Date/Time: Wed, 25 Nov 2026 22:20:54 +0000
Chart Region Bar (Chart Title/Header etc)
View Count: 358
| [2026-01-07 23:50:22] |
| User34124 - Posts: 289 |
Hi, struggling to move this to the middle/right side of the screen, nearer to price-axis. On big screens, very neck cranky to keep looking to the top left corner. If no feature yet, could you simply add the tweak in a future update?
| [2026-01-08 16:02:59] |
There is no option to align the Chart Header or the Region Data Line to the right. It is always left aligned. For the Chart Header, you can arrange the order of the items such that things you want to see on the right are set in that position (or at least close). Refer to the following: Working With Charts: Region Data Line / Chart Header We have noted this as a Feature Request. We do want to point out that if there is something specific you are wanting to view from the Chart Header, it may be accessible through a study, and then can be displayed in a specific position where you want it using the "Text Display for Study". For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
