Date/Time: Wed, 25 Nov 2026 22:50:07 +0000
Cant fully minimize charts
View Count: 952
[2026-02-01 00:21:41]
Ticks - Posts: 212
I upgraded from version 2801 to version 2871.
Big mistake, now all the charts I had minimized, because I don't need to see them.
I just pull study data from them.
All are un-minimized, and I can't even minimize them anymore.
Screenshot attached.
imagecharts not minimized.png / V - Attached On 2026-02-01 00:20:45 UTC - Size: 29.51 KB - 279 views
[2026-02-01 00:40:40]
Sierra_Chart Engineering - Posts: 25484
You need to set the MDI Child Window Minimize Method:
General Settings Window: MDI Child Window Minimize Method (List) (Global Settings >> General Settings >> GUI >> Multiple Document Interface (MDI) and Custom Title Bar Settings)
To: Minimize to Bottom. For each chart, Restore it, then Minimize it again.
Date Time Of Last Edit: 2026-02-01 00:42:22
[2026-02-01 00:56:03]
Ticks - Posts: 212
Ok, I do not see an option to minimize to the taskbar.
I got a bunch of stacked windows at the bottom of the main window.
I didn't choose "Hide" because I may want to find them again for setting changes if needed.
imagecharts minimized stacked at bottom.png / V - Attached On 2026-02-01 00:55:54 UTC - Size: 12.84 KB - 192 views
[2026-02-01 01:54:19]
You cannot minimize to the taskbar for attached MDI child windows. You can also reduce the size of those minimized windows with these settings:
https://www.sierrachart.com/index.php?page=doc/GeneralSettings.html#MDIChildWindowMinimizeWidth%
When you choose Hide Window for the MDI Child Window Minimize Method, to restore the hidden window, select it from the CW menu, or from the MDI tabs when General Settings >> Windows >> Window Tabs >> Show Hidden Windows on MDI Tabs is enabled.
[2026-02-01 04:26:41]
Ticks - Posts: 212
It can be done in version 2801. When I minimize the chart, it goes to the bottom of the application window and is not visible. When I want to see the chart again.
I just click on the chart name at the bottom of the application, and the chart appears.
I will just go back to version 2801.
There is never a full list of upgrades or features added in upgrades anyway.
So I won't miss any features that nobody knows about.
Seems the statement is true. "If it isn't broken, don't upgrade."
Date Time Of Last Edit: 2026-02-01 04:27:33
[2026-02-01 04:37:31]
This is not the Taskbar you are referring to. It is the bottom of the main Sierra Chart window. And this is not true:
A minimized window, still is visible, at the bottom of the main window just like in newer versions. The minimized window is larger in newer versions ( although the size is fully customizable), and can be restored, through the MDI Child Window tabs as explained.
Date Time Of Last Edit: 2026-02-01 04:40:07
