Date/Time: Wed, 25 Nov 2026 22:26:19 +0000
Sound Alert
View Count: 365
| [2026-01-22 17:19:11] |
| User841161 - Posts: 357 |
I am trying to create a Sound Alert at a particular time (11AM CST). Inside of a 5 minute char, i am using Color Bar Based O Alert Condition Study I am using this formula '= BARTIME=110000'. Why does this not trigger an alert.
| [2026-01-22 17:50:54] |
Refer to the following if you want to use a serial value for the time: Spreadsheet Functions: Serial DateTime Values The easier method is to use the TIME() function along with the BARTIME() function. So your alert would be written as the following: =BARTIME = TIME(11, 00, 00) But, if you want a sound alert and do not want the bar colored, then there are Time Alerts that you can setup. Refer to the following: Alerts Manager: Time Alerts For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
