Date/Time: Wed, 25 Nov 2026 23:00:17 +0000
Big delays
View Count: 628
[2026-02-11 15:05:38]
User109490 - Posts: 17
Hi Team,
Since this week I suffer some serious delays. Charts update price quite slow but it 's wider than that, opening a new window or adjusting a price takes seconds. Same with the hairs of the crosshair the cursor can be on another screen well before the crosshair reacts. In fact, the only thing up-to-date is the trade window, where the value of a position changes well ahead of the chart arriving of the implied price. It 's making things rather difficult at the moment. It is definitely Sierra Chart, any other action on my computer, like writing this message, goes at regular speed. I cannot measure the lag, but it feels like a second and a half, maybe two.
Need a bit of guidance here. Is there anything you can do to fix it, and if not, what can I do myself to get things back to normal?
Thanks in advance,
Regards,
Lex
[2026-02-11 15:14:07]
Sierra_Chart Engineering - Posts: 25484
The first thing we want you to do, is adjust the chart update interval to a higher value:
High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often: 30.5 - Chart Update Interval
There is a global setting and a chart specific setting.
Also try enabling OS Timers:
General Settings Window: Use OS Timer for Charts (Global Settings >> General Settings >> General >> Update Intervals)
Also refer to:
High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often: 30.48 - Basic Steps to Resolve Performance Issue in Sierra Chart
Date Time Of Last Edit: 2026-02-11 15:14:31
[2026-02-11 15:47:40]
Thank you for a response quicker than my charts :-)
The response time (global) was at a rather ambitious 10 milliseconds, not my doing but I reset that to 250 for now. Chart-specific is at 0.
Yet that didn't offer any solace. Opening or closing a window, re-centering the DOM scale, entering or deleting a drawing, adjusting a scale: it all functions, but with a quite serious lag. Clicking the crosshair up or clicking it away, same thing. It will still be there for a while. The program is way less responsive than usual.
What may be causing this, can it be that my C station is too full with redundant files perhaps?
Again, thanks for your prompt reaction, it 's appreciated.
Lex
[2026-02-11 16:00:28]
Ok: things are quite much better all of sudden. Pls consider my support request closed, I'll revert if necessary.
Thx,
Lex.
[2026-02-11 22:31:26]
The issue could be related to graphics. For example, too low of a price increment with Volume by Price and TPO Chart studies.
Anyway, you are saying the issue is solved. But giving you some other information that may help
