Date/Time: Wed, 25 Nov 2026 22:50:05 +0000
Trades data not available
View Count: 507
[2026-01-30 14:48:30]
User124881 - Posts: 20
hi there am not getting any data i tried everything but nothing changed
image1.png / V - Attached On 2026-01-30 14:46:08 UTC - Size: 1.22 MB - 218 views
image1.png / V - Attached On 2026-01-30 14:46:42 UTC - Size: 204.78 KB - 145 views
[2026-01-30 16:37:27]
You are getting a "Permission Denied" error from Rithmic. Refer to the following for what we know about this error:
Rithmic Trading Platform Service: Permission Denied Resolution Procedure
[2026-02-03 14:23:53]
hi there am still have hard time to get data from rithmic to sierra i reach out to bulenox a prop firm they said everything is good on there end so i didn't want to go back and forth with them so i got the the the The Denali Data Feed everything work but i can't connect my prop-firm account i just wanted the data feed take a look a the pictures you will see what i mean.
2-i have on the subscription i circle which one should i pick because i just want the ES live data to trade my prop firm
image1.png / V - Attached On 2026-02-03 14:20:20 UTC - Size: 140.07 KB - 194 views
image2.png / V - Attached On 2026-02-03 14:21:27 UTC - Size: 1.18 MB - 244 views
image3.png / V - Attached On 2026-02-03 14:22:00 UTC - Size: 1.29 MB - 222 views
[2026-02-03 14:52:51]
The first thing to keep in mind is that in order to get the CME Group data at the Non-Professional rates, you need a live, funded, futures trading account. And you need to connect your Sierra Chart software to that account at least once a month. Refer to the following:
Denali Exchange Data Feed: Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges
If you do not want to setup a live, funded, futures trading account, then you would need to pay for the Professional exchange option.
[2026-02-03 15:46:52]
so if a i have a live account i can get the denali data feed login one a month and i can connect my prop firm accounts to the same data on sierra?
[2026-02-03 15:50:22]
Sierra_Chart Engineering - Posts: 25484
Yes. Refer to:
Denali Exchange Data Feed: Integration with Trading Services
