. 2026-02-25 23:38:05.871 | HD Request # 12 | Received 299 Intraday data records from 2026-02-25 23:37:18.144000 to 2026-02-25 23:38:02.632000 (44.5 seconds. Delay: 3.2 seconds) and wrote 298 records for XAUUSD 2026-02-25 23:38:05.880 | HD Request # 12 | Add time&sales data | Remembered last file record date-time: 2026-02-25 23:38:02.632000 2026-02-25 23:38:05.880 | Added 16 Time and Sales records to Intraday data file for XAUUSD after download. 2026-02-25 23:38:05.880 | HD Request # 12 | Completion time: 0s. 2026-02-25 23:38:05.880 | HD Request # 12 | Intraday data download complete for XAUUSD. Unique request ID: 12 2026-02-25 23:38:05.880 | Removing historical data download ID 12. 2026-02-25 23:38:05.880 | Real-time Intraday chart data file updates started for XAUUSD 2026-02-25 23:38:05.880 | Intraday chart data file opened for XAUUSD 2026-02-25 23:38:05.880 | HD Request # 12 | Enabling Intraday chart updating for symbol. 2026-02-25 23:38:05.880 | 2026-02-25 23:38:05.880 | Triggering next historical data download in queue. 2026-02-25 23:38:05.880 | HD Request # 13 | Downloading Intraday chart data for TICK-NYSE to the file TICK-NYSE.scid. Service: statscalc 2026-02-25 23:38:05.880 | HD Request # 13 | Download start date-time: 2026-02-25 23:37:18.000000. File last date-time: 2026-02-25 23:37:18.953001 2026-02-25 23:38:05.880 | HD Request # 13 | Using server: ds12.sierracharts.com port 10150 2026-02-25 23:38:05.880 | Socket (5) | Creating socket. 2026-02-25 23:38:05.880 | Socket (5) | New receive buffer size: 0 2026-02-25 23:38:05.880 | Socket (5) | Connecting to IP: 69.39.70.241. 2026-02-25 23:38:05.980 | Socket (6) | Socket gracefully closed by remote side. 2026-02-25 23:38:05.980 | Socket (6) | Closed. 2026-02-25 23:38:06.114 | HD Request # 13 | Setting DTC encoding to Binary VLS 2026-02-25 23:38:06.114 | HD Request # 13 | Sending historical data logon request message. 2026-02-25 23:38:06.230 | HD Request # 13 | Requesting Intraday data. Start date-time: 2026-02-25 23:37:18. Record interval: 0. Symbol: TICK-NYSE 2026-02-25 23:38:06.347 | HD Request # 13 | Decompressing data. 2026-02-25 23:38:06.462 | HD Request # 13 | Receiving Intraday data for TICK-NYSE starting at 2026-02-25 23:37:18.000000 2026-02-25 23:38:06.462 | Socket (5) | CloseSocket call. 2026-02-25 23:38:06.462 | Socket (5) | Shutdown started. Waiting for graceful close. 2026-02-25 23:38:06.462 | Historical data download thread signaled to stop. 2026-02-25 23:38:06.462 | HD Request # 13 | Timestamp of first Intraday data file record written: 2026-02-25 23:37:19.000000. 2026-02-25 23:38:06.462 | HD Request # 13 | Received 44 Intraday data records from 2026-02-25 23:37:18.000000 to 2026-02-25 23:38:01.000000 (43.0 seconds. Delay: 5.5 seconds) and wrote 43 records for TICK-NYSE 2026-02-25 23:38:06.469 | HD Request # 13 | Add time&sales data | Remembered last file record date-time: 2026-02-25 23:38:01.000000 2026-02-25 23:38:06.469 | Added 19 Time and Sales records to Intraday data file for TICK-NYSE after download. 2026-02-25 23:38:06.469 | HD Request # 13 | Completion time: 1s. 2026-02-25 23:38:06.469 | HD Request # 13 | Intraday data download complete for TICK-NYSE. Unique request ID: 13 2026-02-25 23:38:06.469 | Removing historical data download ID 13. 2026-02-25 23:38:06.469 | Real-time Intraday chart data file updates started for TICK-NYSE 2026-02-25 23:38:06.469 | Intraday chart data file opened for TICK-NYSE 2026-02-25 23:38:06.469 | HD Request # 13 | Enabling Intraday chart updating for symbol. 2026-02-25 23:38:06.469 | 2026-02-25 23:38:06.469 | Triggering next historical data download in queue. 2026-02-25 23:38:06.469 | HD Request # 14 | Downloading Intraday chart data for MESH26-CME to the file MESH26-CME.scid. Service: cme 2026-02-25 23:38:06.469 | HD Request # 14 | Download start date-time: 2026-02-25 23:27:08.000000. File last date-time: 2026-02-25 23:27:08.785001 2026-02-25 23:38:06.469 | HD Request # 14 | Using server: ds26.sierracharts.com port 10149 2026-02-25 23:38:06.469 | Socket (6) | Creating socket. 2026-02-25 23:38:06.469 | Socket (6) | New receive buffer size: 0 2026-02-25 23:38:06.469 | Socket (6) | Connecting to IP: 64.152.155.17. 2026-02-25 23:38:06.583 | Socket (5) | Socket gracefully closed by remote side. 2026-02-25 23:38:06.583 | Socket (5) | Closed. 2026-02-25 23:38:06.696 | HD Request # 14 | Setting DTC encoding to Binary VLS 2026-02-25 23:38:06.696 | HD Request # 14 | Sending historical data logon request message. 2026-02-25 23:38:06.839 | HD Request # 14 | Requesting Intraday data. Start date-time: 2026-02-25 23:27:08. Record interval: 0. Symbol: MESH26 2026-02-25 23:38:06.950 | HD Request # 14 | Decompressing data. 2026-02-25 23:38:07.062 | HD Request # 14 | Receiving Intraday data for MESH26-CME starting at 2026-02-25 23:27:08.766000 2026-02-25 23:38:07.062 | Socket (6) | CloseSocket call. 2026-02-25 23:38:07.062 | Socket (6) | Shutdown started. Waiting for graceful close. 2026-02-25 23:38:07.063 | Historical data download thread signaled to stop. 2026-02-25 23:38:07.063 | HD Request # 14 | Timestamp of first Intraday data file record written: 2026-02-25 23:27:10.259000. 2026-02-25 23:38:07.063 | HD Request # 14 | Received 238 Intraday data records from 2026-02-25 23:27:08.766000 to 2026-02-25 23:28:05.857000 (57.1 seconds. Delay: 10.0 minutes) and wrote 235 records for MESH26-CME 2026-02-25 23:38:07.070 | HD Request # 14 | Add time&sales data | Remembered last file record date-time: 2026-02-25 23:28:05.857000 2026-02-25 23:38:07.070 | HD Request # 14 | Completion time: 1s. 2026-02-25 23:38:07.070 | HD Request # 14 | Intraday data download complete for MESH26-CME. Unique request ID: 14 2026-02-25 23:38:07.070 | Removing historical data download ID 14. 2026-02-25 23:38:07.070 | Real-time Intraday chart data file updates started for MESH26-CME 2026-02-25 23:38:07.070 | Intraday chart data file opened for MESH26-CME 2026-02-25 23:38:07.070 | HD Request # 14 | Enabling Intraday chart updating for symbol. 2026-02-25 23:38:07.070 | 2026-02-25 23:38:07.070 | Triggering next historical data download in queue. 2026-02-25 23:38:07.070 | HD Request # 15 | Downloading Intraday chart data for AMZN-NQTV to the file AMZN-NQTV.scid. Service: nasdaq_exchange.data 2026-02-25 23:38:07.071 | HD Request # 15 | Download start date-time: 2026-02-25 23:22:07.000000. File last date-time: 2026-02-25 23:22:07.360001 2026-02-25 23:38:07.071 | HD Request # 15 | Using server: ds33.sierracharts.com port 10150 2026-02-25 23:38:07.071 | Socket (5) | Creating socket. 2026-02-25 23:38:07.071 | Socket (5) | New receive buffer size: 0 2026-02-25 23:38:07.071 | Socket (5) | Connecting to IP: 69.39.70.245. 2026-02-25 23:38:07.173 | Socket (6) | Socket gracefully closed by remote side. 2026-02-25 23:38:07.173 | Socket (6) | Closed. 2026-02-25 23:38:07.306 | HD Request # 15 | Setting DTC encoding to Binary VLS 2026-02-25 23:38:07.306 | HD Request # 15 | Sending historical data logon request message. 2026-02-25 23:38:07.452 | HD Request # 15 | Requesting Intraday data. Start date-time: 2026-02-25 23:22:07. Record interval: 0. Symbol: AMZN-NQTV 2026-02-25 23:38:07.570 | HD Request # 15 | Decompressing data. 2026-02-25 23:38:07.687 | HD Request # 15 | Receiving Intraday data for AMZN-NQTV starting at 2026-02-25 23:22:07.360000 2026-02-25 23:38:07.687 | Socket (5) | CloseSocket call. 2026-02-25 23:38:07.687 | Socket (5) | Shutdown started. Waiting for graceful close. 2026-02-25 23:38:07.688 | Historical data download thread signaled to stop. 2026-02-25 23:38:07.688 | HD Request # 15 | Timestamp of first Intraday data file record written: 2026-02-25 23:22:29.473000. 2026-02-25 23:38:07.688 | HD Request # 15 | Received 11 Intraday data records from 2026-02-25 23:22:07.360000 to 2026-02-25 23:23:00.893001 (53.5 seconds. Delay: 15.1 minutes) and wrote 9 records for AMZN-NQTV 2026-02-25 23:38:07.695 | HD Request # 15 | Add time&sales data | Remembered last file record date-time: 2026-02-25 23:23:00.893001 2026-02-25 23:38:07.695 | HD Request # 15 | Completion time: 0s. 2026-02-25 23:38:07.695 | HD Request # 15 | Intraday data download complete for AMZN-NQTV. Unique request ID: 15 2026-02-25 23:38:07.695 | Removing historical data download ID 15. 2026-02-25 23:38:07.695 | Real-time Intraday chart data file updates started for AMZN-NQTV 2026-02-25 23:38:07.695 | Intraday chart data file opened for AMZN-NQTV 2026-02-25 23:38:07.695 | HD Request # 15 | Enabling Intraday chart updating for symbol. 2026-02-25 23:38:07.695 | 2026-02-25 23:38:07.695 | Triggering next historical data download in queue. 2026-02-25 23:38:07.695 | HD Request # 16 | Downloading Intraday chart data for EURUSD to the file EURUSD.scid. Service: fxcm 2026-02-25 23:38:07.695 | HD Request # 16 | Download start date-time: 2026-02-25 23:37:09.000000. File last date-time: 2026-02-25 23:37:09.016000 2026-02-25 23:38:07.695 | HD Request # 16 | Using server: ds4.sierracharts.com port 10149 2026-02-25 23:38:07.695 | Socket (6) | Creating socket. 2026-02-25 23:38:07.695 | Socket (6) | New receive buffer size: 0 2026-02-25 23:38:07.695 | Socket (6) | Connecting to IP: 64.152.155.113. 2026-02-25 23:38:07.804 | Socket (5) | Socket gracefully closed by remote side. 2026-02-25 23:38:07.805 | Socket (5) | Closed. 2026-02-25 23:38:07.922 | HD Request # 16 | Setting DTC encoding to Binary VLS 2026-02-25 23:38:07.922 | HD Request # 16 | Sending historical data logon request message. 2026-02-25 23:38:08.033 | HD Request # 16 | Requesting Intraday data. Start date-time: 2026-02-25 23:37:09. Record interval: 0. Symbol: EURUSD 2026-02-25 23:38:08.076 | Opened cached Intraday file: C:\SierraChart\Data\MESH26-CME.scid. Thread ID: 19964 2026-02-25 23:38:08.151 | HD Request # 16 | Decompressing data. 2026-02-25 23:38:08.266 | HD Request # 16 | Receiving Intraday data for EURUSD starting at 2026-02-25 23:37:09.016000 2026-02-25 23:38:08.266 | Socket (6) | CloseSocket call. 2026-02-25 23:38:08.266 | Socket (6) | Shutdown started. Waiting for graceful close. 2026-02-25 23:38:08.267 | Historical data download thread signaled to stop. 2026-02-25 23:38:08.267 | HD Request # 16 | Timestamp of first Intraday data file record written: 2026-02-25 23:37:23.434000. 2026-02-25 23:38:08.267 | HD Request # 16 | Received 21 Intraday data records from 2026-02-25 23:37:09.016000 to 2026-02-25 23:37:43.346000 (34.3 seconds. Delay: 24.9 seconds) and wrote 20 records for EURUSD 2026-02-25 23:38:08.275 | HD Request # 16 | Add time&sales data | Remembered last file record date-time: 2026-02-25 23:37:43.346000 2026-02-25 23:38:08.275 | HD Request # 16 | Completion time: 1s. 2026-02-25 23:38:08.275 | HD Request # 16 | Intraday data download complete for EURUSD. Unique request ID: 16 2026-02-25 23:38:08.275 | Removing historical data download ID 16. 2026-02-25 23:38:08.275 | Real-time Intraday chart data file updates started for EURUSD 2026-02-25 23:38:08.275 | Intraday chart data file opened for EURUSD 2026-02-25 23:38:08.275 | HD Request # 16 | Enabling Intraday chart updating for symbol. 2026-02-25 23:38:08.275 | 2026-02-25 23:38:08.275 | No download requests in the queue to start downloads for. 2026-02-25 23:38:08.377 | Socket (6) | Socket gracefully closed by remote side. 2026-02-25 23:38:08.377 | Socket (6) | Closed. 2026-02-25 23:38:10.863 | Opened cached Intraday file: C:\SierraChart\Data\XAUUSD.scid. Thread ID: 10648 2026-02-25 23:38:10.864 | Opened cached Intraday file: C:\SierraChart\Data\TICK-NYSE.scid. Thread ID: 10648 2026-02-25 23:38:12.556 | Opened cached Intraday file: C:\SierraChart\Data\AMZN-NQTV.scid. Thread ID: 19816 2026-02-25 23:38:14.743 | Opened cached Intraday file: C:\SierraChart\Data\AAPL.scid. Thread ID: 17112 2026-02-25 23:38:30.888 | Opened cached Intraday file: C:\SierraChart\Data\EURUSD.scid. Thread ID: 10648 2026-02-25 23:38:31.628 | Opened cached Intraday file: C:\SierraChart\Data\YMH26-CBOT.scid. Thread ID: 19964 |
| [2026-02-26 08:06:15] |
This Message Log does not show a connection to Teton order routing. Follow the instructions here: Sierra Chart Teton Futures Order Routing: Setup Instructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2026-02-26 08:07:03
