Date/Time: Wed, 25 Nov 2026 22:08:24 +0000
MNQ Chart Displays Candles and Studies MGC is blank
View Count: 449
[2026-01-02 17:24:16]
User543381 - Posts: 10
A chart that has the MNQ symbol works perfectly but when I change the same chart to MGC the chart is blank. Please assist.
attachmentImageLog.txt - Attached On 2026-01-02 17:21:15 UTC - Size: 184 B - 114 views
imageUploadImage.png / V - Attached On 2026-01-02 17:21:36 UTC - Size: 4.88 KB - 117 views
[2026-01-02 18:30:22]
MGC is traded on the COMEX exchange of the CME Group. At this time, you have the "CME Non-Professional Top-of-Book" exchange active, which is just for the CME Exchange of the CME Group.
If you want real-time data for COMEX from our Denali Exchange Data Feed, then you will need to activate an exchange option for (or includes) COMEX. Refer to the following regarding adding/changing exchange options:
Denali Exchange Data Feed: Changing Denali Exchange Data Feed Exchange Selections
[2026-01-02 19:02:25]
I have had the COMEX active for several months. Please see screen shot.
imageDenali CME CBOT NYMEX COMEX Active.png / V - Attached On 2026-01-02 19:01:44 UTC - Size: 75.66 KB - 128 views
[2026-01-02 19:36:43]
The last time you had an exchange option active that included COMEX was in August of 2025.
At this time, you only have the following exchange active:
- CME Non-Professional Top-of-Book
Therefore, you are not setup to get any data for COMEX.
You need to select the link for "Activate / Deactivate Denali Exchange Data Feed Exchanges [CME/CBOT/COMEX/NYMEX Exchange]" in the image you provided to see the individual exchanges you have active. The checkmarks just mean that you have at least one exchange active.
