Date/Time: Thu, 26 Nov 2026 04:45:43 +0000
How Do I Access This Chart Linking Dialog Box?
View Count: 586
| [2025-12-27 21:28:10] |
| User708541 - Posts: 215 |
In a recent YouTube video the presenter shows this Chart Linking Dialog box. I have Chart Linking in my chart header, I've tried clicking, double clicking in colored box in my chart header and nothing happens. There must be another way to access that dialogue box. From Sierra's documentation: “On the top Region Data Line of a chart it is possible to add a field that when clicked on with the left pointer button, a Chart Link window will display. To add this field, select Global Settings >> Customize Chart Header on the menu. In the list of the Available Header Fields, Add the Link Number field if it is not already added. Press OK. … Left click on the link number (L:#) on the Region Data Line at the top of a chart or click on NoLink if there is no link number set, to display the Chart Link window to set the Link Number and linking Type.” See enclosed image. Date Time Of Last Edit: 2025-12-27 21:33:31
| [2025-12-29 16:40:57] |
When you are using OpenGL for the graphics, then that option to get the Link settings from the Chart Header does not function. We have not found a workaround for this, which is why it still is this way. We have updated the documentation for this. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-12-30 17:58:18] |
Is there a way/anyway to bring this dialogue box up other than clicking on the header and with OpenGL? I think this linking dialog box would be very handy and easier to use than going into chart settings every time to adjust or set chart linking functions.
| [2025-12-30 19:01:42] |
There are Control Bar and Keyboard Shortcuts for the "Chart Settings" window. Whatever tab you were last on on that page will be what comes up, so if you are bringing up the "Linking" tab often, then most likely it will default to that tab. There are also Control Bar and Keyboard Shortcuts that can be setup to change the current chart's Link Number and Link Settings. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-12-30 21:11:24] |
I'm specifically referring to the dialogue box shown in the screenshot of the video. Any other way (besides deactivating OpenGL) to bring up or activate that particular dialogue box?
Date Time Of Last Edit: 2025-12-30 21:11:51
| [2025-12-30 21:28:12] |
There is not another way other than disabling OpenGL and then using that Link option in the Chart Header.
| [2025-12-31 17:12:23] |
| Sierra_Chart Engineering - Posts: 25491 |
We are looking into this issue. This should not happen.
| [2026-01-08 18:28:46] |
This will be resolved in the next release.
| [2026-05-16 15:34:58] |
What happened to the Chart Linking Box? The very helpful chart link box was up and running great as of version 2899 and in version 2904 the box is gone again. Will this be coming back?
| [2026-05-19 14:17:23] |
When you left click on the Link Number on the chart header, the way that this works in newer versions is that the Chart Settings window opens to the Linking tab. This will not change. We are not going to create a separate window for Chart Linking. The old dialog type windows are being phased out of Sierra Chart. For more information, refer to: Settings Windows Interface: New Chart Settings Window Make sure you are running the current version of Sierra Chart which is currently 2908. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2026-05-19 14:19:11
