Date/Time: Wed, 25 Nov 2026 22:26:08 +0000
Large volume trade indicatore
View Count: 482
| [2026-01-20 19:56:30] |
| User352291 - Posts: 2 |
Hello, I’m writing because I’d like to understand why, for a few days now, I’ve been trying to use the Large Volume Trade Indicator, but despite setting all the configurations, it doesn’t appear on the chart. However, a friend of mine, with the exact same chart and the same indicator settings, has no issues and it shows up correctly.
| [2026-01-20 19:57:29] |
The most common reason for an issue with the Large Volume Trade Indicator is that you are not storing the data at every tick. Check the following setting and ensure it is set to "1 Tick". Follow the information in there to redownload the data as well, if you do change it: Data/Trade Service Settings: Intraday Data Storage Time Unit (Global Settings >> Data/Trade Service Settings >> Common Settings >> Common Settings) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
