Date/Time: Wed, 25 Nov 2026 21:56:21 +0000
Continuous contracts not being displayed/downloaded
View Count: 1768
[2025-12-19 14:16:07]
User994149 - Posts: 9
Hi there,
Earlier today I activated the Denali data feed and my service package. I have set my charts to be continuous contract - volume based rollover. The charts load and I am able to see the data, but they are not being merged with the prior contracts. So for example, on ESH26 I am only able to see data up until 12/14/2025. When looking at my data folder, I can see that there is an ESZ25-CME.scid file (previous contract) but it is only 1KB in size, vs the 200,791KB of my ESH26-CME.scid file. Therefore, it appears to me that the continuous data is not being downloaded, despite saying that it is downloading continuous contract data when I load my charts. It is worth noting as well that this data is in showing in real time, there is no 15 minute delay, so I am sure that I am no longer on the trial package and it is the Denali data feed that is being used. Any help here would be appreciated.
Thank you.
[2025-12-19 14:50:38]
Follow the instructions here:
[2025-12-19 15:13:59]
Thank you for the quick response. I have followed those instructions and can see that the ESZ25-CME.scid file now has a significant amount of data in it, however this is not reflected on the charts. The data on the charts is still only loading until 12/14/2025. I can confirm that the data limiting "days to load" is set to 15 days, so I should be seeing more than this.
[2025-12-19 15:31:53]
Scroll to the beginning of the chart, and provide an image of the chart , by following these *exact* instructions:
Date Time Of Last Edit: 2025-12-19 15:32:21
[2025-12-19 15:43:30]
https://www.sierrachart.com/image.php?Image=1766158948737.png
[2025-12-19 17:02:41]
https://www.sierrachart.com/image.php?Image=1766163617908.png
If I increase the days to load to 50 and then redownload the data then more data does show on the chart, however, all of the data between 11/11/25 and 12/14/25 is still missing. Hopefully this information will help with understanding what the cause of the issue is.
[2025-12-19 17:33:13]
It seems to be working now after following the instructions in this thread:
Missing Data on Continuous Contract
[2025-12-19 17:51:41]
You only need to follow these instructions:
