Date/Time: Wed, 25 Nov 2026 22:21:11 +0000
synthetic symbol
View Count: 420
| [2026-01-13 16:55:28] |
| User473031 - Posts: 73 |
I'm having difficulty making this synthetic symbol graph in region2. It seems to match up with I have seen in the support board. 0.17197*{MSFT-NQTV}+0.16172*{AAPL-NQTV}+0.15774*{NVDA-NQTV}+0.1041*{AMZN-NQTV}+0.0995*{AVGO-NQTV} +0.09096*{META-NQTV}+0.0553*{GOOGL-NQTV}+0.0533*{GOOG-NQTV}+0.0535*{COST-NQTV}+0.04956*{TSLA-NQTV} |
| [2026-01-13 18:19:53] |
What exactly is the problem you are having? Are you getting nothing at all? Are you only getting current data and no historical data? Something else?
| [2026-01-13 20:50:36] |
I'm not getting any data in region2. It is blank
| [2026-01-13 21:13:15] |
We are not having any issue with that particular formula. Please open the symbol you have setup for that formula as a new chart instead of as an additional symbol to an existing chart. If this does not work, then get us the custom symbol settings for the service you are connected to. You will find the file in the "SymbolSettings" folder under your main Sierra Chart installation folder. The specific file we need will start with the words "CustomSymbolSettings." and then following this will be the name of the service that you are connected to, the extension is .xml. For instance, if you are connected to "SC Data", then the file would have the following name: CustomSymbolSettings.scdataallservices.xml For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-01-14 13:59:51] |
I guess you have revealed my issue. I haven't created a custom symbol, and I don't know how that is done. Your last message I don't understand what you are directing me to do. Sorry to have wasted your time. I will research more.
| [2026-01-14 16:15:55] |
Refer to the following: Custom Calculated Symbols For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
