Date/Time: Thu, 26 Nov 2026 03:31:29 +0000
Time and Sales Setting
View Count: 998
| [2026-01-17 20:14:26] |
| Trade with ICE - Posts: 50 |
I don't like this recent update. The Time and Sales settings look like a step backward, IMO. Time and Sales used to highlight above the bid and ask; now it just highlights the filtered one that has been entered in the Alerts tab. This settings window is not as user-friendly as before. |
| [2026-01-17 23:19:51] |
| Sierra_Chart Engineering - Posts: 25489 |
We are checking to make sure there are no settings which have been missed or are different. They should all be the same with no changes. There certainly is no functionality changes in the Time and Sales window. Time and Sales used to highlight above the bid and ask; now it just highlights the filtered one that has been entered in the Alerts tab.
It sounds like what you are referring to are the Time and Sales: color settings which are still supported in the Graphics Settings:Graphics Settings Regarding this: This settings window is not as user-friendly as before.
Refer to:Settings Windows Interface: New Chart Settings Window Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2026-01-17 23:21:10
| [2026-01-17 23:24:50] |
I changed the time and sales color below bid trades background to a bright color just to see if its gonna get triggered but it doesnt. ** The chart I'm using here is not using the global graphics setting, just need to mention it because you might say the chart might be using global setting but this photo is not ** Date Time Of Last Edit: 2026-01-17 23:27:49
| [2026-01-18 08:19:46] |
Why would you expect to see a trade highlighted, indicating a price below the bid price? There is no information that you are providing, to support this conclusion. This is not likely to be the case, ever, and technically cannot ever happen. Even though you might sometimes see it, it more has to do with the behavior of the data feed. Furthermore, there have been absolutely no changes at all, with this functionality. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2026-01-18 08:20:36
| [2026-01-18 15:17:45] |
You keep saying there were no changes. Look at my t/s a few weeks ago. How is this for support? It was being highlighted… with the current update, it's gone. So, if there were no changes at all, why is my t/s not the same after the update? As far as I can remember, Sierra Chart has this functionality highlighting below bid and above asked. Now it's gone. For someone who uses t/s every day, you will notice this. Date Time Of Last Edit: 2026-01-18 16:14:17
| [2026-01-18 18:47:37] |
| User719512 - Posts: 548 |
Hey @ice, Maybe it would be helpful to add more columns to show a specific time where you expect highlighting. I started a NQ replay from 1/16 at 8am pacific and captured this 4 seconds in (see attached) |
| Attachment Deleted. |
| [2026-01-18 18:59:55] |
Hey @ice,
Maybe it would be helpful to add more columns to show a specific time where you expect highlighting. I started a NQ replay from 1/16 at 8am pacific and captured this 4 seconds in (see attached) Did you update to the current version? The only thing highlighting on T/S now is if you set a filter. Without a filter, there is no highlighting. I don't know why Engineering is saying there were no changes; I'm pretty sure there were. My T/S is different now than before. Adding a column to T/S doesn't highlight the 'below bid' and 'above ask' anymore. |
| [2026-01-18 19:14:41] |
The changes to the Time and Sales Settings window, do not change, any of the highlighting or coloring. Those changes simply could not have any affect. The Time and Sales window was also converted, away from what we call MFC. We are looking at the changes now but do not see any reason for changes with coloring or highlighting. So we need to do some more in-depth testing and see why there would be some change with coloring. Also in our experience it is not normal in the CME markets to see trades below the Bid or above the Ask. Sometimes that happens but it is not common but maybe it is more common than we realize. But in actuality this really cannot occur. Also as has been pointed out because we could not see the Bid or Ask price with the last trade price, it was not possible for us to validate that there was anything wrong. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2026-01-18 19:15:31
| [2026-01-18 19:29:16] |
im just reporting what has changed because I use that functionality, and now it's gone.
| [2026-01-18 20:10:35] |
| User431178 - Posts: 910 |
Weird, I am on version 2865 and above ask / below bid highlight works as before, at least on chart replay. |
| [2026-01-18 21:17:04] |
VERSION 2865 - doesnt highlight VERSION 2858 - highlighs So definitely there were some changes here Date Time Of Last Edit: 2026-01-18 21:20:08
| [2026-01-18 21:20:46] |
i changed the color just to make sure
| [2026-01-20 07:02:44] |
We have confirmed there is no issue here. And nothing has changed. You need to add to the Time and Sales window the Ask price and the Bid price to see what they are at each trade. Otherwise, we cannot help.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2026-01-20 07:03:12
| [2026-03-14 20:43:27] |
Ok, I haven't done any replay until now. The above bid and below ask highlight work during a live market open scenario, but it still isn't working on replay. Any ideas why?
| [2026-03-14 23:18:25] |
The only reason we can think of would be not having tick by tick data. Set Sierra Chart to a Tick by Tick Data Configuration. Follow the instructions here to do this: Tick by Tick Data Configuration Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
