Date/Time: Tue, 17 Nov 2026 18:09:15 +0000
still can't fix the historical data missing for all my futures
View Count: 522
[2026-02-04 08:11:57]
whats1thingnow - Posts: 418
hi support, hope this finds you well
i have data missing between jun 2023 and yesterday
i tried to multiple methods including "delete all data and download" and i keep on getting "download failed"
i uploaded the image because i wanted to show both the chart and the settings (instead of this: Support Board Posting Information: Attaching or Posting a Screenshot/Image (Optional) )
can anyone please help!
thanks!!
image20260204_000408.png / V - Attached On 2026-02-04 08:09:27 UTC - Size: 42.12 KB - 152 views
[2026-02-04 14:45:25]
John - SC Support - Posts: 48555
Please do the following for us to get us your Message Log:
Close all of the Chartbooks with "File >> Close All Chartbooks".
Open a single chart for the symbol you have an issue with through "File >> Find Symbol". Tell us that symbol of the chart. Tell us about *one* symbol only.
Select "Edit >> Delete All Data and Download".
Select the "Select All" button on that window and then select "OK" to redownload the data.
After the data finishes downloading, or you have an error, provide a copy of the Message Log following these instructions:
[2026-02-04 16:12:29]
Software version: 2504 64-bit | 2026-02-04 10:26:10.108
Primary Thread ID: 29796 | 2026-02-04 10:26:10.108
Usage end date: 2026-03-07 | 2026-02-04 10:26:10.108
Enabled for: Advanced Features 2. | 2026-02-04 10:26:10.108
Enabled for: Sierra Chart Historical Data Service. | 2026-02-04 10:26:10.108
Enabled for: Denali Real-Time Exchange Data Feed. | 2026-02-04 10:26:10.108
Enabled for: Delayed Denali Exchange Data Feed. | 2026-02-04 10:26:10.108
Enabled for exchange2: CME | 2026-02-04 10:26:10.108
Enabled for exchange2: CBOT (Trading Account Required) | 2026-02-04 10:26:10.108
Enabled for exchange2: COMEX (Trading Account Required) | 2026-02-04 10:26:10.108
Enabled for exchange2: NYMEX (Trading Account Required) | 2026-02-04 10:26:10.108
Enabled for exchange2: CFE | 2026-02-04 10:26:10.108
Allow Support for Sierra Chart Data Feeds is enabled. | 2026-02-04 10:26:10.108
Current selected Data/Trading service: DTC - Sub Instance | 2026-02-04 10:26:10.108
Custom symbol settings values: enabled | 2026-02-04 10:26:10.108
Chart Update Interval: 1000 | 2026-02-04 10:26:10.108
Intraday Data Storage Time Unit: 0 | 2026-02-04 10:26:10.108
Time Zone: -05:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2026-02-04 10:26:10.108
2026-02-04 15:26:10 Local computer time in UTC | 2026-02-04 10:26:10.109
2026-02-04 10:26:10 Local computer time in SC Time Zone | 2026-02-04 10:26:10.109
2026-02-04 08:34:19 Server time in UTC | 2026-02-04 10:26:10.109
Local computer UTC time and Server UTC time difference: 3 seconds. | 2026-02-04 10:26:10.109
Program path: C:\SierraChart\SierraChartInstance_4\ | 2026-02-04 10:26:10.109
Data Files path: C:\SierraChart\SierraChartInstance_4\Data\ | 2026-02-04 10:26:10.109
OS Version Number: 10.0 | 2026-02-04 10:26:10.109
Locale Setting: C | 2026-02-04 10:26:10.109
Crash reporter started: true | 2026-02-04 10:26:10.109
File >> Disconnect selected. | 2026-02-04 10:26:54.875
DTC - Sub Instance | Waiting for socket receive thread to end | 2026-02-04 10:26:54.876
DTC Client socket (5) | CloseSocket call. | 2026-02-04 10:26:54.876
DTC Client socket (5) | Shutdown started. Waiting for graceful close. | 2026-02-04 10:26:54.877
DTC - Sub Instance | Disconnected. | 2026-02-04 10:26:54.878
DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2026-02-04 10:27:05.614
DTC Client socket (3) | Creating socket. | 2026-02-04 10:27:05.614
DTC Client socket (3) | New receive buffer size: 5242880 | 2026-02-04 10:27:05.614
DTC Client socket (3) | Connecting to IP: 127.0.0.1. | 2026-02-04 10:27:05.614
DTC - Sub Instance | Network connection to server complete. | 2026-02-04 10:27:05.616
DTC - Sub Instance | Starting socket receive thread. | 2026-02-04 10:27:05.616
DTC - Sub Instance | Sending encoding request to server: Binary VLS. Compression: none | 2026-02-04 10:27:05.616
DTC - Sub Instance | Setting DTC encoding to Binary VLS | 2026-02-04 10:27:05.848
DTC - Sub Instance | Sending logon request message. | 2026-02-04 10:27:05.848
DTC - Sub Instance | Received logon response. | 2026-02-04 10:27:05.854
DTC - Sub Instance | Server Name: SC DTC Server. Build=45991M. | 2026-02-04 10:27:05.854
DTC - Sub Instance | Server protocol version: 8. Client protocol version: 8 | 2026-02-04 10:27:05.854
DTC - Sub Instance | Successfully connected. Connected to SC DTC Protocol server. Service=scdataallservices|SymbolSettings=scdataallservices. | 2026-02-04 10:27:05.854
DTC - Sub Instance | Trading is supported. | 2026-02-04 10:27:05.854
DTC - Sub Instance | Order cancel and replace is supported. | 2026-02-04 10:27:05.854
DTC - Sub Instance | OCO Orders supported. | 2026-02-04 10:27:05.854
DTC - Sub Instance | Bracket Orders supported. | 2026-02-04 10:27:05.854
DTC - Sub Instance | Connected to server complete. | 2026-02-04 10:27:05.854
Triggering next historical data download in queue. | 2026-02-04 10:27:05.856
No download requests in the queue to start downloads for. | 2026-02-04 10:27:05.857
Received unsolicited security definition for ESH26-CME. ID: 110000000 | 2026-02-04 10:27:05.857
Using symbol data fast lookup vector | 2026-02-04 10:27:05.857
DTC - Sub Instance | Starting real-time market data updates for: ESH26-CME. ID: 1 | 2026-02-04 10:27:05.857
DTC - Sub Instance | Requesting security definition data for: ESH26-CME. ID: 1 | 2026-02-04 10:27:05.857
Requesting market depth updates for: ESH26-CME if supported. | 2026-02-04 10:27:05.857
Added historical Intraday data request for ESH26-CME to the queue. | 2026-02-04 10:27:05.857
Intraday data recording state for symbol ESH26-CME is set to download 'Pending'. | 2026-02-04 10:27:05.857
Triggering next historical data download in queue. | 2026-02-04 10:27:05.857
Added historical Daily data request for ESZ04-CME to the queue. | 2026-02-04 10:27:33.269
Triggering next historical data download in queue. | 2026-02-04 10:27:33.269
Added historical Daily data request for ESH05-CME to the queue. | 2026-02-04 10:27:33.269
Added historical Daily data request for ESM05-CME to the queue. | 2026-02-04 10:27:33.269
Added historical Daily data request for ESU05-CME to the queue. | 2026-02-04 10:27:33.269
Added historical Daily data request for ESZ05-CME to the queue. | 2026-02-04 10:27:33.269
Added historical Daily data request for ESH06-CME to the queue. | 2026-02-04 10:27:33.269
Added historical Daily data request for ESM06-CME to the queue. | 2026-02-04 10:27:33.269
Added historical Daily data request for ESU06-CME to the queue. | 2026-02-04 10:27:33.269
Added historical Daily data request for ESZ06-CME to the queue. | 2026-02-04 10:27:33.269
Added historical Daily data request for ESH07-CME to the queue. | 2026-02-04 10:27:33.269
Added historical Daily data request for ESM07-CME to the queue. | 2026-02-04 10:27:33.269
Added historical Daily data request for ESU07-CME to the queue. | 2026-02-04 10:27:33.269
Added historical Daily data request for ESZ07-CME to the queue. | 2026-02-04 10:27:33.269
Added historical Daily data request for ESH08-CME to the queue. | 2026-02-04 10:27:33.269
Added historical Daily data request for ESM08-CME to the queue. | 2026-02-04 10:27:33.269
Added historical Daily data request for ESU08-CME to the queue. | 2026-02-04 10:27:33.269
Added historical Daily data request for ESZ08-CME to the queue. | 2026-02-04 10:27:33.269
Added historical Daily data request for ESH09-CME to the queue. | 2026-02-04 10:27:33.269
Added historical Daily data request for ESM09-CME to the queue. | 2026-02-04 10:27:33.269
Added historical Daily data request for ESU09-CME to the queue. | 2026-02-04 10:27:33.269
Added historical Daily data request for ESZ09-CME to the queue. | 2026-02-04 10:27:33.269
Added historical Daily data request for ESH10-CME to the queue. | 2026-02-04 10:27:33.269
Added historical Daily data request for ESM10-CME to the queue. | 2026-02-04 10:27:33.269
Added historical Daily data request for ESU10-CME to the queue. | 2026-02-04 10:27:33.269
Added historical Daily data request for ESZ10-CME to the queue. | 2026-02-04 10:27:33.269
Added historical Daily data request for ESH11-CME to the queue. | 2026-02-04 10:27:33.269
Added historical Daily data request for ESM11-CME to the queue. | 2026-02-04 10:27:33.269
Added historical Daily data request for ESU11-CME to the queue. | 2026-02-04 10:27:33.269
Added historical Daily data request for ESZ11-CME to the queue. | 2026-02-04 10:27:33.269
Added historical Daily data request for ESH12-CME to the queue. | 2026-02-04 10:27:33.269
Added historical Daily data request for ESM12-CME to the queue. | 2026-02-04 10:27:33.269
Added historical Daily data request for ESU12-CME to the queue. | 2026-02-04 10:27:33.269
Added historical Daily data request for ESZ12-CME to the queue. | 2026-02-04 10:27:33.269
Added historical Daily data request for ESH13-CME to the queue. | 2026-02-04 10:27:33.269
Added historical Daily data request for ESM13-CME to the queue. | 2026-02-04 10:27:33.269
Added historical Daily data request for ESU13-CME to the queue. | 2026-02-04 10:27:33.269
Added historical Daily data request for ESZ13-CME to the queue. | 2026-02-04 10:27:33.269
Added historical Daily data request for ESH14-CME to the queue. | 2026-02-04 10:27:33.269
Added historical Daily data request for ESM14-CME to the queue. | 2026-02-04 10:27:33.269
Added historical Daily data request for ESU14-CME to the queue. | 2026-02-04 10:27:33.269
Added historical Daily data request for ESZ14-CME to the queue. | 2026-02-04 10:27:33.269
Added historical Daily data request for ESH15-CME to the queue. | 2026-02-04 10:27:33.269
Added historical Daily data request for ESM15-CME to the queue. | 2026-02-04 10:27:33.269
Added historical Daily data request for ESU15-CME to the queue. | 2026-02-04 10:27:33.269
Added historical Daily data request for ESZ15-CME to the queue. | 2026-02-04 10:27:33.269
Added historical Daily data request for ESH16-CME to the queue. | 2026-02-04 10:27:33.269
Added historical Daily data request for ESM16-CME to the queue. | 2026-02-04 10:27:33.269
Added historical Daily data request for ESU16-CME to the queue. | 2026-02-04 10:27:33.269
Added historical Daily data request for ESZ16-CME to the queue. | 2026-02-04 10:27:33.269
Added historical Daily data request for ESH17-CME to the queue. | 2026-02-04 10:27:33.269
Added historical Daily data request for ESM17-CME to the queue. | 2026-02-04 10:27:33.269
Added historical Daily data request for ESU17-CME to the queue. | 2026-02-04 10:27:33.269
Added historical Daily data request for ESZ17-CME to the queue. | 2026-02-04 10:27:33.269
Added historical Daily data request for ESH18-CME to the queue. | 2026-02-04 10:27:33.269
Added historical Daily data request for ESM18-CME to the queue. | 2026-02-04 10:27:33.269
Added historical Daily data request for ESU18-CME to the queue. | 2026-02-04 10:27:33.269
Added historical Daily data request for ESZ18-CME to the queue. | 2026-02-04 10:27:33.269
Added historical Daily data request for ESH19-CME to the queue. | 2026-02-04 10:27:33.269
Added historical Daily data request for ESM19-CME to the queue. | 2026-02-04 10:27:33.269
Added historical Daily data request for ESU19-CME to the queue. | 2026-02-04 10:27:33.269
Added historical Daily data request for ESZ19-CME to the queue. | 2026-02-04 10:27:33.269
Added historical Daily data request for ESH20-CME to the queue. | 2026-02-04 10:27:33.269
Added historical Daily data request for ESM20-CME to the queue. | 2026-02-04 10:27:33.269
Added historical Daily data request for ESU20-CME to the queue. | 2026-02-04 10:27:33.269
Added historical Daily data request for ESZ20-CME to the queue. | 2026-02-04 10:27:33.269
Added historical Daily data request for ESH21-CME to the queue. | 2026-02-04 10:27:33.269
Added historical Daily data request for ESM21-CME to the queue. | 2026-02-04 10:27:33.269
Added historical Daily data request for ESU21-CME to the queue. | 2026-02-04 10:27:33.269
Added historical Daily data request for ESZ21-CME to the queue. | 2026-02-04 10:27:33.269
Added historical Daily data request for ESH22-CME to the queue. | 2026-02-04 10:27:33.269
Added historical Daily data request for ESM22-CME to the queue. | 2026-02-04 10:27:33.269
Added historical Daily data request for ESU22-CME to the queue. | 2026-02-04 10:27:33.269
Added historical Daily data request for ESZ22-CME to the queue. | 2026-02-04 10:27:33.269
Added historical Daily data request for ESH23-CME to the queue. | 2026-02-04 10:27:33.269
Added historical Daily data request for ESM23-CME to the queue. | 2026-02-04 10:27:33.269
Added historical Daily data request for ESU23-CME to the queue. | 2026-02-04 10:27:33.269
Added historical Daily data request for ESZ23-CME to the queue. | 2026-02-04 10:27:33.269
Added historical Daily data request for ESH24-CME to the queue. | 2026-02-04 10:27:33.269
Added historical Daily data request for ESM24-CME to the queue. | 2026-02-04 10:27:33.269
Added historical Daily data request for ESU24-CME to the queue. | 2026-02-04 10:27:33.269
Added historical Daily data request for ESZ24-CME to the queue. | 2026-02-04 10:27:33.269
Added historical Daily data request for ESH25-CME to the queue. | 2026-02-04 10:27:33.269
Added historical Daily data request for ESM25-CME to the queue. | 2026-02-04 10:27:33.269
Added historical Daily data request for ESU25-CME to the queue. | 2026-02-04 10:27:33.269
Added historical Daily data request for ESZ25-CME to the queue. | 2026-02-04 10:27:33.269
Added historical Daily data request for ESH26-CME to the queue. | 2026-02-04 10:27:33.269
Socket (4) | CloseSocket call. | 2026-02-04 10:29:10.759
Socket (4) | Shutdown started. Waiting for graceful close. | 2026-02-04 10:29:10.759
Historical data download thread signaled to stop. | 2026-02-04 10:29:10.759
HD Request # 125 | Received 71062448 Intraday data records from 2024-02-02 11:54:02.352000 to 2025-06-20 09:29:59.576000 (503.9 days. Delay: 229.1 days) and wrote 71062448 records for ESM25-CME | 2026-02-04 10:29:10.760
Enabling compression for file: C:\SierraChart\SierraChartInstance_4\Data\ESM25-CME.scid. This may take a while. | 2026-02-04 10:29:10.760
File compression enabled. C:\SierraChart\SierraChartInstance_4\Data\ESM25-CME.scid. CompressionState=0 | 2026-02-04 10:29:10.760
HD Request # 125 | Add time&sales data | Remembered last file record date-time: 2025-06-20 13:29:59.576000 | 2026-02-04 10:29:10.782
HD Request # 125 | Completion time: 1m 58s. | 2026-02-04 10:29:10.785
HD Request # 125 | Intraday data download complete for ESM25-CME. Unique request ID: 162 | 2026-02-04 10:29:10.785
Removing historical data download ID 162. | 2026-02-04 10:29:10.785
Real-time Intraday chart data file updates started for ESM25-CME | 2026-02-04 10:29:10.785
Intraday chart data file opened for ESM25-CME | 2026-02-04 10:29:10.785
HD Request # 125 | Enabling Intraday chart updating for symbol. | 2026-02-04 10:29:10.785
Triggering next historical data download in queue. | 2026-02-04 11:01:43.860
HD Request # 255 | Downloading Historical Daily chart data for ESZ04-CME. Starting date: 1976-02-05. Service: DTCSubInstance | 2026-02-04 11:01:43.860
HD Request # 255 | Using server: 127.0.0.1 port 11098 | 2026-02-04 11:01:43.860
Socket (4) | Creating socket. | 2026-02-04 11:01:43.860
Socket (4) | New receive buffer size: 5242880 | 2026-02-04 11:01:43.860
Socket (4) | Connecting to IP: 127.0.0.1. | 2026-02-04 11:01:43.860
Socket (5) | Socket gracefully closed by remote side. | 2026-02-04 11:01:43.919
Socket (5) | Closed. | 2026-02-04 11:01:43.919
HD Request # 255 | Setting DTC encoding to Binary VLS | 2026-02-04 11:01:43.959
HD Request # 255 | Sending historical data logon request message. | 2026-02-04 11:01:43.959
HD Request # 255 | Requesting historical Daily data starting at 1976-02-05. | 2026-02-04 11:01:43.959
HD Request # 255 | Data is being downloaded from a remote source. Download will start when this is done. | 2026-02-04 11:01:43.960
HD Request # 255 | Decompressing data. | 2026-02-04 11:01:44.958
HD Request # 255 | Receiving historical Daily data for ESZ04-CME starting at 2004-06-18. | 2026-02-04 11:01:44.959
HD Request # 255 | Writing historical Daily data to the file ESZ04-CME.dly. | 2026-02-04 11:01:44.959
Socket (4) | CloseSocket call. | 2026-02-04 11:01:44.960
Socket (4) | Shutdown started. Waiting for graceful close. | 2026-02-04 11:01:44.960
Historical data download thread signaled to stop. | 2026-02-04 11:01:44.961
HD Request # 255 | Received 128 Daily data records from 2004-06-18 00:00:00 to 2004-12-17 00:00:00 (183.0 days) and wrote 128 records for ESZ04-CME | 2026-02-04 11:01:44.961
HD Request # 255 | Completion time: 1s. | 2026-02-04 11:01:44.961
HD Request # 255 | Daily data download complete for ESZ04-CME. Unique request ID: 256 | 2026-02-04 11:01:44.961
Removing historical data download ID 256. | 2026-02-04 11:01:44.961
Triggering next historical data download in queue. | 2026-02-04 11:01:44.961
HD Request # 256 | Downloading Historical Daily chart data for ESH05-CME. Starting date: 1976-02-05. Service: DTCSubInstance | 2026-02-04 11:01:44.961
HD Request # 256 | Using server: 127.0.0.1 port 11098 | 2026-02-04 11:01:44.961
Socket (4) | Socket gracefully closed by remote side. | 2026-02-04 11:01:44.961
Socket (4) | Closed. | 2026-02-04 11:01:44.961
Socket (5) | Creating socket. | 2026-02-04 11:01:44.962
Socket (5) | New receive buffer size: 5242880 | 2026-02-04 11:01:44.962
Socket (5) | Connecting to IP: 127.0.0.1. | 2026-02-04 11:01:44.962
HD Request # 256 | Setting DTC encoding to Binary VLS | 2026-02-04 11:01:45.305
HD Request # 256 | Sending historical data logon request message. | 2026-02-04 11:01:45.305
HD Request # 256 | Requesting historical Daily data starting at 1976-02-05. | 2026-02-04 11:01:45.306
HD Request # 256 | Data is being downloaded from a remote source. Download will start when this is done. | 2026-02-04 11:01:45.307
Opened cached Intraday file: C:\SierraChart\SierraChartInstance_4\Data\TICK-NYSE.scid. Thread ID: 34596 | 2026-02-04 11:01:45.860
Opened cached Intraday file: C:\SierraChart\SierraChartInstance_4\Data\AUDJPY.scid. Thread ID: 34596 | 2026-02-04 11:01:45.861
Opened cached Intraday file: C:\SierraChart\SierraChartInstance_4\Data\AUDUSD.scid. Thread ID: 34596 | 2026-02-04 11:01:45.861
Opened cached Intraday file: C:\SierraChart\SierraChartInstance_4\Data\BTCG26-CME.scid. Thread ID: 34596 | 2026-02-04 11:01:45.861
Opened cached Intraday file: C:\SierraChart\SierraChartInstance_4\Data\EURJPY.scid. Thread ID: 34596 | 2026-02-04 11:01:45.861
HD Request # 256 | Decompressing data. | 2026-02-04 11:01:46.325
HD Request # 256 | Receiving historical Daily data for ESH05-CME starting at 2004-09-17. | 2026-02-04 11:01:46.325
HD Request # 256 | Writing historical Daily data to the file ESH05-CME.dly. | 2026-02-04 11:01:46.326
Socket (5) | CloseSocket call. | 2026-02-04 11:01:46.327
Socket (5) | Shutdown started. Waiting for graceful close. | 2026-02-04 11:01:46.327
Historical data download thread signaled to stop. | 2026-02-04 11:01:46.328
HD Request # 256 | Received 127 Daily data records from 2004-09-17 00:00:00 to 2005-03-18 00:00:00 (183.0 days) and wrote 127 records for ESH05-CME | 2026-02-04 11:01:46.328
HD Request # 256 | Completion time: 2s. | 2026-02-04 11:01:46.328
HD Request # 256 | Daily data download complete for ESH05-CME. Unique request ID: 257 | 2026-02-04 11:01:46.328
Removing historical data download ID 257. | 2026-02-04 11:01:46.328
Triggering next historical data download in queue. | 2026-02-04 11:01:46.328
HD Request # 257 | Downloading Historical Daily chart data for ESM05-CME. Starting date: 1976-02-05. Service: DTCSubInstance | 2026-02-04 11:01:46.328
Socket (5) | Socket gracefully closed by remote side. | 2026-02-04 11:01:46.328
Socket (5) | Closed. | 2026-02-04 11:01:46.328
HD Request # 257 | Using server: 127.0.0.1 port 11098 | 2026-02-04 11:01:46.329
Socket (4) | Creating socket. | 2026-02-04 11:01:46.329
Socket (4) | New receive buffer size: 5242880 | 2026-02-04 11:01:46.329
Socket (4) | Connecting to IP: 127.0.0.1. | 2026-02-04 11:01:46.329
HD Request # 257 | Setting DTC encoding to Binary VLS | 2026-02-04 11:01:46.550
HD Request # 257 | Sending historical data logon request message. | 2026-02-04 11:01:46.550
HD Request # 257 | Requesting historical Daily data starting at 1976-02-05. | 2026-02-04 11:01:46.551
HD Request # 257 | Data is being downloaded from a remote source. Download will start when this is done. | 2026-02-04 11:01:46.551
HD Request # 257 | Decompressing data. | 2026-02-04 11:01:47.558
HD Request # 257 | Receiving historical Daily data for ESM05-CME starting at 2004-12-17. | 2026-02-04 11:01:47.559
HD Request # 257 | Writing historical Daily data to the file ESM05-CME.dly. | 2026-02-04 11:01:47.559
Socket (4) | CloseSocket call. | 2026-02-04 11:01:47.560
Socket (4) | Shutdown started. Waiting for graceful close. | 2026-02-04 11:01:47.560
Historical data download thread signaled to stop. | 2026-02-04 11:01:47.561
HD Request # 257 | Received 126 Daily data records from 2004-12-17 00:00:00 to 2005-06-17 00:00:00 (183.0 days) and wrote 126 records for ESM05-CME | 2026-02-04 11:01:47.561
HD Request # 257 | Completion time: 1s. | 2026-02-04 11:01:47.561
HD Request # 257 | Daily data download complete for ESM05-CME. Unique request ID: 258 | 2026-02-04 11:01:47.561
Removing historical data download ID 258. | 2026-02-04 11:01:47.561
Triggering next historical data download in queue. | 2026-02-04 11:01:47.561
Socket (4) | Socket gracefully closed by remote side. | 2026-02-04 11:01:47.561
HD Request # 258 | Downloading Historical Daily chart data for ESU05-CME. Starting date: 1976-02-05. Service: DTCSubInstance | 2026-02-04 11:01:47.561
Socket (4) | Closed. | 2026-02-04 11:01:47.561
HD Request # 258 | Using server: 127.0.0.1 port 11098 | 2026-02-04 11:01:47.561
Socket (4) | Creating socket. | 2026-02-04 11:01:47.561
Socket (4) | New receive buffer size: 5242880 | 2026-02-04 11:01:47.561
Socket (4) | Connecting to IP: 127.0.0.1. | 2026-02-04 11:01:47.561
HD Request # 258 | Setting DTC encoding to Binary VLS | 2026-02-04 11:01:47.584
HD Request # 258 | Sending historical data logon request message. | 2026-02-04 11:01:47.584
HD Request # 258 | Requesting historical Daily data starting at 1976-02-05. | 2026-02-04 11:01:47.584
HD Request # 258 | Data is being downloaded from a remote source. Download will start when this is done. | 2026-02-04 11:01:47.586
Opened cached Intraday file: C:\SierraChart\SierraChartInstance_4\Data\BRK.B-NQTV.scid. Thread ID: 11964 | 2026-02-04 11:01:48.400
HD Request # 258 | Decompressing data. | 2026-02-04 11:01:48.579
HD Request # 258 | Receiving historical Daily data for ESU05-CME starting at 2005-03-18. | 2026-02-04 11:01:48.580
HD Request # 258 | Writing historical Daily data to the file ESU05-CME.dly. | 2026-02-04 11:01:48.580
Socket (4) | CloseSocket call. | 2026-02-04 11:01:48.581
Socket (4) | Shutdown started. Waiting for graceful close. | 2026-02-04 11:01:48.581
Historical data download thread signaled to stop. | 2026-02-04 11:01:48.581
HD Request # 258 | Received 127 Daily data records from 2005-03-18 00:00:00 to 2005-09-16 00:00:00 (183.0 days) and wrote 127 records for ESU05-CME | 2026-02-04 11:01:48.581
HD Request # 258 | Completion time: 1s. | 2026-02-04 11:01:48.581
HD Request # 258 | Daily data download complete for ESU05-CME. Unique request ID: 259 | 2026-02-04 11:01:48.581
Removing historical data download ID 259. | 2026-02-04 11:01:48.581
Triggering next historical data download in queue. | 2026-02-04 11:01:48.582
Socket (4) | Socket gracefully closed by remote side. | 2026-02-04 11:01:48.582
HD Request # 259 | Downloading Historical Daily chart data for ESZ05-CME. Starting date: 1976-02-05. Service: DTCSubInstance | 2026-02-04 11:01:48.582
Socket (4) | Closed. | 2026-02-04 11:01:48.582
HD Request # 259 | Using server: 127.0.0.1 port 11098 | 2026-02-04 11:01:48.582
Socket (4) | Creating socket. | 2026-02-04 11:01:48.582
Socket (4) | New receive buffer size: 5242880 | 2026-02-04 11:01:48.582
Socket (4) | Connecting to IP: 127.0.0.1. | 2026-02-04 11:01:48.582
HD Request # 259 | Setting DTC encoding to Binary VLS | 2026-02-04 11:01:48.701
HD Request # 259 | Sending historical data logon request message. | 2026-02-04 11:01:48.701
HD Request # 259 | Requesting historical Daily data starting at 1976-02-05. | 2026-02-04 11:01:48.703
HD Request # 259 | Data is being downloaded from a remote source. Download will start when this is done. | 2026-02-04 11:01:48.704
HD Request # 259 | Decompressing data. | 2026-02-04 11:01:49.708
HD Request # 259 | Receiving historical Daily data for ESZ05-CME starting at 2005-06-17. | 2026-02-04 11:01:49.709
HD Request # 259 | Writing historical Daily data to the file ESZ05-CME.dly. | 2026-02-04 11:01:49.709
Socket (4) | CloseSocket call. | 2026-02-04 11:01:49.710
Socket (4) | Shutdown started. Waiting for graceful close. | 2026-02-04 11:01:49.710
Historical data download thread signaled to stop. | 2026-02-04 11:01:49.711
HD Request # 259 | Received 128 Daily data records from 2005-06-17 00:00:00 to 2005-12-16 00:00:00 (183.0 days) and wrote 128 records for ESZ05-CME | 2026-02-04 11:01:49.711
HD Request # 259 | Completion time: 1s. | 2026-02-04 11:01:49.711
HD Request # 259 | Daily data download complete for ESZ05-CME. Unique request ID: 260 | 2026-02-04 11:01:49.711
Removing historical data download ID 260. | 2026-02-04 11:01:49.711
Triggering next historical data download in queue. | 2026-02-04 11:01:49.711
Socket (4) | Socket gracefully closed by remote side. | 2026-02-04 11:01:49.711
Socket (4) | Closed. | 2026-02-04 11:01:49.711
HD Request # 260 | Downloading Historical Daily chart data for ESH06-CME. Starting date: 1976-02-05. Service: DTCSubInstance | 2026-02-04 11:01:49.711
HD Request # 260 | Using server: 127.0.0.1 port 11098 | 2026-02-04 11:01:49.712
Socket (4) | Creating socket. | 2026-02-04 11:01:49.712
Socket (4) | New receive buffer size: 5242880 | 2026-02-04 11:01:49.712
Socket (4) | Connecting to IP: 127.0.0.1. | 2026-02-04 11:01:49.712
HD Request # 260 | Setting DTC encoding to Binary VLS | 2026-02-04 11:01:49.727
HD Request # 260 | Sending historical data logon request message. | 2026-02-04 11:01:49.727
HD Request # 260 | Requesting historical Daily data starting at 1976-02-05. | 2026-02-04 11:01:49.728
HD Request # 260 | Data is being downloaded from a remote source. Download will start when this is done. | 2026-02-04 11:01:49.728
HD Request # 260 | Decompressing data. | 2026-02-04 11:01:50.742
HD Request # 260 | Receiving historical Daily data for ESH06-CME starting at 2005-09-16. | 2026-02-04 11:01:50.742
HD Request # 260 | Writing historical Daily data to the file ESH06-CME.dly. | 2026-02-04 11:01:50.743
Socket (4) | CloseSocket call. | 2026-02-04 11:01:50.744
Socket (4) | Shutdown started. Waiting for graceful close. | 2026-02-04 11:01:50.744
Historical data download thread signaled to stop. | 2026-02-04 11:01:50.744
HD Request # 260 | Received 126 Daily data records from 2005-09-16 00:00:00 to 2006-03-17 00:00:00 (183.0 days) and wrote 126 records for ESH06-CME | 2026-02-04 11:01:50.744
HD Request # 260 | Completion time: 1s. | 2026-02-04 11:01:50.744
HD Request # 260 | Daily data download complete for ESH06-CME. Unique request ID: 261 | 2026-02-04 11:01:50.744
Removing historical data download ID 261. | 2026-02-04 11:01:50.744
Triggering next historical data download in queue. | 2026-02-04 11:01:50.744
Socket (4) | Socket gracefully closed by remote side. | 2026-02-04 11:01:50.745
HD Request # 261 | Downloading Historical Daily chart data for ESM06-CME. Starting date: 1976-02-05. Service: DTCSubInstance | 2026-02-04 11:01:50.745
Socket (4) | Closed. | 2026-02-04 11:01:50.745
HD Request # 261 | Using server: 127.0.0.1 port 11098 | 2026-02-04 11:01:50.745
Socket (4) | Creating socket. | 2026-02-04 11:01:50.745
Socket (4) | New receive buffer size: 5242880 | 2026-02-04 11:01:50.745
Socket (4) | Connecting to IP: 127.0.0.1. | 2026-02-04 11:01:50.745
HD Request # 261 | Setting DTC encoding to Binary VLS | 2026-02-04 11:01:50.760
HD Request # 261 | Sending historical data logon request message. | 2026-02-04 11:01:50.760
HD Request # 261 | Requesting historical Daily data starting at 1976-02-05. | 2026-02-04 11:01:50.760
HD Request # 261 | Data is being downloaded from a remote source. Download will start when this is done. | 2026-02-04 11:01:50.761
HD Request # 261 | Decompressing data. | 2026-02-04 11:01:51.782
HD Request # 261 | Receiving historical Daily data for ESM06-CME starting at 2005-12-16. | 2026-02-04 11:01:51.783
HD Request # 261 | Writing historical Daily data to the file ESM06-CME.dly. | 2026-02-04 11:01:51.784
Socket (4) | CloseSocket call. | 2026-02-04 11:01:51.785
Socket (4) | Shutdown started. Waiting for graceful close. | 2026-02-04 11:01:51.785
Historical data download thread signaled to stop. | 2026-02-04 11:01:51.785
HD Request # 261 | Received 125 Daily data records from 2005-12-16 00:00:00 to 2006-06-16 00:00:00 (183.0 days) and wrote 125 records for ESM06-CME | 2026-02-04 11:01:51.785
HD Request # 261 | Completion time: 1s. | 2026-02-04 11:01:51.785
HD Request # 261 | Daily data download complete for ESM06-CME. Unique request ID: 262 | 2026-02-04 11:01:51.785
Removing historical data download ID 262. | 2026-02-04 11:01:51.785
Triggering next historical data download in queue. | 2026-02-04 11:01:51.786
Socket (4) | Socket gracefully closed by remote side. | 2026-02-04 11:01:51.786
Socket (4) | Closed. | 2026-02-04 11:01:51.786
HD Request # 262 | Downloading Historical Daily chart data for ESU06-CME. Starting date: 1976-02-05. Service: DTCSubInstance | 2026-02-04 11:01:51.786
HD Request # 262 | Using server: 127.0.0.1 port 11098 | 2026-02-04 11:01:51.786
Socket (4) | Creating socket. | 2026-02-04 11:01:51.786
Socket (4) | New receive buffer size: 5242880 | 2026-02-04 11:01:51.786
Socket (4) | Connecting to IP: 127.0.0.1. | 2026-02-04 11:01:51.786
HD Request # 262 | Setting DTC encoding to Binary VLS | 2026-02-04 11:01:52.069
HD Request # 262 | Sending historical data logon request message. | 2026-02-04 11:01:52.069
HD Request # 262 | Requesting historical Daily data starting at 1976-02-05. | 2026-02-04 11:01:52.070
HD Request # 262 | Data is being downloaded from a remote source. Download will start when this is done. | 2026-02-04 11:01:52.071
HD Request # 262 | Decompressing data. | 2026-02-04 11:01:53.065
HD Request # 262 | Receiving historical Daily data for ESU06-CME starting at 2006-03-17. | 2026-02-04 11:01:53.065
HD Request # 262 | Writing historical Daily data to the file ESU06-CME.dly. | 2026-02-04 11:01:53.066
Socket (4) | CloseSocket call. | 2026-02-04 11:01:53.067
Socket (4) | Shutdown started. Waiting for graceful close. | 2026-02-04 11:01:53.067
Historical data download thread signaled to stop. | 2026-02-04 11:01:53.067
HD Request # 262 | Received 127 Daily data records from 2006-03-17 00:00:00 to 2006-09-15 00:00:00 (183.0 days) and wrote 127 records for ESU06-CME | 2026-02-04 11:01:53.067
HD Request # 262 | Completion time: 2s. | 2026-02-04 11:01:53.067
HD Request # 262 | Daily data download complete for ESU06-CME. Unique request ID: 263 | 2026-02-04 11:01:53.067
Removing historical data download ID 263. | 2026-02-04 11:01:53.067
Triggering next historical data download in queue. | 2026-02-04 11:01:53.067
Socket (4) | Socket gracefully closed by remote side. | 2026-02-04 11:01:53.068
Socket (4) | Closed. | 2026-02-04 11:01:53.068
HD Request # 263 | Downloading Historical Daily chart data for ESZ06-CME. Starting date: 1976-02-05. Service: DTCSubInstance | 2026-02-04 11:01:53.068
HD Request # 263 | Using server: 127.0.0.1 port 11098 | 2026-02-04 11:01:53.068
Socket (4) | Creating socket. | 2026-02-04 11:01:53.068
Socket (4) | New receive buffer size: 5242880 | 2026-02-04 11:01:53.068
Socket (4) | Connecting to IP: 127.0.0.1. | 2026-02-04 11:01:53.068
HD Request # 263 | Setting DTC encoding to Binary VLS | 2026-02-04 11:01:53.389
HD Request # 263 | Sending historical data logon request message. | 2026-02-04 11:01:53.389
HD Request # 263 | Requesting historical Daily data starting at 1976-02-05. | 2026-02-04 11:01:53.390
HD Request # 263 | Data is being downloaded from a remote source. Download will start when this is done. | 2026-02-04 11:01:53.391
HD Request # 263 | Decompressing data. | 2026-02-04 11:01:54.436
HD Request # 263 | Receiving historical Daily data for ESZ06-CME starting at 2006-06-16. | 2026-02-04 11:01:54.437
HD Request # 263 | Writing historical Daily data to the file ESZ06-CME.dly. | 2026-02-04 11:01:54.437
Socket (4) | CloseSocket call. | 2026-02-04 11:01:54.439
Socket (4) | Shutdown started. Waiting for graceful close. | 2026-02-04 11:01:54.439
Historical data download thread signaled to stop. | 2026-02-04 11:01:54.439
HD Request # 263 | Received 128 Daily data records from 2006-06-16 00:00:00 to 2006-12-15 00:00:00 (183.0 days) and wrote 128 records for ESZ06-CME | 2026-02-04 11:01:54.439
HD Request # 263 | Completion time: 1s. | 2026-02-04 11:01:54.439
HD Request # 263 | Daily data download complete for ESZ06-CME. Unique request ID: 264 | 2026-02-04 11:01:54.439
Removing historical data download ID 264. | 2026-02-04 11:01:54.439
Triggering next historical data download in queue. | 2026-02-04 11:01:54.439
HD Request # 264 | Downloading Historical Daily chart data for ESH07-CME. Starting date: 1976-02-05. Service: DTCSubInstance | 2026-02-04 11:01:54.439
HD Request # 264 | Using server: 127.0.0.1 port 11098 | 2026-02-04 11:01:54.439
Socket (4) | Socket gracefully closed by remote side. | 2026-02-04 11:01:54.439
Socket (4) | Closed. | 2026-02-04 11:01:54.439
Socket (5) | Creating socket. | 2026-02-04 11:01:54.440
Socket (5) | New receive buffer size: 5242880 | 2026-02-04 11:01:54.440
Socket (5) | Connecting to IP: 127.0.0.1. | 2026-02-04 11:01:54.440
HD Request # 264 | Setting DTC encoding to Binary VLS | 2026-02-04 11:01:54.696
HD Request # 264 | Sending historical data logon request message. | 2026-02-04 11:01:54.696
HD Request # 264 | Requesting historical Daily data starting at 1976-02-05. | 2026-02-04 11:01:54.697
HD Request # 264 | Data is being downloaded from a remote source. Download will start when this is done. | 2026-02-04 11:01:54.699
HD Request # 264 | Decompressing data. | 2026-02-04 11:01:55.704
HD Request # 264 | Receiving historical Daily data for ESH07-CME starting at 2006-09-15. | 2026-02-04 11:01:55.705
HD Request # 264 | Writing historical Daily data to the file ESH07-CME.dly. | 2026-02-04 11:01:55.705
Socket (5) | CloseSocket call. | 2026-02-04 11:01:55.706
Socket (5) | Shutdown started. Waiting for graceful close. | 2026-02-04 11:01:55.706
Historical data download thread signaled to stop. | 2026-02-04 11:01:55.706
HD Request # 264 | Received 125 Daily data records from 2006-09-15 00:00:00 to 2007-03-16 00:00:00 (183.0 days) and wrote 125 records for ESH07-CME | 2026-02-04 11:01:55.706
HD Request # 264 | Completion time: 1s. | 2026-02-04 11:01:55.706
HD Request # 264 | Daily data download complete for ESH07-CME. Unique request ID: 265 | 2026-02-04 11:01:55.706
Removing historical data download ID 265. | 2026-02-04 11:01:55.706
Triggering next historical data download in queue. | 2026-02-04 11:01:55.706
HD Request # 265 | Downloading Historical Daily chart data for ESM07-CME. Starting date: 1976-02-05. Service: DTCSubInstance | 2026-02-04 11:01:55.707
HD Request # 265 | Using server: 127.0.0.1 port 11098 | 2026-02-04 11:01:55.707
Socket (4) | Creating socket. | 2026-02-04 11:01:55.707
Socket (4) | New receive buffer size: 5242880 | 2026-02-04 11:01:55.707
Socket (4) | Connecting to IP: 127.0.0.1. | 2026-02-04 11:01:55.707
Socket (5) | Socket gracefully closed by remote side. | 2026-02-04 11:01:55.709
Socket (5) | Closed. | 2026-02-04 11:01:55.709
HD Request # 265 | Setting DTC encoding to Binary VLS | 2026-02-04 11:01:55.961
HD Request # 265 | Sending historical data logon request message. | 2026-02-04 11:01:55.961
HD Request # 265 | Requesting historical Daily data starting at 1976-02-05. | 2026-02-04 11:01:55.962
HD Request # 265 | Data is being downloaded from a remote source. Download will start when this is done. | 2026-02-04 11:01:55.963
HD Request # 265 | Decompressing data. | 2026-02-04 11:01:56.972
HD Request # 265 | Receiving historical Daily data for ESM07-CME starting at 2006-12-15. | 2026-02-04 11:01:56.973
HD Request # 265 | Writing historical Daily data to the file ESM07-CME.dly. | 2026-02-04 11:01:56.974
Socket (4) | CloseSocket call. | 2026-02-04 11:01:56.975
Socket (4) | Shutdown started. Waiting for graceful close. | 2026-02-04 11:01:56.975
Historical data download thread signaled to stop. | 2026-02-04 11:01:56.975
HD Request # 265 | Received 124 Daily data records from 2006-12-15 00:00:00 to 2007-06-15 00:00:00 (183.0 days) and wrote 124 records for ESM07-CME | 2026-02-04 11:01:56.975
HD Request # 265 | Completion time: 1s. | 2026-02-04 11:01:56.975
HD Request # 265 | Daily data download complete for ESM07-CME. Unique request ID: 266 | 2026-02-04 11:01:56.975
Removing historical data download ID 266. | 2026-02-04 11:01:56.975
Triggering next historical data download in queue. | 2026-02-04 11:01:56.975
HD Request # 266 | Downloading Historical Daily chart data for ESU07-CME. Starting date: 1976-02-05. Service: DTCSubInstance | 2026-02-04 11:01:56.976
HD Request # 266 | Using server: 127.0.0.1 port 11098 | 2026-02-04 11:01:56.976
Socket (5) | Creating socket. | 2026-02-04 11:01:56.976
Socket (5) | New receive buffer size: 5242880 | 2026-02-04 11:01:56.976
Socket (5) | Connecting to IP: 127.0.0.1. | 2026-02-04 11:01:56.976
Socket (4) | Socket gracefully closed by remote side. | 2026-02-04 11:01:56.976
Socket (4) | Closed. | 2026-02-04 11:01:56.976
HD Request # 266 | Setting DTC encoding to Binary VLS | 2026-02-04 11:01:57.166
HD Request # 266 | Sending historical data logon request message. | 2026-02-04 11:01:57.166
HD Request # 266 | Requesting historical Daily data starting at 1976-02-05. | 2026-02-04 11:01:57.167
HD Request # 266 | Data is being downloaded from a remote source. Download will start when this is done. | 2026-02-04 11:01:57.169
HD Request # 266 | Decompressing data. | 2026-02-04 11:01:58.172
HD Request # 266 | Receiving historical Daily data for ESU07-CME starting at 2007-03-20. | 2026-02-04 11:01:58.173
HD Request # 266 | Writing historical Daily data to the file ESU07-CME.dly. | 2026-02-04 11:01:58.173
Socket (5) | CloseSocket call. | 2026-02-04 11:01:58.174
Socket (5) | Shutdown started. Waiting for graceful close. | 2026-02-04 11:01:58.174
Historical data download thread signaled to stop. | 2026-02-04 11:01:58.175
HD Request # 266 | Received 129 Daily data records from 2007-03-20 00:00:00 to 2007-09-20 00:00:00 (185.0 days) and wrote 129 records for ESU07-CME | 2026-02-04 11:01:58.175
HD Request # 266 | Completion time: 2s. | 2026-02-04 11:01:58.175
HD Request # 266 | Daily data download complete for ESU07-CME. Unique request ID: 267 | 2026-02-04 11:01:58.175
Removing historical data download ID 267. | 2026-02-04 11:01:58.175
Triggering next historical data download in queue. | 2026-02-04 11:01:58.175
HD Request # 267 | Downloading Historical Daily chart data for ESZ07-CME. Starting date: 1976-02-05. Service: DTCSubInstance | 2026-02-04 11:01:58.175
Socket (5) | Socket gracefully closed by remote side. | 2026-02-04 11:01:58.175
Socket (5) | Closed. | 2026-02-04 11:01:58.175
HD Request # 267 | Using server: 127.0.0.1 port 11098 | 2026-02-04 11:01:58.175
Socket (4) | Creating socket. | 2026-02-04 11:01:58.175
Socket (4) | New receive buffer size: 5242880 | 2026-02-04 11:01:58.176
Socket (4) | Connecting to IP: 127.0.0.1. | 2026-02-04 11:01:58.176
HD Request # 267 | Setting DTC encoding to Binary VLS | 2026-02-04 11:01:58.511
HD Request # 267 | Sending historical data logon request message. | 2026-02-04 11:01:58.511
HD Request # 267 | Requesting historical Daily data starting at 1976-02-05. | 2026-02-04 11:01:58.513
HD Request # 267 | Data is being downloaded from a remote source. Download will start when this is done. | 2026-02-04 11:01:58.517
HD Request # 267 | Decompressing data. | 2026-02-04 11:01:59.517
HD Request # 267 | Receiving historical Daily data for ESZ07-CME starting at 2007-06-15. | 2026-02-04 11:01:59.519
HD Request # 267 | Writing historical Daily data to the file ESZ07-CME.dly. | 2026-02-04 11:01:59.519
Socket (4) | CloseSocket call. | 2026-02-04 11:01:59.520
Socket (4) | Shutdown started. Waiting for graceful close. | 2026-02-04 11:01:59.520
Historical data download thread signaled to stop. | 2026-02-04 11:01:59.521
HD Request # 267 | Received 132 Daily data records from 2007-06-15 00:00:00 to 2007-12-20 00:00:00 (189.0 days) and wrote 132 records for ESZ07-CME | 2026-02-04 11:01:59.521
HD Request # 267 | Completion time: 1s. | 2026-02-04 11:01:59.521
HD Request # 267 | Daily data download complete for ESZ07-CME. Unique request ID: 268 | 2026-02-04 11:01:59.521
Removing historical data download ID 268. | 2026-02-04 11:01:59.521
Triggering next historical data download in queue. | 2026-02-04 11:01:59.521
HD Request # 268 | Downloading Historical Daily chart data for ESH08-CME. Starting date: 1976-02-05. Service: DTCSubInstance | 2026-02-04 11:01:59.521
HD Request # 268 | Using server: 127.0.0.1 port 11098 | 2026-02-04 11:01:59.521
Socket (5) | Creating socket. | 2026-02-04 11:01:59.521
Socket (5) | New receive buffer size: 5242880 | 2026-02-04 11:01:59.521
Socket (5) | Connecting to IP: 127.0.0.1. | 2026-02-04 11:01:59.521
Socket (4) | Socket gracefully closed by remote side. | 2026-02-04 11:01:59.521
Socket (4) | Closed. | 2026-02-04 11:01:59.521
HD Request # 268 | Setting DTC encoding to Binary VLS | 2026-02-04 11:01:59.849
HD Request # 268 | Sending historical data logon request message. | 2026-02-04 11:01:59.849
HD Request # 268 | Requesting historical Daily data starting at 1976-02-05. | 2026-02-04 11:01:59.850
HD Request # 268 | Data is being downloaded from a remote source. Download will start when this is done. | 2026-02-04 11:01:59.851
HD Request # 268 | Decompressing data. | 2026-02-04 11:02:01.858
HD Request # 268 | Receiving historical Daily data for ESH08-CME starting at 2007-06-22. | 2026-02-04 11:02:01.860
HD Request # 268 | Writing historical Daily data to the file ESH08-CME.dly. | 2026-02-04 11:02:01.860
Socket (5) | CloseSocket call. | 2026-02-04 11:02:01.861
Socket (5) | Shutdown started. Waiting for graceful close. | 2026-02-04 11:02:01.861
Historical data download thread signaled to stop. | 2026-02-04 11:02:01.862
HD Request # 268 | Received 188 Daily data records from 2007-06-22 00:00:00 to 2008-03-20 00:00:00 (273.0 days) and wrote 188 records for ESH08-CME | 2026-02-04 11:02:01.862
HD Request # 268 | Completion time: 2s. | 2026-02-04 11:02:01.862
HD Request # 268 | Daily data download complete for ESH08-CME. Unique request ID: 269 | 2026-02-04 11:02:01.862
Removing historical data download ID 269. | 2026-02-04 11:02:01.862
Triggering next historical data download in queue. | 2026-02-04 11:02:01.862
HD Request # 269 | Downloading Historical Daily chart data for ESM08-CME. Starting date: 1976-02-05. Service: DTCSubInstance | 2026-02-04 11:02:01.863
HD Request # 269 | Using server: 127.0.0.1 port 11098 | 2026-02-04 11:02:01.863
Socket (4) | Creating socket. | 2026-02-04 11:02:01.863
Socket (4) | New receive buffer size: 5242880 | 2026-02-04 11:02:01.863
Socket (4) | Connecting to IP: 127.0.0.1. | 2026-02-04 11:02:01.863
Socket (5) | Socket gracefully closed by remote side. | 2026-02-04 11:02:01.867
Socket (5) | Closed. | 2026-02-04 11:02:01.867
HD Request # 269 | Setting DTC encoding to Binary VLS | 2026-02-04 11:02:01.939
HD Request # 269 | Sending historical data logon request message. | 2026-02-04 11:02:01.939
HD Request # 269 | Requesting historical Daily data starting at 1976-02-05. | 2026-02-04 11:02:01.940
HD Request # 269 | Data is being downloaded from a remote source. Download will start when this is done. | 2026-02-04 11:02:01.942
HD Request # 269 | Decompressing data. | 2026-02-04 11:02:02.940
HD Request # 269 | Receiving historical Daily data for ESM08-CME starting at 2007-06-22. | 2026-02-04 11:02:02.942
HD Request # 269 | Writing historical Daily data to the file ESM08-CME.dly. | 2026-02-04 11:02:02.942
Socket (4) | CloseSocket call. | 2026-02-04 11:02:02.944
Socket (4) | Shutdown started. Waiting for graceful close. | 2026-02-04 11:02:02.944
Historical data download thread signaled to stop. | 2026-02-04 11:02:02.944
HD Request # 269 | Received 251 Daily data records from 2007-06-22 00:00:00 to 2008-06-19 00:00:00 (364.0 days) and wrote 251 records for ESM08-CME | 2026-02-04 11:02:02.944
HD Request # 269 | Completion time: 1s. | 2026-02-04 11:02:02.944
HD Request # 269 | Daily data download complete for ESM08-CME. Unique request ID: 270 | 2026-02-04 11:02:02.944
Removing historical data download ID 270. | 2026-02-04 11:02:02.944
Triggering next historical data download in queue. | 2026-02-04 11:02:02.944
HD Request # 270 | Downloading Historical Daily chart data for ESU08-CME. Starting date: 1976-02-05. Service: DTCSubInstance | 2026-02-04 11:02:02.944
HD Request # 270 | Using server: 127.0.0.1 port 11098 | 2026-02-04 11:02:02.944
Socket (5) | Creating socket. | 2026-02-04 11:02:02.944
Socket (5) | New receive buffer size: 5242880 | 2026-02-04 11:02:02.945
Socket (5) | Connecting to IP: 127.0.0.1. | 2026-02-04 11:02:02.945
Socket (4) | Socket gracefully closed by remote side. | 2026-02-04 11:02:02.951
Socket (4) | Closed. | 2026-02-04 11:02:02.951
HD Request # 270 | Setting DTC encoding to Binary VLS | 2026-02-04 11:02:03.020
HD Request # 270 | Sending historical data logon request message. | 2026-02-04 11:02:03.020
HD Request # 270 | Requesting historical Daily data starting at 1976-02-05. | 2026-02-04 11:02:03.021
HD Request # 270 | Data is being downloaded from a remote source. Download will start when this is done. | 2026-02-04 11:02:03.022
HD Request # 270 | Decompressing data. | 2026-02-04 11:02:05.033
HD Request # 270 | Receiving historical Daily data for ESU08-CME starting at 2007-06-22. | 2026-02-04 11:02:05.035
HD Request # 270 | Writing historical Daily data to the file ESU08-CME.dly. | 2026-02-04 11:02:05.036
Socket (5) | CloseSocket call. | 2026-02-04 11:02:05.037
Socket (5) | Shutdown started. Waiting for graceful close. | 2026-02-04 11:02:05.037
Historical data download thread signaled to stop. | 2026-02-04 11:02:05.038
HD Request # 270 | Received 314 Daily data records from 2007-06-22 00:00:00 to 2008-09-18 00:00:00 (455.0 days) and wrote 314 records for ESU08-CME | 2026-02-04 11:02:05.038
HD Request # 270 | Completion time: 3s. | 2026-02-04 11:02:05.038
HD Request # 270 | Daily data download complete for ESU08-CME. Unique request ID: 271 | 2026-02-04 11:02:05.038
Removing historical data download ID 271. | 2026-02-04 11:02:05.038
Triggering next historical data download in queue. | 2026-02-04 11:02:05.038
HD Request # 271 | Downloading Historical Daily chart data for ESZ08-CME. Starting date: 1976-02-05. Service: DTCSubInstance | 2026-02-04 11:02:05.038
HD Request # 271 | Using server: 127.0.0.1 port 11098 | 2026-02-04 11:02:05.038
Socket (4) | Creating socket. | 2026-02-04 11:02:05.038
Socket (4) | New receive buffer size: 5242880 | 2026-02-04 11:02:05.038
Socket (4) | Connecting to IP: 127.0.0.1. | 2026-02-04 11:02:05.038
Socket (5) | Socket gracefully closed by remote side. | 2026-02-04 11:02:05.040
Socket (5) | Closed. | 2026-02-04 11:02:05.040
HD Request # 271 | Setting DTC encoding to Binary VLS | 2026-02-04 11:02:05.094
HD Request # 271 | Sending historical data logon request message. | 2026-02-04 11:02:05.094
HD Request # 271 | Requesting historical Daily data starting at 1976-02-05. | 2026-02-04 11:02:05.096
HD Request # 271 | Data is being downloaded from a remote source. Download will start when this is done. | 2026-02-04 11:02:05.099
HD Request # 271 | Decompressing data. | 2026-02-04 11:02:06.093
HD Request # 271 | Receiving historical Daily data for ESZ08-CME starting at 2007-09-21. | 2026-02-04 11:02:06.096
HD Request # 271 | Writing historical Daily data to the file ESZ08-CME.dly. | 2026-02-04 11:02:06.096
Socket (4) | CloseSocket call. | 2026-02-04 11:02:06.098
Socket (4) | Shutdown started. Waiting for graceful close. | 2026-02-04 11:02:06.098
Historical data download thread signaled to stop. | 2026-02-04 11:02:06.098
HD Request # 271 | Received 315 Daily data records from 2007-09-21 00:00:00 to 2008-12-18 00:00:00 (455.0 days) and wrote 315 records for ESZ08-CME | 2026-02-04 11:02:06.098
HD Request # 271 | Completion time: 1s. | 2026-02-04 11:02:06.098
HD Request # 271 | Daily data download complete for ESZ08-CME. Unique request ID: 272 | 2026-02-04 11:02:06.098
Removing historical data download ID 272. | 2026-02-04 11:02:06.098
Triggering next historical data download in queue. | 2026-02-04 11:02:06.099
HD Request # 272 | Downloading Historical Daily chart data for ESH09-CME. Starting date: 1976-02-05. Service: DTCSubInstance | 2026-02-04 11:02:06.099
HD Request # 272 | Using server: 127.0.0.1 port 11098 | 2026-02-04 11:02:06.099
Socket (5) | Creating socket. | 2026-02-04 11:02:06.099
Socket (5) | New receive buffer size: 5242880 | 2026-02-04 11:02:06.099
Socket (5) | Connecting to IP: 127.0.0.1. | 2026-02-04 11:02:06.099
Socket (4) | Socket gracefully closed by remote side. | 2026-02-04 11:02:06.099
Socket (4) | Closed. | 2026-02-04 11:02:06.099
HD Request # 272 | Setting DTC encoding to Binary VLS | 2026-02-04 11:02:06.566
HD Request # 272 | Sending historical data logon request message. | 2026-02-04 11:02:06.566
HD Request # 272 | Requesting historical Daily data starting at 1976-02-05. | 2026-02-04 11:02:06.567
HD Request # 272 | Data is being downloaded from a remote source. Download will start when this is done. | 2026-02-04 11:02:06.569
HD Request # 272 | Decompressing data. | 2026-02-04 11:02:07.566
HD Request # 272 | Receiving historical Daily data for ESH09-CME starting at 2007-12-21. | 2026-02-04 11:02:07.568
HD Request # 272 | Writing historical Daily data to the file ESH09-CME.dly. | 2026-02-04 11:02:07.568
Socket (5) | CloseSocket call. | 2026-02-04 11:02:07.570
Socket (5) | Shutdown started. Waiting for graceful close. | 2026-02-04 11:02:07.570
Historical data download thread signaled to stop. | 2026-02-04 11:02:07.570
HD Request # 272 | Received 312 Daily data records from 2007-12-21 00:00:00 to 2009-03-19 00:00:00 (455.0 days) and wrote 312 records for ESH09-CME | 2026-02-04 11:02:07.570
HD Request # 272 | Completion time: 1s. | 2026-02-04 11:02:07.570
HD Request # 272 | Daily data download complete for ESH09-CME. Unique request ID: 273 | 2026-02-04 11:02:07.570
Removing historical data download ID 273. | 2026-02-04 11:02:07.570
Triggering next historical data download in queue. | 2026-02-04 11:02:07.570
Socket (5) | Socket gracefully closed by remote side. | 2026-02-04 11:02:07.571
HD Request # 273 | Downloading Historical Daily chart data for ESM09-CME. Starting date: 1976-02-05. Service: DTCSubInstance | 2026-02-04 11:02:07.571
Socket (5) | Closed. | 2026-02-04 11:02:07.571
HD Request # 273 | Using server: 127.0.0.1 port 11098 | 2026-02-04 11:02:07.571
Socket (4) | Creating socket. | 2026-02-04 11:02:07.571
Socket (4) | New receive buffer size: 5242880 | 2026-02-04 11:02:07.571
Socket (4) | Connecting to IP: 127.0.0.1. | 2026-02-04 11:02:07.571
HD Request # 273 | Setting DTC encoding to Binary VLS | 2026-02-04 11:02:08.097
HD Request # 273 | Sending historical data logon request message. | 2026-02-04 11:02:08.097
HD Request # 273 | Requesting historical Daily data starting at 1976-02-05. | 2026-02-04 11:02:08.097
HD Request # 273 | Data is being downloaded from a remote source. Download will start when this is done. | 2026-02-04 11:02:08.099
HD Request # 273 | Decompressing data. | 2026-02-04 11:02:09.107
HD Request # 273 | Receiving historical Daily data for ESM09-CME starting at 2008-03-20. | 2026-02-04 11:02:09.110
HD Request # 273 | Writing historical Daily data to the file ESM09-CME.dly. | 2026-02-04 11:02:09.110
Socket (4) | CloseSocket call. | 2026-02-04 11:02:09.112
Socket (4) | Shutdown started. Waiting for graceful close. | 2026-02-04 11:02:09.112
Historical data download thread signaled to stop. | 2026-02-04 11:02:09.113
HD Request # 273 | Received 315 Daily data records from 2008-03-20 00:00:00 to 2009-06-18 00:00:00 (456.0 days) and wrote 315 records for ESM09-CME | 2026-02-04 11:02:09.113
HD Request # 273 | Completion time: 2s. | 2026-02-04 11:02:09.113
HD Request # 273 | Daily data download complete for ESM09-CME. Unique request ID: 274 | 2026-02-04 11:02:09.113
Removing historical data download ID 274. | 2026-02-04 11:02:09.113
Triggering next historical data download in queue. | 2026-02-04 11:02:09.113
HD Request # 274 | Downloading Historical Daily chart data for ESU09-CME. Starting date: 1976-02-05. Service: DTCSubInstance | 2026-02-04 11:02:09.113
HD Request # 274 | Using server: 127.0.0.1 port 11098 | 2026-02-04 11:02:09.113
Socket (5) | Creating socket. | 2026-02-04 11:02:09.113
Socket (5) | New receive buffer size: 5242880 | 2026-02-04 11:02:09.113
Socket (5) | Connecting to IP: 127.0.0.1. | 2026-02-04 11:02:09.113
Socket (4) | Socket gracefully closed by remote side. | 2026-02-04 11:02:09.114
Socket (4) | Closed. | 2026-02-04 11:02:09.114
HD Request # 274 | Setting DTC encoding to Binary VLS | 2026-02-04 11:02:09.498
HD Request # 274 | Sending historical data logon request message. | 2026-02-04 11:02:09.498
HD Request # 274 | Requesting historical Daily data starting at 1976-02-05. | 2026-02-04 11:02:09.498
HD Request # 274 | Data is being downloaded from a remote source. Download will start when this is done. | 2026-02-04 11:02:09.499
HD Request # 274 | Decompressing data. | 2026-02-04 11:02:10.501
HD Request # 274 | Receiving historical Daily data for ESU09-CME starting at 2008-06-20. | 2026-02-04 11:02:10.502
HD Request # 274 | Writing historical Daily data to the file ESU09-CME.dly. | 2026-02-04 11:02:10.502
Socket (5) | CloseSocket call. | 2026-02-04 11:02:10.504
Socket (5) | Shutdown started. Waiting for graceful close. | 2026-02-04 11:02:10.504
Historical data download thread signaled to stop. | 2026-02-04 11:02:10.504
HD Request # 274 | Received 314 Daily data records from 2008-06-20 00:00:00 to 2009-09-17 00:00:00 (455.0 days) and wrote 314 records for ESU09-CME | 2026-02-04 11:02:10.504
HD Request # 274 | Completion time: 1s. | 2026-02-04 11:02:10.504
HD Request # 274 | Daily data download complete for ESU09-CME. Unique request ID: 275 | 2026-02-04 11:02:10.504
Removing historical data download ID 275. | 2026-02-04 11:02:10.504
Triggering next historical data download in queue. | 2026-02-04 11:02:10.504
HD Request # 275 | Downloading Historical Daily chart data for ESZ09-CME. Starting date: 1976-02-05. Service: DTCSubInstance | 2026-02-04 11:02:10.505
HD Request # 275 | Using server: 127.0.0.1 port 11098 | 2026-02-04 11:02:10.505
Socket (4) | Creating socket. | 2026-02-04 11:02:10.505
Socket (4) | New receive buffer size: 5242880 | 2026-02-04 11:02:10.505
Socket (4) | Connecting to IP: 127.0.0.1. | 2026-02-04 11:02:10.505
Socket (5) | Socket gracefully closed by remote side. | 2026-02-04 11:02:10.505
Socket (5) | Closed. | 2026-02-04 11:02:10.505
HD Request # 275 | Setting DTC encoding to Binary VLS | 2026-02-04 11:02:10.632
HD Request # 275 | Sending historical data logon request message. | 2026-02-04 11:02:10.632
HD Request # 275 | Requesting historical Daily data starting at 1976-02-05. | 2026-02-04 11:02:10.633
HD Request # 275 | Data is being downloaded from a remote source. Download will start when this is done. | 2026-02-04 11:02:10.635
HD Request # 275 | Decompressing data. | 2026-02-04 11:02:11.643
HD Request # 275 | Receiving historical Daily data for ESZ09-CME starting at 2008-09-19. | 2026-02-04 11:02:11.645
HD Request # 275 | Writing historical Daily data to the file ESZ09-CME.dly. | 2026-02-04 11:02:11.645
Socket (4) | CloseSocket call. | 2026-02-04 11:02:11.646
Socket (4) | Shutdown started. Waiting for graceful close. | 2026-02-04 11:02:11.646
Historical data download thread signaled to stop. | 2026-02-04 11:02:11.646
HD Request # 275 | Received 315 Daily data records from 2008-09-19 00:00:00 to 2009-12-17 00:00:00 (455.0 days) and wrote 315 records for ESZ09-CME | 2026-02-04 11:02:11.647
HD Request # 275 | Completion time: 1s. | 2026-02-04 11:02:11.647
HD Request # 275 | Daily data download complete for ESZ09-CME. Unique request ID: 276 | 2026-02-04 11:02:11.647
Removing historical data download ID 276. | 2026-02-04 11:02:11.647
Triggering next historical data download in queue. | 2026-02-04 11:02:11.647
HD Request # 276 | Downloading Historical Daily chart data for ESH10-CME. Starting date: 1976-02-05. Service: DTCSubInstance | 2026-02-04 11:02:11.647
HD Request # 276 | Using server: 127.0.0.1 port 11098 | 2026-02-04 11:02:11.647
Socket (5) | Creating socket. | 2026-02-04 11:02:11.647
Socket (5) | New receive buffer size: 5242880 | 2026-02-04 11:02:11.647
Socket (5) | Connecting to IP: 127.0.0.1. | 2026-02-04 11:02:11.647
Socket (4) | Socket gracefully closed by remote side. | 2026-02-04 11:02:11.647
Socket (4) | Closed. | 2026-02-04 11:02:11.647
HD Request # 276 | Setting DTC encoding to Binary VLS | 2026-02-04 11:02:11.772
HD Request # 276 | Sending historical data logon request message. | 2026-02-04 11:02:11.772
HD Request # 276 | Requesting historical Daily data starting at 1976-02-05. | 2026-02-04 11:02:11.772
HD Request # 276 | Data is being downloaded from a remote source. Download will start when this is done. | 2026-02-04 11:02:11.773
HD Request # 276 | Decompressing data. | 2026-02-04 11:02:12.794
HD Request # 276 | Receiving historical Daily data for ESH10-CME starting at 2008-12-19. | 2026-02-04 11:02:12.796
HD Request # 276 | Writing historical Daily data to the file ESH10-CME.dly. | 2026-02-04 11:02:12.796
Socket (5) | CloseSocket call. | 2026-02-04 11:02:12.797
Socket (5) | Shutdown started. Waiting for graceful close. | 2026-02-04 11:02:12.797
Historical data download thread signaled to stop. | 2026-02-04 11:02:12.798
HD Request # 276 | Received 313 Daily data records from 2008-12-19 00:00:00 to 2010-03-19 00:00:00 (456.0 days) and wrote 313 records for ESH10-CME | 2026-02-04 11:02:12.798
HD Request # 276 | Completion time: 1s. | 2026-02-04 11:02:12.798
HD Request # 276 | Daily data download complete for ESH10-CME. Unique request ID: 277 | 2026-02-04 11:02:12.798
Removing historical data download ID 277. | 2026-02-04 11:02:12.798
Triggering next historical data download in queue. | 2026-02-04 11:02:12.798
HD Request # 277 | Downloading Historical Daily chart data for ESM10-CME. Starting date: 1976-02-05. Service: DTCSubInstance | 2026-02-04 11:02:12.798
Socket (5) | Socket gracefully closed by remote side. | 2026-02-04 11:02:12.798
HD Request # 277 | Using server: 127.0.0.1 port 11098 | 2026-02-04 11:02:12.798
Socket (5) | Closed. | 2026-02-04 11:02:12.798
Socket (4) | Creating socket. | 2026-02-04 11:02:12.798
Socket (4) | New receive buffer size: 5242880 | 2026-02-04 11:02:12.798
Socket (4) | Connecting to IP: 127.0.0.1. | 2026-02-04 11:02:12.798
HD Request # 277 | Setting DTC encoding to Binary VLS | 2026-02-04 11:02:12.811
HD Request # 277 | Sending historical data logon request message. | 2026-02-04 11:02:12.811
HD Request # 277 | Requesting historical Daily data starting at 1976-02-05. | 2026-02-04 11:02:12.812
HD Request # 277 | Data is being downloaded from a remote source. Download will start when this is done. | 2026-02-04 11:02:12.813
HD Request # 277 | Decompressing data. | 2026-02-04 11:02:13.822
HD Request # 277 | Receiving historical Daily data for ESM10-CME starting at 2009-03-04. | 2026-02-04 11:02:13.824
HD Request # 277 | Writing historical Daily data to the file ESM10-CME.dly. | 2026-02-04 11:02:13.824
Socket (4) | CloseSocket call. | 2026-02-04 11:02:13.825
Socket (4) | Shutdown started. Waiting for graceful close. | 2026-02-04 11:02:13.825
Historical data download thread signaled to stop. | 2026-02-04 11:02:13.825
HD Request # 277 | Received 317 Daily data records from 2009-03-04 00:00:00 to 2010-06-18 00:00:00 (472.0 days) and wrote 317 records for ESM10-CME | 2026-02-04 11:02:13.825
HD Request # 277 | Completion time: 1s. | 2026-02-04 11:02:13.825
HD Request # 277 | Daily data download complete for ESM10-CME. Unique request ID: 278 | 2026-02-04 11:02:13.825
Removing historical data download ID 278. | 2026-02-04 11:02:13.825
Triggering next historical data download in queue. | 2026-02-04 11:02:13.825
Socket (4) | Socket gracefully closed by remote side. | 2026-02-04 11:02:13.826
HD Request # 278 | Downloading Historical Daily chart data for ESU10-CME. Starting date: 1976-02-05. Service: DTCSubInstance | 2026-02-04 11:02:13.826
HD Request # 278 | Using server: 127.0.0.1 port 11098 | 2026-02-04 11:02:13.826
Socket (4) | Closed. | 2026-02-04 11:02:13.826
Socket (4) | Creating socket. | 2026-02-04 11:02:13.826
Socket (4) | New receive buffer size: 5242880 | 2026-02-04 11:02:13.826
Socket (4) | Connecting to IP: 127.0.0.1. | 2026-02-04 11:02:13.826
HD Request # 278 | Setting DTC encoding to Binary VLS | 2026-02-04 11:02:13.847
HD Request # 278 | Sending historical data logon request message. | 2026-02-04 11:02:13.847
HD Request # 278 | Requesting historical Daily data starting at 1976-02-05. | 2026-02-04 11:02:13.848
HD Request # 278 | Data is being downloaded from a remote source. Download will start when this is done. | 2026-02-04 11:02:13.849
HD Request # 278 | Decompressing data. | 2026-02-04 11:02:14.847
HD Request # 278 | Receiving historical Daily data for ESU10-CME starting at 2009-06-03. | 2026-02-04 11:02:14.849
HD Request # 278 | Writing historical Daily data to the file ESU10-CME.dly. | 2026-02-04 11:02:14.850
Socket (4) | CloseSocket call. | 2026-02-04 11:02:14.851
Socket (4) | Shutdown started. Waiting for graceful close. | 2026-02-04 11:02:14.851
Historical data download thread signaled to stop. | 2026-02-04 11:02:14.851
HD Request # 278 | Received 317 Daily data records from 2009-06-03 00:00:00 to 2010-09-17 00:00:00 (472.0 days) and wrote 317 records for ESU10-CME | 2026-02-04 11:02:14.851
HD Request # 278 | Completion time: 1s. | 2026-02-04 11:02:14.851
HD Request # 278 | Daily data download complete for ESU10-CME. Unique request ID: 279 | 2026-02-04 11:02:14.851
Removing historical data download ID 279. | 2026-02-04 11:02:14.851
Triggering next historical data download in queue. | 2026-02-04 11:02:14.851
HD Request # 279 | Downloading Historical Daily chart data for ESZ10-CME. Starting date: 1976-02-05. Service: DTCSubInstance | 2026-02-04 11:02:14.852
HD Request # 279 | Using server: 127.0.0.1 port 11098 | 2026-02-04 11:02:14.852
Socket (5) | Creating socket. | 2026-02-04 11:02:14.852
Socket (5) | New receive buffer size: 5242880 | 2026-02-04 11:02:14.852
Socket (5) | Connecting to IP: 127.0.0.1. | 2026-02-04 11:02:14.852
Socket (4) | Socket gracefully closed by remote side. | 2026-02-04 11:02:14.852
Socket (4) | Closed. | 2026-02-04 11:02:14.852
HD Request # 279 | Setting DTC encoding to Binary VLS | 2026-02-04 11:02:14.921
HD Request # 279 | Sending historical data logon request message. | 2026-02-04 11:02:14.921
HD Request # 279 | Requesting historical Daily data starting at 1976-02-05. | 2026-02-04 11:02:14.921
HD Request # 279 | Data is being downloaded from a remote source. Download will start when this is done. | 2026-02-04 11:02:14.922
HD Request # 279 | Decompressing data. | 2026-02-04 11:02:15.935
HD Request # 279 | Receiving historical Daily data for ESZ10-CME starting at 2009-09-18. | 2026-02-04 11:02:15.937
HD Request # 279 | Writing historical Daily data to the file ESZ10-CME.dly. | 2026-02-04 11:02:15.937
Socket (5) | CloseSocket call. | 2026-02-04 11:02:15.938
Socket (5) | Shutdown started. Waiting for graceful close. | 2026-02-04 11:02:15.938
Historical data download thread signaled to stop. | 2026-02-04 11:02:15.938
HD Request # 279 | Received 317 Daily data records from 2009-09-18 00:00:00 to 2010-12-17 00:00:00 (456.0 days) and wrote 317 records for ESZ10-CME | 2026-02-04 11:02:15.938
HD Request # 279 | Completion time: 1s. | 2026-02-04 11:02:15.938
HD Request # 279 | Daily data download complete for ESZ10-CME. Unique request ID: 280 | 2026-02-04 11:02:15.938
Removing historical data download ID 280. | 2026-02-04 11:02:15.938
Triggering next historical data download in queue. | 2026-02-04 11:02:15.938
HD Request # 280 | Downloading Historical Daily chart data for ESH11-CME. Starting date: 1976-02-05. Service: DTCSubInstance | 2026-02-04 11:02:15.938
HD Request # 280 | Using server: 127.0.0.1 port 11098 | 2026-02-04 11:02:15.939
Socket (4) | Creating socket. | 2026-02-04 11:02:15.939
Socket (4) | New receive buffer size: 5242880 | 2026-02-04 11:02:15.939
Socket (4) | Connecting to IP: 127.0.0.1. | 2026-02-04 11:02:15.939
Socket (5) | Socket gracefully closed by remote side. | 2026-02-04 11:02:15.939
Socket (5) | Closed. | 2026-02-04 11:02:15.939
HD Request # 280 | Setting DTC encoding to Binary VLS | 2026-02-04 11:02:16.011
HD Request # 280 | Sending historical data logon request message. | 2026-02-04 11:02:16.011
HD Request # 280 | Requesting historical Daily data starting at 1976-02-05. | 2026-02-04 11:02:16.012
HD Request # 280 | Data is being downloaded from a remote source. Download will start when this is done. | 2026-02-04 11:02:16.013
HD Request # 280 | Decompressing data. | 2026-02-04 11:02:17.030
HD Request # 280 | Receiving historical Daily data for ESH11-CME starting at 2009-12-02. | 2026-02-04 11:02:17.032
HD Request # 280 | Writing historical Daily data to the file ESH11-CME.dly. | 2026-02-04 11:02:17.032
Socket (4) | CloseSocket call. | 2026-02-04 11:02:17.034
Socket (4) | Shutdown started. Waiting for graceful close. | 2026-02-04 11:02:17.034
Historical data download thread signaled to stop. | 2026-02-04 11:02:17.034
HD Request # 280 | Received 316 Daily data records from 2009-12-02 00:00:00 to 2011-03-18 00:00:00 (472.0 days) and wrote 316 records for ESH11-CME | 2026-02-04 11:02:17.034
HD Request # 280 | Completion time: 2s. | 2026-02-04 11:02:17.034
HD Request # 280 | Daily data download complete for ESH11-CME. Unique request ID: 281 | 2026-02-04 11:02:17.034
Removing historical data download ID 281. | 2026-02-04 11:02:17.034
Triggering next historical data download in queue. | 2026-02-04 11:02:17.034
Socket (4) | Socket gracefully closed by remote side. | 2026-02-04 11:02:17.034
Socket (4) | Closed. | 2026-02-04 11:02:17.035
HD Request # 281 | Downloading Historical Daily chart data for ESM11-CME. Starting date: 1976-02-05. Service: DTCSubInstance | 2026-02-04 11:02:17.035
HD Request # 281 | Using server: 127.0.0.1 port 11098 | 2026-02-04 11:02:17.035
Socket (4) | Creating socket. | 2026-02-04 11:02:17.035
Socket (4) | New receive buffer size: 5242880 | 2026-02-04 11:02:17.035
Socket (4) | Connecting to IP: 127.0.0.1. | 2026-02-04 11:02:17.035
HD Request # 281 | Setting DTC encoding to Binary VLS | 2026-02-04 11:02:17.391
HD Request # 281 | Sending historical data logon request message. | 2026-02-04 11:02:17.391
HD Request # 281 | Requesting historical Daily data starting at 1976-02-05. | 2026-02-04 11:02:17.391
HD Request # 281 | Data is being downloaded from a remote source. Download will start when this is done. | 2026-02-04 11:02:17.392
HD Request # 281 | Decompressing data. | 2026-02-04 11:02:18.403
HD Request # 281 | Receiving historical Daily data for ESM11-CME starting at 2010-03-19. | 2026-02-04 11:02:18.405
HD Request # 281 | Writing historical Daily data to the file ESM11-CME.dly. | 2026-02-04 11:02:18.405
Socket (4) | CloseSocket call. | 2026-02-04 11:02:18.406
Socket (4) | Shutdown started. Waiting for graceful close. | 2026-02-04 11:02:18.406
Historical data download thread signaled to stop. | 2026-02-04 11:02:18.406
HD Request # 281 | Received 317 Daily data records from 2010-03-19 00:00:00 to 2011-06-17 00:00:00 (456.0 days) and wrote 317 records for ESM11-CME | 2026-02-04 11:02:18.406
HD Request # 281 | Completion time: 1s. | 2026-02-04 11:02:18.406
HD Request # 281 | Daily data download complete for ESM11-CME. Unique request ID: 282 | 2026-02-04 11:02:18.406
Removing historical data download ID 282. | 2026-02-04 11:02:18.406
Triggering next historical data download in queue. | 2026-02-04 11:02:18.406
HD Request # 282 | Downloading Historical Daily chart data for ESU11-CME. Starting date: 1976-02-05. Service: DTCSubInstance | 2026-02-04 11:02:18.406
Socket (4) | Socket gracefully closed by remote side. | 2026-02-04 11:02:18.407
HD Request # 282 | Using server: 127.0.0.1 port 11098 | 2026-02-04 11:02:18.407
Socket (4) | Closed. | 2026-02-04 11:02:18.407
Socket (4) | Creating socket. | 2026-02-04 11:02:18.407
Socket (4) | New receive buffer size: 5242880 | 2026-02-04 11:02:18.407
Socket (4) | Connecting to IP: 127.0.0.1. | 2026-02-04 11:02:18.407
HD Request # 282 | Setting DTC encoding to Binary VLS | 2026-02-04 11:02:18.504
HD Request # 282 | Sending historical data logon request message. | 2026-02-04 11:02:18.504
HD Request # 282 | Requesting historical Daily data starting at 1976-02-05. | 2026-02-04 11:02:18.504
HD Request # 282 | Data is being downloaded from a remote source. Download will start when this is done. | 2026-02-04 11:02:18.506
HD Request # 282 | Decompressing data. | 2026-02-04 11:02:19.513
HD Request # 282 | Receiving historical Daily data for ESU11-CME starting at 2010-06-18. | 2026-02-04 11:02:19.514
HD Request # 282 | Writing historical Daily data to the file ESU11-CME.dly. | 2026-02-04 11:02:19.515
Socket (4) | CloseSocket call. | 2026-02-04 11:02:19.516
Socket (4) | Shutdown started. Waiting for graceful close. | 2026-02-04 11:02:19.516
Historical data download thread signaled to stop. | 2026-02-04 11:02:19.516
HD Request # 282 | Received 316 Daily data records from 2010-06-18 00:00:00 to 2011-09-16 00:00:00 (456.0 days) and wrote 316 records for ESU11-CME | 2026-02-04 11:02:19.516
HD Request # 282 | Completion time: 1s. | 2026-02-04 11:02:19.516
HD Request # 282 | Daily data download complete for ESU11-CME. Unique request ID: 283 | 2026-02-04 11:02:19.516
Removing historical data download ID 283. | 2026-02-04 11:02:19.516
Triggering next historical data download in queue. | 2026-02-04 11:02:19.516
HD Request # 283 | Downloading Historical Daily chart data for ESZ11-CME. Starting date: 1976-02-05. Service: DTCSubInstance | 2026-02-04 11:02:19.516
Socket (4) | Socket gracefully closed by remote side. | 2026-02-04 11:02:19.516
Socket (4) | Closed. | 2026-02-04 11:02:19.516
HD Request # 283 | Using server: 127.0.0.1 port 11098 | 2026-02-04 11:02:19.516
Socket (4) | Creating socket. | 2026-02-04 11:02:19.517
Socket (4) | New receive buffer size: 5242880 | 2026-02-04 11:02:19.517
Socket (4) | Connecting to IP: 127.0.0.1. | 2026-02-04 11:02:19.517
HD Request # 283 | Setting DTC encoding to Binary VLS | 2026-02-04 11:02:19.642
HD Request # 283 | Sending historical data logon request message. | 2026-02-04 11:02:19.642
HD Request # 283 | Requesting historical Daily data starting at 1976-02-05. | 2026-02-04 11:02:19.643
HD Request # 283 | Data is being downloaded from a remote source. Download will start when this is done. | 2026-02-04 11:02:19.643
HD Request # 283 | Decompressing data. | 2026-02-04 11:02:20.651
HD Request # 283 | Receiving historical Daily data for ESZ11-CME starting at 2010-09-17. | 2026-02-04 11:02:20.652
HD Request # 283 | Writing historical Daily data to the file ESZ11-CME.dly. | 2026-02-04 11:02:20.652
Socket (4) | CloseSocket call. | 2026-02-04 11:02:20.653
Socket (4) | Shutdown started. Waiting for graceful close. | 2026-02-04 11:02:20.653
Historical data download thread signaled to stop. | 2026-02-04 11:02:20.654
HD Request # 283 | Received 317 Daily data records from 2010-09-17 00:00:00 to 2011-12-16 00:00:00 (456.0 days) and wrote 317 records for ESZ11-CME | 2026-02-04 11:02:20.654
HD Request # 283 | Completion time: 1s. | 2026-02-04 11:02:20.654
HD Request # 283 | Daily data download complete for ESZ11-CME. Unique request ID: 284 | 2026-02-04 11:02:20.654
Removing historical data download ID 284. | 2026-02-04 11:02:20.654
Triggering next historical data download in queue. | 2026-02-04 11:02:20.654
Socket (4) | Socket gracefully closed by remote side. | 2026-02-04 11:02:20.654
Socket (4) | Closed. | 2026-02-04 11:02:20.654
HD Request # 284 | Downloading Historical Daily chart data for ESH12-CME. Starting date: 1976-02-05. Service: DTCSubInstance | 2026-02-04 11:02:20.654
HD Request # 284 | Using server: 127.0.0.1 port 11098 | 2026-02-04 11:02:20.654
Socket (4) | Creating socket. | 2026-02-04 11:02:20.654
Socket (4) | New receive buffer size: 5242880 | 2026-02-04 11:02:20.654
Socket (4) | Connecting to IP: 127.0.0.1. | 2026-02-04 11:02:20.654
HD Request # 284 | Setting DTC encoding to Binary VLS | 2026-02-04 11:02:20.695
HD Request # 284 | Sending historical data logon request message. | 2026-02-04 11:02:20.695
HD Request # 284 | Requesting historical Daily data starting at 1976-02-05. | 2026-02-04 11:02:20.695
HD Request # 284 | Data is being downloaded from a remote source. Download will start when this is done. | 2026-02-04 11:02:20.696
HD Request # 284 | Decompressing data. | 2026-02-04 11:02:21.702
HD Request # 284 | Receiving historical Daily data for ESH12-CME starting at 2010-12-17. | 2026-02-04 11:02:21.704
HD Request # 284 | Writing historical Daily data to the file ESH12-CME.dly. | 2026-02-04 11:02:21.704
Socket (4) | CloseSocket call. | 2026-02-04 11:02:21.705
Socket (4) | Shutdown started. Waiting for graceful close. | 2026-02-04 11:02:21.705
Historical data download thread signaled to stop. | 2026-02-04 11:02:21.705
HD Request # 284 | Received 314 Daily data records from 2010-12-17 00:00:00 to 2012-03-16 00:00:00 (456.0 days) and wrote 314 records for ESH12-CME | 2026-02-04 11:02:21.705
HD Request # 284 | Completion time: 1s. | 2026-02-04 11:02:21.705
HD Request # 284 | Daily data download complete for ESH12-CME. Unique request ID: 285 | 2026-02-04 11:02:21.705
Removing historical data download ID 285. | 2026-02-04 11:02:21.705
Triggering next historical data download in queue. | 2026-02-04 11:02:21.705
HD Request # 285 | Downloading Historical Daily chart data for ESM12-CME. Starting date: 1976-02-05. Service: DTCSubInstance | 2026-02-04 11:02:21.706
Socket (4) | Socket gracefully closed by remote side. | 2026-02-04 11:02:21.706
Socket (4) | Closed. | 2026-02-04 11:02:21.706
HD Request # 285 | Using server: 127.0.0.1 port 11098 | 2026-02-04 11:02:21.706
Socket (4) | Creating socket. | 2026-02-04 11:02:21.706
Socket (4) | New receive buffer size: 5242880 | 2026-02-04 11:02:21.706
Socket (4) | Connecting to IP: 127.0.0.1. | 2026-02-04 11:02:21.706
HD Request # 285 | Setting DTC encoding to Binary VLS | 2026-02-04 11:02:21.725
HD Request # 285 | Sending historical data logon request message. | 2026-02-04 11:02:21.725
HD Request # 285 | Requesting historical Daily data starting at 1976-02-05. | 2026-02-04 11:02:21.726
HD Request # 285 | Data is being downloaded from a remote source. Download will start when this is done. | 2026-02-04 11:02:21.728
HD Request # 285 | Decompressing data. | 2026-02-04 11:02:22.748
HD Request # 285 | Receiving historical Daily data for ESM12-CME starting at 2011-03-18. | 2026-02-04 11:02:22.750
HD Request # 285 | Writing historical Daily data to the file ESM12-CME.dly. | 2026-02-04 11:02:22.751
Socket (4) | CloseSocket call. | 2026-02-04 11:02:22.752
Socket (4) | Shutdown started. Waiting for graceful close. | 2026-02-04 11:02:22.752
Historical data download thread signaled to stop. | 2026-02-04 11:02:22.753
HD Request # 285 | Received 316 Daily data records from 2011-03-18 00:00:00 to 2012-06-15 00:00:00 (456.0 days) and wrote 316 records for ESM12-CME | 2026-02-04 11:02:22.753
HD Request # 285 | Completion time: 1s. | 2026-02-04 11:02:22.753
HD Request # 285 | Daily data download complete for ESM12-CME. Unique request ID: 286 | 2026-02-04 11:02:22.753
Removing historical data download ID 286. | 2026-02-04 11:02:22.753
Triggering next historical data download in queue. | 2026-02-04 11:02:22.753
HD Request # 286 | Downloading Historical Daily chart data for ESU12-CME. Starting date: 1976-02-05. Service: DTCSubInstance | 2026-02-04 11:02:22.754
Socket (4) | Socket gracefully closed by remote side. | 2026-02-04 11:02:22.754
HD Request # 286 | Using server: 127.0.0.1 port 11098 | 2026-02-04 11:02:22.754
Socket (4) | Closed. | 2026-02-04 11:02:22.754
Socket (2) | Creating socket. | 2026-02-04 11:02:22.754
Socket (2) | New receive buffer size: 5242880 | 2026-02-04 11:02:22.754
Socket (2) | Connecting to IP: 127.0.0.1. | 2026-02-04 11:02:22.754
HD Request # 286 | Setting DTC encoding to Binary VLS | 2026-02-04 11:02:22.775
HD Request # 286 | Sending historical data logon request message. | 2026-02-04 11:02:22.775
HD Request # 286 | Requesting historical Daily data starting at 1976-02-05. | 2026-02-04 11:02:22.775
HD Request # 286 | Data is being downloaded from a remote source. Download will start when this is done. | 2026-02-04 11:02:22.776
HD Request # 286 | Decompressing data. | 2026-02-04 11:02:23.795
HD Request # 286 | Receiving historical Daily data for ESU12-CME starting at 2011-06-17. | 2026-02-04 11:02:23.796
HD Request # 286 | Writing historical Daily data to the file ESU12-CME.dly. | 2026-02-04 11:02:23.797
Socket (2) | CloseSocket call. | 2026-02-04 11:02:23.800
Socket (2) | Shutdown started. Waiting for graceful close. | 2026-02-04 11:02:23.800
Historical data download thread signaled to stop. | 2026-02-04 11:02:23.800
HD Request # 286 | Received 321 Daily data records from 2011-06-17 00:00:00 to 2012-09-21 00:00:00 (463.0 days) and wrote 321 records for ESU12-CME | 2026-02-04 11:02:23.800
HD Request # 286 | Completion time: 1s. | 2026-02-04 11:02:23.800
HD Request # 286 | Daily data download complete for ESU12-CME. Unique request ID: 287 | 2026-02-04 11:02:23.800
Removing historical data download ID 287. | 2026-02-04 11:02:23.800
Triggering next historical data download in queue. | 2026-02-04 11:02:23.800
HD Request # 287 | Downloading Historical Daily chart data for ESZ12-CME. Starting date: 1976-02-05. Service: DTCSubInstance | 2026-02-04 11:02:23.800
HD Request # 287 | Using server: 127.0.0.1 port 11098 | 2026-02-04 11:02:23.800
Socket (2) | Socket gracefully closed by remote side. | 2026-02-04 11:02:23.800
Socket (2) | Closed. | 2026-02-04 11:02:23.800
Socket (4) | Creating socket. | 2026-02-04 11:02:23.801
Socket (4) | New receive buffer size: 5242880 | 2026-02-04 11:02:23.801
Socket (4) | Connecting to IP: 127.0.0.1. | 2026-02-04 11:02:23.801
HD Request # 287 | Setting DTC encoding to Binary VLS | 2026-02-04 11:02:23.816
HD Request # 287 | Sending historical data logon request message. | 2026-02-04 11:02:23.816
HD Request # 287 | Requesting historical Daily data starting at 1976-02-05. | 2026-02-04 11:02:23.816
HD Request # 287 | Data is being downloaded from a remote source. Download will start when this is done. | 2026-02-04 11:02:23.817
HD Request # 287 | Decompressing data. | 2026-02-04 11:02:24.818
HD Request # 287 | Receiving historical Daily data for ESZ12-CME starting at 2011-09-06. | 2026-02-04 11:02:24.820
HD Request # 287 | Writing historical Daily data to the file ESZ12-CME.dly. | 2026-02-04 11:02:24.820
Socket (4) | CloseSocket call. | 2026-02-04 11:02:24.821
Socket (4) | Shutdown started. Waiting for graceful close. | 2026-02-04 11:02:24.821
Historical data download thread signaled to stop. | 2026-02-04 11:02:24.821
HD Request # 287 | Received 323 Daily data records from 2011-09-06 00:00:00 to 2012-12-21 00:00:00 (473.0 days) and wrote 323 records for ESZ12-CME | 2026-02-04 11:02:24.821
HD Request # 287 | Completion time: 1s. | 2026-02-04 11:02:24.821
HD Request # 287 | Daily data download complete for ESZ12-CME. Unique request ID: 288 | 2026-02-04 11:02:24.821
Removing historical data download ID 288. | 2026-02-04 11:02:24.821
Triggering next historical data download in queue. | 2026-02-04 11:02:24.821
HD Request # 288 | Downloading Historical Daily chart data for ESH13-CME. Starting date: 1976-02-05. Service: DTCSubInstance | 2026-02-04 11:02:24.821
Socket (4) | Socket gracefully closed by remote side. | 2026-02-04 11:02:24.821
HD Request # 288 | Using server: 127.0.0.1 port 11098 | 2026-02-04 11:02:24.821
Socket (4) | Closed. | 2026-02-04 11:02:24.821
Socket (2) | Creating socket. | 2026-02-04 11:02:24.822
Socket (2) | New receive buffer size: 5242880 | 2026-02-04 11:02:24.822
Socket (2) | Connecting to IP: 127.0.0.1. | 2026-02-04 11:02:24.822
HD Request # 288 | Setting DTC encoding to Binary VLS | 2026-02-04 11:02:24.905
HD Request # 288 | Sending historical data logon request message. | 2026-02-04 11:02:24.905
HD Request # 288 | Requesting historical Daily data starting at 1976-02-05. | 2026-02-04 11:02:24.905
HD Request # 288 | Data is being downloaded from a remote source. Download will start when this is done. | 2026-02-04 11:02:24.906
HD Request # 288 | Decompressing data. | 2026-02-04 11:02:25.909
HD Request # 288 | Receiving historical Daily data for ESH13-CME starting at 2011-12-16. | 2026-02-04 11:02:25.910
HD Request # 288 | Writing historical Daily data to the file ESH13-CME.dly. | 2026-02-04 11:02:25.910
Socket (2) | CloseSocket call. | 2026-02-04 11:02:25.911
Socket (2) | Shutdown started. Waiting for graceful close. | 2026-02-04 11:02:25.912
Historical data download thread signaled to stop. | 2026-02-04 11:02:25.912
HD Request # 288 | Received 314 Daily data records from 2011-12-16 00:00:00 to 2013-03-15 00:00:00 (456.0 days) and wrote 314 records for ESH13-CME | 2026-02-04 11:02:25.912
HD Request # 288 | Completion time: 1s. | 2026-02-04 11:02:25.912
HD Request # 288 | Daily data download complete for ESH13-CME. Unique request ID: 289 | 2026-02-04 11:02:25.912
Removing historical data download ID 289. | 2026-02-04 11:02:25.912
Triggering next historical data download in queue. | 2026-02-04 11:02:25.912
HD Request # 289 | Downloading Historical Daily chart data for ESM13-CME. Starting date: 1976-02-05. Service: DTCSubInstance | 2026-02-04 11:02:25.913
HD Request # 289 | Using server: 127.0.0.1 port 11098 | 2026-02-04 11:02:25.913
Socket (4) | Creating socket. | 2026-02-04 11:02:25.913
Socket (4) | New receive buffer size: 5242880 | 2026-02-04 11:02:25.913
Socket (4) | Connecting to IP: 127.0.0.1. | 2026-02-04 11:02:25.913
Socket (2) | Socket gracefully closed by remote side. | 2026-02-04 11:02:25.913
Socket (2) | Closed. | 2026-02-04 11:02:25.913
HD Request # 289 | Setting DTC encoding to Binary VLS | 2026-02-04 11:02:26.043
HD Request # 289 | Sending historical data logon request message. | 2026-02-04 11:02:26.043
HD Request # 289 | Requesting historical Daily data starting at 1976-02-05. | 2026-02-04 11:02:26.043
HD Request # 289 | Data is being downloaded from a remote source. Download will start when this is done. | 2026-02-04 11:02:26.044
HD Request # 289 | Decompressing data. | 2026-02-04 11:02:27.050
HD Request # 289 | Receiving historical Daily data for ESM13-CME starting at 2012-03-16. | 2026-02-04 11:02:27.052
HD Request # 289 | Writing historical Daily data to the file ESM13-CME.dly. | 2026-02-04 11:02:27.052
Socket (4) | CloseSocket call. | 2026-02-04 11:02:27.053
Socket (4) | Shutdown started. Waiting for graceful close. | 2026-02-04 11:02:27.053
Historical data download thread signaled to stop. | 2026-02-04 11:02:27.055
HD Request # 289 | Received 321 Daily data records from 2012-03-16 00:00:00 to 2013-06-21 00:00:00 (463.0 days) and wrote 321 records for ESM13-CME | 2026-02-04 11:02:27.055
HD Request # 289 | Completion time: 2s. | 2026-02-04 11:02:27.055
HD Request # 289 | Daily data download complete for ESM13-CME. Unique request ID: 290 | 2026-02-04 11:02:27.055
Removing historical data download ID 290. | 2026-02-04 11:02:27.055
Triggering next historical data download in queue. | 2026-02-04 11:02:27.055
HD Request # 290 | Downloading Historical Daily chart data for ESU13-CME. Starting date: 1976-02-05. Service: DTCSubInstance | 2026-02-04 11:02:27.055
HD Request # 290 | Using server: 127.0.0.1 port 11098 | 2026-02-04 11:02:27.055
Socket (4) | Socket gracefully closed by remote side. | 2026-02-04 11:02:27.055
Socket (4) | Closed. | 2026-02-04 11:02:27.055
Socket (2) | Creating socket. | 2026-02-04 11:02:27.055
Socket (2) | New receive buffer size: 5242880 | 2026-02-04 11:02:27.055
Socket (2) | Connecting to IP: 127.0.0.1. | 2026-02-04 11:02:27.055
HD Request # 290 | Setting DTC encoding to Binary VLS | 2026-02-04 11:02:27.303
HD Request # 290 | Sending historical data logon request message. | 2026-02-04 11:02:27.303
HD Request # 290 | Requesting historical Daily data starting at 1976-02-05. | 2026-02-04 11:02:27.304
HD Request # 290 | Data is being downloaded from a remote source. Download will start when this is done. | 2026-02-04 11:02:27.305
HD Request # 290 | Decompressing data. | 2026-02-04 11:02:28.321
HD Request # 290 | Receiving historical Daily data for ESU13-CME starting at 2012-06-15. | 2026-02-04 11:02:28.326
HD Request # 290 | Writing historical Daily data to the file ESU13-CME.dly. | 2026-02-04 11:02:28.327
Socket (2) | CloseSocket call. | 2026-02-04 11:02:28.328
Socket (2) | Shutdown started. Waiting for graceful close. | 2026-02-04 11:02:28.328
Historical data download thread signaled to stop. | 2026-02-04 11:02:28.328
HD Request # 290 | Received 320 Daily data records from 2012-06-15 00:00:00 to 2013-09-20 00:00:00 (463.0 days) and wrote 320 records for ESU13-CME | 2026-02-04 11:02:28.328
HD Request # 290 | Completion time: 1s. | 2026-02-04 11:02:28.328
HD Request # 290 | Daily data download complete for ESU13-CME. Unique request ID: 291 | 2026-02-04 11:02:28.328
Removing historical data download ID 291. | 2026-02-04 11:02:28.328
Triggering next historical data download in queue. | 2026-02-04 11:02:28.328
Socket (2) | Socket gracefully closed by remote side. | 2026-02-04 11:02:28.328
HD Request # 291 | Downloading Historical Daily chart data for ESZ13-CME. Starting date: 1976-02-05. Service: DTCSubInstance | 2026-02-04 11:02:28.328
Socket (2) | Closed. | 2026-02-04 11:02:28.328
HD Request # 291 | Using server: 127.0.0.1 port 11098 | 2026-02-04 11:02:28.329
Socket (2) | Creating socket. | 2026-02-04 11:02:28.329
Socket (2) | New receive buffer size: 5242880 | 2026-02-04 11:02:28.329
Socket (2) | Connecting to IP: 127.0.0.1. | 2026-02-04 11:02:28.329
HD Request # 291 | Setting DTC encoding to Binary VLS | 2026-02-04 11:02:28.374
HD Request # 291 | Sending historical data logon request message. | 2026-02-04 11:02:28.374
HD Request # 291 | Requesting historical Daily data starting at 1976-02-05. | 2026-02-04 11:02:28.375
HD Request # 291 | Data is being downloaded from a remote source. Download will start when this is done. | 2026-02-04 11:02:28.377
HD Request # 291 | Decompressing data. | 2026-02-04 11:02:29.376
HD Request # 291 | Receiving historical Daily data for ESZ13-CME starting at 2012-09-21. | 2026-02-04 11:02:29.378
HD Request # 291 | Writing historical Daily data to the file ESZ13-CME.dly. | 2026-02-04 11:02:29.378
Socket (2) | CloseSocket call. | 2026-02-04 11:02:29.380
Socket (2) | Shutdown started. Waiting for graceful close. | 2026-02-04 11:02:29.380
Historical data download thread signaled to stop. | 2026-02-04 11:02:29.380
HD Request # 291 | Received 316 Daily data records from 2012-09-21 00:00:00 to 2013-12-20 00:00:00 (456.0 days) and wrote 316 records for ESZ13-CME | 2026-02-04 11:02:29.380
HD Request # 291 | Completion time: 1s. | 2026-02-04 11:02:29.380
HD Request # 291 | Daily data download complete for ESZ13-CME. Unique request ID: 292 | 2026-02-04 11:02:29.380
Removing historical data download ID 292. | 2026-02-04 11:02:29.380
Triggering next historical data download in queue. | 2026-02-04 11:02:29.380
HD Request # 292 | Downloading Historical Daily chart data for ESH14-CME. Starting date: 1976-02-05. Service: DTCSubInstance | 2026-02-04 11:02:29.381
HD Request # 292 | Using server: 127.0.0.1 port 11098 | 2026-02-04 11:02:29.381
Socket (4) | Creating socket. | 2026-02-04 11:02:29.381
Socket (4) | New receive buffer size: 5242880 | 2026-02-04 11:02:29.381
Socket (4) | Connecting to IP: 127.0.0.1. | 2026-02-04 11:02:29.381
Socket (2) | Socket gracefully closed by remote side. | 2026-02-04 11:02:29.381
Socket (2) | Closed. | 2026-02-04 11:02:29.381
HD Request # 292 | Setting DTC encoding to Binary VLS | 2026-02-04 11:02:29.618
HD Request # 292 | Sending historical data logon request message. | 2026-02-04 11:02:29.618
HD Request # 292 | Requesting historical Daily data starting at 1976-02-05. | 2026-02-04 11:02:29.619
HD Request # 292 | Data is being downloaded from a remote source. Download will start when this is done. | 2026-02-04 11:02:29.619
HD Request # 292 | Decompressing data. | 2026-02-04 11:02:30.628
HD Request # 292 | Receiving historical Daily data for ESH14-CME starting at 2012-12-19. | 2026-02-04 11:02:30.629
HD Request # 292 | Writing historical Daily data to the file ESH14-CME.dly. | 2026-02-04 11:02:30.630
Socket (4) | CloseSocket call. | 2026-02-04 11:02:30.632
Socket (4) | Shutdown started. Waiting for graceful close. | 2026-02-04 11:02:30.632
Historical data download thread signaled to stop. | 2026-02-04 11:02:30.632
HD Request # 292 | Received 315 Daily data records from 2012-12-19 00:00:00 to 2014-03-21 00:00:00 (458.0 days) and wrote 315 records for ESH14-CME | 2026-02-04 11:02:30.633
HD Request # 292 | Completion time: 1s. | 2026-02-04 11:02:30.633
HD Request # 292 | Daily data download complete for ESH14-CME. Unique request ID: 293 | 2026-02-04 11:02:30.633
Removing historical data download ID 293. | 2026-02-04 11:02:30.633
Triggering next historical data download in queue. | 2026-02-04 11:02:30.633
HD Request # 293 | Downloading Historical Daily chart data for ESM14-CME. Starting date: 1976-02-05. Service: DTCSubInstance | 2026-02-04 11:02:30.633
Socket (4) | Socket gracefully closed by remote side. | 2026-02-04 11:02:30.633
HD Request # 293 | Using server: 127.0.0.1 port 11098 | 2026-02-04 11:02:30.633
Socket (4) | Closed. | 2026-02-04 11:02:30.633
Socket (2) | Creating socket. | 2026-02-04 11:02:30.633
Socket (2) | New receive buffer size: 5242880 | 2026-02-04 11:02:30.633
Socket (2) | Connecting to IP: 127.0.0.1. | 2026-02-04 11:02:30.633
HD Request # 293 | Setting DTC encoding to Binary VLS | 2026-02-04 11:02:30.649
HD Request # 293 | Sending historical data logon request message. | 2026-02-04 11:02:30.649
HD Request # 293 | Requesting historical Daily data starting at 1976-02-05. | 2026-02-04 11:02:30.650
HD Request # 293 | Data is being downloaded from a remote source. Download will start when this is done. | 2026-02-04 11:02:30.651
HD Request # 293 | Decompressing data. | 2026-02-04 11:02:31.656
HD Request # 293 | Receiving historical Daily data for ESM14-CME starting at 2013-03-15. | 2026-02-04 11:02:31.658
HD Request # 293 | Writing historical Daily data to the file ESM14-CME.dly. | 2026-02-04 11:02:31.658
Socket (2) | CloseSocket call. | 2026-02-04 11:02:31.659
Socket (2) | Shutdown started. Waiting for graceful close. | 2026-02-04 11:02:31.660
Historical data download thread signaled to stop. | 2026-02-04 11:02:31.660
HD Request # 293 | Received 320 Daily data records from 2013-03-15 00:00:00 to 2014-06-20 00:00:00 (463.0 days) and wrote 320 records for ESM14-CME | 2026-02-04 11:02:31.660
HD Request # 293 | Completion time: 1s. | 2026-02-04 11:02:31.660
HD Request # 293 | Daily data download complete for ESM14-CME. Unique request ID: 294 | 2026-02-04 11:02:31.660
Removing historical data download ID 294. | 2026-02-04 11:02:31.660
Triggering next historical data download in queue. | 2026-02-04 11:02:31.660
HD Request # 294 | Downloading Historical Daily chart data for ESU14-CME. Starting date: 1976-02-05. Service: DTCSubInstance | 2026-02-04 11:02:31.660
Socket (2) | Socket gracefully closed by remote side. | 2026-02-04 11:02:31.660
HD Request # 294 | Using server: 127.0.0.1 port 11098 | 2026-02-04 11:02:31.660
Socket (2) | Closed. | 2026-02-04 11:02:31.660
Socket (2) | Creating socket. | 2026-02-04 11:02:31.661
Socket (2) | New receive buffer size: 5242880 | 2026-02-04 11:02:31.661
Socket (2) | Connecting to IP: 127.0.0.1. | 2026-02-04 11:02:31.661
HD Request # 294 | Setting DTC encoding to Binary VLS | 2026-02-04 11:02:31.675
HD Request # 294 | Sending historical data logon request message. | 2026-02-04 11:02:31.675
HD Request # 294 | Requesting historical Daily data starting at 1976-02-05. | 2026-02-04 11:02:31.675
HD Request # 294 | Data is being downloaded from a remote source. Download will start when this is done. | 2026-02-04 11:02:31.676
HD Request # 294 | Decompressing data. | 2026-02-04 11:02:32.671
HD Request # 294 | Receiving historical Daily data for ESU14-CME starting at 2013-06-19. | 2026-02-04 11:02:32.672
HD Request # 294 | Writing historical Daily data to the file ESU14-CME.dly. | 2026-02-04 11:02:32.672
Socket (2) | CloseSocket call. | 2026-02-04 11:02:32.674
Socket (2) | Shutdown started. Waiting for graceful close. | 2026-02-04 11:02:32.674
Historical data download thread signaled to stop. | 2026-02-04 11:02:32.674
HD Request # 294 | Received 317 Daily data records from 2013-06-19 00:00:00 to 2014-09-19 00:00:00 (458.0 days) and wrote 317 records for ESU14-CME | 2026-02-04 11:02:32.674
HD Request # 294 | Completion time: 1s. | 2026-02-04 11:02:32.674
HD Request # 294 | Daily data download complete for ESU14-CME. Unique request ID: 295 | 2026-02-04 11:02:32.674
Removing historical data download ID 295. | 2026-02-04 11:02:32.674
Triggering next historical data download in queue. | 2026-02-04 11:02:32.674
HD Request # 295 | Downloading Historical Daily chart data for ESZ14-CME. Starting date: 1976-02-05. Service: DTCSubInstance | 2026-02-04 11:02:32.674
HD Request # 295 | Using server: 127.0.0.1 port 11098 | 2026-02-04 11:02:32.674
Socket (4) | Creating socket. | 2026-02-04 11:02:32.674
Socket (4) | New receive buffer size: 5242880 | 2026-02-04 11:02:32.674
Socket (4) | Connecting to IP: 127.0.0.1. | 2026-02-04 11:02:32.674
Socket (2) | Socket gracefully closed by remote side. | 2026-02-04 11:02:32.675
Socket (2) | Closed. | 2026-02-04 11:02:32.675
HD Request # 295 | Setting DTC encoding to Binary VLS | 2026-02-04 11:02:32.689
HD Request # 295 | Sending historical data logon request message. | 2026-02-04 11:02:32.689
HD Request # 295 | Requesting historical Daily data starting at 1976-02-05. | 2026-02-04 11:02:32.690
HD Request # 295 | Data is being downloaded from a remote source. Download will start when this is done. | 2026-02-04 11:02:32.691
HD Request # 295 | Decompressing data. | 2026-02-04 11:02:33.690
HD Request # 295 | Receiving historical Daily data for ESZ14-CME starting at 2013-09-18. | 2026-02-04 11:02:33.691
HD Request # 295 | Writing historical Daily data to the file ESZ14-CME.dly. | 2026-02-04 11:02:33.691
Socket (4) | CloseSocket call. | 2026-02-04 11:02:33.693
Socket (4) | Shutdown started. Waiting for graceful close. | 2026-02-04 11:02:33.693
Historical data download thread signaled to stop. | 2026-02-04 11:02:33.693
HD Request # 295 | Received 318 Daily data records from 2013-09-18 00:00:00 to 2014-12-19 00:00:00 (458.0 days) and wrote 318 records for ESZ14-CME | 2026-02-04 11:02:33.693
HD Request # 295 | Completion time: 1s. | 2026-02-04 11:02:33.693
HD Request # 295 | Daily data download complete for ESZ14-CME. Unique request ID: 296 | 2026-02-04 11:02:33.693
Removing historical data download ID 296. | 2026-02-04 11:02:33.693
Triggering next historical data download in queue. | 2026-02-04 11:02:33.693
HD Request # 296 | Downloading Historical Daily chart data for ESH15-CME. Starting date: 1976-02-05. Service: DTCSubInstance | 2026-02-04 11:02:33.694
HD Request # 296 | Using server: 127.0.0.1 port 11098 | 2026-02-04 11:02:33.694
Socket (2) | Creating socket. | 2026-02-04 11:02:33.694
Socket (2) | New receive buffer size: 5242880 | 2026-02-04 11:02:33.694
Socket (2) | Connecting to IP: 127.0.0.1. | 2026-02-04 11:02:33.694
Socket (4) | Socket gracefully closed by remote side. | 2026-02-04 11:02:33.695
Socket (4) | Closed. | 2026-02-04 11:02:33.695
HD Request # 296 | Setting DTC encoding to Binary VLS | 2026-02-04 11:02:33.708
HD Request # 296 | Sending historical data logon request message. | 2026-02-04 11:02:33.708
HD Request # 296 | Requesting historical Daily data starting at 1976-02-05. | 2026-02-04 11:02:33.709
HD Request # 296 | Data is being downloaded from a remote source. Download will start when this is done. | 2026-02-04 11:02:33.709
HD Request # 296 | Decompressing data. | 2026-02-04 11:02:34.705
HD Request # 296 | Receiving historical Daily data for ESH15-CME starting at 2013-12-11. | 2026-02-04 11:02:34.706
HD Request # 296 | Writing historical Daily data to the file ESH15-CME.dly. | 2026-02-04 11:02:34.706
Socket (2) | CloseSocket call. | 2026-02-04 11:02:34.707
Socket (2) | Shutdown started. Waiting for graceful close. | 2026-02-04 11:02:34.707
Historical data download thread signaled to stop. | 2026-02-04 11:02:34.708
HD Request # 296 | Received 320 Daily data records from 2013-12-11 00:00:00 to 2015-03-20 00:00:00 (465.0 days) and wrote 320 records for ESH15-CME | 2026-02-04 11:02:34.708
HD Request # 296 | Completion time: 1s. | 2026-02-04 11:02:34.708
HD Request # 296 | Daily data download complete for ESH15-CME. Unique request ID: 297 | 2026-02-04 11:02:34.708
Removing historical data download ID 297. | 2026-02-04 11:02:34.708
Triggering next historical data download in queue. | 2026-02-04 11:02:34.708
HD Request # 297 | Downloading Historical Daily chart data for ESM15-CME. Starting date: 1976-02-05. Service: DTCSubInstance | 2026-02-04 11:02:34.708
Socket (2) | Socket gracefully closed by remote side. | 2026-02-04 11:02:34.708
Socket (2) | Closed. | 2026-02-04 11:02:34.708
HD Request # 297 | Using server: 127.0.0.1 port 11098 | 2026-02-04 11:02:34.708
Socket (2) | Creating socket. | 2026-02-04 11:02:34.709
Socket (2) | New receive buffer size: 5242880 | 2026-02-04 11:02:34.709
Socket (2) | Connecting to IP: 127.0.0.1. | 2026-02-04 11:02:34.709
HD Request # 297 | Setting DTC encoding to Binary VLS | 2026-02-04 11:02:34.734
HD Request # 297 | Sending historical data logon request message. | 2026-02-04 11:02:34.734
HD Request # 297 | Requesting historical Daily data starting at 1976-02-05. | 2026-02-04 11:02:34.735
HD Request # 297 | Data is being downloaded from a remote source. Download will start when this is done. | 2026-02-04 11:02:34.735
HD Request # 297 | Decompressing data. | 2026-02-04 11:02:35.750
HD Request # 297 | Receiving historical Daily data for ESM15-CME starting at 2014-03-11. | 2026-02-04 11:02:35.751
HD Request # 297 | Writing historical Daily data to the file ESM15-CME.dly. | 2026-02-04 11:02:35.751
Socket (2) | CloseSocket call. | 2026-02-04 11:02:35.752
Socket (2) | Shutdown started. Waiting for graceful close. | 2026-02-04 11:02:35.752
Historical data download thread signaled to stop. | 2026-02-04 11:02:35.753
HD Request # 297 | Received 324 Daily data records from 2014-03-11 00:00:00 to 2015-06-19 00:00:00 (466.0 days) and wrote 324 records for ESM15-CME | 2026-02-04 11:02:35.753
HD Request # 297 | Completion time: 1s. | 2026-02-04 11:02:35.753
HD Request # 297 | Daily data download complete for ESM15-CME. Unique request ID: 298 | 2026-02-04 11:02:35.753
Removing historical data download ID 298. | 2026-02-04 11:02:35.753
Triggering next historical data download in queue. | 2026-02-04 11:02:35.753
HD Request # 298 | Downloading Historical Daily chart data for ESU15-CME. Starting date: 1976-02-05. Service: DTCSubInstance | 2026-02-04 11:02:35.753
HD Request # 298 | Using server: 127.0.0.1 port 11098 | 2026-02-04 11:02:35.753
Socket (2) | Socket gracefully closed by remote side. | 2026-02-04 11:02:35.753
Socket (2) | Closed. | 2026-02-04 11:02:35.753
Socket (4) | Creating socket. | 2026-02-04 11:02:35.754
Socket (4) | New receive buffer size: 5242880 | 2026-02-04 11:02:35.754
Socket (4) | Connecting to IP: 127.0.0.1. | 2026-02-04 11:02:35.754
HD Request # 298 | Setting DTC encoding to Binary VLS | 2026-02-04 11:02:35.769
HD Request # 298 | Sending historical data logon request message. | 2026-02-04 11:02:35.769
HD Request # 298 | Requesting historical Daily data starting at 1976-02-05. | 2026-02-04 11:02:35.770
HD Request # 298 | Data is being downloaded from a remote source. Download will start when this is done. | 2026-02-04 11:02:35.770
HD Request # 298 | Decompressing data. | 2026-02-04 11:02:36.776
HD Request # 298 | Receiving historical Daily data for ESU15-CME starting at 2014-06-10. | 2026-02-04 11:02:36.777
HD Request # 298 | Writing historical Daily data to the file ESU15-CME.dly. | 2026-02-04 11:02:36.778
Socket (4) | CloseSocket call. | 2026-02-04 11:02:36.779
Socket (4) | Shutdown started. Waiting for graceful close. | 2026-02-04 11:02:36.779
Historical data download thread signaled to stop. | 2026-02-04 11:02:36.779
HD Request # 298 | Received 324 Daily data records from 2014-06-10 00:00:00 to 2015-09-18 00:00:00 (466.0 days) and wrote 324 records for ESU15-CME | 2026-02-04 11:02:36.779
HD Request # 298 | Completion time: 1s. | 2026-02-04 11:02:36.779
HD Request # 298 | Daily data download complete for ESU15-CME. Unique request ID: 299 | 2026-02-04 11:02:36.779
Removing historical data download ID 299. | 2026-02-04 11:02:36.779
Triggering next historical data download in queue. | 2026-02-04 11:02:36.779
HD Request # 299 | Downloading Historical Daily chart data for ESZ15-CME. Starting date: 1976-02-05. Service: DTCSubInstance | 2026-02-04 11:02:36.780
HD Request # 299 | Using server: 127.0.0.1 port 11098 | 2026-02-04 11:02:36.780
Socket (2) | Creating socket. | 2026-02-04 11:02:36.780
Socket (2) | New receive buffer size: 5242880 | 2026-02-04 11:02:36.780
Socket (2) | Connecting to IP: 127.0.0.1. | 2026-02-04 11:02:36.780
Socket (4) | Socket gracefully closed by remote side. | 2026-02-04 11:02:36.780
Socket (4) | Closed. | 2026-02-04 11:02:36.780
HD Request # 299 | Setting DTC encoding to Binary VLS | 2026-02-04 11:02:36.794
HD Request # 299 | Sending historical data logon request message. | 2026-02-04 11:02:36.794
HD Request # 299 | Requesting historical Daily data starting at 1976-02-05. | 2026-02-04 11:02:36.795
HD Request # 299 | Data is being downloaded from a remote source. Download will start when this is done. | 2026-02-04 11:02:36.795
HD Request # 299 | Decompressing data. | 2026-02-04 11:02:37.805
HD Request # 299 | Receiving historical Daily data for ESZ15-CME starting at 2014-09-10. | 2026-02-04 11:02:37.806
HD Request # 299 | Writing historical Daily data to the file ESZ15-CME.dly. | 2026-02-04 11:02:37.806
Socket (2) | CloseSocket call. | 2026-02-04 11:02:37.808
Socket (2) | Shutdown started. Waiting for graceful close. | 2026-02-04 11:02:37.808
Historical data download thread signaled to stop. | 2026-02-04 11:02:37.808
HD Request # 299 | Received 324 Daily data records from 2014-09-10 00:00:00 to 2015-12-18 00:00:00 (465.0 days) and wrote 324 records for ESZ15-CME | 2026-02-04 11:02:37.808
HD Request # 299 | Completion time: 1s. | 2026-02-04 11:02:37.808
HD Request # 299 | Daily data download complete for ESZ15-CME. Unique request ID: 300 | 2026-02-04 11:02:37.808
Removing historical data download ID 300. | 2026-02-04 11:02:37.808
Triggering next historical data download in queue. | 2026-02-04 11:02:37.808
HD Request # 300 | Downloading Historical Daily chart data for ESH16-CME. Starting date: 1976-02-05. Service: DTCSubInstance | 2026-02-04 11:02:37.808
HD Request # 300 | Using server: 127.0.0.1 port 11098 | 2026-02-04 11:02:37.809
Socket (4) | Creating socket. | 2026-02-04 11:02:37.809
Socket (4) | New receive buffer size: 5242880 | 2026-02-04 11:02:37.809
Socket (4) | Connecting to IP: 127.0.0.1. | 2026-02-04 11:02:37.809
Socket (2) | Socket gracefully closed by remote side. | 2026-02-04 11:02:37.809
Socket (2) | Closed. | 2026-02-04 11:02:37.809
HD Request # 300 | Setting DTC encoding to Binary VLS | 2026-02-04 11:02:37.822
HD Request # 300 | Sending historical data logon request message. | 2026-02-04 11:02:37.822
HD Request # 300 | Requesting historical Daily data starting at 1976-02-05. | 2026-02-04 11:02:37.824
HD Request # 300 | Data is being downloaded from a remote source. Download will start when this is done. | 2026-02-04 11:02:37.825
HD Request # 300 | Decompressing data. | 2026-02-04 11:02:38.832
HD Request # 300 | Receiving historical Daily data for ESH16-CME starting at 2014-12-17. | 2026-02-04 11:02:38.833
HD Request # 300 | Writing historical Daily data to the file ESH16-CME.dly. | 2026-02-04 11:02:38.834
Socket (4) | CloseSocket call. | 2026-02-04 11:02:38.835
Socket (4) | Shutdown started. Waiting for graceful close. | 2026-02-04 11:02:38.835
Historical data download thread signaled to stop. | 2026-02-04 11:02:38.835
HD Request # 300 | Received 316 Daily data records from 2014-12-17 00:00:00 to 2016-03-18 00:00:00 (458.0 days) and wrote 316 records for ESH16-CME | 2026-02-04 11:02:38.835
HD Request # 300 | Completion time: 1s. | 2026-02-04 11:02:38.835
HD Request # 300 | Daily data download complete for ESH16-CME. Unique request ID: 301 | 2026-02-04 11:02:38.835
Removing historical data download ID 301. | 2026-02-04 11:02:38.835
Triggering next historical data download in queue. | 2026-02-04 11:02:38.835
HD Request # 301 | Downloading Historical Daily chart data for ESM16-CME. Starting date: 1976-02-05. Service: DTCSubInstance | 2026-02-04 11:02:38.835
HD Request # 301 | Using server: 127.0.0.1 port 11098 | 2026-02-04 11:02:38.835
Socket (4) | Socket gracefully closed by remote side. | 2026-02-04 11:02:38.835
Socket (4) | Closed. | 2026-02-04 11:02:38.835
Socket (2) | Creating socket. | 2026-02-04 11:02:38.836
Socket (2) | New receive buffer size: 5242880 | 2026-02-04 11:02:38.836
Socket (2) | Connecting to IP: 127.0.0.1. | 2026-02-04 11:02:38.836
HD Request # 301 | Setting DTC encoding to Binary VLS | 2026-02-04 11:02:38.848
HD Request # 301 | Sending historical data logon request message. | 2026-02-04 11:02:38.848
HD Request # 301 | Requesting historical Daily data starting at 1976-02-05. | 2026-02-04 11:02:38.849
HD Request # 301 | Data is being downloaded from a remote source. Download will start when this is done. | 2026-02-04 11:02:38.849
HD Request # 301 | Decompressing data. | 2026-02-04 11:02:39.867
HD Request # 301 | Receiving historical Daily data for ESM16-CME starting at 2015-03-10. | 2026-02-04 11:02:39.868
HD Request # 301 | Writing historical Daily data to the file ESM16-CME.dly. | 2026-02-04 11:02:39.868
Socket (2) | CloseSocket call. | 2026-02-04 11:02:39.869
Socket (2) | Shutdown started. Waiting for graceful close. | 2026-02-04 11:02:39.869
Historical data download thread signaled to stop. | 2026-02-04 11:02:39.870
HD Request # 301 | Received 323 Daily data records from 2015-03-10 00:00:00 to 2016-06-17 00:00:00 (466.0 days) and wrote 323 records for ESM16-CME | 2026-02-04 11:02:39.870
HD Request # 301 | Completion time: 1s. | 2026-02-04 11:02:39.870
HD Request # 301 | Daily data download complete for ESM16-CME. Unique request ID: 302 | 2026-02-04 11:02:39.870
Removing historical data download ID 302. | 2026-02-04 11:02:39.870
Triggering next historical data download in queue. | 2026-02-04 11:02:39.870
HD Request # 302 | Downloading Historical Daily chart data for ESU16-CME. Starting date: 1976-02-05. Service: DTCSubInstance | 2026-02-04 11:02:39.870
HD Request # 302 | Using server: 127.0.0.1 port 11098 | 2026-02-04 11:02:39.870
Socket (2) | Socket gracefully closed by remote side. | 2026-02-04 11:02:39.870
Socket (2) | Closed. | 2026-02-04 11:02:39.870
Socket (4) | Creating socket. | 2026-02-04 11:02:39.870
Socket (4) | New receive buffer size: 5242880 | 2026-02-04 11:02:39.870
Socket (4) | Connecting to IP: 127.0.0.1. | 2026-02-04 11:02:39.870
HD Request # 302 | Setting DTC encoding to Binary VLS | 2026-02-04 11:02:39.885
HD Request # 302 | Sending historical data logon request message. | 2026-02-04 11:02:39.885
HD Request # 302 | Requesting historical Daily data starting at 1976-02-05. | 2026-02-04 11:02:39.885
HD Request # 302 | Data is being downloaded from a remote source. Download will start when this is done. | 2026-02-04 11:02:39.887
HD Request # 302 | Decompressing data. | 2026-02-04 11:02:40.897
HD Request # 302 | Receiving historical Daily data for ESU16-CME starting at 2015-06-17. | 2026-02-04 11:02:40.897
HD Request # 302 | Writing historical Daily data to the file ESU16-CME.dly. | 2026-02-04 11:02:40.898
Socket (4) | CloseSocket call. | 2026-02-04 11:02:40.899
Socket (4) | Shutdown started. Waiting for graceful close. | 2026-02-04 11:02:40.899
Historical data download thread signaled to stop. | 2026-02-04 11:02:40.899
HD Request # 302 | Received 317 Daily data records from 2015-06-17 00:00:00 to 2016-09-16 00:00:00 (458.0 days) and wrote 317 records for ESU16-CME | 2026-02-04 11:02:40.899
HD Request # 302 | Completion time: 1s. | 2026-02-04 11:02:40.899
HD Request # 302 | Daily data download complete for ESU16-CME. Unique request ID: 303 | 2026-02-04 11:02:40.899
Removing historical data download ID 303. | 2026-02-04 11:02:40.899
Triggering next historical data download in queue. | 2026-02-04 11:02:40.899
HD Request # 303 | Downloading Historical Daily chart data for ESZ16-CME. Starting date: 1976-02-05. Service: DTCSubInstance | 2026-02-04 11:02:40.899
HD Request # 303 | Using server: 127.0.0.1 port 11098 | 2026-02-04 11:02:40.899
Socket (2) | Creating socket. | 2026-02-04 11:02:40.899
Socket (2) | New receive buffer size: 5242880 | 2026-02-04 11:02:40.899
Socket (2) | Connecting to IP: 127.0.0.1. | 2026-02-04 11:02:40.899
Socket (4) | Socket gracefully closed by remote side. | 2026-02-04 11:02:40.900
Socket (4) | Closed. | 2026-02-04 11:02:40.900
HD Request # 303 | Setting DTC encoding to Binary VLS | 2026-02-04 11:02:40.915
HD Request # 303 | Sending historical data logon request message. | 2026-02-04 11:02:40.915
HD Request # 303 | Requesting historical Daily data starting at 1976-02-05. | 2026-02-04 11:02:40.915
HD Request # 303 | Data is being downloaded from a remote source. Download will start when this is done. | 2026-02-04 11:02:40.916
HD Request # 303 | Decompressing data. | 2026-02-04 11:02:41.924
HD Request # 303 | Receiving historical Daily data for ESZ16-CME starting at 2015-09-18. | 2026-02-04 11:02:41.926
HD Request # 303 | Writing historical Daily data to the file ESZ16-CME.dly. | 2026-02-04 11:02:41.926
Socket (2) | CloseSocket call. | 2026-02-04 11:02:41.927
Socket (2) | Shutdown started. Waiting for graceful close. | 2026-02-04 11:02:41.927
Historical data download thread signaled to stop. | 2026-02-04 11:02:41.928
HD Request # 303 | Received 316 Daily data records from 2015-09-18 00:00:00 to 2016-12-16 00:00:00 (456.0 days) and wrote 316 records for ESZ16-CME | 2026-02-04 11:02:41.928
HD Request # 303 | Completion time: 1s. | 2026-02-04 11:02:41.928
HD Request # 303 | Daily data download complete for ESZ16-CME. Unique request ID: 304 | 2026-02-04 11:02:41.928
Removing historical data download ID 304. | 2026-02-04 11:02:41.928
Triggering next historical data download in queue. | 2026-02-04 11:02:41.928
HD Request # 304 | Downloading Historical Daily chart data for ESH17-CME. Starting date: 1976-02-05. Service: DTCSubInstance | 2026-02-04 11:02:41.928
HD Request # 304 | Using server: 127.0.0.1 port 11098 | 2026-02-04 11:02:41.929
Socket (4) | Creating socket. | 2026-02-04 11:02:41.929
Socket (4) | New receive buffer size: 5242880 | 2026-02-04 11:02:41.929
Socket (4) | Connecting to IP: 127.0.0.1. | 2026-02-04 11:02:41.929
Socket (2) | Socket gracefully closed by remote side. | 2026-02-04 11:02:41.929
Socket (2) | Closed. | 2026-02-04 11:02:41.929
HD Request # 304 | Setting DTC encoding to Binary VLS | 2026-02-04 11:02:42.001
HD Request # 304 | Sending historical data logon request message. | 2026-02-04 11:02:42.001
HD Request # 304 | Requesting historical Daily data starting at 1976-02-05. | 2026-02-04 11:02:42.002
HD Request # 304 | Data is being downloaded from a remote source. Download will start when this is done. | 2026-02-04 11:02:42.002
HD Request # 304 | Decompressing data. | 2026-02-04 11:02:43.016
HD Request # 304 | Receiving historical Daily data for ESH17-CME starting at 2015-12-07. | 2026-02-04 11:02:43.018
HD Request # 304 | Writing historical Daily data to the file ESH17-CME.dly. | 2026-02-04 11:02:43.019
Socket (4) | CloseSocket call. | 2026-02-04 11:02:43.020
Socket (4) | Shutdown started. Waiting for graceful close. | 2026-02-04 11:02:43.020
Historical data download thread signaled to stop. | 2026-02-04 11:02:43.020
HD Request # 304 | Received 315 Daily data records from 2015-12-07 00:00:00 to 2017-03-17 00:00:00 (467.0 days) and wrote 315 records for ESH17-CME | 2026-02-04 11:02:43.020
HD Request # 304 | Completion time: 2s. | 2026-02-04 11:02:43.020
HD Request # 304 | Daily data download complete for ESH17-CME. Unique request ID: 305 | 2026-02-04 11:02:43.020
Removing historical data download ID 305. | 2026-02-04 11:02:43.020
Triggering next historical data download in queue. | 2026-02-04 11:02:43.020
HD Request # 305 | Downloading Historical Daily chart data for ESM17-CME. Starting date: 1976-02-05. Service: DTCSubInstance | 2026-02-04 11:02:43.020
HD Request # 305 | Using server: 127.0.0.1 port 11098 | 2026-02-04 11:02:43.020
Socket (4) | Socket gracefully closed by remote side. | 2026-02-04 11:02:43.020
Socket (4) | Closed. | 2026-02-04 11:02:43.020
Socket (2) | Creating socket. | 2026-02-04 11:02:43.021
Socket (2) | New receive buffer size: 5242880 | 2026-02-04 11:02:43.021
Socket (2) | Connecting to IP: 127.0.0.1. | 2026-02-04 11:02:43.021
HD Request # 305 | Setting DTC encoding to Binary VLS | 2026-02-04 11:02:43.419
HD Request # 305 | Sending historical data logon request message. | 2026-02-04 11:02:43.419
HD Request # 305 | Requesting historical Daily data starting at 1976-02-05. | 2026-02-04 11:02:43.419
HD Request # 305 | Data is being downloaded from a remote source. Download will start when this is done. | 2026-02-04 11:02:43.419
HD Request # 305 | Decompressing data. | 2026-02-04 11:02:44.426
HD Request # 305 | Receiving historical Daily data for ESM17-CME starting at 2016-03-18. | 2026-02-04 11:02:44.427
HD Request # 305 | Writing historical Daily data to the file ESM17-CME.dly. | 2026-02-04 11:02:44.427
Socket (2) | CloseSocket call. | 2026-02-04 11:02:44.430
Socket (2) | Shutdown started. Waiting for graceful close. | 2026-02-04 11:02:44.430
Historical data download thread signaled to stop. | 2026-02-04 11:02:44.431
HD Request # 305 | Received 315 Daily data records from 2016-03-18 00:00:00 to 2017-06-16 00:00:00 (456.0 days) and wrote 315 records for ESM17-CME | 2026-02-04 11:02:44.431
HD Request # 305 | Completion time: 1s. | 2026-02-04 11:02:44.431
HD Request # 305 | Daily data download complete for ESM17-CME. Unique request ID: 306 | 2026-02-04 11:02:44.431
Removing historical data download ID 306. | 2026-02-04 11:02:44.431
Triggering next historical data download in queue. | 2026-02-04 11:02:44.431
HD Request # 306 | Downloading Historical Daily chart data for ESU17-CME. Starting date: 1976-02-05. Service: DTCSubInstance | 2026-02-04 11:02:44.431
HD Request # 306 | Using server: 127.0.0.1 port 11098 | 2026-02-04 11:02:44.431
Socket (2) | Socket gracefully closed by remote side. | 2026-02-04 11:02:44.431
Socket (2) | Closed. | 2026-02-04 11:02:44.431
Socket (4) | Creating socket. | 2026-02-04 11:02:44.431
Socket (4) | New receive buffer size: 5242880 | 2026-02-04 11:02:44.431
Socket (4) | Connecting to IP: 127.0.0.1. | 2026-02-04 11:02:44.431
HD Request # 306 | Setting DTC encoding to Binary VLS | 2026-02-04 11:02:44.656
HD Request # 306 | Sending historical data logon request message. | 2026-02-04 11:02:44.656
HD Request # 306 | Requesting historical Daily data starting at 1976-02-05. | 2026-02-04 11:02:44.656
HD Request # 306 | Data is being downloaded from a remote source. Download will start when this is done. | 2026-02-04 11:02:44.657
HD Request # 306 | Decompressing data. | 2026-02-04 11:02:45.665
HD Request # 306 | Receiving historical Daily data for ESU17-CME starting at 2016-06-17. | 2026-02-04 11:02:45.667
HD Request # 306 | Writing historical Daily data to the file ESU17-CME.dly. | 2026-02-04 11:02:45.667
Socket (4) | CloseSocket call. | 2026-02-04 11:02:45.668
Socket (4) | Shutdown started. Waiting for graceful close. | 2026-02-04 11:02:45.668
Historical data download thread signaled to stop. | 2026-02-04 11:02:45.668
HD Request # 306 | Received 315 Daily data records from 2016-06-17 00:00:00 to 2017-09-15 00:00:00 (456.0 days) and wrote 315 records for ESU17-CME | 2026-02-04 11:02:45.668
HD Request # 306 | Completion time: 1s. | 2026-02-04 11:02:45.668
HD Request # 306 | Daily data download complete for ESU17-CME. Unique request ID: 307 | 2026-02-04 11:02:45.668
Removing historical data download ID 307. | 2026-02-04 11:02:45.668
Triggering next historical data download in queue. | 2026-02-04 11:02:45.668
HD Request # 307 | Downloading Historical Daily chart data for ESZ17-CME. Starting date: 1976-02-05. Service: DTCSubInstance | 2026-02-04 11:02:45.668
HD Request # 307 | Using server: 127.0.0.1 port 11098 | 2026-02-04 11:02:45.668
Socket (4) | Socket gracefully closed by remote side. | 2026-02-04 11:02:45.668
Socket (4) | Closed. | 2026-02-04 11:02:45.668
Socket (2) | Creating socket. | 2026-02-04 11:02:45.669
Socket (2) | New receive buffer size: 5242880 | 2026-02-04 11:02:45.669
Socket (2) | Connecting to IP: 127.0.0.1. | 2026-02-04 11:02:45.669
HD Request # 307 | Setting DTC encoding to Binary VLS | 2026-02-04 11:02:45.682
HD Request # 307 | Sending historical data logon request message. | 2026-02-04 11:02:45.682
HD Request # 307 | Requesting historical Daily data starting at 1976-02-05. | 2026-02-04 11:02:45.683
HD Request # 307 | Data is being downloaded from a remote source. Download will start when this is done. | 2026-02-04 11:02:45.683
HD Request # 307 | Decompressing data. | 2026-02-04 11:02:46.702
HD Request # 307 | Receiving historical Daily data for ESZ17-CME starting at 2016-09-16. | 2026-02-04 11:02:46.704
HD Request # 307 | Writing historical Daily data to the file ESZ17-CME.dly. | 2026-02-04 11:02:46.704
Socket (2) | CloseSocket call. | 2026-02-04 11:02:46.705
Socket (2) | Shutdown started. Waiting for graceful close. | 2026-02-04 11:02:46.705
Historical data download thread signaled to stop. | 2026-02-04 11:02:46.705
HD Request # 307 | Received 316 Daily data records from 2016-09-16 00:00:00 to 2017-12-15 00:00:00 (456.0 days) and wrote 316 records for ESZ17-CME | 2026-02-04 11:02:46.705
HD Request # 307 | Completion time: 1s. | 2026-02-04 11:02:46.705
HD Request # 307 | Daily data download complete for ESZ17-CME. Unique request ID: 308 | 2026-02-04 11:02:46.705
Removing historical data download ID 308. | 2026-02-04 11:02:46.705
Triggering next historical data download in queue. | 2026-02-04 11:02:46.705
HD Request # 308 | Downloading Historical Daily chart data for ESH18-CME. Starting date: 1976-02-05. Service: DTCSubInstance | 2026-02-04 11:02:46.705
HD Request # 308 | Using server: 127.0.0.1 port 11098 | 2026-02-04 11:02:46.705
Socket (2) | Socket gracefully closed by remote side. | 2026-02-04 11:02:46.706
Socket (2) | Closed. | 2026-02-04 11:02:46.706
Socket (4) | Creating socket. | 2026-02-04 11:02:46.706
Socket (4) | New receive buffer size: 5242880 | 2026-02-04 11:02:46.706
Socket (4) | Connecting to IP: 127.0.0.1. | 2026-02-04 11:02:46.706
HD Request # 308 | Setting DTC encoding to Binary VLS | 2026-02-04 11:02:46.722
HD Request # 308 | Sending historical data logon request message. | 2026-02-04 11:02:46.722
HD Request # 308 | Requesting historical Daily data starting at 1976-02-05. | 2026-02-04 11:02:46.723
HD Request # 308 | Data is being downloaded from a remote source. Download will start when this is done. | 2026-02-04 11:02:46.723
HD Request # 308 | Decompressing data. | 2026-02-04 11:02:47.749
HD Request # 308 | Receiving historical Daily data for ESH18-CME starting at 2016-12-16. | 2026-02-04 11:02:47.750
HD Request # 308 | Writing historical Daily data to the file ESH18-CME.dly. | 2026-02-04 11:02:47.750
Socket (4) | CloseSocket call. | 2026-02-04 11:02:47.751
Socket (4) | Shutdown started. Waiting for graceful close. | 2026-02-04 11:02:47.751
Historical data download thread signaled to stop. | 2026-02-04 11:02:47.752
HD Request # 308 | Received 313 Daily data records from 2016-12-16 00:00:00 to 2018-03-16 00:00:00 (456.0 days) and wrote 313 records for ESH18-CME | 2026-02-04 11:02:47.752
HD Request # 308 | Completion time: 1s. | 2026-02-04 11:02:47.752
HD Request # 308 | Daily data download complete for ESH18-CME. Unique request ID: 309 | 2026-02-04 11:02:47.752
Removing historical data download ID 309. | 2026-02-04 11:02:47.752
Triggering next historical data download in queue. | 2026-02-04 11:02:47.752
HD Request # 309 | Downloading Historical Daily chart data for ESM18-CME. Starting date: 1976-02-05. Service: DTCSubInstance | 2026-02-04 11:02:47.752
Socket (4) | Socket gracefully closed by remote side. | 2026-02-04 11:02:47.752
HD Request # 309 | Using server: 127.0.0.1 port 11098 | 2026-02-04 11:02:47.752
Socket (4) | Closed. | 2026-02-04 11:02:47.752
Socket (2) | Creating socket. | 2026-02-04 11:02:47.752
Socket (2) | New receive buffer size: 5242880 | 2026-02-04 11:02:47.753
Socket (2) | Connecting to IP: 127.0.0.1. | 2026-02-04 11:02:47.753
HD Request # 309 | Setting DTC encoding to Binary VLS | 2026-02-04 11:02:47.769
HD Request # 309 | Sending historical data logon request message. | 2026-02-04 11:02:47.769
HD Request # 309 | Requesting historical Daily data starting at 1976-02-05. | 2026-02-04 11:02:47.769
HD Request # 309 | Data is being downloaded from a remote source. Download will start when this is done. | 2026-02-04 11:02:47.769
HD Request # 309 | Decompressing data. | 2026-02-04 11:02:48.771
HD Request # 309 | Receiving historical Daily data for ESM18-CME starting at 2017-03-17. | 2026-02-04 11:02:48.772
HD Request # 309 | Writing historical Daily data to the file ESM18-CME.dly. | 2026-02-04 11:02:48.772
Socket (2) | CloseSocket call. | 2026-02-04 11:02:48.774
Socket (2) | Shutdown started. Waiting for graceful close. | 2026-02-04 11:02:48.774
Historical data download thread signaled to stop. | 2026-02-04 11:02:48.774
HD Request # 309 | Received 315 Daily data records from 2017-03-17 00:00:00 to 2018-06-15 00:00:00 (456.0 days) and wrote 315 records for ESM18-CME | 2026-02-04 11:02:48.774
HD Request # 309 | Completion time: 1s. | 2026-02-04 11:02:48.774
HD Request # 309 | Daily data download complete for ESM18-CME. Unique request ID: 310 | 2026-02-04 11:02:48.774
Removing historical data download ID 310. | 2026-02-04 11:02:48.774
Triggering next historical data download in queue. | 2026-02-04 11:02:48.774
HD Request # 310 | Downloading Historical Daily chart data for ESU18-CME. Starting date: 1976-02-05. Service: DTCSubInstance | 2026-02-04 11:02:48.774
HD Request # 310 | Using server: 127.0.0.1 port 11098 | 2026-02-04 11:02:48.775
Socket (4) | Creating socket. | 2026-02-04 11:02:48.775
Socket (4) | New receive buffer size: 5242880 | 2026-02-04 11:02:48.775
Socket (4) | Connecting to IP: 127.0.0.1. | 2026-02-04 11:02:48.775
Socket (2) | Socket gracefully closed by remote side. | 2026-02-04 11:02:48.775
Socket (2) | Closed. | 2026-02-04 11:02:48.775
HD Request # 310 | Setting DTC encoding to Binary VLS | 2026-02-04 11:02:48.788
HD Request # 310 | Sending historical data logon request message. | 2026-02-04 11:02:48.788
HD Request # 310 | Requesting historical Daily data starting at 1976-02-05. | 2026-02-04 11:02:48.789
HD Request # 310 | Data is being downloaded from a remote source. Download will start when this is done. | 2026-02-04 11:02:48.790
HD Request # 310 | Decompressing data. | 2026-02-04 11:02:49.780
HD Request # 310 | Receiving historical Daily data for ESU18-CME starting at 2017-06-14. | 2026-02-04 11:02:49.782
HD Request # 310 | Writing historical Daily data to the file ESU18-CME.dly. | 2026-02-04 11:02:49.782
Socket (4) | CloseSocket call. | 2026-02-04 11:02:49.783
Socket (4) | Shutdown started. Waiting for graceful close. | 2026-02-04 11:02:49.783
Historical data download thread signaled to stop. | 2026-02-04 11:02:49.783
HD Request # 310 | Received 322 Daily data records from 2017-06-14 00:00:00 to 2018-09-21 00:00:00 (465.0 days) and wrote 322 records for ESU18-CME | 2026-02-04 11:02:49.784
HD Request # 310 | Completion time: 1s. | 2026-02-04 11:02:49.784
HD Request # 310 | Daily data download complete for ESU18-CME. Unique request ID: 311 | 2026-02-04 11:02:49.784
Removing historical data download ID 311. | 2026-02-04 11:02:49.784
Triggering next historical data download in queue. | 2026-02-04 11:02:49.784
HD Request # 311 | Downloading Historical Daily chart data for ESZ18-CME. Starting date: 1976-02-05. Service: DTCSubInstance | 2026-02-04 11:02:49.784
HD Request # 311 | Using server: 127.0.0.1 port 11098 | 2026-02-04 11:02:49.784
Socket (2) | Creating socket. | 2026-02-04 11:02:49.784
Socket (2) | New receive buffer size: 5242880 | 2026-02-04 11:02:49.784
Socket (2) | Connecting to IP: 127.0.0.1. | 2026-02-04 11:02:49.784
Socket (4) | Socket gracefully closed by remote side. | 2026-02-04 11:02:49.784
Socket (4) | Closed. | 2026-02-04 11:02:49.784
HD Request # 311 | Setting DTC encoding to Binary VLS | 2026-02-04 11:02:49.798
HD Request # 311 | Sending historical data logon request message. | 2026-02-04 11:02:49.798
HD Request # 311 | Requesting historical Daily data starting at 1976-02-05. | 2026-02-04 11:02:49.798
HD Request # 311 | Data is being downloaded from a remote source. Download will start when this is done. | 2026-02-04 11:02:49.799
HD Request # 311 | Decompressing data. | 2026-02-04 11:02:50.810
HD Request # 311 | Receiving historical Daily data for ESZ18-CME starting at 2017-09-13. | 2026-02-04 11:02:50.811
HD Request # 311 | Writing historical Daily data to the file ESZ18-CME.dly. | 2026-02-04 11:02:50.812
Socket (2) | CloseSocket call. | 2026-02-04 11:02:50.813
Socket (2) | Shutdown started. Waiting for graceful close. | 2026-02-04 11:02:50.813
Historical data download thread signaled to stop. | 2026-02-04 11:02:50.814
HD Request # 311 | Received 322 Daily data records from 2017-09-13 00:00:00 to 2018-12-21 00:00:00 (465.0 days) and wrote 322 records for ESZ18-CME | 2026-02-04 11:02:50.814
HD Request # 311 | Completion time: 1s. | 2026-02-04 11:02:50.814
HD Request # 311 | Daily data download complete for ESZ18-CME. Unique request ID: 312 | 2026-02-04 11:02:50.814
Removing historical data download ID 312. | 2026-02-04 11:02:50.814
Triggering next historical data download in queue. | 2026-02-04 11:02:50.814
HD Request # 312 | Downloading Historical Daily chart data for ESH19-CME. Starting date: 1976-02-05. Service: DTCSubInstance | 2026-02-04 11:02:50.814
HD Request # 312 | Using server: 127.0.0.1 port 11098 | 2026-02-04 11:02:50.814
Socket (4) | Creating socket. | 2026-02-04 11:02:50.814
Socket (4) | New receive buffer size: 5242880 | 2026-02-04 11:02:50.814
Socket (4) | Connecting to IP: 127.0.0.1. | 2026-02-04 11:02:50.814
Socket (2) | Socket gracefully closed by remote side. | 2026-02-04 11:02:50.814
Socket (2) | Closed. | 2026-02-04 11:02:50.814
HD Request # 312 | Setting DTC encoding to Binary VLS | 2026-02-04 11:02:50.828
HD Request # 312 | Sending historical data logon request message. | 2026-02-04 11:02:50.828
HD Request # 312 | Requesting historical Daily data starting at 1976-02-05. | 2026-02-04 11:02:50.828
HD Request # 312 | Data is being downloaded from a remote source. Download will start when this is done. | 2026-02-04 11:02:50.829
HD Request # 312 | Decompressing data. | 2026-02-04 11:02:51.838
HD Request # 312 | Receiving historical Daily data for ESH19-CME starting at 2017-12-13. | 2026-02-04 11:02:51.840
HD Request # 312 | Writing historical Daily data to the file ESH19-CME.dly. | 2026-02-04 11:02:51.840
Socket (4) | CloseSocket call. | 2026-02-04 11:02:51.842
Socket (4) | Shutdown started. Waiting for graceful close. | 2026-02-04 11:02:51.842
Historical data download thread signaled to stop. | 2026-02-04 11:02:51.842
HD Request # 312 | Received 314 Daily data records from 2017-12-13 00:00:00 to 2019-03-15 00:00:00 (458.0 days) and wrote 314 records for ESH19-CME | 2026-02-04 11:02:51.842
HD Request # 312 | Completion time: 1s. | 2026-02-04 11:02:51.842
HD Request # 312 | Daily data download complete for ESH19-CME. Unique request ID: 313 | 2026-02-04 11:02:51.842
Removing historical data download ID 313. | 2026-02-04 11:02:51.842
Triggering next historical data download in queue. | 2026-02-04 11:02:51.842
HD Request # 313 | Downloading Historical Daily chart data for ESM19-CME. Starting date: 1976-02-05. Service: DTCSubInstance | 2026-02-04 11:02:51.842
Socket (4) | Socket gracefully closed by remote side. | 2026-02-04 11:02:51.843
Socket (4) | Closed. | 2026-02-04 11:02:51.843
HD Request # 313 | Using server: 127.0.0.1 port 11098 | 2026-02-04 11:02:51.843
Socket (2) | Creating socket. | 2026-02-04 11:02:51.843
Socket (2) | New receive buffer size: 5242880 | 2026-02-04 11:02:51.843
Socket (2) | Connecting to IP: 127.0.0.1. | 2026-02-04 11:02:51.843
HD Request # 313 | Setting DTC encoding to Binary VLS | 2026-02-04 11:02:51.857
HD Request # 313 | Sending historical data logon request message. | 2026-02-04 11:02:51.857
HD Request # 313 | Requesting historical Daily data starting at 1976-02-05. | 2026-02-04 11:02:51.857
HD Request # 313 | Data is being downloaded from a remote source. Download will start when this is done. | 2026-02-04 11:02:51.858
HD Request # 313 | Decompressing data. | 2026-02-04 11:02:52.866
HD Request # 313 | Receiving historical Daily data for ESM19-CME starting at 2018-03-14. | 2026-02-04 11:02:52.868
HD Request # 313 | Writing historical Daily data to the file ESM19-CME.dly. | 2026-02-04 11:02:52.868
Socket (2) | CloseSocket call. | 2026-02-04 11:02:52.869
Socket (2) | Shutdown started. Waiting for graceful close. | 2026-02-04 11:02:52.869
Historical data download thread signaled to stop. | 2026-02-04 11:02:52.869
HD Request # 313 | Received 321 Daily data records from 2018-03-14 00:00:00 to 2019-06-21 00:00:00 (465.0 days) and wrote 321 records for ESM19-CME | 2026-02-04 11:02:52.869
HD Request # 313 | Completion time: 1s. | 2026-02-04 11:02:52.869
HD Request # 313 | Daily data download complete for ESM19-CME. Unique request ID: 314 | 2026-02-04 11:02:52.869
Removing historical data download ID 314. | 2026-02-04 11:02:52.869
Triggering next historical data download in queue. | 2026-02-04 11:02:52.869
HD Request # 314 | Downloading Historical Daily chart data for ESU19-CME. Starting date: 1976-02-05. Service: DTCSubInstance | 2026-02-04 11:02:52.869
Socket (2) | Socket gracefully closed by remote side. | 2026-02-04 11:02:52.869
HD Request # 314 | Using server: 127.0.0.1 port 11098 | 2026-02-04 11:02:52.869
Socket (2) | Closed. | 2026-02-04 11:02:52.869
Socket (2) | Creating socket. | 2026-02-04 11:02:52.870
Socket (2) | New receive buffer size: 5242880 | 2026-02-04 11:02:52.870
Socket (2) | Connecting to IP: 127.0.0.1. | 2026-02-04 11:02:52.870
HD Request # 314 | Setting DTC encoding to Binary VLS | 2026-02-04 11:02:52.886
HD Request # 314 | Sending historical data logon request message. | 2026-02-04 11:02:52.886
HD Request # 314 | Requesting historical Daily data starting at 1976-02-05. | 2026-02-04 11:02:52.887
HD Request # 314 | Data is being downloaded from a remote source. Download will start when this is done. | 2026-02-04 11:02:52.888
HD Request # 314 | Decompressing data. | 2026-02-04 11:02:53.896
HD Request # 314 | Receiving historical Daily data for ESU19-CME starting at 2018-06-15. | 2026-02-04 11:02:53.898
HD Request # 314 | Writing historical Daily data to the file ESU19-CME.dly. | 2026-02-04 11:02:53.898
Socket (2) | CloseSocket call. | 2026-02-04 11:02:53.899
Socket (2) | Shutdown started. Waiting for graceful close. | 2026-02-04 11:02:53.899
Historical data download thread signaled to stop. | 2026-02-04 11:02:53.900
HD Request # 314 | Received 319 Daily data records from 2018-06-15 00:00:00 to 2019-09-20 00:00:00 (463.0 days) and wrote 319 records for ESU19-CME | 2026-02-04 11:02:53.900
HD Request # 314 | Completion time: 1s. | 2026-02-04 11:02:53.900
HD Request # 314 | Daily data download complete for ESU19-CME. Unique request ID: 315 | 2026-02-04 11:02:53.900
Removing historical data download ID 315. | 2026-02-04 11:02:53.900
Triggering next historical data download in queue. | 2026-02-04 11:02:53.900
Socket (2) | Socket gracefully closed by remote side. | 2026-02-04 11:02:53.900
HD Request # 315 | Downloading Historical Daily chart data for ESZ19-CME. Starting date: 1976-02-05. Service: DTCSubInstance | 2026-02-04 11:02:53.900
Socket (2) | Closed. | 2026-02-04 11:02:53.900
HD Request # 315 | Using server: 127.0.0.1 port 11098 | 2026-02-04 11:02:53.900
Socket (2) | Creating socket. | 2026-02-04 11:02:53.900
Socket (2) | New receive buffer size: 5242880 | 2026-02-04 11:02:53.900
Socket (2) | Connecting to IP: 127.0.0.1. | 2026-02-04 11:02:53.900
HD Request # 315 | Setting DTC encoding to Binary VLS | 2026-02-04 11:02:53.913
HD Request # 315 | Sending historical data logon request message. | 2026-02-04 11:02:53.913
HD Request # 315 | Requesting historical Daily data starting at 1976-02-05. | 2026-02-04 11:02:53.913
HD Request # 315 | Data is being downloaded from a remote source. Download will start when this is done. | 2026-02-04 11:02:53.914
HD Request # 315 | Decompressing data. | 2026-02-04 11:02:54.910
HD Request # 315 | Receiving historical Daily data for ESZ19-CME starting at 2018-09-13. | 2026-02-04 11:02:54.912
HD Request # 315 | Writing historical Daily data to the file ESZ19-CME.dly. | 2026-02-04 11:02:54.912
Socket (2) | CloseSocket call. | 2026-02-04 11:02:54.914
Socket (2) | Shutdown started. Waiting for graceful close. | 2026-02-04 11:02:54.914
Historical data download thread signaled to stop. | 2026-02-04 11:02:54.914
HD Request # 315 | Received 321 Daily data records from 2018-09-13 00:00:00 to 2019-12-20 00:00:00 (464.0 days) and wrote 321 records for ESZ19-CME | 2026-02-04 11:02:54.914
HD Request # 315 | Completion time: 1s. | 2026-02-04 11:02:54.914
HD Request # 315 | Daily data download complete for ESZ19-CME. Unique request ID: 316 | 2026-02-04 11:02:54.914
Removing historical data download ID 316. | 2026-02-04 11:02:54.914
Triggering next historical data download in queue. | 2026-02-04 11:02:54.914
HD Request # 316 | Downloading Historical Daily chart data for ESH20-CME. Starting date: 1976-02-05. Service: DTCSubInstance | 2026-02-04 11:02:54.914
HD Request # 316 | Using server: 127.0.0.1 port 11098 | 2026-02-04 11:02:54.914
Socket (2) | Socket gracefully closed by remote side. | 2026-02-04 11:02:54.914
Socket (2) | Closed. | 2026-02-04 11:02:54.914
Socket (4) | Creating socket. | 2026-02-04 11:02:54.915
Socket (4) | New receive buffer size: 5242880 | 2026-02-04 11:02:54.915
Socket (4) | Connecting to IP: 127.0.0.1. | 2026-02-04 11:02:54.915
HD Request # 316 | Setting DTC encoding to Binary VLS | 2026-02-04 11:02:54.994
HD Request # 316 | Sending historical data logon request message. | 2026-02-04 11:02:54.994
HD Request # 316 | Requesting historical Daily data starting at 1976-02-05. | 2026-02-04 11:02:54.995
HD Request # 316 | Data is being downloaded from a remote source. Download will start when this is done. | 2026-02-04 11:02:54.996
HD Request # 316 | Decompressing data. | 2026-02-04 11:02:56.004
HD Request # 316 | Receiving historical Daily data for ESH20-CME starting at 2018-12-20. | 2026-02-04 11:02:56.005
HD Request # 316 | Writing historical Daily data to the file ESH20-CME.dly. | 2026-02-04 11:02:56.006
Socket (4) | CloseSocket call. | 2026-02-04 11:02:56.007
Socket (4) | Shutdown started. Waiting for graceful close. | 2026-02-04 11:02:56.007
Historical data download thread signaled to stop. | 2026-02-04 11:02:56.007
HD Request # 316 | Received 314 Daily data records from 2018-12-20 00:00:00 to 2020-03-20 00:00:00 (457.0 days) and wrote 314 records for ESH20-CME | 2026-02-04 11:02:56.007
HD Request # 316 | Completion time: 2s. | 2026-02-04 11:02:56.007
HD Request # 316 | Daily data download complete for ESH20-CME. Unique request ID: 317 | 2026-02-04 11:02:56.007
Removing historical data download ID 317. | 2026-02-04 11:02:56.007
Triggering next historical data download in queue. | 2026-02-04 11:02:56.007
Socket (4) | Socket gracefully closed by remote side. | 2026-02-04 11:02:56.008
Socket (4) | Closed. | 2026-02-04 11:02:56.008
HD Request # 317 | Downloading Historical Daily chart data for ESM20-CME. Starting date: 1976-02-05. Service: DTCSubInstance | 2026-02-04 11:02:56.008
HD Request # 317 | Using server: 127.0.0.1 port 11098 | 2026-02-04 11:02:56.008
Socket (2) | Creating socket. | 2026-02-04 11:02:56.008
Socket (2) | New receive buffer size: 5242880 | 2026-02-04 11:02:56.008
Socket (2) | Connecting to IP: 127.0.0.1. | 2026-02-04 11:02:56.008
HD Request # 317 | Setting DTC encoding to Binary VLS | 2026-02-04 11:02:56.080
HD Request # 317 | Sending historical data logon request message. | 2026-02-04 11:02:56.080
HD Request # 317 | Requesting historical Daily data starting at 1976-02-05. | 2026-02-04 11:02:56.081
HD Request # 317 | Data is being downloaded from a remote source. Download will start when this is done. | 2026-02-04 11:02:56.082
HD Request # 317 | Decompressing data. | 2026-02-04 11:02:57.092
HD Request # 317 | Receiving historical Daily data for ESM20-CME starting at 2019-03-14. | 2026-02-04 11:02:57.094
HD Request # 317 | Writing historical Daily data to the file ESM20-CME.dly. | 2026-02-04 11:02:57.094
Socket (2) | CloseSocket call. | 2026-02-04 11:02:57.096
Socket (2) | Shutdown started. Waiting for graceful close. | 2026-02-04 11:02:57.096
Historical data download thread signaled to stop. | 2026-02-04 11:02:57.096
HD Request # 317 | Received 321 Daily data records from 2019-03-14 00:00:00 to 2020-06-19 00:00:00 (464.0 days) and wrote 321 records for ESM20-CME | 2026-02-04 11:02:57.096
HD Request # 317 | Completion time: 1s. | 2026-02-04 11:02:57.096
HD Request # 317 | Daily data download complete for ESM20-CME. Unique request ID: 318 | 2026-02-04 11:02:57.096
Removing historical data download ID 318. | 2026-02-04 11:02:57.096
Triggering next historical data download in queue. | 2026-02-04 11:02:57.097
HD Request # 318 | Downloading Historical Daily chart data for ESU20-CME. Starting date: 1976-02-05. Service: DTCSubInstance | 2026-02-04 11:02:57.097
HD Request # 318 | Using server: 127.0.0.1 port 11098 | 2026-02-04 11:02:57.097
Socket (4) | Creating socket. | 2026-02-04 11:02:57.098
Socket (4) | New receive buffer size: 5242880 | 2026-02-04 11:02:57.098
Socket (4) | Connecting to IP: 127.0.0.1. | 2026-02-04 11:02:57.098
Socket (2) | Socket gracefully closed by remote side. | 2026-02-04 11:02:57.098
Socket (2) | Closed. | 2026-02-04 11:02:57.098
HD Request # 318 | Setting DTC encoding to Binary VLS | 2026-02-04 11:02:57.336
HD Request # 318 | Sending historical data logon request message. | 2026-02-04 11:02:57.336
HD Request # 318 | Requesting historical Daily data starting at 1976-02-05. | 2026-02-04 11:02:57.337
HD Request # 318 | Data is being downloaded from a remote source. Download will start when this is done. | 2026-02-04 11:02:57.337
HD Request # 318 | Decompressing data. | 2026-02-04 11:02:58.356
HD Request # 318 | Receiving historical Daily data for ESU20-CME starting at 2019-06-10. | 2026-02-04 11:02:58.357
HD Request # 318 | Writing historical Daily data to the file ESU20-CME.dly. | 2026-02-04 11:02:58.357
Socket (4) | CloseSocket call. | 2026-02-04 11:02:58.358
Socket (4) | Shutdown started. Waiting for graceful close. | 2026-02-04 11:02:58.359
Historical data download thread signaled to stop. | 2026-02-04 11:02:58.359
HD Request # 318 | Received 324 Daily data records from 2019-06-10 00:00:00 to 2020-09-18 00:00:00 (467.0 days) and wrote 324 records for ESU20-CME | 2026-02-04 11:02:58.359
HD Request # 318 | Completion time: 1s. | 2026-02-04 11:02:58.359
HD Request # 318 | Daily data download complete for ESU20-CME. Unique request ID: 319 | 2026-02-04 11:02:58.359
Removing historical data download ID 319. | 2026-02-04 11:02:58.359
Triggering next historical data download in queue. | 2026-02-04 11:02:58.359
HD Request # 319 | Downloading Historical Daily chart data for ESZ20-CME. Starting date: 1976-02-05. Service: DTCSubInstance | 2026-02-04 11:02:58.359
HD Request # 319 | Using server: 127.0.0.1 port 11098 | 2026-02-04 11:02:58.359
Socket (2) | Creating socket. | 2026-02-04 11:02:58.359
Socket (2) | New receive buffer size: 5242880 | 2026-02-04 11:02:58.359
Socket (2) | Connecting to IP: 127.0.0.1. | 2026-02-04 11:02:58.359
Socket (4) | Socket gracefully closed by remote side. | 2026-02-04 11:02:58.359
Socket (4) | Closed. | 2026-02-04 11:02:58.359
HD Request # 319 | Setting DTC encoding to Binary VLS | 2026-02-04 11:02:58.656
HD Request # 319 | Sending historical data logon request message. | 2026-02-04 11:02:58.656
HD Request # 319 | Requesting historical Daily data starting at 1976-02-05. | 2026-02-04 11:02:58.656
HD Request # 319 | Data is being downloaded from a remote source. Download will start when this is done. | 2026-02-04 11:02:58.657
HD Request # 319 | Decompressing data. | 2026-02-04 11:02:59.661
HD Request # 319 | Receiving historical Daily data for ESZ20-CME starting at 2019-09-09. | 2026-02-04 11:02:59.662
HD Request # 319 | Writing historical Daily data to the file ESZ20-CME.dly. | 2026-02-04 11:02:59.663
Socket (2) | CloseSocket call. | 2026-02-04 11:02:59.664
Socket (2) | Shutdown started. Waiting for graceful close. | 2026-02-04 11:02:59.664
Historical data download thread signaled to stop. | 2026-02-04 11:02:59.664
HD Request # 319 | Received 325 Daily data records from 2019-09-09 00:00:00 to 2020-12-18 00:00:00 (467.0 days) and wrote 325 records for ESZ20-CME | 2026-02-04 11:02:59.664
HD Request # 319 | Completion time: 1s. | 2026-02-04 11:02:59.664
HD Request # 319 | Daily data download complete for ESZ20-CME. Unique request ID: 320 | 2026-02-04 11:02:59.664
Removing historical data download ID 320. | 2026-02-04 11:02:59.664
Triggering next historical data download in queue. | 2026-02-04 11:02:59.664
HD Request # 320 | Downloading Historical Daily chart data for ESH21-CME. Starting date: 1976-02-05. Service: DTCSubInstance | 2026-02-04 11:02:59.665
HD Request # 320 | Using server: 127.0.0.1 port 11098 | 2026-02-04 11:02:59.665
Socket (2) | Socket gracefully closed by remote side. | 2026-02-04 11:02:59.665
Socket (2) | Closed. | 2026-02-04 11:02:59.665
Socket (4) | Creating socket. | 2026-02-04 11:02:59.665
Socket (4) | New receive buffer size: 5242880 | 2026-02-04 11:02:59.665
Socket (4) | Connecting to IP: 127.0.0.1. | 2026-02-04 11:02:59.665
HD Request # 320 | Setting DTC encoding to Binary VLS | 2026-02-04 11:02:59.679
HD Request # 320 | Sending historical data logon request message. | 2026-02-04 11:02:59.679
HD Request # 320 | Requesting historical Daily data starting at 1976-02-05. | 2026-02-04 11:02:59.679
HD Request # 320 | Data is being downloaded from a remote source. Download will start when this is done. | 2026-02-04 11:02:59.680
HD Request # 320 | Decompressing data. | 2026-02-04 11:03:00.683
HD Request # 320 | Receiving historical Daily data for ESH21-CME starting at 2019-12-09. | 2026-02-04 11:03:00.685
HD Request # 320 | Writing historical Daily data to the file ESH21-CME.dly. | 2026-02-04 11:03:00.685
Socket (4) | CloseSocket call. | 2026-02-04 11:03:00.686
Socket (4) | Shutdown started. Waiting for graceful close. | 2026-02-04 11:03:00.686
Historical data download thread signaled to stop. | 2026-02-04 11:03:00.686
HD Request # 320 | Received 322 Daily data records from 2019-12-09 00:00:00 to 2021-03-19 00:00:00 (467.0 days) and wrote 322 records for ESH21-CME | 2026-02-04 11:03:00.686
HD Request # 320 | Completion time: 1s. | 2026-02-04 11:03:00.686
HD Request # 320 | Daily data download complete for ESH21-CME. Unique request ID: 321 | 2026-02-04 11:03:00.686
Removing historical data download ID 321. | 2026-02-04 11:03:00.686
Triggering next historical data download in queue. | 2026-02-04 11:03:00.687
HD Request # 321 | Downloading Historical Daily chart data for ESM21-CME. Starting date: 1976-02-05. Service: DTCSubInstance | 2026-02-04 11:03:00.687
HD Request # 321 | Using server: 127.0.0.1 port 11098 | 2026-02-04 11:03:00.687
Socket (2) | Creating socket. | 2026-02-04 11:03:00.687
Socket (2) | New receive buffer size: 5242880 | 2026-02-04 11:03:00.687
Socket (2) | Connecting to IP: 127.0.0.1. | 2026-02-04 11:03:00.687
Socket (4) | Socket gracefully closed by remote side. | 2026-02-04 11:03:00.687
Socket (4) | Closed. | 2026-02-04 11:03:00.687
HD Request # 321 | Setting DTC encoding to Binary VLS | 2026-02-04 11:03:00.710
HD Request # 321 | Sending historical data logon request message. | 2026-02-04 11:03:00.710
HD Request # 321 | Requesting historical Daily data starting at 1976-02-05. | 2026-02-04 11:03:00.711
HD Request # 321 | Data is being downloaded from a remote source. Download will start when this is done. | 2026-02-04 11:03:00.712
HD Request # 321 | Decompressing data. | 2026-02-04 11:03:01.720
HD Request # 321 | Receiving historical Daily data for ESM21-CME starting at 2020-03-09. | 2026-02-04 11:03:01.721
HD Request # 321 | Writing historical Daily data to the file ESM21-CME.dly. | 2026-02-04 11:03:01.721
Socket (2) | CloseSocket call. | 2026-02-04 11:03:01.723
Socket (2) | Shutdown started. Waiting for graceful close. | 2026-02-04 11:03:01.723
Historical data download thread signaled to stop. | 2026-02-04 11:03:01.723
HD Request # 321 | Received 324 Daily data records from 2020-03-09 00:00:00 to 2021-06-18 00:00:00 (467.0 days) and wrote 324 records for ESM21-CME | 2026-02-04 11:03:01.723
HD Request # 321 | Completion time: 1s. | 2026-02-04 11:03:01.723
HD Request # 321 | Daily data download complete for ESM21-CME. Unique request ID: 322 | 2026-02-04 11:03:01.723
Removing historical data download ID 322. | 2026-02-04 11:03:01.723
Triggering next historical data download in queue. | 2026-02-04 11:03:01.723
Socket (2) | Socket gracefully closed by remote side. | 2026-02-04 11:03:01.723
Socket (2) | Closed. | 2026-02-04 11:03:01.723
HD Request # 322 | Downloading Historical Daily chart data for ESU21-CME. Starting date: 1976-02-05. Service: DTCSubInstance | 2026-02-04 11:03:01.723
HD Request # 322 | Using server: 127.0.0.1 port 11098 | 2026-02-04 11:03:01.723
Socket (2) | Creating socket. | 2026-02-04 11:03:01.724
Socket (2) | New receive buffer size: 5242880 | 2026-02-04 11:03:01.724
Socket (2) | Connecting to IP: 127.0.0.1. | 2026-02-04 11:03:01.724
HD Request # 322 | Setting DTC encoding to Binary VLS | 2026-02-04 11:03:01.738
HD Request # 322 | Sending historical data logon request message. | 2026-02-04 11:03:01.738
HD Request # 322 | Requesting historical Daily data starting at 1976-02-05. | 2026-02-04 11:03:01.738
HD Request # 322 | Data is being downloaded from a remote source. Download will start when this is done. | 2026-02-04 11:03:01.739
HD Request # 322 | Decompressing data. | 2026-02-04 11:03:02.749
HD Request # 322 | Receiving historical Daily data for ESU21-CME starting at 2020-06-08. | 2026-02-04 11:03:02.751
HD Request # 322 | Writing historical Daily data to the file ESU21-CME.dly. | 2026-02-04 11:03:02.751
Socket (2) | CloseSocket call. | 2026-02-04 11:03:02.752
Socket (2) | Shutdown started. Waiting for graceful close. | 2026-02-04 11:03:02.753
Historical data download thread signaled to stop. | 2026-02-04 11:03:02.753
HD Request # 322 | Received 324 Daily data records from 2020-06-08 00:00:00 to 2021-09-17 00:00:00 (467.0 days) and wrote 324 records for ESU21-CME | 2026-02-04 11:03:02.753
HD Request # 322 | Completion time: 1s. | 2026-02-04 11:03:02.753
HD Request # 322 | Daily data download complete for ESU21-CME. Unique request ID: 323 | 2026-02-04 11:03:02.753
Removing historical data download ID 323. | 2026-02-04 11:03:02.753
Triggering next historical data download in queue. | 2026-02-04 11:03:02.753
HD Request # 323 | Downloading Historical Daily chart data for ESZ21-CME. Starting date: 1976-02-05. Service: DTCSubInstance | 2026-02-04 11:03:02.753
HD Request # 323 | Using server: 127.0.0.1 port 11098 | 2026-02-04 11:03:02.753
Socket (4) | Creating socket. | 2026-02-04 11:03:02.753
Socket (4) | New receive buffer size: 5242880 | 2026-02-04 11:03:02.753
Socket (4) | Connecting to IP: 127.0.0.1. | 2026-02-04 11:03:02.753
Socket (2) | Socket gracefully closed by remote side. | 2026-02-04 11:03:02.753
Socket (2) | Closed. | 2026-02-04 11:03:02.753
HD Request # 323 | Setting DTC encoding to Binary VLS | 2026-02-04 11:03:02.768
HD Request # 323 | Sending historical data logon request message. | 2026-02-04 11:03:02.768
HD Request # 323 | Requesting historical Daily data starting at 1976-02-05. | 2026-02-04 11:03:02.768
HD Request # 323 | Data is being downloaded from a remote source. Download will start when this is done. | 2026-02-04 11:03:02.769
HD Request # 323 | Decompressing data. | 2026-02-04 11:03:03.768
HD Request # 323 | Receiving historical Daily data for ESZ21-CME starting at 2020-09-08. | 2026-02-04 11:03:03.770
HD Request # 323 | Writing historical Daily data to the file ESZ21-CME.dly. | 2026-02-04 11:03:03.770
Socket (4) | CloseSocket call. | 2026-02-04 11:03:03.771
Socket (4) | Shutdown started. Waiting for graceful close. | 2026-02-04 11:03:03.771
Historical data download thread signaled to stop. | 2026-02-04 11:03:03.772
HD Request # 323 | Received 324 Daily data records from 2020-09-08 00:00:00 to 2021-12-17 00:00:00 (466.0 days) and wrote 324 records for ESZ21-CME | 2026-02-04 11:03:03.772
HD Request # 323 | Completion time: 1s. | 2026-02-04 11:03:03.772
HD Request # 323 | Daily data download complete for ESZ21-CME. Unique request ID: 324 | 2026-02-04 11:03:03.772
Removing historical data download ID 324. | 2026-02-04 11:03:03.772
Triggering next historical data download in queue. | 2026-02-04 11:03:03.772
HD Request # 324 | Downloading Historical Daily chart data for ESH22-CME. Starting date: 1976-02-05. Service: DTCSubInstance | 2026-02-04 11:03:03.772
Socket (4) | Socket gracefully closed by remote side. | 2026-02-04 11:03:03.772
Socket (4) | Closed. | 2026-02-04 11:03:03.772
HD Request # 324 | Using server: 127.0.0.1 port 11098 | 2026-02-04 11:03:03.772
Socket (2) | Creating socket. | 2026-02-04 11:03:03.773
Socket (2) | New receive buffer size: 5242880 | 2026-02-04 11:03:03.773
Socket (2) | Connecting to IP: 127.0.0.1. | 2026-02-04 11:03:03.773
HD Request # 324 | Setting DTC encoding to Binary VLS | 2026-02-04 11:03:03.797
HD Request # 324 | Sending historical data logon request message. | 2026-02-04 11:03:03.797
HD Request # 324 | Requesting historical Daily data starting at 1976-02-05. | 2026-02-04 11:03:03.798
HD Request # 324 | Data is being downloaded from a remote source. Download will start when this is done. | 2026-02-04 11:03:03.799
HD Request # 324 | Decompressing data. | 2026-02-04 11:03:04.808
HD Request # 324 | Receiving historical Daily data for ESH22-CME starting at 2020-12-07. | 2026-02-04 11:03:04.809
HD Request # 324 | Writing historical Daily data to the file ESH22-CME.dly. | 2026-02-04 11:03:04.809
Socket (2) | CloseSocket call. | 2026-02-04 11:03:04.810
Socket (2) | Shutdown started. Waiting for graceful close. | 2026-02-04 11:03:04.811
Historical data download thread signaled to stop. | 2026-02-04 11:03:04.811
HD Request # 324 | Received 323 Daily data records from 2020-12-07 00:00:00 to 2022-03-18 00:00:00 (467.0 days) and wrote 323 records for ESH22-CME | 2026-02-04 11:03:04.811
HD Request # 324 | Completion time: 1s. | 2026-02-04 11:03:04.811
HD Request # 324 | Daily data download complete for ESH22-CME. Unique request ID: 325 | 2026-02-04 11:03:04.811
Removing historical data download ID 325. | 2026-02-04 11:03:04.811
Triggering next historical data download in queue. | 2026-02-04 11:03:04.811
HD Request # 325 | Downloading Historical Daily chart data for ESM22-CME. Starting date: 1976-02-05. Service: DTCSubInstance | 2026-02-04 11:03:04.811
HD Request # 325 | Using server: 127.0.0.1 port 11098 | 2026-02-04 11:03:04.811
Socket (4) | Creating socket. | 2026-02-04 11:03:04.812
Socket (4) | New receive buffer size: 5242880 | 2026-02-04 11:03:04.812
Socket (4) | Connecting to IP: 127.0.0.1. | 2026-02-04 11:03:04.812
Socket (2) | Socket gracefully closed by remote side. | 2026-02-04 11:03:04.815
Socket (2) | Closed. | 2026-02-04 11:03:04.815
HD Request # 325 | Setting DTC encoding to Binary VLS | 2026-02-04 11:03:04.826
HD Request # 325 | Sending historical data logon request message. | 2026-02-04 11:03:04.826
HD Request # 325 | Requesting historical Daily data starting at 1976-02-05. | 2026-02-04 11:03:04.826
HD Request # 325 | Data is being downloaded from a remote source. Download will start when this is done. | 2026-02-04 11:03:04.827
HD Request # 325 | Decompressing data. | 2026-02-04 11:03:05.841
HD Request # 325 | Receiving historical Daily data for ESM22-CME starting at 2021-03-08. | 2026-02-04 11:03:05.842
HD Request # 325 | Writing historical Daily data to the file ESM22-CME.dly. | 2026-02-04 11:03:05.843
Socket (4) | CloseSocket call. | 2026-02-04 11:03:05.844
Socket (4) | Shutdown started. Waiting for graceful close. | 2026-02-04 11:03:05.844
Historical data download thread signaled to stop. | 2026-02-04 11:03:05.846
HD Request # 325 | Received 324 Daily data records from 2021-03-08 00:00:00 to 2022-06-16 00:00:00 (466.0 days) and wrote 324 records for ESM22-CME | 2026-02-04 11:03:05.846
HD Request # 325 | Completion time: 1s. | 2026-02-04 11:03:05.846
HD Request # 325 | Daily data download complete for ESM22-CME. Unique request ID: 326 | 2026-02-04 11:03:05.846
Removing historical data download ID 326. | 2026-02-04 11:03:05.846
Triggering next historical data download in queue. | 2026-02-04 11:03:05.846
HD Request # 326 | Downloading Historical Daily chart data for ESU22-CME. Starting date: 1976-02-05. Service: DTCSubInstance | 2026-02-04 11:03:05.846
Socket (4) | Socket gracefully closed by remote side. | 2026-02-04 11:03:05.847
HD Request # 326 | Using server: 127.0.0.1 port 11098 | 2026-02-04 11:03:05.847
Socket (4) | Closed. | 2026-02-04 11:03:05.847
Socket (2) | Creating socket. | 2026-02-04 11:03:05.847
Socket (2) | New receive buffer size: 5242880 | 2026-02-04 11:03:05.847
Socket (2) | Connecting to IP: 127.0.0.1. | 2026-02-04 11:03:05.847
HD Request # 326 | Setting DTC encoding to Binary VLS | 2026-02-04 11:03:05.863
HD Request # 326 | Sending historical data logon request message. | 2026-02-04 11:03:05.863
HD Request # 326 | Requesting historical Daily data starting at 1976-02-05. | 2026-02-04 11:03:05.864
HD Request # 326 | Data is being downloaded from a remote source. Download will start when this is done. | 2026-02-04 11:03:05.865
HD Request # 326 | Decompressing data. | 2026-02-04 11:03:06.890
HD Request # 326 | Receiving historical Daily data for ESU22-CME starting at 2021-06-04. | 2026-02-04 11:03:06.891
HD Request # 326 | Writing historical Daily data to the file ESU22-CME.dly. | 2026-02-04 11:03:06.892
Socket (2) | CloseSocket call. | 2026-02-04 11:03:06.893
Socket (2) | Shutdown started. Waiting for graceful close. | 2026-02-04 11:03:06.893
Historical data download thread signaled to stop. | 2026-02-04 11:03:06.893
HD Request # 326 | Received 324 Daily data records from 2021-06-04 00:00:00 to 2022-09-15 00:00:00 (469.0 days) and wrote 324 records for ESU22-CME | 2026-02-04 11:03:06.893
HD Request # 326 | Completion time: 1s. | 2026-02-04 11:03:06.893
HD Request # 326 | Daily data download complete for ESU22-CME. Unique request ID: 327 | 2026-02-04 11:03:06.893
Removing historical data download ID 327. | 2026-02-04 11:03:06.893
Triggering next historical data download in queue. | 2026-02-04 11:03:06.893
HD Request # 327 | Downloading Historical Daily chart data for ESZ22-CME. Starting date: 1976-02-05. Service: DTCSubInstance | 2026-02-04 11:03:06.894
HD Request # 327 | Using server: 127.0.0.1 port 11098 | 2026-02-04 11:03:06.894
Socket (4) | Creating socket. | 2026-02-04 11:03:06.894
Socket (4) | New receive buffer size: 5242880 | 2026-02-04 11:03:06.894
Socket (4) | Connecting to IP: 127.0.0.1. | 2026-02-04 11:03:06.894
Socket (2) | Socket gracefully closed by remote side. | 2026-02-04 11:03:06.894
Socket (2) | Closed. | 2026-02-04 11:03:06.894
HD Request # 327 | Setting DTC encoding to Binary VLS | 2026-02-04 11:03:06.909
HD Request # 327 | Sending historical data logon request message. | 2026-02-04 11:03:06.909
HD Request # 327 | Requesting historical Daily data starting at 1976-02-05. | 2026-02-04 11:03:06.909
HD Request # 327 | Data is being downloaded from a remote source. Download will start when this is done. | 2026-02-04 11:03:06.910
HD Request # 327 | Decompressing data. | 2026-02-04 11:03:07.915
HD Request # 327 | Receiving historical Daily data for ESZ22-CME starting at 2021-06-04. | 2026-02-04 11:03:07.916
HD Request # 327 | Writing historical Daily data to the file ESZ22-CME.dly. | 2026-02-04 11:03:07.917
Socket (4) | CloseSocket call. | 2026-02-04 11:03:07.918
Socket (4) | Shutdown started. Waiting for graceful close. | 2026-02-04 11:03:07.918
Historical data download thread signaled to stop. | 2026-02-04 11:03:07.918
HD Request # 327 | Received 389 Daily data records from 2021-06-04 00:00:00 to 2022-12-16 00:00:00 (561.0 days) and wrote 389 records for ESZ22-CME | 2026-02-04 11:03:07.918
HD Request # 327 | Completion time: 1s. | 2026-02-04 11:03:07.918
HD Request # 327 | Daily data download complete for ESZ22-CME. Unique request ID: 328 | 2026-02-04 11:03:07.918
Removing historical data download ID 328. | 2026-02-04 11:03:07.918
Triggering next historical data download in queue. | 2026-02-04 11:03:07.918
HD Request # 328 | Downloading Historical Daily chart data for ESH23-CME. Starting date: 1976-02-05. Service: DTCSubInstance | 2026-02-04 11:03:07.918
HD Request # 328 | Using server: 127.0.0.1 port 11098 | 2026-02-04 11:03:07.918
Socket (4) | Socket gracefully closed by remote side. | 2026-02-04 11:03:07.918
Socket (4) | Closed. | 2026-02-04 11:03:07.919
Socket (2) | Creating socket. | 2026-02-04 11:03:07.919
Socket (2) | New receive buffer size: 5242880 | 2026-02-04 11:03:07.919
Socket (2) | Connecting to IP: 127.0.0.1. | 2026-02-04 11:03:07.919
HD Request # 328 | Setting DTC encoding to Binary VLS | 2026-02-04 11:03:07.934
HD Request # 328 | Sending historical data logon request message. | 2026-02-04 11:03:07.934
HD Request # 328 | Requesting historical Daily data starting at 1976-02-05. | 2026-02-04 11:03:07.935
HD Request # 328 | Data is being downloaded from a remote source. Download will start when this is done. | 2026-02-04 11:03:07.935
HD Request # 328 | Decompressing data. | 2026-02-04 11:03:08.941
HD Request # 328 | Receiving historical Daily data for ESH23-CME starting at 2021-06-04. | 2026-02-04 11:03:08.944
HD Request # 328 | Writing historical Daily data to the file ESH23-CME.dly. | 2026-02-04 11:03:08.944
Socket (2) | CloseSocket call. | 2026-02-04 11:03:08.946
Socket (2) | Shutdown started. Waiting for graceful close. | 2026-02-04 11:03:08.946
Historical data download thread signaled to stop. | 2026-02-04 11:03:08.946
HD Request # 328 | Received 449 Daily data records from 2021-06-04 00:00:00 to 2023-03-16 00:00:00 (651.0 days) and wrote 449 records for ESH23-CME | 2026-02-04 11:03:08.946
HD Request # 328 | Completion time: 1s. | 2026-02-04 11:03:08.946
HD Request # 328 | Daily data download complete for ESH23-CME. Unique request ID: 329 | 2026-02-04 11:03:08.946
Removing historical data download ID 329. | 2026-02-04 11:03:08.946
Triggering next historical data download in queue. | 2026-02-04 11:03:08.946
HD Request # 329 | Downloading Historical Daily chart data for ESM23-CME. Starting date: 1976-02-05. Service: DTCSubInstance | 2026-02-04 11:03:08.946
HD Request # 329 | Using server: 127.0.0.1 port 11098 | 2026-02-04 11:03:08.946
Socket (4) | Creating socket. | 2026-02-04 11:03:08.946
Socket (4) | New receive buffer size: 5242880 | 2026-02-04 11:03:08.947
Socket (4) | Connecting to IP: 127.0.0.1. | 2026-02-04 11:03:08.947
Socket (2) | Socket gracefully closed by remote side. | 2026-02-04 11:03:08.947
Socket (2) | Closed. | 2026-02-04 11:03:08.947
HD Request # 329 | Setting DTC encoding to Binary VLS | 2026-02-04 11:03:09.101
HD Request # 329 | Sending historical data logon request message. | 2026-02-04 11:03:09.101
HD Request # 329 | Requesting historical Daily data starting at 1976-02-05. | 2026-02-04 11:03:09.102
HD Request # 329 | Data is being downloaded from a remote source. Download will start when this is done. | 2026-02-04 11:03:09.102
HD Request # 329 | Decompressing data. | 2026-02-04 11:03:10.090
HD Request # 329 | Receiving historical Daily data for ESM23-CME starting at 2021-06-04. | 2026-02-04 11:03:10.091
HD Request # 329 | Writing historical Daily data to the file ESM23-CME.dly. | 2026-02-04 11:03:10.092
Socket (4) | CloseSocket call. | 2026-02-04 11:03:10.093
Socket (4) | Shutdown started. Waiting for graceful close. | 2026-02-04 11:03:10.093
Historical data download thread signaled to stop. | 2026-02-04 11:03:10.094
HD Request # 329 | Received 513 Daily data records from 2021-06-04 00:00:00 to 2023-06-15 00:00:00 (2.0 years) and wrote 513 records for ESM23-CME | 2026-02-04 11:03:10.094
HD Request # 329 | Completion time: 2s. | 2026-02-04 11:03:10.094
HD Request # 329 | Daily data download complete for ESM23-CME. Unique request ID: 330 | 2026-02-04 11:03:10.094
Removing historical data download ID 330. | 2026-02-04 11:03:10.094
Triggering next historical data download in queue. | 2026-02-04 11:03:10.094
HD Request # 330 | Downloading Historical Daily chart data for ESU23-CME. Starting date: 1976-02-05. Service: DTCSubInstance | 2026-02-04 11:03:10.095
HD Request # 330 | Using server: 127.0.0.1 port 11098 | 2026-02-04 11:03:10.095
Socket (2) | Creating socket. | 2026-02-04 11:03:10.095
Socket (2) | New receive buffer size: 5242880 | 2026-02-04 11:03:10.095
Socket (2) | Connecting to IP: 127.0.0.1. | 2026-02-04 11:03:10.095
Socket (4) | Socket gracefully closed by remote side. | 2026-02-04 11:03:10.095
Socket (4) | Closed. | 2026-02-04 11:03:10.095
HD Request # 330 | Setting DTC encoding to Binary VLS | 2026-02-04 11:03:10.377
HD Request # 330 | Sending historical data logon request message. | 2026-02-04 11:03:10.377
HD Request # 330 | Requesting historical Daily data starting at 1976-02-05. | 2026-02-04 11:03:10.379
HD Request # 330 | Data is being downloaded from a remote source. Download will start when this is done. | 2026-02-04 11:03:10.380
HD Request # 330 | Decompressing data. | 2026-02-04 11:03:11.370
HD Request # 330 | Receiving historical Daily data for ESU23-CME starting at 2021-06-17. | 2026-02-04 11:03:11.372
HD Request # 330 | Writing historical Daily data to the file ESU23-CME.dly. | 2026-02-04 11:03:11.373
Socket (2) | CloseSocket call. | 2026-02-04 11:03:11.376
Socket (2) | Shutdown started. Waiting for graceful close. | 2026-02-04 11:03:11.376
Historical data download thread signaled to stop. | 2026-02-04 11:03:11.376
HD Request # 330 | Received 514 Daily data records from 2021-06-17 00:00:00 to 2023-06-30 00:00:00 (2.0 years) and wrote 514 records for ESU23-CME | 2026-02-04 11:03:11.376
HD Request # 330 | Completion time: 1s. | 2026-02-04 11:03:11.376
HD Request # 330 | Daily data download complete for ESU23-CME. Unique request ID: 331 | 2026-02-04 11:03:11.376
Removing historical data download ID 331. | 2026-02-04 11:03:11.376
Triggering next historical data download in queue. | 2026-02-04 11:03:11.376
HD Request # 331 | Downloading Historical Daily chart data for ESZ23-CME. Starting date: 1976-02-05. Service: DTCSubInstance | 2026-02-04 11:03:11.377
HD Request # 331 | Using server: 127.0.0.1 port 11098 | 2026-02-04 11:03:11.377
Socket (4) | Creating socket. | 2026-02-04 11:03:11.377
Socket (4) | New receive buffer size: 5242880 | 2026-02-04 11:03:11.377
Socket (4) | Connecting to IP: 127.0.0.1. | 2026-02-04 11:03:11.377
Socket (2) | Socket gracefully closed by remote side. | 2026-02-04 11:03:11.377
Socket (2) | Closed. | 2026-02-04 11:03:11.377
HD Request # 331 | Setting DTC encoding to Binary VLS | 2026-02-04 11:03:11.423
HD Request # 331 | Sending historical data logon request message. | 2026-02-04 11:03:11.423
HD Request # 331 | Requesting historical Daily data starting at 1976-02-05. | 2026-02-04 11:03:11.424
HD Request # 331 | Data is being downloaded from a remote source. Download will start when this is done. | 2026-02-04 11:03:11.424
Socket (4) | CloseSocket call. | 2026-02-04 11:03:12.431
HD Request # 331 | Error downloading historical Daily data for ESZ23-CME. Historical data file not available for symbol. | 2026-02-04 11:03:12.431
Historical data download thread signaled to stop. | 2026-02-04 11:03:12.431
Socket (4) | Shutdown started. Waiting for graceful close. | 2026-02-04 11:03:12.431
HD Request # 331 | Received 0 Daily data records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESZ23-CME | 2026-02-04 11:03:12.431
HD Request # 331 | Completion time: 1s. | 2026-02-04 11:03:12.431
HD Request # 331 | Daily data download complete for ESZ23-CME. Unique request ID: 332 | 2026-02-04 11:03:12.431
Removing historical data download ID 332. | 2026-02-04 11:03:12.431
Triggering next historical data download in queue. | 2026-02-04 11:03:12.431
HD Request # 332 | Downloading Historical Daily chart data for ESH24-CME. Starting date: 1976-02-05. Service: DTCSubInstance | 2026-02-04 11:03:12.431
HD Request # 332 | Using server: 127.0.0.1 port 11098 | 2026-02-04 11:03:12.431
Socket (2) | Creating socket. | 2026-02-04 11:03:12.431
Socket (2) | New receive buffer size: 5242880 | 2026-02-04 11:03:12.431
Socket (2) | Connecting to IP: 127.0.0.1. | 2026-02-04 11:03:12.431
Socket (4) | Socket gracefully closed by remote side. | 2026-02-04 11:03:12.433
Socket (4) | Closed. | 2026-02-04 11:03:12.433
HD Request # 332 | Setting DTC encoding to Binary VLS | 2026-02-04 11:03:12.555
HD Request # 332 | Sending historical data logon request message. | 2026-02-04 11:03:12.555
HD Request # 332 | Requesting historical Daily data starting at 1976-02-05. | 2026-02-04 11:03:12.556
HD Request # 332 | Data is being downloaded from a remote source. Download will start when this is done. | 2026-02-04 11:03:12.557
Socket (2) | CloseSocket call. | 2026-02-04 11:03:13.568
HD Request # 332 | Error downloading historical Daily data for ESH24-CME. Historical data file not available for symbol. | 2026-02-04 11:03:13.568
Socket (2) | Shutdown started. Waiting for graceful close. | 2026-02-04 11:03:13.568
Historical data download thread signaled to stop. | 2026-02-04 11:03:13.568
HD Request # 332 | Received 0 Daily data records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESH24-CME | 2026-02-04 11:03:13.568
HD Request # 332 | Completion time: 1s. | 2026-02-04 11:03:13.568
HD Request # 332 | Daily data download complete for ESH24-CME. Unique request ID: 333 | 2026-02-04 11:03:13.568
Removing historical data download ID 333. | 2026-02-04 11:03:13.568
Triggering next historical data download in queue. | 2026-02-04 11:03:13.568
HD Request # 333 | Downloading Historical Daily chart data for ESM24-CME. Starting date: 1976-02-05. Service: DTCSubInstance | 2026-02-04 11:03:13.568
HD Request # 333 | Using server: 127.0.0.1 port 11098 | 2026-02-04 11:03:13.568
Socket (4) | Creating socket. | 2026-02-04 11:03:13.568
Socket (4) | New receive buffer size: 5242880 | 2026-02-04 11:03:13.568
Socket (4) | Connecting to IP: 127.0.0.1. | 2026-02-04 11:03:13.568
Socket (2) | Socket gracefully closed by remote side. | 2026-02-04 11:03:13.568
Socket (2) | Closed. | 2026-02-04 11:03:13.568
HD Request # 333 | Setting DTC encoding to Binary VLS | 2026-02-04 11:03:13.765
HD Request # 333 | Sending historical data logon request message. | 2026-02-04 11:03:13.765
HD Request # 333 | Requesting historical Daily data starting at 1976-02-05. | 2026-02-04 11:03:13.766
HD Request # 333 | Data is being downloaded from a remote source. Download will start when this is done. | 2026-02-04 11:03:13.766
Socket (4) | CloseSocket call. | 2026-02-04 11:03:15.766
HD Request # 333 | Error downloading historical Daily data for ESM24-CME. Historical data file not available for symbol. | 2026-02-04 11:03:15.767
Historical data download thread signaled to stop. | 2026-02-04 11:03:15.767
HD Request # 333 | Received 0 Daily data records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESM24-CME | 2026-02-04 11:03:15.767
Socket (4) | Shutdown started. Waiting for graceful close. | 2026-02-04 11:03:15.767
HD Request # 333 | Completion time: 2s. | 2026-02-04 11:03:15.767
HD Request # 333 | Daily data download complete for ESM24-CME. Unique request ID: 334 | 2026-02-04 11:03:15.767
Removing historical data download ID 334. | 2026-02-04 11:03:15.767
Triggering next historical data download in queue. | 2026-02-04 11:03:15.767
HD Request # 334 | Downloading Historical Daily chart data for ESU24-CME. Starting date: 1976-02-05. Service: DTCSubInstance | 2026-02-04 11:03:15.767
HD Request # 334 | Using server: 127.0.0.1 port 11098 | 2026-02-04 11:03:15.767
Socket (2) | Creating socket. | 2026-02-04 11:03:15.767
Socket (2) | New receive buffer size: 5242880 | 2026-02-04 11:03:15.767
Socket (2) | Connecting to IP: 127.0.0.1. | 2026-02-04 11:03:15.767
Socket (4) | Socket gracefully closed by remote side. | 2026-02-04 11:03:15.767
Socket (4) | Closed. | 2026-02-04 11:03:15.767
HD Request # 334 | Setting DTC encoding to Binary VLS | 2026-02-04 11:03:15.861
HD Request # 334 | Sending historical data logon request message. | 2026-02-04 11:03:15.861
HD Request # 334 | Requesting historical Daily data starting at 1976-02-05. | 2026-02-04 11:03:15.861
HD Request # 334 | Data is being downloaded from a remote source. Download will start when this is done. | 2026-02-04 11:03:15.862
Socket (2) | CloseSocket call. | 2026-02-04 11:03:16.861
Socket (2) | Shutdown started. Waiting for graceful close. | 2026-02-04 11:03:16.861
HD Request # 334 | Error downloading historical Daily data for ESU24-CME. Historical data file not available for symbol. | 2026-02-04 11:03:16.861
Historical data download thread signaled to stop. | 2026-02-04 11:03:16.861
HD Request # 334 | Received 0 Daily data records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESU24-CME | 2026-02-04 11:03:16.861
HD Request # 334 | Completion time: 1s. | 2026-02-04 11:03:16.861
HD Request # 334 | Daily data download complete for ESU24-CME. Unique request ID: 335 | 2026-02-04 11:03:16.861
Removing historical data download ID 335. | 2026-02-04 11:03:16.861
Triggering next historical data download in queue. | 2026-02-04 11:03:16.862
HD Request # 335 | Downloading Historical Daily chart data for ESZ24-CME. Starting date: 1976-02-05. Service: DTCSubInstance | 2026-02-04 11:03:16.862
HD Request # 335 | Using server: 127.0.0.1 port 11098 | 2026-02-04 11:03:16.862
Socket (4) | Creating socket. | 2026-02-04 11:03:16.862
Socket (4) | New receive buffer size: 5242880 | 2026-02-04 11:03:16.862
Socket (4) | Connecting to IP: 127.0.0.1. | 2026-02-04 11:03:16.862
Socket (2) | Socket gracefully closed by remote side. | 2026-02-04 11:03:16.862
Socket (2) | Closed. | 2026-02-04 11:03:16.862
HD Request # 335 | Setting DTC encoding to Binary VLS | 2026-02-04 11:03:16.875
HD Request # 335 | Sending historical data logon request message. | 2026-02-04 11:03:16.875
HD Request # 335 | Requesting historical Daily data starting at 1976-02-05. | 2026-02-04 11:03:16.879
HD Request # 335 | Data is being downloaded from a remote source. Download will start when this is done. | 2026-02-04 11:03:16.880
Socket (4) | CloseSocket call. | 2026-02-04 11:03:17.869
HD Request # 335 | Error downloading historical Daily data for ESZ24-CME. Historical data file not available for symbol. | 2026-02-04 11:03:17.869
Socket (4) | Shutdown started. Waiting for graceful close. | 2026-02-04 11:03:17.869
Historical data download thread signaled to stop. | 2026-02-04 11:03:17.869
HD Request # 335 | Received 0 Daily data records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESZ24-CME | 2026-02-04 11:03:17.869
HD Request # 335 | Completion time: 1s. | 2026-02-04 11:03:17.869
HD Request # 335 | Daily data download complete for ESZ24-CME. Unique request ID: 336 | 2026-02-04 11:03:17.869
Removing historical data download ID 336. | 2026-02-04 11:03:17.869
Triggering next historical data download in queue. | 2026-02-04 11:03:17.869
HD Request # 336 | Downloading Historical Daily chart data for ESH25-CME. Starting date: 1976-02-05. Service: DTCSubInstance | 2026-02-04 11:03:17.869
HD Request # 336 | Using server: 127.0.0.1 port 11098 | 2026-02-04 11:03:17.869
Socket (2) | Creating socket. | 2026-02-04 11:03:17.869
Socket (2) | New receive buffer size: 5242880 | 2026-02-04 11:03:17.869
Socket (2) | Connecting to IP: 127.0.0.1. | 2026-02-04 11:03:17.869
Socket (4) | Socket gracefully closed by remote side. | 2026-02-04 11:03:17.873
Socket (4) | Closed. | 2026-02-04 11:03:17.873
HD Request # 336 | Setting DTC encoding to Binary VLS | 2026-02-04 11:03:17.886
HD Request # 336 | Sending historical data logon request message. | 2026-02-04 11:03:17.886
HD Request # 336 | Requesting historical Daily data starting at 1976-02-05. | 2026-02-04 11:03:17.886
HD Request # 336 | Data is being downloaded from a remote source. Download will start when this is done. | 2026-02-04 11:03:17.887
Socket (2) | CloseSocket call. | 2026-02-04 11:03:18.888
HD Request # 336 | Error downloading historical Daily data for ESH25-CME. Historical data file not available for symbol. | 2026-02-04 11:03:18.888
Socket (2) | Shutdown started. Waiting for graceful close. | 2026-02-04 11:03:18.888
Historical data download thread signaled to stop. | 2026-02-04 11:03:18.888
HD Request # 336 | Received 0 Daily data records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESH25-CME | 2026-02-04 11:03:18.888
HD Request # 336 | Completion time: 1s. | 2026-02-04 11:03:18.888
HD Request # 336 | Daily data download complete for ESH25-CME. Unique request ID: 337 | 2026-02-04 11:03:18.888
Removing historical data download ID 337. | 2026-02-04 11:03:18.888
Triggering next historical data download in queue. | 2026-02-04 11:03:18.888
HD Request # 337 | Downloading Historical Daily chart data for ESM25-CME. Starting date: 1976-02-05. Service: DTCSubInstance | 2026-02-04 11:03:18.888
HD Request # 337 | Using server: 127.0.0.1 port 11098 | 2026-02-04 11:03:18.888
Socket (4) | Creating socket. | 2026-02-04 11:03:18.888
Socket (4) | New receive buffer size: 5242880 | 2026-02-04 11:03:18.888
Socket (4) | Connecting to IP: 127.0.0.1. | 2026-02-04 11:03:18.888
Socket (2) | Socket gracefully closed by remote side. | 2026-02-04 11:03:18.892
Socket (2) | Closed. | 2026-02-04 11:03:18.892
HD Request # 337 | Setting DTC encoding to Binary VLS | 2026-02-04 11:03:18.904
HD Request # 337 | Sending historical data logon request message. | 2026-02-04 11:03:18.904
HD Request # 337 | Requesting historical Daily data starting at 1976-02-05. | 2026-02-04 11:03:18.904
HD Request # 337 | Data is being downloaded from a remote source. Download will start when this is done. | 2026-02-04 11:03:18.904
Socket (4) | CloseSocket call. | 2026-02-04 11:03:19.912
Socket (4) | Shutdown started. Waiting for graceful close. | 2026-02-04 11:03:19.912
HD Request # 337 | Error downloading historical Daily data for ESM25-CME. Historical data file not available for symbol. | 2026-02-04 11:03:19.912
Historical data download thread signaled to stop. | 2026-02-04 11:03:19.912
HD Request # 337 | Received 0 Daily data records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESM25-CME | 2026-02-04 11:03:19.912
HD Request # 337 | Completion time: 1s. | 2026-02-04 11:03:19.912
HD Request # 337 | Daily data download complete for ESM25-CME. Unique request ID: 338 | 2026-02-04 11:03:19.912
Removing historical data download ID 338. | 2026-02-04 11:03:19.912
Triggering next historical data download in queue. | 2026-02-04 11:03:19.912
HD Request # 338 | Downloading Historical Daily chart data for ESU25-CME. Starting date: 1976-02-05. Service: DTCSubInstance | 2026-02-04 11:03:19.913
HD Request # 338 | Using server: 127.0.0.1 port 11098 | 2026-02-04 11:03:19.913
Socket (2) | Creating socket. | 2026-02-04 11:03:19.913
Socket (2) | New receive buffer size: 5242880 | 2026-02-04 11:03:19.913
Socket (2) | Connecting to IP: 127.0.0.1. | 2026-02-04 11:03:19.913
Socket (4) | Socket gracefully closed by remote side. | 2026-02-04 11:03:19.913
Socket (4) | Closed. | 2026-02-04 11:03:19.913
HD Request # 338 | Setting DTC encoding to Binary VLS | 2026-02-04 11:03:19.929
HD Request # 338 | Sending historical data logon request message. | 2026-02-04 11:03:19.929
HD Request # 338 | Requesting historical Daily data starting at 1976-02-05. | 2026-02-04 11:03:19.930
HD Request # 338 | Data is being downloaded from a remote source. Download will start when this is done. | 2026-02-04 11:03:19.930
HD Request # 338 | Decompressing data. | 2026-02-04 11:03:20.962
Socket (2) | CloseSocket call. | 2026-02-04 11:03:20.962
Socket (2) | Shutdown started. Waiting for graceful close. | 2026-02-04 11:03:20.962
Historical data download thread signaled to stop. | 2026-02-04 11:03:20.962
HD Request # 338 | Received 0 Daily data records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESU25-CME | 2026-02-04 11:03:20.962
HD Request # 338 | Completion time: 1s. | 2026-02-04 11:03:20.962
HD Request # 338 | Daily data download complete for ESU25-CME. Unique request ID: 339 | 2026-02-04 11:03:20.963
Removing historical data download ID 339. | 2026-02-04 11:03:20.963
Triggering next historical data download in queue. | 2026-02-04 11:03:20.963
HD Request # 339 | Downloading Historical Daily chart data for ESZ25-CME. Starting date: 1976-02-05. Service: DTCSubInstance | 2026-02-04 11:03:20.963
HD Request # 339 | Using server: 127.0.0.1 port 11098 | 2026-02-04 11:03:20.963
Socket (4) | Creating socket. | 2026-02-04 11:03:20.963
Socket (4) | New receive buffer size: 5242880 | 2026-02-04 11:03:20.963
Socket (4) | Connecting to IP: 127.0.0.1. | 2026-02-04 11:03:20.963
Socket (2) | Socket gracefully closed by remote side. | 2026-02-04 11:03:20.965
Socket (2) | Closed. | 2026-02-04 11:03:20.965
HD Request # 339 | Setting DTC encoding to Binary VLS | 2026-02-04 11:03:21.040
HD Request # 339 | Sending historical data logon request message. | 2026-02-04 11:03:21.040
HD Request # 339 | Requesting historical Daily data starting at 1976-02-05. | 2026-02-04 11:03:21.040
HD Request # 339 | Data is being downloaded from a remote source. Download will start when this is done. | 2026-02-04 11:03:21.041
HD Request # 339 | Decompressing data. | 2026-02-04 11:03:22.051
Socket (4) | CloseSocket call. | 2026-02-04 11:03:22.051
Socket (4) | Shutdown started. Waiting for graceful close. | 2026-02-04 11:03:22.051
Historical data download thread signaled to stop. | 2026-02-04 11:03:22.051
HD Request # 339 | Received 0 Daily data records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESZ25-CME | 2026-02-04 11:03:22.051
HD Request # 339 | Completion time: 2s. | 2026-02-04 11:03:22.051
HD Request # 339 | Daily data download complete for ESZ25-CME. Unique request ID: 340 | 2026-02-04 11:03:22.051
Removing historical data download ID 340. | 2026-02-04 11:03:22.051
Triggering next historical data download in queue. | 2026-02-04 11:03:22.051
HD Request # 340 | Downloading Historical Daily chart data for ESH26-CME. Starting date: 1976-02-05. Service: DTCSubInstance | 2026-02-04 11:03:22.051
HD Request # 340 | Using server: 127.0.0.1 port 11098 | 2026-02-04 11:03:22.051
Socket (2) | Creating socket. | 2026-02-04 11:03:22.051
Socket (2) | New receive buffer size: 5242880 | 2026-02-04 11:03:22.051
Socket (2) | Connecting to IP: 127.0.0.1. | 2026-02-04 11:03:22.052
Socket (4) | Socket gracefully closed by remote side. | 2026-02-04 11:03:22.053
Socket (4) | Closed. | 2026-02-04 11:03:22.053
HD Request # 340 | Setting DTC encoding to Binary VLS | 2026-02-04 11:03:22.108
HD Request # 340 | Sending historical data logon request message. | 2026-02-04 11:03:22.108
HD Request # 340 | Requesting historical Daily data starting at 1976-02-05. | 2026-02-04 11:03:22.108
HD Request # 340 | Data is being downloaded from a remote source. Download will start when this is done. | 2026-02-04 11:03:22.109
HD Request # 340 | Decompressing data. | 2026-02-04 11:03:23.129
Socket (2) | CloseSocket call. | 2026-02-04 11:03:23.129
Historical data download thread signaled to stop. | 2026-02-04 11:03:23.129
HD Request # 340 | Received 0 Daily data records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESH26-CME | 2026-02-04 11:03:23.129
Socket (2) | Shutdown started. Waiting for graceful close. | 2026-02-04 11:03:23.129
HD Request # 340 | Completion time: 1s. | 2026-02-04 11:03:23.129
HD Request # 340 | Daily data download complete for ESH26-CME. Unique request ID: 341 | 2026-02-04 11:03:23.129
Removing historical data download ID 341. | 2026-02-04 11:03:23.129
Triggering next historical data download in queue. | 2026-02-04 11:03:23.129
No download requests in the queue to start downloads for. | 2026-02-04 11:03:23.129
Socket (2) | Socket gracefully closed by remote side. | 2026-02-04 11:03:23.130
Socket (2) | Closed. | 2026-02-04 11:03:23.130
ESH26-CME [CB] Daily #1 | Download is complete for all contract months in chart. Proceeding with data load. | 2026-02-04 11:03:23.923
ESH26-CME [CB] Daily #1 | Reloading chart. | 2026-02-04 11:03:23.924
ESH26-CME [CB] Daily #1 | Error while getting daily settlement price with date 2023-09-16 from file. C:\SierraChart\SierraChartInstance_4\Data\ESU23-CME.dly. Error: No Data for read. End of file. | 2026-02-04 11:03:24.503
ESH26-CME [CB] Daily #1 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\SierraChartInstance_4\Data\ESZ23-CME.dly. Error: No Data for read. End of file. | 2026-02-04 11:03:24.503
ESH26-CME [CB] Daily #1 | Error while getting daily settlement price with date 2023-12-16 from file. C:\SierraChart\SierraChartInstance_4\Data\ESZ23-CME.dly. Error: No Data for read. End of file. | 2026-02-04 11:03:24.503
ESH26-CME [CB] Daily #1 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\SierraChartInstance_4\Data\ESH24-CME.dly. Error: No Data for read. End of file. | 2026-02-04 11:03:24.503
ESH26-CME [CB] Daily #1 | Error while getting daily settlement price with date 2024-03-16 from file. C:\SierraChart\SierraChartInstance_4\Data\ESH24-CME.dly. Error: No Data for read. End of file. | 2026-02-04 11:03:24.504
ESH26-CME [CB] Daily #1 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\SierraChartInstance_4\Data\ESM24-CME.dly. Error: No Data for read. End of file. | 2026-02-04 11:03:24.504
ESH26-CME [CB] Daily #1 | Error while getting daily settlement price with date 2024-06-21 from file. C:\SierraChart\SierraChartInstance_4\Data\ESM24-CME.dly. Error: No Data for read. End of file. | 2026-02-04 11:03:24.504
ESH26-CME [CB] Daily #1 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\SierraChartInstance_4\Data\ESU24-CME.dly. Error: No Data for read. End of file. | 2026-02-04 11:03:24.504
ESH26-CME [CB] Daily #1 | Error while getting daily settlement price with date 2024-09-20 from file. C:\SierraChart\SierraChartInstance_4\Data\ESU24-CME.dly. Error: No Data for read. End of file. | 2026-02-04 11:03:24.505
ESH26-CME [CB] Daily #1 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\SierraChartInstance_4\Data\ESZ24-CME.dly. Error: No Data for read. End of file. | 2026-02-04 11:03:24.505
ESH26-CME [CB] Daily #1 | Error while getting daily settlement price with date 2024-12-20 from file. C:\SierraChart\SierraChartInstance_4\Data\ESZ24-CME.dly. Error: No Data for read. End of file. | 2026-02-04 11:03:24.505
ESH26-CME [CB] Daily #1 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\SierraChartInstance_4\Data\ESH25-CME.dly. Error: No Data for read. End of file. | 2026-02-04 11:03:24.505
ESH26-CME [CB] Daily #1 | Error while getting daily settlement price with date 2025-03-21 from file. C:\SierraChart\SierraChartInstance_4\Data\ESH25-CME.dly. Error: No Data for read. End of file. | 2026-02-04 11:03:24.505
ESH26-CME [CB] Daily #1 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\SierraChartInstance_4\Data\ESM25-CME.dly. Error: No Data for read. End of file. | 2026-02-04 11:03:24.505
ESH26-CME [CB] Daily #1 | Error while getting daily settlement price with date 2025-06-20 from file. C:\SierraChart\SierraChartInstance_4\Data\ESM25-CME.dly. Error: No Data for read. End of file. | 2026-02-04 11:03:24.506
ESH26-CME [CB] Daily #1 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\SierraChartInstance_4\Data\ESU25-CME.dly. Error: No Data for read. End of file. | 2026-02-04 11:03:24.506
ESH26-CME [CB] Daily #1 | Error while getting daily settlement price with date 2025-09-19 from file. C:\SierraChart\SierraChartInstance_4\Data\ESU25-CME.dly. Error: No Data for read. End of file. | 2026-02-04 11:03:24.506
ESH26-CME [CB] Daily #1 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\SierraChartInstance_4\Data\ESZ25-CME.dly. Error: No Data for read. End of file. | 2026-02-04 11:03:24.506
ESH26-CME [CB] Daily #1 | Error while getting daily settlement price with date 2025-12-19 from file. C:\SierraChart\SierraChartInstance_4\Data\ESZ25-CME.dly. Error: No Data for read. End of file. | 2026-02-04 11:03:24.507
ESH26-CME [CB] Daily #1 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\SierraChartInstance_4\Data\ESH26-CME.dly. Error: No Data for read. End of file. | 2026-02-04 11:03:24.507
ESH26-CME [CB] Daily #1 | Reloading chart. | 2026-02-04 11:03:24.924
ESH26-CME [CB] Daily #1 | Error while getting daily settlement price with date 2023-09-16 from file. C:\SierraChart\SierraChartInstance_4\Data\ESU23-CME.dly. Error: No Data for read. End of file. | 2026-02-04 11:03:25.562
ESH26-CME [CB] Daily #1 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\SierraChartInstance_4\Data\ESZ23-CME.dly. Error: No Data for read. End of file. | 2026-02-04 11:03:25.562
ESH26-CME [CB] Daily #1 | Error while getting daily settlement price with date 2023-12-16 from file. C:\SierraChart\SierraChartInstance_4\Data\ESZ23-CME.dly. Error: No Data for read. End of file. | 2026-02-04 11:03:25.562
ESH26-CME [CB] Daily #1 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\SierraChartInstance_4\Data\ESH24-CME.dly. Error: No Data for read. End of file. | 2026-02-04 11:03:25.562
ESH26-CME [CB] Daily #1 | Error while getting daily settlement price with date 2024-03-16 from file. C:\SierraChart\SierraChartInstance_4\Data\ESH24-CME.dly. Error: No Data for read. End of file. | 2026-02-04 11:03:25.563
ESH26-CME [CB] Daily #1 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\SierraChartInstance_4\Data\ESM24-CME.dly. Error: No Data for read. End of file. | 2026-02-04 11:03:25.563
ESH26-CME [CB] Daily #1 | Error while getting daily settlement price with date 2024-06-21 from file. C:\SierraChart\SierraChartInstance_4\Data\ESM24-CME.dly. Error: No Data for read. End of file. | 2026-02-04 11:03:25.563
ESH26-CME [CB] Daily #1 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\SierraChartInstance_4\Data\ESU24-CME.dly. Error: No Data for read. End of file. | 2026-02-04 11:03:25.563
ESH26-CME [CB] Daily #1 | Error while getting daily settlement price with date 2024-09-20 from file. C:\SierraChart\SierraChartInstance_4\Data\ESU24-CME.dly. Error: No Data for read. End of file. | 2026-02-04 11:03:25.563
ESH26-CME [CB] Daily #1 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\SierraChartInstance_4\Data\ESZ24-CME.dly. Error: No Data for read. End of file. | 2026-02-04 11:03:25.563
ESH26-CME [CB] Daily #1 | Error while getting daily settlement price with date 2024-12-20 from file. C:\SierraChart\SierraChartInstance_4\Data\ESZ24-CME.dly. Error: No Data for read. End of file. | 2026-02-04 11:03:25.564
ESH26-CME [CB] Daily #1 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\SierraChartInstance_4\Data\ESH25-CME.dly. Error: No Data for read. End of file. | 2026-02-04 11:03:25.564
ESH26-CME [CB] Daily #1 | Error while getting daily settlement price with date 2025-03-21 from file. C:\SierraChart\SierraChartInstance_4\Data\ESH25-CME.dly. Error: No Data for read. End of file. | 2026-02-04 11:03:25.564
ESH26-CME [CB] Daily #1 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\SierraChartInstance_4\Data\ESM25-CME.dly. Error: No Data for read. End of file. | 2026-02-04 11:03:25.564
ESH26-CME [CB] Daily #1 | Error while getting daily settlement price with date 2025-06-20 from file. C:\SierraChart\SierraChartInstance_4\Data\ESM25-CME.dly. Error: No Data for read. End of file. | 2026-02-04 11:03:25.565
ESH26-CME [CB] Daily #1 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\SierraChartInstance_4\Data\ESU25-CME.dly. Error: No Data for read. End of file. | 2026-02-04 11:03:25.565
ESH26-CME [CB] Daily #1 | Error while getting daily settlement price with date 2025-09-19 from file. C:\SierraChart\SierraChartInstance_4\Data\ESU25-CME.dly. Error: No Data for read. End of file. | 2026-02-04 11:03:25.565
ESH26-CME [CB] Daily #1 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\SierraChartInstance_4\Data\ESZ25-CME.dly. Error: No Data for read. End of file. | 2026-02-04 11:03:25.565
ESH26-CME [CB] Daily #1 | Error while getting daily settlement price with date 2025-12-19 from file. C:\SierraChart\SierraChartInstance_4\Data\ESZ25-CME.dly. Error: No Data for read. End of file. | 2026-02-04 11:03:25.566
ESH26-CME [CB] Daily #1 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\SierraChartInstance_4\Data\ESH26-CME.dly. Error: No Data for read. End of file. | 2026-02-04 11:03:25.566
Added historical Daily data request for ESH26-CME to the queue. | 2026-02-04 11:03:26.932
Triggering next historical data download in queue. | 2026-02-04 11:03:26.932
HD Request # 341 | Downloading Historical Daily chart data for ESH26-CME. Starting date: 1976-02-05. Service: DTCSubInstance | 2026-02-04 11:03:26.936
HD Request # 341 | Using server: 127.0.0.1 port 11098 | 2026-02-04 11:03:26.936
Socket (2) | Creating socket. | 2026-02-04 11:03:26.937
Socket (2) | New receive buffer size: 5242880 | 2026-02-04 11:03:26.937
Socket (2) | Connecting to IP: 127.0.0.1. | 2026-02-04 11:03:26.937
HD Request # 341 | Setting DTC encoding to Binary VLS | 2026-02-04 11:03:26.952
HD Request # 341 | Sending historical data logon request message. | 2026-02-04 11:03:26.952
HD Request # 341 | Requesting historical Daily data starting at 1976-02-05. | 2026-02-04 11:03:26.952
HD Request # 341 | Decompressing data. | 2026-02-04 11:03:26.953
Socket (2) | CloseSocket call. | 2026-02-04 11:03:26.954
Socket (2) | Shutdown started. Waiting for graceful close. | 2026-02-04 11:03:26.954
Historical data download thread signaled to stop. | 2026-02-04 11:03:26.954
HD Request # 341 | Received 0 Daily data records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESH26-CME | 2026-02-04 11:03:26.954
HD Request # 341 | Completion time: 0s. | 2026-02-04 11:03:26.954
HD Request # 341 | Daily data download complete for ESH26-CME. Unique request ID: 342 | 2026-02-04 11:03:26.954
Removing historical data download ID 342. | 2026-02-04 11:03:26.954
Triggering next historical data download in queue. | 2026-02-04 11:03:26.954
No download requests in the queue to start downloads for. | 2026-02-04 11:03:26.954
Socket (2) | Socket gracefully closed by remote side. | 2026-02-04 11:03:26.956
Socket (2) | Closed. | 2026-02-04 11:03:26.956
ESH26-CME [CB] Daily #1 | Reloading chart. | 2026-02-04 11:03:27.933
ESH26-CME [CB] Daily #1 | Error while getting daily settlement price with date 2023-09-16 from file. C:\SierraChart\SierraChartInstance_4\Data\ESU23-CME.dly. Error: No Data for read. End of file. | 2026-02-04 11:03:28.567
ESH26-CME [CB] Daily #1 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\SierraChartInstance_4\Data\ESZ23-CME.dly. Error: No Data for read. End of file. | 2026-02-04 11:03:28.567
ESH26-CME [CB] Daily #1 | Error while getting daily settlement price with date 2023-12-16 from file. C:\SierraChart\SierraChartInstance_4\Data\ESZ23-CME.dly. Error: No Data for read. End of file. | 2026-02-04 11:03:28.567
ESH26-CME [CB] Daily #1 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\SierraChartInstance_4\Data\ESH24-CME.dly. Error: No Data for read. End of file. | 2026-02-04 11:03:28.567
ESH26-CME [CB] Daily #1 | Error while getting daily settlement price with date 2024-03-16 from file. C:\SierraChart\SierraChartInstance_4\Data\ESH24-CME.dly. Error: No Data for read. End of file. | 2026-02-04 11:03:28.568
ESH26-CME [CB] Daily #1 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\SierraChartInstance_4\Data\ESM24-CME.dly. Error: No Data for read. End of file. | 2026-02-04 11:03:28.568
ESH26-CME [CB] Daily #1 | Error while getting daily settlement price with date 2024-06-21 from file. C:\SierraChart\SierraChartInstance_4\Data\ESM24-CME.dly. Error: No Data for read. End of file. | 2026-02-04 11:03:28.568
ESH26-CME [CB] Daily #1 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\SierraChartInstance_4\Data\ESU24-CME.dly. Error: No Data for read. End of file. | 2026-02-04 11:03:28.568
ESH26-CME [CB] Daily #1 | Error while getting daily settlement price with date 2024-09-20 from file. C:\SierraChart\SierraChartInstance_4\Data\ESU24-CME.dly. Error: No Data for read. End of file. | 2026-02-04 11:03:28.568
ESH26-CME [CB] Daily #1 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\SierraChartInstance_4\Data\ESZ24-CME.dly. Error: No Data for read. End of file. | 2026-02-04 11:03:28.568
ESH26-CME [CB] Daily #1 | Error while getting daily settlement price with date 2024-12-20 from file. C:\SierraChart\SierraChartInstance_4\Data\ESZ24-CME.dly. Error: No Data for read. End of file. | 2026-02-04 11:03:28.569
ESH26-CME [CB] Daily #1 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\SierraChartInstance_4\Data\ESH25-CME.dly. Error: No Data for read. End of file. | 2026-02-04 11:03:28.569
ESH26-CME [CB] Daily #1 | Error while getting daily settlement price with date 2025-03-21 from file. C:\SierraChart\SierraChartInstance_4\Data\ESH25-CME.dly. Error: No Data for read. End of file. | 2026-02-04 11:03:28.569
ESH26-CME [CB] Daily #1 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\SierraChartInstance_4\Data\ESM25-CME.dly. Error: No Data for read. End of file. | 2026-02-04 11:03:28.569
ESH26-CME [CB] Daily #1 | Error while getting daily settlement price with date 2025-06-20 from file. C:\SierraChart\SierraChartInstance_4\Data\ESM25-CME.dly. Error: No Data for read. End of file. | 2026-02-04 11:03:28.570
ESH26-CME [CB] Daily #1 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\SierraChartInstance_4\Data\ESU25-CME.dly. Error: No Data for read. End of file. | 2026-02-04 11:03:28.570
ESH26-CME [CB] Daily #1 | Error while getting daily settlement price with date 2025-09-19 from file. C:\SierraChart\SierraChartInstance_4\Data\ESU25-CME.dly. Error: No Data for read. End of file. | 2026-02-04 11:03:28.570
ESH26-CME [CB] Daily #1 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\SierraChartInstance_4\Data\ESZ25-CME.dly. Error: No Data for read. End of file. | 2026-02-04 11:03:28.570
ESH26-CME [CB] Daily #1 | Error while getting daily settlement price with date 2025-12-19 from file. C:\SierraChart\SierraChartInstance_4\Data\ESZ25-CME.dly. Error: No Data for read. End of file. | 2026-02-04 11:03:28.570
ESH26-CME [CB] Daily #1 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\SierraChartInstance_4\Data\ESH26-CME.dly. Error: No Data for read. End of file. | 2026-02-04 11:03:28.570
Date Time Of Last Edit: 2026-02-04 21:03:55
[2026-02-04 20:40:35]
John - SC Support - Posts: 48555
We see the system is requesting, and getting, the data when you ask it to redownload. But there are a few symbols that had issues, so you get the following in the log:
Since this is a Sub-Instance, you need to ensure that the main instance has this data. If the data is missing in the main instance, then the sub-instance will not be able to get it. Please check that main instance, and if data is missing there, then do the "Edit >> Delete All Data and Download" in that main instance to redownload everything. If all the data is there after the download, then do this same thing in the sub-instance to get the data updated in it.
If the main instance has an issue after you download it, then get us the Message Log from that main instance by following these instructions:
[2026-02-04 21:04:40]
whats1thingnow - Posts: 418
resolved
