Date/Time: Wed, 25 Nov 2026 23:10:12 +0000
Downloar MES, MNQ
View Count: 318
[2026-02-19 16:05:38]
User211332 - Posts: 1
Bonjour,
Je n arrive pas a télécharger les données pour le MNQ et le MES, pouvez vous m'aider ? l ES c'est ok par contre je ne comprends pas pourquoi
Merci d'avance
Salutations
[2026-02-19 16:07:10]
From Google Translate:
[/quote]Hello,
I'm having trouble downloading the data for MNQ and MES. Can you help me? ES is working fine, but I don't understand why.[/quote]
You should not have any issue with these. Everything on your account looks good, so you should be getting the real-time data.
What exactly is occurring? What are you seeing?
Please get us your Message Log by following these instructions - open a chart for one of the symbols for which you are having a problem:
Close all of the Chartbooks with "File >> Close All Chartbooks".
Open a single chart for the symbol you have an issue with through "File >> Find Symbol". Tell us that symbol of the chart. Tell us about *one* symbol only.
