Date/Time: Wed, 25 Nov 2026 22:26:18 +0000
Window control buttons
View Count: 403
| [2026-01-22 16:49:25] |
| User160664 - Posts: 3 |
Hello, I downloaded the latest version of Sierra Chart and the buttons that were supposed to appear in the upper right corner of the window to minimize or restore the subwindows disappeared and instead small windows appeared. |
Attachment Deleted. |
| [2026-01-22 17:35:46] |
The Minimize/Restore/Close buttons that would display in the upper right corner when a window is maximized have moved to the Menu line and display as "Min", "Res", and "Cls". in that line just after the Help menu. You can change the exact wording for these along with the separator. Refer to the following and the 3 settings below it: General Settings Window: MDI Container Window Child Window Menu Text Separator (Global Settings >> General Settings >> GUI >> Multiple Document Interface (MDI) and Custom Title Bar Settings) There are also a number of other changes with respective settings for them. Check the rest of the settings in that section for "Multiple Document Interface (MDI) and Custom Title Bar Settings". Also refer to the following for an understanding of what has changed: Notice: Solution to: Chart/Chartbook Tabs Visibility Issues, Portions of Chart Window Cut Off For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2026-01-22 17:36:39
