Date/Time: Wed, 25 Nov 2026 23:00:16 +0000
gold and silver ratio chart
View Count: 660
| [2026-02-08 22:57:04] |
| whats1thingnow - Posts: 418 |
hope this finds you well I tried to use the study, ratio (bar) and also checked: "display as main price graph". However, the studies I have already have on the chart that is based on the main price graph still isn't calculating from "ratio (bar)". Hence, I tried the next thing: Custom Calculated Symbols Under "Formula Symbol", I tried both: {XAUUSD}/{XAGUSD} and {GCJ26-COMEX}/{SIH26-COMEX} Both of them ended up with this message: Historical Intraday Data Download Failed
Error downloading historical Intraday data for GSR-CUSTOM. Historical data file for GSR-CUSTOM not available. I didn't expect the futures one to work because the documentation said "Continuous Futures Contract Charts are not supported for Custom Calculated Symbols." However, the FXCM CFD data should be ok? I followed every step I think as instructed: Set the Formula Symbol setting, to the actual formula for the symbol according to the following format. The square brackets simply represent optional characters. The curly braces ,{}, need to be entered around a symbol to identify the symbol to the parser.
Format: [numeric value][operator]{symbol}[operator][numeric value][operator]{symbol}. The [ ] characters are not used in the formula symbol itself. This pattern can repeat with as many symbols as necessary. Example: 2*{EURUSD}-2*{EURGBP}. Any of the standard Arithmetic Operators can be used. Set appropriate values for the Price Format, Tick Size, and Currency Value Per Tick settings. Enter an appropriate name for the Category setting. We recommend using Custom Symbols for the Category. Set the Uses Formula Operators setting to Yes. It is absolutely essential to have this option enabled. Set the Download Historical Data for Formula Symbol setting to either Yes or No depending upon whether you want historical data downloaded and calculated for this custom formula symbol or not. Downloading historical data will take more time. So it is not necessarily an advantage to download historical data. By default this is set to No. The amount of historical data that will be generated depends upon the Global Settings >> Data/Trade Service Settings >> Maximum Historical Intraday Days to Download >> Formula Symbols setting. We recommend not using too high of a number for this. Otherwise, downloads will take a long time. No other settings need to be set. Do not contact Sierra Chart support about how to set other settings because they are not needed. Leave them at their default settings!. However, it is fine to set the Intraday Session Times. I also tried: Set the Download Historical Data for Formula Symbol setting to either Yes or No
But still no data is showing on the chart Please help Thank you very much!! |
| [2026-02-09 17:58:01] |
Use the Add Additional Symbol study: Add Additional Symbol And then, if you are just wanting a single line, calculate the ratio using the "Study Subgraphs Divide/Ratio". For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-02-09 18:00:13] |
| Sierra_Chart Engineering - Posts: 25484 |
Also refer to: Using the Basic Arithmetic Studies Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
