Date/Time: Thu, 26 Nov 2026 03:19:30 +0000
Custom Symbol Issues
View Count: 575
[2026-02-19 13:01:17]
User584084 - Posts: 348
I am running SC Version 2867 and IB TWS Version 10.37.1o.
1) 'Custom symbols' no longer appear in 'Available Symbols' in Instance #1 under 'Commodity'. Instance #2 shows 'Custom Symbols'.
Instance #1:
https://www.sierrachart.com/image.php?Image=1771502800414.png
Instance #2:
https://www.sierrachart.com/image.php?Image=1771503162329.png
2) Custom symbols can no longer be rolled over. Previous versions of Sierra Chart allowed a Custom 'New Symbol' to be typed in and all charts with the 'Current Symbol' were rolled over to the Custom 'New Symbol'. The 'New Symbol' field is read only now. Now you need to go into 'Settings' for every chart and edit the 'Symbol'
https://www.sierrachart.com/image.php?Image=1771503853562.png
3) Instance #1 is giving error code 406 when I try rolling over a custom symbol from 42*{RB-202603-NYMEX}-1*{CL-202603-NYMEX} to 42*{RB-202604-NYMEX}-1*{CL-202604-NYMEX}. Message from IB: Currency 1*{CL is not allowed. IB Error Code: 406. Instance #2 is not giving this error code for the same symbol and is able to download the data to a chart.
Instance #1 Message Log error is shown below. This started with the April contract for the RB.CL inter-commodity spread. January, February, and March contracts did not give this error code for Instance #1.
Instance #1
https://www.sierrachart.com/image.php?Image=1771504325921.png
Instance #2
https://www.sierrachart.com/image.php?Image=1771505349998.png
Instance #1 Message Log below:
2026-02-19 07:31:55.137 | Message from IB: Currency 1*{CL is not allowed. IB Error Code: 406. Request ID: 103. Symbol: 42*{RB-202603-NYMEX}-1*{CL-202603-NYMEX}
2026-02-19 07:31:55.214 | Symbol Error | 42*{RB-202603-NYMEX}-1*{CL-202603-NYMEX} is unknown, unavailable, or improperly formatted. The destination or exchange selected is Invalid. Please review your order's "Destination" field. If using a <br>Directed order, review the exchange selected when creating the order ticket or order row. This may occur when <br>creating stock orders for the overnight session or when creating option orders for the overnight session.
2026-02-19 07:31:55.340 | Message from IB: Currency 1*{CL is not allowed. IB Error Code: 406. Request ID: 108. Symbol: 42*{RB-202604-NYMEX}-1*{CL-202604-NYMEX}
2026-02-19 07:31:55.585 | Symbol Error | 42*{RB-202604-NYMEX}-1*{CL-202604-NYMEX} is unknown, unavailable, or improperly formatted. The destination or exchange selected is Invalid. Please review your order's "Destination" field. If using a <br>Directed order, review the exchange selected when creating the order ticket or order row. This may occur when <br>creating stock orders for the overnight session or when creating option orders for the overnight session.
Date Time Of Last Edit: 2026-02-19 13:11:14
[2026-02-24 17:57:50]
I posted this last Thursday 02/19 and this Support Request has not been reviewed by Sierra Support yet.
[2026-02-25 07:46:51]
Sierra_Chart Engineering - Posts: 25489
2. This has already been resolved in the latest prerelease. You are able to enter a new symbol.
Regarding everything else nothing has changed with this functionality and we have not had time to do testing but we would not expect to find a problem. We will be doing testing, this week. We apologize for the delay.
[2026-02-25 23:29:24]
As expected we do not see any problems with custom calculated symbols. Go through the steps here again:
Custom Calculated Symbols: Instructions
Check the existing symbol settings for the custom calculated symbol, in particular follow step 11.
Date Time Of Last Edit: 2026-02-25 23:29:40
[2026-02-26 00:46:07]
I downloaded SC Version 2886 PreRelease.
I went through the 'Custom Calculated Symbols: Instructions'.
Step 4: Use Custom Symbol Settings Values was not enabled in Instance #1. When I enabled this, I was able to download data for Custom Symbol: 42*{RB-202604-NYMEX}-1*{CL-202604-NYMEX} in Instance #1. At some point, this was disabled for Instance #1.
Step 11: Use Formula Operators was not enabled for Custom Symbol: 1*{RB-202604-NYMEX}-1*{RB-202605-NYMEX}. When I enabled this and I enabled Step 4, I was able to download data for this custom symbol in Instance #1.
You can close this support ticket. The issues I had have been resolved.
Thank You for your assistance with this support ticket.
Date Time Of Last Edit: 2026-02-26 02:03:09
